[Mapbender-commits] r9993 - trunk/mapbender/resources/db
svn_mapbender at osgeo.org
Wed Nov 7 07:10:59 PST 2018
Author: armin11
Date: 2018-11-07 07:10:59 -0800 (Wed, 07 Nov 2018)
New Revision: 9993
trunk/mapbender/resources/db/install_geoportal_mb28.sh
Some more fixes
Modified: trunk/mapbender/resources/db/install_geoportal_mb28.sh
--- trunk/mapbender/resources/db/install_geoportal_mb28.sh 2018-11-07 11:08:12 UTC (rev 9992)
+++ trunk/mapbender/resources/db/install_geoportal_mb28.sh 2018-11-07 15:10:59 UTC (rev 9993)
@@ -95,6 +95,9 @@
install_mapbender_database="true"
install_typo3_database="true"
+checkout_mapbender_conf="true"
+install_mapbender_conf="true"
configure_mapbender="true"
configure_typo3="true"
configure_apache="true"
@@ -103,7 +106,7 @@
# other svn to checkout - installation specific
-checkout_custom_svn="true"
+checkout_custom_svn="false"
custom_svn_url="http://www.gdi-rp-dienste.rlp.de/svn/de-rp-landau/data"
# set some environment variables
@@ -188,7 +191,9 @@
if [ $checkout_mapbender_svn = 'true' ]; then
svn co https://svn.osgeo.org/mapbender/trunk/mapbender
fi
+if [ $checkout_mapbender_conf = 'true' ]; then
+ svn co http://www.gdi-rp-dienste.rlp.de/svn/de-rp/data/conf
+fi
if [ $checkout_custom_svn = 'true' ]; then
svn co $custom_svn_url
fi
@@ -236,6 +241,20 @@
echo 'done.'
fi
+# compress and create typo3
+if [ $install_mapbender_conf = 'true' ]; then
+ cd ${installation_folder}svn/
+ tar -czf conf.tar.gz conf/
+ mv conf.tar.gz /tmp/
+ mv /tmp/conf.tar.gz .
+ tar -xzf conf.tar.gz
+ svn info http://www.gdi-rp-dienste.rlp.de/svn/de-rp/data/conf | grep Revision | grep -Eo '[0-9]{1,}' > ${installation_folder}conf/lastinstalled
+ rm conf.tar.gz
+ echo 'done.'
+fi
# compress and create custom conf files
@@ -260,8 +279,6 @@
rm custom.tar.gz
echo 'done.'
fi
# cleanup .svn relicts
@@ -348,7 +365,10 @@
EOF
service postgresql restart
+cp /etc/phppgadmin/config.inc.php /etc/phppgadmin/config.inc.php_geoportal_backup
+sed -i "s/conf\['extra_login_security'\] = true/conf\['extra_login_security'\] = false/g" /etc/phppgadmin/config.inc.php
sudo -u postgres psql -p $mapbender_database_port -d $mapbender_database_name -c 'CREATE SCHEMA mapbender'
sudo -u postgres psql -p $mapbender_database_port -d $mapbender_database_name -c 'ALTER DATABASE mapbender SET search_path TO mapbender,public,pg_catalog,topology'
@@ -654,7 +674,7 @@
cat << EOF > ${installation_folder}mapbender/tools/monitorCapabilities.sh
. /etc/profile
cd ${installation_folder}mapbender/tools/
-[ -f /tmp/wmsmonitorlock ] && : || php5 ${installation_folder}mapbender/tools/mod_monitorCapabilities_main.php group:${mapbender_subadmin_group_id} > /dev/null
+[ -f /tmp/wmsmonitorlock ] && : || /usr/bin/php5 ${installation_folder}mapbender/tools/mod_monitorCapabilities_main.php group:${mapbender_subadmin_group_id} > /dev/null
EOF
# register initial services for default and extended search GUIs
@@ -669,7 +689,7 @@
eval $wms_6_register_cmd
fi
-if [ $checkout_custom_svn = 'true' ]; then
+if [ $checkout_custom_svn = 'true' ] || [$checkout_mapbender_conf]; then
# override information in custom conf files
# mapbender.conf
@@ -1033,7 +1053,7 @@
( crontab -l | grep -v -F "$croncmd5" ; echo "$cronjob5" ) | crontab -
# 6. run ows scheduler - to update ows capabilities
-croncmd6="php5 ${installation_folder}mapbender/tools/mod_runScheduler.php"
+croncmd6="/usr/bin/php5 ${installation_folder}mapbender/tools/mod_runScheduler.php"
cronjob6="57 23 * * * $croncmd6"
( crontab -l | grep -v -F "$croncmd6" ; echo "$cronjob6" ) | crontab -
@@ -1124,6 +1144,11 @@
echo "Backup version of file exists - overwrite it with the original one"
cp /etc/php5/cli/php.ini_geoportal_backup /etc/php5/cli/php.ini
fi
+if [ -e "/etc/phppgadmin/config.inc.php_geoportal_backup" ]; then
+ echo "Backup version of file exists - overwrite it with the original one"
+ cp /etc/phppgadmin/config.inc.php_geoportal_backup /etc/phppgadmin/config.inc.php
+fi
rm *.tar.gz*
rm *.sql
rm -R ${installation_folder}cronjobs
More information about the Mapbender_commits
