[Mapbender-commits] r10207 - trunk/mapbender/http/classes
svn_mapbender at osgeo.org
Tue Aug 13 03:09:48 PDT 2019
Author: hollsandre
Date: 2019-08-13 03:09:48 -0700 (Tue, 13 Aug 2019)
New Revision: 10207
trunk/mapbender/http/classes/class_administration.php
added phpmailer for php7
Modified: trunk/mapbender/http/classes/class_administration.php
--- trunk/mapbender/http/classes/class_administration.php 2019-08-13 05:57:52 UTC (rev 10206)
+++ trunk/mapbender/http/classes/class_administration.php 2019-08-13 10:09:48 UTC (rev 10207)
@@ -21,9 +21,15 @@
require_once(dirname(__FILE__)."/class_cache.php");
require_once dirname(__FILE__) . "/../../tools/wms_extent/extent_service.conf";
# changed to Version 6.0.2 due to dprecated/removed functionality (php7+) TODO - check invokation of new class !!!!
-require(dirname(__FILE__) . "/phpmailer-1.72/class.phpmailer.php");
-#require(dirname(__FILE__) . "/phpmailer-6.0.2/src/PHPMailer.php");
+$phpversion = phpversion();
+if (strpos($phpversion, "7.") === 0) {
+ //use new mailer
+ require(dirname(__FILE__) . "/phpmailer-6.0.2/src/PHPMailer.php");
+ require(dirname(__FILE__) . "/phpmailer-6.0.2/src/SMTP.php");
+ require(dirname(__FILE__) . "/phpmailer-6.0.2/src/Exception.php");
+} else {
+ require(dirname(__FILE__) . "/phpmailer-1.72/class.phpmailer.php");
* class to wrap administration methods
@@ -30,6 +36,7 @@
* @uses phpmailer
class administration {
* checks whether the passed email-address is valid / following a pattern
* @todo is this an exact representation of the RFC 2822?
@@ -39,6 +46,19 @@
* @param <string> a all lowercase email adress to test
* @return <boolean> answer to "is the passed over email valid?""
+ function getPhpVersion() {
+ return phpversion();
+ * checks whether the passed email-address is valid / following a pattern
+ * @todo is this an exact representation of the RFC 2822?
+ * @todo this should be checked: what about umlaut-domains and tld like '.museum'?
+ * @see http://tools.ietf.org/html/rfc2822
+ * @param <string> a all lowercase email adress to test
+ * @return <boolean> answer to "is the passed over email valid?""
function isValidEmail($email) {
if(mb_eregi("^[_a-z0-9-]+(\.[_a-z0-9-]+)*@[a-z0-9-]+(\.[a-z0-9-]+)*(\.[a-z]{2,3})$", $email)) {
return true;
@@ -89,19 +109,27 @@
if ($this->isValidEmail($fromAddr) && $this->isValidEmail($toAddr)) {
- $mail = new PHPMailer();
+ $phpversion = $this->getPhpVersion();
+ if (strpos($phpversion, "7.") === 0) {
+ //use new mailer
+ $mail = new PHPMailer\PHPMailer\PHPMailer();
+ $mail->SMTPOptions = array(
+ 'ssl' => array(
+ 'verify_peer' => false,
+ 'verify_peer_name' => false,
+ 'allow_self_signed' => true
+ $mail->Port = 25;
+ } else {
+ $mail = new PHPMailer();
if ($fromName != "" ) {
$mail->FromName = $fromName;
$mail->IsSMTP(); // set mailer to use SMTP
$mail->Host = $mailHost; // specify main and backup server
- $mail->SMTPAuth = true; // turn on SMTP authentication
- $mail->Username = $mailUsername; // SMTP username
- $mail->Password = $mailPassword; // SMTP password
- $mail->From = $fromAddr;
+ $mail->setFrom($fromAddr,$fromName);
$mail->AddAddress($toAddr, $toName);
#$mail->AddReplyTo("info at ccgis.de", "Information");
More information about the Mapbender_commits
