[Mapbender-commits] r9884 - trunk/mapbender/http/extensions/mobilemap2/scripts/netgis
svn_mapbender at osgeo.org
Fri Mar 16 04:23:40 PDT 2018
Author: armin11
Date: 2018-03-16 04:23:40 -0700 (Fri, 16 Mar 2018)
New Revision: 9884
trunk/mapbender/http/extensions/mobilemap2/scripts/netgis/config.js
Adopt configuration to rhineland-palatinate
Modified: trunk/mapbender/http/extensions/mobilemap2/scripts/netgis/config.js
--- trunk/mapbender/http/extensions/mobilemap2/scripts/netgis/config.js 2018-03-16 09:24:21 UTC (rev 9883)
+++ trunk/mapbender/http/extensions/mobilemap2/scripts/netgis/config.js 2018-03-16 11:23:40 UTC (rev 9884)
@@ -15,12 +15,12 @@
MAP_CONTAINER_ID: "map-container",
/** Initial map center coordinate x in main map projection. */
- INITIAL_CENTER_X: 330101,
+ INITIAL_CENTER_X: 385000,
/** Initial map center coordinate y in main map projection. */
- INITIAL_CENTER_Y: 5513986,
+ INITIAL_CENTER_Y: 5543000,
/** Initial map zoom scale (e.g. 10000 = 1:10000). */
- INITIAL_SCALE: 100000,
+ INITIAL_SCALE: 1500000,
MAP_SCALES: [ 500, 1000, 3000, 5000, 8000, 10000, 15000, 25000, 50000, 100000, 150000, 250000, 500000, 1000000, 1500000, 2000000 ],
/** List of available map projections (identifier and proj4 definition). */
@@ -51,4 +51,4 @@
URL_BACKGROUND_HYBRID: "http://www.gdi-rp-dienste2.rlp.de/mapcache/tms/1.0.0/test@UTM32",
URL_BACKGROUND_AERIAL: "http://geo4.service24.rlp.de/wms/dop_basis.fcgi"
\ No newline at end of file
More information about the Mapbender_commits
