[Mapbender-commits] r10188 - trunk/mapbender/http/classes
svn_mapbender at osgeo.org
Mon Jul 29 06:41:27 PDT 2019
Author: armin11
Date: 2019-07-29 06:41:26 -0700 (Mon, 29 Jul 2019)
New Revision: 10188
trunk/mapbender/http/classes/class_gml_2_factory.php
trunk/mapbender/http/classes/class_gml_3_factory.php
trunk/mapbender/http/classes/class_gml_factory.php
trunk/mapbender/http/classes/class_gml_feature.php
trunk/mapbender/http/classes/class_gml_geometry.php
trunk/mapbender/http/classes/class_wfs.php
New options for wfs linked opendata proxy
Modified: trunk/mapbender/http/classes/class_gml_2_factory.php
--- trunk/mapbender/http/classes/class_gml_2_factory.php 2019-07-29 11:32:16 UTC (rev 10187)
+++ trunk/mapbender/http/classes/class_gml_2_factory.php 2019-07-29 13:41:26 UTC (rev 10188)
@@ -241,9 +241,13 @@
* @param $domNode DOMNodeObject the feature tag of the GML
* (<gml:featureMember> in the above example)
- protected function parseFeature($domNode, $feature, $wfsConf, $gmlBoundedBySrs) {
- $geomFeaturetypeElement = $wfsConf->getGeometryColumnName();
+ protected function parseFeature($domNode, $feature, $wfsConf, $gmlBoundedBySrs, $geometryColumnName=false) {
+ if ($geometryColumnName == false) {
+ //get name by information from wfs_conf
+ $geomFeaturetypeElement = $wfsConf->getGeometryColumnName();
+ } else {
+ $geomFeaturetypeElement = $geometryColumnName;
$currentSibling = $domNode;
$feature->fid = $currentSibling->getAttribute("fid");
@@ -321,9 +325,9 @@
* @return Gml_2
* @param $xml String
- public function createFromXml ($xml, $wfsConf) {
+ public function createFromXml ($xml, $wfsConf, $myWfs=false, $myFeatureType=false, $geomColumnName=false) {
$gml2 = new Gml_2();
- return parent::createFromXml($xml, $wfsConf, $gml2);
+ return parent::createFromXml($xml, $wfsConf, $gml2, $myWfs, $myFeatureType, $geomColumnName);
Modified: trunk/mapbender/http/classes/class_gml_3_factory.php
--- trunk/mapbender/http/classes/class_gml_3_factory.php 2019-07-29 11:32:16 UTC (rev 10187)
+++ trunk/mapbender/http/classes/class_gml_3_factory.php 2019-07-29 13:41:26 UTC (rev 10188)
@@ -48,9 +48,9 @@
* @return Gml_3
$gml3 = new Gml_3();
- return parent::createFromXml($xml, $wfsConf, $gml3);
+ return parent::createFromXml($xml, $wfsConf, $gml3, $myWfs, $myFeatureType, $geomColumnName);
public static function getDimensionFromNode ($domNode) {
@@ -342,9 +342,13 @@
+ } else {
$feature->fid = $domNode->getAttribute("gml:id");
$currentSibling = $domNode->firstChild;
@@ -358,7 +362,7 @@
$ns = $namespace['ns'];
$columnName = $namespace['value'];
$isGeomColumn = ($geomFeaturetypeElement == null || $columnName == $geomFeaturetypeElement);
+ //$e = new mb_exception("classes/class_gml3_factory.php: current column name: ".$columnName." - compare to geomname: ". $geomFeaturetypeElement);
// check if this node is a geometry node.
// however, even if it is a property node,
// it has a child node, the text node!
Modified: trunk/mapbender/http/classes/class_gml_factory.php
--- trunk/mapbender/http/classes/class_gml_factory.php 2019-07-29 11:32:16 UTC (rev 10187)
+++ trunk/mapbender/http/classes/class_gml_factory.php 2019-07-29 13:41:26 UTC (rev 10188)
@@ -214,21 +214,24 @@
* @return Gml
- public function createFromXml ($xml, $wfsConf, $gml) {
+ public function createFromXml ($xml, $wfsConf, $gml, $myWfs=false, $myFeatureType=false, $geomColumnName=false) {
try {
$xml = $this->removeWhiteSpace($xml);
$gmlDoc = new SimpleXMLElement($xml);
- // we need to find the name and namespaces of the featuretype
- // used in this WFS configuration
- $wfsFactory = new UniversalWfsFactory();
- $myWfs = $wfsFactory->createFromDb($wfsConf->wfsId);
- if (is_null($myWfs)) {
- new mb_exception("class_gml_factory.php: createFromXml: WFS not found! ID: " . $wfsConf->wfsId);
- return null;
+ //$e = new mb_exception("wfs: ".gettype($myWfs)." ft: ".gettype($myFeatureType)." geomname: ".$geomColumnName);
+ if ($myWfs != false && $myFeatureType != false && $geomColumnName != false) {
+ $featureType = $myFeatureType;
+ } else {
+ // we need to find the name and namespaces of the featuretype
+ // used in this WFS configuration
+ $wfsFactory = new UniversalWfsFactory();
+ $myWfs = $wfsFactory->createFromDb($wfsConf->wfsId);
+ if (is_null($myWfs)) {
+ new mb_exception("class_gml_factory.php: createFromXml: WFS not found or given! ID: " . $wfsConf->wfsId);
+ return null;
+ $featureType = $myWfs->findFeatureTypeById($wfsConf->featureTypeId);
- $featureType = $myWfs->findFeatureTypeById($wfsConf->featureTypeId);
// register namespace of feature type
$pos = strpos($featureType->name, ":");
if ($pos !== false) {
@@ -256,7 +259,7 @@
foreach ($gmlFeatureMembers as $gmlFeatureMember) {
$gmlfeatureMember_dom = dom_import_simplexml($gmlFeatureMember);
$feature = new Feature();
- $this->parseFeature($gmlfeatureMember_dom->firstChild, $feature, $wfsConf, $gmlBoundedBySrs);
+ $this->parseFeature($gmlfeatureMember_dom->firstChild, $feature, $wfsConf, $gmlBoundedBySrs, $geomColumnName);
if (isset($feature->geometry)) {
$gml->featureCollection->addFeature($feature);
@@ -271,7 +274,7 @@
- $this->parseFeature($gmlfeatureMember_dom, $feature, $wfsConf, $gmlBoundedBySrs);
+ $this->parseFeature($gmlfeatureMember_dom, $feature, $wfsConf, $gmlBoundedBySrs, $geomColumnName);
Modified: trunk/mapbender/http/classes/class_gml_feature.php
--- trunk/mapbender/http/classes/class_gml_feature.php 2019-07-29 11:32:16 UTC (rev 10187)
+++ trunk/mapbender/http/classes/class_gml_feature.php 2019-07-29 13:41:26 UTC (rev 10188)
@@ -82,4 +82,4 @@
\ No newline at end of file
Modified: trunk/mapbender/http/classes/class_gml_geometry.php
--- trunk/mapbender/http/classes/class_gml_geometry.php 2019-07-29 11:32:16 UTC (rev 10187)
+++ trunk/mapbender/http/classes/class_gml_geometry.php 2019-07-29 13:41:26 UTC (rev 10188)
@@ -21,6 +21,7 @@
require_once(dirname(__FILE__)."/../classes/class_connector.php");
require_once(dirname(__FILE__)."/../classes/class_json.php");
require_once(dirname(__FILE__)."/../classes/class_gml_feature_collection.php");
+require_once(dirname(__FILE__)."/../classes/class_crs.php");
abstract class GmlGeometry {
@@ -45,10 +46,13 @@
public function isLatLonSrs ($geomSrs) {
//use user defined $latLonSrsArray from file epsg.php for check
- require_once(dirname(__FILE__)."/../../core/epsg.php");
- $pattern = '/urn/';
- if(preg_match($pattern, $geomSrs)) {
+ //require_once(dirname(__FILE__)."/../../core/epsg.php");
+ //new 2019-07-29
+ $crs = new Crs($geomSrs);
+ //$crs->axisOrder > different types:'east,north' - ('lon,lat') or 'north,east' - ('lat,lon')
+ //TODO: alter geometry classes to handle crs in a right way!
+ //$pattern = '/urn/';
+ /*if(preg_match($pattern, $geomSrs)) {
if(in_array($geomSrs, $latLonSrsArray)) {
return true;
@@ -55,8 +59,13 @@
else {
return false;
+//$e = new mb_exception("classes/class_gml_geometry.php: axis order found: ".$crs->axisOrder);
+ if($crs->axisOrder == 'north,east') {
+ return true;
+ } else {
+ return false;
- return false;
Modified: trunk/mapbender/http/classes/class_wfs.php
--- trunk/mapbender/http/classes/class_wfs.php 2019-07-29 11:32:16 UTC (rev 10187)
+++ trunk/mapbender/http/classes/class_wfs.php 2019-07-29 13:41:26 UTC (rev 10188)
@@ -24,6 +24,7 @@
require_once(dirname(__FILE__)."/class_ows.php");
require_once(dirname(__FILE__)."/class_wfsToDb.php");
require_once(dirname(__FILE__)."/class_wfs_configuration.php");
+require_once(dirname(__FILE__)."/class_crs.php");
* An abstract Web Feature Service (WFS) class, modelling for example
@@ -53,7 +54,7 @@
array_push($this->featureTypeArray, $aFeatureType);
- protected function findFeatureTypeByName ($name) {
+ public function findFeatureTypeByName ($name) {
foreach ($this->featureTypeArray as $ft) {
if ($ft->name == $name) {
return $ft;
@@ -92,6 +93,19 @@
return null;
+ public static function findGeomColumnNameByFeaturetypeId($ftId) {
+ $geomTypesArray = array('GeometryPropertyType','PointPropertyType','LineStringPropertyType','PolygonPropertyType','MultiPointPropertyType','MultiLineStringPropertyType','MultiPolygonPropertyType');
+ $sql = "SELECT element_name, element_type FROM wfs_element WHERE fkey_featuretype_id = $1";
+ $res = db_prep_query($sql, array($ftId), array("i"));
+ //simple uses first supported geom type!
+ while($row = db_fetch_array($res)){
+ if (in_array($row['element_type'], $geomTypesArray)) {
+ return $row['element_name'];
+ return null;
protected function getFeatureGet ($featureTypeName, $filter, $maxFeatures=null) {
switch ($this->getVersion()) {
@@ -248,7 +262,7 @@
// return $this->getFeatureGet($featureTypeName, $filter);
- protected function getFeaturePostPaging ($featureTypeName, $filter, $destSrs, $storedQueryId, $storedQueryParams, $maxFeatures, $startIndex, $version=false) {
+ protected function getFeaturePostPaging ($featureTypeName, $filter, $destSrs, $storedQueryId, $storedQueryParams, $maxFeatures, $startIndex, $version=false, $outputFormat=false) {
if ($version == false) {
$version = $this->getVersion();
} else {
@@ -342,6 +356,33 @@
//TODO test if post is ok! mapserver in trier don't allow it?
//test get request
$getRequest = $this->getFeature.""."SERVICE=wfs&VERSION=".$version."&REQUEST=GetFeature"."&".$typeNameParameterName."=".$featureTypeName."&".$maxFeaturesParameterName."=".$maxFeatures."&STARTINDEX=".$startIndex."&".$maxFeaturesParameterName."=".$maxFeatures;
+ if ($outputFormat != false) {
+ $getRequest .= "&outputFormat=".$outputFormat;
+ if ($destSrs != false) {
+ //check crs representation
+ $crs = new Crs($destSrs);
+ $alterAxisOrder = $crs->alterAxisOrder("wfs_".$version);
+ $srsId = $crs->identifierCode;
+ //add srs to request
+ switch ($version) {
+ case "2.0.2":
+ $getRequest .= "&SRSNAME="."http://www.opengis.net/def/crs/EPSG/0/".$srsId;
+ break;
+ case "2.0.0":
+ $getRequest .= "&SRSNAME="."urn:ogc:def:crs:EPSG::".$srsId;
+ break;
+ case "1.1.0":
+ break;
+ case "1.0.0":
+ $getRequest .= "&SRSNAME="."EPSG:".$srsId;
+ break;
+$e = new mb_exception($getRequest);
+ //convert gml 3 to geojson!
return $this->get($getRequest);
//other variants
//return $this->post($this->getFeature.$maxFeaturesParameterName."=".$maxFeatures."&STARTINDEX=".$startIndex, $postData); //from class_ows!
@@ -551,7 +592,12 @@
"</wfs:Update>";
- public function getFeatureById ($featureTypeName, $outputFormat=false, $id) {
+ public function getFeatureById ($featureTypeName, $outputFormat=false, $id, $version=false, $srsName=false) {
+ if ($version == false) {
+ $version = $this->getVersion();
+ } else {
+ $e = new mb_exception("classes/class_wfs.php: wfs version forced too ".$version."!");
case "2.0.2":
$typeNameParameterName = "typeNames";
@@ -569,12 +615,36 @@
$featureIdParameterName = "featureID";
break;
- $url = $this->getFeature .
+ $getRequest = $this->getFeature .
$this->getConjunctionCharacter($this->getFeature) .
"service=WFS&request=GetFeature&version=" .
$this->getVersion() . "&".strtolower($typeNameParameterName)."=" . $featureTypeName."&".$featureIdParameterName."=".$id;
-$e = new mb_exception($url);
- return $this->get($url); //from class_ows!
+ if ($srsName != false) {
+ $crs = new Crs($srsName);
+ case "2.0.2":
+ break;
+ case "2.0.0":
+ break;
+ case "1.1.0":
+ break;
+ case "1.0.0":
+ break;
+ return $this->get($getRequest); //from class_ows!
protected function transactionDelete ($feature, $featureType, $authWfsConfElement) {
@@ -589,9 +659,7 @@
$featureNS . ":" . $authWfsConfElement->name .
"</ogc:PropertyName><ogc:Literal>" .
$user . "</ogc:Literal></ogc:PropertyIsEqualTo>";
// filter
if (!isset($feature->fid)) {
$e = new mb_exception("Feature ID not set.");
More information about the Mapbender_commits
