[Mapbender-commits] r10218 - trunk/mapbender/http/geoportal
svn_mapbender at osgeo.org svn_mapbender at osgeo.org
Mon Aug 26 08:22:19 PDT 2019
Author: armin11
Date: 2019-08-26 08:22:19 -0700 (Mon, 26 Aug 2019)
New Revision: 10218
   trunk/mapbender/http/geoportal/gaz_geom_mobile.php
New gazetteer client module for the german gazetteer of the Federal Agency for Cartography and Geodesy - conf file with access key needed!
Modified: trunk/mapbender/http/geoportal/gaz_geom_mobile.php
--- trunk/mapbender/http/geoportal/gaz_geom_mobile.php	2019-08-26 09:38:01 UTC (rev 10217)
+++ trunk/mapbender/http/geoportal/gaz_geom_mobile.php	2019-08-26 15:22:19 UTC (rev 10218)
@@ -1,30 +1,8 @@
 <?php
-# $Id$
-# http://www.mapbender.org/index.php/gaz_service.php
-# Copyright (C) 2002 CCGIS
-# This program is free software; you can redistribute it and/or modify
-# it under the terms of the GNU General Public License as published by
-# the Free Software Foundation; either version 2, or (at your option)
-# any later version.
-# This program is distributed in the hope that it will be useful,
-# but WITHOUT ANY WARRANTY; without even the implied warranty of
-# MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE.  See the
-# GNU General Public License for more details.
-# You should have received a copy of the GNU General Public License
-# along with this program; if not, write to the Free Software
-# Foundation, Inc., 59 Temple Place - Suite 330, Boston, MA 02111-1307, USA.
 require_once(dirname(__FILE__)."/../../core/globalSettings.php");
-require_once(dirname(__FILE__)."/../../conf/geoportal.conf");
-require_once(dirname(__FILE__)."/../classes/class_mb_exception.php");
-require_once(dirname(__FILE__)."/../classes/class_json.php");
-//Check if the result should be delivered as a webservice
-IF ($_REQUEST['resultTarget'] != 'web') {
+require_once(dirname(__FILE__)."/../classes/class_connector.php");
+require_once(dirname(__FILE__)."/../../conf/bkgGeocoding.conf");
+if ($_REQUEST['resultTarget'] != 'web') {
 	(isset($_SERVER["argv"][1]))? ($user_id = $_SERVER["argv"][1]) : ($e = new mb_exception("geom: user lacks!"));
 	(isset($_SERVER["argv"][2]))? ($sstr = $_SERVER["argv"][2]) : ($e = new mb_exception("geom: string lacks!"));
 	(isset($_SERVER["argv"][3]))? ($epsg = $_SERVER["argv"][3]) : ($e = new mb_exception("geom: epsg lacks!"));
@@ -32,7 +10,7 @@
 } else {
 	$maxResults = 15; //set default
 	$outputFormat = 'json'; //set default
-	$epsg = 25832;
+	$searchEPSG = 4326;
 	if (isset($_REQUEST["maxResults"]) & $_REQUEST["maxResults"] != "") {
 		//validate integer to 100 - not more
@@ -83,767 +61,61 @@
 	$epsg = $searchEPSG;
 	$searchThruWeb = true;
-$e = new mb_notice("maxResults: ".$maxResults);
-$con = pg_connect("host=".GEOMDB_HOST." port=".GEOMDB_PORT." dbname=".GEOMDB_NAME." user=".GEOMDB_USER." password=".GEOMDB_PASSWORD)
-or die('Verbindungsaufbau fehlgeschlagen: ' . pg_last_error());
-function replaceChars($text){
-//	$search = array( "ä",  "ö",  "ü",  "Ä",  "Ö",  "Ü", "tr.", "ß" );
-//	$repwith = array("ae", "oe", "ue", "AE", "OE", "UE", "tr","ss");
-	//if(CHARSET=="UTF-8")
-	//	$text = utf8_decode($text);
-//	$ret = str_replace($search, $repwith, $text);
-	//	$ret = utf8_encode($ret);
-//	return $ret;
-	return $text;
-/******* conf ***********************************/
-$factor = 1;
-if (intval($epsg) == 4326) $factor = 0.00001;
-/******* wohnplätze *******************/
-$bufferWP = 1000*$factor;
-$arrayWP = array();
-$arrayWPKey = array();
-/******* gemeinde *********************/
-$bufferG = 100*$factor;
-$arrayG = array();
-$toleranceG = 100*$factor;
-/******* kreis *********************/
-$bufferK = 100*$factor;
-$arrayK = array();
-$toleranceK = 1000*$factor;
-/******* verbandsgemeinde *********************/
-$bufferV = 100*$factor;
-$arrayV = array();
-$toleranceV = 1000*$factor;
-/******* strasse *********************/
-$bufferSTR = 175*$factor;
-$arraySTR = array();
-$toleranceSTR = 100*$factor;
-/******* Strasse / Hsnr ****************/
-$bufferSH = 75*$factor;
-$arraySH = array();
-$toleranceSH = 1000*$factor;
-$e = new mb_notice("gaz_geom_mobile was invoked with string:".$sstr);
-/****** Workflow *********************************/
-$test = str_replace("ß", "ss", $sstr);
-$e = new mb_notice("replaced test string: ".$test);
-$astr = mbw_split(",",replaceChars($sstr));
-$e = new mb_notice("replaced string: ".$astr[0]." ".$astr[1]." ".$astr[2]);
-//if only one string without any comma is given
-if(count($astr) == 1){
-	$astr[0] = trim($astr[0]);
-	$e = new mb_notice("gaz_geom_mobile: only one string detected: ".$astr[0]);
-	//check if there may be a postal code
-	$plz = getPlz($astr[0]);
-	//check if there is a housenumber
-	$hsnr = getNr($astr[0]);
-	if($plz != false){
-		//checkSize($astr[0]);
-		checkWP($plz, strtoupper(getCity($astr[0])));
-		checkGfromWP();
+//$searchText = "fall 10, mend";
+$key = BKG_GEOCODING_KEY;
+$basUrl1 = "https://sg.geodatenzentrum.de/gdz_geokodierung__";
+$basUrl2 = "/geosearch?query=";
+$maxFeatures = 15;
+//exchange some letters
+//$e = new mb_exception("searchText1: ".$searchText);
+$searchText= str_replace('ß', 'SS', str_replace('Ü', 'UE', str_replace('Ä', 'AE', str_replace('Ö', 'OE', mb_strtoupper($searchText)))));
+//$e = new mb_exception("searchText2: ".$searchText);
+$invokeUrl = $basUrl1.$key.$basUrl2.$searchText."&srsName=EPSG%3A".$searchEPSG;
+$searchConnector = new connector($invokeUrl);
+$searchResult = $searchConnector->file;
+$gazetteerObject = json_decode($searchResult);
+//parse json
+$returnObject = new stdClass();
+$countGeonames = 0;
+$returnObject->totalResultsCount = 0;
+foreach ($gazetteerObject->features as $feature) {
+	switch ($feature->properties->typ) {
+		//Landkreis/Gemeinde/Wohnplatz/Haus
+		case "Haus":
+			$returnObject->geonames[$countGeonames]->title = $feature->properties->text." ("."Haus".")";
+			$returnObject->geonames[$countGeonames]->category = "haus";
+			break;
+		case "Geoname":
+		        $returnObject->geonames[$countGeonames]->title = $feature->properties->text;
+			break;
+		case "Strasse":
+			$returnObject->geonames[$countGeonames]->title = $feature->properties->text." ("."Straße".")";
+			$returnObject->geonames[$countGeonames]->category = "str";
+			break;
+		case "Ort":
+		        $returnObject->geonames[$countGeonames]->title = $feature->properties->text." ("."Ort".")";
+			break;
+		default:
+			break;
-	else if($hsnr != false){
-	else if($hsnr == false && $plz == false){
-		checkWP(false,strtoupper($astr[0]));
-		checkG(strtoupper($astr[0]));
-		checkGfromWP();
-		checkK(strtoupper($astr[0]));
-		checkVg($astr[0]);
+	$returnObject->geonames[$countGeonames]->minx = str_replace(',', '.', $feature->bbox[0]);
+	$returnObject->geonames[$countGeonames]->miny = str_replace(',', '.',$feature->bbox[1]);
+	$returnObject->geonames[$countGeonames]->maxx = str_replace(',', '.',$feature->bbox[2]);
+	$returnObject->geonames[$countGeonames]->maxy = str_replace(',', '.',$feature->bbox[3]);
+	$countGeonames++;
-//if 2 parts are given - the first one may be a combined or a single value
-// '56743 mendig' or 'ferdinand-sauerbruch-strasse 15' or 'koblenz' or 'mendig' or, or, or ...
-else if(count($astr) == 2){
-	$e = new mb_notice("gaz_geom_mobile: two strings detected: ".$astr[0]." and ".$astr[1]);
-	$astr[1] = trim($astr[1]);
-	$ckeys = array();
-	$cnames = array();
-	$cmissing = array();
-	$myplz = false;
-	$mycity = false;
-	$mystr = false;
-	$mynr = false;
-	$myzs = false;
-	$both = array();
-	// check first entry for postal code
-	if(getPlz($astr[0])){
-		$myplz = getPlz($astr[0]);
-		$e = new mb_notice("gaz_geom_mobile: postalcode detected: ".$myplz);
-		if(getNr($astr[1])){
-			$mynr = getNr($astr[1]);
-			$myzs = getAppendix($astr[1]);
-			$mystr = getStrn($astr[1]);
-		else{
-			$mystr = trim($astr[1]);
-	//check first entry for number
-	else if(getNr($astr[0])){
-		$mynr = getNr($astr[0]);
-		$myzs = getAppendix($astr[0]);
-		$mystr = getStrn($astr[0]);
-		$e = new mb_notice('gaz_geom_mobile: search for streetname: '.$mystr);
-		//check if in second value there is a postalcode
-		if(getPlz($astr[1])){
-			$myplz = getPlz($astr[1]);
-		//maybe it will be a city name
-		else{
-			$mycity = trim($astr[1]);
-			$e = new mb_notice('gaz_geom_mobile: search for city: '.$mycity);
-	//check second for postal code
-	else{
-			$mycity = getCity($astr[0]);
-		else{
-			array_push($both,$astr[0]);
-			array_push($both,$astr[1]);
-	// workflow
-	if(count($both) == 2){
-		$a = "%".strtoupper(trim($both[0]))."%";
-		$b = "%".strtoupper(trim($both[1]))."%";
-		//$a = strtoupper(trim($both[0]))."%";
-		//$b = strtoupper(trim($both[1]))."%";
+$returnObject->totalResultsCount = $countGeonames;
-		$v = array($a, $a);
-		$t = array('s', 's');
-		$sql = "SELECT DISTINCT * FROM (SELECT DISTINCT gem_schl_neu, gemeinde_neu AS gem FROM gemeinden ";
-		$sql .= "WHERE gemeinde_upper LIKE $1";
-		$sql .= "UNION SELECT DISTINCT gem_schl_neu, gemeinde_gem_teile AS gem FROM wohnplatz ";
-		$sql .= "WHERE ewz_int IS NOT NULL AND  gemeinde_gem_teile_upper LIKE $2";
-		$sql .= ") AS str";
-		$res = db_prep_query($sql,$v,$t);
-		while($row = db_fetch_array($res)){
-			array_push($ckeys, $row['gem_schl_neu']);
-			array_push($cnames, encode($row['gem']));
-			array_push($cmissing, $b);
-		$v = array($b, $b);
-		$sql .= "WHERE gemeinde_upper LIKE $1 ";
-			array_push($cmissing, $a);
-		if(count($ckeys)>0){
-			for($i=0; $i<count($ckeys); $i++){
-				$v = array($ckeys[$i], $cmissing[$i]);
-				$t = array('i', 's');
-				$sql = "SELECT DISTINCT strassenname, ";
-				$sql .= "SRID(the_geom) AS srid, AsGML(the_geom) AS gml ,";
-				$sql .= "(xmin(the_geom) - ".$bufferSTR.") as minx, ";
-				$sql .= "(ymin(the_geom) - ".$bufferSTR.") as miny, ";
-				$sql .= "(xmax(the_geom) + ".$bufferSTR.") as maxx, ";
-				$sql .= "(ymax(the_geom) + ".$bufferSTR.") as maxy ";
-				$sql .= "FROM strassenschluessel WHERE gem_schl = $1 ";
-				$sql .= " AND (strassenname_upper LIKE $2)";
-				if (isset($epsg) && is_numeric($epsg) && intval($epsg) != 25832) {
-					$sql = str_replace("the_geom", "transform(the_geom,".$epsg.")", $sql);
-					$show = encode($row["strassenname"])."  ".$cnames[$i];
-					$e = new mb_notice('gaz_geom_mobile: street found: '.$row["strassenname"]);
-					stack_it($arraySTR,"str",$show,"str",$row["srid"],$row["minx"],$row["miny"],$row["maxx"],$row["maxy"],$row["gml"]);
-	else{
-//	echo $myplz ."#";
-//	echo $mycity ."#";
-//	echo $mystr ."#";
-//	echo $mynr ."#";
-//	echo $myzs ."#";
-//	print_r($both);
-		checkSH($mystr,$mynr,$myzs,$myplz,$mycity);
-//$fillSH = checkSH("Akazienweg",30,false,56075,"Koblenz");
-xml_output();
-function checkMinLength($str) {
-	global $searchThruWeb;
-	if (strlen($str) < 3) {
-		if ($searchThruWeb) {
-		//errorOutput();
-			null_json_output();
-		} else {
-			null_output();
-		die();
+if ($returnObject->totalResultsCount == 0) {
+	$returnObject->geonames = array();
-//Strasse Hausnummer
-function checkSH($s,$h,$z,$p,$o){
-	global $bufferSH, $arraySH, $epsg;
-	if ($o && $s) {
-		$str_schl = array();
-		$str_schl_gem = array();
-		$ckeys = array();
-		$a = "%".strtoupper(trim($o))."%";
-		$sql .=") AS str";
-			array_push($cnames, $row['gem']);
-				$v = array($ckeys[$i], "%". strtoupper(trim($s)). "%");
-				//$v = array($ckeys[$i], strtoupper(trim($s)). "%");
-				$sql = "SELECT DISTINCT strassenschluessel ";
-				$sql .= " AND strassenname_upper ILIKE $2";
-					array_push($str_schl, $row['strassenschluessel']);
-					$e = new mb_notice('gaz_geom_mobile: strassenschluessel: '.$row["strassenname"].' for '.$s.' found' );
-					array_push($str_schl_gem, $cnames[$i]);
-			//select all streetkeys
-			if (count($str_schl > 0)) {
-				$v = array($h);
-				$t = array('i');
-				$sql = "SELECT DISTINCT name, hausnummer, zusatz, plz, post_ortsname, ";
-				$sql .= "(xmin(the_geom) - ".$bufferSH.") as minx, ";
-				$sql .= "(ymin(the_geom) - ".$bufferSH.") as miny, ";
-				$sql .= "(xmax(the_geom) + ".$bufferSH.") as maxx, ";
-				$sql .= "(ymax(the_geom) + ".$bufferSH.") as maxy ";
-				$sql .= "FROM hauskoordinaten ";
-				$sql .= "WHERE hausnummer = $1 AND strschl_gesamt IN (";
-				for($i=0; $i<count($str_schl); $i++){
-					if($i > 0){$sql .= ",";}
-					$sql .= "$".($i+2);
-					array_push($v,$str_schl[$i]);
-					array_push($t,'i');
-				$sql .= ")";
-#$show = $row["name"]." ".$row["hausnummer"];
-				if($row["zusatz"] != 'null'){
-				#	$show .= $row["zusatz"];
-$show = $row["name"]." ".$row["hausnummer"].$row["zusatz"];
-//$show = $row["name"]." ".$row["hausnummer"].$row["zusatz"]; TODO: exchange this, when the hauskoordinaten table is delivered in a homogenous encoding!
+if (isset($callback) && $callback != '') {
+	$returnJson = $callback."(".json_encode($returnObject).")";
+} else {
+	$returnJson = json_encode($returnObject);
-	else
-{$show =  $row["name"]." ".$row["hausnummer"];}
-		$show .= ", " . $row["plz"]. " " . $row["post_ortsname"];
-	stack_it($arraySH,"haus",$show,"sh",$row["srid"],$row["minx"],$row["miny"],$row["maxx"],$row["maxy"],$row["gml"]);
-	else {
-		//is this 'else' obsolete?
-		$sql .= "WHERE name ILIKE $1 AND hausnummer = $2 ";
-		$v = array("%".$s."%",$h);
-		//$v = array($s."%",$h);
-		$t = array('s','i');
-		if($z){
-			$sql .= "AND zusatz = $" . (count($v)+1);
-			array_push($v,$z);
-			array_push($t,'s');
-		if($p){
-			$sql .= "AND plz = $" . (count($v)+1);
-			array_push($v,$p);
-		if($o){
-			$sql .= "AND post_ortsname ILIKE $" . (count($v)+1);
-			array_push($v,"%".$o."%");
-		#$sql .= " GROUP BY the_geom, name, hausnummer, zusatz, plz, post_ortsname";
-			$show = $row["name"]." ".$row["hausnummer"];
-			$e = new mb_notice('gaz_geom_mobile.php: streetname2: '.$row["name"]);
-			//$show = $row["name"]." ".$row["hausnummer"]; TODO: see above
-			if($row["zusatz"] != null){
-				$show .= $row["zusatz"];
-	return true;
-//Wohnplatz
-function checkWP($plz,$name){
-	global $bufferWP, $arrayWP, $arrayWPKey, $epsg;
-	$v = array();
-	$t = array();
-	checkMinLength($name);
-	$sql = "SELECT DISTINCT gemeinde_gem_teile, gem_schl_neu, postleitzahl,";
-	$sql .= "(xmin(the_geom) - ".$bufferWP.") as minx, ";
-	$sql .= "(ymin(the_geom) - ".$bufferWP.") as miny, ";
-	$sql .= "(xmax(the_geom) + ".$bufferWP.") as maxx, ";
-	$sql .= "(ymax(the_geom) + ".$bufferWP.") as maxy ";
-	$sql .= "FROM wohnplatz WHERE ";
-	if($plz == false){
-		$sql .= "gemeinde_gem_teile_upper ILIKE $1 ";
-		array_push($v,"%".$name."%");
-	else if($name == false){
-		$sql .= "postleitzahl = $1 ";
-		array_push($v,$plz);
-	else{
-		$sql .= "postleitzahl = $1 AND gemeinde_gem_teile_upper ILIKE $2 ";
-	$sql .= "GROUP BY the_geom, gemeinde_gem_teile, gem_schl_neu, postleitzahl";
-		$show = encode($row["gemeinde_gem_teile"]);
-		$show.= " (Wohnplatz)";
-		if(intval($row['postleitzahl'])> 1){ $show .= " (".$row['postleitzahl'].")"; }
-		stack_it($arrayWP,"wohnplatz",$show,"wp",$row["srid"],$row["minx"],$row["miny"],$row["maxx"],$row["maxy"],$row["gml"]);
-		if(!in_array($row["gem_schl_neu"],$arrayWPKey)){
-			array_push($arrayWPKey,$row["gem_schl_neu"]);
-	return true;
-function checkGfromWP(){
-	global $arrayWPKey, $bufferG, $arrayG, $toleranceG, $epsg;
-	if(count($arrayWPKey) == 0){
-		return false;
-	$v = array();
-	$t = array();
-	$sql = "SELECT DISTINCT gemeinde_neu, ";
-	$sql .= "SRID(the_geom) AS srid, AsGML(Simplify(the_geom,$toleranceG)) AS gml ,";
-	$sql .= "(xmin(the_geom) - ".$bufferG.") as minx, ";
-	$sql .= "(ymin(the_geom) - ".$bufferG.") as miny, ";
-	$sql .= "(xmax(the_geom) + ".$bufferG.") as maxx, ";
-	$sql .= "(ymax(the_geom) + ".$bufferG.") as maxy ";
-	$sql .= "FROM gemeinden WHERE gem_schl_neu IN(";
-	for($i=0; $i<count($arrayWPKey); $i++){
-		$sql .= "$".($i+1);
-		array_push($v,$arrayWPKey[$i]);
-	$sql .= ") GROUP BY the_geom, gemeinde_neu";
-		stack_it($arrayG,"gemeinde_neu",encode($row["gemeinde_neu"]." (Wohnplatz)"),"g",$row["srid"],$row["minx"],$row["miny"],$row["maxx"],$row["maxy"],$row["gml"]);
-function checkG($str){
-	global $bufferG, $arrayG, $toleranceG, $arrayWPKey, $epsg;
-	checkMinLength($str);
-	$tmp = array();
-	$sql = "SELECT DISTINCT gemeinde_neu, gem_schl_neu, ";
-	$sql .= "FROM gemeinden WHERE gemeinde_upper ILIKE $1 ";
-	#$sql .= "GROUP BY the_geom, gemeinde, gem_schl_neu";
-	$v = array("%".$str."%");
-	$t = array('s');
-		stack_it($arrayG,"gemeinde_neu",encode($row["gemeinde_neu"]." (Gemeinde)"),"g",$row["srid"],$row["minx"],$row["miny"],$row["maxx"],$row["maxy"],$row["gml"]);
-		$tmp[count($tmp)] = $row["gem_schl_neu"];
-	$arrayWPKey = array_diff($arrayWPKey,$tmp);
-function checkK($str){
-	global $bufferK, $arrayK, $toleranceK, $epsg;
-	$sql = "SELECT DISTINCT kreis, ";
-	$sql .= "SRID(the_geom) AS srid, AsGML(Simplify(the_geom,".$toleranceK.")) AS gml ,";
-	$sql .= "(xmin(the_geom)-".$bufferK.") as minx, ";
-	$sql .= "(ymin(the_geom)-".$bufferK.") as miny, ";
-	$sql .= "(xmax(the_geom)+".$bufferK.") as maxx, ";
-	$sql .= "(ymax(the_geom)+".$bufferK.") as maxy ";
-	$sql .= "FROM kreis_fl WHERE kreis_upper ILIKE $1 ";
-	$t = array('s');
-		stack_it($arrayK,"kreis",encode($row["kreis"]." (Landkreis)"),"k",$row["srid"],$row["minx"],$row["miny"],$row["maxx"],$row["maxy"],$row["gml"]);
-function checkVg($str){
-	global $bufferV, $arrayV, $toleranceV, $epsg;
-	$sql = "SELECT DISTINCT vg, ";
-	$sql .= "SRID(the_geom) AS srid, AsGML(Simplify(the_geom,".$toleranceV.")) AS gml ,";
-	$sql .= "(xmin(the_geom)-".$bufferV.") as minx, ";
-	$sql .= "(ymin(the_geom)-".$bufferV.") as miny, ";
-	$sql .= "(xmax(the_geom)+".$bufferV.") as maxx, ";
-	$sql .= "(ymax(the_geom)+".$bufferV.") as maxy ";
-	$sql .= "FROM vg_fl WHERE vg ILIKE $1 ";
-	$t = array('s');
-		stack_it($arrayV,"verbandsgemeinde",encode($row["vg"]." (Verbandsgemeinde)"),"vg",$row["srid"],$row["minx"],$row["miny"],$row["maxx"],$row["maxy"],$row["gml"]);
-function stack_it(&$stack,$category,$showtitle,$prefix,$srid,$minx,$miny,$maxx,$maxy,$gml){
-	if (!$searchThruWeb) {
-	$doc = new DOMDocument();
-	$member = $doc->createElement("member");
-	$doc->appendChild($member);
-	$member->setAttribute('id',$prefix.count($stack));
-	$fc = $doc->createElement("FeatureCollection");
-	$member->appendChild($fc);
-	$fc->setAttribute("xmlns:gml","http://www.opengis.net/gml");
-	$bb = $doc->createElement("boundedBy");
-	$fc->appendChild($bb);
-	$box = $doc->createElement("Box");
-	$bb->appendChild($box);
-	$box->setAttribute('srsName',"EPSG:".$srid);
-	$c = $doc->createElement("coordinates");
-	$box->appendChild($c);
-	$coords = $doc->createTextNode($minx.",".$miny." ".$maxx.",".$maxy);
-	$c->appendChild($coords);
-	$fm = $doc->createElement("featureMember");
-	$fc->appendChild($fm);
-	$wp = $doc->createElement($category);
-	$fm->appendChild($wp);
-	$title = $doc->createElement("title");
-	$wp->appendChild($title);
-	$ttitle = $doc->createTextNode($showtitle);
-	$title->appendChild($ttitle);
-	$geom = $doc->createElement("the_geom");
-	$wp->appendChild($geom);
-	$myNode = @simplexml_load_string($gml);
-	$mySNode = dom_import_simplexml($myNode);
-	$domNode = $doc->importNode($mySNode, true);
-	$geom->appendChild($domNode);
-	array_push($stack,$member);
-	} else {
-		//generate simple json objects as array elements
-		$classJSON = new Mapbender_JSON;
-		$returnJSON = new stdClass;
-		$returnJSON->title = $showtitle;
-		$returnJSON->category = $category;
-		$returnJSON->minx = $minx;
-		$returnJSON->miny = $miny;
-		$returnJSON->maxx = $maxx;
-		$returnJSON->maxy = $maxy;
-		$returnJSON = $classJSON->encode($returnJSON);
-		array_push($stack,$returnJSON);
-function null_output(){
-	global $sstr, $arrayWP, $arrayG, $arrayK, $arraySH, $arraySTR, $arrayV;
-	$doc = new DOMDocument('1.0');
-	$doc->encoding = CHARSET;
-	$result = $doc->createElement("result");
-	$doc->appendChild($result);
-	$ready = $doc->createElement('ready');
-	$result->appendChild($ready);
-	$tready = $doc->createTextNode("true");
-	$ready->appendChild($tready);
-	echo $doc->saveXML();
-function null_json_output(){
-	echo "{\"totalResultsCount\":0,\"geonames\":[]}";
-function xml_output(){
-	global $sstr, $arrayWP, $arrayG, $arrayK, $arraySH, $arraySTR, $arrayV, $searchThruWeb, $callback, $maxResults;
-		for($i=0; $i<count($arrayWP); $i++){
-			$domNode = $doc->importNode($arrayWP[$i], true);
-			$result->appendChild($domNode);
-		for($i=0; $i<count($arrayG); $i++){
-			$domNode = $doc->importNode($arrayG[$i], true);
-		for($i=0; $i<count($arrayK); $i++){
-			$domNode = $doc->importNode($arrayK[$i], true);
-		for($i=0; $i<count($arraySH); $i++){
-			$domNode = $doc->importNode($arraySH[$i], true);
-		for($i=0; $i<count($arraySTR); $i++){
-			$domNode = $doc->importNode($arraySTR[$i], true);
-		for($i=0; $i<count($arrayV); $i++){
-			$domNode = $doc->importNode($arrayV[$i], true);
-		//if ($searchThruWeb) {
-		//	header("Content-type: application/xhtml+xml; charset=UTF-8");
-	} else {
-		//generate json object with gml content
-		$countGeonames = 0;
-		$returnJSON->totalResultsCount = 0;
-				if ($countGeonames >= $maxResults) {
-					break;
-				$returnJSON->geonames[$countGeonames] = $classJSON->decode($arrayK[$i]);
-				$countGeonames++;
-				if (countGeonames >= $maxResults) {
-					break;
-			$returnJSON->geonames[$countGeonames] = $classJSON->decode($arrayV[$i]);
-			$countGeonames++;
-					break;
-			$returnJSON->geonames[$countGeonames] = $classJSON->decode($arrayG[$i]);
-			$countGeonames++;
-					break;
-			$returnJSON->geonames[$countGeonames] = $classJSON->decode($arraySTR[$i]);
-			$countGeonames++;
-					break;
-			$returnJSON->geonames[$countGeonames] = $classJSON->decode($arrayWP[$i]);
-			$countGeonames++;
-					break;
-			$returnJSON->geonames[$countGeonames] = $classJSON->decode($arraySH[$i]);
-			$countGeonames++;
-		$returnJSON->totalResultsCount = $countGeonames;
-		if ($returnJSON->totalResultsCount == 0) {
-			$returnJSON->geonames = array();
-		if (isset($callback) && $callback != '') {
-			 $returnJSON = $callback."(".$classJSON->encode($returnJSON).")";
-		} else {
-	       	echo $returnJSON;
-function encode($s){
-#	if(CHARSET == 'UTF-8'){
-#		$s = utf8_encode($s);
-	return $s;
-function getPlz($str){
-	$p = "/.*(\d{5}).*/";
-	$am = array();
- 	if(preg_match($p, $str, $am)){
- 		return $am[1];
- 	else{
- 		return false;
-function getCity($str){
-	$p = "/(^\d{5}){0,1}(.*)/";
-	$am = array();
- 		return trim($am[2]);
- 	else{
- 		return false;
-function getNr($str){
-	$p = "/.*[^0-9](\d{1,4})[^0-9]*/";
-	$am = array();
- 		return $am[(count($am)-1)];
- 	else{
- 		return false;
-function getStrn($str){
-	$p = "/^(\D+)\d/";
-	$am = array();
- 		return trim($am[1]);
- 	else{
- 		return false;
-function getAppendix($str){
-	$p = "/.*\d+.*(\D{1})/";
-	$am = array();
- 		return $am[1];
- 	else{
- 		return false;
-function getCKeysByName($city){
-	global $ckeys;
-	$city = "%".strtoupper(trim($city))."%";
-	$sql = "SELECT gem_schl_neu FROM gis.wohnplatz ";
-	$sql .= "WHERE gemeinde_gem_teile_upper ILIKE $1 ";
-	$v = array($city);
-	$t = array('s');
+header('Content-Type: application/json');
+echo $returnJson;
More information about the Mapbender_commits mailing list
