[Mapbender-commits] r10040 - in trunk/mapbender/http: classes php
svn_mapbender at osgeo.org svn_mapbender at osgeo.org
Mon Jan 28 08:39:01 PST 2019
Author: armin11
Date: 2019-01-28 08:39:01 -0800 (Mon, 28 Jan 2019)
New Revision: 10040
   trunk/mapbender/http/classes/class_cswClient.php
   trunk/mapbender/http/php/mod_callCswMetadata.php
More options for external csw search via json api
Modified: trunk/mapbender/http/classes/class_cswClient.php
--- trunk/mapbender/http/classes/class_cswClient.php	2019-01-23 12:47:43 UTC (rev 10039)
+++ trunk/mapbender/http/classes/class_cswClient.php	2019-01-28 16:39:01 UTC (rev 10040)
@@ -164,10 +164,21 @@
 					if ($additionalFilter !== false) {
 						$postRequest .= '<ogc:And>';
-                    			$postRequest .= '<ogc:PropertyIsEqualTo>';
-                       			$postRequest .= '<ogc:PropertyName>Type</ogc:PropertyName>';
-                        		$postRequest .= '<ogc:Literal>'.$recordtype.'</ogc:Literal>';
-                    			$postRequest .= '</ogc:PropertyIsEqualTo>';
+					if ($recordtype == 'spatialData') {
+						$postRequest .= '<ogc:Or>';
+						foreach (array('dataset','series','tile') as $spatiaDataRecordType) {
+                    					$postRequest .= '<ogc:PropertyIsEqualTo>';
+                       					$postRequest .= '<ogc:PropertyName>Type</ogc:PropertyName>';
+                        				$postRequest .= '<ogc:Literal>'.$spatiaDataRecordType.'</ogc:Literal>';
+                    					$postRequest .= '</ogc:PropertyIsEqualTo>';
+						$postRequest .= '</ogc:Or>';
+					} else {
+                        			$postRequest .= '<ogc:Literal>'.$recordtype.'</ogc:Literal>';
 						$postRequest .= $additionalFilter;
@@ -209,10 +220,21 @@
-                       				$postRequest .= ' <ogc:PropertyName>Type</ogc:PropertyName>';
+						} else {
@@ -237,6 +259,7 @@
 				} else {
 					$e = new mb_exception("classes/class_cswClient.php: Operation getrecordspaging needs more parameters!");
+$e = new mb_exception("postrequest: ".$postRequest);
 					break;
 			default:
 				break;
Modified: trunk/mapbender/http/php/mod_callCswMetadata.php
--- trunk/mapbender/http/php/mod_callCswMetadata.php	2019-01-23 12:47:43 UTC (rev 10039)
+++ trunk/mapbender/http/php/mod_callCswMetadata.php	2019-01-28 16:39:01 UTC (rev 10040)
@@ -27,9 +27,11 @@
 $searchTypeBbox = "intersects"; //outside / inside
 $languageCode = "de";
 $outputFormat = 'json';
-//$searchResources = "dataset,service,application,other";
-//$searchResources = "dataset";
-$searchPages = "1";
+$dummySearchResources = "dataset,series,tile,service,application,nonGeographicDataset";
+//$dummySearchPages = "1,1,1,1,1,1";
+$searchResources = $dummySearchResources;
+$searchPages = $dummySearchPages;
 //	$resourceIds = NULL; //resourceIds is used to get a comma separated list with ids of the resources - layer - featuretypes - wmc
 //it will be used to filter some results
 $resultTarget = "web";
@@ -60,6 +62,7 @@
 //list of possibly hierarchyLevels - iso 19115 MD_ScopeCode
 $MD_ScopeCode = array("attribute","attributeType","collectionHardware","collectionSession","dataset","series","nonGeographicDataset","dimensionGroup","feature","featureType","propertyType","fieldSession","software","service","model","tile");
 $MD_ScopeCode[] = "application";
+$MD_ScopeCode[] = "spatialData";
 //control if some request variables are not set and set them explicit to NULL
 $checkForNullRequests = array("registratingDepartments","isoCategories","inspireThemes","customCategories","regTimeBegin","regTimeEnd","timeBegin","timeEnd","searchBbox","searchTypeBbox","searchResources","orderBy","hostName","resourceIds","restrictToOpenData");
@@ -358,7 +361,7 @@
 	$testMatch = $_REQUEST["searchResources"];
 	#$pattern = '/^(19|20)[0-9]{2}[-](0[1-9]|1[012])[-](0[1-9]|[12][0-9]|3[01])$/';
 	$countSR = count(explode(',',$testMatch));
- 	if (!($countSR >= 1 && $countSR <= 5)){
+ 	if (!($countSR >= 1 && $countSR <= 6)){
 		//echo 'searchResources: <b>'.$testMatch.'</b> count of requested resources out of sync.<br/>';
 		echo 'Parameter <b>searchResources</b> count of requested resource types is more than 5.<br/>';
 		die();
@@ -446,13 +449,13 @@
 if ($resultTarget == 'file' or $resultTarget == 'webclient') {
 	if (!isset($searchResources) OR ($searchResources == "")) {
-		$searchResources = "dataset,service,application,other";
+		$searchResources = $dummySearchResources;
 		$resolveCoupledResources = true;
-		$searchPages = "1,1,1,1";
+		$searchPages = $dummySearchPages;
-if (!isset($searchPages) OR ($searchPages == "")) {
+if (!isset($searchPages) OR ($searchPages == "") or count(explode(",",$searchPages)) !== count(explode(",",$searchResources))) {
 	for($i=0;$i<count(explode(",",$searchResources));$i++) {
 		$searchPages[$i] = 1;
@@ -473,17 +476,37 @@
 //begin main program
 $queryString  = $searchText;
-$queryStringParts = explode(" ",$queryString);
-$queryText = $queryStringParts[0];
-if ($queryText == '*') {
-	$queryText = '';
+$searchTextArray = explode(",",$queryString);
+$queryText = $queryStringArray[0];
+//if ($queryText == '*') {
+//	$queryText = '';
+//} else {
+if (count($searchTextArray) > 1) {
+	$fullTextFilter = "<ogc:And>";
+} else {
+	$fullTextFilter = "";
-//TODO query
-$fullTextFilter = '<ogc:PropertyIsLike wildCard="%" singleChar="_" escapeChar="">';
-$fullTextFilter .= '<ogc:PropertyName>AnyText</ogc:PropertyName>';
-$fullTextFilter .= '<ogc:Literal>%'.$queryText.'%</ogc:Literal>';
-$fullTextFilter .= '</ogc:PropertyIsLike>';
+foreach($searchTextArray as $queryString) {
+	$fullTextFilter .= '<ogc:PropertyIsLike wildCard="%" singleChar="_" escapeChar="">';
+	$fullTextFilter .= '<ogc:PropertyName>AnyText</ogc:PropertyName>';
+	$fullTextFilter .= '<ogc:Literal>%'.$queryString.'%</ogc:Literal>';
+	$fullTextFilter .= '</ogc:PropertyIsLike>';
+	$fullTextFilter .= "</ogc:And>";
+	$fullTextFilter .= '<ogc:Literal>%'.implode('%', $searchTextArray).'%</ogc:Literal>';
+	$fullTextFilter .= '</ogc:PropertyIsLike>';*/
+$e = new mb_exception("fulltextfilter: ".$fullTextFilter);
 $existsSpatialFilter = false;
 $searchBboxArray = explode(",", $searchBbox);
 if ($searchBbox !== NULL) {
@@ -521,8 +544,8 @@
 //combine filter
-if ($existsSpatialFilter == true){
-    $additionalFilter = "<And>".$fullTextFilter.$spatialFilter."</And>";
+if ($existsSpatialFilter == true && $queryText !== ''){
+    $additionalFilter = "<ogc:And>".$fullTextFilter.$spatialFilter."</ogc:And>";
 } else {
     $additionalFilter = $fullTextFilter;
@@ -566,11 +589,187 @@
 //log start time of distributed metadatdata search via csw interface
 $searchCswStartTime = microtime_float();
+$resultObject = new stdClass;
+//define object for dynamic filtering - actually only for searchResources
+$queryJSON = new stdClass;
+$queryJSON->searchFilter = (object) array();
+$queryJSON->searchFilter->origURL = $searchURL;
+//define where to become the information from - this is relevant for the information which must be pulled out of the database
+$classificationElements = array();
+$classificationElements[0]['name'] = 'searchText';
+$classificationElements[1]['name'] = 'searchBbox';
+$classificationElements[2]['name'] = 'searchResources';
+$classificationElements[0]['source'] = '';
+$classificationElements[1]['source'] = '';
+$classificationElements[2]['source'] = '';
+$classificationElements[0]['list'] = true;
+$classificationElements[1]['list'] = false;
+$classificationElements[2]['list'] = true;
+switch($languageCode){
+        case 'de':
+        	$classificationElements[0]['name2show'] = 'Suchbegriff(e):';
+		$classificationElements[1]['name2show'] = 'Räumliche Einschränkung:';
+		$classificationElements[2]['name2show'] = 'Art der Ressource:';
+		$resourceCategories['dataset'] = 'Datensätze';
+		$resourceCategories['spatialData'] = 'Geodaten';
+		$resourceCategories['series'] = 'Datensatzserien';
+		$resourceCategories['tile'] = 'Datensatzteile';
+		$resourceCategories['application'] = 'Anwendungen';
+		$resourceCategories['service'] = 'Dienste';
+		$resourceCategories['nonGeographicDataset'] = 'Daten ohne Raumbezug';
+		$orderByTitle['header'] = 'Sortierung nach:';
+		$orderByTitle['id'] = 'Identifizierungsnummer';
+		$orderByTitle['title'] = 'Alphabetisch';
+		$orderByTitle['rank'] = 'Nachfrage';
+		$orderByTitle['date'] = 'Letzte Änderung';
+		$maxResultsTitle['header'] = 'Treffer pro Seite:';
+       	break;
+        case 'en':
+        	$classificationElements[0]['name2show'] = 'Search Term(s):';
+		$classificationElements[1]['name2show'] = 'Spatial Filter:';
+		$classificationElements[2]['name2show'] = 'Kind of resource:';
+		$resourceCategories['dataset'] = 'Datasets';
+		$resourceCategories['spatialData'] = 'Spatial data';
+		$resourceCategories['series'] = 'Datasetseries';
+		$resourceCategories['tile'] = 'Datasetstiles';
+		$resourceCategories['application'] = 'Applications';
+		$resourceCategories['service'] = 'Services';
+		$resourceCategories['nonGeographicDataset'] = 'Data without spatial dimension';
+		$orderByTitle['header'] = 'Sort by:';
+		$orderByTitle['id'] = 'identification number';
+		$orderByTitle['title'] = 'alphabetically';
+		$orderByTitle['rank'] = 'demand';
+		$orderByTitle['date'] = 'last change';
+		$maxResultsTitle['header'] = 'Results per page:';
+        break;
+        case 'fr':
+        	$classificationElements[0]['name2show'] = 'Mots clés:';
+		$classificationElements[1]['name2show'] = 'Requête spatiale:';
+		$orderByTitle['header'] = 'classé selon:';
+		$orderByTitle['id'] = 'numéro d\'identification';
+		$orderByTitle['title'] = 'par ordre alphabétique';
+		$orderByTitle['rank'] = 'vue';
+		$orderByTitle['date'] = 'mise à jour';
+		$maxResultsTitle['header'] = 'Résultat par page:';
+       	break;
+     	default:
+		$orderByTitle['id'] = 'ID';
+		$orderByTitle['title'] = 'Titel';
+		$orderByTitle['rank'] = 'Relevanz';
+//generate search filter file - if more categories are defined give
+//echo "<br> number of filter elements: ".count($classificationElements)."<br>";
+for($i=0; $i < count($classificationElements); $i++){
+	//echo "<br> filter for element: ".$classificationElements[$i]['name']."<br>";
+	//echo "<br> variable for element: ". (string)${$classificationElements[$i]['name']}."<br>";
+	if (isset(${$classificationElements[$i]['name']}) & ${$classificationElements[$i]['name']} !='' & ${$classificationElements[$i]['name']} != NULL) {
+		//echo "<br> found: ".$classificationElements[$i]['name']."<br>";
+		//pull register information out of database in arrays
+		$queryJSON->searchFilter->{$classificationElements[$i]['name']}->title = $classificationElements[$i]['name2show'];
+		//check if the filter has subfilters - if not delete the whole filter from query
+		if ($classificationElements[$i]['list'] == false) { //the object has no subsets - like bbox or time filters
+			$queryJSON->searchFilter->{$classificationElements[$i]['name']}->delLink = delTotalFromQuery($classificationElements[$i]['name'],$searchURL);
+			$queryJSON->searchFilter->{$classificationElements[$i]['name']}->item = array();
+			if ($classificationElements[$i]['name'] == 'searchBbox') {
+				$sBboxTitle = $searchTypeBbox." ".${$classificationElements[$i]['name']};
+				$queryJSON->searchFilter->{$classificationElements[$i]['name']}->item[0]->title = $sBboxTitle;
+			else {
+			$queryJSON->searchFilter->{$classificationElements[$i]['name']}->item[0]->title = ${$classificationElements[$i]['name']};
+			$queryJSON->searchFilter->{$classificationElements[$i]['name']}->item[0]->delLink = delTotalFromQuery($classificationElements[$i]['name'],$searchURL);
+		} else {
+			//$e = new mb_exception('mod_callMetadata.php: $classificationElements[$i][name]: '.$classificationElements[$i]['name']);
+			//TODO delete all entries of this main category (not for searchText)
+			//$queryJSON->searchFilter->{$classificationElements[$i]['name']}->delLink = NULL;
+			//$e = new mb_exception('mod_callMetadata.php: dellink: '.$queryJSON->searchFilter->{$classificationElements[$i]['name']}->delLink);
+			$queryArray = explode(',', ${$classificationElements[$i]['name']});
+			//loop for the subcategories
+			for($j=0; $j < count($queryArray); $j++){
+				//$e = new mb_exception('mod_callMetadata.php: queryArrayi: '.$queryArray[$j]);
+				if ($classificationElements[$i]['name'] != 'searchResources') {
+					$queryJSON->searchFilter->{$classificationElements[$i]['name']}->item[$j]->title = $queryArray[$j];
+				} else {
+					$queryJSON->searchFilter->{$classificationElements[$i]['name']}->item[$j]->title = $resourceCategories[$queryArray[$j]];
+				//generate links to disable filters on a simple way
+				if (($classificationElements[$i]['name'] === 'searchText' || $classificationElements[$i]['name'] === 'searchResources') & count(explode(',',${$classificationElements[$i]['name']})) === 1) {
+					//$queryJSON->searchFilter->{$classificationElements[$i]['name']}->item[$j]->delLink = NULL;
+					$newSearchLink = delFromQuery($classificationElements[$i]['name'], $searchURL,$queryArray[$j],$queryArray,${$classificationElements[$i]['name']});
+					$newSearchLink = delTotalFromQuery('searchId',$newSearchLink);
+					$queryJSON->searchFilter->{$classificationElements[$i]['name']}->item[$j]->delLink = $newSearchLink;
+				} else {
 //get the first page to also count the available records:
 $i = 0;
-$resultObject = new stdClass;
 foreach ($searchResourcesArray as $searchResource) {
+	//$queryJSON->searchFilter->classes[$i]->title = $resourceCategories[$searchResourcesArray[$i]];
+	//$queryJSON->searchFilter->classes[$i]->name = $searchResourcesArray[$i];
 //echo $searchResource;
 //for ($i = 0; $i < 1 ; $i++) {
@@ -675,6 +874,8 @@
         $i++;
+//add filter object
+$resultObject->searchFilter = $queryJSON->searchFilter;
 echo json_encode($resultObject);
@@ -682,6 +883,8 @@
 //function to delete one of the comma separated values from one get request
 function delFromQuery($paramName,$queryString,$string,$queryArray,$queryList) {
+	global $dummySearchResources;
+	global $dummySearchPages;
 	//check if if count searchArray = 1
 	if (count($queryArray) == 1){
 		//remove request parameter from url by regexpr or replace
@@ -691,11 +894,12 @@
 		} else {
 			$str2exchange = "";
-		if ($paramName == "searchResources") {
-			$str2exchange = "searchResources=dataset,wms,wfs,wmc&";
+		/*if ($paramName == "searchResources") {
+			$str2exchange = "searchResources=".$dummySearchResources."&";
 		} else {
 			$str2exchange = "";
 		$queryStringNew = str_replace($str2search, $str2exchange, $queryString);
 		$queryStringNew = str_replace("&&", "&", $queryStringNew);
 	} else {
@@ -719,6 +923,8 @@
 //function to remove one complete get param out of the query
 function delTotalFromQuery($paramName,$queryString) {
 	//echo $paramName ."<br>";
 	$queryString = "&".$queryString;
 	if ($paramName == "searchText") {
@@ -726,9 +932,9 @@
 		} else {
 			$str2exchange = "";
 	$queryStringNew = preg_replace('/\b'.$paramName.'\=[^&]*&?/',$str2exchange,$queryString); //TODO find empty get params
 	$queryStringNew = ltrim($queryStringNew,'&');
 	$queryStringNew = rtrim($queryStringNew,'&');
More information about the Mapbender_commits mailing list
