[Mapbender-commits] r9966 - in trunk/mapbender/http: classes javascripts php
svn_mapbender at osgeo.org
Fri Sep 28 06:29:57 PDT 2018
Author: armin11
Date: 2018-09-28 06:29:56 -0700 (Fri, 28 Sep 2018)
New Revision: 9966
trunk/mapbender/http/classes/class_user.php
trunk/mapbender/http/classes/class_wmc.php
trunk/mapbender/http/javascripts/initWmcObj.php
trunk/mapbender/http/javascripts/mod_loadwmc.js
trunk/mapbender/http/php/mod_loadwmc_server.php
New option to remove layers without permission from wmc xml before it will be loaded into some gui. New element var for loadwmc module: removeUnaccessableLayers - should be 1 to remove the layers!
Modified: trunk/mapbender/http/classes/class_user.php
--- trunk/mapbender/http/classes/class_user.php 2018-09-28 06:46:41 UTC (rev 9965)
+++ trunk/mapbender/http/classes/class_user.php 2018-09-28 13:29:56 UTC (rev 9966)
@@ -775,6 +775,46 @@
return ($row = db_fetch_array($res)) ? true : false;
+ public function getAccessableLayers ($layerIdArray) {
+ if (gettype($layerIdArray) !== "array" || (gettype($layerIdArray) == "array" && count($layerIdArray) == 0) ) {
+ return array(0);
+ $array_guis = $this->getApplicationsByPermission();
+ $v = array();
+ $t = array();
+ $sql = "SELECT DISTINCT fkey_layer_id FROM gui_layer WHERE fkey_gui_id IN (";
+ $c = 1;
+ for ($i = 0; $i < count($array_guis); $i++) {
+ if ($i > 0) {
+ $sql .= ",";
+ $sql .= "$".$c;
+ $c++;
+ array_push($v, $array_guis[$i]);
+ array_push($t, 's');
+ $sql .= ") AND fkey_layer_id IN (";
+ $j = 0;
+ foreach ($layerIdArray as $layerId) {
+ if ($j > 0) {
+ $sql .= ",";
+ $sql .= "$".$c;
+ $c++;
+ $j++;
+ array_push($v, $layerId);
+ array_push($t, 'i');
+ $sql .= ") AND gui_layer_status = 1";
+ $res = db_prep_query($sql,$v,$t);
+ $allowedLayerIdArray = array();
+ while ($row = db_fetch_array($res)) {
+ $allowedLayerIdArray[] = $row["fkey_layer_id"];
+ return $allowedLayerIdArray;
public function isWmsAccessible ($wms_id) {
Modified: trunk/mapbender/http/classes/class_wmc.php
--- trunk/mapbender/http/classes/class_wmc.php 2018-09-28 06:46:41 UTC (rev 9965)
+++ trunk/mapbender/http/classes/class_wmc.php 2018-09-28 13:29:56 UTC (rev 9966)
@@ -538,6 +538,7 @@
* function to update the information about wms in a mapbender wmc object and stores it in the database
* actually layer names and getmap urls are updated by the given mapbender layer id, also the dataurl entries are created or
* if a layer has related metadata for which download options are available
* @return WMC as XML or false.
public function updateUrlsFromDb() {
@@ -799,6 +800,61 @@
$e = new mb_notice((string)($endTime - $startTime));
return $updatedWMC;
+ public function removeUnaccessibleLayers($wmcXml) {
+ $currentUser = new User(Mapbender::session()->get("mb_user_id"));
+ //declare xpath to pull all layer with given ids from stored wmc docs
+ $query_mbLayerId = "/wmc:ViewContext/wmc:LayerList/wmc:Layer/wmc:Extension/mapbender:layer_id";
+ libxml_use_internal_errors(true);
+ try {
+ $WMCDoc = simplexml_load_string($wmcXml);
+ if ($WMCDoc === false) {
+ foreach(libxml_get_errors() as $error) {
+ $err = new mb_exception("class_wmc:".$error->message);
+ throw new Exception("class_wmc:".'Cannot parse WMC XML!');
+ return false;
+ catch (Exception $e) {
+ $err = new mb_exception("class_wmc:".$e->getMessage());
+ return false;
+ //register relevant namespaces
+ $WMCDoc->registerXPathNamespace("wmc","http://www.opengis.net/context");
+ $WMCDoc->registerXPathNamespace("mapbender","http://www.mapbender.org/context");
+ $WMCDoc->registerXPathNamespace("xlink","http://www.w3.org/1999/xlink");
+ //pull out List of layer objects
+ $layerIdList = $WMCDoc->xpath($query_mbLayerId);
+ $e = new mb_notice(count($layerIdList));
+ //remove layers without permisssion
+ $checkLayerPermission = true;
+ //check for accessible layers with ids
+ if ($checkLayerPermission && gettype($layerIdList) == "array" && count($layerIdList) > 0) {
+ $allowedLayerArray = $currentUser->getAccessableLayers($layerIdList);
+ if (gettype($allowedLayerArray) == "array" && count($allowedLayerArray) > 0) {
+ } else {
+ $allowedLayerArray = array();
+ $allowedLayerArray[] = 0;
+ //iterate over all layers with id and remove layer with an id that is not in $allowedLayerArray!
+ foreach($layerIdList as $layerId) {
+ $queryPath = "/wmc:ViewContext/wmc:LayerList/wmc:Layer[wmc:Extension/mapbender:layer_id='".(integer)$layerId."']";
+ foreach($WMCDoc->xpath($queryPath) as $layer) {
+ if (in_array($layerId, $allowedLayerArray)) {
+ $e = new mb_notice("user is allowed to access layer ".$layerId);
+ } else {
+ $e = new mb_notice("user is not allowed to access layer ".$layerId);
+ unset($layer[0][0]);
+ return $WMCDoc->saveXML();
* Stores this WMC in the database. The WMC has to be instantiated first, see above.
Modified: trunk/mapbender/http/javascripts/initWmcObj.php
--- trunk/mapbender/http/javascripts/initWmcObj.php 2018-09-28 06:46:41 UTC (rev 9965)
+++ trunk/mapbender/http/javascripts/initWmcObj.php 2018-09-28 13:29:56 UTC (rev 9966)
@@ -149,6 +149,14 @@
$e = new mb_exception("initWmcObj.php: ERROR while loading wmc from session - test creating wmc from app: " . $app);
$wmc->createFromApplication($app);
+$removeUnaccessableLayers = false;
+$removeUnaccessableLayers = new ElementVar($app, "loadwmc", "removeUnaccessableLayers");
+if ($wmcDocSession && $removeUnaccessableLayers->value === "1") {
+ $removeUnaccessableLayers = true;
//TODO: if no GET API is given then don't do the following things
// create new WMC with services from GET API
@@ -531,6 +539,12 @@
//TODO test following
//workaround to have a fully merged WMC for loading
$xml = $wmcGetApi->toXml();
+if ($removeUnaccessableLayers == true) {
+ //$e = new mb_exception("try to remove layers without permission while loading from session!");
+ $xml = $wmcGetApi->removeUnaccessibleLayers($xml);
//$e = new mb_exception("initWmcObj.php: XML after merging json: ".$xml);
$wmcGetApi = new wmc();
//debug
Modified: trunk/mapbender/http/javascripts/mod_loadwmc.js
--- trunk/mapbender/http/javascripts/mod_loadwmc.js 2018-09-28 06:46:41 UTC (rev 9965)
+++ trunk/mapbender/http/javascripts/mod_loadwmc.js 2018-09-28 13:29:56 UTC (rev 9966)
@@ -2,6 +2,7 @@
options.checkLayerIdExists = options.checkLayerIdExists ? true : false;
options.checkLayerIdValid = options.checkLayerIdValid ? true : false;
options.checkLayerPermission = options.checkLayerPermission ? true : false;
+options.removeUnaccessableLayers = options.removeUnaccessableLayers ? options.removeUnaccessableLayers : 0;
options.checkLayerAvailability = options.checkLayerAvailability ? true : false;
options.loadWmc = typeof options.loadWmc === "number" ? options.loadWmc : 1;
options.mergeWmc = typeof options.mergeWmc === "number" ? options.mergeWmc : 0;
@@ -554,7 +555,8 @@
return createTableCell(
$.extend({
parameters: {
- id: wmc.id
+ id: wmc.id,
+ removeUnaccessableLayers: options.removeUnaccessableLayers
}, LOAD_WMC_OPTIONS),
loadMergeAppendCallback
Modified: trunk/mapbender/http/php/mod_loadwmc_server.php
--- trunk/mapbender/http/php/mod_loadwmc_server.php 2018-09-28 06:46:41 UTC (rev 9965)
+++ trunk/mapbender/http/php/mod_loadwmc_server.php 2018-09-28 13:29:56 UTC (rev 9966)
@@ -89,13 +89,19 @@
break;
- // loads a WMC (returns array of JS code)
+ //loads a WMC (returns array of JS code)
case 'loadWmc':
$wmcId = $ajaxResponse->getParameter("id");
+ $removeUnaccessableLayers = $ajaxResponse->getParameter("removeUnaccessableLayers");
if ($wmc->createFromDb($wmcId)) {
$updatedWMC = $wmc->updateUrlsFromDb();
- $wmc->createFromXml($updatedWMC);
+ if ($removeUnaccessableLayers == 1) {
+ //new 2018-09-27 - delete unaccessible layers if wished!
+ $accessibleWmcXml = $wmc->removeUnaccessibleLayers($updatedWMC);
+ $wmc->createFromXml($accessibleWmcXml);
+ } else {
+ $wmc->createFromXml($updatedWMC);
$skipWms = $ajaxResponse->getParameter("skipWms");
if (is_array($skipWms)) {
$jsArray = $wmc->toJavaScript($skipWms);
More information about the Mapbender_commits
