[Mapbender-commits] r10055 - in trunk/mapbender/http/extensions: . path-converter-master path-converter-master/src
svn_mapbender at osgeo.org
Wed Feb 13 06:24:05 PST 2019
Author: armin11
Date: 2019-02-13 06:24:05 -0800 (Wed, 13 Feb 2019)
New Revision: 10055
Added:
trunk/mapbender/http/extensions/path-converter-master/
trunk/mapbender/http/extensions/path-converter-master/LICENSE
trunk/mapbender/http/extensions/path-converter-master/composer.json
trunk/mapbender/http/extensions/path-converter-master/src/
trunk/mapbender/http/extensions/path-converter-master/src/Converter.php
trunk/mapbender/http/extensions/path-converter-master/src/ConverterInterface.php
trunk/mapbender/http/extensions/path-converter-master/src/NoConverter.php
fix missing lib
Added: trunk/mapbender/http/extensions/path-converter-master/LICENSE
--- trunk/mapbender/http/extensions/path-converter-master/LICENSE (rev 0)
+++ trunk/mapbender/http/extensions/path-converter-master/LICENSE 2019-02-13 14:24:05 UTC (rev 10055)
@@ -0,0 +1,18 @@
+Copyright (c) 2015 Matthias Mullie
+Permission is hereby granted, free of charge, to any person obtaining a copy of
+this software and associated documentation files (the "Software"), to deal in
+the Software without restriction, including without limitation the rights to
+use, copy, modify, merge, publish, distribute, sublicense, and/or sell copies of
+the Software, and to permit persons to whom the Software is furnished to do so,
+subject to the following conditions:
+The above copyright notice and this permission notice shall be included in all
+copies or substantial portions of the Software.
+THE SOFTWARE IS PROVIDED "AS IS", WITHOUT WARRANTY OF ANY KIND, EXPRESS OR
+IMPLIED, INCLUDING BUT NOT LIMITED TO THE WARRANTIES OF MERCHANTABILITY, FITNESS
+FOR A PARTICULAR PURPOSE AND NONINFRINGEMENT. IN NO EVENT SHALL THE AUTHORS OR
+COPYRIGHT HOLDERS BE LIABLE FOR ANY CLAIM, DAMAGES OR OTHER LIABILITY, WHETHER
+IN AN ACTION OF CONTRACT, TORT OR OTHERWISE, ARISING FROM, OUT OF OR IN
+CONNECTION WITH THE SOFTWARE OR THE USE OR OTHER DEALINGS IN THE SOFTWARE.
Added: trunk/mapbender/http/extensions/path-converter-master/composer.json
--- trunk/mapbender/http/extensions/path-converter-master/composer.json (rev 0)
+++ trunk/mapbender/http/extensions/path-converter-master/composer.json 2019-02-13 14:24:05 UTC (rev 10055)
@@ -0,0 +1,28 @@
+ "name": "matthiasmullie/path-converter",
+ "type": "library",
+ "description": "Relative path converter",
+ "keywords": ["relative", "path", "converter", "paths"],
+ "homepage": "http://github.com/matthiasmullie/path-converter",
+ "license": "MIT",
+ "authors": [
+ "name": "Matthias Mullie",
+ "homepage": "http://www.mullie.eu",
+ "email": "pathconverter at mullie.eu",
+ "role": "Developer"
+ "require": {
+ "php": ">=5.3.0",
+ "ext-pcre": "*"
+ "require-dev": {
+ "phpunit/phpunit": "~4.8"
+ "autoload": {
+ "psr-4": {
+ "MatthiasMullie\\PathConverter\\": "src/"
Added: trunk/mapbender/http/extensions/path-converter-master/src/Converter.php
--- trunk/mapbender/http/extensions/path-converter-master/src/Converter.php (rev 0)
+++ trunk/mapbender/http/extensions/path-converter-master/src/Converter.php 2019-02-13 14:24:05 UTC (rev 10055)
@@ -0,0 +1,196 @@
+<?php
+namespace MatthiasMullie\PathConverter;
+ * Convert paths relative from 1 file to another.
+ * E.g.
+ * ../../images/icon.jpg relative to /css/imports/icons.css
+ * becomes
+ * ../images/icon.jpg relative to /css/minified.css
+ * Please report bugs on https://github.com/matthiasmullie/path-converter/issues
+ * @author Matthias Mullie <pathconverter at mullie.eu>
+ * @copyright Copyright (c) 2015, Matthias Mullie. All rights reserved
+ * @license MIT License
+class Converter implements ConverterInterface
+ * @var string
+ protected $from;
+ * @var string
+ protected $to;
+ * @param string $from The original base path (directory, not file!)
+ * @param string $to The new base path (directory, not file!)
+ * @param string $root Root directory (defaults to `getcwd`)
+ public function __construct($from, $to, $root = '')
+ $shared = $this->shared($from, $to);
+ if ($shared === '') {
+ // when both paths have nothing in common, one of them is probably
+ // absolute while the other is relative
+ $root = $root ?: getcwd();
+ $from = strpos($from, $root) === 0 ? $from : preg_replace('/\/+/', '/', $root.'/'.$from);
+ $to = strpos($to, $root) === 0 ? $to : preg_replace('/\/+/', '/', $root.'/'.$to);
+ // or traveling the tree via `..`
+ // attempt to resolve path, or assume it's fine if it doesn't exist
+ $from = @realpath($from) ?: $from;
+ $to = @realpath($to) ?: $to;
+ $from = $this->dirname($from);
+ $to = $this->dirname($to);
+ $from = $this->normalize($from);
+ $to = $this->normalize($to);
+ $this->from = $from;
+ $this->to = $to;
+ * Normalize path.
+ * @param string $path
+ * @return string
+ protected function normalize($path)
+ // deal with different operating systems' directory structure
+ $path = rtrim(str_replace(DIRECTORY_SEPARATOR, '/', $path), '/');
+ * Example:
+ * /home/forkcms/frontend/cache/compiled_templates/../../core/layout/css/../images/img.gif
+ * to
+ * /home/forkcms/frontend/core/layout/images/img.gif
+ do {
+ $path = preg_replace('/[^\/]+(?<!\.\.)\/\.\.\//', '', $path, -1, $count);
+ } while ($count);
+ return $path;
+ * Figure out the shared path of 2 locations.
+ * Example:
+ * and
+ * /home/forkcms/frontend/cache/minified_css
+ * share
+ * @param string $path1
+ * @param string $path2
+ * @return string
+ protected function shared($path1, $path2)
+ // $path could theoretically be empty (e.g. no path is given), in which
+ // case it shouldn't expand to array(''), which would compare to one's
+ // root /
+ $path1 = $path1 ? explode('/', $path1) : array();
+ $path2 = $path2 ? explode('/', $path2) : array();
+ $shared = array();
+ // compare paths & strip identical ancestors
+ foreach ($path1 as $i => $chunk) {
+ if (isset($path2[$i]) && $path1[$i] == $path2[$i]) {
+ $shared[] = $chunk;
+ } else {
+ break;
+ return implode('/', $shared);
+ * E.g.
+ * ../images/img.gif relative to /home/forkcms/frontend/core/layout/css
+ * should become:
+ * ../../core/layout/images/img.gif relative to
+ * @param string $path The relative path that needs to be converted
+ * @return string The new relative path
+ public function convert($path)
+ // quit early if conversion makes no sense
+ if ($this->from === $this->to) {
+ return $path;
+ $path = $this->normalize($path);
+ // if we're not dealing with a relative path, just return absolute
+ if (strpos($path, '/') === 0) {
+ return $path;
+ // normalize paths
+ $path = $this->normalize($this->from.'/'.$path);
+ // strip shared ancestor paths
+ $shared = $this->shared($path, $this->to);
+ $path = mb_substr($path, mb_strlen($shared));
+ $to = mb_substr($this->to, mb_strlen($shared));
+ // add .. for every directory that needs to be traversed to new path
+ $to = str_repeat('../', count(array_filter(explode('/', $to))));
+ return $to.ltrim($path, '/');
+ * Attempt to get the directory name from a path.
+ * @return string
+ protected function dirname($path)
+ if (@is_file($path)) {
+ return dirname($path);
+ if (@is_dir($path)) {
+ return rtrim($path, '/');
+ // no known file/dir, start making assumptions
+ // ends in / = dir
+ if (mb_substr($path, -1) === '/') {
+ // has a dot in the name, likely a file
+ if (preg_match('/.*\..*$/', basename($path)) !== 0) {
+ // you're on your own here!
+ return $path;
Added: trunk/mapbender/http/extensions/path-converter-master/src/ConverterInterface.php
--- trunk/mapbender/http/extensions/path-converter-master/src/ConverterInterface.php (rev 0)
+++ trunk/mapbender/http/extensions/path-converter-master/src/ConverterInterface.php 2019-02-13 14:24:05 UTC (rev 10055)
@@ -0,0 +1,24 @@
+<?php
+ * Convert file paths.
+interface ConverterInterface
+ * @param string $path The path to be converted
+ * @return string The new path
+ public function convert($path);
Added: trunk/mapbender/http/extensions/path-converter-master/src/NoConverter.php
--- trunk/mapbender/http/extensions/path-converter-master/src/NoConverter.php (rev 0)
+++ trunk/mapbender/http/extensions/path-converter-master/src/NoConverter.php 2019-02-13 14:24:05 UTC (rev 10055)
@@ -0,0 +1,23 @@
+<?php
+ * Don't convert paths.
+class NoConverter implements ConverterInterface
+ * {@inheritdoc}
+ return $path;
More information about the Mapbender_commits
