[Mapbender-commits] r9889 - trunk/mapbender/http/php
svn_mapbender at osgeo.org svn_mapbender at osgeo.org
Mon Mar 26 05:18:55 PDT 2018
Author: armin11
Date: 2018-03-26 05:18:55 -0700 (Mon, 26 Mar 2018)
New Revision: 9889
   trunk/mapbender/http/php/mod_showOpenDataOrganizations.php
Fix
Modified: trunk/mapbender/http/php/mod_showOpenDataOrganizations.php
--- trunk/mapbender/http/php/mod_showOpenDataOrganizations.php	2018-03-26 10:12:53 UTC (rev 9888)
+++ trunk/mapbender/http/php/mod_showOpenDataOrganizations.php	2018-03-26 12:18:55 UTC (rev 9889)
@@ -1,7 +1,9 @@
 <?php
 require_once(dirname(__FILE__)."/../../core/globalSettings.php");
 $showOnlyDatasetMetadata = "false";
+$showOnlyUnlinkedOrganizations = "false";
 //params: opendata licenses, only metadata, ....
 if (isset($_REQUEST["showOnlyDatasetMetadata"]) & $_REQUEST["showOnlyDatasetMetadata"] != "") {
 	$testMatch = $_REQUEST["showOnlyDatasetMetadata"];
  	if (!($testMatch == 'true' or $testMatch == 'false')){
@@ -18,6 +20,26 @@
 	$testMatch = NULL;
+if (isset($_REQUEST["showOnlyUnlinkedOrganizations"]) & $_REQUEST["showOnlyUnlinkedOrganizations"] != "") {
+	$testMatch = $_REQUEST["showOnlyUnlinkedOrganizations"];
+ 	if (!($testMatch == 'true' or $testMatch == 'false')){
+		echo 'Parameter <b>showOnlyUnlinkedOrganizations</b> is not valid (true,false (default to false)).<br/>';
+		die();
+	switch ($testMatch) {
+		case "true":
+			$showOnlyUnlinkedOrganizations = "true";
+		break;
+		case "false":
+			$showOnlyUnlinkedOrganizations = "false";
+		break;
+	$testMatch = NULL;
 $sql = <<<SQL
 select opendata.*, mb_group.uuid, mb_group_id, mb_group_title, mb_group_description, mb_group_homepage, mb_group_logo_path, mb_group_address, mb_group_postcode, mb_group_city, mb_group_email, timestamp, mb_group.mb_group_ckan_uuid from mb_group, (select (sum(count_wms_layer)+sum(count_metadata)) as number_of_opendata_ressources, group_id,mb_group_name from (
@@ -45,17 +67,50 @@
 SQL;
+$sql3 = <<<SQL
+select opendata.*, mb_group.uuid, mb_group_id, mb_group_title, mb_group_description, mb_group_homepage, mb_group_logo_path, mb_group_address, mb_group_postcode, mb_group_city, mb_group_email, timestamp, mb_group.mb_group_ckan_uuid from mb_group, (select (sum(count_wms_layer)+sum(count_metadata)) as number_of_opendata_ressources, group_id,mb_group_name from (
+select count(open_published_layers.layer_id) as count_wms_layer, 0 as count_metadata,open_published_layers.group_id, mb_group_name from (select layer_id, group_id, mb_group_name from layer , (select wms_group.count, mb_group_name,group_id, wms_id from mb_group, (select count(wms_id) ,f_get_responsible_organization_for_ressource(wms_id, 'wms') as group_id,wms_id  from wms where wms_id in (select fkey_wms_id from wms_termsofuse where fkey_termsofuse_id in (select termsofuse_id from termsofuse where isopen = 1)) group by group_id, wms_id) as wms_group where mb_group.mb_group_id = wms_group.group_id AND mb_group.export2ckan = TRUE AND (mb_group.mb_group_ckan_uuid IS NOT NULL) ) as open_published_wms where layer.fkey_wms_id = open_published_wms.wms_id and layer_searchable = 1 and export2csw is true ) as open_published_layers left join ows_relation_metadata on open_published_layers.layer_id = ows_relation_metadata.fkey_layer_id where fkey_layer_id is null group by open_published_layers.gr
 oup_id, open_published_layers.mb_group_name
+union
+select count_wms_layer, metadata_group.count_metadata, group_id,mb_group_name from mb_group, (select count(metadata_id) as count_metadata, 0 as count_wms_layer , f_get_responsible_organization_for_ressource(metadata_id, 'metadata') as group_id from mb_metadata where searchable is true and export2csw is true and metadata_id in (select fkey_metadata_id from md_termsofuse where fkey_termsofuse_id in (select termsofuse_id from termsofuse where isopen = 1)) group by group_id) as metadata_group where mb_group.mb_group_id = metadata_group.group_id AND mb_group.export2ckan = TRUE AND (mb_group.mb_group_ckan_uuid IS NOT NULL)
+) as opendata_ressources group by group_id, mb_group_name) as opendata
+where opendata.group_id = mb_group.mb_group_id
+SQL;
+$sql4 = <<<SQL
+SQL;
 switch ($showOnlyDatasetMetadata) {
 	case "true":
-		$result = db_query($sql2);
+		if ($showOnlyUnlinkedOrganizations == "true") {
+			$result = db_query($sql4);
+		} else {
+			$result = db_query($sql2);
 		break;
 	case "false":
-		$result = db_query($sql);
+			$result = db_query($sql3);
+		} else {
+			$result = db_query($sql);
 		break;
-$result = db_query($sql);
 $returnObject = array();
 while ($row = db_fetch_array($result)) {
More information about the Mapbender_commits mailing list
