[Mapbender-commits] r10174 - in trunk/mapbender: http/classes http/php resources/locale/de_DE/LC_MESSAGES
svn_mapbender at osgeo.org
Tue Jul 2 08:26:00 PDT 2019
Author: armin11
Date: 2019-07-02 08:26:00 -0700 (Tue, 02 Jul 2019)
New Revision: 10174
trunk/mapbender/http/classes/class_metadata.php
trunk/mapbender/http/php/mod_getDownloadOptions.php
trunk/mapbender/resources/locale/de_DE/LC_MESSAGES/Mapbender.po
Add attributes for showing download service title and metadata when resolving coupled resources in catalogue search
Modified: trunk/mapbender/http/classes/class_metadata.php
--- trunk/mapbender/http/classes/class_metadata.php 2019-07-02 05:55:01 UTC (rev 10173)
+++ trunk/mapbender/http/classes/class_metadata.php 2019-07-02 15:26:00 UTC (rev 10174)
@@ -902,7 +902,8 @@
$this->wmsJSON->wms->srv[$j]->layer[0]->maxScale = $legendInfo['maxScale'];
//pull downloadOptions as json with function from other script: php/mod_getDownloadOptions.php
$downloadOptionsCs = str_replace("{","",str_replace("}","",str_replace("}{",",",$legendInfo['downloadOptions'])));
- $downloadOptions = json_decode(getDownloadOptions(explode(',',$downloadOptionsCs)));
+ //$downloadOptions = json_decode(getDownloadOptions(explode(',',$downloadOptionsCs)));
+$downloadOptions = json_decode(getDownloadOptions(explode(',',$downloadOptionsCs), $this->protocol."://".$this->hostName."/mapbender/"));
$this->wmsJSON->wms->srv[$j]->layer[0]->downloadOptions = $downloadOptions;
if ($subLayers[$rootIndex]['layer_name'] == ''){
@@ -2048,7 +2049,8 @@
$servObject->layer[$countsublayer]->maxScale = $legendInfo['maxScale'];
//$e = new mb_exception("class_metadata.php: legendInfo[downloadOptions]: ".$legendInfo['downloadOptions']);
//$e = new mb_exception("class_metadata.php: downloadOptions as string: ".json_encode($downloadOptions));
$servObject->layer[$countsublayer]->downloadOptions = $downloadOptions;
$servObject->layer[$countsublayer]->mdLink = $this->protocol."://".$this->hostName."/mapbender/php/mod_showMetadata.php?languageCode=".$this->languageCode."&resource=layer&layout=tabs&id=".$child['layer_id'];
Modified: trunk/mapbender/http/php/mod_getDownloadOptions.php
--- trunk/mapbender/http/php/mod_getDownloadOptions.php 2019-07-02 05:55:01 UTC (rev 10173)
+++ trunk/mapbender/http/php/mod_getDownloadOptions.php 2019-07-02 15:26:00 UTC (rev 10174)
@@ -99,7 +99,15 @@
$testMatch = NULL;
-function getDownloadOptions($idList) {
+if (defined("MAPBENDER_PATH") && MAPBENDER_PATH != '') {
+ $mapbenderPath = MAPBENDER_PATH."/";
+} else {
+ $mapbenderPath = "http://www.geoportal.rlp.de/mapbender/";
+$mapbenderPathArray = parse_url($mapbenderPath);
+$mapbenderServerUrl = $mapbenderPathArray['scheme']."://".$mapbenderPathArray['host'];
+function getDownloadOptions($idList, $webPath=false) {
//define query to pull all download options - actually only the inspire download services based on atom feeds
$sql = "select service_id, service_uuid, resource_id, resource_type, datalink, NULL as datalink_text, title,format from (
select service_id, resource_id, service_uuid, resource_type, fkey_datalink_id as datalink, title, format from (select fkey_wms_id as service_id, layer_id as resource_id, 'layer' as resource_type, layer.uuid as service_uuid, metadata_relation.title, format from layer inner join (select metadata_id, title, format, uuid, fkey_layer_id from mb_metadata inner join ows_relation_metadata on ows_relation_metadata.fkey_metadata_id = mb_metadata.metadata_id) ";
@@ -163,6 +171,13 @@
$downloadOptions->{$idList[$i]}->option[$j]->serviceUuid = $row['service_uuid'];
$downloadOptions->{$idList[$i]}->option[$j]->featureType[0] = $row['resource_id'];
$downloadOptions->{$idList[$i]}->option[$j]->format = $row['format'];
+ //new 2019/07
+ $downloadOptions->{$idList[$i]}->option[$j]->serviceType = "download";
+ $downloadOptions->{$idList[$i]}->option[$j]->serviceSubType = "ATOM";
+ $downloadOptions->{$idList[$i]}->option[$j]->serviceTitle = _mb('INSPIRE Download Service (predefined ATOM) for dataset').": ".$row['title']." - "._mb("based on WFS datasource");
+ $downloadOptions->{$idList[$i]}->option[$j]->mdLink = $webPath."php/mod_inspireAtomFeedISOMetadata.php?outputFormat=iso19139&generateFrom=wfs&wfsid=".$row['service_id']."&id=".$idList[$i];
+ $downloadOptions->{$idList[$i]}->option[$j]->htmlLink = $webPath."php/mod_exportIso19139.php?url=".$urlencode($downloadOptions->{$idList[$i]}->option[$j]->mdLink);
+ $downloadOptions->{$idList[$i]}->option[$j]->accessUrl = $webPath."php/mod_inspireDownloadFeed.php?id=".$idList[$i]."&type=SERVICE&generateFrom=wfs&wfsid=".$row['service_id'];
$downloadOptions->{$idList[$i]}->title = $row['title'];
$downloadOptions->{$idList[$i]}->uuid = $idList[$i];
@@ -181,6 +196,13 @@
$downloadOptions->{$idList[$i]}->option[$j]->resourceId = $row['resource_id'];
$downloadOptions->{$idList[$i]}->option[$j]->dataLink = $row['datalink'];
+ //new 2019/07
+ $downloadOptions->{$idList[$i]}->option[$j]->serviceTitle = _mb('INSPIRE Download Service (predefined ATOM) for dataset').": ".$row['title']." - "._mb("based on WMS datasource");
+ $downloadOptions->{$idList[$i]}->option[$j]->mdLink = $webPath."php/mod_inspireAtomFeedISOMetadata.php?outputFormat=iso19139&generateFrom=wmslayer&layerid=".$row['resource_id']."&id=".$idList[$i];
+ $downloadOptions->{$idList[$i]}->option[$j]->htmlLink = $webPath."php/mod_exportIso19139.php?url=".urlencode($downloadOptions->{$idList[$i]}->option[$j]->mdLink);
+ $downloadOptions->{$idList[$i]}->option[$j]->accessUrl = $webPath."php/mod_inspireDownloadFeed.php?id=".$idList[$i]."&type=SERVICE&generateFrom=wmslayer&layerid=".$row['resource_id'];
break;
@@ -194,6 +216,12 @@
$downloadOptions->{$idList[$i]}->option[$j]->link = $downloadLink->{"0"};
//check if
+ $downloadOptions->{$idList[$i]}->option[$j]->serviceTitle = _mb('INSPIRE Download Service (predefined ATOM) for dataset').": ".$row['title']." - "._mb("based on links from metadata");
+ $downloadOptions->{$idList[$i]}->option[$j]->mdLink = $webPath."php/mod_inspireAtomFeedISOMetadata.php?outputFormat=iso19139&generateFrom=metadata&id=".$idList[$i];
+ $downloadOptions->{$idList[$i]}->option[$j]->accessUrl = $webPath."php/mod_inspireDownloadFeed.php?id=".$idList[$i]."&type=SERVICE&generateFrom=metadata";
@@ -214,7 +242,8 @@
return $result;
-$downloadOptions = getDownloadOptions($idList);
+$downloadOptions = getDownloadOptions($idList, $mapbenderPath);
if ($downloadOptions != "null" && $outputFormat == "json") {
header('Content-Type: application/json; charset='.CHARSET);
echo $downloadOptions;
Modified: trunk/mapbender/resources/locale/de_DE/LC_MESSAGES/Mapbender.po
--- trunk/mapbender/resources/locale/de_DE/LC_MESSAGES/Mapbender.po 2019-07-02 05:55:01 UTC (rev 10173)
+++ trunk/mapbender/resources/locale/de_DE/LC_MESSAGES/Mapbender.po 2019-07-02 15:26:00 UTC (rev 10174)
@@ -4302,3 +4302,16 @@
msgid "click on single orange box generate download link below map (if seen)!"
msgstr "Klick auf orange Box generiert Downloadlink unterhalb des Kartenbildes (wenn vorhanden)!"
+msgid "INSPIRE Download Service (predefined ATOM) for dataset"
+msgstr "INSPIRE Downloaddienst (predefined ATOM) für Datensatz"
+msgid "based on WFS datasource"
+msgstr "basierend auf WFS Datenquelle"
+msgid "based on WMS datasource"
+msgstr "basierend auf WMS Datenquelle"
+msgid "based on links from metadata"
+msgstr "basierend auf Verlinkungen in Metadaten"
More information about the Mapbender_commits
