[Mapbender-commits] r10371 - in trunk/mapbender/http: classes php
svn_mapbender at osgeo.org
Tue Dec 17 01:58:58 PST 2019
Author: armin11
Date: 2019-12-17 01:58:57 -0800 (Tue, 17 Dec 2019)
New Revision: 10371
trunk/mapbender/http/classes/class_administration.php
trunk/mapbender/http/classes/class_user.php
trunk/mapbender/http/php/mod_createUser.php
trunk/mapbender/http/php/mod_linkedDataProxy.php
fix for sending mails with activation link when self registrating is invoked
Modified: trunk/mapbender/http/classes/class_administration.php
--- trunk/mapbender/http/classes/class_administration.php 2019-12-16 14:58:38 UTC (rev 10370)
+++ trunk/mapbender/http/classes/class_administration.php 2019-12-17 09:58:57 UTC (rev 10371)
@@ -24,6 +24,7 @@
$phpversion = phpversion();
if (strpos($phpversion, "7.") === 0) {
//use new mailer
+$e = new mb_exception($phpversion);
require(dirname(__FILE__) . "/phpmailer-6.0.2/src/PHPMailer.php");
require(dirname(__FILE__) . "/phpmailer-6.0.2/src/SMTP.php");
require(dirname(__FILE__) . "/phpmailer-6.0.2/src/Exception.php");
@@ -98,8 +99,8 @@
* @param integer maximum line length
function sendEmail($fromAddr, $fromName, $toAddr, $toName, $subject, $body, &$error_msg, $wordWrapLength = 50){
+ global $mailHost, $mailUsername, $mailPassword;
- global $mailHost, $mailUsername, $mailPassword;
if($fromAddr == ''){
$fromAddr = MAILADMIN;
@@ -107,7 +108,6 @@
if($fromName == ''){
$fromName = MAILADMINNAME;
if ($this->isValidEmail($fromAddr) && $this->isValidEmail($toAddr)) {
$phpversion = $this->getPhpVersion();
@@ -154,7 +154,9 @@
return true;
else {
+ $e = new mb_exception("classes/class_administration.php - sendEmail - email address not valid!");
return false;
Modified: trunk/mapbender/http/classes/class_user.php
--- trunk/mapbender/http/classes/class_user.php 2019-12-16 14:58:38 UTC (rev 10370)
+++ trunk/mapbender/http/classes/class_user.php 2019-12-17 09:58:57 UTC (rev 10371)
@@ -530,10 +530,10 @@
$userMessage .= _mb("Follow this link to login to Mapbender").": \n";
$userMessage .= LOGIN."\n";
$userMail = $admin->getEmailByUserId($this->id);
- if(!$admin->sendEmail("", "", $userMail, $this->name, utf8_decode(_mb("Your Mapbender Geoportal account")), utf8_decode($userMessage), $error_msg)) {
- return _mb("Registry data could not be send. Please check mail address.");
+ if(!$admin->sendEmail('', '', $userMail, $this->name, utf8_decode(_mb("Your Mapbender Geoportal account")), utf8_decode($userMessage), $error_msg)) {
+ return _mb("Registration data could not be send. Please check the given mail address.");
- return _mb("Registry data has been sent successfully.");
+ return _mb("Registration data has been sent successfully - please control your mail Account to activate your account!");
Modified: trunk/mapbender/http/php/mod_createUser.php
--- trunk/mapbender/http/php/mod_createUser.php 2019-12-16 14:58:38 UTC (rev 10370)
+++ trunk/mapbender/http/php/mod_createUser.php 2019-12-17 09:58:57 UTC (rev 10371)
@@ -23,7 +23,7 @@
echo "This module is disabled. Please check your mapbender.conf.";
die;
+require_once(dirname(__FILE__)."/../../core/globalSettings.php");
require_once(dirname(__FILE__)."/../classes/class_gui.php");
require_once(dirname(__FILE__)."/../classes/class_administration.php");
require_once(dirname(__FILE__)."/../classes/class_user.php");
@@ -161,8 +161,8 @@
$res_del_from_group = db_prep_query($sql_del_from_group,$v,$t);
//send mail with activation key to user!
$userNew = new User($selected_user);
- $userNew->sendUserLoginMail();
- echo "<script language='JavaScript'>alert('Email with activation key has been sent!');</script>";
+ $registrationMessage = $userNew->sendUserLoginMail();
+ echo "<script language='JavaScript'>alert('".$registrationMessage."');</script>";
@@ -272,7 +272,8 @@
echo "<td></td>";
echo "<td>";
if($selected_user == 'new' || !isset($selected_user)){
- echo "<input type='button' class='myButton' value='save' onclick='validate(\""._mb('Save')."\")'>";
+ //echo "<input type='button' class='myButton' value='save' onclick='validate(\""._mb('Save')."\")'>";
+ echo "<input type='button' class='myButton' value='"._mb('Save')."' onclick='validate(\"save\")'>";
echo "</td>";
echo "</tr>";
Modified: trunk/mapbender/http/php/mod_linkedDataProxy.php
--- trunk/mapbender/http/php/mod_linkedDataProxy.php 2019-12-16 14:58:38 UTC (rev 10370)
+++ trunk/mapbender/http/php/mod_linkedDataProxy.php 2019-12-17 09:58:57 UTC (rev 10371)
@@ -948,6 +948,7 @@
$returnObject->success = false;
$returnObject->message = "Wfs object could not be created from db!";
} else {
+$e = new mb_exception($wfs->providerName." - ".$wfs->summary." - ".$wfs->electronicMailAddress." - ".$wfs->fees);
//repair some missing wfs data
if (!isset($wfs->summary) || $wfs->summary == null || $wfs->summary == "") {
$wfs->summary = "WFS description is missing!";
@@ -958,9 +959,6 @@
if (!isset($wfs->electronicMailAddress) || $wfs->electronicMailAddress == null || $wfs->electronicMailAddress == "") {
$wfs->electronicMailAddress = "test at test.org";
- if (!isset($wfs->electronicMailAddress) || $wfs->electronicMailAddress == null || $wfs->electronicMailAddress == "") {
- $wfs->electronicMailAddress = "test at test.org";
if (!isset($wfs->fees) || $wfs->fees == null || $wfs->fees == "") {
$wfs->fees = "No fees are given in WFS Capabilities!";
More information about the Mapbender_commits
