[Mapbender-commits] r10378 - trunk/mapbender/resources/db
    svn_mapbender at osgeo.org
    Wed Dec 18 08:29:39 PST 2019
Author: armin11
Date: 2019-12-18 08:29:39 -0800 (Wed, 18 Dec 2019)
New Revision: 10378
Added:
   trunk/mapbender/resources/db/gui_admin_application_metadata.sql
New gui for edit application metadata
Added: trunk/mapbender/resources/db/gui_admin_application_metadata.sql
--- trunk/mapbender/resources/db/gui_admin_application_metadata.sql	                        (rev 0)
+++ trunk/mapbender/resources/db/gui_admin_application_metadata.sql	2019-12-18 16:29:39 UTC (rev 10378)
@@ -0,0 +1,75 @@
+INSERT INTO gui (gui_id, gui_name, gui_description, gui_public) VALUES ('admin_application_metadata','admin_application_metadata','Simple administration gui for dataset-metadata',1);
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin_application_metadata','jq_metadata',1,1,'Metadata plugin','','','','',NULL ,NULL,NULL ,NULL,NULL ,'','','','','../extensions/jquery.metadata.2.1/jquery.metadata.min.js','','','http://plugins.jquery.com/project/metadata');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin_application_metadata','jq_ui',1,1,'The jQuery UI core','','','','',NULL ,NULL,NULL ,NULL,NULL ,'','','','','../extensions/jquery-ui-1.8.16.custom/development-bundle/ui/minified/jquery.ui.core.min.js','','','');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('admin_application_metadata','jq_ui','css','../extensions/jquery-ui-1.7.2.custom/css/ui-lightness/jquery-ui-1.7.2.custom.css','','file/css');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin_application_metadata','jq_ui_effects',1,1,'Effects from the jQuery UI framework','','','','',NULL ,NULL,NULL ,NULL,NULL ,'','','','jq_ui_effects.php','../extensions/jquery-ui-1.8.16.custom/development-bundle/ui/minified/jquery.effects.core.min.js','','','');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('admin_application_metadata','jq_ui_effects','blind','1','1 = effect active','php_var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('admin_application_metadata','jq_ui_effects','bounce','0','1 = effect active','php_var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('admin_application_metadata','jq_ui_effects','clip','0','1 = effect active','php_var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('admin_application_metadata','jq_ui_effects','drop','0','1 = effect active','php_var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('admin_application_metadata','jq_ui_effects','explode','0','1 = effect active','php_var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('admin_application_metadata','jq_ui_effects','fold','1','1 = effect active','php_var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('admin_application_metadata','jq_ui_effects','highlight','0','1 = effect active','php_var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('admin_application_metadata','jq_ui_effects','pulsate','0','1 = effect active','php_var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('admin_application_metadata','jq_ui_effects','scale','0','1 = effect active','php_var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('admin_application_metadata','jq_ui_effects','shake','0','1 = effect active','php_var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('admin_application_metadata','jq_ui_effects','slide','0','1 = effect active','php_var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('admin_application_metadata','jq_ui_effects','transfer','0','1 = effect active','php_var');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin_application_metadata','jq_upload',1,1,'Allows to upload files into Mapbender''s temporary files folder','','','','',NULL ,NULL,NULL ,NULL,NULL ,'','','','','../plugins/jq_upload.js','','','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin_application_metadata','jq_validate',1,1,'The jQuery validation plugin','','','','',NULL ,NULL,NULL ,NULL,NULL ,'','','','../javascripts/jq_validate.js','../extensions/jquery-validate/jquery.validate.min.js','','','http://docs.jquery.com/Plugins/Validation');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('admin_application_metadata','jq_validate','css','label.error { float: none; color: red; padding-left: .5em; vertical-align: top; }','','text/css');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin_application_metadata','mb_geodata_import',1,0,'Allows to upload files into Mapbender''s temporary files folder','','','','',NULL ,NULL,NULL ,NULL,NULL ,'','','','../plugins/mb_metadata_import.js','','','','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin_application_metadata','mb_helpDialog',1,1,'','','','','',NULL ,NULL,NULL ,NULL,NULL ,'','','','','mb_helpDialog.js','','jq_ui_dialog, jq_metadata','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin_application_metadata','mb_metadata_gml_import',1,1,'','','div','','',NULL ,NULL,NULL ,NULL,NULL ,'','','div','../plugins/mb_metadata_gml_import.js','','','','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin_application_metadata','mb_metadata_preview_import',1,1,'','','div','','',NULL ,NULL,NULL ,NULL,NULL ,'','','div','../plugins/mb_metadata_preview_import.js','','','','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin_application_metadata','mb_metadata_xml_import',1,1,'','','div','','',NULL ,NULL,NULL ,NULL,NULL ,'','','div','../plugins/mb_metadata_xml_import.js','','','','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin_application_metadata','jq_datatables',1,1,'Includes the jQuery plugin datatables, use like this
+$(selector).datatables(options)','','','','',NULL ,NULL,NULL ,NULL,NULL ,'','','','../plugins/jq_datatables.js','../extensions/DataTables-1.9.4/media/js/jquery.dataTables.min.js,../extensions/DataTables-1.9.4/extras/TableTools/media/js/TableTools.min.js','','','http://www.datatables.net/');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('admin_application_metadata','jq_datatables','defaultCss','../extensions/DataTables-1.9.4/media/css/demo_table_jui.css','','file/css');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin_application_metadata','body',1,1,'body (obligatory)','','body','','',NULL ,NULL,NULL ,NULL,NULL ,'','','','','','','','');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('admin_application_metadata','body','css_class_bg','../css/metadataeditor.css','to define the color of the body','file/css');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('admin_application_metadata','body','favicon','../img/favicon.png','favicon','php_var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('admin_application_metadata','body','includeWhileLoading','1','show splash screen while the application is loading','php_var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('admin_application_metadata','body','jq_ui_theme','../extensions/jquery-ui-1.7.2.custom/css/smoothness/jquery-ui-1.7.2.custom.css','UI Theme from Themeroller','file/css');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('admin_application_metadata','body','use_load_message','true','show splash screen while the application is loading','php_var');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin_application_metadata','mb_metadata_manager_select',2,1,'Select a metadata resource from owned metadata - add js element var to define hierachyLevel other than dataset','Select application metadata','div','','',NULL ,NULL,NULL ,NULL,NULL ,'','<table style=''cursor:pointer'' class=''display''></table>','div','../plugins/mb_metadata_manager_select.js','','','jq_datatables','');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('admin_application_metadata','mb_metadata_manager_select','hierarchyLevel','application','type of metadata from mb_metadata','var');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin_application_metadata','jq_ui_widget',2,1,'jQuery UI widget','','','','',NULL ,NULL,NULL ,NULL,NULL ,'','','','','../extensions/jquery-ui-1.8.16.custom/development-bundle/ui/minified/jquery.ui.widget.min.js','','','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin_application_metadata','jq_ui_position',2,1,'jQuery UI position','','','','',NULL ,NULL,NULL ,NULL,NULL ,'','','','','../extensions/jquery-ui-1.8.16.custom/development-bundle/ui/minified/jquery.ui.position.min.js','','','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin_application_metadata','mb_md_showMetadata',2,1,'Show editor for metadata','Metadata Editor','div','','',NULL ,NULL,NULL ,NULL,NULL ,'display:none;','','div','../plugins/mb_metadata_showMetadata.js','','','jq_ui_dialog','');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('admin_application_metadata','mb_md_showMetadata','differentFromOriginalCss','.differentFromOriginal{
+background-color:#FFFACD;
+}','css for class differentFromOriginal','text/css');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('admin_application_metadata','mb_md_showMetadata','inputs','[
+        "method": "init",
+        "title": "initialize",
+        "linkedTo": [
+                "id": "mb_md_edit",
+                "event": "showOriginalMetadata",
+                "attr": "data"
+        "method": "initLayer",
+        "linkedTo": [
+                "id": "mb_md_layer",
+                "event": "showOriginalLayerMetadata",
+                "attr": "data"
+]','','var');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin_application_metadata','jq_ui_mouse',3,1,'jQuery UI mouse','','','','',NULL ,NULL,NULL ,NULL,NULL ,'','','','','../extensions/jquery-ui-1.8.16.custom/development-bundle/ui/minified/jquery.ui.mouse.min.js','','jq_ui_widget','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin_application_metadata','jq_ui_droppable',4,1,'jQuery UI droppable','','','','',NULL ,NULL,NULL ,NULL,NULL ,'','','','','../extensions/jquery-ui-1.8.16.custom/development-bundle/ui/minified/jquery.ui.droppable.min.js','','jq_ui,jq_ui_widget,jq_ui_mouse,jq_ui_draggable','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin_application_metadata','jq_ui_button',4,1,'jQuery UI button','','','','',NULL ,NULL,NULL ,NULL,NULL ,'','','','','../extensions/jquery-ui-1.8.16.custom/development-bundle/ui/minified/jquery.ui.button.min.js','','jq_ui,jq_ui_widget','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin_application_metadata','jq_ui_datepicker',5,1,'Datepicker from jQuery UI framework','','','','',NULL ,NULL,NULL ,NULL,NULL ,'','','','../plugins/jq_ui_datepicker.js','../extensions/jquery-ui-1.8.16.custom/development-bundle/ui/jquery.ui.datepicker.js','','jq_ui','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin_application_metadata','jq_ui_resizable',5,1,'Resizable from the jQuery UI framework','','','','',NULL ,NULL,NULL ,NULL,NULL ,'','','','../plugins/jq_ui_resizable.js','../extensions/jquery-ui-1.8.16.custom/development-bundle/ui/jquery.ui.resizable.js','','jq_ui,jq_ui_mouse,jq_ui_widget','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin_application_metadata','jq_ui_draggable',5,1,'Draggable from the jQuery UI framework','','','','',NULL ,NULL,NULL ,NULL,NULL ,'','','','','../extensions/jquery-ui-1.8.16.custom/development-bundle/ui/minified/jquery.ui.draggable.min.js','','jq_ui,jq_ui_mouse,jq_ui_widget','http://jqueryui.com/demos/draggable/');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin_application_metadata','jq_ui_dialog',5,1,'Module to manage jQuery UI dialog windows with multiple options for customization.','','div','','',-1,-1,NULL ,NULL,NULL ,'','','div','','../extensions/jquery-ui-1.8.16.custom/development-bundle/ui/minified/jquery.ui.dialog.min.js','','jq_ui,jq_ui_widget,jq_ui_button,jq_ui_draggable,jq_ui_mouse,jq_ui_position,jq_ui_resizable','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin_application_metadata','jq_ui_tabs',5,1,'horizontal tabs from the jQuery UI framework','','','','',NULL ,NULL,NULL ,NULL,NULL ,'','','','','../extensions/jquery-ui-1.8.16.custom/development-bundle/ui/minified/jquery.ui.tabs.min.js','','jq_ui,jq_ui_widget','');
More information about the Mapbender_commits
