[Mapbender-commits] r10169 - trunk/mapbender/http/javascripts
svn_mapbender at osgeo.org svn_mapbender at osgeo.org
Mon Jul 1 01:25:34 PDT 2019
Author: armin11
Date: 2019-07-01 01:25:34 -0700 (Mon, 01 Jul 2019)
New Revision: 10169
Added:
   trunk/mapbender/http/javascripts/mod_termsOfUse.php
Simple module that show the link to the terms of use of all used services in the current wmc
Added: trunk/mapbender/http/javascripts/mod_termsOfUse.php
--- trunk/mapbender/http/javascripts/mod_termsOfUse.php	                        (rev 0)
+++ trunk/mapbender/http/javascripts/mod_termsOfUse.php	2019-07-01 08:25:34 UTC (rev 10169)
@@ -0,0 +1,51 @@
+<?php
+require_once dirname(__FILE__) . "/../../core/globalSettings.php";
+# $Id: mod_copyright.php 6660 2010-07-30 09:34:33Z christoph $
+# http://www.mapbender.org/index.php/mod_copyright.php
+# Copyright (C) 2002 CCGIS
+# This program is free software; you can redistribute it and/or modify
+# it under the terms of the GNU General Public License as published by
+# the Free Software Foundation; either version 2, or (at your option)
+# any later version.
+# This program is distributed in the hope that it will be useful,
+# but WITHOUT ANY WARRANTY; without even the implied warranty of
+# MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE.  See the
+# GNU General Public License for more details.
+# You should have received a copy of the GNU General Public License
+# along with this program; if not, write to the Free Software
+# Foundation, Inc., 59 Temple Place - Suite 330, Boston, MA 02111-1307, USA.
+var mod_copyright_target = options.target;
+options.mod_copyright_text = typeof options.mod_copyright_text === "undefined" ? "mapbender.org" : options.mod_copyright_text;
+var mod_copyright_text = options.mod_copyright_text;
+var mod_copyright_left = 5;
+var mod_copyright_bottom = 20;
+var mod_copyright_color1 = "white";
+var mod_copyright_color2 = "black";
+var mod_copyright_font = "Arial, Helvetica, sans-serif";
+var mod_copyright_fontsize = "9px";
+eventAfterInit.register(function () {
+	mod_copyright();
+function mod_copyright(){
+	var myMapObj = Mapbender.modules[mod_copyright_target];
+	var str_c = "<div style='z-index:110;font-family:" + mod_copyright_font + ";font-size:" + mod_copyright_fontsize + ";color:" + mod_copyright_color2 + ";position:absolute;bottom:5px;right:5px'><a style='color:black;' href='../php/mod_getWmcDisclaimer.php?id=current' target='_blank'><?php echo _mb('Terms of use');?></a></div>";
+	var map_el = myMapObj.getDomElement();
+	if(!map_el.ownerDocument.getElementById(myMapObj.elementName+"_copyright")){
+		//create Box Elements
+		var el_top = map_el.ownerDocument.createElement("div");
+		el_top.style.overflow = "hidden";
+		el_top.id = myMapObj.elementName+"_copyright";
+		map_el.appendChild(el_top);
+	writeTag(myMapObj.frameName, myMapObj.elementName+"_copyright", str_c);
More information about the Mapbender_commits mailing list
