[Mapbender-commits] r10374 - in trunk/mapbender/http: classes sld
svn_mapbender at osgeo.org
Wed Dec 18 00:00:25 PST 2019
Author: armin11
Date: 2019-12-18 00:00:24 -0800 (Wed, 18 Dec 2019)
New Revision: 10374
trunk/mapbender/http/classes/class_iso19139.php
trunk/mapbender/http/sld/sld_parse.php
Little fix and initial option to integrate sld editor again?
Modified: trunk/mapbender/http/classes/class_iso19139.php
--- trunk/mapbender/http/classes/class_iso19139.php 2019-12-17 13:03:45 UTC (rev 10373)
+++ trunk/mapbender/http/classes/class_iso19139.php 2019-12-18 08:00:24 UTC (rev 10374)
@@ -718,7 +718,6 @@
if ($metadataConnector->timedOut == true) {
return false;
- $xml = $metadataConnector->file;
$mbMetadata = $this->createMapbenderMetadataFromXML($xml);
return $mbMetadata;
@@ -728,7 +727,6 @@
$metadataConnector = new connector();
$metadataConnector->set("timeOut", "10");
$metadataConnector->load($url);
$this->metadata = $xml;
Modified: trunk/mapbender/http/sld/sld_parse.php
--- trunk/mapbender/http/sld/sld_parse.php 2019-12-17 13:03:45 UTC (rev 10373)
+++ trunk/mapbender/http/sld/sld_parse.php 2019-12-18 08:00:24 UTC (rev 10374)
@@ -1,5 +1,5 @@
<?php
-# $Id: sld_parse.php 2412 2008-04-23 16:14:30Z christoph $
+# $Id$
# http://www.mapbender.org/index.php/SLD/sld_config.php
# Copyright (C) 2002 CCGIS
@@ -32,9 +32,8 @@
* @package sld_parse
* @author Markus Krzyzanowski
-//require_once(dirname(__FILE__)."/../php/mb_validateSession.php");
+require_once(dirname(__FILE__)."/../php/mb_validateSession.php");
+require_once(dirname(__FILE__)."/../classes/class_connector.php");
* Creates a empty SLD object up to the rule object
@@ -65,21 +64,14 @@
* @param string $file URL of the file
* @return string content of the file
-function readSld($file)
- if (!($fp = fopen($file, "rb")))
- die("could not open XML input - ".$file);
- $data = "";
- while(!feof($fp))
- $data .= fread($fp, 1024);
- return $data;
+function readSld($url) {
+ $sldConnector = new connector();
+ $sldConnector->set("timeOut", "5");
+ $sldConnector->load($url);
+ if ($sldConnector->timedOut == true) {
+ return false;
+ return $sldConnector->file;
More information about the Mapbender_commits
