[Mapbender-commits] r10193 - in trunk/mapbender/http: classes php
svn_mapbender at osgeo.org
Fri Aug 2 00:01:58 PDT 2019
Author: armin11
Date: 2019-08-02 00:01:58 -0700 (Fri, 02 Aug 2019)
New Revision: 10193
trunk/mapbender/http/classes/class_cswClient.php
trunk/mapbender/http/php/mod_callCswMetadata.php
First fix for spatial search via csw: https://ies-svn.jrc.ec.europa.eu/issues/3658
Modified: trunk/mapbender/http/classes/class_cswClient.php
--- trunk/mapbender/http/classes/class_cswClient.php 2019-08-01 09:32:44 UTC (rev 10192)
+++ trunk/mapbender/http/classes/class_cswClient.php 2019-08-02 07:01:58 UTC (rev 10193)
@@ -140,7 +140,7 @@
$postRequest .= '<csw:Query typeNames="csw:Record">';
$postRequest .= '<csw:ElementSetName>full</csw:ElementSetName>'; //full to get all queryables?
if ($recordtype !== false) {
- $postRequest .= '<csw:Constraint version="1.0.0">';
+ $postRequest .= '<csw:Constraint version="1.1.0">';
$postRequest .= '<ogc:Filter>';
if ($additionalFilter !== false) {
$postRequest .= '<ogc:And>';
@@ -178,7 +178,7 @@
$postRequest .= '</csw:Constraint>';
} else {
$postRequest .= $additionalFilter;
$postRequest .= '</ogc:Filter>';
@@ -211,7 +211,7 @@
$postRequest = '<?xml version="1.0" encoding="UTF-8"?>';
$postRequest .= '<csw:Transaction service="CSW" version="2.0.2" xmlns:csw="http://www.opengis.net/cat/csw/2.0.2" xmlns:ogc="http://www.opengis.net/ogc" xmlns:apiso="http://www.opengis.net/cat/csw/apiso/1.0" xmlns:gml="http://www.opengis.net/gml">';
$postRequest .= '<csw:Delete>';
$postRequest .= '<ogc:PropertyIsLike wildCard="%" singleChar="_" escapeChar="/">';
$postRequest .= ' <ogc:PropertyName>apiso:Identifier</ogc:PropertyName>';
@@ -231,7 +231,7 @@
@@ -261,7 +261,7 @@
} else {
@@ -288,7 +288,7 @@
//$postRequest .= '<csw:ElementSetName>summary</csw:ElementSetName>';
@@ -318,7 +318,7 @@
} else {
@@ -498,7 +498,7 @@
$cswInterfaceObject = new connector();
$cswInterfaceObject->set('httpType','POST');
$postData = stripslashes($postData);
- //$e = new mb_exception("classes/class_cswClient.php: post xml: ".$postData);
+ $e = new mb_exception("classes/class_cswClient.php: post xml: ".$postData);
$dataXMLObject = new SimpleXMLElement($postData);
$postData = $dataXMLObject->asXML();
//$e = new mb_exception($postData);
Modified: trunk/mapbender/http/php/mod_callCswMetadata.php
--- trunk/mapbender/http/php/mod_callCswMetadata.php 2019-08-01 09:32:44 UTC (rev 10192)
+++ trunk/mapbender/http/php/mod_callCswMetadata.php 2019-08-02 07:01:58 UTC (rev 10193)
@@ -237,6 +237,7 @@
echo 'Mandatory parameter <b>catalogueId</b> not set!<br/>';
die();
+//example: &searchBbox=7.18159618172,50.2823608933,7.26750846535,50.3502633407
if (isset($_REQUEST["searchBbox"]) & $_REQUEST["searchBbox"] != "") {
//validate to float/integer
$testMatch = $_REQUEST["searchBbox"];
@@ -530,10 +531,18 @@
$spatialFilter .= "<ogc:BBOX>";
$spatialFilter .= "<ogc:PropertyName>BoundingBox</ogc:PropertyName>";
- $spatialFilter .= '<gml:Box xmlns:gml="http://www.opengis.net/gml" srsName="EPSG:4326">';
+ /*$spatialFilter .= '<gml:Box xmlns:gml="http://www.opengis.net/gml" srsName="EPSG:4326">';
$spatialFilter .= '<gml:coordinates decimal="." cs="," ts=" ">';
$spatialFilter .= $searchBboxArray[0].','.$searchBboxArray[1].' '.$searchBboxArray[2].','.$searchBboxArray[3];
- $spatialFilter .= '</gml:coordinates></gml:Box>';
+ $spatialFilter .= '</gml:coordinates></gml:Box>';*/
+ //Exchanged to support INSPIRE Discovery service: https://ies-svn.jrc.ec.europa.eu/issues/3658
+ $spatialFilter .= '<gml:Envelope srsName="EPSG:4326">';
+ $spatialFilter .= '<gml:lowerCorner>'.$searchBboxArray[0].' '.$searchBboxArray[1].'</gml:lowerCorner>';
+ $spatialFilter .= '<gml:upperCorner>'.$searchBboxArray[2].' '.$searchBboxArray[3].'</gml:upperCorner>';
+ $spatialFilter .= '</gml:Envelope>';
switch ($searchTypeBbox) {
case "intersect":
$spatialFilter .= "</ogc:BBOX>";
@@ -555,7 +564,7 @@
$additionalFilter = "<ogc:And>".$fullTextFilter.$spatialFilter."</ogc:And>";
} else {
if ($searchText == '' || $searchText == '*') {
- $additionalFilter = false;
+ $additionalFilter = $spatialFilter;
} else {
$additionalFilter = $fullTextFilter;
More information about the Mapbender_commits
