[Mapbender-commits] r10141 - trunk/mapbender/resources/db
svn_mapbender at osgeo.org svn_mapbender at osgeo.org
Thu Jun 6 06:07:32 PDT 2019
Author: armin11
Date: 2019-06-06 06:07:32 -0700 (Thu, 06 Jun 2019)
New Revision: 10141
   trunk/mapbender/resources/db/gui_Administration_DE.sql
   trunk/mapbender/resources/db/gui_PortalAdmin_DE.sql
some enhancements from hesse - thanx to karlo ;-)
Modified: trunk/mapbender/resources/db/gui_Administration_DE.sql
--- trunk/mapbender/resources/db/gui_Administration_DE.sql	2019-06-06 09:39:23 UTC (rev 10140)
+++ trunk/mapbender/resources/db/gui_Administration_DE.sql	2019-06-06 13:07:32 UTC (rev 10141)
@@ -1,180 +1,165 @@
-INSERT INTO gui (gui_id, gui_name, gui_description, gui_public) VALUES ('Administration_DE','Administration_DE','Administrationsoberfläche',1);
-INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('Administration_DE','body',1,1,'Navigation','','body','','',0,0,200,40,NULL ,'','','','../geoportal/mod_revertGuiSessionSettings.php','','','','');
-INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('Administration_DE','body','favicon','../img/favicon.png','favicon','php_var');
-INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('Administration_DE','body','includeWhileLoading','','show splash screen while the application is loading','php_var');
-INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('Administration_DE','body','jq_ui_effects_transfer','.ui-effects-transfer { z-index:1003; border: 2px dotted gray; } ','','text/css');
-INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('Administration_DE','body','jq_ui_theme','../extensions/jquery-ui-1.7.2.custom/css/smoothness/jquery-ui-1.7.2.custom.css','','file/css');
-INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('Administration_DE','body','use_load_message','false','show splash screen while the application is loading','php_var');
-INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('Administration_DE','i18n',1,1,'Internationalization module, collects data from all elements and sends them to the server in a single POST request. The strings are translated via gettext only.','Internationalization','div','','',NULL ,NULL,NULL ,NULL,NULL ,'','','div','../plugins/mb_i18n.js','','','','http://www.mapbender.org/Gettext');
-INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('Administration_DE','jq_ui_widget',1,1,'jQuery UI widget','','','','',NULL ,NULL,NULL ,NULL,NULL ,'','','','','../extensions/jquery-ui-1.8.16.custom/development-bundle/ui/jquery.ui.widget.js','','','');
-INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('Administration_DE','jq_ui',1,1,'jQuery UI core','','','','',NULL ,NULL,NULL ,NULL,NULL ,'','','','','../extensions/jquery-ui-1.8.16.custom/development-bundle/ui/jquery.ui.core.js','','','');
-INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('Administration_DE','jq_ui','css','../extensions/jquery-ui-1.7.2.custom/css/ui-lightness/jquery-ui-1.7.2.custom.css','','file/css');
-INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('Administration_DE','updateWMSs_collection',2,1,'Put existing divs in new div object. List the elements comma-separated under target, and make sure they have a title.','','div','','',0,40,200,30,NULL ,'','','div','../plugins/mb_div_collection.js','','updateWMSs,updateWMSs_icon','','');
-INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('Administration_DE','wmc_metadata_collection',2,1,'Put existing divs in new div object. List the elements comma-separated under target, and make sure they have a title.','','div','','',0,0,200,30,NULL ,'','','div','../plugins/mb_div_collection.js','','wmc_metadata,wmc_metadata_icon','','');
-INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('Administration_DE','menu_wmc',2,1,'WMC admin menu','Admin WMC','div','','',NULL ,NULL,NULL ,NULL,NULL ,'','','div','../plugins/mb_div_collection.js','','wmc_metadata_collection','','');
-INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('Administration_DE','menu_wmc','css','../extensions/jquery-ui-1.7.2.custom/css/ui-lightness/jquery-ui-1.7.2.custom.css','','file/css');
-INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('Administration_DE','monitor_results_collection',2,1,'Put existing divs in new div object. List the elements comma-separated under target, and make sure they have a title.','','div','','',0,200,200,30,NULL ,'','','div','../plugins/mb_div_collection.js','','monitor_results,monitor_results_icon','','');
-INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('Administration_DE','monitor_results_icon',2,1,'icon','','img','../img/gnome/preferences-desktop-remote-desktop.png','',0,0,NULL ,NULL,2,'','','','','','','','');
-INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('Administration_DE','wmc_metadata_icon',2,1,'icon','','img','../img/gnome/preferences-desktop-personal.png','',0,0,NULL ,NULL,2,'','','','','','','','');
-INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('Administration_DE','loadWFS_icon',2,1,'icon','','img','../img/gnome/document-save.png','',0,0,NULL ,NULL,2,'','','','','','','','');
-INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('Administration_DE','updateWMSs_icon',2,1,'icon','','img','../img/gnome/view-refresh.png','',0,0,NULL ,NULL,2,'','','','','','','','');
-INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('Administration_DE','wfs_metadata_icon',2,1,'icon','','img','../img/gnome/preferences-desktop-personal.png','',0,0,NULL ,NULL,2,'','','','','','','','');
-INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('Administration_DE','wfs_metadata_collection',2,1,'Put existing divs in new div object. List the elements comma-separated under target, and make sure they have a title.','','div','','',150,0,200,30,NULL ,'','','div','../plugins/mb_div_collection.js','','wfs_metadata,wfs_metadata_icon','','');
-INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('Administration_DE','wms_metadata_icon',2,1,'icon','','img','../img/gnome/preferences-desktop-personal.png','',0,0,NULL ,NULL,2,'','','','','','','','');
-INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('Administration_DE','wms_mail_abo_icon',2,1,'icon','','img','../img/gnome/mail-message-new.png','',0,0,NULL ,NULL,2,'','','','','','','','');
-INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('Administration_DE','deleteGui',2,0,'delete gui','Delete GUI','a','','href = "../php/mod_deleteGUI.php?sessionID" ',80,15,200,20,NULL ,'font-family: Arial, Helvetica, sans-serif; font-size : 12px; text-decoration : none; color: #808080;','DELETE GUI','a','','','','','http://www.mapbender.org/index.php/DeleteGUI');
-INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('Administration_DE','updateWFS_icon',2,1,'icon','','img','../img/gnome/view-refresh.png','',0,0,NULL ,NULL,2,'','','','','','','','');
-INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('Administration_DE','deleteWFS_collection',2,1,'Put existing divs in new div object. List the elements comma-separated under target, and make sure they have a title.','','div','','',0,80,200,30,NULL ,'','','div','../plugins/mb_div_collection.js','','deleteWFS,deleteWFS_icon','','');
-INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('Administration_DE','editGUI_WFS_icon',2,1,'icon','','img','../img/gnome/preferences-other.png','',0,0,NULL ,NULL,2,'','','','','','','','');
-INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('Administration_DE','editGUI_WFS_collection',2,1,'Put existing divs in new div object. List the elements comma-separated under target, and make sure they have a title.','','div','','',0,120,200,30,NULL ,'','','div','../plugins/mb_div_collection.js','','editGUI_WFS,editGUI_WFS_icon','','');
-INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('Administration_DE','wms_mail_abo_collection',2,1,'Put existing divs in new div object. List the elements comma-separated under target, and make sure they have a title.','','div','','',150,40,200,30,NULL ,'','','div','../plugins/mb_div_collection.js','','monitor_abo_show,wms_mail_abo_icon','','');
-INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('Administration_DE','owsproxy_collection',2,1,'Put existing divs in new div object. List the elements comma-separated under target, and make sure they have a title.','','div','','',0,160,200,30,NULL ,'','','div','../plugins/mb_div_collection.js','','owsproxy,owsproxy_icon','','');
-INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('Administration_DE','owsproxy_wfs_collection',2,1,'Put existing divs in new div object. List the elements comma-separated under target, and make sure they have a title.','','div','','',0,160,200,30,NULL ,'','','div','../plugins/mb_div_collection.js','','owsproxy_wfs,owsproxy_wfs_icon','','');
-INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('Administration_DE','owsproxy_wfs_icon',2,1,'icon','','img','../img/gnome/emblem-readonly.png','',0,0,NULL ,NULL,2,'','','','','','','','');
-INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('Administration_DE','wfs_conf_icon',2,1,'icon','','img','../img/gnome/preferences-other.png','',0,0,NULL ,NULL,2,'','','','','','','','');
-INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('Administration_DE','wfs_conf_collection',2,1,'Put existing divs in new div object. List the elements comma-separated under target, and make sure they have a title.','','div','','',150,80,200,30,NULL ,'','','div','../plugins/mb_div_collection.js','','wfs_conf,wfs_conf_icon','','');
-INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('Administration_DE','deleteWFSConf_collection',2,1,'Put existing divs in new div object. List the elements comma-separated under target, and make sure they have a title.','','div','','',150,120,200,30,NULL ,'','','div','../plugins/mb_div_collection.js','','deleteWFSConf,deleteWFSConf_icon','','');
-INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('Administration_DE','editFilteredGroup_collection',2,1,'Put existing divs in new div object. List the elements comma-separated under target, and make sure they have a title.','','div','','',0,40,200,30,NULL ,'','','div','../plugins/mb_div_collection.js','','editFilteredGroup,editFilteredGroup_icon','','');
-INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('Administration_DE','filteredGroup_User_collection',2,1,'Put existing divs in new div object. List the elements comma-separated under target, and make sure they have a title.','','div','','',0,80,200,30,NULL ,'','','div','../plugins/mb_div_collection.js','','filteredGroup_User,filteredGroup_User_icon','','');
-INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('Administration_DE','editFilteredGroup_icon',2,1,'icon','','img','../img/gnome/editMyGroup.png','',0,0,NULL ,NULL,2,'','','','','','','','');
-INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('Administration_DE','newGui_collection',2,1,'Put existing divs in new div object. List the elements comma-separated under target, and make sure they have a title.','','div','','',0,0,200,30,NULL ,'','','div','../plugins/mb_div_collection.js','','newGui,newGui_icon','','');
-INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('Administration_DE','loadWMS_collection',2,1,'Put existing divs in new div object. List the elements comma-separated under target, and make sure they have a title.','','div','','',0,0,200,30,NULL ,'','','div','../plugins/mb_div_collection.js','','loadWMS,loadWMS_icon','','');
-INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('Administration_DE','loadWFS_collection',2,1,'Put existing divs in new div object. List the elements comma-separated under target, and make sure they have a title.','','div','','',0,0,200,30,NULL ,'','','div','../plugins/mb_div_collection.js','','loadWFS,loadWFS_icon','','');
-INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('Administration_DE','newGui_icon',2,1,'icon','','img','../img/gnome/newGui.png','',0,0,NULL ,NULL,2,'','','','','','','','');
-INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('Administration_DE','rename_copy_gui_icon',2,1,'icon','','img','../img/gnome/edit-copy.png','',0,0,NULL ,NULL,2,'','','','','','','','');
-INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('Administration_DE','rename_copy_gui_collection',2,1,'Put existing divs in new div object. List the elements comma-separated under target, and make sure they have a title.','','div','','',0,40,200,30,NULL ,'','','div','../plugins/mb_div_collection.js','','rename_copy_Gui,rename_copy_gui_icon','','');
-INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('Administration_DE','deleteWFSConf_icon',2,1,'icon','','img','../img/gnome/edit-delete.png','',0,0,NULL ,NULL,2,'','','','','','','','');
-INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('Administration_DE','editElements_icon',2,1,'icon','','img','../img/gnome/editGuiElements.png','',0,0,NULL ,NULL,2,'','','','','','','','');
-INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('Administration_DE','editElements_collection',2,1,'Put existing divs in new div object. List the elements comma-separated under target, and make sure they have a title.','','div','','',0,120,200,30,NULL ,'','','div','../plugins/mb_div_collection.js','','editElements,editElements_icon','','');
-INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('Administration_DE','delete_filteredGui_collection',2,1,'Put existing divs in new div object. List the elements comma-separated under target, and make sure they have a title.','','div','','',0,80,200,30,NULL ,'','','div','../plugins/mb_div_collection.js','','delete_filteredGui,delete_filteredGui_icon','','');
-INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('Administration_DE','delete_filteredGui_icon',2,1,'icon','','img','../img/gnome/deleteGui.png','',0,0,NULL ,NULL,2,'','','','','','','','');
-INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('Administration_DE','deleteGui_icon',2,0,'icon','','img','../img/gnome/deleteGui.png','',0,0,NULL ,NULL,2,'','','','','','','','');
-INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('Administration_DE','category_filteredGui_icon',2,1,'icon','','img','../img/gnome/myGuiCategories.png','',0,0,NULL ,NULL,2,'','','','','','','','');
-INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('Administration_DE','category_filteredGui_collection',2,1,'Put existing divs in new div object. List the elements comma-separated under target, and make sure they have a title.','','div','','',0,160,200,30,NULL ,'','','div','../plugins/mb_div_collection.js','','category_filteredGUI,category_filteredGui_icon','','');
-INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('Administration_DE','filteredGui_user_icon',2,1,'icon','','img','../img/gnome/myGuiUser.png','',0,0,NULL ,NULL,2,'','','','','','','','');
-INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('Administration_DE','filteredGui_group_icon',2,1,'icon','','img','../img/gnome/myGuiGroup.png','',0,0,NULL ,NULL,2,'','','','','','','','');
-INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('Administration_DE','filteredGui_group_collection',2,1,'Put existing divs in new div object. List the elements comma-separated under target, and make sure they have a title.','','div','','',0,40,200,30,NULL ,'','','div','../plugins/mb_div_collection.js','','filteredGui_Group,filteredGui_group_icon','','');
-INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('Administration_DE','filteredGroup_User_icon',2,1,'icon','','img','../img/gnome/myGroupUser.png','',0,0,NULL ,NULL,2,'','','','','','','','');
-INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('Administration_DE','filteredGui_filteredGroup_icon',2,1,'icon','','img','../img/gnome/myGuiMyGroup.png','',0,0,NULL ,NULL,2,'','','','','','','','');
-INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('Administration_DE','filteredGui_filteredGroup_collection',2,1,'Put existing divs in new div object. List the elements comma-separated under target, and make sure they have a title.','','div','','',0,80,200,30,NULL ,'','','div','../plugins/mb_div_collection.js','','filteredGui_filteredGroup,filteredGui_filteredGroup_icon','','');
-INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('Administration_DE','fullScreen',2,1,'Link to open Admin in new window','Öffne in neuem Fenster','span','','onclick="window.open(window.location.href,''Administrations Fenster'',''scrollbars=yes,resizeable=yes'')"
-',10,320,100,20,NULL ,'font-family: Arial, Helvetica, sans-serif; font-size : 12px; text-decoration : none; color: #808080;','Zu klein? - Öffne in neuem Fenster','span','','','','','http://www.mapbender.org/index.php/');
-INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('Administration_DE','loadWMS_icon',2,1,'icon','','img','../img/gnome/document-save.png','',0,0,NULL ,NULL,2,'','','','','','','','');
-INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('Administration_DE','editGUI_WMS_collection',2,1,'Put existing divs in new div object. List the elements comma-separated under target, and make sure they have a title.','','div','','',0,120,200,30,NULL ,'','','div','../plugins/mb_div_collection.js','','editGUI_WMS,editGUI_WMS_icon','','');
-INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('Administration_DE','updateWFS',2,1,'edit the elements of the gui','Update WFS','a','','href="../javascripts/mod_wfs_client.html"
-',80,15,NULL ,NULL,NULL ,'font-family: Arial, Helvetica, sans-serif; font-size : 12px; text-decoration : none; color: #808080;','Aktualisieren','a','','','','AdminFrame','http://www.mapbender.org/index.php/UpdateWMS');
-INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('Administration_DE','wfs_conf',2,1,'configure wfs','Configure Featuretype','a','','href = "../php/mod_wfs_conf_client.php"
-',80,15,NULL ,NULL,NULL ,'font-family: Arial, Helvetica, sans-serif; font-size : 12px; text-decoration : none; color: #808080;','Featuretype Modul einrichten','a','','','','AdminFrame','http://www.mapbender.org/index.php/DeleteWMS');
-INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('Administration_DE','wfs_metadata',2,1,'wfs metadata editor','Metadataeditor WFS','a','','href = "../frames/index.php?guiID=admin_wfs_metadata"
-',80,15,NULL ,NULL,NULL ,'font-family: Arial, Helvetica, sans-serif; font-size : 12px; text-decoration : none; color: #808080;','Metadaten Editor','a','','','','','http://www.mapbender.org/index.php/DeleteWMS');
-INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('Administration_DE','wmc_metadata',2,1,'wmc metadata editor','Metadataeditor WMC','a','','href = "../frames/index.php?guiID=admin_wmc_metadata"
-INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('Administration_DE','fullScreenIcon',2,1,'show iframe in new window','Open in new Window','img','../img/button_blue_red/resizemapsize_off.png','',120,320,24,24,NULL ,'','','','','','mapframe1','','');
-INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('Administration_DE','fullScreenIcon','adjust_height','-35','to adjust the height of the mapframe on the bottom of the window','var');
-INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('Administration_DE','fullScreenIcon','adjust_width','30','to adjust the width of the mapframe on the right side of the window','var');
-INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('Administration_DE','fullScreenIcon','resize_option','button','auto (autoresize on load), button (resize by button)','var');
-INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('Administration_DE','monitor_results',2,1,'','Monitoring results','a','','href = "../php/mod_monitorCapabilities_read.php?sessionID" ',80,15,NULL ,NULL,2,'font-family: Arial, Helvetica, sans-serif; font-size : 12px; text-decoration : none; color: #808080;','Monitoring Ergebnisse','a','','','','','http://www.mapbender.org/');
-INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('Administration_DE','owsproxy',2,1,'secure services','OWSProxy WMS','a','','href="../php/mod_owsproxy_conf.php?sessionID"'' ',80,15,NULL ,NULL,NULL ,'font-family: Arial, Helvetica, sans-serif; font-size : 12px; text-decoration : none; color: #808080;','Sicherheits Proxy','a','','','','','');
-INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('Administration_DE','wms_metadata',2,1,'wms metadata editor','Metadataeditor WMS','a','','href = "../frames/index.php?guiID=admin_wms_metadata"
-',80,15,NULL ,NULL,NULL ,'font-family: Arial, Helvetica, sans-serif; font-size : 12px; text-decoration : none; color: #808080;','Metadaten - Editor','a','','','','','http://www.mapbender.org/index.php/DeleteWMS');
-INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('Administration_DE','deleteWMS',2,1,'!Vollständig löschen!','Delete WMS completely','a','','href = "../php/mod_deleteWMS.php?sessionID"
-',80,15,NULL ,NULL,NULL ,'font-family: Arial, Helvetica, sans-serif; font-size : 12px; text-decoration : none; color: #808080;','!Vollständig löschen!','a','','','','','http://www.mapbender.org/index.php/DeleteWMS');
-INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('Administration_DE','monitor_abo_show',2,1,'send mail to user which have abos','Mail Abo WMS','a','','href = "../php/mod_abo_show.php?sessionID"
-',80,15,NULL ,NULL,NULL ,'font-family: Arial, Helvetica, sans-serif; font-size : 12px; text-decoration : none; color: #808080;','Abonnenten benachrichtigen','a','','','','','http://www.mapbender.org/index.php/DeleteWMS');
-INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('Administration_DE','deleteWFS',2,1,'delete wfs','Delete WFS','a','','href = "../php/mod_deleteWFS.php?sessionID"
-',80,15,NULL ,NULL,NULL ,'font-family: Arial, Helvetica, sans-serif; font-size : 12px; text-decoration : none; color: #808080;','Löschen','a','','','','','http://www.mapbender.org/index.php/DeleteWMS');
-INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('Administration_DE','deleteWFSConf',2,1,'delete wfs conf','Delete WFS-Conf','a','','href = "../javascripts/mod_deleteWfsConf_client.html" ',80,15,250,20,NULL ,'font-family: Arial, Helvetica, sans-serif; font-size : 12px; text-decoration : none; color: #808080;','Löschen von WFS Modulen','a','','','','AdminFrame','');
-INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('Administration_DE','delete_filteredGui',2,1,'Anwendung löschen','Anwendung löschen','a','','href = "../php/mod_deleteFilteredGUI.php?sessionID"',80,15,200,20,NULL ,'font-family: Arial, Helvetica, sans-serif; font-size : 12px; text-decoration : none; color: #808080;','Anwendung löschen','a','','','','','http://www.mapbender.org/index.php/DeleteGUI');
-INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('Administration_DE','editElements',2,1,'Anwendungselemente bearbeiten','Anwendungselemente bearbeiten','a','','href = "../php/mod_editElements.php?sessionID" ',80,15,200,20,NULL ,'font-family: Arial, Helvetica, sans-serif; font-size : 12px; text-decoration : none;color: #808080;','Anwendungselemente bearbeiten','a','','','','','http://www.mapbender.org/index.php/Edit_GUI_Elements');
-INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('Administration_DE','editFilteredGroup',2,1,'Gruppe anlegen und editieren','Create and edit group','a','','href = "../php/mod_editFilteredGroup.php?sessionID"',80,15,200,20,NULL ,'font-family: Arial, Helvetica, sans-serif; font-size : 12px; text-decoration : none; color: #808080;','Gruppe anlegen und editieren','a','','','','','http://www.mapbender.org/index.php/user');
-INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('Administration_DE','editGUI_WFS',2,1,'edit the elements of the gui','WFS-Konfiguration Anwendung zuweisen','a','','href="../javascripts/mod_wfs_client.html"
-',80,15,NULL ,NULL,NULL ,'font-family: Arial, Helvetica, sans-serif; font-size : 12px; text-decoration : none; color: #808080;','WFS-Konfiguration Anwendung zuweisen','a','','','','AdminFrame','http://www.mapbender.org/index.php/Edit_GUI_WMS');
-INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('Administration_DE','editGUI_WFS','file_css','../css/edit_gui.css','','file/css');
-INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('Administration_DE','filteredGroup_User',2,1,'allocate groups of this admin to user','myGroup -> User','a','','href = "../php/mod_filteredGroup_User.php?sessionID&e_id_css=filteredGroup_User" ',80,15,200,20,NULL ,'font-family: Arial, Helvetica, sans-serif; font-size : 12px; text-decoration : none; color: #808080;','Nutzer in eigene Gruppe übernehmen','a','','','','','http://www.mapbender.org/index.php/user');
-INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('Administration_DE','filteredGroup_User','file css','../css/administration_alloc.css','file css','file/css');
-INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('Administration_DE','filteredGui_Group',2,1,'allocate guis to groups','myGui -> Group','a','','href = "../php/mod_filteredGui_group.php?sessionID&e_id_css=filteredGui_Group" ',80,15,200,20,NULL ,'font-family: Arial, Helvetica, sans-serif; font-size : 12px; text-decoration : none; color: #808080;','Eigene Oberfläche externer Gruppe zuordnen','a','','','','AdminFrame','http://www.mapbender.org/index.php/user');
-INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('Administration_DE','filteredGui_Group','file css','../css/administration_alloc.css','file css','file/css');
-INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('Administration_DE','filteredGui_filteredGroup',2,1,'mehreren Gruppen Zugriff auf <br>einzelne Anwendung erlauben','mehreren Gruppen Zugriff auf <br>einzelne Anwendung erlauben','a','','href = "../php/mod_filteredGui_filteredGroup.php?sessionID&e_id_css=filteredGui_filteredGroup" ',80,15,200,20,NULL ,'font-family: Arial, Helvetica, sans-serif; font-size : 12px; text-decoration : none; color: #808080;','mehreren Gruppen Zugriff auf <br>einzelne Anwendung erlauben','a','','','','AdminFrame','http://www.mapbender.org/index.php/user');
-INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('Administration_DE','filteredGui_filteredGroup','file css','../css/administration_alloc.css','file css','file/css');
-INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('Administration_DE','filteredGui_user',2,1,'allocate the guis of this admin to a user','myGui -> User','a','','href = "../php/mod_filteredGui_User.php?sessionID&e_id_css=filteredGui_user" ',80,15,200,20,NULL ,'font-family: Arial, Helvetica, sans-serif; font-size : 12px; text-decoration : none; color: #808080;','Eigene Oberfläche externem Nutzer zuordnen','a','','','','','http://www.mapbender.org/index.php/user');
-INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('Administration_DE','filteredGui_user','file css','../css/administration_alloc.css','a file css','file/css');
-INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('Administration_DE','loadWFS',2,1,'load capabilities in a gui','Load WFS','a','','href = "../php/mod_loadWFSCapabilities.php?sessionID" target="AdminFrame"',80,15,NULL ,NULL,NULL ,'font-family: Arial, Helvetica, sans-serif; font-size : 12px; text-decoration : none; color: #808080;','Laden','a','','','','','http://www.mapbender.org/index.php/WFS_Konfiguration');
-INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('Administration_DE','newGui',2,1,'Anwendung erzeugen','Anwendung erzeugen','a','','href = "../php/mod_newGui.php?sessionID" ',80,15,200,20,NULL ,'font-family: Arial, Helvetica, sans-serif; font-size : 12px; text-decoration : none;color: #808080;','Anwendung erzeugen','a','','','','','http://www.mapbender.org/index.php/newGUI');
-INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('Administration_DE','editFilteredUser',2,1,'Benutzer anlegen und editieren','Benutzer anlegen und editieren','a','','href = "../php/mod_editFilteredUser.php?sessionID" target="AdminFrame"',80,15,200,20,NULL ,'font-family: Arial, Helvetica, sans-serif; font-size : 12px; text-decoration : none; color: #808080;','Benutzer anlegen und editieren','a','','','','','http://www.mapbender.org/index.php/user');
-INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('Administration_DE','editFilteredUser','withPasswordInsertion','true','define if admin can set the new user','php_var');
-INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('Administration_DE','deleteWMS_icon',2,1,'icon','','img','../img/gnome/edit-delete.png','',0,0,NULL ,NULL,2,'','','','','','','','');
-INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('Administration_DE','editGUI_WMS_icon',2,1,'icon','','img','../img/gnome/preferences-other.png','',0,0,NULL ,NULL,2,'','','','','','','','');
-INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('Administration_DE','deleteWMS_collection',2,1,'Put existing divs in new div object. List the elements comma-separated under target, and make sure they have a title.','','div','','',0,80,200,30,NULL ,'','','div','../plugins/mb_div_collection.js','','deleteWMS,deleteWMS_icon','','');
-INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('Administration_DE','menu_user',2,1,'User admin menu','Admin Nutzer','div','','',NULL ,NULL,NULL ,NULL,NULL ,'','','div','../plugins/mb_div_collection.js','','editFilteredUser_collection,editFilteredGroup_collection,filteredGroup_User_collection','','');
-INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('Administration_DE','loadExtWMS_icon',2,1,'icon','','img','../img/gnome/loadExternalWms.png','',0,0,NULL ,NULL,2,'','','','','','','','');
-INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('Administration_DE','loadExtWMS_collection',2,1,'Put existing divs in new div object. List the elements comma-separated under target, and make sure they have a title.','','div','','',150,80,200,30,NULL ,'','','div','../plugins/mb_div_collection.js','','loadWMSList,loadExtWMS_icon','','');
-INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('Administration_DE','loadWMSList',2,1,'load capabilities in a gui','WMS in Anwendung einbinden','a','','href = "../php/mod_loadCapabilitiesList.php?sessionID"',80,15,NULL ,NULL,NULL ,'font-family: Arial, Helvetica, sans-serif; font-size : 12px; text-decoration : none; color: #808080;','WMS in Anwendung einbinden','a','','','','','http://www.mapbender.org/index.php/Add_new_maps_to_Mapbender');
-INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('Administration_DE','editGUI_WMS',2,1,'WMS Anwendungseinstellungen','WMS Anwendungseinstellungen','a','','href="../php/mod_editGuiWms.php?sessionID"
-',80,15,NULL ,NULL,NULL ,'font-family: Arial, Helvetica, sans-serif; font-size : 12px; text-decoration : none; color: #808080;','WMS Anwendungseinstellungen','a','','','','','http://www.mapbender.org/index.php/Edit_GUI_WMS');
-INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('Administration_DE','editGUI_WMS','file_css','../css/edit_gui.css','','file/css');
-INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('Administration_DE','updateWMSs',2,1,'Hochgeladene aktualisieren','Update WMS','a','','href="../php/mod_updateWMS.php?sessionID"''
-',80,15,NULL ,NULL,NULL ,'font-family: Arial, Helvetica, sans-serif; font-size : 12px; text-decoration : none; color: #808080;','Hochgeladene aktualisieren','a','','','','','http://www.mapbender.org/index.php/UpdateWMS');
-INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('Administration_DE','loadWMS',2,1,'Capabilities hochladen','Load WMS','a','','href = "../php/mod_loadCapabilities.php?sessionID"',80,15,NULL ,NULL,NULL ,'font-family: Arial, Helvetica, sans-serif; font-size : 12px; text-decoration : none; color: #808080;','Capabilities hochladen','a','','','','','http://www.mapbender.org/index.php/Add_new_maps_to_Mapbender');
-INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('Administration_DE','category_filteredGUI',2,1,'Anwendung zu Kategorie zuordnen','Anwendung zu Kategorie zuordnen','a','','href = "../php/mod_category_filteredGUI.php?sessionID&e_id_css=filteredUser_filteredGroup"',80,15,190,20,10,'font-family: Arial, Helvetica, sans-serif; font-size : 12px; text-decoration : none; color: #808080;','Anwendung zu Kategorie zuordnen','a','','','','','http://www.mapbender.org/GUI_Category');
-INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('Administration_DE','category_filteredGUI','cssfile','../css/administration_alloc.css','css file for admin module','file/css');
-INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('Administration_DE','rename_copy_Gui',2,1,'Anwendung kopieren/umbenennen','Anwendung kopieren/umbenennen','a','','href = "../php/mod_renameGUI.php?sessionID" ',80,15,200,20,NULL ,'font-family: Arial, Helvetica, sans-serif; font-size : 12px; text-decoration : none; color: #808080;','Anwendung kopieren/umbenennen','a','','','','','');
-INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('Administration_DE','showLoggedUser',2,1,'Anzeige des eingeloggten Benutzers','','iframe','../php/mod_showLoggedUser.php?sessionID','frameborder="0" scrolling=''no''',1,1,200,30,1,'background-color:lightgrey;','','iframe','','','','','');
-INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('Administration_DE','showLoggedUser','css_file_user_logged','../css/administration_alloc.css','file/css','file/css');
-INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('Administration_DE','editFilteredUser_icon',2,1,'icon','','img','../img/gnome/editMyUser.png','',0,0,NULL ,NULL,2,'','','','','','','','');
-INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('Administration_DE','editFilteredUser_collection',2,1,'Put existing divs in new div object. List the elements comma-separated under target, and make sure they have a title.','','div','','',0,0,200,30,NULL ,'','','div','../plugins/mb_div_collection.js','','editFilteredUser,editFilteredUser_icon','','');
-INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('Administration_DE','myGUIlist',2,1,'Zurück zur Anwendungsübersicht','Zurück zur Anwendungsübersicht','img','../img/button_blue_red/home_off.png','onClick="mod_home_init()" border=''0'' onmouseover=''this.src="../img/button_blue_red/home_over.png"'' onmouseout=''this.src="../img/button_blue_red/home_off.png"''',200,2,24,24,2,'','','','mod_home.php','','','','http://www.mapbender.org/index.php/MyGUIlist');
-INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('Administration_DE','gui_owner',2,1,'Anwendung editieren Benutzer zuordnen','Anwendung editieren Benutzer zuordnen','a','','href = "../php/mod_gui_owner.php?sessionID" target = "AdminFrame" ',80,15,200,20,NULL ,'font-family: Arial, Helvetica, sans-serif; font-size : 12px; text-decoration : none; color: #808080;','Anwendung editieren Benutzer zuordnen','a','','','','AdminFrame','http://www.mapbender.org/index.php/user');
-INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('Administration_DE','gui_owner','file css','../css/administration_alloc.css','file css','file/css');
-INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('Administration_DE','gui_owner_collection',2,1,'Put existing divs in new div object. List the elements comma-separated under target, and make sure they have a title.','','div','','',0,160,200,30,NULL ,'','','div','../plugins/mb_div_collection.js','','gui_owner,gui_owner_icon','','');
-INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('Administration_DE','gui_owner_icon',2,1,'icon','','img','../img/gnome/guiMyUser.png','',0,0,NULL ,NULL,2,'','','','','','','','');
-INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('Administration_DE','allowPublishMetadata_collection',2,1,'Put existing divs in new div object. List the elements comma-separated under target, and make sure they have a title.','','div','','',0,115,200,30,NULL ,'','','div','../plugins/mb_div_collection.js','','allowPublishMetadata,allowPublishMetadata_icon','','');
-INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('Administration_DE','allowPublishMetadata_icon',2,1,'icon','','img','../img/gnome/emblem-shared.png','',0,0,NULL ,NULL,2,'','','','','','','','');
-INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('Administration_DE','menu_auth',2,1,'GUI admin menu','Autorisierung','div','','',NULL ,NULL,NULL ,NULL,NULL ,'','','div','../plugins/mb_div_collection.js','','filteredGui_user_collection,filteredGui_group_collection,filteredGui_filteredGroup_collection,gui_owner_collection,allowPublishMetadata_collection','','');
-INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('Administration_DE','allowPublishMetadata',2,1,'Einrichtungen erlauben im Auftrag <br>Metadaten zu veröffentlichen','Einrichtungen erlauben im Auftrag <br>Metadaten zu veröffentlichen','a','','href = "../geoportal/mod_allow_publishing_metadata.php?sessionID&e_id_css=allowPublishMetadata" ',80,15,200,20,NULL ,'font-family: Arial, Helvetica, sans-serif; font-size : 12px; text-decoration : none; color: #808080;','Einrichtungen erlauben im Auftrag <br>Metadaten zu veröffentlichen','a','','','','AdminFrame','http://www.mapbender.org/index.php/user');
-INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('Administration_DE','allowPublishMetadata','adminGroupId','36','','php_var');
-INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('Administration_DE','allowPublishMetadata','authorizeRoleId','3','','php_var');
-INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('Administration_DE','allowPublishMetadata','file css','../css/allow_publishing_metadata.css','file css','file/css');
-INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('Administration_DE','filteredGui_user_collection',2,1,'Put existing divs in new div object. List the elements comma-separated under target, and make sure they have a title.','','div','','',0,0,200,30,NULL ,'','','div','../plugins/mb_div_collection.js','','ownedGui_User,filteredGui_user_icon','','');
-INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('Administration_DE','deleteWFS_icon',2,1,'icon','','img','../img/gnome/edit-delete.png','',0,0,NULL ,NULL,2,'','','','','','','','');
-INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('Administration_DE','owsproxy_icon',2,1,'icon','','img','../img/gnome/emblem-readonly.png','',0,0,NULL ,NULL,2,'','','','','','','','');
-INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('Administration_DE','wms_metadata_collection',2,1,'Put existing divs in new div object. List the elements comma-separated under target, and make sure they have a title.','','div','','',150,0,200,30,NULL ,'','','div','../plugins/mb_div_collection.js','','wms_metadata,wms_metadata_icon','','');
-INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('Administration_DE','menu_metadata',2,1,'dataset metadata admin menu','Admin Metadata','div','','',NULL ,NULL,NULL ,NULL,NULL ,'','','div','../plugins/mb_div_collection.js','','dataset_metadata_collection,ckan_sync_collection','','');
-INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('Administration_DE','monitor_results_wfs',2,1,'','Monitoring results','a','','href = "../php/mod_monitorCapabilities_read.php?sessionID&serviceType=wfs" ',80,15,NULL ,NULL,2,'font-family: Arial, Helvetica, sans-serif; font-size : 12px; text-decoration : none; color: #808080;','Monitoring Ergebnisse','a','','','','','http://www.mapbender.org/');
-INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('Administration_DE','monitor_results_collection_wfs',2,1,'Put existing divs in new div object. List the elements comma-separated under target, and make sure they have a title.','','div','','',0,200,200,30,NULL ,'','','div','../plugins/mb_div_collection.js','','monitor_results_wfs,monitor_results_icon_wfs','','');
-INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('Administration_DE','menu_wfs',2,1,'WFS admin menu','Admin WFS','div','','',NULL ,NULL,NULL ,NULL,NULL ,'','','div','../plugins/mb_div_collection.js','','loadWFS_collection,updateWFS_collection,editGUI_WFS_collection,deleteWFS_collection,wfs_metadata_collection,owsproxy_wfs_collection,wfs_conf_collection,deleteWFSConf_collection,monitor_results_collection_wfs','','');
-INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('Administration_DE','ownedGui_User',2,1,'allocate the guis of this admin to a user','myGui -> User','a','','href = "../php/mod_ownedGui_User.php?sessionID&e_id_css=filteredGui_user" ',80,15,200,20,NULL ,'font-family: Arial, Helvetica, sans-serif; font-size : 12px; text-decoration : none; color: #808080;','Eigene Oberfläche externem Nutzer zuordnen','a','','','','','http://www.mapbender.org/index.php/user');
-INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('Administration_DE','ownedGui_User','file css','../css/administration_alloc.css','a file css','file/css');
-INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('Administration_DE','updateWFS_collection',2,1,'Put existing divs in new div object. List the elements comma-separated under target, and make sure they have a title.','','div','','',0,40,200,30,NULL ,'','','div','../plugins/mb_div_collection.js','','updateWFS,updateWFS_icon','','');
-INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('Administration_DE','jq_ui_position',2,1,'jQuery UI position','','','','',NULL ,NULL,NULL ,NULL,NULL ,'','','','','../extensions/jquery-ui-1.8.16.custom/development-bundle/ui/jquery.ui.position.js','','','');
-INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('Administration_DE','jq_ui_mouse',2,1,'jQuery UI mouse','','','','',NULL ,NULL,NULL ,NULL,NULL ,'','','','','../extensions/jquery-ui-1.8.16.custom/development-bundle/ui/jquery.ui.mouse.js','','jq_ui_widget','');
-INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('Administration_DE','exportGUI_icon',2,1,'icon','','img','../img/gnome/exportGui2Sql.png','',0,0,NULL ,NULL,2,'','','','','','','','');
-INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('Administration_DE','exportGUI',2,1,'Gui als Sql exportieren','Export Gui in SQL','a','','href = "../php/mod_exportGUI.php?sessionID"',80,15,190,20,10,'font-family: Arial, Helvetica, sans-serif; font-size : 12px; text-decoration : none; color: #808080;','Export Gui als SQL','a','','','','','http://www.mapbender.org/exportGUI');
-INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('Administration_DE','exportGUI','cssfile','../css/administration_alloc.css','css file for admin module','file/css');
-INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('Administration_DE','menu_gui',2,1,'GUI admin menu','Admin Anwendung','div','','',NULL ,NULL,NULL ,NULL,NULL ,'','','div','../plugins/mb_div_collection.js','','newGui_collection,rename_copy_gui_collection,delete_filteredGui_collection,editElements_collection,category_filteredGui_collection,exportGUI_collection','','');
-INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('Administration_DE','exportGUI_collection',2,1,'Put existing divs in new div object. List the elements comma-separated under target, and make sure they have a title.','','div','','',0,200,200,30,NULL ,'','','div','../plugins/mb_div_collection.js','','exportGUI,exportGUI_icon','','');
-INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('Administration_DE','wmsScheduler_icon',2,1,'icon','','img','../img/gnome/scheduler.png','',0,0,NULL ,NULL,2,'','','','','','','','');
-INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('Administration_DE','wmsScheduler',2,1,'WMS Scheduler','Dynamische WMS Aktualisierung','a','','href = "../frames/index.php?guiID=admin_ows_scheduler"
-',80,15,NULL ,NULL,NULL ,'font-family: Arial, Helvetica, sans-serif; font-size : 12px; text-decoration : none; color: #808080;','Dynamische WMS Aktualisierung','a','','','','','http://www.mapbender.org/index.php/DeleteWMS');
-INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('Administration_DE','wmsScheduler_collection',2,1,'Put existing divs in new div object. List the elements comma-separated under target, and make sure they have a title.','','div','','',150,120,200,30,NULL ,'','','div','../plugins/mb_div_collection.js','','wmsScheduler,wmsScheduler_icon','','');
-INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('Administration_DE','menu_wms',2,1,'WMS admin menu','Admin WMS','div','','',NULL ,NULL,NULL ,NULL,NULL ,'','','div','../plugins/mb_div_collection.js','','loadWMS_collection,updateWMSs_collection,deleteWMS_collection,editGUI_WMS_collection,owsproxy_collection,owsproxy_calc_collection,monitor_results_collection,wms_metadata_collection,wms_mail_abo_collection,loadExtWMS_collection,wmsScheduler_collection','','');
-INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('Administration_DE','menu_wms','css','../extensions/jquery-ui-1.7.2.custom/css/ui-lightness/jquery-ui-1.7.2.custom.css','','file/css');
-INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('Administration_DE','owsproxy_calc',2,1,'secure services','OWSProxy WMS Calculation','a','','href = "../frames/index.php?guiID=Owsproxy_csv"',80,10,NULL ,NULL,NULL ,'font-family: Arial, Helvetica, sans-serif; font-size : 12px; text-decoration : none; color: #808080;','Sicherheits Proxy (Abrechnung)','a','','','','','');
-INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('Administration_DE','owsproxy_calc_collection',2,1,'Put existing divs in new div object. List the elements comma-separated under target, and make sure they have a title.','','div','','',150,160,200,30,NULL ,'','','div','../plugins/mb_div_collection.js','','owsproxy_calc,owsproxy_calc_icon','','');
-INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('Administration_DE','owsproxy_calc_icon',2,1,'icon','','img','../img/gnome/emblem-readonly.png','',0,0,NULL ,NULL,2,'','','','','','','','');
-INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('Administration_DE','monitor_results_icon_wfs',2,1,'icon','','img','../img/gnome/preferences-desktop-remote-desktop.png','',0,0,NULL ,NULL,2,'','','','','','','','');
-INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('Administration_DE','dataset_metadata_icon',2,1,'icon','','img','../img/gnome/preferences-desktop-personal.png','',0,0,NULL ,NULL,2,'','','','','','','','');
-INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('Administration_DE','dataset_metadata',2,1,'dataset metadata manager','Metadataeditor Dataset','a','','href = "../frames/index.php?guiID=admin_metadata"
-INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('Administration_DE','dataset_metadata_collection',2,1,'Put existing divs in new div object. List the elements comma-separated under target, and make sure they have a title.','','div','','',0,0,200,30,NULL ,'','','div','../plugins/mb_div_collection.js','','dataset_metadata,dataset_metadata_icon','','');
-INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('Administration_DE','owsproxy_wfs',2,1,'secure services','OWSProxy WFS','a','','href="../php/mod_owsproxy_wfs_conf.php?sessionID"',80,15,NULL ,NULL,NULL ,'font-family: Arial, Helvetica, sans-serif; font-size : 12px; text-decoration : none; color: #808080;','Sicherheits Proxy','a','','','','','');
-INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('Administration_DE','ckan_sync',2,1,'ckan sync module','Ckan Synchronisierung','a','','href = "../javascripts/mod_syncCkan_client.php?compareTimestamps=true"',80,10,NULL ,NULL,NULL ,'font-family: Arial, Helvetica, sans-serif; font-size : 12px; text-decoration : none; color: #808080;','Ckan Synchronisierungsmodul','a','','','','','');
-INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('Administration_DE','ckan_sync_collection',2,1,'Put existing divs in new div object. List the elements comma-separated under target, and make sure they have a title.','','div','','',0,80,200,30,NULL ,'','','div','../plugins/mb_div_collection.js','','ckan_sync,ckan_sync_icon','','');
-INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('Administration_DE','ckan_sync_icon',2,1,'icon','','img','../img/misc/ckan.png','',0,0,NULL ,NULL,2,'','','','','','','','');
-INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('Administration_DE','jq_ui_button',4,1,'jQuery UI button','','','','',NULL ,NULL,NULL ,NULL,NULL ,'','','','','../extensions/jquery-ui-1.8.16.custom/development-bundle/ui/jquery.ui.button.js','','jq_ui,jq_ui_widget','');
-INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('Administration_DE','jq_ui_resizable',5,1,'Resizable from the jQuery UI framework','','','','',NULL ,NULL,NULL ,NULL,NULL ,'','','','../plugins/jq_ui_resizable.js','../extensions/jquery-ui-1.8.16.custom/development-bundle/ui/jquery.ui.resizable.js','','jq_ui,jq_ui_mouse,jq_ui_widget','');
-INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('Administration_DE','jq_ui_dialog',5,1,'Dialog from jQuery UI framework','','','','',NULL ,NULL,NULL ,NULL,NULL ,'','','','','../extensions/jquery-ui-1.8.16.custom/development-bundle/ui/jquery.ui.dialog.js','','jq_ui,jq_ui_widget,jq_ui_button,jq_ui_draggable,jq_ui_mouse,jq_ui_position,jq_ui_resizable','');
-INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('Administration_DE','jq_ui_draggable',5,1,'Draggable from the jQuery UI framework','','','','',NULL ,NULL,NULL ,NULL,NULL ,'','','','','../extensions/jquery-ui-1.8.16.custom/development-bundle/ui/jquery.ui.draggable.js','','jq_ui,jq_ui_mouse,jq_ui_widget','http://jqueryui.com/demos/draggable/');
-INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('Administration_DE','mb_iframepopup',7,1,'iframepopup','','div','','',NULL ,NULL,NULL ,NULL,NULL ,'','','div','../plugins/mb_iframepopup.js','','','','');
-INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('Administration_DE','mb_horizontal_accordion',10,1,'Put existing divs in new horizontal accordion div object. List the elements comma-separated under target, and make sure they have a title.','','div','','',0,0,NULL ,NULL,NULL ,'','<dl></dl>','div','../plugins/mb_horizontal_accordion.js','../../extensions/jqueryEasyAccordion/jquery.easyAccordion.js','menu_wms,menu_wfs,menu_metadata,menu_wmc,menu_user,menu_gui,menu_auth','','');
-INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('Administration_DE','mb_horizontal_accordion','Accordion css file','../extensions/jqueryEasyAccordion/mb_jquery.easyAccordion.css','','file/css');
+INSERT INTO gui (gui_id, gui_name, gui_description, gui_public) VALUES ('Administration_DE','Administration_DE','Administrationsoberfläche',1);
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('Administration_DE','allowPublishMetadata',2,1,'Einrichtungen erlauben im Auftrag <br>Metadaten zu veröffentlichen','Einrichtungen erlauben im Auftrag <br>Metadaten zu veröffentlichen','a','','href = "../geoportal/mod_allow_publishing_metadata.php?sessionID&e_id_css=allowPublishMetadata" ',80,1,200,20,NULL ,'font-family: Arial, Helvetica, sans-serif; font-size : 12px; text-decoration : none; color: #808080;','Einrichtungen erlauben im Auftrag <br>Metadaten zu veröffentlichen','a','','','','AdminFrame','http://www.mapbender.org/index.php/user');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('Administration_DE','allowPublishMetadata_collection',2,1,'Put existing divs in new div object. List the elements comma-separated under target, and make sure they have a title.','','div','','',0,115,200,30,NULL ,'','','div','../plugins/mb_div_collection.js','','allowPublishMetadata,allowPublishMetadata_icon','','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('Administration_DE','allowPublishMetadata_icon',2,1,'icon','','img','../img/gnome/emblem-shared.png','',0,0,NULL ,NULL,2,'','','','','','','','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('Administration_DE','body',1,1,'Navigation','','body','','',0,0,NULL ,40,NULL ,'','','','../geoportal/mod_revertGuiSessionSettings.php','','','','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('Administration_DE','category_filteredGUI',2,1,'Anwendung zu Kategorie zuordnen','Anwendung zu Kategorie zuordnen','a','','href = "../php/mod_category_filteredGUI.php?sessionID&e_id_css=filteredUser_filteredGroup"',80,1,190,20,10,'font-family: Arial, Helvetica, sans-serif; font-size : 12px; text-decoration : none; color: #808080;','Anwendung zu Kategorie zuordnen','a','','','','','http://www.mapbender.org/GUI_Category');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('Administration_DE','category_filteredGui_collection',2,1,'Put existing divs in new div object. List the elements comma-separated under target, and make sure they have a title.','','div','','',0,160,200,30,NULL ,'','','div','../plugins/mb_div_collection.js','','category_filteredGUI,category_filteredGui_icon','','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('Administration_DE','category_filteredGui_icon',2,1,'icon','','img','../img/gnome/myGuiCategories.png','',0,0,NULL ,NULL,2,'','','','','','','','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('Administration_DE','ckan_sync',2,1,'ckan sync module','Ckan Synchronisierung','a','','href = "../javascripts/mod_syncCkan_client.php?compareTimestamps=true"',80,1,NULL ,NULL,NULL ,'font-family: Arial, Helvetica, sans-serif; font-size : 12px; text-decoration : none; color: #808080;','Ckan Synchronisierungsmodul','a','','','','','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('Administration_DE','ckan_sync_collection',2,1,'Put existing divs in new div object. List the elements comma-separated under target, and make sure they have a title.','','div','','',0,80,200,30,NULL ,'','','div','../plugins/mb_div_collection.js','','ckan_sync,ckan_sync_icon','','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('Administration_DE','ckan_sync_icon',2,1,'icon','','img','../img/misc/ckan.png','',0,0,NULL ,NULL,2,'','','','','','','','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('Administration_DE','dataset_metadata',2,1,'dataset metadata manager','Metadataeditor Dataset','a','','href = "../frames/index.php?guiID=admin_metadata"',80,1,NULL ,NULL,NULL ,'font-family: Arial, Helvetica, sans-serif; font-size : 12px; text-decoration : none; color: #808080;','Metadaten - Editor','a','','','','','http://www.mapbender.org/index.php/DeleteWMS');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('Administration_DE','dataset_metadata_collection',2,1,'Put existing divs in new div object. List the elements comma-separated under target, and make sure they have a title.','','div','','',0,0,200,30,NULL ,'','','div','../plugins/mb_div_collection.js','','dataset_metadata,dataset_metadata_icon','','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('Administration_DE','dataset_metadata_icon',2,1,'icon','','img','../img/gnome/preferences-desktop-personal.png','',0,0,NULL ,NULL,2,'','','','','','','','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('Administration_DE','deleteGui',2,0,'delete gui','Delete GUI','a','','href = "../php/mod_deleteGUI.php?sessionID" ',80,15,200,20,NULL ,'font-family: Arial, Helvetica, sans-serif; font-size : 12px; text-decoration : none; color: #808080;','DELETE GUI','a','','','','','http://www.mapbender.org/index.php/DeleteGUI');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('Administration_DE','deleteGui_icon',2,0,'icon','','img','../img/gnome/deleteGui.png','',0,0,NULL ,NULL,2,'','','','','','','','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('Administration_DE','deleteWFS',2,1,'delete wfs','Delete WFS','a','','href = "../php/mod_deleteWFS.php?sessionID"',80,1,NULL ,NULL,NULL ,'font-family: Arial, Helvetica, sans-serif; font-size : 12px; text-decoration : none; color: #808080;','Löschen','a','','','','','http://www.mapbender.org/index.php/DeleteWMS');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('Administration_DE','deleteWFSConf',2,1,'delete wfs conf','Delete WFS-Conf','a','','href = "../javascripts/mod_deleteWfsConf_client.html" ',80,1,250,20,NULL ,'font-family: Arial, Helvetica, sans-serif; font-size : 12px; text-decoration : none; color: #808080;','Löschen von WFS Modulen','a','','','','AdminFrame','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('Administration_DE','deleteWFSConf_collection',2,1,'Put existing divs in new div object. List the elements comma-separated under target, and make sure they have a title.','','div','','',200,120,200,30,NULL ,'','','div','../plugins/mb_div_collection.js','','deleteWFSConf,deleteWFSConf_icon','','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('Administration_DE','deleteWFSConf_icon',2,1,'icon','','img','../img/gnome/edit-delete.png','',0,0,NULL ,NULL,2,'','','','','','','','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('Administration_DE','deleteWFS_collection',2,1,'Put existing divs in new div object. List the elements comma-separated under target, and make sure they have a title.','','div','','',0,80,200,30,NULL ,'','','div','../plugins/mb_div_collection.js','','deleteWFS,deleteWFS_icon','','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('Administration_DE','deleteWFS_icon',2,1,'icon','','img','../img/gnome/edit-delete.png','',0,0,NULL ,NULL,2,'','','','','','','','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('Administration_DE','deleteWMS',2,1,'!Vollständig löschen!','Delete WMS completely','a','','href = "../php/mod_deleteWMS.php?sessionID"',80,1,NULL ,NULL,NULL ,'font-family: Arial, Helvetica, sans-serif; font-size : 12px; text-decoration : none; color: #808080;','!Vollständig löschen!','a','','','','','http://www.mapbender.org/index.php/DeleteWMS');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('Administration_DE','deleteWMS_collection',2,1,'Put existing divs in new div object. List the elements comma-separated under target, and make sure they have a title.','','div','','',0,80,200,30,NULL ,'','','div','../plugins/mb_div_collection.js','','deleteWMS,deleteWMS_icon','','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('Administration_DE','deleteWMS_icon',2,1,'icon','','img','../img/gnome/edit-delete.png','',0,0,NULL ,NULL,2,'','','','','','','','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('Administration_DE','delete_filteredGui',2,1,'Anwendung löschen','Anwendung löschen','a','','href = "../php/mod_deleteFilteredGUI.php?sessionID"',80,1,200,20,NULL ,'font-family: Arial, Helvetica, sans-serif; font-size : 12px; text-decoration : none; color: #808080;','Anwendung löschen','a','','','','','http://www.mapbender.org/index.php/DeleteGUI');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('Administration_DE','delete_filteredGui_collection',2,1,'Put existing divs in new div object. List the elements comma-separated under target, and make sure they have a title.','','div','','',0,80,200,30,NULL ,'','','div','../plugins/mb_div_collection.js','','delete_filteredGui,delete_filteredGui_icon','','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('Administration_DE','delete_filteredGui_icon',2,1,'icon','','img','../img/gnome/deleteGui.png','',0,0,NULL ,NULL,2,'','','','','','','','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('Administration_DE','editElements',2,1,'Anwendungselemente bearbeiten','Anwendungselemente bearbeiten','a','','href = "../php/mod_editElements.php?sessionID" ',80,1,200,20,NULL ,'font-family: Arial, Helvetica, sans-serif; font-size : 12px; text-decoration : none;color: #808080;','Anwendungselemente bearbeiten','a','','','','','http://www.mapbender.org/index.php/Edit_GUI_Elements');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('Administration_DE','editElements_collection',2,1,'Put existing divs in new div object. List the elements comma-separated under target, and make sure they have a title.','','div','','',0,120,200,30,NULL ,'','','div','../plugins/mb_div_collection.js','','editElements,editElements_icon','','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('Administration_DE','editElements_icon',2,1,'icon','','img','../img/gnome/editGuiElements.png','',0,0,NULL ,NULL,2,'','','','','','','','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('Administration_DE','editFilteredGroup',2,1,'Gruppe anlegen und editieren','Create and edit group','a','','href = "../php/mod_editFilteredGroup.php?sessionID"',80,1,200,20,NULL ,'font-family: Arial, Helvetica, sans-serif; font-size : 12px; text-decoration : none; color: #808080;','Gruppe anlegen und editieren','a','','','','','http://www.mapbender.org/index.php/user');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('Administration_DE','editFilteredGroup_collection',2,1,'Put existing divs in new div object. List the elements comma-separated under target, and make sure they have a title.','','div','','',0,40,200,30,NULL ,'','','div','../plugins/mb_div_collection.js','','editFilteredGroup,editFilteredGroup_icon','','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('Administration_DE','editFilteredGroup_icon',2,1,'icon','','img','../img/gnome/editMyGroup.png','',0,0,NULL ,NULL,2,'','','','','','','','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('Administration_DE','editFilteredUser',2,1,'Benutzer anlegen und editieren','Benutzer anlegen und editieren','a','','href = "../php/mod_editFilteredUser.php?sessionID" target="AdminFrame"',80,1,200,20,NULL ,'font-family: Arial, Helvetica, sans-serif; font-size : 12px; text-decoration : none; color: #808080;','Benutzer anlegen und editieren','a','','','','','http://www.mapbender.org/index.php/user');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('Administration_DE','editFilteredUser_collection',2,1,'Put existing divs in new div object. List the elements comma-separated under target, and make sure they have a title.','','div','','',0,0,200,30,NULL ,'','','div','../plugins/mb_div_collection.js','','editFilteredUser,editFilteredUser_icon','','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('Administration_DE','editFilteredUser_icon',2,1,'icon','','img','../img/gnome/editMyUser.png','',0,0,NULL ,NULL,2,'','','','','','','','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('Administration_DE','editGUI_WFS',2,1,'edit the elements of the gui','WFS-Konfiguration Anwendung zuweisen','a','','href="../javascripts/mod_wfs_client.html"',80,1,NULL ,NULL,NULL ,'font-family: Arial, Helvetica, sans-serif; font-size : 12px; text-decoration : none; color: #808080;','WFS-Konfiguration Anwendung zuweisen','a','','','','AdminFrame','http://www.mapbender.org/index.php/Edit_GUI_WMS');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('Administration_DE','editGUI_WFS_collection',2,1,'Put existing divs in new div object. List the elements comma-separated under target, and make sure they have a title.','','div','','',0,120,200,30,NULL ,'','','div','../plugins/mb_div_collection.js','','editGUI_WFS,editGUI_WFS_icon','','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('Administration_DE','editGUI_WFS_icon',2,1,'icon','','img','../img/gnome/preferences-other.png','',0,0,NULL ,NULL,2,'','','','','','','','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('Administration_DE','editGUI_WMS',2,1,'WMS Anwendungseinstellungen','WMS Anwendungseinstellungen','a','','href="../php/mod_editGuiWms.php?sessionID" ',80,1,NULL ,NULL,NULL ,'font-family: Arial, Helvetica, sans-serif; font-size : 12px; text-decoration : none; color: #808080;','WMS Anwendungseinstellungen','a','','','','','http://www.mapbender.org/index.php/Edit_GUI_WMS');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('Administration_DE','editGUI_WMS_collection',2,1,'Put existing divs in new div object. List the elements comma-separated under target, and make sure they have a title.','','div','','',0,120,200,30,NULL ,'','','div','../plugins/mb_div_collection.js','','editGUI_WMS,editGUI_WMS_icon','','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('Administration_DE','editGUI_WMS_icon',2,1,'icon','','img','../img/gnome/preferences-other.png','',0,0,NULL ,NULL,2,'','','','','','','','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('Administration_DE','exportGUI',2,1,'Gui als Sql exportieren','Export Gui in SQL','a','','href = "../php/mod_exportGUI.php?sessionID"',80,1,190,20,10,'font-family: Arial, Helvetica, sans-serif; font-size : 12px; text-decoration : none; color: #808080;','Export Gui als SQL','a','','','','','http://www.mapbender.org/exportGUI');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('Administration_DE','exportGUI_collection',2,1,'Put existing divs in new div object. List the elements comma-separated under target, and make sure they have a title.','','div','','',0,200,200,30,NULL ,'','','div','../plugins/mb_div_collection.js','','exportGUI,exportGUI_icon','','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('Administration_DE','exportGUI_icon',2,1,'icon','','img','../img/gnome/exportGui2Sql.png','',0,0,NULL ,NULL,2,'','','','','','','','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('Administration_DE','filteredGroup_User',2,1,'allocate groups of this admin to user','myGroup -> User','a','','href = "../php/mod_filteredGroup_User.php?sessionID&e_id_css=filteredGroup_User" ',80,1,200,20,NULL ,'font-family: Arial, Helvetica, sans-serif; font-size : 12px; text-decoration : none; color: #808080;','Nutzer in eigene Gruppe übernehmen','a','','','','','http://www.mapbender.org/index.php/user');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('Administration_DE','filteredGroup_User_collection',2,1,'Put existing divs in new div object. List the elements comma-separated under target, and make sure they have a title.','','div','','',0,80,200,30,NULL ,'','','div','../plugins/mb_div_collection.js','','filteredGroup_User,filteredGroup_User_icon','','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('Administration_DE','filteredGroup_User_icon',2,1,'icon','','img','../img/gnome/myGroupUser.png','',0,0,NULL ,NULL,2,'','','','','','','','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('Administration_DE','filteredGui_Group',2,1,'allocate guis to groups','myGui -> Group','a','','href = "../php/mod_filteredGui_group.php?sessionID&e_id_css=filteredGui_Group" ',80,1,200,20,NULL ,'font-family: Arial, Helvetica, sans-serif; font-size : 12px; text-decoration : none; color: #808080;','Eigene Oberfläche externer Gruppe zuordnen','a','','','','AdminFrame','http://www.mapbender.org/index.php/user');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('Administration_DE','filteredGui_filteredGroup',2,1,'mehreren Gruppen Zugriff auf <br>einzelne Anwendung erlauben','mehreren Gruppen Zugriff auf <br>einzelne Anwendung erlauben','a','','href = "../php/mod_filteredGui_filteredGroup.php?sessionID&e_id_css=filteredGui_filteredGroup" ',80,1,200,20,NULL ,'font-family: Arial, Helvetica, sans-serif; font-size : 12px; text-decoration : none; color: #808080;','mehreren Gruppen Zugriff auf <br>einzelne Anwendung erlauben','a','','','','AdminFrame','http://www.mapbender.org/index.php/user');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('Administration_DE','filteredGui_filteredGroup_collection',2,1,'Put existing divs in new div object. List the elements comma-separated under target, and make sure they have a title.','','div','','',0,80,200,30,NULL ,'','','div','../plugins/mb_div_collection.js','','filteredGui_filteredGroup,filteredGui_filteredGroup_icon','','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('Administration_DE','filteredGui_filteredGroup_icon',2,1,'icon','','img','../img/gnome/myGuiMyGroup.png','',0,0,NULL ,NULL,2,'','','','','','','','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('Administration_DE','filteredGui_group_collection',2,1,'Put existing divs in new div object. List the elements comma-separated under target, and make sure they have a title.','','div','','',0,40,200,30,NULL ,'','','div','../plugins/mb_div_collection.js','','filteredGui_Group,filteredGui_group_icon','','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('Administration_DE','filteredGui_group_icon',2,1,'icon','','img','../img/gnome/myGuiGroup.png','',0,0,NULL ,NULL,2,'','','','','','','','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('Administration_DE','filteredGui_user',2,1,'allocate the guis of this admin to a user','myGui -> User','a','','href = "../php/mod_filteredGui_User.php?sessionID&e_id_css=filteredGui_user" ',80,1,200,20,NULL ,'font-family: Arial, Helvetica, sans-serif; font-size : 12px; text-decoration : none; color: #808080;','Eigene Oberfläche externem Nutzer zuordnen','a','','','','','http://www.mapbender.org/index.php/user');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('Administration_DE','filteredGui_user_collection',2,1,'Put existing divs in new div object. List the elements comma-separated under target, and make sure they have a title.','','div','','',0,0,200,30,NULL ,'','','div','../plugins/mb_div_collection.js','','ownedGui_User,filteredGui_user_icon','','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('Administration_DE','filteredGui_user_icon',2,1,'icon','','img','../img/gnome/myGuiUser.png','',0,0,NULL ,NULL,2,'','','','','','','','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('Administration_DE','fullScreen',2,1,'Link to open Admin in new window','Öffne in neuem Fenster','span','','onclick="window.open(window.location.href,''Administrations Fenster'',''scrollbars=yes,resizeable=yes'')"',10,320,100,20,NULL ,'font-family: Arial, Helvetica, sans-serif; font-size : 12px; text-decoration : none; color: #808080;','Zu klein? - Öffne in neuem Fenster','span','','','','','http://www.mapbender.org/index.php/');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('Administration_DE','fullScreenIcon',2,1,'show iframe in new window','Open in new Window','img','../img/button_blue_red/resizemapsize_off.png','',120,320,24,24,NULL ,'cursor:pointer;','','','','','mapframe1','','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('Administration_DE','gui_owner',2,1,'Anwendung editieren Benutzer zuordnen','Anwendung editieren Benutzer zuordnen','a','','href = "../php/mod_gui_owner.php?sessionID" target = "AdminFrame" ',80,1,200,20,NULL ,'font-family: Arial, Helvetica, sans-serif; font-size : 12px; text-decoration : none; color: #808080;','Anwendung editieren Benutzer zuordnen','a','','','','AdminFrame','http://www.mapbender.org/index.php/user');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('Administration_DE','gui_owner_collection',2,1,'Put existing divs in new div object. List the elements comma-separated under target, and make sure they have a title.','','div','','',0,160,200,30,NULL ,'','','div','../plugins/mb_div_collection.js','','gui_owner,gui_owner_icon','','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('Administration_DE','gui_owner_icon',2,1,'icon','','img','../img/gnome/guiMyUser.png','',0,0,NULL ,NULL,2,'','','','','','','','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('Administration_DE','i18n',1,1,'Internationalization module, collects data from all elements and sends them to the server in a single POST request. The strings are translated via gettext only.','Internationalization','div','','',NULL ,NULL,NULL ,NULL,NULL ,'','','div','../plugins/mb_i18n.js','','','','http://www.mapbender.org/Gettext');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('Administration_DE','jq_ui',1,1,'jQuery UI core','','','','',NULL ,NULL,NULL ,NULL,NULL ,'','','','','../extensions/jquery-ui-1.8.16.custom/development-bundle/ui/jquery.ui.core.js','','','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('Administration_DE','jq_ui_button',4,1,'jQuery UI button','','','','',NULL ,NULL,NULL ,NULL,NULL ,'','','','','../extensions/jquery-ui-1.8.16.custom/development-bundle/ui/jquery.ui.button.js','','jq_ui,jq_ui_widget','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('Administration_DE','jq_ui_dialog',5,1,'Dialog from jQuery UI framework','','','','',NULL ,NULL,NULL ,NULL,NULL ,'','','','','../extensions/jquery-ui-1.8.16.custom/development-bundle/ui/jquery.ui.dialog.js','','jq_ui,jq_ui_widget,jq_ui_button,jq_ui_draggable,jq_ui_mouse,jq_ui_position,jq_ui_resizable','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('Administration_DE','jq_ui_draggable',5,1,'Draggable from the jQuery UI framework','','','','',NULL ,NULL,NULL ,NULL,NULL ,'','','','','../extensions/jquery-ui-1.8.16.custom/development-bundle/ui/jquery.ui.draggable.js','','jq_ui,jq_ui_mouse,jq_ui_widget','http://jqueryui.com/demos/draggable/');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('Administration_DE','jq_ui_mouse',2,1,'jQuery UI mouse','','','','',NULL ,NULL,NULL ,NULL,NULL ,'','','','','../extensions/jquery-ui-1.8.16.custom/development-bundle/ui/jquery.ui.mouse.js','','jq_ui_widget','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('Administration_DE','jq_ui_position',2,1,'jQuery UI position','','','','',NULL ,NULL,NULL ,NULL,NULL ,'','','','','../extensions/jquery-ui-1.8.16.custom/development-bundle/ui/jquery.ui.position.js','','','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('Administration_DE','jq_ui_resizable',5,1,'Resizable from the jQuery UI framework','','','','',NULL ,NULL,NULL ,NULL,NULL ,'','','','../plugins/jq_ui_resizable.js','../extensions/jquery-ui-1.8.16.custom/development-bundle/ui/jquery.ui.resizable.js','','jq_ui,jq_ui_mouse,jq_ui_widget','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('Administration_DE','jq_ui_widget',1,1,'jQuery UI widget','','','','',NULL ,NULL,NULL ,NULL,NULL ,'','','','','../extensions/jquery-ui-1.8.16.custom/development-bundle/ui/jquery.ui.widget.js','','','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('Administration_DE','loadExtWMS_collection',2,1,'Put existing divs in new div object. List the elements comma-separated under target, and make sure they have a title.','','div','','',200,80,200,30,NULL ,'','','div','../plugins/mb_div_collection.js','','loadWMSList,loadExtWMS_icon','','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('Administration_DE','loadExtWMS_icon',2,1,'icon','','img','../img/gnome/loadExternalWms.png','',0,0,NULL ,NULL,2,'','','','','','','','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('Administration_DE','loadWFS',2,1,'load capabilities in a gui','Load WFS','a','','href = "../php/mod_loadWFSCapabilities.php?sessionID" target="AdminFrame"',80,1,NULL ,NULL,NULL ,'font-family: Arial, Helvetica, sans-serif; font-size : 12px; text-decoration : none; color: #808080;','Laden','a','','','','','http://www.mapbender.org/index.php/WFS_Konfiguration');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('Administration_DE','loadWFS_collection',2,1,'Put existing divs in new div object. List the elements comma-separated under target, and make sure they have a title.','','div','','',0,0,200,30,NULL ,'','','div','../plugins/mb_div_collection.js','','loadWFS,loadWFS_icon','','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('Administration_DE','loadWFS_icon',2,1,'icon','','img','../img/gnome/document-save.png','',0,0,NULL ,NULL,2,'','','','','','','','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('Administration_DE','loadWMS',2,1,'Capabilities hochladen','Load WMS','a','','href = "../php/mod_loadCapabilities.php?sessionID"',80,1,NULL ,NULL,NULL ,'font-family: Arial, Helvetica, sans-serif; font-size : 12px; text-decoration : none; color: #808080;','Capabilities hochladen','a','','','','','http://www.mapbender.org/index.php/Add_new_maps_to_Mapbender');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('Administration_DE','loadWMSList',2,1,'load capabilities in a gui','WMS in Anwendung einbinden','a','','href = "../php/mod_loadCapabilitiesList.php?sessionID"',80,1,NULL ,NULL,NULL ,'font-family: Arial, Helvetica, sans-serif; font-size : 12px; text-decoration : none; color: #808080;','WMS in Anwendung einbinden','a','','','','','http://www.mapbender.org/index.php/Add_new_maps_to_Mapbender');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('Administration_DE','loadWMS_collection',2,1,'Put existing divs in new div object. List the elements comma-separated under target, and make sure they have a title.','','div','','',0,0,200,30,NULL ,'','','div','../plugins/mb_div_collection.js','','loadWMS,loadWMS_icon','','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('Administration_DE','loadWMS_icon',2,1,'icon','','img','../img/gnome/document-save.png','',0,0,NULL ,NULL,2,'','','','','','','','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('Administration_DE','mb_horizontal_accordion',10,1,'Put existing divs in new horizontal accordion div object. List the elements comma-separated under target, and make sure they have a title.','','div','','',0,0,NULL ,NULL,NULL ,'','<dl></dl>','div','../plugins/mb_horizontal_accordion.js','../../extensions/jqueryEasyAccordion/jquery.easyAccordion.js','menu_wms,menu_wfs,menu_metadata,menu_wmc,menu_user,menu_gui,menu_auth','','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('Administration_DE','mb_iframepopup',7,1,'iframepopup','','div','','',NULL ,NULL,NULL ,NULL,NULL ,'','','div','../plugins/mb_iframepopup.js','','','','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('Administration_DE','menu_auth',2,1,'GUI admin menu','Autorisierung','div','','',NULL ,NULL,NULL ,NULL,NULL ,'','','div','../plugins/mb_div_collection.js','','filteredGui_user_collection,filteredGui_group_collection,filteredGui_filteredGroup_collection,gui_owner_collection,allowPublishMetadata_collection','','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('Administration_DE','menu_gui',2,1,'GUI admin menu','Admin Anwendung','div','','',NULL ,NULL,NULL ,NULL,NULL ,'','','div','../plugins/mb_div_collection.js','','newGui_collection,rename_copy_gui_collection,delete_filteredGui_collection,editElements_collection,category_filteredGui_collection,exportGUI_collection','','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('Administration_DE','menu_metadata',2,1,'dataset metadata admin menu','Admin Metadata','div','','',NULL ,NULL,NULL ,NULL,NULL ,'','','div','../plugins/mb_div_collection.js','','dataset_metadata_collection,ckan_sync_collection','','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('Administration_DE','menu_user',2,1,'User admin menu','Admin Nutzer','div','','',NULL ,NULL,NULL ,NULL,NULL ,'','','div','../plugins/mb_div_collection.js','','editFilteredUser_collection,editFilteredGroup_collection,filteredGroup_User_collection','','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('Administration_DE','menu_wfs',2,1,'WFS admin menu','Admin WFS','div','','',NULL ,NULL,NULL ,NULL,NULL ,'','','div','../plugins/mb_div_collection.js','','loadWFS_collection,updateWFS_collection,editGUI_WFS_collection,deleteWFS_collection,wfs_metadata_collection,owsproxy_wfs_collection,wfs_conf_collection,deleteWFSConf_collection,monitor_results_collection_wfs','','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('Administration_DE','menu_wmc',2,1,'WMC admin menu','Admin WMC','div','','',NULL ,NULL,NULL ,NULL,NULL ,'','','div','../plugins/mb_div_collection.js','','wmc_metadata_collection','','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('Administration_DE','menu_wms',2,1,'WMS admin menu','Admin WMS','div','','',NULL ,NULL,NULL ,NULL,NULL ,'','','div','../plugins/mb_div_collection.js','','loadWMS_collection,updateWMSs_collection,deleteWMS_collection,editGUI_WMS_collection,owsproxy_collection,owsproxy_calc_collection,monitor_results_collection,wms_metadata_collection,wms_mail_abo_collection,loadExtWMS_collection,wmsScheduler_collection','','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('Administration_DE','monitor_abo_show',2,1,'send mail to user which have abos','Mail Abo WMS','a','','href = "../php/mod_abo_show.php?sessionID"',80,1,NULL ,NULL,NULL ,'font-family: Arial, Helvetica, sans-serif; font-size : 12px; text-decoration : none; color: #808080;','Abonnenten benachrichtigen','a','','','','','http://www.mapbender.org/index.php/DeleteWMS');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('Administration_DE','monitor_results',2,1,'','Monitoring results','a','','href = "../php/mod_monitorCapabilities_read.php?sessionID" ',80,1,NULL ,NULL,2,'font-family: Arial, Helvetica, sans-serif; font-size : 12px; text-decoration : none; color: #808080;','Monitoring Ergebnisse','a','','','','','http://www.mapbender.org/');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('Administration_DE','monitor_results_collection',2,1,'Put existing divs in new div object. List the elements comma-separated under target, and make sure they have a title.','','div','','',0,200,200,30,NULL ,'','','div','../plugins/mb_div_collection.js','','monitor_results,monitor_results_icon','','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('Administration_DE','monitor_results_collection_wfs',2,1,'Put existing divs in new div object. List the elements comma-separated under target, and make sure they have a title.','','div','','',0,200,200,30,NULL ,'','','div','../plugins/mb_div_collection.js','','monitor_results_wfs,monitor_results_icon_wfs','','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('Administration_DE','monitor_results_icon',2,1,'icon','','img','../img/gnome/preferences-desktop-remote-desktop.png','',0,0,NULL ,NULL,2,'','','','','','','','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('Administration_DE','monitor_results_icon_wfs',2,1,'icon','','img','../img/gnome/preferences-desktop-remote-desktop.png','',0,0,NULL ,NULL,2,'','','','','','','','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('Administration_DE','monitor_results_wfs',2,1,'','Monitoring results','a','','href = "../php/mod_monitorCapabilities_read.php?sessionID&serviceType=wfs" ',80,1,NULL ,NULL,2,'font-family: Arial, Helvetica, sans-serif; font-size : 12px; text-decoration : none; color: #808080;','Monitoring Ergebnisse','a','','','','','http://www.mapbender.org/');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('Administration_DE','myGUIlist',2,1,'Zurück zur Anwendungsübersicht','Zurück zur Anwendungsübersicht','img','../img/button_blue_red/home_off.png','onClick="mod_home_init()" border=''0'' onmouseover=''this.src="../img/button_blue_red/home_over.png"'' onmouseout=''this.src="../img/button_blue_red/home_off.png"''',30,2,24,24,2,'cursor:pointer;','','','mod_home.php','','','','http://www.mapbender.org/index.php/MyGUIlist');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('Administration_DE','newGui',2,1,'Anwendung erzeugen','Anwendung erzeugen','a','','href = "../php/mod_newGui.php?sessionID" ',80,1,200,20,NULL ,'font-family: Arial, Helvetica, sans-serif; font-size : 12px; text-decoration : none;color: #808080;','Anwendung erzeugen','a','','','','','http://www.mapbender.org/index.php/newGUI');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('Administration_DE','newGui_collection',2,1,'Put existing divs in new div object. List the elements comma-separated under target, and make sure they have a title.','','div','','',0,0,200,30,NULL ,'','','div','../plugins/mb_div_collection.js','','newGui,newGui_icon','','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('Administration_DE','newGui_icon',2,1,'icon','','img','../img/gnome/newGui.png','',0,0,NULL ,NULL,2,'','','','','','','','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('Administration_DE','ownedGui_User',2,1,'allocate the guis of this admin to a user','myGui -> User','a','','href = "../php/mod_ownedGui_User.php?sessionID&e_id_css=filteredGui_user" ',80,1,200,20,NULL ,'font-family: Arial, Helvetica, sans-serif; font-size : 12px; text-decoration : none; color: #808080;','Eigene Oberfläche externem Nutzer zuordnen','a','','','','','http://www.mapbender.org/index.php/user');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('Administration_DE','owsproxy',2,1,'secure services','OWSProxy WMS','a','','href="../php/mod_owsproxy_conf.php?sessionID"'' ',80,1,NULL ,NULL,NULL ,'font-family: Arial, Helvetica, sans-serif; font-size : 12px; text-decoration : none; color: #808080;','Sicherheits Proxy','a','','','','','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('Administration_DE','owsproxy_calc',2,1,'secure services','OWSProxy WMS Calculation','a','','href = "../frames/index.php?guiID=Owsproxy_csv"',80,1,NULL ,NULL,NULL ,'font-family: Arial, Helvetica, sans-serif; font-size : 12px; text-decoration : none; color: #808080;','Sicherheits Proxy (Abrechnung)','a','','','','','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('Administration_DE','owsproxy_calc_collection',2,1,'Put existing divs in new div object. List the elements comma-separated under target, and make sure they have a title.','','div','','',200,160,200,30,NULL ,'','','div','../plugins/mb_div_collection.js','','owsproxy_calc,owsproxy_calc_icon','','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('Administration_DE','owsproxy_calc_icon',2,1,'icon','','img','../img/gnome/emblem-readonly.png','',0,0,NULL ,NULL,2,'','','','','','','','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('Administration_DE','owsproxy_collection',2,1,'Put existing divs in new div object. List the elements comma-separated under target, and make sure they have a title.','','div','','',0,160,200,30,NULL ,'','','div','../plugins/mb_div_collection.js','','owsproxy,owsproxy_icon','','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('Administration_DE','owsproxy_icon',2,1,'icon','','img','../img/gnome/emblem-readonly.png','',0,0,NULL ,NULL,2,'','','','','','','','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('Administration_DE','owsproxy_wfs',2,1,'secure services','OWSProxy WFS','a','','href="../php/mod_owsproxy_wfs_conf.php?sessionID"',80,1,NULL ,NULL,NULL ,'font-family: Arial, Helvetica, sans-serif; font-size : 12px; text-decoration : none; color: #808080;','Sicherheits Proxy','a','','','','','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('Administration_DE','owsproxy_wfs_collection',2,1,'Put existing divs in new div object. List the elements comma-separated under target, and make sure they have a title.','','div','','',0,160,200,30,NULL ,'','','div','../plugins/mb_div_collection.js','','owsproxy_wfs,owsproxy_wfs_icon','','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('Administration_DE','owsproxy_wfs_icon',2,1,'icon','','img','../img/gnome/emblem-readonly.png','',0,0,NULL ,NULL,2,'','','','','','','','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('Administration_DE','rename_copy_Gui',2,1,'Anwendung kopieren/umbenennen','Anwendung kopieren/umbenennen','a','','href = "../php/mod_renameGUI.php?sessionID" ',80,1,200,20,NULL ,'font-family: Arial, Helvetica, sans-serif; font-size : 12px; text-decoration : none; color: #808080;','Anwendung kopieren/umbenennen','a','','','','','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('Administration_DE','rename_copy_gui_collection',2,1,'Put existing divs in new div object. List the elements comma-separated under target, and make sure they have a title.','','div','','',0,40,200,30,NULL ,'','','div','../plugins/mb_div_collection.js','','rename_copy_Gui,rename_copy_gui_icon','','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('Administration_DE','rename_copy_gui_icon',2,1,'icon','','img','../img/gnome/edit-copy.png','',0,0,NULL ,NULL,2,'','','','','','','','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('Administration_DE','showLoggedUser',2,1,'Anzeige des eingeloggten Benutzers','','iframe','../php/mod_showLoggedUser.php?sessionID','frameborder="0" scrolling=''no''',1,1,NULL ,NULL,1,'padding:6px 55px;','','iframe','','','','','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('Administration_DE','updateWFS',2,1,'edit the elements of the gui','Update WFS','a','','href="../javascripts/mod_wfs_client.html"',80,1,NULL ,NULL,NULL ,'font-family: Arial, Helvetica, sans-serif; font-size : 12px; text-decoration : none; color: #808080;','Aktualisieren','a','','','','AdminFrame','http://www.mapbender.org/index.php/UpdateWMS');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('Administration_DE','updateWFS_collection',2,1,'Put existing divs in new div object. List the elements comma-separated under target, and make sure they have a title.','','div','','',0,40,200,30,NULL ,'','','div','../plugins/mb_div_collection.js','','updateWFS,updateWFS_icon','','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('Administration_DE','updateWFS_icon',2,1,'icon','','img','../img/gnome/view-refresh.png','',0,0,NULL ,NULL,2,'','','','','','','','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('Administration_DE','updateWMSs',2,1,'Hochgeladene aktualisieren','Update WMS','a','','href="../php/mod_updateWMS.php?sessionID"'' ',80,1,NULL ,NULL,NULL ,'font-family: Arial, Helvetica, sans-serif; font-size : 12px; text-decoration : none; color: #808080;','Hochgeladene aktualisieren','a','','','','','http://www.mapbender.org/index.php/UpdateWMS');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('Administration_DE','updateWMSs_collection',2,1,'Put existing divs in new div object. List the elements comma-separated under target, and make sure they have a title.','','div','','',0,40,200,30,NULL ,'','','div','../plugins/mb_div_collection.js','','updateWMSs,updateWMSs_icon','','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('Administration_DE','updateWMSs_icon',2,1,'icon','','img','../img/gnome/view-refresh.png','',0,0,NULL ,NULL,2,'','','','','','','','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('Administration_DE','wfs_conf',2,1,'configure wfs','Configure Featuretype','a','','href = "../php/mod_wfs_conf_client.php"',80,1,NULL ,NULL,NULL ,'font-family: Arial, Helvetica, sans-serif; font-size : 12px; text-decoration : none; color: #808080;','Featuretype Modul einrichten','a','','','','AdminFrame','http://www.mapbender.org/index.php/DeleteWMS');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('Administration_DE','wfs_conf_collection',2,1,'Put existing divs in new div object. List the elements comma-separated under target, and make sure they have a title.','','div','','',200,80,200,30,NULL ,'','','div','../plugins/mb_div_collection.js','','wfs_conf,wfs_conf_icon','','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('Administration_DE','wfs_conf_icon',2,1,'icon','','img','../img/gnome/preferences-other.png','',0,0,NULL ,NULL,2,'','','','','','','','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('Administration_DE','wfs_metadata',2,1,'wfs metadata editor','Metadataeditor WFS','a','','href = "../frames/index.php?guiID=admin_wfs_metadata"',80,1,NULL ,NULL,NULL ,'font-family: Arial, Helvetica, sans-serif; font-size : 12px; text-decoration : none; color: #808080;','Metadaten Editor','a','','','','','http://www.mapbender.org/index.php/DeleteWMS');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('Administration_DE','wfs_metadata_collection',2,1,'Put existing divs in new div object. List the elements comma-separated under target, and make sure they have a title.','','div','','',200,0,200,30,NULL ,'','','div','../plugins/mb_div_collection.js','','wfs_metadata,wfs_metadata_icon','','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('Administration_DE','wfs_metadata_icon',2,1,'icon','','img','../img/gnome/preferences-desktop-personal.png','',0,0,NULL ,NULL,2,'','','','','','','','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('Administration_DE','wmc_metadata',2,1,'wmc metadata editor','Metadataeditor WMC','a','','href = "../frames/index.php?guiID=admin_wmc_metadata"',80,1,NULL ,NULL,NULL ,'font-family: Arial, Helvetica, sans-serif; font-size : 12px; text-decoration : none; color: #808080;','Metadaten Editor','a','','','','','http://www.mapbender.org/index.php/DeleteWMS');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('Administration_DE','wmc_metadata_collection',2,1,'Put existing divs in new div object. List the elements comma-separated under target, and make sure they have a title.','','div','','',0,0,200,30,NULL ,'','','div','../plugins/mb_div_collection.js','','wmc_metadata,wmc_metadata_icon','','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('Administration_DE','wmc_metadata_icon',2,1,'icon','','img','../img/gnome/preferences-desktop-personal.png','',0,0,NULL ,NULL,2,'','','','','','','','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('Administration_DE','wmsScheduler',2,1,'WMS Scheduler','Dynamische WMS Aktualisierung','a','','href = "../frames/index.php?guiID=admin_ows_scheduler"',80,1,NULL ,NULL,NULL ,'font-family: Arial, Helvetica, sans-serif; font-size : 12px; text-decoration : none; color: #808080;','Dynamische WMS Aktualisierung','a','','','','','http://www.mapbender.org/index.php/DeleteWMS');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('Administration_DE','wmsScheduler_collection',2,1,'Put existing divs in new div object. List the elements comma-separated under target, and make sure they have a title.','','div','','',200,120,200,30,NULL ,'','','div','../plugins/mb_div_collection.js','','wmsScheduler,wmsScheduler_icon','','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('Administration_DE','wmsScheduler_icon',2,1,'icon','','img','../img/gnome/scheduler.png','',0,0,NULL ,NULL,2,'','','','','','','','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('Administration_DE','wms_mail_abo_collection',2,1,'Put existing divs in new div object. List the elements comma-separated under target, and make sure they have a title.','','div','','',200,40,200,30,NULL ,'','','div','../plugins/mb_div_collection.js','','monitor_abo_show,wms_mail_abo_icon','','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('Administration_DE','wms_mail_abo_icon',2,1,'icon','','img','../img/gnome/mail-message-new.png','',0,0,NULL ,NULL,2,'','','','','','','','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('Administration_DE','wms_metadata',2,1,'wms metadata editor','Metadataeditor WMS','a','','href = "../frames/index.php?guiID=admin_wms_metadata"',80,1,NULL ,NULL,NULL ,'font-family: Arial, Helvetica, sans-serif; font-size : 12px; text-decoration : none; color: #808080;','Metadaten - Editor','a','','','','','http://www.mapbender.org/index.php/DeleteWMS');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('Administration_DE','wms_metadata_collection',2,1,'Put existing divs in new div object. List the elements comma-separated under target, and make sure they have a title.','','div','','',200,0,200,30,NULL ,'','','div','../plugins/mb_div_collection.js','','wms_metadata,wms_metadata_icon','','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('Administration_DE','wms_metadata_icon',2,1,'icon','','img','../img/gnome/preferences-desktop-personal.png','',0,0,NULL ,NULL,2,'','','','','','','','');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('Administration_DE','allowPublishMetadata','adminGroupId','36','','php_var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('Administration_DE','allowPublishMetadata','authorizeRoleId','3','','php_var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('Administration_DE','allowPublishMetadata','file css','../css/allow_publishing_metadata.css','file css','file/css');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('Administration_DE','body','favicon','../img/favicon.png','favicon','php_var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('Administration_DE','body','includeWhileLoading','','show splash screen while the application is loading','php_var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('Administration_DE','body','jq_ui_effects_transfer','.ui-effects-transfer { z-index:1003; border: 2px dotted gray; } ','','text/css');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('Administration_DE','body','jq_ui_theme','../extensions/jquery-ui-1.7.2.custom/css/smoothness/jquery-ui-1.7.2.custom.css','','file/css');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('Administration_DE','body','use_load_message','false','show splash screen while the application is loading','php_var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('Administration_DE','category_filteredGUI','cssfile','../css/administration_alloc.css','css file for admin module','file/css');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('Administration_DE','editFilteredUser','withPasswordInsertion','true','define if admin can set the new user','php_var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('Administration_DE','editGUI_WFS','file_css','../css/edit_gui.css','','file/css');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('Administration_DE','editGUI_WMS','file_css','../css/edit_gui.css','','file/css');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('Administration_DE','exportGUI','cssfile','../css/administration_alloc.css','css file for admin module','file/css');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('Administration_DE','filteredGroup_User','file css','../css/administration_alloc.css','file css','file/css');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('Administration_DE','filteredGui_Group','file css','../css/administration_alloc.css','file css','file/css');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('Administration_DE','filteredGui_filteredGroup','file css','../css/administration_alloc.css','file css','file/css');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('Administration_DE','filteredGui_user','file css','../css/administration_alloc.css','a file css','file/css');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('Administration_DE','fullScreenIcon','adjust_height','-35','to adjust the height of the mapframe on the bottom of the window','var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('Administration_DE','fullScreenIcon','adjust_width','30','to adjust the width of the mapframe on the right side of the window','var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('Administration_DE','fullScreenIcon','resize_option','button','auto (autoresize on load), button (resize by button)','var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('Administration_DE','gui_owner','file css','../css/administration_alloc.css','file css','file/css');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('Administration_DE','jq_ui','css','../extensions/jquery-ui-1.7.2.custom/css/ui-lightness/jquery-ui-1.7.2.custom.css','','file/css');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('Administration_DE','mb_horizontal_accordion','Accordion css file','../extensions/jqueryEasyAccordion/mb_jquery.easyAccordion.css','','file/css');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('Administration_DE','menu_wmc','css','../extensions/jquery-ui-1.7.2.custom/css/ui-lightness/jquery-ui-1.7.2.custom.css','','file/css');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('Administration_DE','menu_wms','css','../extensions/jquery-ui-1.7.2.custom/css/ui-lightness/jquery-ui-1.7.2.custom.css','','file/css');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('Administration_DE','ownedGui_User','file css','../css/administration_alloc.css','a file css','file/css');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('Administration_DE','showLoggedUser','css_file_user_logged','../css/administration_alloc.css','file/css','file/css');
Modified: trunk/mapbender/resources/db/gui_PortalAdmin_DE.sql
--- trunk/mapbender/resources/db/gui_PortalAdmin_DE.sql	2019-06-06 09:39:23 UTC (rev 10140)
+++ trunk/mapbender/resources/db/gui_PortalAdmin_DE.sql	2019-06-06 13:07:32 UTC (rev 10141)
@@ -1,80 +1,78 @@
-INSERT INTO gui (gui_id, gui_name, gui_description, gui_public) VALUES ('PortalAdmin_DE','PortalAdmin_DE','Administrationsoberfläche',1);
-INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('PortalAdmin_DE','jq_ui_widget',1,1,'jQuery UI widget','','','','',NULL ,NULL,NULL ,NULL,NULL ,'','','','','../extensions/jquery-ui-1.8.16.custom/development-bundle/ui/jquery.ui.widget.js','','','');
-INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('PortalAdmin_DE','i18n',1,1,'Internationalization module, collects data from all elements and sends them to the server in a single POST request. The strings are translated via gettext only.','Internationalization','div','','',NULL ,NULL,NULL ,NULL,NULL ,'','','div','../plugins/mb_i18n.js','','','','http://www.mapbender.org/Gettext');
-INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('PortalAdmin_DE','jq_ui',1,1,'jQuery UI core','','','','',NULL ,NULL,NULL ,NULL,NULL ,'','','','','../extensions/jquery-ui-1.8.16.custom/development-bundle/ui/jquery.ui.core.js','','','');
-INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('PortalAdmin_DE','jq_ui','css','../extensions/jquery-ui-1.7.2.custom/css/ui-lightness/jquery-ui-1.7.2.custom.css','','file/css');
-INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('PortalAdmin_DE','body',1,1,'Navigation','','body','','',0,0,200,40,NULL ,'','','','../geoportal/mod_revertGuiSessionSettings.php','','','','');
-INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('PortalAdmin_DE','body','favicon','../img/favicon.png','favicon','php_var');
-INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('PortalAdmin_DE','body','includeWhileLoading','','show splash screen while the application is loading','php_var');
-INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('PortalAdmin_DE','body','jq_ui_effects_transfer','.ui-effects-transfer { z-index:1003; border: 2px dotted gray; } ','','text/css');
-INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('PortalAdmin_DE','body','jq_ui_theme','../extensions/jquery-ui-1.7.2.custom/css/smoothness/jquery-ui-1.7.2.custom.css','','file/css');
-INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('PortalAdmin_DE','body','use_load_message','false','show splash screen while the application is loading','php_var');
-INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('PortalAdmin_DE','reindexWFS_collection',2,1,'Put existing divs in new div object. List the elements comma-separated under target, and make sure they have a title.','','div','','',0,80,200,30,NULL ,'','','div','../plugins/mb_div_collection.js','','reindexWFS,reindexWFS_icon','','');
-INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('PortalAdmin_DE','reindexWFS_icon',2,1,'icon','','img','../img/gnome/system-run.png','',0,0,NULL ,NULL,2,'','','','','','','','');
-INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('PortalAdmin_DE','reindexWMS',2,1,'Reindex search WMS','Reindex search WMS','a','','href = "../php/mod_catalogueMaintenance.php?sessionID&resourceType=wms&maintenanceFunction=reindex"',80,15,210,20,5,'font-family: Arial, Helvetica, sans-serif; font-size : 12px; text-decoration : none; color: #808080;','Reindex search WMS','a','','','','','http://www.mapbender.org/');
-INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('PortalAdmin_DE','reindexWMS','file css','../css/administration_alloc.css','file css','file/css');
-INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('PortalAdmin_DE','reindexWMS_collection',2,1,'Put existing divs in new div object. List the elements comma-separated under target, and make sure they have a title.','','div','','',0,40,200,30,NULL ,'','','div','../plugins/mb_div_collection.js','','reindexWMS,reindexWMS_icon','','');
-INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('PortalAdmin_DE','reindexWMS_icon',2,1,'icon','','img','../img/gnome/system-run.png','',0,0,NULL ,NULL,2,'','','','','','','','');
-INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('PortalAdmin_DE','groupUser_icon',2,1,'icon','','img','../img/gnome/groupUser.png','',0,0,NULL ,NULL,2,'','','','','','','','');
-INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('PortalAdmin_DE','menu_category',2,1,'GUI admin menu','Kategorien','div','','',NULL ,NULL,NULL ,NULL,NULL ,'','','div','../plugins/mb_div_collection.js','','createGuiCategory_collection,deleteCategory_collection','','');
-INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('PortalAdmin_DE','groupUser_collection',2,1,'Put existing divs in new div object. List the elements comma-separated under target, and make sure they have a title.','','div','','',0,40,200,30,NULL ,'','','div','../plugins/mb_div_collection.js','','Group_User,groupUser_icon','','');
-INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('PortalAdmin_DE','showLoggedUser',2,1,'Anzeige des eingeloggten Benutzers','','iframe','../php/mod_showLoggedUser.php?sessionID','frameborder="0" scrolling=''no''',1,1,200,30,1,'background-color:lightgrey;','','iframe','','','','','');
-INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('PortalAdmin_DE','showLoggedUser','css_file_user_logged','../css/administration_alloc.css','file/css','file/css');
-INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('PortalAdmin_DE','menu_group',2,1,'GUI admin menu','Gruppen','div','','',NULL ,NULL,NULL ,NULL,NULL ,'','','div','../plugins/mb_div_collection.js','','editGroup_collection,groupUser_collection','','');
-INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('PortalAdmin_DE','editGroup_collection',2,1,'Put existing divs in new div object. List the elements comma-separated under target, and make sure they have a title.','','div','','',0,0,200,30,NULL ,'','','div','../plugins/mb_div_collection.js','','editGroup,editGroup_icon','','');
-INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('PortalAdmin_DE','editGroup_icon',2,1,'icon','','img','../img/gnome/editGroup.png','',0,0,NULL ,NULL,2,'','','','','','','','');
-INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('PortalAdmin_DE','menu_role',2,1,'GUI admin menu','Rollen','div','','',NULL ,NULL,NULL ,NULL,NULL ,'','','div','../plugins/mb_div_collection.js','','groupUserRole_collection','','');
-INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('PortalAdmin_DE','editGroup',2,1,'Gruppe anlegen und editieren','Create and edit group','a','','href = "../php/mod_editGroup.php?sessionID"',80,15,200,20,NULL ,'font-family: Arial, Helvetica, sans-serif; font-size : 12px; text-decoration : none; color: #808080;','Gruppe anlegen und editieren','a','','','','','http://www.mapbender.org/index.php/user');
-INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('PortalAdmin_DE','Group_User_Role',2,1,'Rollenzuweisung','Rollenzuweisung','a','','href = "../php/mod_group_user_role.php?sessionID"',80,15,210,20,5,'font-family: Arial, Helvetica, sans-serif; font-size : 12px; text-decoration : none; color: #808080;','Rollenzuweisung','a','','','','','http://www.mapbender.org/GUI_Category');
-INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('PortalAdmin_DE','Group_User_Role','file css','../css/administration_alloc.css','file css','file/css');
-INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('PortalAdmin_DE','groupUserRole_collection',2,1,'Put existing divs in new div object. List the elements comma-separated under target, and make sure they have a title.','','div','','',0,0,200,30,NULL ,'','','div','../plugins/mb_div_collection.js','','Group_User_Role,groupUserRole_icon','','');
-INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('PortalAdmin_DE','createCategory',2,1,'Anwendungskategorie erstellen','Anwendungskategorie erstellen','a','','href = "../php/mod_createCategory.php?sessionID"',80,15,210,20,5,'font-family: Arial, Helvetica, sans-serif; font-size : 12px; text-decoration : none; color: #808080;','Anwendungskategorie erstellen','a','','','','','http://www.mapbender.org/GUI_Category');
-INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('PortalAdmin_DE','createGuiCategory_collection',2,1,'Put existing divs in new div object. List the elements comma-separated under target, and make sure they have a title.','','div','','',0,0,200,30,NULL ,'','','div','../plugins/mb_div_collection.js','','createCategory,createGuiCategory_icon','','');
-INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('PortalAdmin_DE','fullScreenIcon',2,1,'show iframe in new window','Open in new Window','img','../img/button_blue_red/resizemapsize_off.png','',120,320,24,24,NULL ,'','','','','','mapframe1','','');
-INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('PortalAdmin_DE','fullScreenIcon','adjust_height','-35','to adjust the height of the mapframe on the bottom of the window','var');
-INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('PortalAdmin_DE','fullScreenIcon','adjust_width','30','to adjust the width of the mapframe on the right side of the window','var');
-INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('PortalAdmin_DE','fullScreenIcon','resize_option','button','auto (autoresize on load), button (resize by button)','var');
-INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('PortalAdmin_DE','fullScreen',2,1,'Link to open Admin in new window','Öffne in neuem Fenster','span','','onclick="window.open(window.location.href,''Administrations Fenster'',''scrollbars=yes,resizeable=yes'')"
-',10,320,100,20,NULL ,'font-family: Arial, Helvetica, sans-serif; font-size : 12px; text-decoration : none; color: #808080;','Zu klein? - Öffne in neuem Fenster','span','','','','','http://www.mapbender.org/index.php/');
-INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('PortalAdmin_DE','deleteCategory_icon',2,1,'icon','','img','../img/gnome/deleteCategories.png','',0,0,NULL ,NULL,2,'','','','','','','','');
-INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('PortalAdmin_DE','groupUserRole_icon',2,1,'icon','','img','../img/gnome/group1.png','',0,0,NULL ,NULL,2,'','','','','','','','');
-INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('PortalAdmin_DE','myGUIlist',2,1,'Zurück zur Anwendungsübersicht','Zurück zur Anwendungsübersicht','img','../img/button_blue_red/home_off.png','onClick="mod_home_init()" border=''0'' onmouseover=''this.src="../img/button_blue_red/home_over.png"'' onmouseout=''this.src="../img/button_blue_red/home_off.png"''',200,2,24,24,2,'','','','mod_home.php','','','','http://www.mapbender.org/index.php/MyGUIlist');
-INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('PortalAdmin_DE','deleteCategory_collection',2,1,'Put existing divs in new div object. List the elements comma-separated under target, and make sure they have a title.','','div','','',0,40,200,30,NULL ,'','','div','../plugins/mb_div_collection.js','','deleteCategory,deleteCategory_icon','','');
-INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('PortalAdmin_DE','createGuiCategory_icon',2,1,'icon','','img','../img/gnome/createCategories.png','',0,0,NULL ,NULL,2,'','','','','','','','');
-INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('PortalAdmin_DE','deleteCategory',2,1,'Anwendungskategorie löschen','Anwendungskategorie löschen','a','','href = "../php/mod_deleteCategory.php?sessionID"',80,15,210,20,5,'font-family: Arial, Helvetica, sans-serif; font-size : 12px; text-decoration : none; color: #808080;','Anwendungskategorie löschen','a','','','','','http://www.mapbender.org/GUI_Category');
-INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('PortalAdmin_DE','Group_User',2,1,'Gruppen Nutzer Zuordnung','Gruppen <-> Nutzer','a','','href = "../php/mod_group_user.php?sessionID"',80,15,210,20,5,'font-family: Arial, Helvetica, sans-serif; font-size : 12px; text-decoration : none; color: #808080;','Gruppen Nutzer Zuordnung','a','','','','','http://www.mapbender.org/GUI_Category');
-INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('PortalAdmin_DE','Group_User','file css','../css/administration_alloc.css','file css','file/css');
-INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('PortalAdmin_DE','Start_Monitor_for_WMS_icon',2,1,'icon','','img','../img/gnome/system-run.png','',0,0,NULL ,NULL,2,'','','','','','','','');
-INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('PortalAdmin_DE','reindexDATASET',2,1,'Reindex search DATASET','Reindex search DATASET','a','','href = "../php/mod_catalogueMaintenance.php?sessionID&resourceType=dataset&maintenanceFunction=reindex"',80,15,210,20,5,'font-family: Arial, Helvetica, sans-serif; font-size : 12px; text-decoration : none; color: #808080;','Reindex search DATASET','a','','','','','http://www.mapbender.org/');
-INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('PortalAdmin_DE','reindexDATASET','file css','../css/administration_alloc.css','file css','file/css');
-INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('PortalAdmin_DE','editUser_collection',2,1,'Put existing divs in new div object. List the elements comma-separated under target, and make sure they have a title.','','div','','',0,0,200,30,NULL ,'','','div','../plugins/mb_div_collection.js','','editUser,editUser_icon','','');
-INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('PortalAdmin_DE','editUser',2,1,'Benutzer anlegen und editieren','Benutzer anlegen und editieren','a','','href = "../php/mod_editUser.php?sessionID" target="AdminFrame"',80,15,200,20,NULL ,'font-family: Arial, Helvetica, sans-serif; font-size : 12px; text-decoration : none; color: #808080;','Benutzer anlegen und editieren','a','','','','','http://www.mapbender.org/index.php/user');
-INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('PortalAdmin_DE','editUser','withPasswordInsertion','true','define if admin can set the new user','php_var');
-INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('PortalAdmin_DE','editMaintenance_collection',2,1,'Put existing divs in new div object. List the elements comma-separated under target, and make sure they have a title.','','div','','',0,0,200,30,NULL ,'','','div','../plugins/mb_div_collection.js','','orphanWMS,orphanWMS_icon','','');
-INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('PortalAdmin_DE','orphanWMS',2,1,'display orphaned wms','','a','','href = "../php/mod_orphanWMS.php?sessionID" target="AdminFrame"',80,15,200,20,NULL ,'font-family: Arial, Helvetica, sans-serif; font-size : 12px; text-decoration : none; color: #808080;','Verwaiste WMS löschen','a','','','','AdminFrame','http://www.mapbender.org/index.php/DeleteWMS');
-INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('PortalAdmin_DE','orphanWMS_icon',2,1,'icon','','img','../img/gnome/edit-clear.png','',0,0,NULL ,NULL,2,'','','','','','','','');
-INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('PortalAdmin_DE','Start_Monitor_for_WMS',2,1,'Start Monitor for WMS','Start Monitor for WMS','a','','href = "../php/mod_catalogueMaintenance.php?sessionID&resourceType=wms&maintenanceFunction=monitor"',80,15,210,20,5,'font-family: Arial, Helvetica, sans-serif; font-size : 12px; text-decoration : none; color: #808080;','Start Monitor for WMS','a','','','','','http://www.mapbender.org/');
-INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('PortalAdmin_DE','Start_Monitor_for_WMS','file css','../css/administration_alloc.css','file css','file/css');
-INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('PortalAdmin_DE','jq_ui_position',2,1,'jQuery UI position','','','','',NULL ,NULL,NULL ,NULL,NULL ,'','','','','../extensions/jquery-ui-1.8.16.custom/development-bundle/ui/jquery.ui.position.js','','','');
-INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('PortalAdmin_DE','menu_user',2,1,'User admin menu','Admin Nutzer','div','','',NULL ,NULL,NULL ,NULL,NULL ,'','','div','../plugins/mb_div_collection.js','','editUser_collection','','');
-INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('PortalAdmin_DE','editUser_icon',2,1,'icon','','img','../img/gnome/editMyUser.png','',0,0,NULL ,NULL,2,'','','','','','','','');
-INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('PortalAdmin_DE','jq_ui_mouse',2,1,'jQuery UI mouse','','','','',NULL ,NULL,NULL ,NULL,NULL ,'','','','','../extensions/jquery-ui-1.8.16.custom/development-bundle/ui/jquery.ui.mouse.js','','jq_ui_widget','');
-INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('PortalAdmin_DE','reindexDATASET_collection',2,1,'Put existing divs in new div object. List the elements comma-separated under target, and make sure they have a title.','','div','','',0,120,200,30,NULL ,'','','div','../plugins/mb_div_collection.js','','reindexDATASET,reindexDATASET_icon','','');
-INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('PortalAdmin_DE','reindexDATASET_icon',2,1,'icon','','img','../img/gnome/system-run.png','',0,0,NULL ,NULL,2,'','','','','','','','');
-INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('PortalAdmin_DE','reindexWFS',2,1,'Reindex search WFS','Reindex search WFS','a','','href = "../php/mod_catalogueMaintenance.php?sessionID&resourceType=wfs&maintenanceFunction=reindex"',80,15,210,20,5,'font-family: Arial, Helvetica, sans-serif; font-size : 12px; text-decoration : none; color: #808080;','Reindex search WFS','a','','','','','http://www.mapbender.org/');
-INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('PortalAdmin_DE','reindexWFS','file css','../css/administration_alloc.css','file css','file/css');
-INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('PortalAdmin_DE','reindexWMC_collection',2,1,'Put existing divs in new div object. List the elements comma-separated under target, and make sure they have a title.','','div','','',0,160,200,30,NULL ,'','','div','../plugins/mb_div_collection.js','','reindexWMC,reindexWMC_icon','','');
-INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('PortalAdmin_DE','Start_Monitor_for_WMS_collection',2,1,'Put existing divs in new div object. List the elements comma-separated under target, and make sure they have a title.','','div','','',0,200,200,30,NULL ,'','','div','../plugins/mb_div_collection.js','','Start_Monitor_for_WMS,Start_Monitor_for_WMS_icon','','');
-INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('PortalAdmin_DE','reindexWMC',2,1,'Reindex search WMC','Reindex search WMC','a','','href = "../php/mod_catalogueMaintenance.php?sessionID&resourceType=wmc&maintenanceFunction=reindex"',80,15,210,20,5,'font-family: Arial, Helvetica, sans-serif; font-size : 12px; text-decoration : none; color: #808080;','Reindex search WMC','a','','','','','http://www.mapbender.org/');
-INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('PortalAdmin_DE','reindexWMC','file css','../css/administration_alloc.css','file css','file/css');
-INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('PortalAdmin_DE','menu_maintenance',2,1,'GUI admin menu','Wartung','div','','',NULL ,NULL,NULL ,NULL,NULL ,'','','div','../plugins/mb_div_collection.js','','editMaintenance_collection, reindexWMS_collection,reindexWFS_collection,reindexDATASET_collection,reindexWMC_collection,Start_Monitor_for_WMS_collection','','');
-INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('PortalAdmin_DE','reindexWMC_icon',2,1,'icon','','img','../img/gnome/system-run.png','',0,0,NULL ,NULL,2,'','','','','','','','');
-INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('PortalAdmin_DE','jq_ui_button',4,1,'jQuery UI button','','','','',NULL ,NULL,NULL ,NULL,NULL ,'','','','','../extensions/jquery-ui-1.8.16.custom/development-bundle/ui/jquery.ui.button.js','','jq_ui,jq_ui_widget','');
-INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('PortalAdmin_DE','jq_ui_resizable',5,1,'Resizable from the jQuery UI framework','','','','',NULL ,NULL,NULL ,NULL,NULL ,'','','','../plugins/jq_ui_resizable.js','../extensions/jquery-ui-1.8.16.custom/development-bundle/ui/jquery.ui.resizable.js','','jq_ui,jq_ui_mouse,jq_ui_widget','');
-INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('PortalAdmin_DE','jq_ui_dialog',5,1,'Dialog from jQuery UI framework','','','','',NULL ,NULL,NULL ,NULL,NULL ,'','','','','../extensions/jquery-ui-1.8.16.custom/development-bundle/ui/jquery.ui.dialog.js','','jq_ui,jq_ui_widget,jq_ui_button,jq_ui_draggable,jq_ui_mouse,jq_ui_position,jq_ui_resizable','');
-INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('PortalAdmin_DE','jq_ui_draggable',5,1,'Draggable from the jQuery UI framework','','','','',NULL ,NULL,NULL ,NULL,NULL ,'','','','','../extensions/jquery-ui-1.8.16.custom/development-bundle/ui/jquery.ui.draggable.js','','jq_ui,jq_ui_mouse,jq_ui_widget','http://jqueryui.com/demos/draggable/');
-INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('PortalAdmin_DE','mb_iframepopup',7,1,'iframepopup','','div','','',NULL ,NULL,NULL ,NULL,NULL ,'','','div','../plugins/mb_iframepopup.js','','','','');
-INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('PortalAdmin_DE','mb_horizontal_accordion',10,1,'Put existing divs in new horizontal accordion div object. List the elements comma-separated under target, and make sure they have a title.','','div','','',0,0,NULL ,NULL,NULL ,'','<dl></dl>','div','../plugins/mb_horizontal_accordion.js','../../extensions/jqueryEasyAccordion/jquery.easyAccordion.js','menu_maintenance,menu_group,menu_user,menu_role,menu_category','','');
-INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('PortalAdmin_DE','mb_horizontal_accordion','Accordion css file','../extensions/jqueryEasyAccordion/mb_jquery.easyAccordion.css','','file/css');
+INSERT INTO gui (gui_id, gui_name, gui_description, gui_public) VALUES ('PortalAdmin_DE','PortalAdmin_DE','Administrationsoberfläche',1);
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('PortalAdmin_DE','Group_User',2,1,'Gruppen Nutzer Zuordnung','Gruppen <-> Nutzer','a','','href = "../php/mod_group_user.php?sessionID"',80,15,210,20,5,'font-family: Arial, Helvetica, sans-serif; font-size : 12px; text-decoration : none; color: #808080;','Gruppen Nutzer Zuordnung','a','','','','','http://www.mapbender.org/GUI_Category');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('PortalAdmin_DE','Group_User_Role',2,1,'Rollenzuweisung','Rollenzuweisung','a','','href = "../php/mod_group_user_role.php?sessionID"',80,15,210,20,5,'font-family: Arial, Helvetica, sans-serif; font-size : 12px; text-decoration : none; color: #808080;','Rollenzuweisung','a','','','','','http://www.mapbender.org/GUI_Category');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('PortalAdmin_DE','Start_Monitor_for_WMS',2,1,'Start Monitor for WMS','Start Monitor for WMS','a','','href = "../php/mod_catalogueMaintenance.php?sessionID&resourceType=wms&maintenanceFunction=monitor"',80,15,210,20,5,'font-family: Arial, Helvetica, sans-serif; font-size : 12px; text-decoration : none; color: #808080;','Start Monitor for WMS','a','','','','','http://www.mapbender.org/');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('PortalAdmin_DE','Start_Monitor_for_WMS_collection',2,1,'Put existing divs in new div object. List the elements comma-separated under target, and make sure they have a title.','','div','','',0,200,200,30,NULL ,'','','div','../plugins/mb_div_collection.js','','Start_Monitor_for_WMS,Start_Monitor_for_WMS_icon','','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('PortalAdmin_DE','Start_Monitor_for_WMS_icon',2,1,'icon','','img','../img/gnome/system-run.png','',0,0,NULL ,NULL,2,'','','','','','','','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('PortalAdmin_DE','body',1,1,'Navigation','','body','','',0,0,200,40,NULL ,'','','','../geoportal/mod_revertGuiSessionSettings.php','','','','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('PortalAdmin_DE','createCategory',2,1,'Anwendungskategorie erstellen','Anwendungskategorie erstellen','a','','href = "../php/mod_createCategory.php?sessionID"',80,15,210,20,5,'font-family: Arial, Helvetica, sans-serif; font-size : 12px; text-decoration : none; color: #808080;','Anwendungskategorie erstellen','a','','','','','http://www.mapbender.org/GUI_Category');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('PortalAdmin_DE','createGuiCategory_collection',2,1,'Put existing divs in new div object. List the elements comma-separated under target, and make sure they have a title.','','div','','',0,0,200,30,NULL ,'','','div','../plugins/mb_div_collection.js','','createCategory,createGuiCategory_icon','','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('PortalAdmin_DE','createGuiCategory_icon',2,1,'icon','','img','../img/gnome/createCategories.png','',0,0,NULL ,NULL,2,'','','','','','','','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('PortalAdmin_DE','deleteCategory',2,1,'Anwendungskategorie löschen','Anwendungskategorie löschen','a','','href = "../php/mod_deleteCategory.php?sessionID"',80,15,210,20,5,'font-family: Arial, Helvetica, sans-serif; font-size : 12px; text-decoration : none; color: #808080;','Anwendungskategorie löschen','a','','','','','http://www.mapbender.org/GUI_Category');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('PortalAdmin_DE','deleteCategory_collection',2,1,'Put existing divs in new div object. List the elements comma-separated under target, and make sure they have a title.','','div','','',0,40,200,30,NULL ,'','','div','../plugins/mb_div_collection.js','','deleteCategory,deleteCategory_icon','','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('PortalAdmin_DE','deleteCategory_icon',2,1,'icon','','img','../img/gnome/deleteCategories.png','',0,0,NULL ,NULL,2,'','','','','','','','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('PortalAdmin_DE','editGroup',2,1,'Gruppe anlegen und editieren','Create and edit group','a','','href = "../php/mod_editGroup.php?sessionID"',80,15,200,20,NULL ,'font-family: Arial, Helvetica, sans-serif; font-size : 12px; text-decoration : none; color: #808080;','Gruppe anlegen und editieren','a','','','','','http://www.mapbender.org/index.php/user');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('PortalAdmin_DE','editGroup_collection',2,1,'Put existing divs in new div object. List the elements comma-separated under target, and make sure they have a title.','','div','','',0,0,200,30,NULL ,'','','div','../plugins/mb_div_collection.js','','editGroup,editGroup_icon','','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('PortalAdmin_DE','editGroup_icon',2,1,'icon','','img','../img/gnome/editGroup.png','',0,0,NULL ,NULL,2,'','','','','','','','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('PortalAdmin_DE','editMaintenance_collection',2,1,'Put existing divs in new div object. List the elements comma-separated under target, and make sure they have a title.','','div','','',0,0,200,30,NULL ,'','','div','../plugins/mb_div_collection.js','','orphanWMS,orphanWMS_icon','','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('PortalAdmin_DE','editUser',2,1,'Benutzer anlegen und editieren','Benutzer anlegen und editieren','a','','href = "../php/mod_editUser.php?sessionID" target="AdminFrame"',80,15,200,20,NULL ,'font-family: Arial, Helvetica, sans-serif; font-size : 12px; text-decoration : none; color: #808080;','Benutzer anlegen und editieren','a','','','','','http://www.mapbender.org/index.php/user');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('PortalAdmin_DE','editUser_collection',2,1,'Put existing divs in new div object. List the elements comma-separated under target, and make sure they have a title.','','div','','',0,0,200,30,NULL ,'','','div','../plugins/mb_div_collection.js','','editUser,editUser_icon','','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('PortalAdmin_DE','editUser_icon',2,1,'icon','','img','../img/gnome/editMyUser.png','',0,0,NULL ,NULL,2,'','','','','','','','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('PortalAdmin_DE','fullScreen',2,1,'Link to open Admin in new window','Öffne in neuem Fenster','span','','onclick="window.open(window.location.href,''Administrations Fenster'',''scrollbars=yes,resizeable=yes'')"',10,320,100,20,NULL ,'font-family: Arial, Helvetica, sans-serif; font-size : 12px; text-decoration : none; color: #808080;','Zu klein? - Öffne in neuem Fenster','span','','','','','http://www.mapbender.org/index.php/');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('PortalAdmin_DE','fullScreenIcon',2,1,'show iframe in new window','Open in new Window','img','../img/button_blue_red/resizemapsize_off.png','',120,320,24,24,NULL ,'cursor:pointer;','','','','','mapframe1','','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('PortalAdmin_DE','groupUserRole_collection',2,1,'Put existing divs in new div object. List the elements comma-separated under target, and make sure they have a title.','','div','','',0,0,200,30,NULL ,'','','div','../plugins/mb_div_collection.js','','Group_User_Role,groupUserRole_icon','','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('PortalAdmin_DE','groupUserRole_icon',2,1,'icon','','img','../img/gnome/group1.png','',0,0,NULL ,NULL,2,'','','','','','','','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('PortalAdmin_DE','groupUser_collection',2,1,'Put existing divs in new div object. List the elements comma-separated under target, and make sure they have a title.','','div','','',0,40,200,30,NULL ,'','','div','../plugins/mb_div_collection.js','','Group_User,groupUser_icon','','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('PortalAdmin_DE','groupUser_icon',2,1,'icon','','img','../img/gnome/groupUser.png','',0,0,NULL ,NULL,2,'','','','','','','','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('PortalAdmin_DE','i18n',1,1,'Internationalization module, collects data from all elements and sends them to the server in a single POST request. The strings are translated via gettext only.','Internationalization','div','','',NULL ,NULL,NULL ,NULL,NULL ,'','','div','../plugins/mb_i18n.js','','','','http://www.mapbender.org/Gettext');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('PortalAdmin_DE','jq_ui',1,1,'jQuery UI core','','','','',NULL ,NULL,NULL ,NULL,NULL ,'','','','','../extensions/jquery-ui-1.8.16.custom/development-bundle/ui/jquery.ui.core.js','','','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('PortalAdmin_DE','jq_ui_button',4,1,'jQuery UI button','','','','',NULL ,NULL,NULL ,NULL,NULL ,'','','','','../extensions/jquery-ui-1.8.16.custom/development-bundle/ui/jquery.ui.button.js','','jq_ui,jq_ui_widget','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('PortalAdmin_DE','jq_ui_dialog',5,1,'Dialog from jQuery UI framework','','','','',NULL ,NULL,NULL ,NULL,NULL ,'','','','','../extensions/jquery-ui-1.8.16.custom/development-bundle/ui/jquery.ui.dialog.js','','jq_ui,jq_ui_widget,jq_ui_button,jq_ui_draggable,jq_ui_mouse,jq_ui_position,jq_ui_resizable','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('PortalAdmin_DE','jq_ui_draggable',5,1,'Draggable from the jQuery UI framework','','','','',NULL ,NULL,NULL ,NULL,NULL ,'','','','','../extensions/jquery-ui-1.8.16.custom/development-bundle/ui/jquery.ui.draggable.js','','jq_ui,jq_ui_mouse,jq_ui_widget','http://jqueryui.com/demos/draggable/');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('PortalAdmin_DE','jq_ui_mouse',2,1,'jQuery UI mouse','','','','',NULL ,NULL,NULL ,NULL,NULL ,'','','','','../extensions/jquery-ui-1.8.16.custom/development-bundle/ui/jquery.ui.mouse.js','','jq_ui_widget','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('PortalAdmin_DE','jq_ui_position',2,1,'jQuery UI position','','','','',NULL ,NULL,NULL ,NULL,NULL ,'','','','','../extensions/jquery-ui-1.8.16.custom/development-bundle/ui/jquery.ui.position.js','','','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('PortalAdmin_DE','jq_ui_resizable',5,1,'Resizable from the jQuery UI framework','','','','',NULL ,NULL,NULL ,NULL,NULL ,'','','','../plugins/jq_ui_resizable.js','../extensions/jquery-ui-1.8.16.custom/development-bundle/ui/jquery.ui.resizable.js','','jq_ui,jq_ui_mouse,jq_ui_widget','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('PortalAdmin_DE','jq_ui_widget',1,1,'jQuery UI widget','','','','',NULL ,NULL,NULL ,NULL,NULL ,'','','','','../extensions/jquery-ui-1.8.16.custom/development-bundle/ui/jquery.ui.widget.js','','','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('PortalAdmin_DE','mb_horizontal_accordion',10,1,'Put existing divs in new horizontal accordion div object. List the elements comma-separated under target, and make sure they have a title.','','div','','',0,0,NULL ,NULL,NULL ,'','<dl></dl>','div','../plugins/mb_horizontal_accordion.js','../../extensions/jqueryEasyAccordion/jquery.easyAccordion.js','menu_maintenance,menu_group,menu_user,menu_role,menu_category','','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('PortalAdmin_DE','mb_iframepopup',7,1,'iframepopup','','div','','',NULL ,NULL,NULL ,NULL,NULL ,'','','div','../plugins/mb_iframepopup.js','','','','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('PortalAdmin_DE','menu_category',2,1,'GUI admin menu','Kategorien','div','','',NULL ,NULL,NULL ,NULL,NULL ,'','','div','../plugins/mb_div_collection.js','','createGuiCategory_collection,deleteCategory_collection','','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('PortalAdmin_DE','menu_group',2,1,'GUI admin menu','Gruppen','div','','',NULL ,NULL,NULL ,NULL,NULL ,'','','div','../plugins/mb_div_collection.js','','editGroup_collection,groupUser_collection','','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('PortalAdmin_DE','menu_maintenance',2,1,'GUI admin menu','Wartung','div','','',NULL ,NULL,NULL ,NULL,NULL ,'','','div','../plugins/mb_div_collection.js','','editMaintenance_collection, reindexWMS_collection,reindexWFS_collection,reindexDATASET_collection,reindexWMC_collection,Start_Monitor_for_WMS_collection','','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('PortalAdmin_DE','menu_role',2,1,'GUI admin menu','Rollen','div','','',NULL ,NULL,NULL ,NULL,NULL ,'','','div','../plugins/mb_div_collection.js','','groupUserRole_collection','','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('PortalAdmin_DE','menu_user',2,1,'User admin menu','Admin Nutzer','div','','',NULL ,NULL,NULL ,NULL,NULL ,'','','div','../plugins/mb_div_collection.js','','editUser_collection','','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('PortalAdmin_DE','myGUIlist',2,1,'Zurück zur Anwendungsübersicht','Zurück zur Anwendungsübersicht','img','../img/button_blue_red/home_off.png','onClick="mod_home_init()" border=''0'' onmouseover=''this.src="../img/button_blue_red/home_over.png"'' onmouseout=''this.src="../img/button_blue_red/home_off.png"''',30,2,24,24,2,'cursor:pointer;','','','mod_home.php','','','','http://www.mapbender.org/index.php/MyGUIlist');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('PortalAdmin_DE','orphanWMS',2,1,'display orphaned wms','','a','','href = "../php/mod_orphanWMS.php?sessionID" target="AdminFrame"',80,15,200,20,NULL ,'font-family: Arial, Helvetica, sans-serif; font-size : 12px; text-decoration : none; color: #808080;','Verwaiste WMS löschen','a','','','','AdminFrame','http://www.mapbender.org/index.php/DeleteWMS');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('PortalAdmin_DE','orphanWMS_icon',2,1,'icon','','img','../img/gnome/edit-clear.png','',0,0,NULL ,NULL,2,'','','','','','','','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('PortalAdmin_DE','reindexDATASET',2,1,'Reindex search DATASET','Reindex search DATASET','a','','href = "../php/mod_catalogueMaintenance.php?sessionID&resourceType=dataset&maintenanceFunction=reindex"',80,15,210,20,5,'font-family: Arial, Helvetica, sans-serif; font-size : 12px; text-decoration : none; color: #808080;','Reindex search DATASET','a','','','','','http://www.mapbender.org/');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('PortalAdmin_DE','reindexDATASET_collection',2,1,'Put existing divs in new div object. List the elements comma-separated under target, and make sure they have a title.','','div','','',0,120,200,30,NULL ,'','','div','../plugins/mb_div_collection.js','','reindexDATASET,reindexDATASET_icon','','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('PortalAdmin_DE','reindexDATASET_icon',2,1,'icon','','img','../img/gnome/system-run.png','',0,0,NULL ,NULL,2,'','','','','','','','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('PortalAdmin_DE','reindexWFS',2,1,'Reindex search WFS','Reindex search WFS','a','','href = "../php/mod_catalogueMaintenance.php?sessionID&resourceType=wfs&maintenanceFunction=reindex"',80,15,210,20,5,'font-family: Arial, Helvetica, sans-serif; font-size : 12px; text-decoration : none; color: #808080;','Reindex search WFS','a','','','','','http://www.mapbender.org/');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('PortalAdmin_DE','reindexWFS_collection',2,1,'Put existing divs in new div object. List the elements comma-separated under target, and make sure they have a title.','','div','','',0,80,200,30,NULL ,'','','div','../plugins/mb_div_collection.js','','reindexWFS,reindexWFS_icon','','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('PortalAdmin_DE','reindexWFS_icon',2,1,'icon','','img','../img/gnome/system-run.png','',0,0,NULL ,NULL,2,'','','','','','','','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('PortalAdmin_DE','reindexWMC',2,1,'Reindex search WMC','Reindex search WMC','a','','href = "../php/mod_catalogueMaintenance.php?sessionID&resourceType=wmc&maintenanceFunction=reindex"',80,15,210,20,5,'font-family: Arial, Helvetica, sans-serif; font-size : 12px; text-decoration : none; color: #808080;','Reindex search WMC','a','','','','','http://www.mapbender.org/');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('PortalAdmin_DE','reindexWMC_collection',2,1,'Put existing divs in new div object. List the elements comma-separated under target, and make sure they have a title.','','div','','',0,160,200,30,NULL ,'','','div','../plugins/mb_div_collection.js','','reindexWMC,reindexWMC_icon','','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('PortalAdmin_DE','reindexWMC_icon',2,1,'icon','','img','../img/gnome/system-run.png','',0,0,NULL ,NULL,2,'','','','','','','','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('PortalAdmin_DE','reindexWMS',2,1,'Reindex search WMS','Reindex search WMS','a','','href = "../php/mod_catalogueMaintenance.php?sessionID&resourceType=wms&maintenanceFunction=reindex"',80,15,210,20,5,'font-family: Arial, Helvetica, sans-serif; font-size : 12px; text-decoration : none; color: #808080;','Reindex search WMS','a','','','','','http://www.mapbender.org/');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('PortalAdmin_DE','reindexWMS_collection',2,1,'Put existing divs in new div object. List the elements comma-separated under target, and make sure they have a title.','','div','','',0,40,200,30,NULL ,'','','div','../plugins/mb_div_collection.js','','reindexWMS,reindexWMS_icon','','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('PortalAdmin_DE','reindexWMS_icon',2,1,'icon','','img','../img/gnome/system-run.png','',0,0,NULL ,NULL,2,'','','','','','','','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('PortalAdmin_DE','showLoggedUser',2,1,'Anzeige des eingeloggten Benutzers','','iframe','../php/mod_showLoggedUser.php?sessionID','frameborder="0" scrolling=''no''',1,1,200,30,1,'padding:6px 55px;','','iframe','','','','','');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('PortalAdmin_DE','Group_User','file css','../css/administration_alloc.css','file css','file/css');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('PortalAdmin_DE','Group_User_Role','file css','../css/administration_alloc.css','file css','file/css');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('PortalAdmin_DE','Start_Monitor_for_WMS','file css','../css/administration_alloc.css','file css','file/css');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('PortalAdmin_DE','body','favicon','../img/favicon.png','favicon','php_var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('PortalAdmin_DE','body','includeWhileLoading','','show splash screen while the application is loading','php_var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('PortalAdmin_DE','body','jq_ui_effects_transfer','.ui-effects-transfer { z-index:1003; border: 2px dotted gray; } ','','text/css');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('PortalAdmin_DE','body','jq_ui_theme','../extensions/jquery-ui-1.7.2.custom/css/smoothness/jquery-ui-1.7.2.custom.css','','file/css');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('PortalAdmin_DE','body','use_load_message','false','show splash screen while the application is loading','php_var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('PortalAdmin_DE','editUser','withPasswordInsertion','true','define if admin can set the new user','php_var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('PortalAdmin_DE','fullScreenIcon','adjust_height','-35','to adjust the height of the mapframe on the bottom of the window','var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('PortalAdmin_DE','fullScreenIcon','adjust_width','30','to adjust the width of the mapframe on the right side of the window','var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('PortalAdmin_DE','fullScreenIcon','resize_option','button','auto (autoresize on load), button (resize by button)','var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('PortalAdmin_DE','jq_ui','css','../extensions/jquery-ui-1.7.2.custom/css/ui-lightness/jquery-ui-1.7.2.custom.css','','file/css');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('PortalAdmin_DE','mb_horizontal_accordion','Accordion css file','../extensions/jqueryEasyAccordion/mb_jquery.easyAccordion.css','','file/css');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('PortalAdmin_DE','reindexDATASET','file css','../css/administration_alloc.css','file css','file/css');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('PortalAdmin_DE','reindexWFS','file css','../css/administration_alloc.css','file css','file/css');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('PortalAdmin_DE','reindexWMC','file css','../css/administration_alloc.css','file css','file/css');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('PortalAdmin_DE','reindexWMS','file css','../css/administration_alloc.css','file css','file/css');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('PortalAdmin_DE','showLoggedUser','css_file_user_logged','../css/administration_alloc.css','file/css','file/css');
More information about the Mapbender_commits mailing list
