[Mapbender-commits] r10177 - in trunk/mapbender: http/classes http/javascripts http/plugins resources/locale/de_DE/LC_MESSAGES
svn_mapbender at osgeo.org
Wed Jul 3 02:35:45 PDT 2019
Author: armin11
Date: 2019-07-03 02:35:45 -0700 (Wed, 03 Jul 2019)
New Revision: 10177
trunk/mapbender/http/classes/class_wms.php
trunk/mapbender/http/javascripts/initWmcObj.php
trunk/mapbender/http/plugins/mb_sessionWmc.js
trunk/mapbender/resources/locale/de_DE/LC_MESSAGES/Mapbender.po
Add message if external wms could not be loaded!
Modified: trunk/mapbender/http/classes/class_wms.php
--- trunk/mapbender/http/classes/class_wms.php 2019-07-03 07:15:02 UTC (rev 10176)
+++ trunk/mapbender/http/classes/class_wms.php 2019-07-03 09:35:45 UTC (rev 10177)
@@ -1251,13 +1251,12 @@
$returnObject['success'] = false;
$returnObject['message'] = _mb("WMS could not be loaded!");
return $returnObject;
- else{
+ } else {
$this->wms_status = true;
$this->optimizeWMS();
$e = new mb_notice("class_wms: createObjFromXML: WMS " . $url . " has been loaded successfully.");
$returnObject['success'] = true;
+ $returnObject['message'] = _mb("WMS Capabilities has been parsed successfully!");
Modified: trunk/mapbender/http/javascripts/initWmcObj.php
--- trunk/mapbender/http/javascripts/initWmcObj.php 2019-07-03 07:15:02 UTC (rev 10176)
+++ trunk/mapbender/http/javascripts/initWmcObj.php 2019-07-03 09:35:45 UTC (rev 10177)
@@ -64,7 +64,11 @@
"wmcTou" => array(
"message" => ""
+ "notAccessable" => array(
+ "message" => _mb("Following WebMapService is not accessable or could not be invoked").":",
+ "wms" => array()
@@ -218,33 +222,54 @@
// get WMS by URL
elseif (array_key_exists('url', $multipleAssocArray)) {
$currentWms = new wms();
- $currentWms->createObjFromXML($multipleAssocArray['url']);
- else {
+ //try to parse capabilities - if not successful give message to unavailable array!
+//$e = new mb_exception("javascripts/initWmcObj.php: begin result of wms parsing: ");
+ $resultOfWmsParsing = $currentWms->createObjFromXML($multipleAssocArray['url']);
+//$e = new mb_exception("javascripts/initWmcObj.php: result of wms parsing: ".json_encode($resultOfWmsParsing));
+ } else {
continue;
- array_push($wmsArray, $currentWms);
- $options['visible'] = $multipleAssocArray['visible'] === "1" ?
- true : false;
- $options['zoom'] = $multipleAssocArray['zoom'] === "1" ?
- true : false;
- $wmcGetApi->mergeWmsArray($wmsArray, $options);
- $wmsArray = array();
- $multipleAssocArray = array();
+ if ($resultOfWmsParsing['success'] == true) {
+ array_push($wmsArray, $currentWms);
+ $options['visible'] = $multipleAssocArray['visible'] === "1" ?
+ true : false;
+ $options['zoom'] = $multipleAssocArray['zoom'] === "1" ?
+ true : false;
+ $wmcGetApi->mergeWmsArray($wmsArray, $options);
+ $wmsArray = array();
+ $multipleAssocArray = array();
+ } else {
+//$e = new mb_exception("javascripts/initWmcObj.php: wms with problem: ".$multipleAssocArray['url']);
+ $resultObj["notAccessable"]["wms"] = array_merge(
+ $resultObj["notAccessable"]["wms"],
+ $multipleAssocArray['url'].' - '.$resultOfWmsParsing['message']
} else {
if(is_numeric($key)) {
// get WMS by ID
if (is_numeric($val)) {
- $currentWms->createObjFromDBNoGui($val);
+ $resultOfWmsParsing = $currentWms->createObjFromDBNoGui($val);
// get WMS by URL
else if (is_string($val)) {
- $currentWms->createObjFromXML($val);
+ $resultOfWmsParsing = $currentWms->createObjFromXML($val);
- $wmcGetApi->mergeWmsArray($wmsArray);
+ true : false;
+ true : false;
+ } else {
+//$e = new mb_exception("javascripts/initWmcObj.php: wms with problem: message: ".(string)$val." - ".$resultOfWmsParsing['message']);
+ $resultObj["notAccessable"]["wms"][] = htmlentities($val)." - ("._mb('Notice')."</b>: ".$resultOfWmsParsing['message'].")";
else {
$singleAssocArray[$key] = $val;
Modified: trunk/mapbender/http/plugins/mb_sessionWmc.js
--- trunk/mapbender/http/plugins/mb_sessionWmc.js 2019-07-03 07:15:02 UTC (rev 10176)
+++ trunk/mapbender/http/plugins/mb_sessionWmc.js 2019-07-03 09:35:45 UTC (rev 10177)
@@ -137,6 +137,11 @@
dialogHasContent = true;
continue;
+ /*if (constraintType === "notAccessable" && caseObj.message != "") {
+ html += "<fieldset>"+caseObj.message+"</fieldset>";
+ dialogHasContent = true;
+ continue;
if (caseObj.wms && caseObj.wms.length === 0) {
continue;
@@ -144,19 +149,29 @@
var permissionHtml = "";
for (var index in caseObj.wms) {
var wms = caseObj.wms[index];
- permissionHtml += "<label for='" + constraintType + "_" + wms.index + "'>" +
- (constraintType === "noPermission" ? "<li>" : "<input id='" + options.id + "_" + constraintType + "_" + wms.index + "' " + "type='checkbox' checked='checked' />") +
- wms.title + "</label><br>";
- wmsCount++;
+ if (constraintType !== "notAccessable") {
+ permissionHtml += "<label for='" + constraintType + "_" + wms.index + "'>" +
+ (constraintType === "noPermission" ? "<li>" : "<input id='" + options.id + "_" + constraintType + "_" + wms.index + "' " + "type='checkbox' checked='checked' />") +
+ wms.title + "</label><br>";
+ wmsCount++;
+ } else {
+ permissionHtml += wms;
+ wmsCount++;
if (wmsCount > 0) {
- html += "<fieldset>" + caseObj.message +
- "<br><ul>" + permissionHtml + "</ul>" :
- " "+translatedI18nObject.confirmationQuestion+"<br><br>" +
- permissionHtml
- ) + "</fieldset><br>";
- dialogHasContent = true;
+ //if (constraintType !== "notAccessable") {
+ html += "<fieldset>" + caseObj.message +
+ "<br><ul>" + permissionHtml + "</ul>" :
+ (constraintType === "notAccessable" ?
+ "<br><br>" :
+ " "+translatedI18nObject.confirmationQuestion+"<br><br>"
+ permissionHtml
constraintTypeArray.push(constraintType);
Modified: trunk/mapbender/resources/locale/de_DE/LC_MESSAGES/Mapbender.po
--- trunk/mapbender/resources/locale/de_DE/LC_MESSAGES/Mapbender.po 2019-07-03 07:15:02 UTC (rev 10176)
+++ trunk/mapbender/resources/locale/de_DE/LC_MESSAGES/Mapbender.po 2019-07-03 09:35:45 UTC (rev 10177)
@@ -4314,4 +4314,10 @@
msgid "based on links from metadata"
msgstr "basierend auf Verlinkungen in Metadaten"
+msgid "Following WebMapService is not accessable or could not be invoked"
+msgstr "Der folgenden WebMapService ist nicht erreichbar oder konnte nicht richtig aufgerufen werden"
+msgid "Notice"
+msgstr "Hinweis"
More information about the Mapbender_commits
