[Mapbender-commits] r9991 - trunk/mapbender/resources/db
svn_mapbender at osgeo.org
Wed Nov 7 03:06:07 PST 2018
Author: armin11
Date: 2018-11-07 03:06:07 -0800 (Wed, 07 Nov 2018)
New Revision: 9991
trunk/mapbender/resources/db/install_geoportal_mb28.sh
New version with configured php error log
Modified: trunk/mapbender/resources/db/install_geoportal_mb28.sh
--- trunk/mapbender/resources/db/install_geoportal_mb28.sh 2018-11-06 07:36:07 UTC (rev 9990)
+++ trunk/mapbender/resources/db/install_geoportal_mb28.sh 2018-11-07 11:06:07 UTC (rev 9991)
@@ -75,11 +75,11 @@
use_proxy="true"
-http_proxy_host="proxyip" # TODO: adopt!!!
-http_proxy_port="proxyport" # TODO: adopt!!!
+http_proxy_host="proxyip"
+http_proxy_port="proxyport"
-https_proxy_host="proxyip" # TODO: adopt!!!
-https_proxy_port="proxyport" # TODO: adopt!!!
+https_proxy_host="proxyip"
+https_proxy_port="proxyport"
# what should be done
@@ -144,8 +144,20 @@
# mysql root password: mysqlroot - normally debian-sys-maint
# after install - 1.9GB!!!
+# adopt php logging - only log errors
+cp /etc/php5/cli/php.ini /etc/php5/cli/php.ini_geoportal_backup
+cp /etc/php5/apache2/php.ini /etc/php5/apache2/php.ini_geoportal_backup
+sed -i "s/error_reporting = E_ALL & ~E_DEPRECATED & ~E_STRICT/error_reporting = E_ERROR/g" /etc/php5/cli/php.ini
+sed -i "s/;error_log = php_errors.log/error_log = \/tmp\/php5_cli_errors\.log/g" /etc/php5/cli/php.ini
+sed -i "s/error_reporting = E_ALL & ~E_DEPRECATED & ~E_STRICT/error_reporting = E_ERROR/g" /etc/php5/apache2/php.ini
+sed -i "s/;error_log = php_errors.log/error_log = \/tmp\/php5_apache_errors\.log/g" /etc/php5/apache2/php.ini
# set some environment variables
if [ $use_proxy = 'true' ]; then
@@ -1077,6 +1089,9 @@
rm -R ${installation_folder}portal
rm -R ${installation_folder}svn
rm -R ${installation_folder}conf
+rm -R ${installation_folder}access
+rm -R ${installation_folder}db_backup
rm ${installation_folder}geoportal_database_adoption_1.sql
rm ${installation_folder}geoportal_database_adoption_2.sql
@@ -1101,6 +1116,14 @@
echo "Backup version of file exists - overwrite it with the original one"
cp /etc/apache2/conf-available/phppgadmin.conf_backup_geoportal /etc/apache2/conf-available/phppgadmin.conf
fi
+if [ -e "/etc/php5/apache2/php.ini_geoportal_backup" ]; then
+ echo "Backup version of file exists - overwrite it with the original one"
+ cp /etc/php5/apache2/php.ini_geoportal_backup /etc/php5/apache2/php.ini
+fi
+if [ -e "/etc/php5/cli/php.ini_geoportal_backup" ]; then
+ cp /etc/php5/cli/php.ini_geoportal_backup /etc/php5/cli/php.ini
+fi
rm *.tar.gz*
rm *.sql
rm -R ${installation_folder}cronjobs
More information about the Mapbender_commits
