[Mapbender-commits] r10204 - in trunk/mapbender/http: frames javascripts
svn_mapbender at osgeo.org
Fri Aug 9 01:30:04 PDT 2019
Author: armin11
Date: 2019-08-09 01:30:03 -0700 (Fri, 09 Aug 2019)
New Revision: 10204
Added:
trunk/mapbender/http/frames/home.php
trunk/mapbender/http/javascripts/mod_home.php
Alter target for home button to new page
Added: trunk/mapbender/http/frames/home.php
--- trunk/mapbender/http/frames/home.php (rev 0)
+++ trunk/mapbender/http/frames/home.php 2019-08-09 08:30:03 UTC (rev 10204)
@@ -0,0 +1,75 @@
+<?php
+# This program is free software; you can redistribute it and/or modify
+# it under the terms of the GNU General Public License as published by
+# the Free Software Foundation; either version 2, or (at your option)
+# any later version.
+# This program is distributed in the hope that it will be useful,
+# but WITHOUT ANY WARRANTY; without even the implied warranty of
+# MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the
+# GNU General Public License for more details.
+# You should have received a copy of the GNU General Public License
+# along with this program; if not, write to the Free Software
+# Foundation, Inc., 59 Temple Place - Suite 330, Boston, MA 02111-1307, USA.
+require_once(dirname(__FILE__)."/../php/mb_validateSession.php");
+require_once(dirname(__FILE__)."/../php/mb_listGUIs.php");
+<!DOCTYPE HTML PUBLIC "-//W3C//DTD HTML 4.01 Transitional//EN">
+<html>
+<head>
+Licensing: See the GNU General Public License for more details.
+http://www.gnu.org/copyleft/gpl.html
+or:
+mapbender/licence/
+<meta http-equiv="cache-control" content="no-cache">
+<meta http-equiv="pragma" content="no-cache">
+<meta http-equiv="expires" content="0">
+<META http-equiv="Content-Style-Type" content="text/css">
+<META http-equiv="Content-Script-Type" content="text/javascript">
+<?php
+echo '<meta http-equiv="Content-Type" content="text/html; charset='.CHARSET.'">';
+<title>Home</title>
+<script type="text/javascript" src="../extensions/jquery-ui-1.8.1.custom/js/jquery-1.4.2.min.js"></script>
+<script type="text/javascript" src="../extensions/jquery-ui-1.8.1.custom/js/jquery-ui-1.8.1.custom.min.js"></script>
+<script type="text/javascript" src="../extensions/jquery-ui-1.8.1.custom/development-bundle/ui/jquery.ui.tabs.js"></script>
+<link rel="stylesheet" type="text/css" href="../extensions/jquery-ui-1.8.1.custom/development-bundle/themes/base/jquery.ui.all.css" />
+<link rel="stylesheet" type="text/css" href="../extensions/jquery-ui-1.8.1.custom/development-bundle/themes/base/jquery.ui.tabs.css" />
+<?php
+$css_folder = "";
+echo "<link rel=\"stylesheet\" type=\"text/css\" href=\"../css/" . $css_folder . "login.css\">";
+echo "<link rel=\"shortcut icon\" href=\"../img/favicon.ico\">";
+echo "<script type='text/javascript'>";
+echo "<!--". chr(13).chr(10);
+echo "function setFocus(){";
+ echo "if(document.loginForm){";
+ echo "document.loginForm.name.focus();";
+ echo "}";
+echo "}";
+echo "// -->". chr(13).chr(10);
+echo "</script>";
+<script type='text/javascript'>
+$(document).ready(function () {
+ $(function() {
+ $("#guiListTabs").tabs({
+ event: 'click'
+</script>
+<?php
+echo "</head>";
+echo "<body onload='setFocus()'>";
+//get array of available guis
+require_once(dirname(__FILE__)."/../php/mb_getGUIs.php");
+$arrayGUIs = mb_getGUIs(Mapbender::session()->get("mb_user_id"));
+mb_listGUIs($arrayGUIs);
+</body>
+</html>
Modified: trunk/mapbender/http/javascripts/mod_home.php
--- trunk/mapbender/http/javascripts/mod_home.php 2019-08-08 09:58:26 UTC (rev 10203)
+++ trunk/mapbender/http/javascripts/mod_home.php 2019-08-09 08:30:03 UTC (rev 10204)
@@ -19,21 +19,9 @@
function mod_home_init(){
<?php
-echo "var url = '".LOGIN."';";
-echo "var name = '".urlencode(Mapbender::session()->get("mb_user_name"))."';";
-echo "var pw = '".Mapbender::session()->get("mb_user_password")."';";
+echo "var url = '".str_replace('login.php', 'home.php', LOGIN)."';";
+//echo "var name = '".urlencode(Mapbender::session()->get("mb_user_name"))."';";
+//echo "var pw = '".Mapbender::session()->get("mb_user_password")."';";
- var str = "<form name='myGuiList_form' method='POST' action='' target='_self'>";
- str += "<input type='hidden' name='name' value='"+name+"' />";
- str += "<input type='hidden' name='password' value='"+pw+"' />";
- str += "</form>";
- var mod_home_div = document.createElement('div');
- mod_home_div.setAttribute("id","mod_home_d");
- var tmp = document.body.appendChild(mod_home_div);
- document.getElementById("mod_home_d").innerHTML = str;
- document.forms.myGuiList_form.action = url;
- document.forms.myGuiList_form.submit();
- //document.location.href = url + "?name=" + name + "&password=" + pw;
\ No newline at end of file
+ document.location.href = url;
More information about the Mapbender_commits
