[Mapbender-commits] r9987 - trunk/mapbender/http/classes
    svn_mapbender at osgeo.org
    Fri Nov  2 02:06:19 PDT 2018
Author: armin11
Date: 2018-11-02 02:06:19 -0700 (Fri, 02 Nov 2018)
New Revision: 9987
   trunk/mapbender/http/classes/class_iso19139.php
Option to allow the bulk update of external metadata records without changing their owner and organization
Modified: trunk/mapbender/http/classes/class_iso19139.php
--- trunk/mapbender/http/classes/class_iso19139.php	2018-10-29 15:36:38 UTC (rev 9986)
+++ trunk/mapbender/http/classes/class_iso19139.php	2018-11-02 09:06:19 UTC (rev 9987)
@@ -2264,19 +2264,20 @@
 		return $dlArray;
-	public function updateMetadataById($metadataId) {
+	public function updateMetadataById($metadataId, $changeAuthorization=true) {
 		$e = new mb_notice("update metadata id: ".$metadataId);
 		//check if the timestamp of an existing metadata element is not newer than the timestamp of the current metadata object!!!!
 		//TODO
 		//problem: <<<SQL have a limited number of chars!
-		$sql = "UPDATE mb_metadata SET link = $1, origin = $18, md_format = $2, data = $3, ";
-		$sql .= "linktype = $4, uuid = $5, title = $6, createdate = $7, changedate = $8, lastchanged = now(), ";
-		$sql .= "abstract = $9, searchtext = $10, type = $11, tmp_reference_1 = $12, tmp_reference_2 = $13, export2csw = $14, datasetid = $15, ";
-		$sql .= "datasetid_codespace = $16, randomid = $17, harvestresult = $20, harvestexception = $21, lineage = $22, inspire_top_consistence = $23, ";
-		$sql .= "spatial_res_type = $24, spatial_res_value = $25, update_frequency = $26, format = $27, inspire_charset = $28, ref_system = $29, the_geom = $30, datalinks = $31, inspire_whole_area = $32, inspire_actual_coverage = $33, inspire_download = $34, bounding_geom = $35, transfer_size = $36, fees = $37, md_license_source_note = $38, constraints = $39, responsible_party_name = $40, responsible_party_email = $41, preview_image = $42, fkey_mb_group_id = $43, md_proxy = $44, inspire_interoperability = $45, searchable = $46 WHERE metadata_id = $19";
-		//$e= new mb_exception("class_iso19139.php: downloadLinks json".$this->jsonEncodeDownloadLinks($this->downloadLinks));
-		//$e= new mb_exception("class_iso19139.php: downloadLinks[0]".$this->downloadLinks[0]);
-		$v = array(
+		if ($changeAuthorization == true) {
+		    $sql = "UPDATE mb_metadata SET link = $1, origin = $18, md_format = $2, data = $3, ";
+		    $sql .= "linktype = $4, uuid = $5, title = $6, createdate = $7, changedate = $8, lastchanged = now(), ";
+		    $sql .= "abstract = $9, searchtext = $10, type = $11, tmp_reference_1 = $12, tmp_reference_2 = $13, export2csw = $14, datasetid = $15, ";
+		    $sql .= "datasetid_codespace = $16, randomid = $17, harvestresult = $20, harvestexception = $21, lineage = $22, inspire_top_consistence = $23, ";
+		    $sql .= "spatial_res_type = $24, spatial_res_value = $25, update_frequency = $26, format = $27, inspire_charset = $28, ref_system = $29, the_geom = $30, datalinks = $31, inspire_whole_area = $32, inspire_actual_coverage = $33, inspire_download = $34, bounding_geom = $35, transfer_size = $36, fees = $37, md_license_source_note = $38, constraints = $39, responsible_party_name = $40, responsible_party_email = $41, preview_image = $42, fkey_mb_group_id = $43, md_proxy = $44, inspire_interoperability = $45, searchable = $46 WHERE metadata_id = $19";
+		    //$e= new mb_exception("class_iso19139.php: downloadLinks json".$this->jsonEncodeDownloadLinks($this->downloadLinks));
+		    //$e= new mb_exception("class_iso19139.php: downloadLinks[0]".$this->downloadLinks[0]);
+		    $v = array(
 			$this->href,
 			$this->format,
 			$this->metadata,
@@ -2324,10 +2325,70 @@
 			$this->mdProxy,
 			$this->inspireInteroperability,
 			$this->searchable
-		//$e = new mb_exception("class_iso19139: ".$this->createWktBboxFromArray($this->wgs84Bbox));
-		$t = array('s','s','s','s','s','s','s','s','s','s','s','s','s','b','s','s','s','s','i','i','s','s','b','s','s','s','s','s','s','POLYGON','s','s','s','i','POLYGON','d','s','s','s','s','s','s','i','b','b','b');
-		$res = db_prep_query($sql,$v,$t);
+		    //$e = new mb_exception("class_iso19139: ".$this->createWktBboxFromArray($this->wgs84Bbox));
+		    $t = array('s','s','s','s','s','s','s','s','s','s','s','s','s','b','s','s','s','s','i','i','s','s','b','s','s','s','s','s','s','POLYGON','s','s','s','i','POLYGON','d','s','s','s','s','s','s','i','b','b','b');
+		    $res = db_prep_query($sql,$v,$t);
+		} else { //do the update without changing owner and fkey_mb_group_id!
+		    $sql .= "spatial_res_type = $24, spatial_res_value = $25, update_frequency = $26, format = $27, inspire_charset = $28, ref_system = $29, the_geom = $30, datalinks = $31, inspire_whole_area = $32, inspire_actual_coverage = $33, inspire_download = $34, bounding_geom = $35, transfer_size = $36, fees = $37, md_license_source_note = $38, constraints = $39, responsible_party_name = $40, responsible_party_email = $41, preview_image = $42, md_proxy = $43, inspire_interoperability = $44, searchable = $45 WHERE metadata_id = $19";
+		    $v = array(
+			$this->href,
+			$this->format,
+			$this->metadata,
+			$this->type,
+			$this->fileIdentifier, // is the old one! or not?
+			$this->title,
+			$this->createDate,
+			$this->changeDate,
+			$this->abstract,
+			$this->keywords[0],
+			$this->hierachyLevel,
+			$this->tmpExtentBegin,
+			$this->tmpExtentEnd,
+			$this->export2Csw,
+			$this->datasetId,
+			$this->datasetIdCodeSpace,
+			$this->randomId,
+			$this->origin,
+			//$this->owner, //owner is the old one - maybe here we have something TODO!
+			$metadataId, //The first metadataId which was found will be selected!
+			$this->harvestResult,
+			$this->harvestException,
+			$this->lineage,
+			$this->inspireTopConsistence,
+			$this->spatialResType,
+			$this->spatialResValue,
+			$this->updateFrequency,
+			$this->dataFormat,
+			$this->inspireCharset,
+			$this->refSystem,
+			$this->createWktBboxFromArray($this->wgs84Bbox),
+			$this->jsonEncodeDownloadLinks($this->downloadLinks),
+			$this->inspireWholeArea,
+			$this->inspireActualCoverage,
+			$this->inspireDownload,
+			$this->createWktPolygonFromPointArray($this->polygonalExtentExterior),
+			$this->transferSize,
+			$this->fees,
+			$this->licenseSourceNote,
+			$this->accessConstraints,
+			$this->resourceResponsibleParty,
+			$this->resourceContactEmail,
+			$this->previewImage,
+			$this->mdProxy,
+			$this->inspireInteroperability,
+			$this->searchable
+		    $t = array('s','s','s','s','s','s','s','s','s','s','s','s','s','b','s','s','s','s','i','i','s','s','b','s','s','s','s','s','s','POLYGON','s','s','s','i','POLYGON','d','s','s','s','s','s','s','b','b','b');
 		return $res;
More information about the Mapbender_commits
