[Mapbender-commits] r10200 - trunk/mapbender/http/php
    svn_mapbender at osgeo.org
    Thu Aug  8 00:02:34 PDT 2019
Author: armin11
Date: 2019-08-08 00:02:34 -0700 (Thu, 08 Aug 2019)
New Revision: 10200
   trunk/mapbender/http/php/mod_linkedDataProxy.php
Fix for Linked Open Data Proxy
Modified: trunk/mapbender/http/php/mod_linkedDataProxy.php
--- trunk/mapbender/http/php/mod_linkedDataProxy.php	2019-08-07 09:58:45 UTC (rev 10199)
+++ trunk/mapbender/http/php/mod_linkedDataProxy.php	2019-08-08 07:02:34 UTC (rev 10200)
@@ -4,6 +4,7 @@
 require_once(dirname(__FILE__)."/../classes/class_universal_wfs_factory.php");
 require_once(dirname(__FILE__)."/../classes/class_gml_3_factory.php");
 require_once(dirname(__FILE__)."/../classes/class_owsConstraints.php");
+require_once(dirname(__FILE__)."/../classes/class_connector.php");//for resolving external @context content
 //http://localhost/mapbender/devel_tests/wfsClientTest.php?wfsid=16&ft=vermkv:fluren_rlp&bbox=7.9,50.8,8.0,52
 //initialize some parameter
 $limit = 10;
@@ -11,7 +12,7 @@
 //$maxObjectsPerPage = 10;
 //default page
 $page = 0;
-//default format f
+//default format f is html
 $f = "html";
 //parameter to control if the native json should be requested from the server, if support for geojson is available!
 $nativeJson = false;
@@ -224,9 +225,9 @@
 if (!isset($wfsid) || $wfsid == "") {
     //list all public available wfs which are classified as opendata!
     $returnObject->service = array();
-    $sql = "SELECT * FROM (SELECT wfs_id, wfs_version, wfs_abstract, wfs_title, wfs_owsproxy, fkey_termsofuse_id, wfs_getcapabilities, providername, fees FROM wfs INNER JOIN wfs_termsofuse ON wfs_id = fkey_wfs_id) AS wfs_tou INNER JOIN termsofuse ON fkey_termsofuse_id = termsofuse_id WHERE isopen = 1";
+    //$sql = "SELECT * FROM (SELECT wfs_id, wfs_version, wfs_abstract, wfs_title, wfs_owsproxy, fkey_termsofuse_id, wfs_getcapabilities, providername, fees FROM wfs INNER JOIN wfs_termsofuse ON wfs_id = fkey_wfs_id) AS wfs_tou INNER JOIN termsofuse ON fkey_termsofuse_id = termsofuse_id WHERE isopen = 1";
     //all wfs - without open filter!
-    //$sql = "SELECT wfs_id, wfs_abstract, wfs_version, wfs_title, wfs_owsproxy, wfs_getcapabilities, providername, fees FROM wfs";
+    $sql = "SELECT wfs_id, wfs_abstract, wfs_version, wfs_title, wfs_owsproxy, wfs_getcapabilities, providername, fees FROM wfs";
     $v = array();
     $t = array();
     $res = db_prep_query($sql, $v, $t);
@@ -239,14 +240,6 @@
         $returnObject->service[$i]->provider = $row['providername'];
         $returnObject->service[$i]->license = $row['fees'];
 	$returnObject->service[$i]->accessUrl = $row['wfs_getcapabilities'];
-        //get contraints
-        $constraints = new OwsConstraints();
-        $constraints->languageCode = "de";
-        $constraints->asTable = true;
-        $constraints->id = $returnObject->service[$i]->id;
-        $constraints->type = "wfs";
-        $constraints->returnDirect = false;
-        //$returnObject->service[$i]->tou = json_encode($constraints->getDisclaimer());//TODO encoding problems occur!
         $i++;
     if ($i == 0) {
@@ -281,6 +274,17 @@
 	    //$returnObject->providerHomepage = $wfs->homepage; //TODO add to ows class!
             $returnObject->providerHomepage = "http://www.geoportal.rlp.de/";
 	    $returnObject->license = $wfs->fees;
+	//get contraints
+        $constraints = new OwsConstraints();
+        $constraints->languageCode = "de";
+        $constraints->asTable = true;
+        $constraints->id = $wfsid;
+        $constraints->type = "wfs";
+        $constraints->returnDirect = false;
+        $tou = $constraints->getDisclaimer();//TODO encoding problems occur!
+	//$returnObject->license = $tou; - generate license info in json for json format!!!!!
 	    $returnObject->accessUrl = $wfs->getCapabilities;
 	    $returnObject->links = array();
@@ -774,6 +778,15 @@
 			$usedProxyTime = microtime_float() - $proxyStartTime;
 			$returnObject = $geojsonList->features[0];
+			//integrate json-ld @context if it is resovable!*******************************************************************************
+			/*$ldContextConnector = new Connector();
+			$url = "http://localhost/mapbender/geoportal/".str_replace(":","__",$ftName).".jsonld";
+			$file = $ldContextConnector->load($url);
+//$e = new mb_exception($file);
+			$contextObject = json_decode($file);
+//$e = new mb_exception(json_encode($contextObject));
+			$returnObject->properties->{'@context'} = $contextObject->{'@context'};*/
 			//add service title and collection title for navigation
 			//for rlp
 			$returnObject->serviceTitle = $wfs->title;
@@ -916,19 +929,19 @@
             $html .= '</ol>';
 	} else {
 	    if (!isset($collection) || $collections == 'all') {
-	        $html .= '<li class="breadcrumb-item"><a href="'.delTotalFromQuery("wfsid", $_SERVER['REQUEST_URI']).'">Datasets</a></li>'.$newline; //TODO - use base uri
+	        $html .= '<li class="breadcrumb-item"><a href="'.rtrim(delTotalFromQuery(array("f","wfsid"), $_SERVER['REQUEST_URI']),'?').'">Datasets</a></li>'.$newline; //TODO - use base uri
                 $html .= '<li class="breadcrumb-item active">'.$returnObject->title.'</li>'.$newline;
                 $html .= '</ol>';
 	    } else {
 		if (!isset($item) || $items == 'all') {
-		    $html .= '<li class="breadcrumb-item"><a href="'.delTotalFromQuery(array("wfsid","collection","collections","item","items","limit","offset","bbox"), $_SERVER['REQUEST_URI']).'">Datasets</a></li>'.$newline; //TODO - use base uri
-                    $html .= '<li class="breadcrumb-item"><a href="'.delTotalFromQuery(array("collection","collections","item","items","limit","offset","bbox"), $_SERVER['REQUEST_URI']).'">'.$returnObject->serviceTitle.'</a></li>'.$newline;
+		    $html .= '<li class="breadcrumb-item"><a href="'.rtrim(delTotalFromQuery(array("f","wfsid","collection","collections","item","items","limit","offset","bbox"), $_SERVER['REQUEST_URI']),'?').'">Datasets</a></li>'.$newline; //TODO - use base uri
+                    $html .= '<li class="breadcrumb-item"><a href="'.rtrim(delTotalFromQuery(array("f","collection","collections","item","items","limit","offset","bbox"), $_SERVER['REQUEST_URI']),'?').'">'.$returnObject->serviceTitle.'</a></li>'.$newline;
                     $html .= '<li class="breadcrumb-item active">'.$returnObject->collectionTitle.'</li>'.$newline;
                     $html .= '</ol>';
 		} else {
-		    $html .= '<li class="breadcrumb-item"><a href="'.delTotalFromQuery(array("item","limit","offset","bbox"), $_SERVER['REQUEST_URI']).'&items=all'.'">'.$returnObject->collectionTitle.'</a></li>'.$newline;
+		    $html .= '<li class="breadcrumb-item"><a href="'.rtrim(delTotalFromQuery(array("f","item","limit","offset","bbox"), $_SERVER['REQUEST_URI']),'?').'&items=all'.'">'.$returnObject->collectionTitle.'</a></li>'.$newline;
                     $html .= '<li class="breadcrumb-item active">'.$returnObject->id.'</li>'.$newline;
                     $html .= '</ol>';
@@ -936,11 +949,11 @@
 	    // other formats ! for collection, item, ...
 	    //if (!isset($item)) {
                 $html .= '<ul class="list-separated m-0 p-0 text-muted">'.$newline;
-                $html .= '    <li><a href="'.delTotalFromQuery("f", $_SERVER['REQUEST_URI']).'&f=json" target="_blank">GeoJSON</a></li>'.$newline;
+                $html .= '    <li><a href="'.rtrim(delTotalFromQuery("f", $_SERVER['REQUEST_URI']),'?').'&f=json" target="_blank">GeoJSON</a></li>'.$newline;
 		if (isset($collection) || $collections == 'all') {
-                    $html .= '    <li><a href="'.delTotalFromQuery("f", $_SERVER['REQUEST_URI']).'&f=xml" target="_blank">GML</a></li>'.$newline;
+                    $html .= '    <li><a href="'.rtrim(delTotalFromQuery("f", $_SERVER['REQUEST_URI']),'?').'&f=xml" target="_blank">GML</a></li>'.$newline;
 		} else {
-			$html .= '    <li><a href="'.delTotalFromQuery("f", $_SERVER['REQUEST_URI']).'&f=xml" target="_blank">XML</a></li>'.$newline;
+			$html .= '    <li><a href="'.rtrim(delTotalFromQuery("f", $_SERVER['REQUEST_URI']),'?').'&f=xml" target="_blank">XML</a></li>'.$newline;
                 $html .= '</ul> '.$newline;
@@ -973,7 +986,7 @@
 	    foreach ($returnObject->service as $service) {
 	        $html .= '            <li itemprop="dataset" itemscope itemtype="http://schema.org/Dataset">'.$newline;
                 $html .= '                <h2>'.$newline;
-                $html .= '                    <a itemprop="url" href="'.$_SERVER['REQUEST_URI'].'&wfsid='.$service->id.'">'.$newline;
+                $html .= '                    <a itemprop="url" href="'.rtrim($_SERVER['REQUEST_URI'],'?').'?wfsid='.$service->id.'">'.$newline;
                 $html .= '                        <span itemprop="name">'.$service->title.'</span>'.$newline;
                 $html .= '                    </a>'.$newline;
                 $html .= '                </h2>'.$newline;
@@ -1174,7 +1187,11 @@
 				foreach($feature->properties as $key=>$value) {
 				    $html .= '                        <div class="row my-1">'.$newline;
 				    $html .= '                            <div class="col-md-6 font-weight-bold text-truncate" title="'.$key.'">'.$key.'</div>'.$newline;
-				    $html .= '                            <div class="col-md-6" >'.string2html($value).'</div>'.$newline;
+				    if (gettype($value) == "string") {
+				        $html .= '                            <div class="col-md-6" >'.string2html($value).'</div>'.$newline;
+				    } else {
+					$html .= '                            <div class="col-md-6" >'.json_encode($value).'</div>'.$newline;
 				    $html .= '                        </div>'.$newline;
@@ -1193,7 +1210,11 @@
+                            } else {
More information about the Mapbender_commits
