[Mapbender-commits] r10368 - trunk/mapbender/resources/db/pgsql/UTF-8/update
svn_mapbender at osgeo.org svn_mapbender at osgeo.org
Mon Dec 9 05:24:44 PST 2019
Author: armin11
Date: 2019-12-09 05:24:44 -0800 (Mon, 09 Dec 2019)
New Revision: 10368
   trunk/mapbender/resources/db/pgsql/UTF-8/update/update_2.7.4_to_2.8_pgsql_UTF-8.sql
new search application view
Modified: trunk/mapbender/resources/db/pgsql/UTF-8/update/update_2.7.4_to_2.8_pgsql_UTF-8.sql
--- trunk/mapbender/resources/db/pgsql/UTF-8/update/update_2.7.4_to_2.8_pgsql_UTF-8.sql	2019-12-09 13:20:27 UTC (rev 10367)
+++ trunk/mapbender/resources/db/pgsql/UTF-8/update/update_2.7.4_to_2.8_pgsql_UTF-8.sql	2019-12-09 13:24:44 UTC (rev 10368)
@@ -2908,4 +2908,932 @@
 UPDATE gui_element SET e_target = 'editMaintenance_collection, reindexWMS_collection,reindexWFS_collection,reindexDATASET_collection,reindexWMC_collection,Start_Monitor_for_WMS_collection,CSW_collection' WHERE fkey_gui_id = 'PortalAdmin_DE' AND e_id = 'menu_maintenance';
+-- Table: custom_category_origin
+-- DROP TABLE custom_category_origin;
+CREATE TABLE custom_category_origin
+  id serial,
+  name character varying(255) NOT NULL,
+  uri character varying(500) NOT NULL,
+  type character varying(100) NOT NULL,
+  CONSTRAINT custom_category_origin_pkey PRIMARY KEY (id)
+WITH (
+  OIDS=TRUE
+ALTER TABLE custom_category_origin
+  OWNER TO postgres;
+ALTER TABLE custom_category ADD COLUMN fkey_custom_category_origin_id integer;
+-- Foreign Key: custom_category_ibfk_1
+-- ALTER TABLE custom_category DROP CONSTRAINT custom_category_ibfk_1;
+  ADD CONSTRAINT custom_category_ibfk_1 FOREIGN KEY (fkey_custom_category_origin_id)
+      REFERENCES custom_category_origin (id) MATCH SIMPLE
+      ON UPDATE CASCADE ON DELETE RESTRICT;
+-- Column: custom_category_description_en
+-- ALTER TABLE custom_category DROP COLUMN custom_category_description_en;
+ALTER TABLE custom_category ADD COLUMN custom_category_description_en text;
+-- Column: custom_category_online_link
+-- ALTER TABLE custom_category DROP COLUMN custom_category_online_link;
+ALTER TABLE custom_category ADD COLUMN custom_category_online_link text;
+ALTER TABLE custom_category ALTER COLUMN custom_category_key TYPE VARCHAR(4096);
+ALTER TABLE custom_category ADD COLUMN custom_category_parent_key VARCHAR(4096);
+ALTER TABLE custom_category ADD CONSTRAINT custom_category_key_unique_c UNIQUE (custom_category_key);
+ADD CONSTRAINT custom_category_key_parent_ibfk1 FOREIGN KEY (custom_category_parent_key)
+      REFERENCES custom_category (custom_category_key) MATCH SIMPLE
+      ON UPDATE CASCADE ON DELETE CASCADE;
+--remove application metadata from searchInterface for datasets
+-- View: search_dataset_view
+-- DROP VIEW search_dataset_view;
+CREATE OR REPLACE VIEW search_dataset_view AS
+ SELECT DISTINCT ON (datasets.metadata_id) datasets.user_id,
+    datasets.dataset_id,
+    datasets.metadata_id,
+    datasets.dataset_srs,
+    datasets.title,
+    datasets.dataset_abstract,
+    datasets.accessconstraints,
+    datasets.isopen,
+    datasets.termsofuse,
+    datasets.searchtext,
+    datasets.dataset_timestamp,
+    datasets.department,
+    datasets.mb_group_name,
+    datasets.mb_group_title,
+    datasets.mb_group_country,
+    datasets.load_count,
+    datasets.mb_group_stateorprovince,
+    datasets.md_inspire_cats,
+    datasets.md_custom_cats,
+    datasets.md_topic_cats,
+    datasets.the_geom,
+    datasets.bbox,
+    datasets.preview_url,
+    datasets.fileidentifier,
+    datasets.coupled_resources,
+    datasets.mb_group_logo_path,
+    datasets.timebegin,
+    datasets.timeend
+   FROM ( SELECT dataset_dep.fkey_mb_user_id AS user_id,
+            dataset_dep.dataset_id,
+            dataset_dep.dataset_id AS metadata_id,
+            dataset_dep.srs AS dataset_srs,
+            dataset_dep.title,
+            dataset_dep.abstract AS dataset_abstract,
+            dataset_dep.accessconstraints,
+            dataset_dep.isopen,
+            dataset_dep.termsofuse,
+            f_collect_searchtext_dataset(dataset_dep.dataset_id) AS searchtext,
+            dataset_dep.dataset_timestamp,
+            dataset_dep.department,
+            dataset_dep.mb_group_name,
+            dataset_dep.mb_group_title,
+            dataset_dep.mb_group_country,
+                CASE
+                    WHEN dataset_dep.load_count IS NULL THEN 0::bigint
+                    ELSE dataset_dep.load_count
+                END AS load_count,
+            dataset_dep.mb_group_stateorprovince,
+            f_collect_inspire_cat_dataset(dataset_dep.dataset_id) AS md_inspire_cats,
+            f_collect_custom_cat_dataset(dataset_dep.dataset_id) AS md_custom_cats,
+            f_collect_topic_cat_dataset(dataset_dep.dataset_id) AS md_topic_cats,
+            dataset_dep.bbox AS the_geom,
+            (((((st_xmin(dataset_dep.bbox::box3d)::text || ','::text) || st_ymin(dataset_dep.bbox::box3d)::text) || ','::text) || st_xmax(dataset_dep.bbox::box3d)::text) || ','::text) || st_ymax(dataset_dep.bbox::box3d)::text AS bbox,
+            dataset_dep.preview_url,
+            dataset_dep.fileidentifier,
+            f_get_coupled_resources(dataset_dep.dataset_id) AS coupled_resources,
+            dataset_dep.mb_group_logo_path,
+            dataset_dep.timebegin::date AS timebegin,
+                CASE
+                    WHEN dataset_dep.update_frequency::text = 'continual'::text THEN now()::date
+                    WHEN dataset_dep.update_frequency::text = 'daily'::text THEN now()::date
+                    WHEN dataset_dep.update_frequency::text = 'weekly'::text THEN (now() - '7 days'::interval)::date
+                    WHEN dataset_dep.update_frequency::text = 'fortnightly'::text THEN (now() - '14 days'::interval)::date
+                    WHEN dataset_dep.update_frequency::text = 'monthly'::text THEN (now() - '1 mon'::interval)::date
+                    WHEN dataset_dep.update_frequency::text = 'quarterly'::text THEN (now() - '3 mons'::interval)::date
+                    WHEN dataset_dep.update_frequency::text = 'biannually'::text THEN (now() - '6 mons'::interval)::date
+                    WHEN dataset_dep.update_frequency::text = 'annually'::text THEN (now() - '1 year'::interval)::date
+                    ELSE dataset_dep.timeend::date
+                END AS timeend
+           FROM ( SELECT mb_metadata.the_geom AS bbox,
+                    mb_metadata.ref_system AS srs,
+                    mb_metadata.metadata_id AS dataset_id,
+                    mb_metadata.title,
+                    mb_metadata.abstract,
+                    mb_metadata.lastchanged AS dataset_timestamp,
+                    mb_metadata.tmp_reference_1 AS timebegin,
+                    mb_metadata.tmp_reference_2 AS timeend,
+                    mb_metadata.uuid AS fileidentifier,
+                    mb_metadata.preview_image AS preview_url,
+                    mb_metadata.load_count,
+                    mb_metadata.fkey_mb_user_id,
+                    mb_metadata.constraints AS accessconstraints,
+                    mb_metadata.update_frequency,
+                    f_getmd_tou(mb_metadata.metadata_id) AS termsofuse,
+                    f_tou_isopen(f_getmd_tou(mb_metadata.metadata_id)) AS isopen,
+                    mb_metadata.mb_group_id AS department,
+                    mb_metadata.mb_group_name,
+                    mb_metadata.mb_group_title,
+                    mb_metadata.mb_group_country,
+                    mb_metadata.mb_group_stateorprovince,
+                    mb_metadata.mb_group_logo_path
+                   FROM ( SELECT mb_metadata_1.metadata_id,
+                            mb_metadata_1.uuid,
+                            mb_metadata_1.origin,
+                            mb_metadata_1.includeincaps,
+                            mb_metadata_1.fkey_mb_group_id,
+                            mb_metadata_1.schema,
+                            mb_metadata_1.createdate,
+                            mb_metadata_1.changedate,
+                            mb_metadata_1.lastchanged,
+                            mb_metadata_1.link,
+                            mb_metadata_1.linktype,
+                            mb_metadata_1.md_format,
+                            mb_metadata_1.title,
+                            mb_metadata_1.abstract,
+                            mb_metadata_1.searchtext,
+                            mb_metadata_1.status,
+                            mb_metadata_1.type,
+                            mb_metadata_1.harvestresult,
+                            mb_metadata_1.harvestexception,
+                            mb_metadata_1.export2csw,
+                            mb_metadata_1.tmp_reference_1,
+                            mb_metadata_1.tmp_reference_2,
+                            mb_metadata_1.spatial_res_type,
+                            mb_metadata_1.spatial_res_value,
+                            mb_metadata_1.ref_system,
+                            mb_metadata_1.format,
+                            mb_metadata_1.inspire_charset,
+                            mb_metadata_1.inspire_top_consistence,
+                            mb_metadata_1.fkey_mb_user_id,
+                            mb_metadata_1.responsible_party,
+                            mb_metadata_1.individual_name,
+                            mb_metadata_1.visibility,
+                            mb_metadata_1.locked,
+                            mb_metadata_1.copyof,
+                            mb_metadata_1.constraints,
+                            mb_metadata_1.fees,
+                            mb_metadata_1.classification,
+                            mb_metadata_1.browse_graphic,
+                            mb_metadata_1.inspire_conformance,
+                            mb_metadata_1.preview_image,
+                            mb_metadata_1.the_geom,
+                            mb_metadata_1.lineage,
+                            mb_metadata_1.datasetid,
+                            mb_metadata_1.randomid,
+                            mb_metadata_1.update_frequency,
+                            mb_metadata_1.datasetid_codespace,
+                            mb_metadata_1.bounding_geom,
+                            mb_metadata_1.inspire_whole_area,
+                            mb_metadata_1.inspire_actual_coverage,
+                            mb_metadata_1.datalinks,
+                            mb_metadata_1.inspire_download,
+                            mb_metadata_1.transfer_size,
+                            mb_metadata_1.md_license_source_note,
+                            mb_metadata_1.responsible_party_name,
+                            mb_metadata_1.responsible_party_email,
+                            mb_metadata_1.searchable,
+                            mb_metadata_1.load_count,
+                            user_dep.fkey_mb_group_id,
+                            user_dep.mb_group_id,
+                            user_dep.mb_group_name,
+                            user_dep.mb_group_title,
+                            user_dep.mb_group_country,
+                            user_dep.mb_group_stateorprovince,
+                            user_dep.mb_group_logo_path,
+                            user_dep.fkey_mb_user_id_from_users
+                           FROM ( SELECT mb_metadata_2.metadata_id,
+                                    mb_metadata_2.uuid,
+                                    mb_metadata_2.origin,
+                                    mb_metadata_2.includeincaps,
+                                    mb_metadata_2.fkey_mb_group_id,
+                                    mb_metadata_2.schema,
+                                    mb_metadata_2.createdate,
+                                    mb_metadata_2.changedate,
+                                    mb_metadata_2.lastchanged,
+                                    mb_metadata_2.link,
+                                    mb_metadata_2.linktype,
+                                    mb_metadata_2.md_format,
+                                    mb_metadata_2.title,
+                                    mb_metadata_2.abstract,
+                                    mb_metadata_2.searchtext,
+                                    mb_metadata_2.status,
+                                    mb_metadata_2.type,
+                                    mb_metadata_2.harvestresult,
+                                    mb_metadata_2.harvestexception,
+                                    mb_metadata_2.export2csw,
+                                    mb_metadata_2.tmp_reference_1,
+                                    mb_metadata_2.tmp_reference_2,
+                                    mb_metadata_2.spatial_res_type,
+                                    mb_metadata_2.spatial_res_value,
+                                    mb_metadata_2.ref_system,
+                                    mb_metadata_2.format,
+                                    mb_metadata_2.inspire_charset,
+                                    mb_metadata_2.inspire_top_consistence,
+                                    mb_metadata_2.fkey_mb_user_id,
+                                    mb_metadata_2.responsible_party,
+                                    mb_metadata_2.individual_name,
+                                    mb_metadata_2.visibility,
+                                    mb_metadata_2.locked,
+                                    mb_metadata_2.copyof,
+                                    mb_metadata_2.constraints,
+                                    mb_metadata_2.fees,
+                                    mb_metadata_2.classification,
+                                    mb_metadata_2.browse_graphic,
+                                    mb_metadata_2.inspire_conformance,
+                                    mb_metadata_2.preview_image,
+                                    mb_metadata_2.the_geom,
+                                    mb_metadata_2.lineage,
+                                    mb_metadata_2.datasetid,
+                                    mb_metadata_2.randomid,
+                                    mb_metadata_2.update_frequency,
+                                    mb_metadata_2.datasetid_codespace,
+                                    mb_metadata_2.bounding_geom,
+                                    mb_metadata_2.inspire_whole_area,
+                                    mb_metadata_2.inspire_actual_coverage,
+                                    mb_metadata_2.datalinks,
+                                    mb_metadata_2.inspire_download,
+                                    mb_metadata_2.transfer_size,
+                                    mb_metadata_2.md_license_source_note,
+                                    mb_metadata_2.responsible_party_name,
+                                    mb_metadata_2.responsible_party_email,
+                                    mb_metadata_2.searchable,
+                                    metadata_load_count.load_count
+                                   FROM mb_metadata mb_metadata_2
+                                     LEFT JOIN metadata_load_count ON mb_metadata_2.metadata_id = metadata_load_count.fkey_metadata_id) mb_metadata_1,
+                            ( SELECT groups_for_publishing.fkey_mb_group_id,
+                                    groups_for_publishing.mb_group_id,
+                                    groups_for_publishing.mb_group_name,
+                                    groups_for_publishing.mb_group_title,
+                                    groups_for_publishing.mb_group_country,
+                                    groups_for_publishing.mb_group_stateorprovince,
+                                    groups_for_publishing.mb_group_logo_path,
+                                    0 AS fkey_mb_user_id_from_users
+                                   FROM groups_for_publishing) user_dep
+                          WHERE mb_metadata_1.fkey_mb_group_id = user_dep.mb_group_id AND mb_metadata_1.the_geom IS NOT NULL AND mb_metadata_1.searchable IS TRUE
+                        UNION ALL
+                         SELECT mb_metadata_1.metadata_id,
+                            ( SELECT publishing_registrating_authorities.fkey_mb_group_id,
+                                    publishing_registrating_authorities.mb_group_id,
+                                    publishing_registrating_authorities.mb_group_name,
+                                    publishing_registrating_authorities.mb_group_title,
+                                    publishing_registrating_authorities.mb_group_country,
+                                    publishing_registrating_authorities.mb_group_stateorprovince,
+                                    publishing_registrating_authorities.mb_group_logo_path,
+                                    users_for_publishing.fkey_mb_user_id AS fkey_mb_user_id_from_users
+                                   FROM groups_for_publishing publishing_registrating_authorities,
+                                  WHERE users_for_publishing.primary_group_id = publishing_registrating_authorities.fkey_mb_group_id) user_dep
+                          WHERE (mb_metadata_1.fkey_mb_group_id IS NULL OR mb_metadata_1.fkey_mb_group_id = 0) AND mb_metadata_1.fkey_mb_user_id = user_dep.fkey_mb_user_id_from_users AND mb_metadata_1.the_geom IS NOT NULL AND mb_metadata_1.searchable IS TRUE) mb_metadata (metadata_id, uuid, origin, includeincaps, fkey_mb_group_id, schema, createdate, changedate, lastchanged, link, linktype, md_format, title, abstract, searchtext, status, type, harvestresult, harvestexception, export2csw, tmp_reference_1, tmp_reference_2, spatial_res_type, spatial_res_value, ref_system, format, inspire_charset, inspire_top_consistence, fkey_mb_user_id, responsible_party, individual_name, visibility, locked, copyof, constraints, fees, classification, browse_graphic, inspire_conformance, preview_image, the_geom, lineage, datasetid, randomid, update_frequency, datasetid_codespace, bounding_geom, inspire_whole_area, inspire_actual_coverage, datalinks, inspire_download, transfer_size, md_license_source_no
 te, responsible_party_name, responsible_party_email, searchable, load_count, fkey_mb_group_id_1, mb_group_id, mb_group_name, mb_group_title, mb_group_country, mb_group_stateorprovince, mb_group_logo_path, fkey_mb_user_id_from_users)) dataset_dep
+          ORDER BY dataset_dep.dataset_id) datasets;
+--ALTER TABLE search_dataset_view
+--  OWNER TO postgres;
+--GRANT ALL ON TABLE search_dataset_view TO postgres;
+-- Materialized View: search_application_view
+-- DROP MATERIALIZED VIEW search_application_view;
+CREATE MATERIALIZED VIEW search_application_view AS
+    datasets.title,
+    datasets.isopen,
+    datasets.bbox,
+    datasets.timeend,
+    datasets.link,
+    datasets.fkey_gui_id,
+    datasets.fkey_wmc_serial_id,
+    datasets.fkey_mapviewer_id
+                CASE
+            dataset_dep.link,
+            dataset_dep.fkey_gui_id,
+            dataset_dep.fkey_wmc_serial_id,
+            dataset_dep.fkey_mapviewer_id,
+                CASE
+                END AS timeend
+                    mb_metadata.mb_group_logo_path,
+                    mb_metadata.link,
+                    mb_metadata.fkey_gui_id,
+                    mb_metadata.fkey_wmc_serial_id,
+                    mb_metadata.fkey_mapviewer_id
+                            mb_metadata_1.fkey_gui_id,
+                            mb_metadata_1.fkey_wmc_serial_id,
+                            mb_metadata_1.fkey_mapviewer_id,
+                                    mb_metadata_2.fkey_gui_id,
+                                    mb_metadata_2.fkey_wmc_serial_id,
+                                    mb_metadata_2.fkey_mapviewer_id,
+                          WHERE mb_metadata_1.fkey_mb_group_id = user_dep.mb_group_id AND mb_metadata_1.the_geom IS NOT NULL AND mb_metadata_1.searchable IS TRUE AND mb_metadata_1.type::text = 'application'::text
+                        UNION ALL
+                          WHERE (mb_metadata_1.fkey_mb_group_id IS NULL OR mb_metadata_1.fkey_mb_group_id = 0) AND mb_metadata_1.fkey_mb_user_id = user_dep.fkey_mb_user_id_from_users AND mb_metadata_1.the_geom IS NOT NULL AND mb_metadata_1.searchable IS TRUE AND mb_metadata_1.type::text = 'application'::text) mb_metadata(metadata_id, uuid, origin, includeincaps, fkey_mb_group_id, schema, createdate, changedate, lastchanged, link, linktype, md_format, title, abstract, searchtext, status, type, harvestresult, harvestexception, export2csw, tmp_reference_1, tmp_reference_2, spatial_res_type, spatial_res_value, ref_system, format, inspire_charset, inspire_top_consistence, fkey_mb_user_id, responsible_party, individual_name, visibility, locked, copyof, constraints, fees, classification, browse_graphic, inspire_conformance, preview_image, the_geom, lineage, datasetid, randomid, update_frequency, datasetid_codespace, bounding_geom, inspire_whole_area, inspire_actual_coverage, datalinks, ins
 pire_download, transfer_size, md_license_source_note, responsible_party_name, responsible_party_email, searchable, load_count, fkey_gui_id, fkey_wmc_serial_id, fkey_mapviewer_id, fkey_mb_group_id_1, mb_group_id, mb_group_name, mb_group_title, mb_group_country, mb_group_stateorprovince, mb_group_logo_path, fkey_mb_user_id_from_users)) dataset_dep
+WITH DATA;
+ALTER TABLE search_application_view
+GRANT ALL ON TABLE search_application_view TO postgres;
+GRANT ALL ON TABLE search_application_view TO mapbenderdbuser;
+-- Index: gist_wst_application_the_geom
+-- DROP INDEX gist_wst_application_the_geom;
+CREATE INDEX gist_wst_application_the_geom
+  ON search_application_view
+  USING gist
+  (the_geom);
+-- Index: idx_wst_application_dataset_id
+-- DROP INDEX idx_wst_application_dataset_id;
+CREATE INDEX idx_wst_application_dataset_id
+  USING btree
+  (dataset_id);
+-- Index: idx_wst_application_department
+-- DROP INDEX idx_wst_application_department;
+CREATE INDEX idx_wst_application_department
+  USING btree
+  (department);
+-- Index: idx_wst_application_md_custom_cats
+-- DROP INDEX idx_wst_application_md_custom_cats;
+CREATE INDEX idx_wst_application_md_custom_cats
+  USING btree
+  (md_custom_cats COLLATE pg_catalog."default");
+-- Index: idx_wst_application_md_inspire_cats
+-- DROP INDEX idx_wst_application_md_inspire_cats;
+CREATE INDEX idx_wst_application_md_inspire_cats
+  USING btree
+  (md_inspire_cats COLLATE pg_catalog."default");
+-- Index: idx_wst_application_md_topic_cats
+-- DROP INDEX idx_wst_application_md_topic_cats;
+CREATE INDEX idx_wst_application_md_topic_cats
+  USING btree
+  (md_topic_cats COLLATE pg_catalog."default");
+-- Index: idx_wst_application_metadata_id
+-- DROP INDEX idx_wst_application_metadata_id;
+CREATE INDEX idx_wst_application_metadata_id
+  USING btree
+  (metadata_id);
+-- Index: idx_wst_application_searchtext
+-- DROP INDEX idx_wst_application_searchtext;
+CREATE INDEX idx_wst_application_searchtext
+  USING btree
+  (searchtext COLLATE pg_catalog."default");
+-- Index: idx_wst_application_timebegin
+-- DROP INDEX idx_wst_application_timebegin;
+CREATE INDEX idx_wst_application_timebegin
+  USING btree
+  (timebegin);
+-- Index: idx_wst_application_timeend
+-- DROP INDEX idx_wst_application_timeend;
+CREATE INDEX idx_wst_application_timeend
+  USING btree
+  (timeend);
+-- Index: idx_wst_application_timestamp
+-- DROP INDEX idx_wst_application_timestamp;
+CREATE INDEX idx_wst_application_timestamp
+  USING btree
+  (dataset_timestamp);
More information about the Mapbender_commits mailing list
