[Mapbender-commits] r10148 - in trunk/mapbender/http/extensions/mobilemap2: . libs/bootstrap/css scripts/netgis styles
svn_mapbender at osgeo.org
Fri Jun 14 00:30:34 PDT 2019
Author: armin11
Date: 2019-06-14 00:30:34 -0700 (Fri, 14 Jun 2019)
New Revision: 10148
Added:
trunk/mapbender/http/extensions/mobilemap2/scripts/netgis/client.html
trunk/mapbender/http/extensions/mobilemap2/scripts/netgis/client.js
trunk/mapbender/http/extensions/mobilemap2/scripts/netgis/params.js
trunk/mapbender/http/extensions/mobilemap2/styles/sidemenu.css
trunk/mapbender/http/extensions/mobilemap2/test_embed.html
trunk/mapbender/http/extensions/mobilemap2/index.html
trunk/mapbender/http/extensions/mobilemap2/libs/bootstrap/css/bootstrap-custom.css
trunk/mapbender/http/extensions/mobilemap2/libs/bootstrap/css/bootstrap-custom.min.css
trunk/mapbender/http/extensions/mobilemap2/scripts/netgis/component.js
trunk/mapbender/http/extensions/mobilemap2/scripts/netgis/config.js
trunk/mapbender/http/extensions/mobilemap2/scripts/netgis/layers.js
trunk/mapbender/http/extensions/mobilemap2/scripts/netgis/manager.js
trunk/mapbender/http/extensions/mobilemap2/scripts/netgis/map.js
trunk/mapbender/http/extensions/mobilemap2/scripts/netgis/menu.js
trunk/mapbender/http/extensions/mobilemap2/styles/common.css
trunk/mapbender/http/extensions/mobilemap2/styles/layout.css
trunk/mapbender/http/extensions/mobilemap2/styles/menu.css
trunk/mapbender/http/extensions/mobilemap2/styles/popup.css
New options for mobilemap from NETGIS - thanx to Saarland
Modified: trunk/mapbender/http/extensions/mobilemap2/index.html
--- trunk/mapbender/http/extensions/mobilemap2/index.html 2019-06-13 15:04:42 UTC (rev 10147)
+++ trunk/mapbender/http/extensions/mobilemap2/index.html 2019-06-14 07:30:34 UTC (rev 10148)
@@ -2,7 +2,7 @@
NetGIS WebGIS Client
-(c) Sebastian Pauli, NetGIS, 2017
+(c) Sebastian Pauli, NetGIS, 2017-2019
<html lang="de">
@@ -12,443 +12,38 @@
<meta name="viewport" content="width=device-width, initial-scale=1" />
<title>GeoPortal RLP</title>
<!-- Library Styles -->
- <!--<link rel="stylesheet" type="text/css" href="./libs/bootstrap/css/bootstrap.min.css" />-->
<link rel="stylesheet" type="text/css" href="./libs/bootstrap/css/bootstrap-custom.min.css" />
<link rel="stylesheet" type="text/css" href="./libs/openlayers/ol.css" />
- <!-- Custom Styles -->
- <link rel="stylesheet" type="text/css" href="./styles/common.css" />
- <link rel="stylesheet" type="text/css" href="./styles/layout.css" />
- <link rel="stylesheet" type="text/css" href="./styles/map.css" />
- <link rel="stylesheet" type="text/css" href="./styles/popup.css" />
- <link rel="stylesheet" type="text/css" href="./styles/menu.css" />
- <link rel="stylesheet" type="text/css" href="./styles/manager.css" />
+ <style>
+ html, body
+ width: 100%;
+ height: 100%;
+ </style>
</head>
<body>
- <!-- Navbar -->
- <nav class="navbar navbar-inverse navbar-fixed-top shadow-lg">
- <div class="container-fluid">
- <div class="navbar-header">
- <button type="button" class="navbar-toggle" data-toggle="collapse" data-target="#navbar">
- <span class="icon-bar"></span>
- <!--<span class="glyphicon glyphicon-menu-hamburger"></span>-->
- </button>
- <a class="navbar-brand" href="#">GeoPortal.RLP</a>
- </div>
- <div class="collapse navbar-collapse" id="navbar">
- <ul class="nav navbar-nav">
- <!-- Layers -->
- <li class="dropdown">
- <a href="#" class="dropdown-toggle" data-toggle="dropdown"><span class="icon-left glyphicon glyphicon-th-list"></span>Ebenen <span class="caret"></span></a>
- <ul class="dropdown-menu layer-list" id="layer-menu">
- <li><a href="#" data-toggle="modal" data-target="#layer-dialog"><span class="icon-left glyphicon glyphicon-cog"></span>Verwalten</a></li>
- <li class="divider hidden-xs"></li>
- </ul>
- </li>
- <!-- Tools -->
- <a href="#" class="dropdown-toggle" data-toggle="dropdown"><span class="icon-left glyphicon glyphicon-th-large"></span>Tools <span class="caret"></span></a>
- <ul class="dropdown-menu">
- <li><a href="#" class="tool-pan"><span class="icon-left glyphicon glyphicon-move"></span>Ansicht bewegen</a></li>
- <li><a href="#" class="tool-zoom-box-in"><span class="icon-left glyphicon glyphicon-zoom-in"></span>Hineinzoomen (Rechteck)</a></li>
- <li><a href="#" class="tool-zoom-box-out"><span class="icon-left glyphicon glyphicon-zoom-out"></span>Herauszoomen (Rechteck)</a></li>
- <li><a href="#" class="tool-view-undo"><span class="icon-left glyphicon glyphicon-step-backward"></span>Vorherige Ansicht</a></li>
- <li><a href="#" class="tool-view-redo"><span class="icon-left glyphicon glyphicon-step-forward"></span>Nächste Ansicht</a></li>
- <li><a href="#" class="tool-feature-info"><span class="icon-left glyphicon glyphicon-info-sign"></span>Objekt-Abfrage</a></li>
- <li><a href="#" class="tool-measure-length"><span class="icon-left glyphicon glyphicon-resize-full"></span>Strecke messen</a></li>
- <li><a href="#" class="tool-measure-area"><span class="icon-left glyphicon glyphicon-edit"></span>Fläche messen</a></li>
- </ul>
- </li>
- <!-- Geolocation -->
- <a href="#" class="dropdown-toggle" data-toggle="dropdown"><span class="icon-left glyphicon glyphicon-record"></span>Position <span class="caret"></span></a>
- <li><a href="#" class="btn-position-active"><span class="icon-left glyphicon glyphicon-unchecked"></span>Aktiviert</a></li>
- <li><a href="#" class="btn-position-center"><span class="icon-left glyphicon glyphicon-unchecked"></span>Auto.-Zentrieren</a></li>
- <li><a href="#" class="btn-position-zoom"><span class="icon-left glyphicon glyphicon-record"></span>Position zentrieren</a></li>
- </ul>
- </li>
- <!-- Scale -->
- <a href="#" class="dropdown-toggle" data-toggle="dropdown"><span class="icon-left glyphicon glyphicon-cog"></span>Maßstab <span class="caret"></span></a>
- <ul class="dropdown-menu" id="scale-menu">
- </ul>
- </li>
- </ul>
- <div class="navbar-form navbar-right">
- <!-- Search Bar -->
- <div class="input-group">
- <span id="search-button" class="input-group-addon clickable" data-toggle="collapse" data-target="#search-panel">
- <i class="glyphicon glyphicon-search"></i>
- <i class="glyphicon glyphicon-refresh spinner hidden"></i>
- </span>
- <input id="search-input" type="text" class="form-control" placeholder="Ortssuche..." autocomplete="off" value="" />
- </div>
- </div>
- </div>
- </div>
- </nav>
+ <div id="geoportal-container" style="width: 100%; height: 100%;"></div>
- <!-- Content -->
- <div class="container-fluid container-full">
- <div class="row row-full">
- <!-- Viewport -->
- <div class="col-md-12 col-lg-12 col-full no-padding">
- <!-- Map Container -->
- <div id="map-container"></div>
- <div id="position-overlay" class="clickable" title="Ihre Position"><span class="glyphicon glyphicon-record"></span></div>
- <div class="btn-group-vertical map-control-right index-top shadow-md">
- <button type="button" class="btn btn-primary tool-view-full" title="Volle Ausdehnung zoomen"><img src="./images/icon_rlp.png" height="20"></button>
- <button type="button" class="btn btn-primary tool-zoom-in" title="Hineinzoomen"><span class="glyphicon glyphicon-plus"></span></button>
- <button type="button" class="btn btn-primary tool-zoom-out" title="Herauszoomen"><span class="glyphicon glyphicon-minus"></span></button>
- </div>
- <div class="btn-group-vertical map-control-left index-top shadow-md">
- <button type="button" class="btn btn-primary tool-feature-info" title="Abfragen"><span class="glyphicon glyphicon-info-sign"></span></button>
- <button type="button" class="btn btn-primary tool-legend" title="Legende" data-toggle="modal" data-target="#legend-dialog"><span class="glyphicon glyphicon-option-vertical"></span></button>
- </div>
- <div id="measure-container" class="measure-overlay">
- <span id="measure-content"></span>
- <span id="measure-close" class="glyphicon glyphicon-remove clickable" style="margin-left: 0.25em"></span>
- </div>
- <div id="result-overlay">
- <span class="glyphicon glyphicon-record"></span>
- </div>
- <div id="watermark-container" class="index-top small">
- <a href="http://www.geoportal.rlp.de/portal/servicebereich/impressum.html" target="_blank">© GDI-RP</a>
- </div>
- <div id="popup-container" class="ol-popup">
- <div id="popup-closer" class="ol-popup-closer text-primary"></div>
- <div id="popup-content"></div>
- </div>
- </div>
- <!-- Search Output -->
- <div class="col-xs-12 collapse no-padding shadow-lg" id="search-panel">
- <div class="list-group" id="search-list">
- <a class="list-group-item" data-toggle="collapse" href="#search-panel">
- <span class="glyphicon glyphicon-search icon-left"></span>
- <strong>Suchergebnisse:</strong>
- <span class="glyphicon glyphicon-remove pull-right"></span>
- <div id="search-message">
- <div class="alert alert-info">
- <strong>Ihre Ortsuche ergab keine Treffer. Tipp: Trennen Sie mehrere Suchbegriffe mit einem Komma!</strong><br/>
- Beispiel: <i>„Von-Kuhl-Straße 49, Koblenz“</i>
- </div>
- </div>
- </a>
- </div>
- </div>
- </div>
- </div>
- <!-- Layer Manager -->
- <div class="modal fade" id="layer-dialog" style="/*overflow-y: scroll*/">
- <div class="modal-dialog">
- <div class="panel panel-primary">
- <div class="panel-heading clickable" data-toggle="modal" data-target="#layer-dialog">
- <h4 class="panel-title">Ebenen verwalten<span class="pull-right glyphicon glyphicon-remove"></span></h4>
- </div>
- <div class="panel-body">
- <!-- Layer Search -->
- <div class="form-group">
- <span id="layer-search-button" class="input-group-addon clickable">
- </span>
- <input id="layer-search-input" type="text" class="form-control" placeholder="Datensuche..." />
- </div>
- </div>
- <!-- Search Results -->
- <div class="panel-heading clickable" data-toggle="collapse" data-target="#layer-results">
- <h4 class="panel-title">Suchergebnisse (<span id="layer-results-count">0</span>)<span class="icon-right glyphicon glyphicon-chevron-down pull-right"></span></h4>
- </div>
- <div id="layer-results" class="panel-collapse collapse">
- <div class="alert alert-info alert-dismissable hidden" id="layer-results-alert">
- <a href="#" class="close" data-dismiss="alert" aria-label="close">×</a>
- Zu Ihrer Suchanfrage wurden <strong><span id="layer-results-total">0</span> Ebenen</strong> gefunden, es können aber nur max. 40 Ergebnisse angezeigt werden.<br/>
- </div>
- <div class="list-group" style="margin-bottom: 0px" id="layer-results-list">
- </div>
- </div>
- </div>
- </div>
- <!-- Layer List -->
- <div class="panel panel-primary" style="margin-bottom: 0px">
- <div class="panel-heading clickable" data-toggle="collapse" data-target="#layer-container">
- <h4 class="panel-title">Ebenen (<span id="layer-count">0</span>)<span class="icon-right glyphicon glyphicon-chevron-down pull-right"></span></h4>
- </div>
- <div id="layer-container" class="panel-collapse collapse">
- <ul class="nav nav-tabs nav-justified">
- <li id="tab-layers-all" class="active">
- <a href="#layer-list-all" data-toggle="tab"><span class="icon-left glyphicon glyphicon-folder-open"></span> Themen</a>
- </li>
- <li id="tab-layers-map">
- <a href="#layer-list-map" data-toggle="tab"><span class="icon-left glyphicon glyphicon-eye-open"></span> Karte</a>
- </li>
- </ul>
- <div class="tab-content">
- <div class="tab-pane active list-group layer-list" id="layer-list-all">
- </div>
- <div class="tab-pane list-group layer-list" id="layer-list-map">
- </div>
- </div>
- </div>
- </div>
- </div>
- </div>
- <div class="panel-footer">
- </div>
- </div>
- </div>
- </div>
- <!-- Legend Dialog -->
- <div class="modal fade" id="legend-dialog">
- <div class="modal-dialog" style="vertical-align: middle;">
- <div class="panel-heading clickable" data-toggle="modal" data-target="#legend-dialog">
- <h4 class="panel-title">Legende<span class="pull-right glyphicon glyphicon-remove"></span></h4>
- </div>
- <div class="panel-body" id="legend-panel">
- </div>
- </div>
- </div>
- </div>
- </div>
- <!-- Geolocation Dialog -->
- <div class="modal fade" id="geolocation-dialog">
- <div class="modal-dialog" style="vertical-align: middle">
- <div class="panel-heading" data-toggle="modal" data-target="#geolocation-dialog">
- <h4 class="panel-title clickable">Fehler<span class="pull-right glyphicon glyphicon-remove"></span></h4>
- </div>
- <strong>Die Positionierung ihres Gerätes konnte nicht aktiviert werden.</strong><br/>
- Bitte stellen Sie sicher, dass Sie ihrem Web-Browser den Zugriff auf ihren Standort erlauben
- und diese Seite über eine gesicherte Verbindung aufrufen (https).
- </div>
- </div>
- </div>
- </div>
- </div>
- </div>
- <!-- Loader Dialog -->
- <div class="modal fade" id="loader-dialog">
- <div class="panel-heading">
- <h4 class="panel-title" id="loader-title">Bitte warten...<span class="glyphicon glyphicon-refresh pull-right"></span></h4>
- </div>
- <span id="loader-message">Karte wird geladen.</span>
- </div>
- <div class="progress" style="margin-bottom: 0px;">
- <div class="progress-bar progress-bar-striped progress-bar-info active" role="progressbar"></div>
- </div>
- </div>
- </div>
- </div>
- </div>
- <!-- Templates -->
- <script type="text/html" id="menu-layer-template">
- <li data-id="id" >
- <a href="#" class="btn-layer" data-template-bind='{ "attribute": "data-id", "value": "id" }'>
- <span class="icon-left glyphicon glyphicon-unchecked"></span>
- <span data-content="title"></span>
- </a>
- </li>
- </script>
- <script type="text/html" id="menu-group-template">
- <li data-id="id" class="dropdown-submenu">
- <a href="#" class="btn-group" data-template-bind='{ "attribute": "data-id", "value": "id" }'>
- <span class="icon-folder glyphicon glyphicon-folder-open"></span>
- <span class="hidden-md hidden-lg caret"></span>
- <span class="hidden-xs hidden-sm caret-right"></span>
- </a>
- <ul class="dropdown-menu child-container">
- </ul>
- </li>
- </script>
- <script type="text/html" id="layer-item-template">
- <div data-id="id">
- <a href="#" class="btn-layer list-group-item" data-template-bind='{ "attribute": "data-id", "value": "id" }'>
- <span class="pull-right">
- <span class="btn-remove glyphicon glyphicon-remove"></span>
- </span>
- </a>
- </div>
- </script>
- <script type="text/html" id="layer-group-template">
- <div data-id="id" class="hover-group">
- <a href="" class="btn-group list-group-item collapser" data-template-bind='{ "attribute": "data-id", "value": "id" }' data-toggle="collapse">
- <span class="btn-remove-group glyphicon glyphicon-remove" title="Dienst entfernen"></span>
- <span class="icon-right glyphicon glyphicon-chevron-down"></span>
- </span>
- </a>
- <div class="collapse child-container">
- </div>
- </div>
- </script>
- <script type="text/html" id="map-layer-template">
- <span class="icon-left glyphicon glyphicon-check"></span>
- <span class="btn-zoom glyphicon glyphicon-fullscreen" title="Zoom"></span>
- <span class="btn-up glyphicon glyphicon-arrow-up" title="Rauf"></span>
- <span class="btn-down glyphicon glyphicon-arrow-down" title="Runter"></span>
- </span>
- </a>
- </div>
- </script>
- <script type="text/html" id="layer-result-template">
- <div class="list-group-item" data-template-bind='{ "attribute": "data-index", "value": "index" }'>
- <h4 class="list-group-item-heading clickable">
- <span class="result-item-title" data-content="title"></span>
- <!--<span class="badge" data-content="count"></span>-->
- <span class="btn-add pull-right glyphicon glyphicon-plus"></span>
- </h4>
- <div class="list-group-item-text">
- <div class="collapse">
- <table class="table table-condensed">
- <thead><tr><th>Beschreibung:</tb></tr></thead>
- <tbody><tr><td data-content="details"></td></tr></tbody>
- </table>
- <thead><tr><th>Ebenen:</tb></tr></thead>
- <tbody data-content="rows"></tbody>
- </table>
- </div>
- <button class="btn btn-default btn-xs btn-block collapser"><span class="glyphicon glyphicon-triangle-bottom"></span></button>
- </div>
- </div>
- </script>
- <script type="text/html" id="search-result-template">
- <a href="#" class="list-group-item search-result" data-template-bind='{ "attribute": "data-index", "value": "index" }'>
- <span class="icon-left glyphicon glyphicon-map-marker"></span>
- </a>
- </script>
- <!-- TODO: layer item collapse -->
- <script type="text/html" id="legend-item-template">
- <div class="panel-heading clickable">
- <h4 class="panel-title"><span data-content="title"></span></h4>
- </div>
- <img data-template-bind='{ "attribute": "src", "value": "url" }'></img>
- </div>
- </div>
- </script>
<!-- Library Scripts -->
<script type="text/javascript" src="./libs/jquery/jquery.min.js"></script>
<script type="text/javascript" src="./libs/jquery-template/jquery.loadTemplate.min.js"></script>
<script type="text/javascript" src="./libs/bootstrap/js/bootstrap.min.js"></script>
<script type="text/javascript" src="./libs/proj4js/proj4.js"></script>
- <script type="text/javascript" src="./libs/openlayers/ol-debug.js"></script>
+ <script type="text/javascript" src="./libs/openlayers/ol.js"></script>
- <!-- Custom Scripts -->
- <script type="text/javascript" src="./scripts/netgis/netgis.js"></script>
- <script type="text/javascript" src="./scripts/netgis/config.js"></script>
- <script type="text/javascript" src="./scripts/netgis/events.js"></script>
- <script type="text/javascript" src="./scripts/netgis/entity.js"></script>
- <script type="text/javascript" src="./scripts/netgis/component.js"></script>
- <script type="text/javascript" src="./scripts/netgis/entities.js"></script>
+ <!-- Load Client -->
+ <script type="text/javascript" src="./scripts/netgis/client.js"></script>
- <script type="text/javascript" src="./scripts/netgis/loader.js"></script>
- <script type="text/javascript" src="./scripts/netgis/map.js"></script>
- <script type="text/javascript" src="./scripts/netgis/menu.js"></script>
- <script type="text/javascript" src="./scripts/netgis/manager.js"></script>
- <script type="text/javascript" src="./scripts/netgis/layers.js"></script>
+ <script>
+ netgis.client.load( "geoportal-container" );
+ </script>
</body>
Modified: trunk/mapbender/http/extensions/mobilemap2/libs/bootstrap/css/bootstrap-custom.css
--- trunk/mapbender/http/extensions/mobilemap2/libs/bootstrap/css/bootstrap-custom.css 2019-06-13 15:04:42 UTC (rev 10147)
+++ trunk/mapbender/http/extensions/mobilemap2/libs/bootstrap/css/bootstrap-custom.css 2019-06-14 07:30:34 UTC (rev 10148)
@@ -254,8 +254,8 @@
@font-face {
font-family: 'Glyphicons Halflings';
- src: url('../fonts/glyphicons-halflings-regular.eot');
- src: url('../fonts/glyphicons-halflings-regular.eot?#iefix') format('embedded-opentype'), url('../fonts/glyphicons-halflings-regular.woff2') format('woff2'), url('../fonts/glyphicons-halflings-regular.woff') format('woff'), url('../fonts/glyphicons-halflings-regular.ttf') format('truetype'), url('../fonts/glyphicons-halflings-regular.svg#glyphicons_halflingsregular') format('svg');
+ src: url('https://cdn.jsdelivr.net/bootstrap/3.3.7/fonts/glyphicons-halflings-regular.eot');
+ src: url('https://cdn.jsdelivr.net/bootstrap/3.3.7/fonts/glyphicons-halflings-regular.eot?#iefix') format('embedded-opentype'), url('https://cdn.jsdelivr.net/bootstrap/3.3.7/fonts/glyphicons-halflings-regular.woff2') format('woff2'), url('https://cdn.jsdelivr.net/bootstrap/3.3.7/fonts/glyphicons-halflings-regular.woff') format('woff'), url('https://cdn.jsdelivr.net/bootstrap/3.3.7/fonts/glyphicons-halflings-regular.ttf') format('truetype'), url('https://cdn.jsdelivr.net/bootstrap/3.3.7/fonts/glyphicons-halflings-regular.svg#glyphicons_halflingsregular') format('svg');
.glyphicon {
position: relative;
@@ -7270,4 +7270,4 @@
border-color: #dcdcdc;
-webkit-box-shadow: inset 0 1px 3px rgba(0, 0, 0, 0.05), 0 1px 0 rgba(255, 255, 255, 0.1);
\ No newline at end of file
Modified: trunk/mapbender/http/extensions/mobilemap2/libs/bootstrap/css/bootstrap-custom.min.css
--- trunk/mapbender/http/extensions/mobilemap2/libs/bootstrap/css/bootstrap-custom.min.css 2019-06-13 15:04:42 UTC (rev 10147)
+++ trunk/mapbender/http/extensions/mobilemap2/libs/bootstrap/css/bootstrap-custom.min.css 2019-06-14 07:30:34 UTC (rev 10148)
@@ -2,4 +2,4 @@
* Bootstrap v3.3.7 (http://getbootstrap.com)
* Copyright 2011-2016 Twitter, Inc.
* Licensed under MIT (https://github.com/twbs/bootstrap/blob/master/LICENSE)
- *//* normalize.css v3.0.3 | MIT License | github.com/necolas/normalize.css */html{font-family:sans-serif;-ms-text-size-adjust:100%;-webkit-text-size-adjust:100%}body{margin:0}article,aside,details,figcaption,figure,footer,header,hgroup,main,menu,nav,section,summary{display:block}audio,canvas,progress,video{display:inline-block;vertical-align:baseline}audio:not([controls]){display:none;height:0}[hidden],template{display:none}a{background-color:transparent}a:active,a:hover{outline:0}abbr[title]{border-bottom:1px dotted}b,strong{font-weight:bold}dfn{font-style:italic}h1{font-size:2em;margin:.67em 0}mark{background:#ff0;color:#000}small{font-size:80%}sub,sup{font-size:75%;line-height:0;position:relative;vertical-align:baseline}sup{top:-0.5em}sub{bottom:-0.25em}img{border:0}svg:not(:root){overflow:hidden}figure{margin:1em 40px}hr{box-sizing:content-box;height:0}pre{overflow:auto}code,kbd,pre,samp{font-family:monospace,monospace;font-size:1em}button,input,optgroup,select,textarea{color:i
nherit;font:inherit;margin:0}button{overflow:visible}button,select{text-transform:none}button,html input[type="button"],input[type="reset"],input[type="submit"]{-webkit-appearance:button;cursor:pointer}button[disabled],html input[disabled]{cursor:default}button::-moz-focus-inner,input::-moz-focus-inner{border:0;padding:0}input{line-height:normal}input[type="checkbox"],input[type="radio"]{box-sizing:border-box;padding:0}input[type="number"]::-webkit-inner-spin-button,input[type="number"]::-webkit-outer-spin-button{height:auto}input[type="search"]{-webkit-appearance:textfield;box-sizing:content-box}input[type="search"]::-webkit-search-cancel-button,input[type="search"]::-webkit-search-decoration{-webkit-appearance:none}fieldset{border:1px solid #c0c0c0;margin:0 2px;padding:.35em .625em .75em}legend{border:0;padding:0}textarea{overflow:auto}optgroup{font-weight:bold}table{border-collapse:collapse;border-spacing:0}td,th{padding:0}/* Source: https://github.com/h5bp/html5-boilerplate/blob
/master/src/css/main.css */@media print{*,*:before,*:after{background:transparent!important;color:#000!important;box-shadow:none!important;text-shadow:none!important}a,a:visited{text-decoration:underline}a[href]:after{content:" (" attr(href) ")"}abbr[title]:after{content:" (" attr(title) ")"}a[href^="#"]:after,a[href^="javascript:"]:after{content:""}pre,blockquote{border:1px solid #999;page-break-inside:avoid}thead{display:table-header-group}tr,img{page-break-inside:avoid}img{max-width:100%!important}p,h2,h3{orphans:3;widows:3}h2,h3{page-break-after:avoid}.navbar{display:none}.btn>.caret,.dropup>.btn>.caret{border-top-color:#000!important}.label{border:1px solid #000}.table{border-collapse:collapse!important}.table td,.table th{background-color:#fff!important}.table-bordered th,.table-bordered td{border:1px solid #ddd!important}}@font-face{font-family:'Glyphicons Halflings';src:url('../fonts/glyphicons-halflings-regular.ttf');src:url('../fonts/glyphicons-halflings-regular.ttf?#iefix
') format('embedded-opentype'),url('../fonts/glyphicons-halflings-regular.woff2') format('woff2'),url('../fonts/glyphicons-halflings-regular.woff') format('woff'),url('../fonts/glyphicons-halflings-regular.ttf') format('truetype'),url('../fonts/glyphicons-halflings-regular.svg#glyphicons_halflingsregular') format('svg')}.glyphicon{position:relative;top:1px;display:inline-block;font-family:'Glyphicons Halflings';font-style:normal;font-weight:normal;line-height:1;-webkit-font-smoothing:antialiased;-moz-osx-font-smoothing:grayscale}.glyphicon-asterisk:before{content:"\002a"}.glyphicon-plus:before{content:"\002b"}.glyphicon-euro:before,.glyphicon-eur:before{content:"\20ac"}.glyphicon-minus:before{content:"\2212"}.glyphicon-cloud:before{content:"\2601"}.glyphicon-envelope:before{content:"\2709"}.glyphicon-pencil:before{content:"\270f"}.glyphicon-glass:before{content:"\e001"}.glyphicon-music:before{content:"\e002"}.glyphicon-search:before{content:"\e003"}.glyphicon-heart:before{content:"\
e005"}.glyphicon-star:before{content:"\e006"}.glyphicon-star-empty:before{content:"\e007"}.glyphicon-user:before{content:"\e008"}.glyphicon-film:before{content:"\e009"}.glyphicon-th-large:before{content:"\e010"}.glyphicon-th:before{content:"\e011"}.glyphicon-th-list:before{content:"\e012"}.glyphicon-ok:before{content:"\e013"}.glyphicon-remove:before{content:"\e014"}.glyphicon-zoom-in:before{content:"\e015"}.glyphicon-zoom-out:before{content:"\e016"}.glyphicon-off:before{content:"\e017"}.glyphicon-signal:before{content:"\e018"}.glyphicon-cog:before{content:"\e019"}.glyphicon-trash:before{content:"\e020"}.glyphicon-home:before{content:"\e021"}.glyphicon-file:before{content:"\e022"}.glyphicon-time:before{content:"\e023"}.glyphicon-road:before{content:"\e024"}.glyphicon-download-alt:before{content:"\e025"}.glyphicon-download:before{content:"\e026"}.glyphicon-upload:before{content:"\e027"}.glyphicon-inbox:before{content:"\e028"}.glyphicon-play-circle:before{content:"\e029"}.glyphicon-rep
eat:before{content:"\e030"}.glyphicon-refresh:before{content:"\e031"}.glyphicon-list-alt:before{content:"\e032"}.glyphicon-lock:before{content:"\e033"}.glyphicon-flag:before{content:"\e034"}.glyphicon-headphones:before{content:"\e035"}.glyphicon-volume-off:before{content:"\e036"}.glyphicon-volume-down:before{content:"\e037"}.glyphicon-volume-up:before{content:"\e038"}.glyphicon-qrcode:before{content:"\e039"}.glyphicon-barcode:before{content:"\e040"}.glyphicon-tag:before{content:"\e041"}.glyphicon-tags:before{content:"\e042"}.glyphicon-book:before{content:"\e043"}.glyphicon-bookmark:before{content:"\e044"}.glyphicon-print:before{content:"\e045"}.glyphicon-camera:before{content:"\e046"}.glyphicon-font:before{content:"\e047"}.glyphicon-bold:before{content:"\e048"}.glyphicon-italic:before{content:"\e049"}.glyphicon-text-height:before{content:"\e050"}.glyphicon-text-width:before{content:"\e051"}.glyphicon-align-left:before{content:"\e052"}.glyphicon-align-center:before{content:"\e053"}.g
lyphicon-align-right:before{content:"\e054"}.glyphicon-align-justify:before{content:"\e055"}.glyphicon-list:before{content:"\e056"}.glyphicon-indent-left:before{content:"\e057"}.glyphicon-indent-right:before{content:"\e058"}.glyphicon-facetime-video:before{content:"\e059"}.glyphicon-picture:before{content:"\e060"}.glyphicon-map-marker:before{content:"\e062"}.glyphicon-adjust:before{content:"\e063"}.glyphicon-tint:before{content:"\e064"}.glyphicon-edit:before{content:"\e065"}.glyphicon-share:before{content:"\e066"}.glyphicon-check:before{content:"\e067"}.glyphicon-move:before{content:"\e068"}.glyphicon-step-backward:before{content:"\e069"}.glyphicon-fast-backward:before{content:"\e070"}.glyphicon-backward:before{content:"\e071"}.glyphicon-play:before{content:"\e072"}.glyphicon-pause:before{content:"\e073"}.glyphicon-stop:before{content:"\e074"}.glyphicon-forward:before{content:"\e075"}.glyphicon-fast-forward:before{content:"\e076"}.glyphicon-step-forward:before{content:"\e077"}.glyph
icon-eject:before{content:"\e078"}.glyphicon-chevron-left:before{content:"\e079"}.glyphicon-chevron-right:before{content:"\e080"}.glyphicon-plus-sign:before{content:"\e081"}.glyphicon-minus-sign:before{content:"\e082"}.glyphicon-remove-sign:before{content:"\e083"}.glyphicon-ok-sign:before{content:"\e084"}.glyphicon-question-sign:before{content:"\e085"}.glyphicon-info-sign:before{content:"\e086"}.glyphicon-screenshot:before{content:"\e087"}.glyphicon-remove-circle:before{content:"\e088"}.glyphicon-ok-circle:before{content:"\e089"}.glyphicon-ban-circle:before{content:"\e090"}.glyphicon-arrow-left:before{content:"\e091"}.glyphicon-arrow-right:before{content:"\e092"}.glyphicon-arrow-up:before{content:"\e093"}.glyphicon-arrow-down:before{content:"\e094"}.glyphicon-share-alt:before{content:"\e095"}.glyphicon-resize-full:before{content:"\e096"}.glyphicon-resize-small:before{content:"\e097"}.glyphicon-exclamation-sign:before{content:"\e101"}.glyphicon-gift:before{content:"\e102"}.glyphicon-
leaf:before{content:"\e103"}.glyphicon-fire:before{content:"\e104"}.glyphicon-eye-open:before{content:"\e105"}.glyphicon-eye-close:before{content:"\e106"}.glyphicon-warning-sign:before{content:"\e107"}.glyphicon-plane:before{content:"\e108"}.glyphicon-calendar:before{content:"\e109"}.glyphicon-random:before{content:"\e110"}.glyphicon-comment:before{content:"\e111"}.glyphicon-magnet:before{content:"\e112"}.glyphicon-chevron-up:before{content:"\e113"}.glyphicon-chevron-down:before{content:"\e114"}.glyphicon-retweet:before{content:"\e115"}.glyphicon-shopping-cart:before{content:"\e116"}.glyphicon-folder-close:before{content:"\e117"}.glyphicon-folder-open:before{content:"\e118"}.glyphicon-resize-vertical:before{content:"\e119"}.glyphicon-resize-horizontal:before{content:"\e120"}.glyphicon-hdd:before{content:"\e121"}.glyphicon-bullhorn:before{content:"\e122"}.glyphicon-bell:before{content:"\e123"}.glyphicon-certificate:before{content:"\e124"}.glyphicon-thumbs-up:before{content:"\e125"}.g
lyphicon-thumbs-down:before{content:"\e126"}.glyphicon-hand-right:before{content:"\e127"}.glyphicon-hand-left:before{content:"\e128"}.glyphicon-hand-up:before{content:"\e129"}.glyphicon-hand-down:before{content:"\e130"}.glyphicon-circle-arrow-right:before{content:"\e131"}.glyphicon-circle-arrow-left:before{content:"\e132"}.glyphicon-circle-arrow-up:before{content:"\e133"}.glyphicon-circle-arrow-down:before{content:"\e134"}.glyphicon-globe:before{content:"\e135"}.glyphicon-wrench:before{content:"\e136"}.glyphicon-tasks:before{content:"\e137"}.glyphicon-filter:before{content:"\e138"}.glyphicon-briefcase:before{content:"\e139"}.glyphicon-fullscreen:before{content:"\e140"}.glyphicon-dashboard:before{content:"\e141"}.glyphicon-paperclip:before{content:"\e142"}.glyphicon-heart-empty:before{content:"\e143"}.glyphicon-link:before{content:"\e144"}.glyphicon-phone:before{content:"\e145"}.glyphicon-pushpin:before{content:"\e146"}.glyphicon-usd:before{content:"\e148"}.glyphicon-gbp:before{conte
nt:"\e149"}.glyphicon-sort:before{content:"\e150"}.glyphicon-sort-by-alphabet:before{content:"\e151"}.glyphicon-sort-by-alphabet-alt:before{content:"\e152"}.glyphicon-sort-by-order:before{content:"\e153"}.glyphicon-sort-by-order-alt:before{content:"\e154"}.glyphicon-sort-by-attributes:before{content:"\e155"}.glyphicon-sort-by-attributes-alt:before{content:"\e156"}.glyphicon-unchecked:before{content:"\e157"}.glyphicon-expand:before{content:"\e158"}.glyphicon-collapse-down:before{content:"\e159"}.glyphicon-collapse-up:before{content:"\e160"}.glyphicon-log-in:before{content:"\e161"}.glyphicon-flash:before{content:"\e162"}.glyphicon-log-out:before{content:"\e163"}.glyphicon-new-window:before{content:"\e164"}.glyphicon-record:before{content:"\e165"}.glyphicon-save:before{content:"\e166"}.glyphicon-open:before{content:"\e167"}.glyphicon-saved:before{content:"\e168"}.glyphicon-import:before{content:"\e169"}.glyphicon-export:before{content:"\e170"}.glyphicon-send:before{content:"\e171"}.gly
phicon-floppy-disk:before{content:"\e172"}.glyphicon-floppy-saved:before{content:"\e173"}.glyphicon-floppy-remove:before{content:"\e174"}.glyphicon-floppy-save:before{content:"\e175"}.glyphicon-floppy-open:before{content:"\e176"}.glyphicon-credit-card:before{content:"\e177"}.glyphicon-transfer:before{content:"\e178"}.glyphicon-cutlery:before{content:"\e179"}.glyphicon-header:before{content:"\e180"}.glyphicon-compressed:before{content:"\e181"}.glyphicon-earphone:before{content:"\e182"}.glyphicon-phone-alt:before{content:"\e183"}.glyphicon-tower:before{content:"\e184"}.glyphicon-stats:before{content:"\e185"}.glyphicon-sd-video:before{content:"\e186"}.glyphicon-hd-video:before{content:"\e187"}.glyphicon-subtitles:before{content:"\e188"}.glyphicon-sound-stereo:before{content:"\e189"}.glyphicon-sound-dolby:before{content:"\e190"}.glyphicon-sound-5-1:before{content:"\e191"}.glyphicon-sound-6-1:before{content:"\e192"}.glyphicon-sound-7-1:before{content:"\e193"}.glyphicon-copyright-mark:bef
ore{content:"\e194"}.glyphicon-registration-mark:before{content:"\e195"}.glyphicon-cloud-download:before{content:"\e197"}.glyphicon-cloud-upload:before{content:"\e198"}.glyphicon-tree-conifer:before{content:"\e199"}.glyphicon-tree-deciduous:before{content:"\e200"}.glyphicon-cd:before{content:"\e201"}.glyphicon-save-file:before{content:"\e202"}.glyphicon-open-file:before{content:"\e203"}.glyphicon-level-up:before{content:"\e204"}.glyphicon-copy:before{content:"\e205"}.glyphicon-paste:before{content:"\e206"}.glyphicon-alert:before{content:"\e209"}.glyphicon-equalizer:before{content:"\e210"}.glyphicon-king:before{content:"\e211"}.glyphicon-queen:before{content:"\e212"}.glyphicon-pawn:before{content:"\e213"}.glyphicon-bishop:before{content:"\e214"}.glyphicon-knight:before{content:"\e215"}.glyphicon-baby-formula:before{content:"\e216"}.glyphicon-tent:before{content:"\26fa"}.glyphicon-blackboard:before{content:"\e218"}.glyphicon-bed:before{content:"\e219"}.glyphicon-apple:before{content:"
\f8ff"}.glyphicon-erase:before{content:"\e221"}.glyphicon-hourglass:before{content:"\231b"}.glyphicon-lamp:before{content:"\e223"}.glyphicon-duplicate:before{content:"\e224"}.glyphicon-piggy-bank:before{content:"\e225"}.glyphicon-scissors:before{content:"\e226"}.glyphicon-bitcoin:before{content:"\e227"}.glyphicon-btc:before{content:"\e227"}.glyphicon-xbt:before{content:"\e227"}.glyphicon-yen:before{content:"\00a5"}.glyphicon-jpy:before{content:"\00a5"}.glyphicon-ruble:before{content:"\20bd"}.glyphicon-rub:before{content:"\20bd"}.glyphicon-scale:before{content:"\e230"}.glyphicon-ice-lolly:before{content:"\e231"}.glyphicon-ice-lolly-tasted:before{content:"\e232"}.glyphicon-education:before{content:"\e233"}.glyphicon-option-horizontal:before{content:"\e234"}.glyphicon-option-vertical:before{content:"\e235"}.glyphicon-menu-hamburger:before{content:"\e236"}.glyphicon-modal-window:before{content:"\e237"}.glyphicon-oil:before{content:"\e238"}.glyphicon-grain:before{content:"\e239"}.glyphic
on-sunglasses:before{content:"\e240"}.glyphicon-text-size:before{content:"\e241"}.glyphicon-text-color:before{content:"\e242"}.glyphicon-text-background:before{content:"\e243"}.glyphicon-object-align-top:before{content:"\e244"}.glyphicon-object-align-bottom:before{content:"\e245"}.glyphicon-object-align-horizontal:before{content:"\e246"}.glyphicon-object-align-left:before{content:"\e247"}.glyphicon-object-align-vertical:before{content:"\e248"}.glyphicon-object-align-right:before{content:"\e249"}.glyphicon-triangle-right:before{content:"\e250"}.glyphicon-triangle-left:before{content:"\e251"}.glyphicon-triangle-bottom:before{content:"\e252"}.glyphicon-triangle-top:before{content:"\e253"}.glyphicon-console:before{content:"\e254"}.glyphicon-superscript:before{content:"\e255"}.glyphicon-subscript:before{content:"\e256"}.glyphicon-menu-left:before{content:"\e257"}.glyphicon-menu-right:before{content:"\e258"}.glyphicon-menu-down:before{content:"\e259"}.glyphicon-menu-up:before{content:"\e2
60"}*{-webkit-box-sizing:border-box;-moz-box-sizing:border-box;box-sizing:border-box}*:before,*:after{-webkit-box-sizing:border-box;-moz-box-sizing:border-box;box-sizing:border-box}html{font-size:10px;-webkit-tap-highlight-color:rgba(0,0,0,0)}body{font-family:"Helvetica Neue",Helvetica,Arial,sans-serif;font-size:14px;line-height:1.42857143;color:#333;background-color:#fff}input,button,select,textarea{font-family:inherit;font-size:inherit;line-height:inherit}a{color:#871e32;text-decoration:none}a:hover,a:focus{color:#48101b;text-decoration:underline}a:focus{outline:5px auto -webkit-focus-ring-color;outline-offset:-2px}figure{margin:0}img{vertical-align:middle}.img-responsive,.thumbnail>img,.thumbnail a>img,.carousel-inner>.item>img,.carousel-inner>.item>a>img{display:block;max-width:100%;height:auto}.img-rounded{border-radius:6px}.img-thumbnail{padding:4px;line-height:1.42857143;background-color:#fff;border:1px solid #ddd;border-radius:4px;-webkit-transition:all .2s ease-in-out;-o-tr
ansition:all .2s ease-in-out;transition:all .2s ease-in-out;display:inline-block;max-width:100%;height:auto}.img-circle{border-radius:50%}hr{margin-top:20px;margin-bottom:20px;border:0;border-top:1px solid #eee}.sr-only{position:absolute;width:1px;height:1px;margin:-1px;padding:0;overflow:hidden;clip:rect(0,0,0,0);border:0}.sr-only-focusable:active,.sr-only-focusable:focus{position:static;width:auto;height:auto;margin:0;overflow:visible;clip:auto}[role="button"]{cursor:pointer}h1,h2,h3,h4,h5,h6,.h1,.h2,.h3,.h4,.h5,.h6{font-family:inherit;font-weight:500;line-height:1.1;color:inherit}h1 small,h2 small,h3 small,h4 small,h5 small,h6 small,.h1 small,.h2 small,.h3 small,.h4 small,.h5 small,.h6 small,h1 .small,h2 .small,h3 .small,h4 .small,h5 .small,h6 .small,.h1 .small,.h2 .small,.h3 .small,.h4 .small,.h5 .small,.h6 .small{font-weight:normal;line-height:1;color:#777}h1,.h1,h2,.h2,h3,.h3{margin-top:20px;margin-bottom:10px}h1 small,.h1 small,h2 small,.h2 small,h3 small,.h3 small,h1 .small,
.h1 .small,h2 .small,.h2 .small,h3 .small,.h3 .small{font-size:65%}h4,.h4,h5,.h5,h6,.h6{margin-top:10px;margin-bottom:10px}h4 small,.h4 small,h5 small,.h5 small,h6 small,.h6 small,h4 .small,.h4 .small,h5 .small,.h5 .small,h6 .small,.h6 .small{font-size:75%}h1,.h1{font-size:36px}h2,.h2{font-size:30px}h3,.h3{font-size:24px}h4,.h4{font-size:18px}h5,.h5{font-size:14px}h6,.h6{font-size:12px}p{margin:0 0 10px}.lead{margin-bottom:20px;font-size:16px;font-weight:300;line-height:1.4}@media(min-width:768px){.lead{font-size:21px}}small,.small{font-size:85%}mark,.mark{background-color:#fcf8e3;padding:.2em}.text-left{text-align:left}.text-right{text-align:right}.text-center{text-align:center}.text-justify{text-align:justify}.text-nowrap{white-space:nowrap}.text-lowercase{text-transform:lowercase}.text-uppercase{text-transform:uppercase}.text-capitalize{text-transform:capitalize}.text-muted{color:#777}.text-primary{color:#871e32}a.text-primary:hover,a.text-primary:focus{color:#5d1523}.text-succes
s{color:#3c763d}a.text-success:hover,a.text-success:focus{color:#2b542c}.text-info{color:#31708f}a.text-info:hover,a.text-info:focus{color:#245269}.text-warning{color:#8a6d3b}a.text-warning:hover,a.text-warning:focus{color:#66512c}.text-danger{color:#a94442}a.text-danger:hover,a.text-danger:focus{color:#843534}.bg-primary{color:#fff;background-color:#871e32}a.bg-primary:hover,a.bg-primary:focus{background-color:#5d1523}.bg-success{background-color:#dff0d8}a.bg-success:hover,a.bg-success:focus{background-color:#c1e2b3}.bg-info{background-color:#d9edf7}a.bg-info:hover,a.bg-info:focus{background-color:#afd9ee}.bg-warning{background-color:#fcf8e3}a.bg-warning:hover,a.bg-warning:focus{background-color:#f7ecb5}.bg-danger{background-color:#f2dede}a.bg-danger:hover,a.bg-danger:focus{background-color:#e4b9b9}.page-header{padding-bottom:9px;margin:40px 0 20px;border-bottom:1px solid #eee}ul,ol{margin-top:0;margin-bottom:10px}ul ul,ol ul,ul ol,ol ol{margin-bottom:0}.list-unstyled{padding-left:
0;list-style:none}.list-inline{padding-left:0;list-style:none;margin-left:-5px}.list-inline>li{display:inline-block;padding-left:5px;padding-right:5px}dl{margin-top:0;margin-bottom:20px}dt,dd{line-height:1.42857143}dt{font-weight:bold}dd{margin-left:0}@media(min-width:768px){.dl-horizontal dt{float:left;width:160px;clear:left;text-align:right;overflow:hidden;text-overflow:ellipsis;white-space:nowrap}.dl-horizontal dd{margin-left:180px}}abbr[title],abbr[data-original-title]{cursor:help;border-bottom:1px dotted #777}.initialism{font-size:90%;text-transform:uppercase}blockquote{padding:10px 20px;margin:0 0 20px;font-size:17.5px;border-left:5px solid #eee}blockquote p:last-child,blockquote ul:last-child,blockquote ol:last-child{margin-bottom:0}blockquote footer,blockquote small,blockquote .small{display:block;font-size:80%;line-height:1.42857143;color:#777}blockquote footer:before,blockquote small:before,blockquote .small:before{content:'\2014 \00A0'}.blockquote-reverse,blockquote.pull-
right{padding-right:15px;padding-left:0;border-right:5px solid #eee;border-left:0;text-align:right}.blockquote-reverse footer:before,blockquote.pull-right footer:before,.blockquote-reverse small:before,blockquote.pull-right small:before,.blockquote-reverse .small:before,blockquote.pull-right .small:before{content:''}.blockquote-reverse footer:after,blockquote.pull-right footer:after,.blockquote-reverse small:after,blockquote.pull-right small:after,.blockquote-reverse .small:after,blockquote.pull-right .small:after{content:'\00A0 \2014'}address{margin-bottom:20px;font-style:normal;line-height:1.42857143}code,kbd,pre,samp{font-family:Menlo,Monaco,Consolas,"Courier New",monospace}code{padding:2px 4px;font-size:90%;color:#c7254e;background-color:#f9f2f4;border-radius:4px}kbd{padding:2px 4px;font-size:90%;color:#fff;background-color:#333;border-radius:3px;box-shadow:inset 0 -1px 0 rgba(0,0,0,0.25)}kbd kbd{padding:0;font-size:100%;font-weight:bold;box-shadow:none}pre{display:block;padding
:9.5px;margin:0 0 10px;font-size:13px;line-height:1.42857143;word-break:break-all;word-wrap:break-word;color:#333;background-color:#f5f5f5;border:1px solid #ccc;border-radius:4px}pre code{padding:0;font-size:inherit;color:inherit;white-space:pre-wrap;background-color:transparent;border-radius:0}.pre-scrollable{max-height:340px;overflow-y:scroll}.container{margin-right:auto;margin-left:auto;padding-left:15px;padding-right:15px}@media(min-width:768px){.container{width:750px}}@media(min-width:992px){.container{width:970px}}@media(min-width:1200px){.container{width:1170px}}.container-fluid{margin-right:auto;margin-left:auto;padding-left:15px;padding-right:15px}.row{margin-left:-15px;margin-right:-15px}.col-xs-1,.col-sm-1,.col-md-1,.col-lg-1,.col-xs-2,.col-sm-2,.col-md-2,.col-lg-2,.col-xs-3,.col-sm-3,.col-md-3,.col-lg-3,.col-xs-4,.col-sm-4,.col-md-4,.col-lg-4,.col-xs-5,.col-sm-5,.col-md-5,.col-lg-5,.col-xs-6,.col-sm-6,.col-md-6,.col-lg-6,.col-xs-7,.col-sm-7,.col-md-7,.col-lg-7,.col-xs-8,
.col-sm-8,.col-md-8,.col-lg-8,.col-xs-9,.col-sm-9,.col-md-9,.col-lg-9,.col-xs-10,.col-sm-10,.col-md-10,.col-lg-10,.col-xs-11,.col-sm-11,.col-md-11,.col-lg-11,.col-xs-12,.col-sm-12,.col-md-12,.col-lg-12{position:relative;min-height:1px;padding-left:15px;padding-right:15px}.col-xs-1,.col-xs-2,.col-xs-3,.col-xs-4,.col-xs-5,.col-xs-6,.col-xs-7,.col-xs-8,.col-xs-9,.col-xs-10,.col-xs-11,.col-xs-12{float:left}.col-xs-12{width:100%}.col-xs-11{width:91.66666667%}.col-xs-10{width:83.33333333%}.col-xs-9{width:75%}.col-xs-8{width:66.66666667%}.col-xs-7{width:58.33333333%}.col-xs-6{width:50%}.col-xs-5{width:41.66666667%}.col-xs-4{width:33.33333333%}.col-xs-3{width:25%}.col-xs-2{width:16.66666667%}.col-xs-1{width:8.33333333%}.col-xs-pull-12{right:100%}.col-xs-pull-11{right:91.66666667%}.col-xs-pull-10{right:83.33333333%}.col-xs-pull-9{right:75%}.col-xs-pull-8{right:66.66666667%}.col-xs-pull-7{right:58.33333333%}.col-xs-pull-6{right:50%}.col-xs-pull-5{right:41.66666667%}.col-xs-pull-4{right:33.333
33333%}.col-xs-pull-3{right:25%}.col-xs-pull-2{right:16.66666667%}.col-xs-pull-1{right:8.33333333%}.col-xs-pull-0{right:auto}.col-xs-push-12{left:100%}.col-xs-push-11{left:91.66666667%}.col-xs-push-10{left:83.33333333%}.col-xs-push-9{left:75%}.col-xs-push-8{left:66.66666667%}.col-xs-push-7{left:58.33333333%}.col-xs-push-6{left:50%}.col-xs-push-5{left:41.66666667%}.col-xs-push-4{left:33.33333333%}.col-xs-push-3{left:25%}.col-xs-push-2{left:16.66666667%}.col-xs-push-1{left:8.33333333%}.col-xs-push-0{left:auto}.col-xs-offset-12{margin-left:100%}.col-xs-offset-11{margin-left:91.66666667%}.col-xs-offset-10{margin-left:83.33333333%}.col-xs-offset-9{margin-left:75%}.col-xs-offset-8{margin-left:66.66666667%}.col-xs-offset-7{margin-left:58.33333333%}.col-xs-offset-6{margin-left:50%}.col-xs-offset-5{margin-left:41.66666667%}.col-xs-offset-4{margin-left:33.33333333%}.col-xs-offset-3{margin-left:25%}.col-xs-offset-2{margin-left:16.66666667%}.col-xs-offset-1{margin-left:8.33333333%}.col-xs-offse
t-0{margin-left:0}@media(min-width:768px){.col-sm-1,.col-sm-2,.col-sm-3,.col-sm-4,.col-sm-5,.col-sm-6,.col-sm-7,.col-sm-8,.col-sm-9,.col-sm-10,.col-sm-11,.col-sm-12{float:left}.col-sm-12{width:100%}.col-sm-11{width:91.66666667%}.col-sm-10{width:83.33333333%}.col-sm-9{width:75%}.col-sm-8{width:66.66666667%}.col-sm-7{width:58.33333333%}.col-sm-6{width:50%}.col-sm-5{width:41.66666667%}.col-sm-4{width:33.33333333%}.col-sm-3{width:25%}.col-sm-2{width:16.66666667%}.col-sm-1{width:8.33333333%}.col-sm-pull-12{right:100%}.col-sm-pull-11{right:91.66666667%}.col-sm-pull-10{right:83.33333333%}.col-sm-pull-9{right:75%}.col-sm-pull-8{right:66.66666667%}.col-sm-pull-7{right:58.33333333%}.col-sm-pull-6{right:50%}.col-sm-pull-5{right:41.66666667%}.col-sm-pull-4{right:33.33333333%}.col-sm-pull-3{right:25%}.col-sm-pull-2{right:16.66666667%}.col-sm-pull-1{right:8.33333333%}.col-sm-pull-0{right:auto}.col-sm-push-12{left:100%}.col-sm-push-11{left:91.66666667%}.col-sm-push-10{left:83.33333333%}.col-sm-pus
h-9{left:75%}.col-sm-push-8{left:66.66666667%}.col-sm-push-7{left:58.33333333%}.col-sm-push-6{left:50%}.col-sm-push-5{left:41.66666667%}.col-sm-push-4{left:33.33333333%}.col-sm-push-3{left:25%}.col-sm-push-2{left:16.66666667%}.col-sm-push-1{left:8.33333333%}.col-sm-push-0{left:auto}.col-sm-offset-12{margin-left:100%}.col-sm-offset-11{margin-left:91.66666667%}.col-sm-offset-10{margin-left:83.33333333%}.col-sm-offset-9{margin-left:75%}.col-sm-offset-8{margin-left:66.66666667%}.col-sm-offset-7{margin-left:58.33333333%}.col-sm-offset-6{margin-left:50%}.col-sm-offset-5{margin-left:41.66666667%}.col-sm-offset-4{margin-left:33.33333333%}.col-sm-offset-3{margin-left:25%}.col-sm-offset-2{margin-left:16.66666667%}.col-sm-offset-1{margin-left:8.33333333%}.col-sm-offset-0{margin-left:0}}@media(min-width:992px){.col-md-1,.col-md-2,.col-md-3,.col-md-4,.col-md-5,.col-md-6,.col-md-7,.col-md-8,.col-md-9,.col-md-10,.col-md-11,.col-md-12{float:left}.col-md-12{width:100%}.col-md-11{width:91.66666667%}.
col-md-10{width:83.33333333%}.col-md-9{width:75%}.col-md-8{width:66.66666667%}.col-md-7{width:58.33333333%}.col-md-6{width:50%}.col-md-5{width:41.66666667%}.col-md-4{width:33.33333333%}.col-md-3{width:25%}.col-md-2{width:16.66666667%}.col-md-1{width:8.33333333%}.col-md-pull-12{right:100%}.col-md-pull-11{right:91.66666667%}.col-md-pull-10{right:83.33333333%}.col-md-pull-9{right:75%}.col-md-pull-8{right:66.66666667%}.col-md-pull-7{right:58.33333333%}.col-md-pull-6{right:50%}.col-md-pull-5{right:41.66666667%}.col-md-pull-4{right:33.33333333%}.col-md-pull-3{right:25%}.col-md-pull-2{right:16.66666667%}.col-md-pull-1{right:8.33333333%}.col-md-pull-0{right:auto}.col-md-push-12{left:100%}.col-md-push-11{left:91.66666667%}.col-md-push-10{left:83.33333333%}.col-md-push-9{left:75%}.col-md-push-8{left:66.66666667%}.col-md-push-7{left:58.33333333%}.col-md-push-6{left:50%}.col-md-push-5{left:41.66666667%}.col-md-push-4{left:33.33333333%}.col-md-push-3{left:25%}.col-md-push-2{left:16.66666667%}.co
l-md-push-1{left:8.33333333%}.col-md-push-0{left:auto}.col-md-offset-12{margin-left:100%}.col-md-offset-11{margin-left:91.66666667%}.col-md-offset-10{margin-left:83.33333333%}.col-md-offset-9{margin-left:75%}.col-md-offset-8{margin-left:66.66666667%}.col-md-offset-7{margin-left:58.33333333%}.col-md-offset-6{margin-left:50%}.col-md-offset-5{margin-left:41.66666667%}.col-md-offset-4{margin-left:33.33333333%}.col-md-offset-3{margin-left:25%}.col-md-offset-2{margin-left:16.66666667%}.col-md-offset-1{margin-left:8.33333333%}.col-md-offset-0{margin-left:0}}@media(min-width:1200px){.col-lg-1,.col-lg-2,.col-lg-3,.col-lg-4,.col-lg-5,.col-lg-6,.col-lg-7,.col-lg-8,.col-lg-9,.col-lg-10,.col-lg-11,.col-lg-12{float:left}.col-lg-12{width:100%}.col-lg-11{width:91.66666667%}.col-lg-10{width:83.33333333%}.col-lg-9{width:75%}.col-lg-8{width:66.66666667%}.col-lg-7{width:58.33333333%}.col-lg-6{width:50%}.col-lg-5{width:41.66666667%}.col-lg-4{width:33.33333333%}.col-lg-3{width:25%}.col-lg-2{width:16.6666
6667%}.col-lg-1{width:8.33333333%}.col-lg-pull-12{right:100%}.col-lg-pull-11{right:91.66666667%}.col-lg-pull-10{right:83.33333333%}.col-lg-pull-9{right:75%}.col-lg-pull-8{right:66.66666667%}.col-lg-pull-7{right:58.33333333%}.col-lg-pull-6{right:50%}.col-lg-pull-5{right:41.66666667%}.col-lg-pull-4{right:33.33333333%}.col-lg-pull-3{right:25%}.col-lg-pull-2{right:16.66666667%}.col-lg-pull-1{right:8.33333333%}.col-lg-pull-0{right:auto}.col-lg-push-12{left:100%}.col-lg-push-11{left:91.66666667%}.col-lg-push-10{left:83.33333333%}.col-lg-push-9{left:75%}.col-lg-push-8{left:66.66666667%}.col-lg-push-7{left:58.33333333%}.col-lg-push-6{left:50%}.col-lg-push-5{left:41.66666667%}.col-lg-push-4{left:33.33333333%}.col-lg-push-3{left:25%}.col-lg-push-2{left:16.66666667%}.col-lg-push-1{left:8.33333333%}.col-lg-push-0{left:auto}.col-lg-offset-12{margin-left:100%}.col-lg-offset-11{margin-left:91.66666667%}.col-lg-offset-10{margin-left:83.33333333%}.col-lg-offset-9{margin-left:75%}.col-lg-offset-8{mar
gin-left:66.66666667%}.col-lg-offset-7{margin-left:58.33333333%}.col-lg-offset-6{margin-left:50%}.col-lg-offset-5{margin-left:41.66666667%}.col-lg-offset-4{margin-left:33.33333333%}.col-lg-offset-3{margin-left:25%}.col-lg-offset-2{margin-left:16.66666667%}.col-lg-offset-1{margin-left:8.33333333%}.col-lg-offset-0{margin-left:0}}table{background-color:transparent}caption{padding-top:8px;padding-bottom:8px;color:#777;text-align:left}th{text-align:left}.table{width:100%;max-width:100%;margin-bottom:20px}.table>thead>tr>th,.table>tbody>tr>th,.table>tfoot>tr>th,.table>thead>tr>td,.table>tbody>tr>td,.table>tfoot>tr>td{padding:8px;line-height:1.42857143;vertical-align:top;border-top:1px solid #ddd}.table>thead>tr>th{vertical-align:bottom;border-bottom:2px solid #ddd}.table>caption+thead>tr:first-child>th,.table>colgroup+thead>tr:first-child>th,.table>thead:first-child>tr:first-child>th,.table>caption+thead>tr:first-child>td,.table>colgroup+thead>tr:first-child>td,.table>thead:first-child>tr
:first-child>td{border-top:0}.table>tbody+tbody{border-top:2px solid #ddd}.table .table{background-color:#fff}.table-condensed>thead>tr>th,.table-condensed>tbody>tr>th,.table-condensed>tfoot>tr>th,.table-condensed>thead>tr>td,.table-condensed>tbody>tr>td,.table-condensed>tfoot>tr>td{padding:5px}.table-bordered{border:1px solid #ddd}.table-bordered>thead>tr>th,.table-bordered>tbody>tr>th,.table-bordered>tfoot>tr>th,.table-bordered>thead>tr>td,.table-bordered>tbody>tr>td,.table-bordered>tfoot>tr>td{border:1px solid #ddd}.table-bordered>thead>tr>th,.table-bordered>thead>tr>td{border-bottom-width:2px}.table-striped>tbody>tr:nth-of-type(odd){background-color:#f9f9f9}.table-hover>tbody>tr:hover{background-color:#f5f5f5}table col[class*="col-"]{position:static;float:none;display:table-column}table td[class*="col-"],table th[class*="col-"]{position:static;float:none;display:table-cell}.table>thead>tr>td.active,.table>tbody>tr>td.active,.table>tfoot>tr>td.active,.table>thead>tr>th.active,.ta
ble>tbody>tr>th.active,.table>tfoot>tr>th.active,.table>thead>tr.active>td,.table>tbody>tr.active>td,.table>tfoot>tr.active>td,.table>thead>tr.active>th,.table>tbody>tr.active>th,.table>tfoot>tr.active>th{background-color:#f5f5f5}.table-hover>tbody>tr>td.active:hover,.table-hover>tbody>tr>th.active:hover,.table-hover>tbody>tr.active:hover>td,.table-hover>tbody>tr:hover>.active,.table-hover>tbody>tr.active:hover>th{background-color:#e8e8e8}.table>thead>tr>td.success,.table>tbody>tr>td.success,.table>tfoot>tr>td.success,.table>thead>tr>th.success,.table>tbody>tr>th.success,.table>tfoot>tr>th.success,.table>thead>tr.success>td,.table>tbody>tr.success>td,.table>tfoot>tr.success>td,.table>thead>tr.success>th,.table>tbody>tr.success>th,.table>tfoot>tr.success>th{background-color:#dff0d8}.table-hover>tbody>tr>td.success:hover,.table-hover>tbody>tr>th.success:hover,.table-hover>tbody>tr.success:hover>td,.table-hover>tbody>tr:hover>.success,.table-hover>tbody>tr.success:hover>th{background-c
olor:#d0e9c6}.table>thead>tr>td.info,.table>tbody>tr>td.info,.table>tfoot>tr>td.info,.table>thead>tr>th.info,.table>tbody>tr>th.info,.table>tfoot>tr>th.info,.table>thead>tr.info>td,.table>tbody>tr.info>td,.table>tfoot>tr.info>td,.table>thead>tr.info>th,.table>tbody>tr.info>th,.table>tfoot>tr.info>th{background-color:#d9edf7}.table-hover>tbody>tr>td.info:hover,.table-hover>tbody>tr>th.info:hover,.table-hover>tbody>tr.info:hover>td,.table-hover>tbody>tr:hover>.info,.table-hover>tbody>tr.info:hover>th{background-color:#c4e3f3}.table>thead>tr>td.warning,.table>tbody>tr>td.warning,.table>tfoot>tr>td.warning,.table>thead>tr>th.warning,.table>tbody>tr>th.warning,.table>tfoot>tr>th.warning,.table>thead>tr.warning>td,.table>tbody>tr.warning>td,.table>tfoot>tr.warning>td,.table>thead>tr.warning>th,.table>tbody>tr.warning>th,.table>tfoot>tr.warning>th{background-color:#fcf8e3}.table-hover>tbody>tr>td.warning:hover,.table-hover>tbody>tr>th.warning:hover,.table-hover>tbody>tr.warning:hover>td,.t
able-hover>tbody>tr:hover>.warning,.table-hover>tbody>tr.warning:hover>th{background-color:#faf2cc}.table>thead>tr>td.danger,.table>tbody>tr>td.danger,.table>tfoot>tr>td.danger,.table>thead>tr>th.danger,.table>tbody>tr>th.danger,.table>tfoot>tr>th.danger,.table>thead>tr.danger>td,.table>tbody>tr.danger>td,.table>tfoot>tr.danger>td,.table>thead>tr.danger>th,.table>tbody>tr.danger>th,.table>tfoot>tr.danger>th{background-color:#f2dede}.table-hover>tbody>tr>td.danger:hover,.table-hover>tbody>tr>th.danger:hover,.table-hover>tbody>tr.danger:hover>td,.table-hover>tbody>tr:hover>.danger,.table-hover>tbody>tr.danger:hover>th{background-color:#ebcccc}.table-responsive{overflow-x:auto;min-height:.01%}@media screen and (max-width:767px){.table-responsive{width:100%;margin-bottom:15px;overflow-y:hidden;-ms-overflow-style:-ms-autohiding-scrollbar;border:1px solid #ddd}.table-responsive>.table{margin-bottom:0}.table-responsive>.table>thead>tr>th,.table-responsive>.table>tbody>tr>th,.table-responsi
ve>.table>tfoot>tr>th,.table-responsive>.table>thead>tr>td,.table-responsive>.table>tbody>tr>td,.table-responsive>.table>tfoot>tr>td{white-space:nowrap}.table-responsive>.table-bordered{border:0}.table-responsive>.table-bordered>thead>tr>th:first-child,.table-responsive>.table-bordered>tbody>tr>th:first-child,.table-responsive>.table-bordered>tfoot>tr>th:first-child,.table-responsive>.table-bordered>thead>tr>td:first-child,.table-responsive>.table-bordered>tbody>tr>td:first-child,.table-responsive>.table-bordered>tfoot>tr>td:first-child{border-left:0}.table-responsive>.table-bordered>thead>tr>th:last-child,.table-responsive>.table-bordered>tbody>tr>th:last-child,.table-responsive>.table-bordered>tfoot>tr>th:last-child,.table-responsive>.table-bordered>thead>tr>td:last-child,.table-responsive>.table-bordered>tbody>tr>td:last-child,.table-responsive>.table-bordered>tfoot>tr>td:last-child{border-right:0}.table-responsive>.table-bordered>tbody>tr:last-child>th,.table-responsive>.table-b
ordered>tfoot>tr:last-child>th,.table-responsive>.table-bordered>tbody>tr:last-child>td,.table-responsive>.table-bordered>tfoot>tr:last-child>td{border-bottom:0}}fieldset{padding:0;margin:0;border:0;min-width:0}legend{display:block;width:100%;padding:0;margin-bottom:20px;font-size:21px;line-height:inherit;color:#333;border:0;border-bottom:1px solid #e5e5e5}label{display:inline-block;max-width:100%;margin-bottom:5px;font-weight:bold}input[type="search"]{-webkit-box-sizing:border-box;-moz-box-sizing:border-box;box-sizing:border-box}input[type="radio"],input[type="checkbox"]{margin:4px 0 0;margin-top:1px \9;line-height:normal}input[type="file"]{display:block}input[type="range"]{display:block;width:100%}select[multiple],select[size]{height:auto}input[type="file"]:focus,input[type="radio"]:focus,input[type="checkbox"]:focus{outline:5px auto -webkit-focus-ring-color;outline-offset:-2px}output{display:block;padding-top:7px;font-size:14px;line-height:1.42857143;color:#555}.form-control{disp
lay:block;width:100%;height:34px;padding:6px 12px;font-size:14px;line-height:1.42857143;color:#555;background-color:#fff;background-image:none;border:1px solid #ccc;border-radius:4px;-webkit-box-shadow:inset 0 1px 1px rgba(0,0,0,0.075);box-shadow:inset 0 1px 1px rgba(0,0,0,0.075);-webkit-transition:border-color ease-in-out .15s,box-shadow ease-in-out .15s;-o-transition:border-color ease-in-out .15s,box-shadow ease-in-out .15s;transition:border-color ease-in-out .15s,box-shadow ease-in-out .15s}.form-control:focus{border-color:#d82d4c;outline:0;-webkit-box-shadow:inset 0 1px 1px rgba(0,0,0,.075),0 0 8px rgba(216,45,76,0.6);box-shadow:inset 0 1px 1px rgba(0,0,0,.075),0 0 8px rgba(216,45,76,0.6)}.form-control::-moz-placeholder{color:#999;opacity:1}.form-control:-ms-input-placeholder{color:#999}.form-control::-webkit-input-placeholder{color:#999}.form-control::-ms-expand{border:0;background-color:transparent}.form-control[disabled],.form-control[readonly],fieldset[disabled] .form-contro
l{background-color:#eee;opacity:1}.form-control[disabled],fieldset[disabled] .form-control{cursor:not-allowed}textarea.form-control{height:auto}input[type="search"]{-webkit-appearance:none}@media screen and (-webkit-min-device-pixel-ratio:0){input[type="date"].form-control,input[type="time"].form-control,input[type="datetime-local"].form-control,input[type="month"].form-control{line-height:34px}input[type="date"].input-sm,input[type="time"].input-sm,input[type="datetime-local"].input-sm,input[type="month"].input-sm,.input-group-sm input[type="date"],.input-group-sm input[type="time"],.input-group-sm input[type="datetime-local"],.input-group-sm input[type="month"]{line-height:30px}input[type="date"].input-lg,input[type="time"].input-lg,input[type="datetime-local"].input-lg,input[type="month"].input-lg,.input-group-lg input[type="date"],.input-group-lg input[type="time"],.input-group-lg input[type="datetime-local"],.input-group-lg input[type="month"]{line-height:46px}}.form-group{marg
in-bottom:15px}.radio,.checkbox{position:relative;display:block;margin-top:10px;margin-bottom:10px}.radio label,.checkbox label{min-height:20px;padding-left:20px;margin-bottom:0;font-weight:normal;cursor:pointer}.radio input[type="radio"],.radio-inline input[type="radio"],.checkbox input[type="checkbox"],.checkbox-inline input[type="checkbox"]{position:absolute;margin-left:-20px;margin-top:4px \9}.radio+.radio,.checkbox+.checkbox{margin-top:-5px}.radio-inline,.checkbox-inline{position:relative;display:inline-block;padding-left:20px;margin-bottom:0;vertical-align:middle;font-weight:normal;cursor:pointer}.radio-inline+.radio-inline,.checkbox-inline+.checkbox-inline{margin-top:0;margin-left:10px}input[type="radio"][disabled],input[type="checkbox"][disabled],input[type="radio"].disabled,input[type="checkbox"].disabled,fieldset[disabled] input[type="radio"],fieldset[disabled] input[type="checkbox"]{cursor:not-allowed}.radio-inline.disabled,.checkbox-inline.disabled,fieldset[disabled] .ra
dio-inline,fieldset[disabled] .checkbox-inline{cursor:not-allowed}.radio.disabled label,.checkbox.disabled label,fieldset[disabled] .radio label,fieldset[disabled] .checkbox label{cursor:not-allowed}.form-control-static{padding-top:7px;padding-bottom:7px;margin-bottom:0;min-height:34px}.form-control-static.input-lg,.form-control-static.input-sm{padding-left:0;padding-right:0}.input-sm{height:30px;padding:5px 10px;font-size:12px;line-height:1.5;border-radius:3px}select.input-sm{height:30px;line-height:30px}textarea.input-sm,select[multiple].input-sm{height:auto}.form-group-sm .form-control{height:30px;padding:5px 10px;font-size:12px;line-height:1.5;border-radius:3px}.form-group-sm select.form-control{height:30px;line-height:30px}.form-group-sm textarea.form-control,.form-group-sm select[multiple].form-control{height:auto}.form-group-sm .form-control-static{height:30px;min-height:32px;padding:6px 10px;font-size:12px;line-height:1.5}.input-lg{height:46px;padding:10px 16px;font-size:18p
x;line-height:1.3333333;border-radius:6px}select.input-lg{height:46px;line-height:46px}textarea.input-lg,select[multiple].input-lg{height:auto}.form-group-lg .form-control{height:46px;padding:10px 16px;font-size:18px;line-height:1.3333333;border-radius:6px}.form-group-lg select.form-control{height:46px;line-height:46px}.form-group-lg textarea.form-control,.form-group-lg select[multiple].form-control{height:auto}.form-group-lg .form-control-static{height:46px;min-height:38px;padding:11px 16px;font-size:18px;line-height:1.3333333}.has-feedback{position:relative}.has-feedback .form-control{padding-right:42.5px}.form-control-feedback{position:absolute;top:0;right:0;z-index:2;display:block;width:34px;height:34px;line-height:34px;text-align:center;pointer-events:none}.input-lg+.form-control-feedback,.input-group-lg+.form-control-feedback,.form-group-lg .form-control+.form-control-feedback{width:46px;height:46px;line-height:46px}.input-sm+.form-control-feedback,.input-group-sm+.form-contro
l-feedback,.form-group-sm .form-control+.form-control-feedback{width:30px;height:30px;line-height:30px}.has-success .help-block,.has-success .control-label,.has-success .radio,.has-success .checkbox,.has-success .radio-inline,.has-success .checkbox-inline,.has-success.radio label,.has-success.checkbox label,.has-success.radio-inline label,.has-success.checkbox-inline label{color:#3c763d}.has-success .form-control{border-color:#3c763d;-webkit-box-shadow:inset 0 1px 1px rgba(0,0,0,0.075);box-shadow:inset 0 1px 1px rgba(0,0,0,0.075)}.has-success .form-control:focus{border-color:#2b542c;-webkit-box-shadow:inset 0 1px 1px rgba(0,0,0,0.075),0 0 6px #67b168;box-shadow:inset 0 1px 1px rgba(0,0,0,0.075),0 0 6px #67b168}.has-success .input-group-addon{color:#3c763d;border-color:#3c763d;background-color:#dff0d8}.has-success .form-control-feedback{color:#3c763d}.has-warning .help-block,.has-warning .control-label,.has-warning .radio,.has-warning .checkbox,.has-warning .radio-inline,.has-warning
.checkbox-inline,.has-warning.radio label,.has-warning.checkbox label,.has-warning.radio-inline label,.has-warning.checkbox-inline label{color:#8a6d3b}.has-warning .form-control{border-color:#8a6d3b;-webkit-box-shadow:inset 0 1px 1px rgba(0,0,0,0.075);box-shadow:inset 0 1px 1px rgba(0,0,0,0.075)}.has-warning .form-control:focus{border-color:#66512c;-webkit-box-shadow:inset 0 1px 1px rgba(0,0,0,0.075),0 0 6px #c0a16b;box-shadow:inset 0 1px 1px rgba(0,0,0,0.075),0 0 6px #c0a16b}.has-warning .input-group-addon{color:#8a6d3b;border-color:#8a6d3b;background-color:#fcf8e3}.has-warning .form-control-feedback{color:#8a6d3b}.has-error .help-block,.has-error .control-label,.has-error .radio,.has-error .checkbox,.has-error .radio-inline,.has-error .checkbox-inline,.has-error.radio label,.has-error.checkbox label,.has-error.radio-inline label,.has-error.checkbox-inline label{color:#a94442}.has-error .form-control{border-color:#a94442;-webkit-box-shadow:inset 0 1px 1px rgba(0,0,0,0.075);box-sha
dow:inset 0 1px 1px rgba(0,0,0,0.075)}.has-error .form-control:focus{border-color:#843534;-webkit-box-shadow:inset 0 1px 1px rgba(0,0,0,0.075),0 0 6px #ce8483;box-shadow:inset 0 1px 1px rgba(0,0,0,0.075),0 0 6px #ce8483}.has-error .input-group-addon{color:#a94442;border-color:#a94442;background-color:#f2dede}.has-error .form-control-feedback{color:#a94442}.has-feedback label ~ .form-control-feedback{top:25px}.has-feedback label.sr-only ~ .form-control-feedback{top:0}.help-block{display:block;margin-top:5px;margin-bottom:10px;color:#737373}@media(min-width:768px){.form-inline .form-group{display:inline-block;margin-bottom:0;vertical-align:middle}.form-inline .form-control{display:inline-block;width:auto;vertical-align:middle}.form-inline .form-control-static{display:inline-block}.form-inline .input-group{display:inline-table;vertical-align:middle}.form-inline .input-group .input-group-addon,.form-inline .input-group .input-group-btn,.form-inline .input-group .form-control{width:auto}
.form-inline .input-group>.form-control{width:100%}.form-inline .control-label{margin-bottom:0;vertical-align:middle}.form-inline .radio,.form-inline .checkbox{display:inline-block;margin-top:0;margin-bottom:0;vertical-align:middle}.form-inline .radio label,.form-inline .checkbox label{padding-left:0}.form-inline .radio input[type="radio"],.form-inline .checkbox input[type="checkbox"]{position:relative;margin-left:0}.form-inline .has-feedback .form-control-feedback{top:0}}.form-horizontal .radio,.form-horizontal .checkbox,.form-horizontal .radio-inline,.form-horizontal .checkbox-inline{margin-top:0;margin-bottom:0;padding-top:7px}.form-horizontal .radio,.form-horizontal .checkbox{min-height:27px}.form-horizontal .form-group{margin-left:-15px;margin-right:-15px}@media(min-width:768px){.form-horizontal .control-label{text-align:right;margin-bottom:0;padding-top:7px}}.form-horizontal .has-feedback .form-control-feedback{right:15px}@media(min-width:768px){.form-horizontal .form-group-lg
.control-label{padding-top:11px;font-size:18px}}@media(min-width:768px){.form-horizontal .form-group-sm .control-label{padding-top:6px;font-size:12px}}.btn{display:inline-block;margin-bottom:0;font-weight:normal;text-align:center;vertical-align:middle;touch-action:manipulation;cursor:pointer;background-image:none;border:1px solid transparent;white-space:nowrap;padding:6px 12px;font-size:14px;line-height:1.42857143;border-radius:4px;-webkit-user-select:none;-moz-user-select:none;-ms-user-select:none;user-select:none}.btn:focus,.btn:active:focus,.btn.active:focus,.btn.focus,.btn:active.focus,.btn.active.focus{outline:5px auto -webkit-focus-ring-color;outline-offset:-2px}.btn:hover,.btn:focus,.btn.focus{color:#333;text-decoration:none}.btn:active,.btn.active{outline:0;background-image:none;-webkit-box-shadow:inset 0 3px 5px rgba(0,0,0,0.125);box-shadow:inset 0 3px 5px rgba(0,0,0,0.125)}.btn.disabled,.btn[disabled],fieldset[disabled] .btn{cursor:not-allowed;opacity:.65;filter:alpha(opa
city=65);-webkit-box-shadow:none;box-shadow:none}a.btn.disabled,fieldset[disabled] a.btn{pointer-events:none}.btn-default{color:#333;background-color:#fff;border-color:#ccc}.btn-default:focus,.btn-default.focus{color:#333;background-color:#e6e6e6;border-color:#8c8c8c}.btn-default:hover{color:#333;background-color:#e6e6e6;border-color:#adadad}.btn-default:active,.btn-default.active,.open>.dropdown-toggle.btn-default{color:#333;background-color:#e6e6e6;border-color:#adadad}.btn-default:active:hover,.btn-default.active:hover,.open>.dropdown-toggle.btn-default:hover,.btn-default:active:focus,.btn-default.active:focus,.open>.dropdown-toggle.btn-default:focus,.btn-default:active.focus,.btn-default.active.focus,.open>.dropdown-toggle.btn-default.focus{color:#333;background-color:#d4d4d4;border-color:#8c8c8c}.btn-default:active,.btn-default.active,.open>.dropdown-toggle.btn-default{background-image:none}.btn-default.disabled:hover,.btn-default[disabled]:hover,fieldset[disabled] .btn-default
:hover,.btn-default.disabled:focus,.btn-default[disabled]:focus,fieldset[disabled] .btn-default:focus,.btn-default.disabled.focus,.btn-default[disabled].focus,fieldset[disabled] .btn-default.focus{background-color:#fff;border-color:#ccc}.btn-default .badge{color:#fff;background-color:#333}.btn-primary{color:#fff;background-color:#871e32;border-color:#72192a}.btn-primary:focus,.btn-primary.focus{color:#fff;background-color:#5d1523;border-color:#0a0204}.btn-primary:hover{color:#fff;background-color:#5d1523;border-color:#400e18}.btn-primary:active,.btn-primary.active,.open>.dropdown-toggle.btn-primary{color:#fff;background-color:#5d1523;border-color:#400e18}.btn-primary:active:hover,.btn-primary.active:hover,.open>.dropdown-toggle.btn-primary:hover,.btn-primary:active:focus,.btn-primary.active:focus,.open>.dropdown-toggle.btn-primary:focus,.btn-primary:active.focus,.btn-primary.active.focus,.open>.dropdown-toggle.btn-primary.focus{color:#fff;background-color:#400e18;border-color:#0a020
4}.btn-primary:active,.btn-primary.active,.open>.dropdown-toggle.btn-primary{background-image:none}.btn-primary.disabled:hover,.btn-primary[disabled]:hover,fieldset[disabled] .btn-primary:hover,.btn-primary.disabled:focus,.btn-primary[disabled]:focus,fieldset[disabled] .btn-primary:focus,.btn-primary.disabled.focus,.btn-primary[disabled].focus,fieldset[disabled] .btn-primary.focus{background-color:#871e32;border-color:#72192a}.btn-primary .badge{color:#871e32;background-color:#fff}.btn-success{color:#fff;background-color:#5cb85c;border-color:#4cae4c}.btn-success:focus,.btn-success.focus{color:#fff;background-color:#449d44;border-color:#255625}.btn-success:hover{color:#fff;background-color:#449d44;border-color:#398439}.btn-success:active,.btn-success.active,.open>.dropdown-toggle.btn-success{color:#fff;background-color:#449d44;border-color:#398439}.btn-success:active:hover,.btn-success.active:hover,.open>.dropdown-toggle.btn-success:hover,.btn-success:active:focus,.btn-success.active
:focus,.open>.dropdown-toggle.btn-success:focus,.btn-success:active.focus,.btn-success.active.focus,.open>.dropdown-toggle.btn-success.focus{color:#fff;background-color:#398439;border-color:#255625}.btn-success:active,.btn-success.active,.open>.dropdown-toggle.btn-success{background-image:none}.btn-success.disabled:hover,.btn-success[disabled]:hover,fieldset[disabled] .btn-success:hover,.btn-success.disabled:focus,.btn-success[disabled]:focus,fieldset[disabled] .btn-success:focus,.btn-success.disabled.focus,.btn-success[disabled].focus,fieldset[disabled] .btn-success.focus{background-color:#5cb85c;border-color:#4cae4c}.btn-success .badge{color:#5cb85c;background-color:#fff}.btn-info{color:#fff;background-color:#5bc0de;border-color:#46b8da}.btn-info:focus,.btn-info.focus{color:#fff;background-color:#31b0d5;border-color:#1b6d85}.btn-info:hover{color:#fff;background-color:#31b0d5;border-color:#269abc}.btn-info:active,.btn-info.active,.open>.dropdown-toggle.btn-info{color:#fff;backgroun
d-color:#31b0d5;border-color:#269abc}.btn-info:active:hover,.btn-info.active:hover,.open>.dropdown-toggle.btn-info:hover,.btn-info:active:focus,.btn-info.active:focus,.open>.dropdown-toggle.btn-info:focus,.btn-info:active.focus,.btn-info.active.focus,.open>.dropdown-toggle.btn-info.focus{color:#fff;background-color:#269abc;border-color:#1b6d85}.btn-info:active,.btn-info.active,.open>.dropdown-toggle.btn-info{background-image:none}.btn-info.disabled:hover,.btn-info[disabled]:hover,fieldset[disabled] .btn-info:hover,.btn-info.disabled:focus,.btn-info[disabled]:focus,fieldset[disabled] .btn-info:focus,.btn-info.disabled.focus,.btn-info[disabled].focus,fieldset[disabled] .btn-info.focus{background-color:#5bc0de;border-color:#46b8da}.btn-info .badge{color:#5bc0de;background-color:#fff}.btn-warning{color:#fff;background-color:#f0ad4e;border-color:#eea236}.btn-warning:focus,.btn-warning.focus{color:#fff;background-color:#ec971f;border-color:#985f0d}.btn-warning:hover{color:#fff;background-
color:#ec971f;border-color:#d58512}.btn-warning:active,.btn-warning.active,.open>.dropdown-toggle.btn-warning{color:#fff;background-color:#ec971f;border-color:#d58512}.btn-warning:active:hover,.btn-warning.active:hover,.open>.dropdown-toggle.btn-warning:hover,.btn-warning:active:focus,.btn-warning.active:focus,.open>.dropdown-toggle.btn-warning:focus,.btn-warning:active.focus,.btn-warning.active.focus,.open>.dropdown-toggle.btn-warning.focus{color:#fff;background-color:#d58512;border-color:#985f0d}.btn-warning:active,.btn-warning.active,.open>.dropdown-toggle.btn-warning{background-image:none}.btn-warning.disabled:hover,.btn-warning[disabled]:hover,fieldset[disabled] .btn-warning:hover,.btn-warning.disabled:focus,.btn-warning[disabled]:focus,fieldset[disabled] .btn-warning:focus,.btn-warning.disabled.focus,.btn-warning[disabled].focus,fieldset[disabled] .btn-warning.focus{background-color:#f0ad4e;border-color:#eea236}.btn-warning .badge{color:#f0ad4e;background-color:#fff}.btn-dange
r{color:#fff;background-color:#d9534f;border-color:#d43f3a}.btn-danger:focus,.btn-danger.focus{color:#fff;background-color:#c9302c;border-color:#761c19}.btn-danger:hover{color:#fff;background-color:#c9302c;border-color:#ac2925}.btn-danger:active,.btn-danger.active,.open>.dropdown-toggle.btn-danger{color:#fff;background-color:#c9302c;border-color:#ac2925}.btn-danger:active:hover,.btn-danger.active:hover,.open>.dropdown-toggle.btn-danger:hover,.btn-danger:active:focus,.btn-danger.active:focus,.open>.dropdown-toggle.btn-danger:focus,.btn-danger:active.focus,.btn-danger.active.focus,.open>.dropdown-toggle.btn-danger.focus{color:#fff;background-color:#ac2925;border-color:#761c19}.btn-danger:active,.btn-danger.active,.open>.dropdown-toggle.btn-danger{background-image:none}.btn-danger.disabled:hover,.btn-danger[disabled]:hover,fieldset[disabled] .btn-danger:hover,.btn-danger.disabled:focus,.btn-danger[disabled]:focus,fieldset[disabled] .btn-danger:focus,.btn-danger.disabled.focus,.btn-dang
er[disabled].focus,fieldset[disabled] .btn-danger.focus{background-color:#d9534f;border-color:#d43f3a}.btn-danger .badge{color:#d9534f;background-color:#fff}.btn-link{color:#871e32;font-weight:normal;border-radius:0}.btn-link,.btn-link:active,.btn-link.active,.btn-link[disabled],fieldset[disabled] .btn-link{background-color:transparent;-webkit-box-shadow:none;box-shadow:none}.btn-link,.btn-link:hover,.btn-link:focus,.btn-link:active{border-color:transparent}.btn-link:hover,.btn-link:focus{color:#48101b;text-decoration:underline;background-color:transparent}.btn-link[disabled]:hover,fieldset[disabled] .btn-link:hover,.btn-link[disabled]:focus,fieldset[disabled] .btn-link:focus{color:#777;text-decoration:none}.btn-lg,.btn-group-lg>.btn{padding:10px 16px;font-size:18px;line-height:1.3333333;border-radius:6px}.btn-sm,.btn-group-sm>.btn{padding:5px 10px;font-size:12px;line-height:1.5;border-radius:3px}.btn-xs,.btn-group-xs>.btn{padding:1px 5px;font-size:12px;line-height:1.5;border-radius
:3px}.btn-block{display:block;width:100%}.btn-block+.btn-block{margin-top:5px}input[type="submit"].btn-block,input[type="reset"].btn-block,input[type="button"].btn-block{width:100%}.fade{opacity:0;-webkit-transition:opacity .15s linear;-o-transition:opacity .15s linear;transition:opacity .15s linear}.fade.in{opacity:1}.collapse{display:none}.collapse.in{display:block}tr.collapse.in{display:table-row}tbody.collapse.in{display:table-row-group}.collapsing{position:relative;height:0;overflow:hidden;-webkit-transition-property:height,visibility;transition-property:height,visibility;-webkit-transition-duration:.35s;transition-duration:.35s;-webkit-transition-timing-function:ease;transition-timing-function:ease}.caret{display:inline-block;width:0;height:0;margin-left:2px;vertical-align:middle;border-top:4px dashed;border-top:4px solid \9;border-right:4px solid transparent;border-left:4px solid transparent}.dropup,.dropdown{position:relative}.dropdown-toggle:focus{outline:0}.dropdown-menu{p
osition:absolute;top:100%;left:0;z-index:1000;display:none;float:left;min-width:160px;padding:5px 0;margin:2px 0 0;list-style:none;font-size:14px;text-align:left;background-color:#fff;border:1px solid #ccc;border:1px solid rgba(0,0,0,0.15);border-radius:4px;-webkit-box-shadow:0 6px 12px rgba(0,0,0,0.175);box-shadow:0 6px 12px rgba(0,0,0,0.175);background-clip:padding-box}.dropdown-menu.pull-right{right:0;left:auto}.dropdown-menu .divider{height:1px;margin:9px 0;overflow:hidden;background-color:#e5e5e5}.dropdown-menu>li>a{display:block;padding:3px 20px;clear:both;font-weight:normal;line-height:1.42857143;color:#333;white-space:nowrap}.dropdown-menu>li>a:hover,.dropdown-menu>li>a:focus{text-decoration:none;color:#fff;background-color:#871d33}.dropdown-menu>.active>a,.dropdown-menu>.active>a:hover,.dropdown-menu>.active>a:focus{color:#fff;text-decoration:none;outline:0;background-color:#871e32}.dropdown-menu>.disabled>a,.dropdown-menu>.disabled>a:hover,.dropdown-menu>.disabled>a:focus{
color:#777}.dropdown-menu>.disabled>a:hover,.dropdown-menu>.disabled>a:focus{text-decoration:none;background-color:transparent;background-image:none;filter:progid:DXImageTransform.Microsoft.gradient(enabled = false);cursor:not-allowed}.open>.dropdown-menu{display:block}.open>a{outline:0}.dropdown-menu-right{left:auto;right:0}.dropdown-menu-left{left:0;right:auto}.dropdown-header{display:block;padding:3px 20px;font-size:12px;line-height:1.42857143;color:#777;white-space:nowrap}.dropdown-backdrop{position:fixed;left:0;right:0;bottom:0;top:0;z-index:990}.pull-right>.dropdown-menu{right:0;left:auto}.dropup .caret,.navbar-fixed-bottom .dropdown .caret{border-top:0;border-bottom:4px dashed;border-bottom:4px solid \9;content:""}.dropup .dropdown-menu,.navbar-fixed-bottom .dropdown .dropdown-menu{top:auto;bottom:100%;margin-bottom:2px}@media(min-width:768px){.navbar-right .dropdown-menu{left:auto;right:0}.navbar-right .dropdown-menu-left{left:0;right:auto}}.btn-group,.btn-group-vertical{pos
ition:relative;display:inline-block;vertical-align:middle}.btn-group>.btn,.btn-group-vertical>.btn{position:relative;float:left}.btn-group>.btn:hover,.btn-group-vertical>.btn:hover,.btn-group>.btn:focus,.btn-group-vertical>.btn:focus,.btn-group>.btn:active,.btn-group-vertical>.btn:active,.btn-group>.btn.active,.btn-group-vertical>.btn.active{z-index:2}.btn-group .btn+.btn,.btn-group .btn+.btn-group,.btn-group .btn-group+.btn,.btn-group .btn-group+.btn-group{margin-left:-1px}.btn-toolbar{margin-left:-5px}.btn-toolbar .btn,.btn-toolbar .btn-group,.btn-toolbar .input-group{float:left}.btn-toolbar>.btn,.btn-toolbar>.btn-group,.btn-toolbar>.input-group{margin-left:5px}.btn-group>.btn:not(:first-child):not(:last-child):not(.dropdown-toggle){border-radius:0}.btn-group>.btn:first-child{margin-left:0}.btn-group>.btn:first-child:not(:last-child):not(.dropdown-toggle){border-bottom-right-radius:0;border-top-right-radius:0}.btn-group>.btn:last-child:not(:first-child),.btn-group>.dropdown-toggle
:not(:first-child){border-bottom-left-radius:0;border-top-left-radius:0}.btn-group>.btn-group{float:left}.btn-group>.btn-group:not(:first-child):not(:last-child)>.btn{border-radius:0}.btn-group>.btn-group:first-child:not(:last-child)>.btn:last-child,.btn-group>.btn-group:first-child:not(:last-child)>.dropdown-toggle{border-bottom-right-radius:0;border-top-right-radius:0}.btn-group>.btn-group:last-child:not(:first-child)>.btn:first-child{border-bottom-left-radius:0;border-top-left-radius:0}.btn-group .dropdown-toggle:active,.btn-group.open .dropdown-toggle{outline:0}.btn-group>.btn+.dropdown-toggle{padding-left:8px;padding-right:8px}.btn-group>.btn-lg+.dropdown-toggle{padding-left:12px;padding-right:12px}.btn-group.open .dropdown-toggle{-webkit-box-shadow:inset 0 3px 5px rgba(0,0,0,0.125);box-shadow:inset 0 3px 5px rgba(0,0,0,0.125)}.btn-group.open .dropdown-toggle.btn-link{-webkit-box-shadow:none;box-shadow:none}.btn .caret{margin-left:0}.btn-lg .caret{border-width:5px 5px 0;border-
bottom-width:0}.dropup .btn-lg .caret{border-width:0 5px 5px}.btn-group-vertical>.btn,.btn-group-vertical>.btn-group,.btn-group-vertical>.btn-group>.btn{display:block;float:none;width:100%;max-width:100%}.btn-group-vertical>.btn-group>.btn{float:none}.btn-group-vertical>.btn+.btn,.btn-group-vertical>.btn+.btn-group,.btn-group-vertical>.btn-group+.btn,.btn-group-vertical>.btn-group+.btn-group{margin-top:-1px;margin-left:0}.btn-group-vertical>.btn:not(:first-child):not(:last-child){border-radius:0}.btn-group-vertical>.btn:first-child:not(:last-child){border-top-right-radius:4px;border-top-left-radius:4px;border-bottom-right-radius:0;border-bottom-left-radius:0}.btn-group-vertical>.btn:last-child:not(:first-child){border-top-right-radius:0;border-top-left-radius:0;border-bottom-right-radius:4px;border-bottom-left-radius:4px}.btn-group-vertical>.btn-group:not(:first-child):not(:last-child)>.btn{border-radius:0}.btn-group-vertical>.btn-group:first-child:not(:last-child)>.btn:last-child,.
btn-group-vertical>.btn-group:first-child:not(:last-child)>.dropdown-toggle{border-bottom-right-radius:0;border-bottom-left-radius:0}.btn-group-vertical>.btn-group:last-child:not(:first-child)>.btn:first-child{border-top-right-radius:0;border-top-left-radius:0}.btn-group-justified{display:table;width:100%;table-layout:fixed;border-collapse:separate}.btn-group-justified>.btn,.btn-group-justified>.btn-group{float:none;display:table-cell;width:1%}.btn-group-justified>.btn-group .btn{width:100%}.btn-group-justified>.btn-group .dropdown-menu{left:auto}[data-toggle="buttons"]>.btn input[type="radio"],[data-toggle="buttons"]>.btn-group>.btn input[type="radio"],[data-toggle="buttons"]>.btn input[type="checkbox"],[data-toggle="buttons"]>.btn-group>.btn input[type="checkbox"]{position:absolute;clip:rect(0,0,0,0);pointer-events:none}.input-group{position:relative;display:table;border-collapse:separate}.input-group[class*="col-"]{float:none;padding-left:0;padding-right:0}.input-group .form-cont
rol{position:relative;z-index:2;float:left;width:100%;margin-bottom:0}.input-group .form-control:focus{z-index:3}.input-group-lg>.form-control,.input-group-lg>.input-group-addon,.input-group-lg>.input-group-btn>.btn{height:46px;padding:10px 16px;font-size:18px;line-height:1.3333333;border-radius:6px}select.input-group-lg>.form-control,select.input-group-lg>.input-group-addon,select.input-group-lg>.input-group-btn>.btn{height:46px;line-height:46px}textarea.input-group-lg>.form-control,textarea.input-group-lg>.input-group-addon,textarea.input-group-lg>.input-group-btn>.btn,select[multiple].input-group-lg>.form-control,select[multiple].input-group-lg>.input-group-addon,select[multiple].input-group-lg>.input-group-btn>.btn{height:auto}.input-group-sm>.form-control,.input-group-sm>.input-group-addon,.input-group-sm>.input-group-btn>.btn{height:30px;padding:5px 10px;font-size:12px;line-height:1.5;border-radius:3px}select.input-group-sm>.form-control,select.input-group-sm>.input-group-addo
n,select.input-group-sm>.input-group-btn>.btn{height:30px;line-height:30px}textarea.input-group-sm>.form-control,textarea.input-group-sm>.input-group-addon,textarea.input-group-sm>.input-group-btn>.btn,select[multiple].input-group-sm>.form-control,select[multiple].input-group-sm>.input-group-addon,select[multiple].input-group-sm>.input-group-btn>.btn{height:auto}.input-group-addon,.input-group-btn,.input-group .form-control{display:table-cell}.input-group-addon:not(:first-child):not(:last-child),.input-group-btn:not(:first-child):not(:last-child),.input-group .form-control:not(:first-child):not(:last-child){border-radius:0}.input-group-addon,.input-group-btn{width:1%;white-space:nowrap;vertical-align:middle}.input-group-addon{padding:6px 12px;font-size:14px;font-weight:normal;line-height:1;color:#555;text-align:center;background-color:#eee;border:1px solid #ccc;border-radius:4px}.input-group-addon.input-sm{padding:5px 10px;font-size:12px;border-radius:3px}.input-group-addon.input-lg
{padding:10px 16px;font-size:18px;border-radius:6px}.input-group-addon input[type="radio"],.input-group-addon input[type="checkbox"]{margin-top:0}.input-group .form-control:first-child,.input-group-addon:first-child,.input-group-btn:first-child>.btn,.input-group-btn:first-child>.btn-group>.btn,.input-group-btn:first-child>.dropdown-toggle,.input-group-btn:last-child>.btn:not(:last-child):not(.dropdown-toggle),.input-group-btn:last-child>.btn-group:not(:last-child)>.btn{border-bottom-right-radius:0;border-top-right-radius:0}.input-group-addon:first-child{border-right:0}.input-group .form-control:last-child,.input-group-addon:last-child,.input-group-btn:last-child>.btn,.input-group-btn:last-child>.btn-group>.btn,.input-group-btn:last-child>.dropdown-toggle,.input-group-btn:first-child>.btn:not(:first-child),.input-group-btn:first-child>.btn-group:not(:first-child)>.btn{border-bottom-left-radius:0;border-top-left-radius:0}.input-group-addon:last-child{border-left:0}.input-group-btn{pos
ition:relative;font-size:0;white-space:nowrap}.input-group-btn>.btn{position:relative}.input-group-btn>.btn+.btn{margin-left:-1px}.input-group-btn>.btn:hover,.input-group-btn>.btn:focus,.input-group-btn>.btn:active{z-index:2}.input-group-btn:first-child>.btn,.input-group-btn:first-child>.btn-group{margin-right:-1px}.input-group-btn:last-child>.btn,.input-group-btn:last-child>.btn-group{z-index:2;margin-left:-1px}.nav{margin-bottom:0;padding-left:0;list-style:none}.nav>li{position:relative;display:block}.nav>li>a{position:relative;display:block;padding:10px 15px}.nav>li>a:hover,.nav>li>a:focus{text-decoration:none;background-color:#eee}.nav>li.disabled>a{color:#777}.nav>li.disabled>a:hover,.nav>li.disabled>a:focus{color:#777;text-decoration:none;background-color:transparent;cursor:not-allowed}.nav .open>a,.nav .open>a:hover,.nav .open>a:focus{background-color:#eee;border-color:#871e32}.nav .nav-divider{height:1px;margin:9px 0;overflow:hidden;background-color:#e5e5e5}.nav>li>a>img{max
-width:none}.nav-tabs{border-bottom:1px solid #ddd}.nav-tabs>li{float:left;margin-bottom:-1px}.nav-tabs>li>a{margin-right:2px;line-height:1.42857143;border:1px solid transparent;border-radius:4px 4px 0 0}.nav-tabs>li>a:hover{border-color:#eee #eeeeee #ddd}.nav-tabs>li.active>a,.nav-tabs>li.active>a:hover,.nav-tabs>li.active>a:focus{color:#555;background-color:#fff;border:1px solid #ddd;border-bottom-color:transparent;cursor:default}.nav-tabs.nav-justified{width:100%;border-bottom:0}.nav-tabs.nav-justified>li{float:none}.nav-tabs.nav-justified>li>a{text-align:center;margin-bottom:5px}.nav-tabs.nav-justified>.dropdown .dropdown-menu{top:auto;left:auto}@media(min-width:768px){.nav-tabs.nav-justified>li{display:table-cell;width:1%}.nav-tabs.nav-justified>li>a{margin-bottom:0}}.nav-tabs.nav-justified>li>a{margin-right:0;border-radius:4px}.nav-tabs.nav-justified>.active>a,.nav-tabs.nav-justified>.active>a:hover,.nav-tabs.nav-justified>.active>a:focus{border:1px solid #ddd}@media(min-width
:768px){.nav-tabs.nav-justified>li>a{border-bottom:1px solid #ddd;border-radius:4px 4px 0 0}.nav-tabs.nav-justified>.active>a,.nav-tabs.nav-justified>.active>a:hover,.nav-tabs.nav-justified>.active>a:focus{border-bottom-color:#fff}}.nav-pills>li{float:left}.nav-pills>li>a{border-radius:4px}.nav-pills>li+li{margin-left:2px}.nav-pills>li.active>a,.nav-pills>li.active>a:hover,.nav-pills>li.active>a:focus{color:#fff;background-color:#871e32}.nav-stacked>li{float:none}.nav-stacked>li+li{margin-top:2px;margin-left:0}.nav-justified{width:100%}.nav-justified>li{float:none}.nav-justified>li>a{text-align:center;margin-bottom:5px}.nav-justified>.dropdown .dropdown-menu{top:auto;left:auto}@media(min-width:768px){.nav-justified>li{display:table-cell;width:1%}.nav-justified>li>a{margin-bottom:0}}.nav-tabs-justified{border-bottom:0}.nav-tabs-justified>li>a{margin-right:0;border-radius:4px}.nav-tabs-justified>.active>a,.nav-tabs-justified>.active>a:hover,.nav-tabs-justified>.active>a:focus{border:1
px solid #ddd}@media(min-width:768px){.nav-tabs-justified>li>a{border-bottom:1px solid #ddd;border-radius:4px 4px 0 0}.nav-tabs-justified>.active>a,.nav-tabs-justified>.active>a:hover,.nav-tabs-justified>.active>a:focus{border-bottom-color:#fff}}.tab-content>.tab-pane{display:none}.tab-content>.active{display:block}.nav-tabs .dropdown-menu{margin-top:-1px;border-top-right-radius:0;border-top-left-radius:0}.navbar{position:relative;min-height:50px;margin-bottom:20px;border:1px solid transparent}@media(min-width:768px){.navbar{border-radius:4px}}@media(min-width:768px){.navbar-header{float:left}}.navbar-collapse{overflow-x:visible;padding-right:15px;padding-left:15px;border-top:1px solid transparent;box-shadow:inset 0 1px 0 rgba(255,255,255,0.1);-webkit-overflow-scrolling:touch}.navbar-collapse.in{overflow-y:auto}@media(min-width:768px){.navbar-collapse{width:auto;border-top:0;box-shadow:none}.navbar-collapse.collapse{display:block!important;height:auto!important;padding-bottom:0;over
flow:visible!important}.navbar-collapse.in{overflow-y:visible}.navbar-fixed-top .navbar-collapse,.navbar-static-top .navbar-collapse,.navbar-fixed-bottom .navbar-collapse{padding-left:0;padding-right:0}}.navbar-fixed-top .navbar-collapse,.navbar-fixed-bottom .navbar-collapse{max-height:340px}@media(max-device-width:480px) and (orientation:landscape){.navbar-fixed-top .navbar-collapse,.navbar-fixed-bottom .navbar-collapse{max-height:200px}}.container>.navbar-header,.container-fluid>.navbar-header,.container>.navbar-collapse,.container-fluid>.navbar-collapse{margin-right:-15px;margin-left:-15px}@media(min-width:768px){.container>.navbar-header,.container-fluid>.navbar-header,.container>.navbar-collapse,.container-fluid>.navbar-collapse{margin-right:0;margin-left:0}}.navbar-static-top{z-index:1000;border-width:0 0 1px}@media(min-width:768px){.navbar-static-top{border-radius:0}}.navbar-fixed-top,.navbar-fixed-bottom{position:fixed;right:0;left:0;z-index:1030}@media(min-width:768px){.nav
bar-fixed-top,.navbar-fixed-bottom{border-radius:0}}.navbar-fixed-top{top:0;border-width:0 0 1px}.navbar-fixed-bottom{bottom:0;margin-bottom:0;border-width:1px 0 0}.navbar-brand{float:left;padding:15px 15px;font-size:18px;line-height:20px;height:50px}.navbar-brand:hover,.navbar-brand:focus{text-decoration:none}.navbar-brand>img{display:block}@media(min-width:768px){.navbar>.container .navbar-brand,.navbar>.container-fluid .navbar-brand{margin-left:-15px}}.navbar-toggle{position:relative;float:right;margin-right:15px;padding:9px 10px;margin-top:8px;margin-bottom:8px;background-color:transparent;background-image:none;border:1px solid transparent;border-radius:4px}.navbar-toggle:focus{outline:0}.navbar-toggle .icon-bar{display:block;width:22px;height:2px;border-radius:1px}.navbar-toggle .icon-bar+.icon-bar{margin-top:4px}@media(min-width:768px){.navbar-toggle{display:none}}.navbar-nav{margin:7.5px -15px}.navbar-nav>li>a{padding-top:10px;padding-bottom:10px;line-height:20px}@media(max-w
idth:767px){.navbar-nav .open .dropdown-menu{position:static;float:none;width:auto;margin-top:0;background-color:transparent;border:0;box-shadow:none}.navbar-nav .open .dropdown-menu>li>a,.navbar-nav .open .dropdown-menu .dropdown-header{padding:5px 15px 5px 25px}.navbar-nav .open .dropdown-menu>li>a{line-height:20px}.navbar-nav .open .dropdown-menu>li>a:hover,.navbar-nav .open .dropdown-menu>li>a:focus{background-image:none}}@media(min-width:768px){.navbar-nav{float:left;margin:0}.navbar-nav>li{float:left}.navbar-nav>li>a{padding-top:15px;padding-bottom:15px}}.navbar-form{margin-left:-15px;margin-right:-15px;padding:10px 15px;border-top:1px solid transparent;border-bottom:1px solid transparent;-webkit-box-shadow:inset 0 1px 0 rgba(255,255,255,0.1),0 1px 0 rgba(255,255,255,0.1);box-shadow:inset 0 1px 0 rgba(255,255,255,0.1),0 1px 0 rgba(255,255,255,0.1);margin-top:8px;margin-bottom:8px}@media(min-width:768px){.navbar-form .form-group{display:inline-block;margin-bottom:0;vertical-ali
gn:middle}.navbar-form .form-control{display:inline-block;width:auto;vertical-align:middle}.navbar-form .form-control-static{display:inline-block}.navbar-form .input-group{display:inline-table;vertical-align:middle}.navbar-form .input-group .input-group-addon,.navbar-form .input-group .input-group-btn,.navbar-form .input-group .form-control{width:auto}.navbar-form .input-group>.form-control{width:100%}.navbar-form .control-label{margin-bottom:0;vertical-align:middle}.navbar-form .radio,.navbar-form .checkbox{display:inline-block;margin-top:0;margin-bottom:0;vertical-align:middle}.navbar-form .radio label,.navbar-form .checkbox label{padding-left:0}.navbar-form .radio input[type="radio"],.navbar-form .checkbox input[type="checkbox"]{position:relative;margin-left:0}.navbar-form .has-feedback .form-control-feedback{top:0}}@media(max-width:767px){.navbar-form .form-group{margin-bottom:5px}.navbar-form .form-group:last-child{margin-bottom:0}}@media(min-width:768px){.navbar-form{width:aut
o;border:0;margin-left:0;margin-right:0;padding-top:0;padding-bottom:0;-webkit-box-shadow:none;box-shadow:none}}.navbar-nav>li>.dropdown-menu{margin-top:0;border-top-right-radius:0;border-top-left-radius:0}.navbar-fixed-bottom .navbar-nav>li>.dropdown-menu{margin-bottom:0;border-top-right-radius:4px;border-top-left-radius:4px;border-bottom-right-radius:0;border-bottom-left-radius:0}.navbar-btn{margin-top:8px;margin-bottom:8px}.navbar-btn.btn-sm{margin-top:10px;margin-bottom:10px}.navbar-btn.btn-xs{margin-top:14px;margin-bottom:14px}.navbar-text{margin-top:15px;margin-bottom:15px}@media(min-width:768px){.navbar-text{float:left;margin-left:15px;margin-right:15px}}@media(min-width:768px){.navbar-left{float:left!important}.navbar-right{float:right!important;margin-right:-15px}.navbar-right ~ .navbar-right{margin-right:0}}.navbar-default{background-color:#f8f8f8;border-color:#e7e7e7}.navbar-default .navbar-brand{color:#777}.navbar-default .navbar-brand:hover,.navbar-default .navbar-brand
:focus{color:#5e5e5e;background-color:transparent}.navbar-default .navbar-text{color:#777}.navbar-default .navbar-nav>li>a{color:#777}.navbar-default .navbar-nav>li>a:hover,.navbar-default .navbar-nav>li>a:focus{color:#333;background-color:transparent}.navbar-default .navbar-nav>.active>a,.navbar-default .navbar-nav>.active>a:hover,.navbar-default .navbar-nav>.active>a:focus{color:#555;background-color:#e7e7e7}.navbar-default .navbar-nav>.disabled>a,.navbar-default .navbar-nav>.disabled>a:hover,.navbar-default .navbar-nav>.disabled>a:focus{color:#ccc;background-color:transparent}.navbar-default .navbar-toggle{border-color:#ddd}.navbar-default .navbar-toggle:hover,.navbar-default .navbar-toggle:focus{background-color:#ddd}.navbar-default .navbar-toggle .icon-bar{background-color:#888}.navbar-default .navbar-collapse,.navbar-default .navbar-form{border-color:#e7e7e7}.navbar-default .navbar-nav>.open>a,.navbar-default .navbar-nav>.open>a:hover,.navbar-default .navbar-nav>.open>a:focus{
background-color:#e7e7e7;color:#555}@media(max-width:767px){.navbar-default .navbar-nav .open .dropdown-menu>li>a{color:#777}.navbar-default .navbar-nav .open .dropdown-menu>li>a:hover,.navbar-default .navbar-nav .open .dropdown-menu>li>a:focus{color:#333;background-color:transparent}.navbar-default .navbar-nav .open .dropdown-menu>.active>a,.navbar-default .navbar-nav .open .dropdown-menu>.active>a:hover,.navbar-default .navbar-nav .open .dropdown-menu>.active>a:focus{color:#555;background-color:#e7e7e7}.navbar-default .navbar-nav .open .dropdown-menu>.disabled>a,.navbar-default .navbar-nav .open .dropdown-menu>.disabled>a:hover,.navbar-default .navbar-nav .open .dropdown-menu>.disabled>a:focus{color:#ccc;background-color:transparent}}.navbar-default .navbar-link{color:#777}.navbar-default .navbar-link:hover{color:#333}.navbar-default .btn-link{color:#777}.navbar-default .btn-link:hover,.navbar-default .btn-link:focus{color:#333}.navbar-default .btn-link[disabled]:hover,fieldset[di
sabled] .navbar-default .btn-link:hover,.navbar-default .btn-link[disabled]:focus,fieldset[disabled] .navbar-default .btn-link:focus{color:#ccc}.navbar-inverse{background-color:#470f1b;border-color:#1d060b}.navbar-inverse .navbar-brand{color:#d0d0d0}.navbar-inverse .navbar-brand:hover,.navbar-inverse .navbar-brand:focus{color:#fff;background-color:transparent}.navbar-inverse .navbar-text{color:#9d9d9d}.navbar-inverse .navbar-nav>li>a{color:#d0d0d0}.navbar-inverse .navbar-nav>li>a:hover,.navbar-inverse .navbar-nav>li>a:focus{color:#fff;background-color:transparent}.navbar-inverse .navbar-nav>.active>a,.navbar-inverse .navbar-nav>.active>a:hover,.navbar-inverse .navbar-nav>.active>a:focus{color:#fff;background-color:#1d060b}.navbar-inverse .navbar-nav>.disabled>a,.navbar-inverse .navbar-nav>.disabled>a:hover,.navbar-inverse .navbar-nav>.disabled>a:focus{color:#444;background-color:transparent}.navbar-inverse .navbar-toggle{border-color:#333}.navbar-inverse .navbar-toggle:hover,.navbar
-inverse .navbar-toggle:focus{background-color:#333}.navbar-inverse .navbar-toggle .icon-bar{background-color:#fff}.navbar-inverse .navbar-collapse,.navbar-inverse .navbar-form{border-color:#2a0910}.navbar-inverse .navbar-nav>.open>a,.navbar-inverse .navbar-nav>.open>a:hover,.navbar-inverse .navbar-nav>.open>a:focus{background-color:#1d060b;color:#fff}@media(max-width:767px){.navbar-inverse .navbar-nav .open .dropdown-menu>.dropdown-header{border-color:#1d060b}.navbar-inverse .navbar-nav .open .dropdown-menu .divider{background-color:#1d060b}.navbar-inverse .navbar-nav .open .dropdown-menu>li>a{color:#d0d0d0}.navbar-inverse .navbar-nav .open .dropdown-menu>li>a:hover,.navbar-inverse .navbar-nav .open .dropdown-menu>li>a:focus{color:#fff;background-color:transparent}.navbar-inverse .navbar-nav .open .dropdown-menu>.active>a,.navbar-inverse .navbar-nav .open .dropdown-menu>.active>a:hover,.navbar-inverse .navbar-nav .open .dropdown-menu>.active>a:focus{color:#fff;background-color:#1d0
60b}.navbar-inverse .navbar-nav .open .dropdown-menu>.disabled>a,.navbar-inverse .navbar-nav .open .dropdown-menu>.disabled>a:hover,.navbar-inverse .navbar-nav .open .dropdown-menu>.disabled>a:focus{color:#444;background-color:transparent}}.navbar-inverse .navbar-link{color:#d0d0d0}.navbar-inverse .navbar-link:hover{color:#fff}.navbar-inverse .btn-link{color:#d0d0d0}.navbar-inverse .btn-link:hover,.navbar-inverse .btn-link:focus{color:#fff}.navbar-inverse .btn-link[disabled]:hover,fieldset[disabled] .navbar-inverse .btn-link:hover,.navbar-inverse .btn-link[disabled]:focus,fieldset[disabled] .navbar-inverse .btn-link:focus{color:#444}.breadcrumb{padding:8px 15px;margin-bottom:20px;list-style:none;background-color:#f5f5f5;border-radius:4px}.breadcrumb>li{display:inline-block}.breadcrumb>li+li:before{content:"/\00a0";padding:0 5px;color:#ccc}.breadcrumb>.active{color:#777}.pagination{display:inline-block;padding-left:0;margin:20px 0;border-radius:4px}.pagination>li{display:inline}.pagi
nation>li>a,.pagination>li>span{position:relative;float:left;padding:6px 12px;line-height:1.42857143;text-decoration:none;color:#871e32;background-color:#fff;border:1px solid #ddd;margin-left:-1px}.pagination>li:first-child>a,.pagination>li:first-child>span{margin-left:0;border-bottom-left-radius:4px;border-top-left-radius:4px}.pagination>li:last-child>a,.pagination>li:last-child>span{border-bottom-right-radius:4px;border-top-right-radius:4px}.pagination>li>a:hover,.pagination>li>span:hover,.pagination>li>a:focus,.pagination>li>span:focus{z-index:2;color:#48101b;background-color:#eee;border-color:#ddd}.pagination>.active>a,.pagination>.active>span,.pagination>.active>a:hover,.pagination>.active>span:hover,.pagination>.active>a:focus,.pagination>.active>span:focus{z-index:3;color:#fff;background-color:#871e32;border-color:#871e32;cursor:default}.pagination>.disabled>span,.pagination>.disabled>span:hover,.pagination>.disabled>span:focus,.pagination>.disabled>a,.pagination>.disabled>a:
hover,.pagination>.disabled>a:focus{color:#777;background-color:#fff;border-color:#ddd;cursor:not-allowed}.pagination-lg>li>a,.pagination-lg>li>span{padding:10px 16px;font-size:18px;line-height:1.3333333}.pagination-lg>li:first-child>a,.pagination-lg>li:first-child>span{border-bottom-left-radius:6px;border-top-left-radius:6px}.pagination-lg>li:last-child>a,.pagination-lg>li:last-child>span{border-bottom-right-radius:6px;border-top-right-radius:6px}.pagination-sm>li>a,.pagination-sm>li>span{padding:5px 10px;font-size:12px;line-height:1.5}.pagination-sm>li:first-child>a,.pagination-sm>li:first-child>span{border-bottom-left-radius:3px;border-top-left-radius:3px}.pagination-sm>li:last-child>a,.pagination-sm>li:last-child>span{border-bottom-right-radius:3px;border-top-right-radius:3px}.pager{padding-left:0;margin:20px 0;list-style:none;text-align:center}.pager li{display:inline}.pager li>a,.pager li>span{display:inline-block;padding:5px 14px;background-color:#fff;border:1px solid #ddd;bo
rder-radius:15px}.pager li>a:hover,.pager li>a:focus{text-decoration:none;background-color:#eee}.pager .next>a,.pager .next>span{float:right}.pager .previous>a,.pager .previous>span{float:left}.pager .disabled>a,.pager .disabled>a:hover,.pager .disabled>a:focus,.pager .disabled>span{color:#777;background-color:#fff;cursor:not-allowed}.label{display:inline;padding:.2em .6em .3em;font-size:75%;font-weight:bold;line-height:1;color:#fff;text-align:center;white-space:nowrap;vertical-align:baseline;border-radius:.25em}a.label:hover,a.label:focus{color:#fff;text-decoration:none;cursor:pointer}.label:empty{display:none}.btn .label{position:relative;top:-1px}.label-default{background-color:#777}.label-default[href]:hover,.label-default[href]:focus{background-color:#5e5e5e}.label-primary{background-color:#871e32}.label-primary[href]:hover,.label-primary[href]:focus{background-color:#5d1523}.label-success{background-color:#5cb85c}.label-success[href]:hover,.label-success[href]:focus{background
-color:#449d44}.label-info{background-color:#5bc0de}.label-info[href]:hover,.label-info[href]:focus{background-color:#31b0d5}.label-warning{background-color:#f0ad4e}.label-warning[href]:hover,.label-warning[href]:focus{background-color:#ec971f}.label-danger{background-color:#d9534f}.label-danger[href]:hover,.label-danger[href]:focus{background-color:#c9302c}.badge{display:inline-block;min-width:10px;padding:3px 7px;font-size:12px;font-weight:bold;color:#fff;line-height:1;vertical-align:middle;white-space:nowrap;text-align:center;background-color:#777;border-radius:10px}.badge:empty{display:none}.btn .badge{position:relative;top:-1px}.btn-xs .badge,.btn-group-xs>.btn .badge{top:0;padding:1px 5px}a.badge:hover,a.badge:focus{color:#fff;text-decoration:none;cursor:pointer}.list-group-item.active>.badge,.nav-pills>.active>a>.badge{color:#871e32;background-color:#fff}.list-group-item>.badge{float:right}.list-group-item>.badge+.badge{margin-right:5px}.nav-pills>li>a>.badge{margin-left:3px}
.jumbotron{padding-top:30px;padding-bottom:30px;margin-bottom:30px;color:inherit;background-color:#eee}.jumbotron h1,.jumbotron .h1{color:inherit}.jumbotron p{margin-bottom:15px;font-size:21px;font-weight:200}.jumbotron>hr{border-top-color:#d5d5d5}.container .jumbotron,.container-fluid .jumbotron{border-radius:6px;padding-left:15px;padding-right:15px}.jumbotron .container{max-width:100%}@media screen and (min-width:768px){.jumbotron{padding-top:48px;padding-bottom:48px}.container .jumbotron,.container-fluid .jumbotron{padding-left:60px;padding-right:60px}.jumbotron h1,.jumbotron .h1{font-size:63px}}.thumbnail{display:block;padding:4px;margin-bottom:20px;line-height:1.42857143;background-color:#fff;border:1px solid #ddd;border-radius:4px;-webkit-transition:border .2s ease-in-out;-o-transition:border .2s ease-in-out;transition:border .2s ease-in-out}.thumbnail>img,.thumbnail a>img{margin-left:auto;margin-right:auto}a.thumbnail:hover,a.thumbnail:focus,a.thumbnail.active{border-color:#8
71e32}.thumbnail .caption{padding:9px;color:#333}.alert{padding:15px;margin-bottom:20px;border:1px solid transparent;border-radius:4px}.alert h4{margin-top:0;color:inherit}.alert .alert-link{font-weight:bold}.alert>p,.alert>ul{margin-bottom:0}.alert>p+p{margin-top:5px}.alert-dismissable,.alert-dismissible{padding-right:35px}.alert-dismissable .close,.alert-dismissible .close{position:relative;top:-2px;right:-21px;color:inherit}.alert-success{background-color:#dff0d8;border-color:#d6e9c6;color:#3c763d}.alert-success hr{border-top-color:#c9e2b3}.alert-success .alert-link{color:#2b542c}.alert-info{background-color:#d9edf7;border-color:#bce8f1;color:#31708f}.alert-info hr{border-top-color:#a6e1ec}.alert-info .alert-link{color:#245269}.alert-warning{background-color:#fcf8e3;border-color:#faebcc;color:#8a6d3b}.alert-warning hr{border-top-color:#f7e1b5}.alert-warning .alert-link{color:#66512c}.alert-danger{background-color:#f2dede;border-color:#ebccd1;color:#a94442}.alert-danger hr{border-
top-color:#e4b9c0}.alert-danger .alert-link{color:#843534}@-webkit-keyframes progress-bar-stripes{from{background-position:40px 0}to{background-position:0 0}}@keyframes progress-bar-stripes{from{background-position:40px 0}to{background-position:0 0}}.progress{overflow:hidden;height:20px;margin-bottom:20px;background-color:#f5f5f5;border-radius:4px;-webkit-box-shadow:inset 0 1px 2px rgba(0,0,0,0.1);box-shadow:inset 0 1px 2px rgba(0,0,0,0.1)}.progress-bar{float:left;width:0;height:100%;font-size:12px;line-height:20px;color:#fff;text-align:center;background-color:#871e32;-webkit-box-shadow:inset 0 -1px 0 rgba(0,0,0,0.15);box-shadow:inset 0 -1px 0 rgba(0,0,0,0.15);-webkit-transition:width .6s ease;-o-transition:width .6s ease;transition:width .6s ease}.progress-striped .progress-bar,.progress-bar-striped{background-image:-webkit-linear-gradient(45deg,rgba(255,255,255,0.15) 25%,transparent 25%,transparent 50%,rgba(255,255,255,0.15) 50%,rgba(255,255,255,0.15) 75%,transparent 75%,transpare
nt);background-image:-o-linear-gradient(45deg,rgba(255,255,255,0.15) 25%,transparent 25%,transparent 50%,rgba(255,255,255,0.15) 50%,rgba(255,255,255,0.15) 75%,transparent 75%,transparent);background-image:linear-gradient(45deg,rgba(255,255,255,0.15) 25%,transparent 25%,transparent 50%,rgba(255,255,255,0.15) 50%,rgba(255,255,255,0.15) 75%,transparent 75%,transparent);background-size:40px 40px}.progress.active .progress-bar,.progress-bar.active{-webkit-animation:progress-bar-stripes 2s linear infinite;-o-animation:progress-bar-stripes 2s linear infinite;animation:progress-bar-stripes 2s linear infinite}.progress-bar-success{background-color:#5cb85c}.progress-striped .progress-bar-success{background-image:-webkit-linear-gradient(45deg,rgba(255,255,255,0.15) 25%,transparent 25%,transparent 50%,rgba(255,255,255,0.15) 50%,rgba(255,255,255,0.15) 75%,transparent 75%,transparent);background-image:-o-linear-gradient(45deg,rgba(255,255,255,0.15) 25%,transparent 25%,transparent 50%,rgba(255,255
,255,0.15) 50%,rgba(255,255,255,0.15) 75%,transparent 75%,transparent);background-image:linear-gradient(45deg,rgba(255,255,255,0.15) 25%,transparent 25%,transparent 50%,rgba(255,255,255,0.15) 50%,rgba(255,255,255,0.15) 75%,transparent 75%,transparent)}.progress-bar-info{background-color:#5bc0de}.progress-striped .progress-bar-info{background-image:-webkit-linear-gradient(45deg,rgba(255,255,255,0.15) 25%,transparent 25%,transparent 50%,rgba(255,255,255,0.15) 50%,rgba(255,255,255,0.15) 75%,transparent 75%,transparent);background-image:-o-linear-gradient(45deg,rgba(255,255,255,0.15) 25%,transparent 25%,transparent 50%,rgba(255,255,255,0.15) 50%,rgba(255,255,255,0.15) 75%,transparent 75%,transparent);background-image:linear-gradient(45deg,rgba(255,255,255,0.15) 25%,transparent 25%,transparent 50%,rgba(255,255,255,0.15) 50%,rgba(255,255,255,0.15) 75%,transparent 75%,transparent)}.progress-bar-warning{background-color:#f0ad4e}.progress-striped .progress-bar-warning{background-image:-webki
t-linear-gradient(45deg,rgba(255,255,255,0.15) 25%,transparent 25%,transparent 50%,rgba(255,255,255,0.15) 50%,rgba(255,255,255,0.15) 75%,transparent 75%,transparent);background-image:-o-linear-gradient(45deg,rgba(255,255,255,0.15) 25%,transparent 25%,transparent 50%,rgba(255,255,255,0.15) 50%,rgba(255,255,255,0.15) 75%,transparent 75%,transparent);background-image:linear-gradient(45deg,rgba(255,255,255,0.15) 25%,transparent 25%,transparent 50%,rgba(255,255,255,0.15) 50%,rgba(255,255,255,0.15) 75%,transparent 75%,transparent)}.progress-bar-danger{background-color:#d9534f}.progress-striped .progress-bar-danger{background-image:-webkit-linear-gradient(45deg,rgba(255,255,255,0.15) 25%,transparent 25%,transparent 50%,rgba(255,255,255,0.15) 50%,rgba(255,255,255,0.15) 75%,transparent 75%,transparent);background-image:-o-linear-gradient(45deg,rgba(255,255,255,0.15) 25%,transparent 25%,transparent 50%,rgba(255,255,255,0.15) 50%,rgba(255,255,255,0.15) 75%,transparent 75%,transparent);backgrou
nd-image:linear-gradient(45deg,rgba(255,255,255,0.15) 25%,transparent 25%,transparent 50%,rgba(255,255,255,0.15) 50%,rgba(255,255,255,0.15) 75%,transparent 75%,transparent)}.media{margin-top:15px}.media:first-child{margin-top:0}.media,.media-body{zoom:1;overflow:hidden}.media-body{width:10000px}.media-object{display:block}.media-object.img-thumbnail{max-width:none}.media-right,.media>.pull-right{padding-left:10px}.media-left,.media>.pull-left{padding-right:10px}.media-left,.media-right,.media-body{display:table-cell;vertical-align:top}.media-middle{vertical-align:middle}.media-bottom{vertical-align:bottom}.media-heading{margin-top:0;margin-bottom:5px}.media-list{padding-left:0;list-style:none}.list-group{margin-bottom:20px;padding-left:0}.list-group-item{position:relative;display:block;padding:10px 15px;margin-bottom:-1px;background-color:#fff;border:1px solid #ddd}.list-group-item:first-child{border-top-right-radius:4px;border-top-left-radius:4px}.list-group-item:last-child{margin-
bottom:0;border-bottom-right-radius:4px;border-bottom-left-radius:4px}a.list-group-item,button.list-group-item{color:#555}a.list-group-item .list-group-item-heading,button.list-group-item .list-group-item-heading{color:#333}a.list-group-item:hover,button.list-group-item:hover,a.list-group-item:focus,button.list-group-item:focus{text-decoration:none;color:#555;background-color:#f5f5f5}button.list-group-item{width:100%;text-align:left}.list-group-item.disabled,.list-group-item.disabled:hover,.list-group-item.disabled:focus{background-color:#eee;color:#777;cursor:not-allowed}.list-group-item.disabled .list-group-item-heading,.list-group-item.disabled:hover .list-group-item-heading,.list-group-item.disabled:focus .list-group-item-heading{color:inherit}.list-group-item.disabled .list-group-item-text,.list-group-item.disabled:hover .list-group-item-text,.list-group-item.disabled:focus .list-group-item-text{color:#777}.list-group-item.active,.list-group-item.active:hover,.list-group-item.a
ctive:focus{z-index:2;color:#fff;background-color:#871e32;border-color:#871e32}.list-group-item.active .list-group-item-heading,.list-group-item.active:hover .list-group-item-heading,.list-group-item.active:focus .list-group-item-heading,.list-group-item.active .list-group-item-heading>small,.list-group-item.active:hover .list-group-item-heading>small,.list-group-item.active:focus .list-group-item-heading>small,.list-group-item.active .list-group-item-heading>.small,.list-group-item.active:hover .list-group-item-heading>.small,.list-group-item.active:focus .list-group-item-heading>.small{color:inherit}.list-group-item.active .list-group-item-text,.list-group-item.active:hover .list-group-item-text,.list-group-item.active:focus .list-group-item-text{color:#e58c9d}.list-group-item-success{color:#3c763d;background-color:#dff0d8}a.list-group-item-success,button.list-group-item-success{color:#3c763d}a.list-group-item-success .list-group-item-heading,button.list-group-item-success .list-g
roup-item-heading{color:inherit}a.list-group-item-success:hover,button.list-group-item-success:hover,a.list-group-item-success:focus,button.list-group-item-success:focus{color:#3c763d;background-color:#d0e9c6}a.list-group-item-success.active,button.list-group-item-success.active,a.list-group-item-success.active:hover,button.list-group-item-success.active:hover,a.list-group-item-success.active:focus,button.list-group-item-success.active:focus{color:#fff;background-color:#3c763d;border-color:#3c763d}.list-group-item-info{color:#31708f;background-color:#d9edf7}a.list-group-item-info,button.list-group-item-info{color:#31708f}a.list-group-item-info .list-group-item-heading,button.list-group-item-info .list-group-item-heading{color:inherit}a.list-group-item-info:hover,button.list-group-item-info:hover,a.list-group-item-info:focus,button.list-group-item-info:focus{color:#31708f;background-color:#c4e3f3}a.list-group-item-info.active,button.list-group-item-info.active,a.list-group-item-info.
active:hover,button.list-group-item-info.active:hover,a.list-group-item-info.active:focus,button.list-group-item-info.active:focus{color:#fff;background-color:#31708f;border-color:#31708f}.list-group-item-warning{color:#8a6d3b;background-color:#fcf8e3}a.list-group-item-warning,button.list-group-item-warning{color:#8a6d3b}a.list-group-item-warning .list-group-item-heading,button.list-group-item-warning .list-group-item-heading{color:inherit}a.list-group-item-warning:hover,button.list-group-item-warning:hover,a.list-group-item-warning:focus,button.list-group-item-warning:focus{color:#8a6d3b;background-color:#faf2cc}a.list-group-item-warning.active,button.list-group-item-warning.active,a.list-group-item-warning.active:hover,button.list-group-item-warning.active:hover,a.list-group-item-warning.active:focus,button.list-group-item-warning.active:focus{color:#fff;background-color:#8a6d3b;border-color:#8a6d3b}.list-group-item-danger{color:#a94442;background-color:#f2dede}a.list-group-item-d
anger,button.list-group-item-danger{color:#a94442}a.list-group-item-danger .list-group-item-heading,button.list-group-item-danger .list-group-item-heading{color:inherit}a.list-group-item-danger:hover,button.list-group-item-danger:hover,a.list-group-item-danger:focus,button.list-group-item-danger:focus{color:#a94442;background-color:#ebcccc}a.list-group-item-danger.active,button.list-group-item-danger.active,a.list-group-item-danger.active:hover,button.list-group-item-danger.active:hover,a.list-group-item-danger.active:focus,button.list-group-item-danger.active:focus{color:#fff;background-color:#a94442;border-color:#a94442}.list-group-item-heading{margin-top:0;margin-bottom:5px}.list-group-item-text{margin-bottom:0;line-height:1.3}.panel{margin-bottom:20px;background-color:#fff;border:1px solid transparent;border-radius:4px;-webkit-box-shadow:0 1px 1px rgba(0,0,0,0.05);box-shadow:0 1px 1px rgba(0,0,0,0.05)}.panel-body{padding:15px}.panel-heading{padding:10px 15px;border-bottom:1px so
lid transparent;border-top-right-radius:3px;border-top-left-radius:3px}.panel-heading>.dropdown .dropdown-toggle{color:inherit}.panel-title{margin-top:0;margin-bottom:0;font-size:16px;color:inherit}.panel-title>a,.panel-title>small,.panel-title>.small,.panel-title>small>a,.panel-title>.small>a{color:inherit}.panel-footer{padding:10px 15px;background-color:#f5f5f5;border-top:1px solid #ddd;border-bottom-right-radius:3px;border-bottom-left-radius:3px}.panel>.list-group,.panel>.panel-collapse>.list-group{margin-bottom:0}.panel>.list-group .list-group-item,.panel>.panel-collapse>.list-group .list-group-item{border-width:1px 0;border-radius:0}.panel>.list-group:first-child .list-group-item:first-child,.panel>.panel-collapse>.list-group:first-child .list-group-item:first-child{border-top:0;border-top-right-radius:3px;border-top-left-radius:3px}.panel>.list-group:last-child .list-group-item:last-child,.panel>.panel-collapse>.list-group:last-child .list-group-item:last-child{border-bottom:0
;border-bottom-right-radius:3px;border-bottom-left-radius:3px}.panel>.panel-heading+.panel-collapse>.list-group .list-group-item:first-child{border-top-right-radius:0;border-top-left-radius:0}.panel-heading+.list-group .list-group-item:first-child{border-top-width:0}.list-group+.panel-footer{border-top-width:0}.panel>.table,.panel>.table-responsive>.table,.panel>.panel-collapse>.table{margin-bottom:0}.panel>.table caption,.panel>.table-responsive>.table caption,.panel>.panel-collapse>.table caption{padding-left:15px;padding-right:15px}.panel>.table:first-child,.panel>.table-responsive:first-child>.table:first-child{border-top-right-radius:3px;border-top-left-radius:3px}.panel>.table:first-child>thead:first-child>tr:first-child,.panel>.table-responsive:first-child>.table:first-child>thead:first-child>tr:first-child,.panel>.table:first-child>tbody:first-child>tr:first-child,.panel>.table-responsive:first-child>.table:first-child>tbody:first-child>tr:first-child{border-top-left-radius:
3px;border-top-right-radius:3px}.panel>.table:first-child>thead:first-child>tr:first-child td:first-child,.panel>.table-responsive:first-child>.table:first-child>thead:first-child>tr:first-child td:first-child,.panel>.table:first-child>tbody:first-child>tr:first-child td:first-child,.panel>.table-responsive:first-child>.table:first-child>tbody:first-child>tr:first-child td:first-child,.panel>.table:first-child>thead:first-child>tr:first-child th:first-child,.panel>.table-responsive:first-child>.table:first-child>thead:first-child>tr:first-child th:first-child,.panel>.table:first-child>tbody:first-child>tr:first-child th:first-child,.panel>.table-responsive:first-child>.table:first-child>tbody:first-child>tr:first-child th:first-child{border-top-left-radius:3px}.panel>.table:first-child>thead:first-child>tr:first-child td:last-child,.panel>.table-responsive:first-child>.table:first-child>thead:first-child>tr:first-child td:last-child,.panel>.table:first-child>tbody:first-child>tr:fir
st-child td:last-child,.panel>.table-responsive:first-child>.table:first-child>tbody:first-child>tr:first-child td:last-child,.panel>.table:first-child>thead:first-child>tr:first-child th:last-child,.panel>.table-responsive:first-child>.table:first-child>thead:first-child>tr:first-child th:last-child,.panel>.table:first-child>tbody:first-child>tr:first-child th:last-child,.panel>.table-responsive:first-child>.table:first-child>tbody:first-child>tr:first-child th:last-child{border-top-right-radius:3px}.panel>.table:last-child,.panel>.table-responsive:last-child>.table:last-child{border-bottom-right-radius:3px;border-bottom-left-radius:3px}.panel>.table:last-child>tbody:last-child>tr:last-child,.panel>.table-responsive:last-child>.table:last-child>tbody:last-child>tr:last-child,.panel>.table:last-child>tfoot:last-child>tr:last-child,.panel>.table-responsive:last-child>.table:last-child>tfoot:last-child>tr:last-child{border-bottom-left-radius:3px;border-bottom-right-radius:3px}.panel>.
table:last-child>tbody:last-child>tr:last-child td:first-child,.panel>.table-responsive:last-child>.table:last-child>tbody:last-child>tr:last-child td:first-child,.panel>.table:last-child>tfoot:last-child>tr:last-child td:first-child,.panel>.table-responsive:last-child>.table:last-child>tfoot:last-child>tr:last-child td:first-child,.panel>.table:last-child>tbody:last-child>tr:last-child th:first-child,.panel>.table-responsive:last-child>.table:last-child>tbody:last-child>tr:last-child th:first-child,.panel>.table:last-child>tfoot:last-child>tr:last-child th:first-child,.panel>.table-responsive:last-child>.table:last-child>tfoot:last-child>tr:last-child th:first-child{border-bottom-left-radius:3px}.panel>.table:last-child>tbody:last-child>tr:last-child td:last-child,.panel>.table-responsive:last-child>.table:last-child>tbody:last-child>tr:last-child td:last-child,.panel>.table:last-child>tfoot:last-child>tr:last-child td:last-child,.panel>.table-responsive:last-child>.table:last-chil
d>tfoot:last-child>tr:last-child td:last-child,.panel>.table:last-child>tbody:last-child>tr:last-child th:last-child,.panel>.table-responsive:last-child>.table:last-child>tbody:last-child>tr:last-child th:last-child,.panel>.table:last-child>tfoot:last-child>tr:last-child th:last-child,.panel>.table-responsive:last-child>.table:last-child>tfoot:last-child>tr:last-child th:last-child{border-bottom-right-radius:3px}.panel>.panel-body+.table,.panel>.panel-body+.table-responsive,.panel>.table+.panel-body,.panel>.table-responsive+.panel-body{border-top:1px solid #ddd}.panel>.table>tbody:first-child>tr:first-child th,.panel>.table>tbody:first-child>tr:first-child td{border-top:0}.panel>.table-bordered,.panel>.table-responsive>.table-bordered{border:0}.panel>.table-bordered>thead>tr>th:first-child,.panel>.table-responsive>.table-bordered>thead>tr>th:first-child,.panel>.table-bordered>tbody>tr>th:first-child,.panel>.table-responsive>.table-bordered>tbody>tr>th:first-child,.panel>.table-borde
red>tfoot>tr>th:first-child,.panel>.table-responsive>.table-bordered>tfoot>tr>th:first-child,.panel>.table-bordered>thead>tr>td:first-child,.panel>.table-responsive>.table-bordered>thead>tr>td:first-child,.panel>.table-bordered>tbody>tr>td:first-child,.panel>.table-responsive>.table-bordered>tbody>tr>td:first-child,.panel>.table-bordered>tfoot>tr>td:first-child,.panel>.table-responsive>.table-bordered>tfoot>tr>td:first-child{border-left:0}.panel>.table-bordered>thead>tr>th:last-child,.panel>.table-responsive>.table-bordered>thead>tr>th:last-child,.panel>.table-bordered>tbody>tr>th:last-child,.panel>.table-responsive>.table-bordered>tbody>tr>th:last-child,.panel>.table-bordered>tfoot>tr>th:last-child,.panel>.table-responsive>.table-bordered>tfoot>tr>th:last-child,.panel>.table-bordered>thead>tr>td:last-child,.panel>.table-responsive>.table-bordered>thead>tr>td:last-child,.panel>.table-bordered>tbody>tr>td:last-child,.panel>.table-responsive>.table-bordered>tbody>tr>td:last-child,.pan
el>.table-bordered>tfoot>tr>td:last-child,.panel>.table-responsive>.table-bordered>tfoot>tr>td:last-child{border-right:0}.panel>.table-bordered>thead>tr:first-child>td,.panel>.table-responsive>.table-bordered>thead>tr:first-child>td,.panel>.table-bordered>tbody>tr:first-child>td,.panel>.table-responsive>.table-bordered>tbody>tr:first-child>td,.panel>.table-bordered>thead>tr:first-child>th,.panel>.table-responsive>.table-bordered>thead>tr:first-child>th,.panel>.table-bordered>tbody>tr:first-child>th,.panel>.table-responsive>.table-bordered>tbody>tr:first-child>th{border-bottom:0}.panel>.table-bordered>tbody>tr:last-child>td,.panel>.table-responsive>.table-bordered>tbody>tr:last-child>td,.panel>.table-bordered>tfoot>tr:last-child>td,.panel>.table-responsive>.table-bordered>tfoot>tr:last-child>td,.panel>.table-bordered>tbody>tr:last-child>th,.panel>.table-responsive>.table-bordered>tbody>tr:last-child>th,.panel>.table-bordered>tfoot>tr:last-child>th,.panel>.table-responsive>.table-bord
ered>tfoot>tr:last-child>th{border-bottom:0}.panel>.table-responsive{border:0;margin-bottom:0}.panel-group{margin-bottom:20px}.panel-group .panel{margin-bottom:0;border-radius:4px}.panel-group .panel+.panel{margin-top:5px}.panel-group .panel-heading{border-bottom:0}.panel-group .panel-heading+.panel-collapse>.panel-body,.panel-group .panel-heading+.panel-collapse>.list-group{border-top:1px solid #ddd}.panel-group .panel-footer{border-top:0}.panel-group .panel-footer+.panel-collapse .panel-body{border-bottom:1px solid #ddd}.panel-default{border-color:#ddd}.panel-default>.panel-heading{color:#333;background-color:#f5f5f5;border-color:#ddd}.panel-default>.panel-heading+.panel-collapse>.panel-body{border-top-color:#ddd}.panel-default>.panel-heading .badge{color:#f5f5f5;background-color:#333}.panel-default>.panel-footer+.panel-collapse>.panel-body{border-bottom-color:#ddd}.panel-primary{border-color:#871e32}.panel-primary>.panel-heading{color:#fff;background-color:#871e32;border-color:#8
71e32}.panel-primary>.panel-heading+.panel-collapse>.panel-body{border-top-color:#871e32}.panel-primary>.panel-heading .badge{color:#871e32;background-color:#fff}.panel-primary>.panel-footer+.panel-collapse>.panel-body{border-bottom-color:#871e32}.panel-success{border-color:#d6e9c6}.panel-success>.panel-heading{color:#3c763d;background-color:#dff0d8;border-color:#d6e9c6}.panel-success>.panel-heading+.panel-collapse>.panel-body{border-top-color:#d6e9c6}.panel-success>.panel-heading .badge{color:#dff0d8;background-color:#3c763d}.panel-success>.panel-footer+.panel-collapse>.panel-body{border-bottom-color:#d6e9c6}.panel-info{border-color:#bce8f1}.panel-info>.panel-heading{color:#31708f;background-color:#d9edf7;border-color:#bce8f1}.panel-info>.panel-heading+.panel-collapse>.panel-body{border-top-color:#bce8f1}.panel-info>.panel-heading .badge{color:#d9edf7;background-color:#31708f}.panel-info>.panel-footer+.panel-collapse>.panel-body{border-bottom-color:#bce8f1}.panel-warning{border-col
or:#faebcc}.panel-warning>.panel-heading{color:#8a6d3b;background-color:#fcf8e3;border-color:#faebcc}.panel-warning>.panel-heading+.panel-collapse>.panel-body{border-top-color:#faebcc}.panel-warning>.panel-heading .badge{color:#fcf8e3;background-color:#8a6d3b}.panel-warning>.panel-footer+.panel-collapse>.panel-body{border-bottom-color:#faebcc}.panel-danger{border-color:#ebccd1}.panel-danger>.panel-heading{color:#a94442;background-color:#f2dede;border-color:#ebccd1}.panel-danger>.panel-heading+.panel-collapse>.panel-body{border-top-color:#ebccd1}.panel-danger>.panel-heading .badge{color:#f2dede;background-color:#a94442}.panel-danger>.panel-footer+.panel-collapse>.panel-body{border-bottom-color:#ebccd1}.embed-responsive{position:relative;display:block;height:0;padding:0;overflow:hidden}.embed-responsive .embed-responsive-item,.embed-responsive iframe,.embed-responsive embed,.embed-responsive object,.embed-responsive video{position:absolute;top:0;left:0;bottom:0;height:100%;width:100%;
border:0}.embed-responsive-16by9{padding-bottom:56.25%}.embed-responsive-4by3{padding-bottom:75%}.well{min-height:20px;padding:19px;margin-bottom:20px;background-color:#f5f5f5;border:1px solid #e3e3e3;border-radius:4px;-webkit-box-shadow:inset 0 1px 1px rgba(0,0,0,0.05);box-shadow:inset 0 1px 1px rgba(0,0,0,0.05)}.well blockquote{border-color:#ddd;border-color:rgba(0,0,0,0.15)}.well-lg{padding:24px;border-radius:6px}.well-sm{padding:9px;border-radius:3px}.close{float:right;font-size:21px;font-weight:bold;line-height:1;color:#000;text-shadow:0 1px 0 #fff;opacity:.2;filter:alpha(opacity=20)}.close:hover,.close:focus{color:#000;text-decoration:none;cursor:pointer;opacity:.5;filter:alpha(opacity=50)}button.close{padding:0;cursor:pointer;background:transparent;border:0;-webkit-appearance:none}.modal-open{overflow:hidden}.modal{display:none;overflow:hidden;position:fixed;top:0;right:0;bottom:0;left:0;z-index:1050;-webkit-overflow-scrolling:touch;outline:0}.modal.fade .modal-dialog{-webkit
-transform:translate(0,-25%);-ms-transform:translate(0,-25%);-o-transform:translate(0,-25%);transform:translate(0,-25%);-webkit-transition:-webkit-transform .3s ease-out;-moz-transition:-moz-transform .3s ease-out;-o-transition:-o-transform .3s ease-out;transition:transform .3s ease-out}.modal.in .modal-dialog{-webkit-transform:translate(0,0);-ms-transform:translate(0,0);-o-transform:translate(0,0);transform:translate(0,0)}.modal-open .modal{overflow-x:hidden;overflow-y:auto}.modal-dialog{position:relative;width:auto;margin:10px}.modal-content{position:relative;background-color:#fff;border:1px solid #999;border:1px solid rgba(0,0,0,0.2);border-radius:6px;-webkit-box-shadow:0 3px 9px rgba(0,0,0,0.5);box-shadow:0 3px 9px rgba(0,0,0,0.5);background-clip:padding-box;outline:0}.modal-backdrop{position:fixed;top:0;right:0;bottom:0;left:0;z-index:1040;background-color:#000}.modal-backdrop.fade{opacity:0;filter:alpha(opacity=0)}.modal-backdrop.in{opacity:.5;filter:alpha(opacity=50)}.modal-h
eader{padding:15px;border-bottom:1px solid #e5e5e5}.modal-header .close{margin-top:-2px}.modal-title{margin:0;line-height:1.42857143}.modal-body{position:relative;padding:15px}.modal-footer{padding:15px;text-align:right;border-top:1px solid #e5e5e5}.modal-footer .btn+.btn{margin-left:5px;margin-bottom:0}.modal-footer .btn-group .btn+.btn{margin-left:-1px}.modal-footer .btn-block+.btn-block{margin-left:0}.modal-scrollbar-measure{position:absolute;top:-9999px;width:50px;height:50px;overflow:scroll}@media(min-width:768px){.modal-dialog{width:600px;margin:30px auto}.modal-content{-webkit-box-shadow:0 5px 15px rgba(0,0,0,0.5);box-shadow:0 5px 15px rgba(0,0,0,0.5)}.modal-sm{width:300px}}@media(min-width:992px){.modal-lg{width:900px}}.tooltip{position:absolute;z-index:1070;display:block;font-family:"Helvetica Neue",Helvetica,Arial,sans-serif;font-style:normal;font-weight:normal;letter-spacing:normal;line-break:auto;line-height:1.42857143;text-align:left;text-align:start;text-decoration:non
e;text-shadow:none;text-transform:none;white-space:normal;word-break:normal;word-spacing:normal;word-wrap:normal;font-size:12px;opacity:0;filter:alpha(opacity=0)}.tooltip.in{opacity:.9;filter:alpha(opacity=90)}.tooltip.top{margin-top:-3px;padding:5px 0}.tooltip.right{margin-left:3px;padding:0 5px}.tooltip.bottom{margin-top:3px;padding:5px 0}.tooltip.left{margin-left:-3px;padding:0 5px}.tooltip-inner{max-width:200px;padding:3px 8px;color:#fff;text-align:center;background-color:#000;border-radius:4px}.tooltip-arrow{position:absolute;width:0;height:0;border-color:transparent;border-style:solid}.tooltip.top .tooltip-arrow{bottom:0;left:50%;margin-left:-5px;border-width:5px 5px 0;border-top-color:#000}.tooltip.top-left .tooltip-arrow{bottom:0;right:5px;margin-bottom:-5px;border-width:5px 5px 0;border-top-color:#000}.tooltip.top-right .tooltip-arrow{bottom:0;left:5px;margin-bottom:-5px;border-width:5px 5px 0;border-top-color:#000}.tooltip.right .tooltip-arrow{top:50%;left:0;margin-top:-5p
x;border-width:5px 5px 5px 0;border-right-color:#000}.tooltip.left .tooltip-arrow{top:50%;right:0;margin-top:-5px;border-width:5px 0 5px 5px;border-left-color:#000}.tooltip.bottom .tooltip-arrow{top:0;left:50%;margin-left:-5px;border-width:0 5px 5px;border-bottom-color:#000}.tooltip.bottom-left .tooltip-arrow{top:0;right:5px;margin-top:-5px;border-width:0 5px 5px;border-bottom-color:#000}.tooltip.bottom-right .tooltip-arrow{top:0;left:5px;margin-top:-5px;border-width:0 5px 5px;border-bottom-color:#000}.popover{position:absolute;top:0;left:0;z-index:1060;display:none;max-width:276px;padding:1px;font-family:"Helvetica Neue",Helvetica,Arial,sans-serif;font-style:normal;font-weight:normal;letter-spacing:normal;line-break:auto;line-height:1.42857143;text-align:left;text-align:start;text-decoration:none;text-shadow:none;text-transform:none;white-space:normal;word-break:normal;word-spacing:normal;word-wrap:normal;font-size:14px;background-color:#fff;background-clip:padding-box;border:1px s
olid #ccc;border:1px solid rgba(0,0,0,0.2);border-radius:6px;-webkit-box-shadow:0 5px 10px rgba(0,0,0,0.2);box-shadow:0 5px 10px rgba(0,0,0,0.2)}.popover.top{margin-top:-10px}.popover.right{margin-left:10px}.popover.bottom{margin-top:10px}.popover.left{margin-left:-10px}.popover-title{margin:0;padding:8px 14px;font-size:14px;background-color:#f7f7f7;border-bottom:1px solid #ebebeb;border-radius:5px 5px 0 0}.popover-content{padding:9px 14px}.popover>.arrow,.popover>.arrow:after{position:absolute;display:block;width:0;height:0;border-color:transparent;border-style:solid}.popover>.arrow{border-width:11px}.popover>.arrow:after{border-width:10px;content:""}.popover.top>.arrow{left:50%;margin-left:-11px;border-bottom-width:0;border-top-color:#999;border-top-color:rgba(0,0,0,0.25);bottom:-11px}.popover.top>.arrow:after{content:" ";bottom:1px;margin-left:-10px;border-bottom-width:0;border-top-color:#fff}.popover.right>.arrow{top:50%;left:-11px;margin-top:-11px;border-left-width:0;border-rig
ht-color:#999;border-right-color:rgba(0,0,0,0.25)}.popover.right>.arrow:after{content:" ";left:1px;bottom:-10px;border-left-width:0;border-right-color:#fff}.popover.bottom>.arrow{left:50%;margin-left:-11px;border-top-width:0;border-bottom-color:#999;border-bottom-color:rgba(0,0,0,0.25);top:-11px}.popover.bottom>.arrow:after{content:" ";top:1px;margin-left:-10px;border-top-width:0;border-bottom-color:#fff}.popover.left>.arrow{top:50%;right:-11px;margin-top:-11px;border-right-width:0;border-left-color:#999;border-left-color:rgba(0,0,0,0.25)}.popover.left>.arrow:after{content:" ";right:1px;border-right-width:0;border-left-color:#fff;bottom:-10px}.carousel{position:relative}.carousel-inner{position:relative;overflow:hidden;width:100%}.carousel-inner>.item{display:none;position:relative;-webkit-transition:.6s ease-in-out left;-o-transition:.6s ease-in-out left;transition:.6s ease-in-out left}.carousel-inner>.item>img,.carousel-inner>.item>a>img{line-height:1}@media all and (transform-3d)
,(-webkit-transform-3d){.carousel-inner>.item{-webkit-transition:-webkit-transform .6s ease-in-out;-moz-transition:-moz-transform .6s ease-in-out;-o-transition:-o-transform .6s ease-in-out;transition:transform .6s ease-in-out;-webkit-backface-visibility:hidden;-moz-backface-visibility:hidden;backface-visibility:hidden;-webkit-perspective:1000px;-moz-perspective:1000px;perspective:1000px}.carousel-inner>.item.next,.carousel-inner>.item.active.right{-webkit-transform:translate3d(100%,0,0);transform:translate3d(100%,0,0);left:0}.carousel-inner>.item.prev,.carousel-inner>.item.active.left{-webkit-transform:translate3d(-100%,0,0);transform:translate3d(-100%,0,0);left:0}.carousel-inner>.item.next.left,.carousel-inner>.item.prev.right,.carousel-inner>.item.active{-webkit-transform:translate3d(0,0,0);transform:translate3d(0,0,0);left:0}}.carousel-inner>.active,.carousel-inner>.next,.carousel-inner>.prev{display:block}.carousel-inner>.active{left:0}.carousel-inner>.next,.carousel-inner>.prev
{position:absolute;top:0;width:100%}.carousel-inner>.next{left:100%}.carousel-inner>.prev{left:-100%}.carousel-inner>.next.left,.carousel-inner>.prev.right{left:0}.carousel-inner>.active.left{left:-100%}.carousel-inner>.active.right{left:100%}.carousel-control{position:absolute;top:0;left:0;bottom:0;width:15%;opacity:.5;filter:alpha(opacity=50);font-size:20px;color:#fff;text-align:center;text-shadow:0 1px 2px rgba(0,0,0,0.6);background-color:rgba(0,0,0,0)}.carousel-control.left{background-image:-webkit-linear-gradient(left,rgba(0,0,0,0.5) 0,rgba(0,0,0,0.0001) 100%);background-image:-o-linear-gradient(left,rgba(0,0,0,0.5) 0,rgba(0,0,0,0.0001) 100%);background-image:linear-gradient(to right,rgba(0,0,0,0.5) 0,rgba(0,0,0,0.0001) 100%);background-repeat:repeat-x;filter:progid:DXImageTransform.Microsoft.gradient(startColorstr='#80000000',endColorstr='#00000000',GradientType=1)}.carousel-control.right{left:auto;right:0;background-image:-webkit-linear-gradient(left,rgba(0,0,0,0.0001) 0,rgba
(0,0,0,0.5) 100%);background-image:-o-linear-gradient(left,rgba(0,0,0,0.0001) 0,rgba(0,0,0,0.5) 100%);background-image:linear-gradient(to right,rgba(0,0,0,0.0001) 0,rgba(0,0,0,0.5) 100%);background-repeat:repeat-x;filter:progid:DXImageTransform.Microsoft.gradient(startColorstr='#00000000',endColorstr='#80000000',GradientType=1)}.carousel-control:hover,.carousel-control:focus{outline:0;color:#fff;text-decoration:none;opacity:.9;filter:alpha(opacity=90)}.carousel-control .icon-prev,.carousel-control .icon-next,.carousel-control .glyphicon-chevron-left,.carousel-control .glyphicon-chevron-right{position:absolute;top:50%;margin-top:-10px;z-index:5;display:inline-block}.carousel-control .icon-prev,.carousel-control .glyphicon-chevron-left{left:50%;margin-left:-10px}.carousel-control .icon-next,.carousel-control .glyphicon-chevron-right{right:50%;margin-right:-10px}.carousel-control .icon-prev,.carousel-control .icon-next{width:20px;height:20px;line-height:1;font-family:serif}.carousel-co
ntrol .icon-prev:before{content:'\2039'}.carousel-control .icon-next:before{content:'\203a'}.carousel-indicators{position:absolute;bottom:10px;left:50%;z-index:15;width:60%;margin-left:-30%;padding-left:0;list-style:none;text-align:center}.carousel-indicators li{display:inline-block;width:10px;height:10px;margin:1px;text-indent:-999px;border:1px solid #fff;border-radius:10px;cursor:pointer;background-color:#000 \9;background-color:rgba(0,0,0,0)}.carousel-indicators .active{margin:0;width:12px;height:12px;background-color:#fff}.carousel-caption{position:absolute;left:15%;right:15%;bottom:20px;z-index:10;padding-top:20px;padding-bottom:20px;color:#fff;text-align:center;text-shadow:0 1px 2px rgba(0,0,0,0.6)}.carousel-caption .btn{text-shadow:none}@media screen and (min-width:768px){.carousel-control .glyphicon-chevron-left,.carousel-control .glyphicon-chevron-right,.carousel-control .icon-prev,.carousel-control .icon-next{width:30px;height:30px;margin-top:-10px;font-size:30px}.carousel
-control .glyphicon-chevron-left,.carousel-control .icon-prev{margin-left:-10px}.carousel-control .glyphicon-chevron-right,.carousel-control .icon-next{margin-right:-10px}.carousel-caption{left:20%;right:20%;padding-bottom:30px}.carousel-indicators{bottom:20px}}.clearfix:before,.clearfix:after,.dl-horizontal dd:before,.dl-horizontal dd:after,.container:before,.container:after,.container-fluid:before,.container-fluid:after,.row:before,.row:after,.form-horizontal .form-group:before,.form-horizontal .form-group:after,.btn-toolbar:before,.btn-toolbar:after,.btn-group-vertical>.btn-group:before,.btn-group-vertical>.btn-group:after,.nav:before,.nav:after,.navbar:before,.navbar:after,.navbar-header:before,.navbar-header:after,.navbar-collapse:before,.navbar-collapse:after,.pager:before,.pager:after,.panel-body:before,.panel-body:after,.modal-header:before,.modal-header:after,.modal-footer:before,.modal-footer:after{content:" ";display:table}.clearfix:after,.dl-horizontal dd:after,.containe
r:after,.container-fluid:after,.row:after,.form-horizontal .form-group:after,.btn-toolbar:after,.btn-group-vertical>.btn-group:after,.nav:after,.navbar:after,.navbar-header:after,.navbar-collapse:after,.pager:after,.panel-body:after,.modal-header:after,.modal-footer:after{clear:both}.center-block{display:block;margin-left:auto;margin-right:auto}.pull-right{float:right!important}.pull-left{float:left!important}.hide{display:none!important}.show{display:block!important}.invisible{visibility:hidden}.text-hide{font:0/0 a;color:transparent;text-shadow:none;background-color:transparent;border:0}.hidden{display:none!important}.affix{position:fixed}@-ms-viewport{width:device-width}.visible-xs,.visible-sm,.visible-md,.visible-lg{display:none!important}.visible-xs-block,.visible-xs-inline,.visible-xs-inline-block,.visible-sm-block,.visible-sm-inline,.visible-sm-inline-block,.visible-md-block,.visible-md-inline,.visible-md-inline-block,.visible-lg-block,.visible-lg-inline,.visible-lg-inline-bl
ock{display:none!important}@media(max-width:767px){.visible-xs{display:block!important}table.visible-xs{display:table!important}tr.visible-xs{display:table-row!important}th.visible-xs,td.visible-xs{display:table-cell!important}}@media(max-width:767px){.visible-xs-block{display:block!important}}@media(max-width:767px){.visible-xs-inline{display:inline!important}}@media(max-width:767px){.visible-xs-inline-block{display:inline-block!important}}@media(min-width:768px) and (max-width:991px){.visible-sm{display:block!important}table.visible-sm{display:table!important}tr.visible-sm{display:table-row!important}th.visible-sm,td.visible-sm{display:table-cell!important}}@media(min-width:768px) and (max-width:991px){.visible-sm-block{display:block!important}}@media(min-width:768px) and (max-width:991px){.visible-sm-inline{display:inline!important}}@media(min-width:768px) and (max-width:991px){.visible-sm-inline-block{display:inline-block!important}}@media(min-width:992px) and (max-width:1199px)
{.visible-md{display:block!important}table.visible-md{display:table!important}tr.visible-md{display:table-row!important}th.visible-md,td.visible-md{display:table-cell!important}}@media(min-width:992px) and (max-width:1199px){.visible-md-block{display:block!important}}@media(min-width:992px) and (max-width:1199px){.visible-md-inline{display:inline!important}}@media(min-width:992px) and (max-width:1199px){.visible-md-inline-block{display:inline-block!important}}@media(min-width:1200px){.visible-lg{display:block!important}table.visible-lg{display:table!important}tr.visible-lg{display:table-row!important}th.visible-lg,td.visible-lg{display:table-cell!important}}@media(min-width:1200px){.visible-lg-block{display:block!important}}@media(min-width:1200px){.visible-lg-inline{display:inline!important}}@media(min-width:1200px){.visible-lg-inline-block{display:inline-block!important}}@media(max-width:767px){.hidden-xs{display:none!important}}@media(min-width:768px) and (max-width:991px){.hidde
n-sm{display:none!important}}@media(min-width:992px) and (max-width:1199px){.hidden-md{display:none!important}}@media(min-width:1200px){.hidden-lg{display:none!important}}.visible-print{display:none!important}@media print{.visible-print{display:block!important}table.visible-print{display:table!important}tr.visible-print{display:table-row!important}th.visible-print,td.visible-print{display:table-cell!important}}.visible-print-block{display:none!important}@media print{.visible-print-block{display:block!important}}.visible-print-inline{display:none!important}@media print{.visible-print-inline{display:inline!important}}.visible-print-inline-block{display:none!important}@media print{.visible-print-inline-block{display:inline-block!important}}@media print{.hidden-print{display:none!important}}.btn-default,.btn-primary,.btn-success,.btn-info,.btn-warning,.btn-danger{text-shadow:0 -1px 0 rgba(0,0,0,0.2);-webkit-box-shadow:inset 0 1px 0 rgba(255,255,255,0.15),0 1px 1px rgba(0,0,0,0.075);box-
shadow:inset 0 1px 0 rgba(255,255,255,0.15),0 1px 1px rgba(0,0,0,0.075)}.btn-default:active,.btn-primary:active,.btn-success:active,.btn-info:active,.btn-warning:active,.btn-danger:active,.btn-default.active,.btn-primary.active,.btn-success.active,.btn-info.active,.btn-warning.active,.btn-danger.active{-webkit-box-shadow:inset 0 3px 5px rgba(0,0,0,0.125);box-shadow:inset 0 3px 5px rgba(0,0,0,0.125)}.btn-default.disabled,.btn-primary.disabled,.btn-success.disabled,.btn-info.disabled,.btn-warning.disabled,.btn-danger.disabled,.btn-default[disabled],.btn-primary[disabled],.btn-success[disabled],.btn-info[disabled],.btn-warning[disabled],.btn-danger[disabled],fieldset[disabled] .btn-default,fieldset[disabled] .btn-primary,fieldset[disabled] .btn-success,fieldset[disabled] .btn-info,fieldset[disabled] .btn-warning,fieldset[disabled] .btn-danger{-webkit-box-shadow:none;box-shadow:none}.btn-default .badge,.btn-primary .badge,.btn-success .badge,.btn-info .badge,.btn-warning .badge,.btn-dan
ger .badge{text-shadow:none}.btn:active,.btn.active{background-image:none}.btn-default{background-image:-webkit-linear-gradient(top,#fff 0,#e0e0e0 100%);background-image:-o-linear-gradient(top,#fff 0,#e0e0e0 100%);background-image:linear-gradient(to bottom,#fff 0,#e0e0e0 100%);filter:progid:DXImageTransform.Microsoft.gradient(startColorstr='#ffffffff',endColorstr='#ffe0e0e0',GradientType=0);filter:progid:DXImageTransform.Microsoft.gradient(enabled = false);background-repeat:repeat-x;border-color:#dbdbdb;text-shadow:0 1px 0 #fff;border-color:#ccc}.btn-default:hover,.btn-default:focus{background-color:#e0e0e0;background-position:0 -15px}.btn-default:active,.btn-default.active{background-color:#e0e0e0;border-color:#dbdbdb}.btn-default.disabled,.btn-default[disabled],fieldset[disabled] .btn-default,.btn-default.disabled:hover,.btn-default[disabled]:hover,fieldset[disabled] .btn-default:hover,.btn-default.disabled:focus,.btn-default[disabled]:focus,fieldset[disabled] .btn-default:focus,.
btn-default.disabled.focus,.btn-default[disabled].focus,fieldset[disabled] .btn-default.focus,.btn-default.disabled:active,.btn-default[disabled]:active,fieldset[disabled] .btn-default:active,.btn-default.disabled.active,.btn-default[disabled].active,fieldset[disabled] .btn-default.active{background-color:#e0e0e0;background-image:none}.btn-primary{background-image:-webkit-linear-gradient(top,#871e32 0,#55131f 100%);background-image:-o-linear-gradient(top,#871e32 0,#55131f 100%);background-image:linear-gradient(to bottom,#871e32 0,#55131f 100%);filter:progid:DXImageTransform.Microsoft.gradient(startColorstr='#ff871e32',endColorstr='#ff55131f',GradientType=0);filter:progid:DXImageTransform.Microsoft.gradient(enabled = false);background-repeat:repeat-x;border-color:#4d111c}.btn-primary:hover,.btn-primary:focus{background-color:#55131f;background-position:0 -15px}.btn-primary:active,.btn-primary.active{background-color:#55131f;border-color:#4d111c}.btn-primary.disabled,.btn-primary[disa
bled],fieldset[disabled] .btn-primary,.btn-primary.disabled:hover,.btn-primary[disabled]:hover,fieldset[disabled] .btn-primary:hover,.btn-primary.disabled:focus,.btn-primary[disabled]:focus,fieldset[disabled] .btn-primary:focus,.btn-primary.disabled.focus,.btn-primary[disabled].focus,fieldset[disabled] .btn-primary.focus,.btn-primary.disabled:active,.btn-primary[disabled]:active,fieldset[disabled] .btn-primary:active,.btn-primary.disabled.active,.btn-primary[disabled].active,fieldset[disabled] .btn-primary.active{background-color:#55131f;background-image:none}.btn-success{background-image:-webkit-linear-gradient(top,#5cb85c 0,#419641 100%);background-image:-o-linear-gradient(top,#5cb85c 0,#419641 100%);background-image:linear-gradient(to bottom,#5cb85c 0,#419641 100%);filter:progid:DXImageTransform.Microsoft.gradient(startColorstr='#ff5cb85c',endColorstr='#ff419641',GradientType=0);filter:progid:DXImageTransform.Microsoft.gradient(enabled = false);background-repeat:repeat-x;border-c
olor:#3e8f3e}.btn-success:hover,.btn-success:focus{background-color:#419641;background-position:0 -15px}.btn-success:active,.btn-success.active{background-color:#419641;border-color:#3e8f3e}.btn-success.disabled,.btn-success[disabled],fieldset[disabled] .btn-success,.btn-success.disabled:hover,.btn-success[disabled]:hover,fieldset[disabled] .btn-success:hover,.btn-success.disabled:focus,.btn-success[disabled]:focus,fieldset[disabled] .btn-success:focus,.btn-success.disabled.focus,.btn-success[disabled].focus,fieldset[disabled] .btn-success.focus,.btn-success.disabled:active,.btn-success[disabled]:active,fieldset[disabled] .btn-success:active,.btn-success.disabled.active,.btn-success[disabled].active,fieldset[disabled] .btn-success.active{background-color:#419641;background-image:none}.btn-info{background-image:-webkit-linear-gradient(top,#5bc0de 0,#2aabd2 100%);background-image:-o-linear-gradient(top,#5bc0de 0,#2aabd2 100%);background-image:linear-gradient(to bottom,#5bc0de 0,#2aabd
2 100%);filter:progid:DXImageTransform.Microsoft.gradient(startColorstr='#ff5bc0de',endColorstr='#ff2aabd2',GradientType=0);filter:progid:DXImageTransform.Microsoft.gradient(enabled = false);background-repeat:repeat-x;border-color:#28a4c9}.btn-info:hover,.btn-info:focus{background-color:#2aabd2;background-position:0 -15px}.btn-info:active,.btn-info.active{background-color:#2aabd2;border-color:#28a4c9}.btn-info.disabled,.btn-info[disabled],fieldset[disabled] .btn-info,.btn-info.disabled:hover,.btn-info[disabled]:hover,fieldset[disabled] .btn-info:hover,.btn-info.disabled:focus,.btn-info[disabled]:focus,fieldset[disabled] .btn-info:focus,.btn-info.disabled.focus,.btn-info[disabled].focus,fieldset[disabled] .btn-info.focus,.btn-info.disabled:active,.btn-info[disabled]:active,fieldset[disabled] .btn-info:active,.btn-info.disabled.active,.btn-info[disabled].active,fieldset[disabled] .btn-info.active{background-color:#2aabd2;background-image:none}.btn-warning{background-image:-webkit-line
ar-gradient(top,#f0ad4e 0,#eb9316 100%);background-image:-o-linear-gradient(top,#f0ad4e 0,#eb9316 100%);background-image:linear-gradient(to bottom,#f0ad4e 0,#eb9316 100%);filter:progid:DXImageTransform.Microsoft.gradient(startColorstr='#fff0ad4e',endColorstr='#ffeb9316',GradientType=0);filter:progid:DXImageTransform.Microsoft.gradient(enabled = false);background-repeat:repeat-x;border-color:#e38d13}.btn-warning:hover,.btn-warning:focus{background-color:#eb9316;background-position:0 -15px}.btn-warning:active,.btn-warning.active{background-color:#eb9316;border-color:#e38d13}.btn-warning.disabled,.btn-warning[disabled],fieldset[disabled] .btn-warning,.btn-warning.disabled:hover,.btn-warning[disabled]:hover,fieldset[disabled] .btn-warning:hover,.btn-warning.disabled:focus,.btn-warning[disabled]:focus,fieldset[disabled] .btn-warning:focus,.btn-warning.disabled.focus,.btn-warning[disabled].focus,fieldset[disabled] .btn-warning.focus,.btn-warning.disabled:active,.btn-warning[disabled]:acti
ve,fieldset[disabled] .btn-warning:active,.btn-warning.disabled.active,.btn-warning[disabled].active,fieldset[disabled] .btn-warning.active{background-color:#eb9316;background-image:none}.btn-danger{background-image:-webkit-linear-gradient(top,#d9534f 0,#c12e2a 100%);background-image:-o-linear-gradient(top,#d9534f 0,#c12e2a 100%);background-image:linear-gradient(to bottom,#d9534f 0,#c12e2a 100%);filter:progid:DXImageTransform.Microsoft.gradient(startColorstr='#ffd9534f',endColorstr='#ffc12e2a',GradientType=0);filter:progid:DXImageTransform.Microsoft.gradient(enabled = false);background-repeat:repeat-x;border-color:#b92c28}.btn-danger:hover,.btn-danger:focus{background-color:#c12e2a;background-position:0 -15px}.btn-danger:active,.btn-danger.active{background-color:#c12e2a;border-color:#b92c28}.btn-danger.disabled,.btn-danger[disabled],fieldset[disabled] .btn-danger,.btn-danger.disabled:hover,.btn-danger[disabled]:hover,fieldset[disabled] .btn-danger:hover,.btn-danger.disabled:focus,.
btn-danger[disabled]:focus,fieldset[disabled] .btn-danger:focus,.btn-danger.disabled.focus,.btn-danger[disabled].focus,fieldset[disabled] .btn-danger.focus,.btn-danger.disabled:active,.btn-danger[disabled]:active,fieldset[disabled] .btn-danger:active,.btn-danger.disabled.active,.btn-danger[disabled].active,fieldset[disabled] .btn-danger.active{background-color:#c12e2a;background-image:none}.thumbnail,.img-thumbnail{-webkit-box-shadow:0 1px 2px rgba(0,0,0,0.075);box-shadow:0 1px 2px rgba(0,0,0,0.075)}.dropdown-menu>li>a:hover,.dropdown-menu>li>a:focus{background-image:-webkit-linear-gradient(top,#871d33 0,#72182b 100%);background-image:-o-linear-gradient(top,#871d33 0,#72182b 100%);background-image:linear-gradient(to bottom,#871d33 0,#72182b 100%);background-repeat:repeat-x;filter:progid:DXImageTransform.Microsoft.gradient(startColorstr='#ff871d33',endColorstr='#ff72182b',GradientType=0);background-color:#72182b}.dropdown-menu>.active>a,.dropdown-menu>.active>a:hover,.dropdown-menu>.
active>a:focus{background-image:-webkit-linear-gradient(top,#871e32 0,#72192a 100%);background-image:-o-linear-gradient(top,#871e32 0,#72192a 100%);background-image:linear-gradient(to bottom,#871e32 0,#72192a 100%);background-repeat:repeat-x;filter:progid:DXImageTransform.Microsoft.gradient(startColorstr='#ff871e32',endColorstr='#ff72192a',GradientType=0);background-color:#72192a}.navbar-default{background-image:-webkit-linear-gradient(top,#fff 0,#f8f8f8 100%);background-image:-o-linear-gradient(top,#fff 0,#f8f8f8 100%);background-image:linear-gradient(to bottom,#fff 0,#f8f8f8 100%);background-repeat:repeat-x;filter:progid:DXImageTransform.Microsoft.gradient(startColorstr='#ffffffff',endColorstr='#fff8f8f8',GradientType=0);filter:progid:DXImageTransform.Microsoft.gradient(enabled = false);border-radius:4px;-webkit-box-shadow:inset 0 1px 0 rgba(255,255,255,0.15),0 1px 5px rgba(0,0,0,0.075);box-shadow:inset 0 1px 0 rgba(255,255,255,0.15),0 1px 5px rgba(0,0,0,0.075)}.navbar-default .na
vbar-nav>.open>a,.navbar-default .navbar-nav>.active>a{background-image:-webkit-linear-gradient(top,#dbdbdb 0,#e2e2e2 100%);background-image:-o-linear-gradient(top,#dbdbdb 0,#e2e2e2 100%);background-image:linear-gradient(to bottom,#dbdbdb 0,#e2e2e2 100%);background-repeat:repeat-x;filter:progid:DXImageTransform.Microsoft.gradient(startColorstr='#ffdbdbdb',endColorstr='#ffe2e2e2',GradientType=0);-webkit-box-shadow:inset 0 3px 9px rgba(0,0,0,0.075);box-shadow:inset 0 3px 9px rgba(0,0,0,0.075)}.navbar-brand,.navbar-nav>li>a{text-shadow:0 1px 0 rgba(255,255,255,0.25)}.navbar-inverse{background-image:-webkit-linear-gradient(top,#71182b 0,#470f1b 100%);background-image:-o-linear-gradient(top,#71182b 0,#470f1b 100%);background-image:linear-gradient(to bottom,#71182b 0,#470f1b 100%);background-repeat:repeat-x;filter:progid:DXImageTransform.Microsoft.gradient(startColorstr='#ff71182b',endColorstr='#ff470f1b',GradientType=0);filter:progid:DXImageTransform.Microsoft.gradient(enabled = false);b
order-radius:4px}.navbar-inverse .navbar-nav>.open>a,.navbar-inverse .navbar-nav>.active>a{background-image:-webkit-linear-gradient(top,#1d060b 0,#27080f 100%);background-image:-o-linear-gradient(top,#1d060b 0,#27080f 100%);background-image:linear-gradient(to bottom,#1d060b 0,#27080f 100%);background-repeat:repeat-x;filter:progid:DXImageTransform.Microsoft.gradient(startColorstr='#ff1d060b',endColorstr='#ff27080f',GradientType=0);-webkit-box-shadow:inset 0 3px 9px rgba(0,0,0,0.25);box-shadow:inset 0 3px 9px rgba(0,0,0,0.25)}.navbar-inverse .navbar-brand,.navbar-inverse .navbar-nav>li>a{text-shadow:0 -1px 0 rgba(0,0,0,0.25)}.navbar-static-top,.navbar-fixed-top,.navbar-fixed-bottom{border-radius:0}@media(max-width:767px){.navbar .navbar-nav .open .dropdown-menu>.active>a,.navbar .navbar-nav .open .dropdown-menu>.active>a:hover,.navbar .navbar-nav .open .dropdown-menu>.active>a:focus{color:#fff;background-image:-webkit-linear-gradient(top,#871e32 0,#72192a 100%);background-image:-o-lin
ear-gradient(top,#871e32 0,#72192a 100%);background-image:linear-gradient(to bottom,#871e32 0,#72192a 100%);background-repeat:repeat-x;filter:progid:DXImageTransform.Microsoft.gradient(startColorstr='#ff871e32',endColorstr='#ff72192a',GradientType=0)}}.alert{text-shadow:0 1px 0 rgba(255,255,255,0.2);-webkit-box-shadow:inset 0 1px 0 rgba(255,255,255,0.25),0 1px 2px rgba(0,0,0,0.05);box-shadow:inset 0 1px 0 rgba(255,255,255,0.25),0 1px 2px rgba(0,0,0,0.05)}.alert-success{background-image:-webkit-linear-gradient(top,#dff0d8 0,#c8e5bc 100%);background-image:-o-linear-gradient(top,#dff0d8 0,#c8e5bc 100%);background-image:linear-gradient(to bottom,#dff0d8 0,#c8e5bc 100%);background-repeat:repeat-x;filter:progid:DXImageTransform.Microsoft.gradient(startColorstr='#ffdff0d8',endColorstr='#ffc8e5bc',GradientType=0);border-color:#b2dba1}.alert-info{background-image:-webkit-linear-gradient(top,#d9edf7 0,#b9def0 100%);background-image:-o-linear-gradient(top,#d9edf7 0,#b9def0 100%);background-ima
ge:linear-gradient(to bottom,#d9edf7 0,#b9def0 100%);background-repeat:repeat-x;filter:progid:DXImageTransform.Microsoft.gradient(startColorstr='#ffd9edf7',endColorstr='#ffb9def0',GradientType=0);border-color:#9acfea}.alert-warning{background-image:-webkit-linear-gradient(top,#fcf8e3 0,#f8efc0 100%);background-image:-o-linear-gradient(top,#fcf8e3 0,#f8efc0 100%);background-image:linear-gradient(to bottom,#fcf8e3 0,#f8efc0 100%);background-repeat:repeat-x;filter:progid:DXImageTransform.Microsoft.gradient(startColorstr='#fffcf8e3',endColorstr='#fff8efc0',GradientType=0);border-color:#f5e79e}.alert-danger{background-image:-webkit-linear-gradient(top,#f2dede 0,#e7c3c3 100%);background-image:-o-linear-gradient(top,#f2dede 0,#e7c3c3 100%);background-image:linear-gradient(to bottom,#f2dede 0,#e7c3c3 100%);background-repeat:repeat-x;filter:progid:DXImageTransform.Microsoft.gradient(startColorstr='#fff2dede',endColorstr='#ffe7c3c3',GradientType=0);border-color:#dca7a7}.progress{background-im
age:-webkit-linear-gradient(top,#ebebeb 0,#f5f5f5 100%);background-image:-o-linear-gradient(top,#ebebeb 0,#f5f5f5 100%);background-image:linear-gradient(to bottom,#ebebeb 0,#f5f5f5 100%);background-repeat:repeat-x;filter:progid:DXImageTransform.Microsoft.gradient(startColorstr='#ffebebeb',endColorstr='#fff5f5f5',GradientType=0)}.progress-bar{background-image:-webkit-linear-gradient(top,#871e32 0,#5d1523 100%);background-image:-o-linear-gradient(top,#871e32 0,#5d1523 100%);background-image:linear-gradient(to bottom,#871e32 0,#5d1523 100%);background-repeat:repeat-x;filter:progid:DXImageTransform.Microsoft.gradient(startColorstr='#ff871e32',endColorstr='#ff5d1523',GradientType=0)}.progress-bar-success{background-image:-webkit-linear-gradient(top,#5cb85c 0,#449d44 100%);background-image:-o-linear-gradient(top,#5cb85c 0,#449d44 100%);background-image:linear-gradient(to bottom,#5cb85c 0,#449d44 100%);background-repeat:repeat-x;filter:progid:DXImageTransform.Microsoft.gradient(startColors
tr='#ff5cb85c',endColorstr='#ff449d44',GradientType=0)}.progress-bar-info{background-image:-webkit-linear-gradient(top,#5bc0de 0,#31b0d5 100%);background-image:-o-linear-gradient(top,#5bc0de 0,#31b0d5 100%);background-image:linear-gradient(to bottom,#5bc0de 0,#31b0d5 100%);background-repeat:repeat-x;filter:progid:DXImageTransform.Microsoft.gradient(startColorstr='#ff5bc0de',endColorstr='#ff31b0d5',GradientType=0)}.progress-bar-warning{background-image:-webkit-linear-gradient(top,#f0ad4e 0,#ec971f 100%);background-image:-o-linear-gradient(top,#f0ad4e 0,#ec971f 100%);background-image:linear-gradient(to bottom,#f0ad4e 0,#ec971f 100%);background-repeat:repeat-x;filter:progid:DXImageTransform.Microsoft.gradient(startColorstr='#fff0ad4e',endColorstr='#ffec971f',GradientType=0)}.progress-bar-danger{background-image:-webkit-linear-gradient(top,#d9534f 0,#c9302c 100%);background-image:-o-linear-gradient(top,#d9534f 0,#c9302c 100%);background-image:linear-gradient(to bottom,#d9534f 0,#c9302c
100%);background-repeat:repeat-x;filter:progid:DXImageTransform.Microsoft.gradient(startColorstr='#ffd9534f',endColorstr='#ffc9302c',GradientType=0)}.progress-bar-striped{background-image:-webkit-linear-gradient(45deg,rgba(255,255,255,0.15) 25%,transparent 25%,transparent 50%,rgba(255,255,255,0.15) 50%,rgba(255,255,255,0.15) 75%,transparent 75%,transparent);background-image:-o-linear-gradient(45deg,rgba(255,255,255,0.15) 25%,transparent 25%,transparent 50%,rgba(255,255,255,0.15) 50%,rgba(255,255,255,0.15) 75%,transparent 75%,transparent);background-image:linear-gradient(45deg,rgba(255,255,255,0.15) 25%,transparent 25%,transparent 50%,rgba(255,255,255,0.15) 50%,rgba(255,255,255,0.15) 75%,transparent 75%,transparent)}.list-group{border-radius:4px;-webkit-box-shadow:0 1px 2px rgba(0,0,0,0.075);box-shadow:0 1px 2px rgba(0,0,0,0.075)}.list-group-item.active,.list-group-item.active:hover,.list-group-item.active:focus{text-shadow:0 -1px 0 #5d1523;background-image:-webkit-linear-gradient(to
p,#871e32 0,#681726 100%);background-image:-o-linear-gradient(top,#871e32 0,#681726 100%);background-image:linear-gradient(to bottom,#871e32 0,#681726 100%);background-repeat:repeat-x;filter:progid:DXImageTransform.Microsoft.gradient(startColorstr='#ff871e32',endColorstr='#ff681726',GradientType=0);border-color:#681726}.list-group-item.active .badge,.list-group-item.active:hover .badge,.list-group-item.active:focus .badge{text-shadow:none}.panel{-webkit-box-shadow:0 1px 2px rgba(0,0,0,0.05);box-shadow:0 1px 2px rgba(0,0,0,0.05)}.panel-default>.panel-heading{background-image:-webkit-linear-gradient(top,#f5f5f5 0,#e8e8e8 100%);background-image:-o-linear-gradient(top,#f5f5f5 0,#e8e8e8 100%);background-image:linear-gradient(to bottom,#f5f5f5 0,#e8e8e8 100%);background-repeat:repeat-x;filter:progid:DXImageTransform.Microsoft.gradient(startColorstr='#fff5f5f5',endColorstr='#ffe8e8e8',GradientType=0)}.panel-primary>.panel-heading{background-image:-webkit-linear-gradient(top,#871e32 0,#7219
2a 100%);background-image:-o-linear-gradient(top,#871e32 0,#72192a 100%);background-image:linear-gradient(to bottom,#871e32 0,#72192a 100%);background-repeat:repeat-x;filter:progid:DXImageTransform.Microsoft.gradient(startColorstr='#ff871e32',endColorstr='#ff72192a',GradientType=0)}.panel-success>.panel-heading{background-image:-webkit-linear-gradient(top,#dff0d8 0,#d0e9c6 100%);background-image:-o-linear-gradient(top,#dff0d8 0,#d0e9c6 100%);background-image:linear-gradient(to bottom,#dff0d8 0,#d0e9c6 100%);background-repeat:repeat-x;filter:progid:DXImageTransform.Microsoft.gradient(startColorstr='#ffdff0d8',endColorstr='#ffd0e9c6',GradientType=0)}.panel-info>.panel-heading{background-image:-webkit-linear-gradient(top,#d9edf7 0,#c4e3f3 100%);background-image:-o-linear-gradient(top,#d9edf7 0,#c4e3f3 100%);background-image:linear-gradient(to bottom,#d9edf7 0,#c4e3f3 100%);background-repeat:repeat-x;filter:progid:DXImageTransform.Microsoft.gradient(startColorstr='#ffd9edf7',endColorstr
='#ffc4e3f3',GradientType=0)}.panel-warning>.panel-heading{background-image:-webkit-linear-gradient(top,#fcf8e3 0,#faf2cc 100%);background-image:-o-linear-gradient(top,#fcf8e3 0,#faf2cc 100%);background-image:linear-gradient(to bottom,#fcf8e3 0,#faf2cc 100%);background-repeat:repeat-x;filter:progid:DXImageTransform.Microsoft.gradient(startColorstr='#fffcf8e3',endColorstr='#fffaf2cc',GradientType=0)}.panel-danger>.panel-heading{background-image:-webkit-linear-gradient(top,#f2dede 0,#ebcccc 100%);background-image:-o-linear-gradient(top,#f2dede 0,#ebcccc 100%);background-image:linear-gradient(to bottom,#f2dede 0,#ebcccc 100%);background-repeat:repeat-x;filter:progid:DXImageTransform.Microsoft.gradient(startColorstr='#fff2dede',endColorstr='#ffebcccc',GradientType=0)}.well{background-image:-webkit-linear-gradient(top,#e8e8e8 0,#f5f5f5 100%);background-image:-o-linear-gradient(top,#e8e8e8 0,#f5f5f5 100%);background-image:linear-gradient(to bottom,#e8e8e8 0,#f5f5f5 100%);background-repeat
:repeat-x;filter:progid:DXImageTransform.Microsoft.gradient(startColorstr='#ffe8e8e8',endColorstr='#fff5f5f5',GradientType=0);border-color:#dcdcdc;-webkit-box-shadow:inset 0 1px 3px rgba(0,0,0,0.05),0 1px 0 rgba(255,255,255,0.1);box-shadow:inset 0 1px 3px rgba(0,0,0,0.05),0 1px 0 rgba(255,255,255,0.1)}
+ *//* normalize.css v3.0.3 | MIT License | github.com/necolas/normalize.css */html{font-family:sans-serif;-ms-text-size-adjust:100%;-webkit-text-size-adjust:100%}body{margin:0}article,aside,details,figcaption,figure,footer,header,hgroup,main,menu,nav,section,summary{display:block}audio,canvas,progress,video{display:inline-block;vertical-align:baseline}audio:not([controls]){display:none;height:0}[hidden],template{display:none}a{background-color:transparent}a:active,a:hover{outline:0}abbr[title]{border-bottom:1px dotted}b,strong{font-weight:bold}dfn{font-style:italic}h1{font-size:2em;margin:.67em 0}mark{background:#ff0;color:#000}small{font-size:80%}sub,sup{font-size:75%;line-height:0;position:relative;vertical-align:baseline}sup{top:-0.5em}sub{bottom:-0.25em}img{border:0}svg:not(:root){overflow:hidden}figure{margin:1em 40px}hr{box-sizing:content-box;height:0}pre{overflow:auto}code,kbd,pre,samp{font-family:monospace,monospace;font-size:1em}button,input,optgroup,select,textarea{color:i
nherit;font:inherit;margin:0}button{overflow:visible}button,select{text-transform:none}button,html input[type="button"],input[type="reset"],input[type="submit"]{-webkit-appearance:button;cursor:pointer}button[disabled],html input[disabled]{cursor:default}button::-moz-focus-inner,input::-moz-focus-inner{border:0;padding:0}input{line-height:normal}input[type="checkbox"],input[type="radio"]{box-sizing:border-box;padding:0}input[type="number"]::-webkit-inner-spin-button,input[type="number"]::-webkit-outer-spin-button{height:auto}input[type="search"]{-webkit-appearance:textfield;box-sizing:content-box}input[type="search"]::-webkit-search-cancel-button,input[type="search"]::-webkit-search-decoration{-webkit-appearance:none}fieldset{border:1px solid #c0c0c0;margin:0 2px;padding:.35em .625em .75em}legend{border:0;padding:0}textarea{overflow:auto}optgroup{font-weight:bold}table{border-collapse:collapse;border-spacing:0}td,th{padding:0}/* Source: https://github.com/h5bp/html5-boilerplate/blob
/master/src/css/main.css */@media print{*,*:before,*:after{background:transparent!important;color:#000!important;box-shadow:none!important;text-shadow:none!important}a,a:visited{text-decoration:underline}a[href]:after{content:" (" attr(href) ")"}abbr[title]:after{content:" (" attr(title) ")"}a[href^="#"]:after,a[href^="javascript:"]:after{content:""}pre,blockquote{border:1px solid #999;page-break-inside:avoid}thead{display:table-header-group}tr,img{page-break-inside:avoid}img{max-width:100%!important}p,h2,h3{orphans:3;widows:3}h2,h3{page-break-after:avoid}.navbar{display:none}.btn>.caret,.dropup>.btn>.caret{border-top-color:#000!important}.label{border:1px solid #000}.table{border-collapse:collapse!important}.table td,.table th{background-color:#fff!important}.table-bordered th,.table-bordered td{border:1px solid #ddd!important}}@font-face{font-family:'Glyphicons Halflings';src:url('https://cdn.jsdelivr.net/bootstrap/3.3.7/fonts/glyphicons-halflings-regular.eot');src:url('https://cd
n.jsdelivr.net/bootstrap/3.3.7/fonts/glyphicons-halflings-regular.eot?#iefix') format('embedded-opentype'),url('https://cdn.jsdelivr.net/bootstrap/3.3.7/fonts/glyphicons-halflings-regular.woff2') format('woff2'),url('https://cdn.jsdelivr.net/bootstrap/3.3.7/fonts/glyphicons-halflings-regular.woff') format('woff'),url('https://cdn.jsdelivr.net/bootstrap/3.3.7/fonts/glyphicons-halflings-regular.ttf') format('truetype'),url('https://cdn.jsdelivr.net/bootstrap/3.3.7/fonts/glyphicons-halflings-regular.svg#glyphicons_halflingsregular') format('svg')}.glyphicon{position:relative;top:1px;display:inline-block;font-family:'Glyphicons Halflings';font-style:normal;font-weight:normal;line-height:1;-webkit-font-smoothing:antialiased;-moz-osx-font-smoothing:grayscale}.glyphicon-asterisk:before{content:"\002a"}.glyphicon-plus:before{content:"\002b"}.glyphicon-euro:before,.glyphicon-eur:before{content:"\20ac"}.glyphicon-minus:before{content:"\2212"}.glyphicon-cloud:before{content:"\2601"}.glyphicon-
envelope:before{content:"\2709"}.glyphicon-pencil:before{content:"\270f"}.glyphicon-glass:before{content:"\e001"}.glyphicon-music:before{content:"\e002"}.glyphicon-search:before{content:"\e003"}.glyphicon-heart:before{content:"\e005"}.glyphicon-star:before{content:"\e006"}.glyphicon-star-empty:before{content:"\e007"}.glyphicon-user:before{content:"\e008"}.glyphicon-film:before{content:"\e009"}.glyphicon-th-large:before{content:"\e010"}.glyphicon-th:before{content:"\e011"}.glyphicon-th-list:before{content:"\e012"}.glyphicon-ok:before{content:"\e013"}.glyphicon-remove:before{content:"\e014"}.glyphicon-zoom-in:before{content:"\e015"}.glyphicon-zoom-out:before{content:"\e016"}.glyphicon-off:before{content:"\e017"}.glyphicon-signal:before{content:"\e018"}.glyphicon-cog:before{content:"\e019"}.glyphicon-trash:before{content:"\e020"}.glyphicon-home:before{content:"\e021"}.glyphicon-file:before{content:"\e022"}.glyphicon-time:before{content:"\e023"}.glyphicon-road:before{content:"\e024"}.gl
yphicon-download-alt:before{content:"\e025"}.glyphicon-download:before{content:"\e026"}.glyphicon-upload:before{content:"\e027"}.glyphicon-inbox:before{content:"\e028"}.glyphicon-play-circle:before{content:"\e029"}.glyphicon-repeat:before{content:"\e030"}.glyphicon-refresh:before{content:"\e031"}.glyphicon-list-alt:before{content:"\e032"}.glyphicon-lock:before{content:"\e033"}.glyphicon-flag:before{content:"\e034"}.glyphicon-headphones:before{content:"\e035"}.glyphicon-volume-off:before{content:"\e036"}.glyphicon-volume-down:before{content:"\e037"}.glyphicon-volume-up:before{content:"\e038"}.glyphicon-qrcode:before{content:"\e039"}.glyphicon-barcode:before{content:"\e040"}.glyphicon-tag:before{content:"\e041"}.glyphicon-tags:before{content:"\e042"}.glyphicon-book:before{content:"\e043"}.glyphicon-bookmark:before{content:"\e044"}.glyphicon-print:before{content:"\e045"}.glyphicon-camera:before{content:"\e046"}.glyphicon-font:before{content:"\e047"}.glyphicon-bold:before{content:"\e048
"}.glyphicon-italic:before{content:"\e049"}.glyphicon-text-height:before{content:"\e050"}.glyphicon-text-width:before{content:"\e051"}.glyphicon-align-left:before{content:"\e052"}.glyphicon-align-center:before{content:"\e053"}.glyphicon-align-right:before{content:"\e054"}.glyphicon-align-justify:before{content:"\e055"}.glyphicon-list:before{content:"\e056"}.glyphicon-indent-left:before{content:"\e057"}.glyphicon-indent-right:before{content:"\e058"}.glyphicon-facetime-video:before{content:"\e059"}.glyphicon-picture:before{content:"\e060"}.glyphicon-map-marker:before{content:"\e062"}.glyphicon-adjust:before{content:"\e063"}.glyphicon-tint:before{content:"\e064"}.glyphicon-edit:before{content:"\e065"}.glyphicon-share:before{content:"\e066"}.glyphicon-check:before{content:"\e067"}.glyphicon-move:before{content:"\e068"}.glyphicon-step-backward:before{content:"\e069"}.glyphicon-fast-backward:before{content:"\e070"}.glyphicon-backward:before{content:"\e071"}.glyphicon-play:before{content:"
\e072"}.glyphicon-pause:before{content:"\e073"}.glyphicon-stop:before{content:"\e074"}.glyphicon-forward:before{content:"\e075"}.glyphicon-fast-forward:before{content:"\e076"}.glyphicon-step-forward:before{content:"\e077"}.glyphicon-eject:before{content:"\e078"}.glyphicon-chevron-left:before{content:"\e079"}.glyphicon-chevron-right:before{content:"\e080"}.glyphicon-plus-sign:before{content:"\e081"}.glyphicon-minus-sign:before{content:"\e082"}.glyphicon-remove-sign:before{content:"\e083"}.glyphicon-ok-sign:before{content:"\e084"}.glyphicon-question-sign:before{content:"\e085"}.glyphicon-info-sign:before{content:"\e086"}.glyphicon-screenshot:before{content:"\e087"}.glyphicon-remove-circle:before{content:"\e088"}.glyphicon-ok-circle:before{content:"\e089"}.glyphicon-ban-circle:before{content:"\e090"}.glyphicon-arrow-left:before{content:"\e091"}.glyphicon-arrow-right:before{content:"\e092"}.glyphicon-arrow-up:before{content:"\e093"}.glyphicon-arrow-down:before{content:"\e094"}.glyphicon
-share-alt:before{content:"\e095"}.glyphicon-resize-full:before{content:"\e096"}.glyphicon-resize-small:before{content:"\e097"}.glyphicon-exclamation-sign:before{content:"\e101"}.glyphicon-gift:before{content:"\e102"}.glyphicon-leaf:before{content:"\e103"}.glyphicon-fire:before{content:"\e104"}.glyphicon-eye-open:before{content:"\e105"}.glyphicon-eye-close:before{content:"\e106"}.glyphicon-warning-sign:before{content:"\e107"}.glyphicon-plane:before{content:"\e108"}.glyphicon-calendar:before{content:"\e109"}.glyphicon-random:before{content:"\e110"}.glyphicon-comment:before{content:"\e111"}.glyphicon-magnet:before{content:"\e112"}.glyphicon-chevron-up:before{content:"\e113"}.glyphicon-chevron-down:before{content:"\e114"}.glyphicon-retweet:before{content:"\e115"}.glyphicon-shopping-cart:before{content:"\e116"}.glyphicon-folder-close:before{content:"\e117"}.glyphicon-folder-open:before{content:"\e118"}.glyphicon-resize-vertical:before{content:"\e119"}.glyphicon-resize-horizontal:before{
content:"\e120"}.glyphicon-hdd:before{content:"\e121"}.glyphicon-bullhorn:before{content:"\e122"}.glyphicon-bell:before{content:"\e123"}.glyphicon-certificate:before{content:"\e124"}.glyphicon-thumbs-up:before{content:"\e125"}.glyphicon-thumbs-down:before{content:"\e126"}.glyphicon-hand-right:before{content:"\e127"}.glyphicon-hand-left:before{content:"\e128"}.glyphicon-hand-up:before{content:"\e129"}.glyphicon-hand-down:before{content:"\e130"}.glyphicon-circle-arrow-right:before{content:"\e131"}.glyphicon-circle-arrow-left:before{content:"\e132"}.glyphicon-circle-arrow-up:before{content:"\e133"}.glyphicon-circle-arrow-down:before{content:"\e134"}.glyphicon-globe:before{content:"\e135"}.glyphicon-wrench:before{content:"\e136"}.glyphicon-tasks:before{content:"\e137"}.glyphicon-filter:before{content:"\e138"}.glyphicon-briefcase:before{content:"\e139"}.glyphicon-fullscreen:before{content:"\e140"}.glyphicon-dashboard:before{content:"\e141"}.glyphicon-paperclip:before{content:"\e142"}.gly
phicon-heart-empty:before{content:"\e143"}.glyphicon-link:before{content:"\e144"}.glyphicon-phone:before{content:"\e145"}.glyphicon-pushpin:before{content:"\e146"}.glyphicon-usd:before{content:"\e148"}.glyphicon-gbp:before{content:"\e149"}.glyphicon-sort:before{content:"\e150"}.glyphicon-sort-by-alphabet:before{content:"\e151"}.glyphicon-sort-by-alphabet-alt:before{content:"\e152"}.glyphicon-sort-by-order:before{content:"\e153"}.glyphicon-sort-by-order-alt:before{content:"\e154"}.glyphicon-sort-by-attributes:before{content:"\e155"}.glyphicon-sort-by-attributes-alt:before{content:"\e156"}.glyphicon-unchecked:before{content:"\e157"}.glyphicon-expand:before{content:"\e158"}.glyphicon-collapse-down:before{content:"\e159"}.glyphicon-collapse-up:before{content:"\e160"}.glyphicon-log-in:before{content:"\e161"}.glyphicon-flash:before{content:"\e162"}.glyphicon-log-out:before{content:"\e163"}.glyphicon-new-window:before{content:"\e164"}.glyphicon-record:before{content:"\e165"}.glyphicon-save
:before{content:"\e166"}.glyphicon-open:before{content:"\e167"}.glyphicon-saved:before{content:"\e168"}.glyphicon-import:before{content:"\e169"}.glyphicon-export:before{content:"\e170"}.glyphicon-send:before{content:"\e171"}.glyphicon-floppy-disk:before{content:"\e172"}.glyphicon-floppy-saved:before{content:"\e173"}.glyphicon-floppy-remove:before{content:"\e174"}.glyphicon-floppy-save:before{content:"\e175"}.glyphicon-floppy-open:before{content:"\e176"}.glyphicon-credit-card:before{content:"\e177"}.glyphicon-transfer:before{content:"\e178"}.glyphicon-cutlery:before{content:"\e179"}.glyphicon-header:before{content:"\e180"}.glyphicon-compressed:before{content:"\e181"}.glyphicon-earphone:before{content:"\e182"}.glyphicon-phone-alt:before{content:"\e183"}.glyphicon-tower:before{content:"\e184"}.glyphicon-stats:before{content:"\e185"}.glyphicon-sd-video:before{content:"\e186"}.glyphicon-hd-video:before{content:"\e187"}.glyphicon-subtitles:before{content:"\e188"}.glyphicon-sound-stereo:be
fore{content:"\e189"}.glyphicon-sound-dolby:before{content:"\e190"}.glyphicon-sound-5-1:before{content:"\e191"}.glyphicon-sound-6-1:before{content:"\e192"}.glyphicon-sound-7-1:before{content:"\e193"}.glyphicon-copyright-mark:before{content:"\e194"}.glyphicon-registration-mark:before{content:"\e195"}.glyphicon-cloud-download:before{content:"\e197"}.glyphicon-cloud-upload:before{content:"\e198"}.glyphicon-tree-conifer:before{content:"\e199"}.glyphicon-tree-deciduous:before{content:"\e200"}.glyphicon-cd:before{content:"\e201"}.glyphicon-save-file:before{content:"\e202"}.glyphicon-open-file:before{content:"\e203"}.glyphicon-level-up:before{content:"\e204"}.glyphicon-copy:before{content:"\e205"}.glyphicon-paste:before{content:"\e206"}.glyphicon-alert:before{content:"\e209"}.glyphicon-equalizer:before{content:"\e210"}.glyphicon-king:before{content:"\e211"}.glyphicon-queen:before{content:"\e212"}.glyphicon-pawn:before{content:"\e213"}.glyphicon-bishop:before{content:"\e214"}.glyphicon-knig
ht:before{content:"\e215"}.glyphicon-baby-formula:before{content:"\e216"}.glyphicon-tent:before{content:"\26fa"}.glyphicon-blackboard:before{content:"\e218"}.glyphicon-bed:before{content:"\e219"}.glyphicon-apple:before{content:"\f8ff"}.glyphicon-erase:before{content:"\e221"}.glyphicon-hourglass:before{content:"\231b"}.glyphicon-lamp:before{content:"\e223"}.glyphicon-duplicate:before{content:"\e224"}.glyphicon-piggy-bank:before{content:"\e225"}.glyphicon-scissors:before{content:"\e226"}.glyphicon-bitcoin:before{content:"\e227"}.glyphicon-btc:before{content:"\e227"}.glyphicon-xbt:before{content:"\e227"}.glyphicon-yen:before{content:"\00a5"}.glyphicon-jpy:before{content:"\00a5"}.glyphicon-ruble:before{content:"\20bd"}.glyphicon-rub:before{content:"\20bd"}.glyphicon-scale:before{content:"\e230"}.glyphicon-ice-lolly:before{content:"\e231"}.glyphicon-ice-lolly-tasted:before{content:"\e232"}.glyphicon-education:before{content:"\e233"}.glyphicon-option-horizontal:before{content:"\e234"}.gly
phicon-option-vertical:before{content:"\e235"}.glyphicon-menu-hamburger:before{content:"\e236"}.glyphicon-modal-window:before{content:"\e237"}.glyphicon-oil:before{content:"\e238"}.glyphicon-grain:before{content:"\e239"}.glyphicon-sunglasses:before{content:"\e240"}.glyphicon-text-size:before{content:"\e241"}.glyphicon-text-color:before{content:"\e242"}.glyphicon-text-background:before{content:"\e243"}.glyphicon-object-align-top:before{content:"\e244"}.glyphicon-object-align-bottom:before{content:"\e245"}.glyphicon-object-align-horizontal:before{content:"\e246"}.glyphicon-object-align-left:before{content:"\e247"}.glyphicon-object-align-vertical:before{content:"\e248"}.glyphicon-object-align-right:before{content:"\e249"}.glyphicon-triangle-right:before{content:"\e250"}.glyphicon-triangle-left:before{content:"\e251"}.glyphicon-triangle-bottom:before{content:"\e252"}.glyphicon-triangle-top:before{content:"\e253"}.glyphicon-console:before{content:"\e254"}.glyphicon-superscript:before{con
tent:"\e255"}.glyphicon-subscript:before{content:"\e256"}.glyphicon-menu-left:before{content:"\e257"}.glyphicon-menu-right:before{content:"\e258"}.glyphicon-menu-down:before{content:"\e259"}.glyphicon-menu-up:before{content:"\e260"}*{-webkit-box-sizing:border-box;-moz-box-sizing:border-box;box-sizing:border-box}*:before,*:after{-webkit-box-sizing:border-box;-moz-box-sizing:border-box;box-sizing:border-box}html{font-size:10px;-webkit-tap-highlight-color:rgba(0,0,0,0)}body{font-family:"Helvetica Neue",Helvetica,Arial,sans-serif;font-size:14px;line-height:1.42857143;color:#333;background-color:#fff}input,button,select,textarea{font-family:inherit;font-size:inherit;line-height:inherit}a{color:#871e32;text-decoration:none}a:hover,a:focus{color:#48101b;text-decoration:underline}a:focus{outline:5px auto -webkit-focus-ring-color;outline-offset:-2px}figure{margin:0}img{vertical-align:middle}.img-responsive,.thumbnail>img,.thumbnail a>img,.carousel-inner>.item>img,.carousel-inner>.item>a>img{
display:block;max-width:100%;height:auto}.img-rounded{border-radius:6px}.img-thumbnail{padding:4px;line-height:1.42857143;background-color:#fff;border:1px solid #ddd;border-radius:4px;-webkit-transition:all .2s ease-in-out;-o-transition:all .2s ease-in-out;transition:all .2s ease-in-out;display:inline-block;max-width:100%;height:auto}.img-circle{border-radius:50%}hr{margin-top:20px;margin-bottom:20px;border:0;border-top:1px solid #eee}.sr-only{position:absolute;width:1px;height:1px;margin:-1px;padding:0;overflow:hidden;clip:rect(0,0,0,0);border:0}.sr-only-focusable:active,.sr-only-focusable:focus{position:static;width:auto;height:auto;margin:0;overflow:visible;clip:auto}[role="button"]{cursor:pointer}h1,h2,h3,h4,h5,h6,.h1,.h2,.h3,.h4,.h5,.h6{font-family:inherit;font-weight:500;line-height:1.1;color:inherit}h1 small,h2 small,h3 small,h4 small,h5 small,h6 small,.h1 small,.h2 small,.h3 small,.h4 small,.h5 small,.h6 small,h1 .small,h2 .small,h3 .small,h4 .small,h5 .small,h6 .small,.h1 .
small,.h2 .small,.h3 .small,.h4 .small,.h5 .small,.h6 .small{font-weight:normal;line-height:1;color:#777}h1,.h1,h2,.h2,h3,.h3{margin-top:20px;margin-bottom:10px}h1 small,.h1 small,h2 small,.h2 small,h3 small,.h3 small,h1 .small,.h1 .small,h2 .small,.h2 .small,h3 .small,.h3 .small{font-size:65%}h4,.h4,h5,.h5,h6,.h6{margin-top:10px;margin-bottom:10px}h4 small,.h4 small,h5 small,.h5 small,h6 small,.h6 small,h4 .small,.h4 .small,h5 .small,.h5 .small,h6 .small,.h6 .small{font-size:75%}h1,.h1{font-size:36px}h2,.h2{font-size:30px}h3,.h3{font-size:24px}h4,.h4{font-size:18px}h5,.h5{font-size:14px}h6,.h6{font-size:12px}p{margin:0 0 10px}.lead{margin-bottom:20px;font-size:16px;font-weight:300;line-height:1.4}@media(min-width:768px){.lead{font-size:21px}}small,.small{font-size:85%}mark,.mark{background-color:#fcf8e3;padding:.2em}.text-left{text-align:left}.text-right{text-align:right}.text-center{text-align:center}.text-justify{text-align:justify}.text-nowrap{white-space:nowrap}.text-lowercase{
text-transform:lowercase}.text-uppercase{text-transform:uppercase}.text-capitalize{text-transform:capitalize}.text-muted{color:#777}.text-primary{color:#871e32}a.text-primary:hover,a.text-primary:focus{color:#5d1523}.text-success{color:#3c763d}a.text-success:hover,a.text-success:focus{color:#2b542c}.text-info{color:#31708f}a.text-info:hover,a.text-info:focus{color:#245269}.text-warning{color:#8a6d3b}a.text-warning:hover,a.text-warning:focus{color:#66512c}.text-danger{color:#a94442}a.text-danger:hover,a.text-danger:focus{color:#843534}.bg-primary{color:#fff;background-color:#871e32}a.bg-primary:hover,a.bg-primary:focus{background-color:#5d1523}.bg-success{background-color:#dff0d8}a.bg-success:hover,a.bg-success:focus{background-color:#c1e2b3}.bg-info{background-color:#d9edf7}a.bg-info:hover,a.bg-info:focus{background-color:#afd9ee}.bg-warning{background-color:#fcf8e3}a.bg-warning:hover,a.bg-warning:focus{background-color:#f7ecb5}.bg-danger{background-color:#f2dede}a.bg-danger:hover,a
.bg-danger:focus{background-color:#e4b9b9}.page-header{padding-bottom:9px;margin:40px 0 20px;border-bottom:1px solid #eee}ul,ol{margin-top:0;margin-bottom:10px}ul ul,ol ul,ul ol,ol ol{margin-bottom:0}.list-unstyled{padding-left:0;list-style:none}.list-inline{padding-left:0;list-style:none;margin-left:-5px}.list-inline>li{display:inline-block;padding-left:5px;padding-right:5px}dl{margin-top:0;margin-bottom:20px}dt,dd{line-height:1.42857143}dt{font-weight:bold}dd{margin-left:0}@media(min-width:768px){.dl-horizontal dt{float:left;width:160px;clear:left;text-align:right;overflow:hidden;text-overflow:ellipsis;white-space:nowrap}.dl-horizontal dd{margin-left:180px}}abbr[title],abbr[data-original-title]{cursor:help;border-bottom:1px dotted #777}.initialism{font-size:90%;text-transform:uppercase}blockquote{padding:10px 20px;margin:0 0 20px;font-size:17.5px;border-left:5px solid #eee}blockquote p:last-child,blockquote ul:last-child,blockquote ol:last-child{margin-bottom:0}blockquote footer,b
lockquote small,blockquote .small{display:block;font-size:80%;line-height:1.42857143;color:#777}blockquote footer:before,blockquote small:before,blockquote .small:before{content:'\2014 \00A0'}.blockquote-reverse,blockquote.pull-right{padding-right:15px;padding-left:0;border-right:5px solid #eee;border-left:0;text-align:right}.blockquote-reverse footer:before,blockquote.pull-right footer:before,.blockquote-reverse small:before,blockquote.pull-right small:before,.blockquote-reverse .small:before,blockquote.pull-right .small:before{content:''}.blockquote-reverse footer:after,blockquote.pull-right footer:after,.blockquote-reverse small:after,blockquote.pull-right small:after,.blockquote-reverse .small:after,blockquote.pull-right .small:after{content:'\00A0 \2014'}address{margin-bottom:20px;font-style:normal;line-height:1.42857143}code,kbd,pre,samp{font-family:Menlo,Monaco,Consolas,"Courier New",monospace}code{padding:2px 4px;font-size:90%;color:#c7254e;background-color:#f9f2f4;border-ra
dius:4px}kbd{padding:2px 4px;font-size:90%;color:#fff;background-color:#333;border-radius:3px;box-shadow:inset 0 -1px 0 rgba(0,0,0,0.25)}kbd kbd{padding:0;font-size:100%;font-weight:bold;box-shadow:none}pre{display:block;padding:9.5px;margin:0 0 10px;font-size:13px;line-height:1.42857143;word-break:break-all;word-wrap:break-word;color:#333;background-color:#f5f5f5;border:1px solid #ccc;border-radius:4px}pre code{padding:0;font-size:inherit;color:inherit;white-space:pre-wrap;background-color:transparent;border-radius:0}.pre-scrollable{max-height:340px;overflow-y:scroll}.container{margin-right:auto;margin-left:auto;padding-left:15px;padding-right:15px}@media(min-width:768px){.container{width:750px}}@media(min-width:992px){.container{width:970px}}@media(min-width:1200px){.container{width:1170px}}.container-fluid{margin-right:auto;margin-left:auto;padding-left:15px;padding-right:15px}.row{margin-left:-15px;margin-right:-15px}.col-xs-1,.col-sm-1,.col-md-1,.col-lg-1,.col-xs-2,.col-sm-2,.c
ol-md-2,.col-lg-2,.col-xs-3,.col-sm-3,.col-md-3,.col-lg-3,.col-xs-4,.col-sm-4,.col-md-4,.col-lg-4,.col-xs-5,.col-sm-5,.col-md-5,.col-lg-5,.col-xs-6,.col-sm-6,.col-md-6,.col-lg-6,.col-xs-7,.col-sm-7,.col-md-7,.col-lg-7,.col-xs-8,.col-sm-8,.col-md-8,.col-lg-8,.col-xs-9,.col-sm-9,.col-md-9,.col-lg-9,.col-xs-10,.col-sm-10,.col-md-10,.col-lg-10,.col-xs-11,.col-sm-11,.col-md-11,.col-lg-11,.col-xs-12,.col-sm-12,.col-md-12,.col-lg-12{position:relative;min-height:1px;padding-left:15px;padding-right:15px}.col-xs-1,.col-xs-2,.col-xs-3,.col-xs-4,.col-xs-5,.col-xs-6,.col-xs-7,.col-xs-8,.col-xs-9,.col-xs-10,.col-xs-11,.col-xs-12{float:left}.col-xs-12{width:100%}.col-xs-11{width:91.66666667%}.col-xs-10{width:83.33333333%}.col-xs-9{width:75%}.col-xs-8{width:66.66666667%}.col-xs-7{width:58.33333333%}.col-xs-6{width:50%}.col-xs-5{width:41.66666667%}.col-xs-4{width:33.33333333%}.col-xs-3{width:25%}.col-xs-2{width:16.66666667%}.col-xs-1{width:8.33333333%}.col-xs-pull-12{right:100%}.col-xs-pull-11{right
:91.66666667%}.col-xs-pull-10{right:83.33333333%}.col-xs-pull-9{right:75%}.col-xs-pull-8{right:66.66666667%}.col-xs-pull-7{right:58.33333333%}.col-xs-pull-6{right:50%}.col-xs-pull-5{right:41.66666667%}.col-xs-pull-4{right:33.33333333%}.col-xs-pull-3{right:25%}.col-xs-pull-2{right:16.66666667%}.col-xs-pull-1{right:8.33333333%}.col-xs-pull-0{right:auto}.col-xs-push-12{left:100%}.col-xs-push-11{left:91.66666667%}.col-xs-push-10{left:83.33333333%}.col-xs-push-9{left:75%}.col-xs-push-8{left:66.66666667%}.col-xs-push-7{left:58.33333333%}.col-xs-push-6{left:50%}.col-xs-push-5{left:41.66666667%}.col-xs-push-4{left:33.33333333%}.col-xs-push-3{left:25%}.col-xs-push-2{left:16.66666667%}.col-xs-push-1{left:8.33333333%}.col-xs-push-0{left:auto}.col-xs-offset-12{margin-left:100%}.col-xs-offset-11{margin-left:91.66666667%}.col-xs-offset-10{margin-left:83.33333333%}.col-xs-offset-9{margin-left:75%}.col-xs-offset-8{margin-left:66.66666667%}.col-xs-offset-7{margin-left:58.33333333%}.col-xs-offset-6{m
argin-left:50%}.col-xs-offset-5{margin-left:41.66666667%}.col-xs-offset-4{margin-left:33.33333333%}.col-xs-offset-3{margin-left:25%}.col-xs-offset-2{margin-left:16.66666667%}.col-xs-offset-1{margin-left:8.33333333%}.col-xs-offset-0{margin-left:0}@media(min-width:768px){.col-sm-1,.col-sm-2,.col-sm-3,.col-sm-4,.col-sm-5,.col-sm-6,.col-sm-7,.col-sm-8,.col-sm-9,.col-sm-10,.col-sm-11,.col-sm-12{float:left}.col-sm-12{width:100%}.col-sm-11{width:91.66666667%}.col-sm-10{width:83.33333333%}.col-sm-9{width:75%}.col-sm-8{width:66.66666667%}.col-sm-7{width:58.33333333%}.col-sm-6{width:50%}.col-sm-5{width:41.66666667%}.col-sm-4{width:33.33333333%}.col-sm-3{width:25%}.col-sm-2{width:16.66666667%}.col-sm-1{width:8.33333333%}.col-sm-pull-12{right:100%}.col-sm-pull-11{right:91.66666667%}.col-sm-pull-10{right:83.33333333%}.col-sm-pull-9{right:75%}.col-sm-pull-8{right:66.66666667%}.col-sm-pull-7{right:58.33333333%}.col-sm-pull-6{right:50%}.col-sm-pull-5{right:41.66666667%}.col-sm-pull-4{right:33.33333
333%}.col-sm-pull-3{right:25%}.col-sm-pull-2{right:16.66666667%}.col-sm-pull-1{right:8.33333333%}.col-sm-pull-0{right:auto}.col-sm-push-12{left:100%}.col-sm-push-11{left:91.66666667%}.col-sm-push-10{left:83.33333333%}.col-sm-push-9{left:75%}.col-sm-push-8{left:66.66666667%}.col-sm-push-7{left:58.33333333%}.col-sm-push-6{left:50%}.col-sm-push-5{left:41.66666667%}.col-sm-push-4{left:33.33333333%}.col-sm-push-3{left:25%}.col-sm-push-2{left:16.66666667%}.col-sm-push-1{left:8.33333333%}.col-sm-push-0{left:auto}.col-sm-offset-12{margin-left:100%}.col-sm-offset-11{margin-left:91.66666667%}.col-sm-offset-10{margin-left:83.33333333%}.col-sm-offset-9{margin-left:75%}.col-sm-offset-8{margin-left:66.66666667%}.col-sm-offset-7{margin-left:58.33333333%}.col-sm-offset-6{margin-left:50%}.col-sm-offset-5{margin-left:41.66666667%}.col-sm-offset-4{margin-left:33.33333333%}.col-sm-offset-3{margin-left:25%}.col-sm-offset-2{margin-left:16.66666667%}.col-sm-offset-1{margin-left:8.33333333%}.col-sm-offset-
0{margin-left:0}}@media(min-width:992px){.col-md-1,.col-md-2,.col-md-3,.col-md-4,.col-md-5,.col-md-6,.col-md-7,.col-md-8,.col-md-9,.col-md-10,.col-md-11,.col-md-12{float:left}.col-md-12{width:100%}.col-md-11{width:91.66666667%}.col-md-10{width:83.33333333%}.col-md-9{width:75%}.col-md-8{width:66.66666667%}.col-md-7{width:58.33333333%}.col-md-6{width:50%}.col-md-5{width:41.66666667%}.col-md-4{width:33.33333333%}.col-md-3{width:25%}.col-md-2{width:16.66666667%}.col-md-1{width:8.33333333%}.col-md-pull-12{right:100%}.col-md-pull-11{right:91.66666667%}.col-md-pull-10{right:83.33333333%}.col-md-pull-9{right:75%}.col-md-pull-8{right:66.66666667%}.col-md-pull-7{right:58.33333333%}.col-md-pull-6{right:50%}.col-md-pull-5{right:41.66666667%}.col-md-pull-4{right:33.33333333%}.col-md-pull-3{right:25%}.col-md-pull-2{right:16.66666667%}.col-md-pull-1{right:8.33333333%}.col-md-pull-0{right:auto}.col-md-push-12{left:100%}.col-md-push-11{left:91.66666667%}.col-md-push-10{left:83.33333333%}.col-md-push
-9{left:75%}.col-md-push-8{left:66.66666667%}.col-md-push-7{left:58.33333333%}.col-md-push-6{left:50%}.col-md-push-5{left:41.66666667%}.col-md-push-4{left:33.33333333%}.col-md-push-3{left:25%}.col-md-push-2{left:16.66666667%}.col-md-push-1{left:8.33333333%}.col-md-push-0{left:auto}.col-md-offset-12{margin-left:100%}.col-md-offset-11{margin-left:91.66666667%}.col-md-offset-10{margin-left:83.33333333%}.col-md-offset-9{margin-left:75%}.col-md-offset-8{margin-left:66.66666667%}.col-md-offset-7{margin-left:58.33333333%}.col-md-offset-6{margin-left:50%}.col-md-offset-5{margin-left:41.66666667%}.col-md-offset-4{margin-left:33.33333333%}.col-md-offset-3{margin-left:25%}.col-md-offset-2{margin-left:16.66666667%}.col-md-offset-1{margin-left:8.33333333%}.col-md-offset-0{margin-left:0}}@media(min-width:1200px){.col-lg-1,.col-lg-2,.col-lg-3,.col-lg-4,.col-lg-5,.col-lg-6,.col-lg-7,.col-lg-8,.col-lg-9,.col-lg-10,.col-lg-11,.col-lg-12{float:left}.col-lg-12{width:100%}.col-lg-11{width:91.66666667%}.
col-lg-10{width:83.33333333%}.col-lg-9{width:75%}.col-lg-8{width:66.66666667%}.col-lg-7{width:58.33333333%}.col-lg-6{width:50%}.col-lg-5{width:41.66666667%}.col-lg-4{width:33.33333333%}.col-lg-3{width:25%}.col-lg-2{width:16.66666667%}.col-lg-1{width:8.33333333%}.col-lg-pull-12{right:100%}.col-lg-pull-11{right:91.66666667%}.col-lg-pull-10{right:83.33333333%}.col-lg-pull-9{right:75%}.col-lg-pull-8{right:66.66666667%}.col-lg-pull-7{right:58.33333333%}.col-lg-pull-6{right:50%}.col-lg-pull-5{right:41.66666667%}.col-lg-pull-4{right:33.33333333%}.col-lg-pull-3{right:25%}.col-lg-pull-2{right:16.66666667%}.col-lg-pull-1{right:8.33333333%}.col-lg-pull-0{right:auto}.col-lg-push-12{left:100%}.col-lg-push-11{left:91.66666667%}.col-lg-push-10{left:83.33333333%}.col-lg-push-9{left:75%}.col-lg-push-8{left:66.66666667%}.col-lg-push-7{left:58.33333333%}.col-lg-push-6{left:50%}.col-lg-push-5{left:41.66666667%}.col-lg-push-4{left:33.33333333%}.col-lg-push-3{left:25%}.col-lg-push-2{left:16.66666667%}.co
l-lg-push-1{left:8.33333333%}.col-lg-push-0{left:auto}.col-lg-offset-12{margin-left:100%}.col-lg-offset-11{margin-left:91.66666667%}.col-lg-offset-10{margin-left:83.33333333%}.col-lg-offset-9{margin-left:75%}.col-lg-offset-8{margin-left:66.66666667%}.col-lg-offset-7{margin-left:58.33333333%}.col-lg-offset-6{margin-left:50%}.col-lg-offset-5{margin-left:41.66666667%}.col-lg-offset-4{margin-left:33.33333333%}.col-lg-offset-3{margin-left:25%}.col-lg-offset-2{margin-left:16.66666667%}.col-lg-offset-1{margin-left:8.33333333%}.col-lg-offset-0{margin-left:0}}table{background-color:transparent}caption{padding-top:8px;padding-bottom:8px;color:#777;text-align:left}th{text-align:left}.table{width:100%;max-width:100%;margin-bottom:20px}.table>thead>tr>th,.table>tbody>tr>th,.table>tfoot>tr>th,.table>thead>tr>td,.table>tbody>tr>td,.table>tfoot>tr>td{padding:8px;line-height:1.42857143;vertical-align:top;border-top:1px solid #ddd}.table>thead>tr>th{vertical-align:bottom;border-bottom:2px solid #ddd}
.table>caption+thead>tr:first-child>th,.table>colgroup+thead>tr:first-child>th,.table>thead:first-child>tr:first-child>th,.table>caption+thead>tr:first-child>td,.table>colgroup+thead>tr:first-child>td,.table>thead:first-child>tr:first-child>td{border-top:0}.table>tbody+tbody{border-top:2px solid #ddd}.table .table{background-color:#fff}.table-condensed>thead>tr>th,.table-condensed>tbody>tr>th,.table-condensed>tfoot>tr>th,.table-condensed>thead>tr>td,.table-condensed>tbody>tr>td,.table-condensed>tfoot>tr>td{padding:5px}.table-bordered{border:1px solid #ddd}.table-bordered>thead>tr>th,.table-bordered>tbody>tr>th,.table-bordered>tfoot>tr>th,.table-bordered>thead>tr>td,.table-bordered>tbody>tr>td,.table-bordered>tfoot>tr>td{border:1px solid #ddd}.table-bordered>thead>tr>th,.table-bordered>thead>tr>td{border-bottom-width:2px}.table-striped>tbody>tr:nth-of-type(odd){background-color:#f9f9f9}.table-hover>tbody>tr:hover{background-color:#f5f5f5}table col[class*="col-"]{position:static;float
:none;display:table-column}table td[class*="col-"],table th[class*="col-"]{position:static;float:none;display:table-cell}.table>thead>tr>td.active,.table>tbody>tr>td.active,.table>tfoot>tr>td.active,.table>thead>tr>th.active,.table>tbody>tr>th.active,.table>tfoot>tr>th.active,.table>thead>tr.active>td,.table>tbody>tr.active>td,.table>tfoot>tr.active>td,.table>thead>tr.active>th,.table>tbody>tr.active>th,.table>tfoot>tr.active>th{background-color:#f5f5f5}.table-hover>tbody>tr>td.active:hover,.table-hover>tbody>tr>th.active:hover,.table-hover>tbody>tr.active:hover>td,.table-hover>tbody>tr:hover>.active,.table-hover>tbody>tr.active:hover>th{background-color:#e8e8e8}.table>thead>tr>td.success,.table>tbody>tr>td.success,.table>tfoot>tr>td.success,.table>thead>tr>th.success,.table>tbody>tr>th.success,.table>tfoot>tr>th.success,.table>thead>tr.success>td,.table>tbody>tr.success>td,.table>tfoot>tr.success>td,.table>thead>tr.success>th,.table>tbody>tr.success>th,.table>tfoot>tr.success>th{ba
ckground-color:#dff0d8}.table-hover>tbody>tr>td.success:hover,.table-hover>tbody>tr>th.success:hover,.table-hover>tbody>tr.success:hover>td,.table-hover>tbody>tr:hover>.success,.table-hover>tbody>tr.success:hover>th{background-color:#d0e9c6}.table>thead>tr>td.info,.table>tbody>tr>td.info,.table>tfoot>tr>td.info,.table>thead>tr>th.info,.table>tbody>tr>th.info,.table>tfoot>tr>th.info,.table>thead>tr.info>td,.table>tbody>tr.info>td,.table>tfoot>tr.info>td,.table>thead>tr.info>th,.table>tbody>tr.info>th,.table>tfoot>tr.info>th{background-color:#d9edf7}.table-hover>tbody>tr>td.info:hover,.table-hover>tbody>tr>th.info:hover,.table-hover>tbody>tr.info:hover>td,.table-hover>tbody>tr:hover>.info,.table-hover>tbody>tr.info:hover>th{background-color:#c4e3f3}.table>thead>tr>td.warning,.table>tbody>tr>td.warning,.table>tfoot>tr>td.warning,.table>thead>tr>th.warning,.table>tbody>tr>th.warning,.table>tfoot>tr>th.warning,.table>thead>tr.warning>td,.table>tbody>tr.warning>td,.table>tfoot>tr.warning>
td,.table>thead>tr.warning>th,.table>tbody>tr.warning>th,.table>tfoot>tr.warning>th{background-color:#fcf8e3}.table-hover>tbody>tr>td.warning:hover,.table-hover>tbody>tr>th.warning:hover,.table-hover>tbody>tr.warning:hover>td,.table-hover>tbody>tr:hover>.warning,.table-hover>tbody>tr.warning:hover>th{background-color:#faf2cc}.table>thead>tr>td.danger,.table>tbody>tr>td.danger,.table>tfoot>tr>td.danger,.table>thead>tr>th.danger,.table>tbody>tr>th.danger,.table>tfoot>tr>th.danger,.table>thead>tr.danger>td,.table>tbody>tr.danger>td,.table>tfoot>tr.danger>td,.table>thead>tr.danger>th,.table>tbody>tr.danger>th,.table>tfoot>tr.danger>th{background-color:#f2dede}.table-hover>tbody>tr>td.danger:hover,.table-hover>tbody>tr>th.danger:hover,.table-hover>tbody>tr.danger:hover>td,.table-hover>tbody>tr:hover>.danger,.table-hover>tbody>tr.danger:hover>th{background-color:#ebcccc}.table-responsive{overflow-x:auto;min-height:.01%}@media screen and (max-width:767px){.table-responsive{width:100%;margi
n-bottom:15px;overflow-y:hidden;-ms-overflow-style:-ms-autohiding-scrollbar;border:1px solid #ddd}.table-responsive>.table{margin-bottom:0}.table-responsive>.table>thead>tr>th,.table-responsive>.table>tbody>tr>th,.table-responsive>.table>tfoot>tr>th,.table-responsive>.table>thead>tr>td,.table-responsive>.table>tbody>tr>td,.table-responsive>.table>tfoot>tr>td{white-space:nowrap}.table-responsive>.table-bordered{border:0}.table-responsive>.table-bordered>thead>tr>th:first-child,.table-responsive>.table-bordered>tbody>tr>th:first-child,.table-responsive>.table-bordered>tfoot>tr>th:first-child,.table-responsive>.table-bordered>thead>tr>td:first-child,.table-responsive>.table-bordered>tbody>tr>td:first-child,.table-responsive>.table-bordered>tfoot>tr>td:first-child{border-left:0}.table-responsive>.table-bordered>thead>tr>th:last-child,.table-responsive>.table-bordered>tbody>tr>th:last-child,.table-responsive>.table-bordered>tfoot>tr>th:last-child,.table-responsive>.table-bordered>thead>t
r>td:last-child,.table-responsive>.table-bordered>tbody>tr>td:last-child,.table-responsive>.table-bordered>tfoot>tr>td:last-child{border-right:0}.table-responsive>.table-bordered>tbody>tr:last-child>th,.table-responsive>.table-bordered>tfoot>tr:last-child>th,.table-responsive>.table-bordered>tbody>tr:last-child>td,.table-responsive>.table-bordered>tfoot>tr:last-child>td{border-bottom:0}}fieldset{padding:0;margin:0;border:0;min-width:0}legend{display:block;width:100%;padding:0;margin-bottom:20px;font-size:21px;line-height:inherit;color:#333;border:0;border-bottom:1px solid #e5e5e5}label{display:inline-block;max-width:100%;margin-bottom:5px;font-weight:bold}input[type="search"]{-webkit-box-sizing:border-box;-moz-box-sizing:border-box;box-sizing:border-box}input[type="radio"],input[type="checkbox"]{margin:4px 0 0;margin-top:1px \9;line-height:normal}input[type="file"]{display:block}input[type="range"]{display:block;width:100%}select[multiple],select[size]{height:auto}input[type="file"]
:focus,input[type="radio"]:focus,input[type="checkbox"]:focus{outline:5px auto -webkit-focus-ring-color;outline-offset:-2px}output{display:block;padding-top:7px;font-size:14px;line-height:1.42857143;color:#555}.form-control{display:block;width:100%;height:34px;padding:6px 12px;font-size:14px;line-height:1.42857143;color:#555;background-color:#fff;background-image:none;border:1px solid #ccc;border-radius:4px;-webkit-box-shadow:inset 0 1px 1px rgba(0,0,0,0.075);box-shadow:inset 0 1px 1px rgba(0,0,0,0.075);-webkit-transition:border-color ease-in-out .15s,box-shadow ease-in-out .15s;-o-transition:border-color ease-in-out .15s,box-shadow ease-in-out .15s;transition:border-color ease-in-out .15s,box-shadow ease-in-out .15s}.form-control:focus{border-color:#d82d4c;outline:0;-webkit-box-shadow:inset 0 1px 1px rgba(0,0,0,.075),0 0 8px rgba(216,45,76,0.6);box-shadow:inset 0 1px 1px rgba(0,0,0,.075),0 0 8px rgba(216,45,76,0.6)}.form-control::-moz-placeholder{color:#999;opacity:1}.form-control:
-ms-input-placeholder{color:#999}.form-control::-webkit-input-placeholder{color:#999}.form-control::-ms-expand{border:0;background-color:transparent}.form-control[disabled],.form-control[readonly],fieldset[disabled] .form-control{background-color:#eee;opacity:1}.form-control[disabled],fieldset[disabled] .form-control{cursor:not-allowed}textarea.form-control{height:auto}input[type="search"]{-webkit-appearance:none}@media screen and (-webkit-min-device-pixel-ratio:0){input[type="date"].form-control,input[type="time"].form-control,input[type="datetime-local"].form-control,input[type="month"].form-control{line-height:34px}input[type="date"].input-sm,input[type="time"].input-sm,input[type="datetime-local"].input-sm,input[type="month"].input-sm,.input-group-sm input[type="date"],.input-group-sm input[type="time"],.input-group-sm input[type="datetime-local"],.input-group-sm input[type="month"]{line-height:30px}input[type="date"].input-lg,input[type="time"].input-lg,input[type="datetime-loc
al"].input-lg,input[type="month"].input-lg,.input-group-lg input[type="date"],.input-group-lg input[type="time"],.input-group-lg input[type="datetime-local"],.input-group-lg input[type="month"]{line-height:46px}}.form-group{margin-bottom:15px}.radio,.checkbox{position:relative;display:block;margin-top:10px;margin-bottom:10px}.radio label,.checkbox label{min-height:20px;padding-left:20px;margin-bottom:0;font-weight:normal;cursor:pointer}.radio input[type="radio"],.radio-inline input[type="radio"],.checkbox input[type="checkbox"],.checkbox-inline input[type="checkbox"]{position:absolute;margin-left:-20px;margin-top:4px \9}.radio+.radio,.checkbox+.checkbox{margin-top:-5px}.radio-inline,.checkbox-inline{position:relative;display:inline-block;padding-left:20px;margin-bottom:0;vertical-align:middle;font-weight:normal;cursor:pointer}.radio-inline+.radio-inline,.checkbox-inline+.checkbox-inline{margin-top:0;margin-left:10px}input[type="radio"][disabled],input[type="checkbox"][disabled],inpu
t[type="radio"].disabled,input[type="checkbox"].disabled,fieldset[disabled] input[type="radio"],fieldset[disabled] input[type="checkbox"]{cursor:not-allowed}.radio-inline.disabled,.checkbox-inline.disabled,fieldset[disabled] .radio-inline,fieldset[disabled] .checkbox-inline{cursor:not-allowed}.radio.disabled label,.checkbox.disabled label,fieldset[disabled] .radio label,fieldset[disabled] .checkbox label{cursor:not-allowed}.form-control-static{padding-top:7px;padding-bottom:7px;margin-bottom:0;min-height:34px}.form-control-static.input-lg,.form-control-static.input-sm{padding-left:0;padding-right:0}.input-sm{height:30px;padding:5px 10px;font-size:12px;line-height:1.5;border-radius:3px}select.input-sm{height:30px;line-height:30px}textarea.input-sm,select[multiple].input-sm{height:auto}.form-group-sm .form-control{height:30px;padding:5px 10px;font-size:12px;line-height:1.5;border-radius:3px}.form-group-sm select.form-control{height:30px;line-height:30px}.form-group-sm textarea.form-co
ntrol,.form-group-sm select[multiple].form-control{height:auto}.form-group-sm .form-control-static{height:30px;min-height:32px;padding:6px 10px;font-size:12px;line-height:1.5}.input-lg{height:46px;padding:10px 16px;font-size:18px;line-height:1.3333333;border-radius:6px}select.input-lg{height:46px;line-height:46px}textarea.input-lg,select[multiple].input-lg{height:auto}.form-group-lg .form-control{height:46px;padding:10px 16px;font-size:18px;line-height:1.3333333;border-radius:6px}.form-group-lg select.form-control{height:46px;line-height:46px}.form-group-lg textarea.form-control,.form-group-lg select[multiple].form-control{height:auto}.form-group-lg .form-control-static{height:46px;min-height:38px;padding:11px 16px;font-size:18px;line-height:1.3333333}.has-feedback{position:relative}.has-feedback .form-control{padding-right:42.5px}.form-control-feedback{position:absolute;top:0;right:0;z-index:2;display:block;width:34px;height:34px;line-height:34px;text-align:center;pointer-events:no
ne}.input-lg+.form-control-feedback,.input-group-lg+.form-control-feedback,.form-group-lg .form-control+.form-control-feedback{width:46px;height:46px;line-height:46px}.input-sm+.form-control-feedback,.input-group-sm+.form-control-feedback,.form-group-sm .form-control+.form-control-feedback{width:30px;height:30px;line-height:30px}.has-success .help-block,.has-success .control-label,.has-success .radio,.has-success .checkbox,.has-success .radio-inline,.has-success .checkbox-inline,.has-success.radio label,.has-success.checkbox label,.has-success.radio-inline label,.has-success.checkbox-inline label{color:#3c763d}.has-success .form-control{border-color:#3c763d;-webkit-box-shadow:inset 0 1px 1px rgba(0,0,0,0.075);box-shadow:inset 0 1px 1px rgba(0,0,0,0.075)}.has-success .form-control:focus{border-color:#2b542c;-webkit-box-shadow:inset 0 1px 1px rgba(0,0,0,0.075),0 0 6px #67b168;box-shadow:inset 0 1px 1px rgba(0,0,0,0.075),0 0 6px #67b168}.has-success .input-group-addon{color:#3c763d;bor
der-color:#3c763d;background-color:#dff0d8}.has-success .form-control-feedback{color:#3c763d}.has-warning .help-block,.has-warning .control-label,.has-warning .radio,.has-warning .checkbox,.has-warning .radio-inline,.has-warning .checkbox-inline,.has-warning.radio label,.has-warning.checkbox label,.has-warning.radio-inline label,.has-warning.checkbox-inline label{color:#8a6d3b}.has-warning .form-control{border-color:#8a6d3b;-webkit-box-shadow:inset 0 1px 1px rgba(0,0,0,0.075);box-shadow:inset 0 1px 1px rgba(0,0,0,0.075)}.has-warning .form-control:focus{border-color:#66512c;-webkit-box-shadow:inset 0 1px 1px rgba(0,0,0,0.075),0 0 6px #c0a16b;box-shadow:inset 0 1px 1px rgba(0,0,0,0.075),0 0 6px #c0a16b}.has-warning .input-group-addon{color:#8a6d3b;border-color:#8a6d3b;background-color:#fcf8e3}.has-warning .form-control-feedback{color:#8a6d3b}.has-error .help-block,.has-error .control-label,.has-error .radio,.has-error .checkbox,.has-error .radio-inline,.has-error .checkbox-inline,.has
-error.radio label,.has-error.checkbox label,.has-error.radio-inline label,.has-error.checkbox-inline label{color:#a94442}.has-error .form-control{border-color:#a94442;-webkit-box-shadow:inset 0 1px 1px rgba(0,0,0,0.075);box-shadow:inset 0 1px 1px rgba(0,0,0,0.075)}.has-error .form-control:focus{border-color:#843534;-webkit-box-shadow:inset 0 1px 1px rgba(0,0,0,0.075),0 0 6px #ce8483;box-shadow:inset 0 1px 1px rgba(0,0,0,0.075),0 0 6px #ce8483}.has-error .input-group-addon{color:#a94442;border-color:#a94442;background-color:#f2dede}.has-error .form-control-feedback{color:#a94442}.has-feedback label ~ .form-control-feedback{top:25px}.has-feedback label.sr-only ~ .form-control-feedback{top:0}.help-block{display:block;margin-top:5px;margin-bottom:10px;color:#737373}@media(min-width:768px){.form-inline .form-group{display:inline-block;margin-bottom:0;vertical-align:middle}.form-inline .form-control{display:inline-block;width:auto;vertical-align:middle}.form-inline .form-control-static{d
isplay:inline-block}.form-inline .input-group{display:inline-table;vertical-align:middle}.form-inline .input-group .input-group-addon,.form-inline .input-group .input-group-btn,.form-inline .input-group .form-control{width:auto}.form-inline .input-group>.form-control{width:100%}.form-inline .control-label{margin-bottom:0;vertical-align:middle}.form-inline .radio,.form-inline .checkbox{display:inline-block;margin-top:0;margin-bottom:0;vertical-align:middle}.form-inline .radio label,.form-inline .checkbox label{padding-left:0}.form-inline .radio input[type="radio"],.form-inline .checkbox input[type="checkbox"]{position:relative;margin-left:0}.form-inline .has-feedback .form-control-feedback{top:0}}.form-horizontal .radio,.form-horizontal .checkbox,.form-horizontal .radio-inline,.form-horizontal .checkbox-inline{margin-top:0;margin-bottom:0;padding-top:7px}.form-horizontal .radio,.form-horizontal .checkbox{min-height:27px}.form-horizontal .form-group{margin-left:-15px;margin-right:-15p
x}@media(min-width:768px){.form-horizontal .control-label{text-align:right;margin-bottom:0;padding-top:7px}}.form-horizontal .has-feedback .form-control-feedback{right:15px}@media(min-width:768px){.form-horizontal .form-group-lg .control-label{padding-top:11px;font-size:18px}}@media(min-width:768px){.form-horizontal .form-group-sm .control-label{padding-top:6px;font-size:12px}}.btn{display:inline-block;margin-bottom:0;font-weight:normal;text-align:center;vertical-align:middle;touch-action:manipulation;cursor:pointer;background-image:none;border:1px solid transparent;white-space:nowrap;padding:6px 12px;font-size:14px;line-height:1.42857143;border-radius:4px;-webkit-user-select:none;-moz-user-select:none;-ms-user-select:none;user-select:none}.btn:focus,.btn:active:focus,.btn.active:focus,.btn.focus,.btn:active.focus,.btn.active.focus{outline:5px auto -webkit-focus-ring-color;outline-offset:-2px}.btn:hover,.btn:focus,.btn.focus{color:#333;text-decoration:none}.btn:active,.btn.active{ou
tline:0;background-image:none;-webkit-box-shadow:inset 0 3px 5px rgba(0,0,0,0.125);box-shadow:inset 0 3px 5px rgba(0,0,0,0.125)}.btn.disabled,.btn[disabled],fieldset[disabled] .btn{cursor:not-allowed;opacity:.65;filter:alpha(opacity=65);-webkit-box-shadow:none;box-shadow:none}a.btn.disabled,fieldset[disabled] a.btn{pointer-events:none}.btn-default{color:#333;background-color:#fff;border-color:#ccc}.btn-default:focus,.btn-default.focus{color:#333;background-color:#e6e6e6;border-color:#8c8c8c}.btn-default:hover{color:#333;background-color:#e6e6e6;border-color:#adadad}.btn-default:active,.btn-default.active,.open>.dropdown-toggle.btn-default{color:#333;background-color:#e6e6e6;border-color:#adadad}.btn-default:active:hover,.btn-default.active:hover,.open>.dropdown-toggle.btn-default:hover,.btn-default:active:focus,.btn-default.active:focus,.open>.dropdown-toggle.btn-default:focus,.btn-default:active.focus,.btn-default.active.focus,.open>.dropdown-toggle.btn-default.focus{color:#333;bac
kground-color:#d4d4d4;border-color:#8c8c8c}.btn-default:active,.btn-default.active,.open>.dropdown-toggle.btn-default{background-image:none}.btn-default.disabled:hover,.btn-default[disabled]:hover,fieldset[disabled] .btn-default:hover,.btn-default.disabled:focus,.btn-default[disabled]:focus,fieldset[disabled] .btn-default:focus,.btn-default.disabled.focus,.btn-default[disabled].focus,fieldset[disabled] .btn-default.focus{background-color:#fff;border-color:#ccc}.btn-default .badge{color:#fff;background-color:#333}.btn-primary{color:#fff;background-color:#871e32;border-color:#72192a}.btn-primary:focus,.btn-primary.focus{color:#fff;background-color:#5d1523;border-color:#0a0204}.btn-primary:hover{color:#fff;background-color:#5d1523;border-color:#400e18}.btn-primary:active,.btn-primary.active,.open>.dropdown-toggle.btn-primary{color:#fff;background-color:#5d1523;border-color:#400e18}.btn-primary:active:hover,.btn-primary.active:hover,.open>.dropdown-toggle.btn-primary:hover,.btn-primary:
active:focus,.btn-primary.active:focus,.open>.dropdown-toggle.btn-primary:focus,.btn-primary:active.focus,.btn-primary.active.focus,.open>.dropdown-toggle.btn-primary.focus{color:#fff;background-color:#400e18;border-color:#0a0204}.btn-primary:active,.btn-primary.active,.open>.dropdown-toggle.btn-primary{background-image:none}.btn-primary.disabled:hover,.btn-primary[disabled]:hover,fieldset[disabled] .btn-primary:hover,.btn-primary.disabled:focus,.btn-primary[disabled]:focus,fieldset[disabled] .btn-primary:focus,.btn-primary.disabled.focus,.btn-primary[disabled].focus,fieldset[disabled] .btn-primary.focus{background-color:#871e32;border-color:#72192a}.btn-primary .badge{color:#871e32;background-color:#fff}.btn-success{color:#fff;background-color:#5cb85c;border-color:#4cae4c}.btn-success:focus,.btn-success.focus{color:#fff;background-color:#449d44;border-color:#255625}.btn-success:hover{color:#fff;background-color:#449d44;border-color:#398439}.btn-success:active,.btn-success.active,.o
pen>.dropdown-toggle.btn-success{color:#fff;background-color:#449d44;border-color:#398439}.btn-success:active:hover,.btn-success.active:hover,.open>.dropdown-toggle.btn-success:hover,.btn-success:active:focus,.btn-success.active:focus,.open>.dropdown-toggle.btn-success:focus,.btn-success:active.focus,.btn-success.active.focus,.open>.dropdown-toggle.btn-success.focus{color:#fff;background-color:#398439;border-color:#255625}.btn-success:active,.btn-success.active,.open>.dropdown-toggle.btn-success{background-image:none}.btn-success.disabled:hover,.btn-success[disabled]:hover,fieldset[disabled] .btn-success:hover,.btn-success.disabled:focus,.btn-success[disabled]:focus,fieldset[disabled] .btn-success:focus,.btn-success.disabled.focus,.btn-success[disabled].focus,fieldset[disabled] .btn-success.focus{background-color:#5cb85c;border-color:#4cae4c}.btn-success .badge{color:#5cb85c;background-color:#fff}.btn-info{color:#fff;background-color:#5bc0de;border-color:#46b8da}.btn-info:focus,.btn
-info.focus{color:#fff;background-color:#31b0d5;border-color:#1b6d85}.btn-info:hover{color:#fff;background-color:#31b0d5;border-color:#269abc}.btn-info:active,.btn-info.active,.open>.dropdown-toggle.btn-info{color:#fff;background-color:#31b0d5;border-color:#269abc}.btn-info:active:hover,.btn-info.active:hover,.open>.dropdown-toggle.btn-info:hover,.btn-info:active:focus,.btn-info.active:focus,.open>.dropdown-toggle.btn-info:focus,.btn-info:active.focus,.btn-info.active.focus,.open>.dropdown-toggle.btn-info.focus{color:#fff;background-color:#269abc;border-color:#1b6d85}.btn-info:active,.btn-info.active,.open>.dropdown-toggle.btn-info{background-image:none}.btn-info.disabled:hover,.btn-info[disabled]:hover,fieldset[disabled] .btn-info:hover,.btn-info.disabled:focus,.btn-info[disabled]:focus,fieldset[disabled] .btn-info:focus,.btn-info.disabled.focus,.btn-info[disabled].focus,fieldset[disabled] .btn-info.focus{background-color:#5bc0de;border-color:#46b8da}.btn-info .badge{color:#5bc0de;
background-color:#fff}.btn-warning{color:#fff;background-color:#f0ad4e;border-color:#eea236}.btn-warning:focus,.btn-warning.focus{color:#fff;background-color:#ec971f;border-color:#985f0d}.btn-warning:hover{color:#fff;background-color:#ec971f;border-color:#d58512}.btn-warning:active,.btn-warning.active,.open>.dropdown-toggle.btn-warning{color:#fff;background-color:#ec971f;border-color:#d58512}.btn-warning:active:hover,.btn-warning.active:hover,.open>.dropdown-toggle.btn-warning:hover,.btn-warning:active:focus,.btn-warning.active:focus,.open>.dropdown-toggle.btn-warning:focus,.btn-warning:active.focus,.btn-warning.active.focus,.open>.dropdown-toggle.btn-warning.focus{color:#fff;background-color:#d58512;border-color:#985f0d}.btn-warning:active,.btn-warning.active,.open>.dropdown-toggle.btn-warning{background-image:none}.btn-warning.disabled:hover,.btn-warning[disabled]:hover,fieldset[disabled] .btn-warning:hover,.btn-warning.disabled:focus,.btn-warning[disabled]:focus,fieldset[disabled
] .btn-warning:focus,.btn-warning.disabled.focus,.btn-warning[disabled].focus,fieldset[disabled] .btn-warning.focus{background-color:#f0ad4e;border-color:#eea236}.btn-warning .badge{color:#f0ad4e;background-color:#fff}.btn-danger{color:#fff;background-color:#d9534f;border-color:#d43f3a}.btn-danger:focus,.btn-danger.focus{color:#fff;background-color:#c9302c;border-color:#761c19}.btn-danger:hover{color:#fff;background-color:#c9302c;border-color:#ac2925}.btn-danger:active,.btn-danger.active,.open>.dropdown-toggle.btn-danger{color:#fff;background-color:#c9302c;border-color:#ac2925}.btn-danger:active:hover,.btn-danger.active:hover,.open>.dropdown-toggle.btn-danger:hover,.btn-danger:active:focus,.btn-danger.active:focus,.open>.dropdown-toggle.btn-danger:focus,.btn-danger:active.focus,.btn-danger.active.focus,.open>.dropdown-toggle.btn-danger.focus{color:#fff;background-color:#ac2925;border-color:#761c19}.btn-danger:active,.btn-danger.active,.open>.dropdown-toggle.btn-danger{background-ima
ge:none}.btn-danger.disabled:hover,.btn-danger[disabled]:hover,fieldset[disabled] .btn-danger:hover,.btn-danger.disabled:focus,.btn-danger[disabled]:focus,fieldset[disabled] .btn-danger:focus,.btn-danger.disabled.focus,.btn-danger[disabled].focus,fieldset[disabled] .btn-danger.focus{background-color:#d9534f;border-color:#d43f3a}.btn-danger .badge{color:#d9534f;background-color:#fff}.btn-link{color:#871e32;font-weight:normal;border-radius:0}.btn-link,.btn-link:active,.btn-link.active,.btn-link[disabled],fieldset[disabled] .btn-link{background-color:transparent;-webkit-box-shadow:none;box-shadow:none}.btn-link,.btn-link:hover,.btn-link:focus,.btn-link:active{border-color:transparent}.btn-link:hover,.btn-link:focus{color:#48101b;text-decoration:underline;background-color:transparent}.btn-link[disabled]:hover,fieldset[disabled] .btn-link:hover,.btn-link[disabled]:focus,fieldset[disabled] .btn-link:focus{color:#777;text-decoration:none}.btn-lg,.btn-group-lg>.btn{padding:10px 16px;font-si
ze:18px;line-height:1.3333333;border-radius:6px}.btn-sm,.btn-group-sm>.btn{padding:5px 10px;font-size:12px;line-height:1.5;border-radius:3px}.btn-xs,.btn-group-xs>.btn{padding:1px 5px;font-size:12px;line-height:1.5;border-radius:3px}.btn-block{display:block;width:100%}.btn-block+.btn-block{margin-top:5px}input[type="submit"].btn-block,input[type="reset"].btn-block,input[type="button"].btn-block{width:100%}.fade{opacity:0;-webkit-transition:opacity .15s linear;-o-transition:opacity .15s linear;transition:opacity .15s linear}.fade.in{opacity:1}.collapse{display:none}.collapse.in{display:block}tr.collapse.in{display:table-row}tbody.collapse.in{display:table-row-group}.collapsing{position:relative;height:0;overflow:hidden;-webkit-transition-property:height,visibility;transition-property:height,visibility;-webkit-transition-duration:.35s;transition-duration:.35s;-webkit-transition-timing-function:ease;transition-timing-function:ease}.caret{display:inline-block;width:0;height:0;margin-lef
t:2px;vertical-align:middle;border-top:4px dashed;border-top:4px solid \9;border-right:4px solid transparent;border-left:4px solid transparent}.dropup,.dropdown{position:relative}.dropdown-toggle:focus{outline:0}.dropdown-menu{position:absolute;top:100%;left:0;z-index:1000;display:none;float:left;min-width:160px;padding:5px 0;margin:2px 0 0;list-style:none;font-size:14px;text-align:left;background-color:#fff;border:1px solid #ccc;border:1px solid rgba(0,0,0,0.15);border-radius:4px;-webkit-box-shadow:0 6px 12px rgba(0,0,0,0.175);box-shadow:0 6px 12px rgba(0,0,0,0.175);background-clip:padding-box}.dropdown-menu.pull-right{right:0;left:auto}.dropdown-menu .divider{height:1px;margin:9px 0;overflow:hidden;background-color:#e5e5e5}.dropdown-menu>li>a{display:block;padding:3px 20px;clear:both;font-weight:normal;line-height:1.42857143;color:#333;white-space:nowrap}.dropdown-menu>li>a:hover,.dropdown-menu>li>a:focus{text-decoration:none;color:#fff;background-color:#871d33}.dropdown-menu>.act
ive>a,.dropdown-menu>.active>a:hover,.dropdown-menu>.active>a:focus{color:#fff;text-decoration:none;outline:0;background-color:#871e32}.dropdown-menu>.disabled>a,.dropdown-menu>.disabled>a:hover,.dropdown-menu>.disabled>a:focus{color:#777}.dropdown-menu>.disabled>a:hover,.dropdown-menu>.disabled>a:focus{text-decoration:none;background-color:transparent;background-image:none;filter:progid:DXImageTransform.Microsoft.gradient(enabled = false);cursor:not-allowed}.open>.dropdown-menu{display:block}.open>a{outline:0}.dropdown-menu-right{left:auto;right:0}.dropdown-menu-left{left:0;right:auto}.dropdown-header{display:block;padding:3px 20px;font-size:12px;line-height:1.42857143;color:#777;white-space:nowrap}.dropdown-backdrop{position:fixed;left:0;right:0;bottom:0;top:0;z-index:990}.pull-right>.dropdown-menu{right:0;left:auto}.dropup .caret,.navbar-fixed-bottom .dropdown .caret{border-top:0;border-bottom:4px dashed;border-bottom:4px solid \9;content:""}.dropup .dropdown-menu,.navbar-fixed-b
ottom .dropdown .dropdown-menu{top:auto;bottom:100%;margin-bottom:2px}@media(min-width:768px){.navbar-right .dropdown-menu{left:auto;right:0}.navbar-right .dropdown-menu-left{left:0;right:auto}}.btn-group,.btn-group-vertical{position:relative;display:inline-block;vertical-align:middle}.btn-group>.btn,.btn-group-vertical>.btn{position:relative;float:left}.btn-group>.btn:hover,.btn-group-vertical>.btn:hover,.btn-group>.btn:focus,.btn-group-vertical>.btn:focus,.btn-group>.btn:active,.btn-group-vertical>.btn:active,.btn-group>.btn.active,.btn-group-vertical>.btn.active{z-index:2}.btn-group .btn+.btn,.btn-group .btn+.btn-group,.btn-group .btn-group+.btn,.btn-group .btn-group+.btn-group{margin-left:-1px}.btn-toolbar{margin-left:-5px}.btn-toolbar .btn,.btn-toolbar .btn-group,.btn-toolbar .input-group{float:left}.btn-toolbar>.btn,.btn-toolbar>.btn-group,.btn-toolbar>.input-group{margin-left:5px}.btn-group>.btn:not(:first-child):not(:last-child):not(.dropdown-toggle){border-radius:0}.btn-gro
up>.btn:first-child{margin-left:0}.btn-group>.btn:first-child:not(:last-child):not(.dropdown-toggle){border-bottom-right-radius:0;border-top-right-radius:0}.btn-group>.btn:last-child:not(:first-child),.btn-group>.dropdown-toggle:not(:first-child){border-bottom-left-radius:0;border-top-left-radius:0}.btn-group>.btn-group{float:left}.btn-group>.btn-group:not(:first-child):not(:last-child)>.btn{border-radius:0}.btn-group>.btn-group:first-child:not(:last-child)>.btn:last-child,.btn-group>.btn-group:first-child:not(:last-child)>.dropdown-toggle{border-bottom-right-radius:0;border-top-right-radius:0}.btn-group>.btn-group:last-child:not(:first-child)>.btn:first-child{border-bottom-left-radius:0;border-top-left-radius:0}.btn-group .dropdown-toggle:active,.btn-group.open .dropdown-toggle{outline:0}.btn-group>.btn+.dropdown-toggle{padding-left:8px;padding-right:8px}.btn-group>.btn-lg+.dropdown-toggle{padding-left:12px;padding-right:12px}.btn-group.open .dropdown-toggle{-webkit-box-shadow:inse
t 0 3px 5px rgba(0,0,0,0.125);box-shadow:inset 0 3px 5px rgba(0,0,0,0.125)}.btn-group.open .dropdown-toggle.btn-link{-webkit-box-shadow:none;box-shadow:none}.btn .caret{margin-left:0}.btn-lg .caret{border-width:5px 5px 0;border-bottom-width:0}.dropup .btn-lg .caret{border-width:0 5px 5px}.btn-group-vertical>.btn,.btn-group-vertical>.btn-group,.btn-group-vertical>.btn-group>.btn{display:block;float:none;width:100%;max-width:100%}.btn-group-vertical>.btn-group>.btn{float:none}.btn-group-vertical>.btn+.btn,.btn-group-vertical>.btn+.btn-group,.btn-group-vertical>.btn-group+.btn,.btn-group-vertical>.btn-group+.btn-group{margin-top:-1px;margin-left:0}.btn-group-vertical>.btn:not(:first-child):not(:last-child){border-radius:0}.btn-group-vertical>.btn:first-child:not(:last-child){border-top-right-radius:4px;border-top-left-radius:4px;border-bottom-right-radius:0;border-bottom-left-radius:0}.btn-group-vertical>.btn:last-child:not(:first-child){border-top-right-radius:0;border-top-left-radius
:0;border-bottom-right-radius:4px;border-bottom-left-radius:4px}.btn-group-vertical>.btn-group:not(:first-child):not(:last-child)>.btn{border-radius:0}.btn-group-vertical>.btn-group:first-child:not(:last-child)>.btn:last-child,.btn-group-vertical>.btn-group:first-child:not(:last-child)>.dropdown-toggle{border-bottom-right-radius:0;border-bottom-left-radius:0}.btn-group-vertical>.btn-group:last-child:not(:first-child)>.btn:first-child{border-top-right-radius:0;border-top-left-radius:0}.btn-group-justified{display:table;width:100%;table-layout:fixed;border-collapse:separate}.btn-group-justified>.btn,.btn-group-justified>.btn-group{float:none;display:table-cell;width:1%}.btn-group-justified>.btn-group .btn{width:100%}.btn-group-justified>.btn-group .dropdown-menu{left:auto}[data-toggle="buttons"]>.btn input[type="radio"],[data-toggle="buttons"]>.btn-group>.btn input[type="radio"],[data-toggle="buttons"]>.btn input[type="checkbox"],[data-toggle="buttons"]>.btn-group>.btn input[type="che
ckbox"]{position:absolute;clip:rect(0,0,0,0);pointer-events:none}.input-group{position:relative;display:table;border-collapse:separate}.input-group[class*="col-"]{float:none;padding-left:0;padding-right:0}.input-group .form-control{position:relative;z-index:2;float:left;width:100%;margin-bottom:0}.input-group .form-control:focus{z-index:3}.input-group-lg>.form-control,.input-group-lg>.input-group-addon,.input-group-lg>.input-group-btn>.btn{height:46px;padding:10px 16px;font-size:18px;line-height:1.3333333;border-radius:6px}select.input-group-lg>.form-control,select.input-group-lg>.input-group-addon,select.input-group-lg>.input-group-btn>.btn{height:46px;line-height:46px}textarea.input-group-lg>.form-control,textarea.input-group-lg>.input-group-addon,textarea.input-group-lg>.input-group-btn>.btn,select[multiple].input-group-lg>.form-control,select[multiple].input-group-lg>.input-group-addon,select[multiple].input-group-lg>.input-group-btn>.btn{height:auto}.input-group-sm>.form-contro
l,.input-group-sm>.input-group-addon,.input-group-sm>.input-group-btn>.btn{height:30px;padding:5px 10px;font-size:12px;line-height:1.5;border-radius:3px}select.input-group-sm>.form-control,select.input-group-sm>.input-group-addon,select.input-group-sm>.input-group-btn>.btn{height:30px;line-height:30px}textarea.input-group-sm>.form-control,textarea.input-group-sm>.input-group-addon,textarea.input-group-sm>.input-group-btn>.btn,select[multiple].input-group-sm>.form-control,select[multiple].input-group-sm>.input-group-addon,select[multiple].input-group-sm>.input-group-btn>.btn{height:auto}.input-group-addon,.input-group-btn,.input-group .form-control{display:table-cell}.input-group-addon:not(:first-child):not(:last-child),.input-group-btn:not(:first-child):not(:last-child),.input-group .form-control:not(:first-child):not(:last-child){border-radius:0}.input-group-addon,.input-group-btn{width:1%;white-space:nowrap;vertical-align:middle}.input-group-addon{padding:6px 12px;font-size:14px;f
ont-weight:normal;line-height:1;color:#555;text-align:center;background-color:#eee;border:1px solid #ccc;border-radius:4px}.input-group-addon.input-sm{padding:5px 10px;font-size:12px;border-radius:3px}.input-group-addon.input-lg{padding:10px 16px;font-size:18px;border-radius:6px}.input-group-addon input[type="radio"],.input-group-addon input[type="checkbox"]{margin-top:0}.input-group .form-control:first-child,.input-group-addon:first-child,.input-group-btn:first-child>.btn,.input-group-btn:first-child>.btn-group>.btn,.input-group-btn:first-child>.dropdown-toggle,.input-group-btn:last-child>.btn:not(:last-child):not(.dropdown-toggle),.input-group-btn:last-child>.btn-group:not(:last-child)>.btn{border-bottom-right-radius:0;border-top-right-radius:0}.input-group-addon:first-child{border-right:0}.input-group .form-control:last-child,.input-group-addon:last-child,.input-group-btn:last-child>.btn,.input-group-btn:last-child>.btn-group>.btn,.input-group-btn:last-child>.dropdown-toggle,.inp
ut-group-btn:first-child>.btn:not(:first-child),.input-group-btn:first-child>.btn-group:not(:first-child)>.btn{border-bottom-left-radius:0;border-top-left-radius:0}.input-group-addon:last-child{border-left:0}.input-group-btn{position:relative;font-size:0;white-space:nowrap}.input-group-btn>.btn{position:relative}.input-group-btn>.btn+.btn{margin-left:-1px}.input-group-btn>.btn:hover,.input-group-btn>.btn:focus,.input-group-btn>.btn:active{z-index:2}.input-group-btn:first-child>.btn,.input-group-btn:first-child>.btn-group{margin-right:-1px}.input-group-btn:last-child>.btn,.input-group-btn:last-child>.btn-group{z-index:2;margin-left:-1px}.nav{margin-bottom:0;padding-left:0;list-style:none}.nav>li{position:relative;display:block}.nav>li>a{position:relative;display:block;padding:10px 15px}.nav>li>a:hover,.nav>li>a:focus{text-decoration:none;background-color:#eee}.nav>li.disabled>a{color:#777}.nav>li.disabled>a:hover,.nav>li.disabled>a:focus{color:#777;text-decoration:none;background-col
or:transparent;cursor:not-allowed}.nav .open>a,.nav .open>a:hover,.nav .open>a:focus{background-color:#eee;border-color:#871e32}.nav .nav-divider{height:1px;margin:9px 0;overflow:hidden;background-color:#e5e5e5}.nav>li>a>img{max-width:none}.nav-tabs{border-bottom:1px solid #ddd}.nav-tabs>li{float:left;margin-bottom:-1px}.nav-tabs>li>a{margin-right:2px;line-height:1.42857143;border:1px solid transparent;border-radius:4px 4px 0 0}.nav-tabs>li>a:hover{border-color:#eee #eeeeee #ddd}.nav-tabs>li.active>a,.nav-tabs>li.active>a:hover,.nav-tabs>li.active>a:focus{color:#555;background-color:#fff;border:1px solid #ddd;border-bottom-color:transparent;cursor:default}.nav-tabs.nav-justified{width:100%;border-bottom:0}.nav-tabs.nav-justified>li{float:none}.nav-tabs.nav-justified>li>a{text-align:center;margin-bottom:5px}.nav-tabs.nav-justified>.dropdown .dropdown-menu{top:auto;left:auto}@media(min-width:768px){.nav-tabs.nav-justified>li{display:table-cell;width:1%}.nav-tabs.nav-justified>li>a{mar
gin-bottom:0}}.nav-tabs.nav-justified>li>a{margin-right:0;border-radius:4px}.nav-tabs.nav-justified>.active>a,.nav-tabs.nav-justified>.active>a:hover,.nav-tabs.nav-justified>.active>a:focus{border:1px solid #ddd}@media(min-width:768px){.nav-tabs.nav-justified>li>a{border-bottom:1px solid #ddd;border-radius:4px 4px 0 0}.nav-tabs.nav-justified>.active>a,.nav-tabs.nav-justified>.active>a:hover,.nav-tabs.nav-justified>.active>a:focus{border-bottom-color:#fff}}.nav-pills>li{float:left}.nav-pills>li>a{border-radius:4px}.nav-pills>li+li{margin-left:2px}.nav-pills>li.active>a,.nav-pills>li.active>a:hover,.nav-pills>li.active>a:focus{color:#fff;background-color:#871e32}.nav-stacked>li{float:none}.nav-stacked>li+li{margin-top:2px;margin-left:0}.nav-justified{width:100%}.nav-justified>li{float:none}.nav-justified>li>a{text-align:center;margin-bottom:5px}.nav-justified>.dropdown .dropdown-menu{top:auto;left:auto}@media(min-width:768px){.nav-justified>li{display:table-cell;width:1%}.nav-justifie
d>li>a{margin-bottom:0}}.nav-tabs-justified{border-bottom:0}.nav-tabs-justified>li>a{margin-right:0;border-radius:4px}.nav-tabs-justified>.active>a,.nav-tabs-justified>.active>a:hover,.nav-tabs-justified>.active>a:focus{border:1px solid #ddd}@media(min-width:768px){.nav-tabs-justified>li>a{border-bottom:1px solid #ddd;border-radius:4px 4px 0 0}.nav-tabs-justified>.active>a,.nav-tabs-justified>.active>a:hover,.nav-tabs-justified>.active>a:focus{border-bottom-color:#fff}}.tab-content>.tab-pane{display:none}.tab-content>.active{display:block}.nav-tabs .dropdown-menu{margin-top:-1px;border-top-right-radius:0;border-top-left-radius:0}.navbar{position:relative;min-height:50px;margin-bottom:20px;border:1px solid transparent}@media(min-width:768px){.navbar{border-radius:4px}}@media(min-width:768px){.navbar-header{float:left}}.navbar-collapse{overflow-x:visible;padding-right:15px;padding-left:15px;border-top:1px solid transparent;box-shadow:inset 0 1px 0 rgba(255,255,255,0.1);-webkit-overflo
w-scrolling:touch}.navbar-collapse.in{overflow-y:auto}@media(min-width:768px){.navbar-collapse{width:auto;border-top:0;box-shadow:none}.navbar-collapse.collapse{display:block!important;height:auto!important;padding-bottom:0;overflow:visible!important}.navbar-collapse.in{overflow-y:visible}.navbar-fixed-top .navbar-collapse,.navbar-static-top .navbar-collapse,.navbar-fixed-bottom .navbar-collapse{padding-left:0;padding-right:0}}.navbar-fixed-top .navbar-collapse,.navbar-fixed-bottom .navbar-collapse{max-height:340px}@media(max-device-width:480px) and (orientation:landscape){.navbar-fixed-top .navbar-collapse,.navbar-fixed-bottom .navbar-collapse{max-height:200px}}.container>.navbar-header,.container-fluid>.navbar-header,.container>.navbar-collapse,.container-fluid>.navbar-collapse{margin-right:-15px;margin-left:-15px}@media(min-width:768px){.container>.navbar-header,.container-fluid>.navbar-header,.container>.navbar-collapse,.container-fluid>.navbar-collapse{margin-right:0;margin-lef
t:0}}.navbar-static-top{z-index:1000;border-width:0 0 1px}@media(min-width:768px){.navbar-static-top{border-radius:0}}.navbar-fixed-top,.navbar-fixed-bottom{position:fixed;right:0;left:0;z-index:1030}@media(min-width:768px){.navbar-fixed-top,.navbar-fixed-bottom{border-radius:0}}.navbar-fixed-top{top:0;border-width:0 0 1px}.navbar-fixed-bottom{bottom:0;margin-bottom:0;border-width:1px 0 0}.navbar-brand{float:left;padding:15px 15px;font-size:18px;line-height:20px;height:50px}.navbar-brand:hover,.navbar-brand:focus{text-decoration:none}.navbar-brand>img{display:block}@media(min-width:768px){.navbar>.container .navbar-brand,.navbar>.container-fluid .navbar-brand{margin-left:-15px}}.navbar-toggle{position:relative;float:right;margin-right:15px;padding:9px 10px;margin-top:8px;margin-bottom:8px;background-color:transparent;background-image:none;border:1px solid transparent;border-radius:4px}.navbar-toggle:focus{outline:0}.navbar-toggle .icon-bar{display:block;width:22px;height:2px;border-
radius:1px}.navbar-toggle .icon-bar+.icon-bar{margin-top:4px}@media(min-width:768px){.navbar-toggle{display:none}}.navbar-nav{margin:7.5px -15px}.navbar-nav>li>a{padding-top:10px;padding-bottom:10px;line-height:20px}@media(max-width:767px){.navbar-nav .open .dropdown-menu{position:static;float:none;width:auto;margin-top:0;background-color:transparent;border:0;box-shadow:none}.navbar-nav .open .dropdown-menu>li>a,.navbar-nav .open .dropdown-menu .dropdown-header{padding:5px 15px 5px 25px}.navbar-nav .open .dropdown-menu>li>a{line-height:20px}.navbar-nav .open .dropdown-menu>li>a:hover,.navbar-nav .open .dropdown-menu>li>a:focus{background-image:none}}@media(min-width:768px){.navbar-nav{float:left;margin:0}.navbar-nav>li{float:left}.navbar-nav>li>a{padding-top:15px;padding-bottom:15px}}.navbar-form{margin-left:-15px;margin-right:-15px;padding:10px 15px;border-top:1px solid transparent;border-bottom:1px solid transparent;-webkit-box-shadow:inset 0 1px 0 rgba(255,255,255,0.1),0 1px 0 rg
ba(255,255,255,0.1);box-shadow:inset 0 1px 0 rgba(255,255,255,0.1),0 1px 0 rgba(255,255,255,0.1);margin-top:8px;margin-bottom:8px}@media(min-width:768px){.navbar-form .form-group{display:inline-block;margin-bottom:0;vertical-align:middle}.navbar-form .form-control{display:inline-block;width:auto;vertical-align:middle}.navbar-form .form-control-static{display:inline-block}.navbar-form .input-group{display:inline-table;vertical-align:middle}.navbar-form .input-group .input-group-addon,.navbar-form .input-group .input-group-btn,.navbar-form .input-group .form-control{width:auto}.navbar-form .input-group>.form-control{width:100%}.navbar-form .control-label{margin-bottom:0;vertical-align:middle}.navbar-form .radio,.navbar-form .checkbox{display:inline-block;margin-top:0;margin-bottom:0;vertical-align:middle}.navbar-form .radio label,.navbar-form .checkbox label{padding-left:0}.navbar-form .radio input[type="radio"],.navbar-form .checkbox input[type="checkbox"]{position:relative;margin-le
ft:0}.navbar-form .has-feedback .form-control-feedback{top:0}}@media(max-width:767px){.navbar-form .form-group{margin-bottom:5px}.navbar-form .form-group:last-child{margin-bottom:0}}@media(min-width:768px){.navbar-form{width:auto;border:0;margin-left:0;margin-right:0;padding-top:0;padding-bottom:0;-webkit-box-shadow:none;box-shadow:none}}.navbar-nav>li>.dropdown-menu{margin-top:0;border-top-right-radius:0;border-top-left-radius:0}.navbar-fixed-bottom .navbar-nav>li>.dropdown-menu{margin-bottom:0;border-top-right-radius:4px;border-top-left-radius:4px;border-bottom-right-radius:0;border-bottom-left-radius:0}.navbar-btn{margin-top:8px;margin-bottom:8px}.navbar-btn.btn-sm{margin-top:10px;margin-bottom:10px}.navbar-btn.btn-xs{margin-top:14px;margin-bottom:14px}.navbar-text{margin-top:15px;margin-bottom:15px}@media(min-width:768px){.navbar-text{float:left;margin-left:15px;margin-right:15px}}@media(min-width:768px){.navbar-left{float:left!important}.navbar-right{float:right!important;margi
n-right:-15px}.navbar-right ~ .navbar-right{margin-right:0}}.navbar-default{background-color:#f8f8f8;border-color:#e7e7e7}.navbar-default .navbar-brand{color:#777}.navbar-default .navbar-brand:hover,.navbar-default .navbar-brand:focus{color:#5e5e5e;background-color:transparent}.navbar-default .navbar-text{color:#777}.navbar-default .navbar-nav>li>a{color:#777}.navbar-default .navbar-nav>li>a:hover,.navbar-default .navbar-nav>li>a:focus{color:#333;background-color:transparent}.navbar-default .navbar-nav>.active>a,.navbar-default .navbar-nav>.active>a:hover,.navbar-default .navbar-nav>.active>a:focus{color:#555;background-color:#e7e7e7}.navbar-default .navbar-nav>.disabled>a,.navbar-default .navbar-nav>.disabled>a:hover,.navbar-default .navbar-nav>.disabled>a:focus{color:#ccc;background-color:transparent}.navbar-default .navbar-toggle{border-color:#ddd}.navbar-default .navbar-toggle:hover,.navbar-default .navbar-toggle:focus{background-color:#ddd}.navbar-default .navbar-toggle .icon-b
ar{background-color:#888}.navbar-default .navbar-collapse,.navbar-default .navbar-form{border-color:#e7e7e7}.navbar-default .navbar-nav>.open>a,.navbar-default .navbar-nav>.open>a:hover,.navbar-default .navbar-nav>.open>a:focus{background-color:#e7e7e7;color:#555}@media(max-width:767px){.navbar-default .navbar-nav .open .dropdown-menu>li>a{color:#777}.navbar-default .navbar-nav .open .dropdown-menu>li>a:hover,.navbar-default .navbar-nav .open .dropdown-menu>li>a:focus{color:#333;background-color:transparent}.navbar-default .navbar-nav .open .dropdown-menu>.active>a,.navbar-default .navbar-nav .open .dropdown-menu>.active>a:hover,.navbar-default .navbar-nav .open .dropdown-menu>.active>a:focus{color:#555;background-color:#e7e7e7}.navbar-default .navbar-nav .open .dropdown-menu>.disabled>a,.navbar-default .navbar-nav .open .dropdown-menu>.disabled>a:hover,.navbar-default .navbar-nav .open .dropdown-menu>.disabled>a:focus{color:#ccc;background-color:transparent}}.navbar-default .navbar
-link{color:#777}.navbar-default .navbar-link:hover{color:#333}.navbar-default .btn-link{color:#777}.navbar-default .btn-link:hover,.navbar-default .btn-link:focus{color:#333}.navbar-default .btn-link[disabled]:hover,fieldset[disabled] .navbar-default .btn-link:hover,.navbar-default .btn-link[disabled]:focus,fieldset[disabled] .navbar-default .btn-link:focus{color:#ccc}.navbar-inverse{background-color:#470f1b;border-color:#1d060b}.navbar-inverse .navbar-brand{color:#d0d0d0}.navbar-inverse .navbar-brand:hover,.navbar-inverse .navbar-brand:focus{color:#fff;background-color:transparent}.navbar-inverse .navbar-text{color:#9d9d9d}.navbar-inverse .navbar-nav>li>a{color:#d0d0d0}.navbar-inverse .navbar-nav>li>a:hover,.navbar-inverse .navbar-nav>li>a:focus{color:#fff;background-color:transparent}.navbar-inverse .navbar-nav>.active>a,.navbar-inverse .navbar-nav>.active>a:hover,.navbar-inverse .navbar-nav>.active>a:focus{color:#fff;background-color:#1d060b}.navbar-inverse .navbar-nav>.disabled
>a,.navbar-inverse .navbar-nav>.disabled>a:hover,.navbar-inverse .navbar-nav>.disabled>a:focus{color:#444;background-color:transparent}.navbar-inverse .navbar-toggle{border-color:#333}.navbar-inverse .navbar-toggle:hover,.navbar-inverse .navbar-toggle:focus{background-color:#333}.navbar-inverse .navbar-toggle .icon-bar{background-color:#fff}.navbar-inverse .navbar-collapse,.navbar-inverse .navbar-form{border-color:#2a0910}.navbar-inverse .navbar-nav>.open>a,.navbar-inverse .navbar-nav>.open>a:hover,.navbar-inverse .navbar-nav>.open>a:focus{background-color:#1d060b;color:#fff}@media(max-width:767px){.navbar-inverse .navbar-nav .open .dropdown-menu>.dropdown-header{border-color:#1d060b}.navbar-inverse .navbar-nav .open .dropdown-menu .divider{background-color:#1d060b}.navbar-inverse .navbar-nav .open .dropdown-menu>li>a{color:#d0d0d0}.navbar-inverse .navbar-nav .open .dropdown-menu>li>a:hover,.navbar-inverse .navbar-nav .open .dropdown-menu>li>a:focus{color:#fff;background-color:trans
parent}.navbar-inverse .navbar-nav .open .dropdown-menu>.active>a,.navbar-inverse .navbar-nav .open .dropdown-menu>.active>a:hover,.navbar-inverse .navbar-nav .open .dropdown-menu>.active>a:focus{color:#fff;background-color:#1d060b}.navbar-inverse .navbar-nav .open .dropdown-menu>.disabled>a,.navbar-inverse .navbar-nav .open .dropdown-menu>.disabled>a:hover,.navbar-inverse .navbar-nav .open .dropdown-menu>.disabled>a:focus{color:#444;background-color:transparent}}.navbar-inverse .navbar-link{color:#d0d0d0}.navbar-inverse .navbar-link:hover{color:#fff}.navbar-inverse .btn-link{color:#d0d0d0}.navbar-inverse .btn-link:hover,.navbar-inverse .btn-link:focus{color:#fff}.navbar-inverse .btn-link[disabled]:hover,fieldset[disabled] .navbar-inverse .btn-link:hover,.navbar-inverse .btn-link[disabled]:focus,fieldset[disabled] .navbar-inverse .btn-link:focus{color:#444}.breadcrumb{padding:8px 15px;margin-bottom:20px;list-style:none;background-color:#f5f5f5;border-radius:4px}.breadcrumb>li{displa
y:inline-block}.breadcrumb>li+li:before{content:"/\00a0";padding:0 5px;color:#ccc}.breadcrumb>.active{color:#777}.pagination{display:inline-block;padding-left:0;margin:20px 0;border-radius:4px}.pagination>li{display:inline}.pagination>li>a,.pagination>li>span{position:relative;float:left;padding:6px 12px;line-height:1.42857143;text-decoration:none;color:#871e32;background-color:#fff;border:1px solid #ddd;margin-left:-1px}.pagination>li:first-child>a,.pagination>li:first-child>span{margin-left:0;border-bottom-left-radius:4px;border-top-left-radius:4px}.pagination>li:last-child>a,.pagination>li:last-child>span{border-bottom-right-radius:4px;border-top-right-radius:4px}.pagination>li>a:hover,.pagination>li>span:hover,.pagination>li>a:focus,.pagination>li>span:focus{z-index:2;color:#48101b;background-color:#eee;border-color:#ddd}.pagination>.active>a,.pagination>.active>span,.pagination>.active>a:hover,.pagination>.active>span:hover,.pagination>.active>a:focus,.pagination>.active>span:f
ocus{z-index:3;color:#fff;background-color:#871e32;border-color:#871e32;cursor:default}.pagination>.disabled>span,.pagination>.disabled>span:hover,.pagination>.disabled>span:focus,.pagination>.disabled>a,.pagination>.disabled>a:hover,.pagination>.disabled>a:focus{color:#777;background-color:#fff;border-color:#ddd;cursor:not-allowed}.pagination-lg>li>a,.pagination-lg>li>span{padding:10px 16px;font-size:18px;line-height:1.3333333}.pagination-lg>li:first-child>a,.pagination-lg>li:first-child>span{border-bottom-left-radius:6px;border-top-left-radius:6px}.pagination-lg>li:last-child>a,.pagination-lg>li:last-child>span{border-bottom-right-radius:6px;border-top-right-radius:6px}.pagination-sm>li>a,.pagination-sm>li>span{padding:5px 10px;font-size:12px;line-height:1.5}.pagination-sm>li:first-child>a,.pagination-sm>li:first-child>span{border-bottom-left-radius:3px;border-top-left-radius:3px}.pagination-sm>li:last-child>a,.pagination-sm>li:last-child>span{border-bottom-right-radius:3px;border
-top-right-radius:3px}.pager{padding-left:0;margin:20px 0;list-style:none;text-align:center}.pager li{display:inline}.pager li>a,.pager li>span{display:inline-block;padding:5px 14px;background-color:#fff;border:1px solid #ddd;border-radius:15px}.pager li>a:hover,.pager li>a:focus{text-decoration:none;background-color:#eee}.pager .next>a,.pager .next>span{float:right}.pager .previous>a,.pager .previous>span{float:left}.pager .disabled>a,.pager .disabled>a:hover,.pager .disabled>a:focus,.pager .disabled>span{color:#777;background-color:#fff;cursor:not-allowed}.label{display:inline;padding:.2em .6em .3em;font-size:75%;font-weight:bold;line-height:1;color:#fff;text-align:center;white-space:nowrap;vertical-align:baseline;border-radius:.25em}a.label:hover,a.label:focus{color:#fff;text-decoration:none;cursor:pointer}.label:empty{display:none}.btn .label{position:relative;top:-1px}.label-default{background-color:#777}.label-default[href]:hover,.label-default[href]:focus{background-color:#5e
5e5e}.label-primary{background-color:#871e32}.label-primary[href]:hover,.label-primary[href]:focus{background-color:#5d1523}.label-success{background-color:#5cb85c}.label-success[href]:hover,.label-success[href]:focus{background-color:#449d44}.label-info{background-color:#5bc0de}.label-info[href]:hover,.label-info[href]:focus{background-color:#31b0d5}.label-warning{background-color:#f0ad4e}.label-warning[href]:hover,.label-warning[href]:focus{background-color:#ec971f}.label-danger{background-color:#d9534f}.label-danger[href]:hover,.label-danger[href]:focus{background-color:#c9302c}.badge{display:inline-block;min-width:10px;padding:3px 7px;font-size:12px;font-weight:bold;color:#fff;line-height:1;vertical-align:middle;white-space:nowrap;text-align:center;background-color:#777;border-radius:10px}.badge:empty{display:none}.btn .badge{position:relative;top:-1px}.btn-xs .badge,.btn-group-xs>.btn .badge{top:0;padding:1px 5px}a.badge:hover,a.badge:focus{color:#fff;text-decoration:none;curso
r:pointer}.list-group-item.active>.badge,.nav-pills>.active>a>.badge{color:#871e32;background-color:#fff}.list-group-item>.badge{float:right}.list-group-item>.badge+.badge{margin-right:5px}.nav-pills>li>a>.badge{margin-left:3px}.jumbotron{padding-top:30px;padding-bottom:30px;margin-bottom:30px;color:inherit;background-color:#eee}.jumbotron h1,.jumbotron .h1{color:inherit}.jumbotron p{margin-bottom:15px;font-size:21px;font-weight:200}.jumbotron>hr{border-top-color:#d5d5d5}.container .jumbotron,.container-fluid .jumbotron{border-radius:6px;padding-left:15px;padding-right:15px}.jumbotron .container{max-width:100%}@media screen and (min-width:768px){.jumbotron{padding-top:48px;padding-bottom:48px}.container .jumbotron,.container-fluid .jumbotron{padding-left:60px;padding-right:60px}.jumbotron h1,.jumbotron .h1{font-size:63px}}.thumbnail{display:block;padding:4px;margin-bottom:20px;line-height:1.42857143;background-color:#fff;border:1px solid #ddd;border-radius:4px;-webkit-transition:bor
der .2s ease-in-out;-o-transition:border .2s ease-in-out;transition:border .2s ease-in-out}.thumbnail>img,.thumbnail a>img{margin-left:auto;margin-right:auto}a.thumbnail:hover,a.thumbnail:focus,a.thumbnail.active{border-color:#871e32}.thumbnail .caption{padding:9px;color:#333}.alert{padding:15px;margin-bottom:20px;border:1px solid transparent;border-radius:4px}.alert h4{margin-top:0;color:inherit}.alert .alert-link{font-weight:bold}.alert>p,.alert>ul{margin-bottom:0}.alert>p+p{margin-top:5px}.alert-dismissable,.alert-dismissible{padding-right:35px}.alert-dismissable .close,.alert-dismissible .close{position:relative;top:-2px;right:-21px;color:inherit}.alert-success{background-color:#dff0d8;border-color:#d6e9c6;color:#3c763d}.alert-success hr{border-top-color:#c9e2b3}.alert-success .alert-link{color:#2b542c}.alert-info{background-color:#d9edf7;border-color:#bce8f1;color:#31708f}.alert-info hr{border-top-color:#a6e1ec}.alert-info .alert-link{color:#245269}.alert-warning{background-col
or:#fcf8e3;border-color:#faebcc;color:#8a6d3b}.alert-warning hr{border-top-color:#f7e1b5}.alert-warning .alert-link{color:#66512c}.alert-danger{background-color:#f2dede;border-color:#ebccd1;color:#a94442}.alert-danger hr{border-top-color:#e4b9c0}.alert-danger .alert-link{color:#843534}@-webkit-keyframes progress-bar-stripes{from{background-position:40px 0}to{background-position:0 0}}@keyframes progress-bar-stripes{from{background-position:40px 0}to{background-position:0 0}}.progress{overflow:hidden;height:20px;margin-bottom:20px;background-color:#f5f5f5;border-radius:4px;-webkit-box-shadow:inset 0 1px 2px rgba(0,0,0,0.1);box-shadow:inset 0 1px 2px rgba(0,0,0,0.1)}.progress-bar{float:left;width:0;height:100%;font-size:12px;line-height:20px;color:#fff;text-align:center;background-color:#871e32;-webkit-box-shadow:inset 0 -1px 0 rgba(0,0,0,0.15);box-shadow:inset 0 -1px 0 rgba(0,0,0,0.15);-webkit-transition:width .6s ease;-o-transition:width .6s ease;transition:width .6s ease}.progress-s
triped .progress-bar,.progress-bar-striped{background-image:-webkit-linear-gradient(45deg,rgba(255,255,255,0.15) 25%,transparent 25%,transparent 50%,rgba(255,255,255,0.15) 50%,rgba(255,255,255,0.15) 75%,transparent 75%,transparent);background-image:-o-linear-gradient(45deg,rgba(255,255,255,0.15) 25%,transparent 25%,transparent 50%,rgba(255,255,255,0.15) 50%,rgba(255,255,255,0.15) 75%,transparent 75%,transparent);background-image:linear-gradient(45deg,rgba(255,255,255,0.15) 25%,transparent 25%,transparent 50%,rgba(255,255,255,0.15) 50%,rgba(255,255,255,0.15) 75%,transparent 75%,transparent);background-size:40px 40px}.progress.active .progress-bar,.progress-bar.active{-webkit-animation:progress-bar-stripes 2s linear infinite;-o-animation:progress-bar-stripes 2s linear infinite;animation:progress-bar-stripes 2s linear infinite}.progress-bar-success{background-color:#5cb85c}.progress-striped .progress-bar-success{background-image:-webkit-linear-gradient(45deg,rgba(255,255,255,0.15) 25%,
transparent 25%,transparent 50%,rgba(255,255,255,0.15) 50%,rgba(255,255,255,0.15) 75%,transparent 75%,transparent);background-image:-o-linear-gradient(45deg,rgba(255,255,255,0.15) 25%,transparent 25%,transparent 50%,rgba(255,255,255,0.15) 50%,rgba(255,255,255,0.15) 75%,transparent 75%,transparent);background-image:linear-gradient(45deg,rgba(255,255,255,0.15) 25%,transparent 25%,transparent 50%,rgba(255,255,255,0.15) 50%,rgba(255,255,255,0.15) 75%,transparent 75%,transparent)}.progress-bar-info{background-color:#5bc0de}.progress-striped .progress-bar-info{background-image:-webkit-linear-gradient(45deg,rgba(255,255,255,0.15) 25%,transparent 25%,transparent 50%,rgba(255,255,255,0.15) 50%,rgba(255,255,255,0.15) 75%,transparent 75%,transparent);background-image:-o-linear-gradient(45deg,rgba(255,255,255,0.15) 25%,transparent 25%,transparent 50%,rgba(255,255,255,0.15) 50%,rgba(255,255,255,0.15) 75%,transparent 75%,transparent);background-image:linear-gradient(45deg,rgba(255,255,255,0.15) 2
5%,transparent 25%,transparent 50%,rgba(255,255,255,0.15) 50%,rgba(255,255,255,0.15) 75%,transparent 75%,transparent)}.progress-bar-warning{background-color:#f0ad4e}.progress-striped .progress-bar-warning{background-image:-webkit-linear-gradient(45deg,rgba(255,255,255,0.15) 25%,transparent 25%,transparent 50%,rgba(255,255,255,0.15) 50%,rgba(255,255,255,0.15) 75%,transparent 75%,transparent);background-image:-o-linear-gradient(45deg,rgba(255,255,255,0.15) 25%,transparent 25%,transparent 50%,rgba(255,255,255,0.15) 50%,rgba(255,255,255,0.15) 75%,transparent 75%,transparent);background-image:linear-gradient(45deg,rgba(255,255,255,0.15) 25%,transparent 25%,transparent 50%,rgba(255,255,255,0.15) 50%,rgba(255,255,255,0.15) 75%,transparent 75%,transparent)}.progress-bar-danger{background-color:#d9534f}.progress-striped .progress-bar-danger{background-image:-webkit-linear-gradient(45deg,rgba(255,255,255,0.15) 25%,transparent 25%,transparent 50%,rgba(255,255,255,0.15) 50%,rgba(255,255,255,0.1
5) 75%,transparent 75%,transparent);background-image:-o-linear-gradient(45deg,rgba(255,255,255,0.15) 25%,transparent 25%,transparent 50%,rgba(255,255,255,0.15) 50%,rgba(255,255,255,0.15) 75%,transparent 75%,transparent);background-image:linear-gradient(45deg,rgba(255,255,255,0.15) 25%,transparent 25%,transparent 50%,rgba(255,255,255,0.15) 50%,rgba(255,255,255,0.15) 75%,transparent 75%,transparent)}.media{margin-top:15px}.media:first-child{margin-top:0}.media,.media-body{zoom:1;overflow:hidden}.media-body{width:10000px}.media-object{display:block}.media-object.img-thumbnail{max-width:none}.media-right,.media>.pull-right{padding-left:10px}.media-left,.media>.pull-left{padding-right:10px}.media-left,.media-right,.media-body{display:table-cell;vertical-align:top}.media-middle{vertical-align:middle}.media-bottom{vertical-align:bottom}.media-heading{margin-top:0;margin-bottom:5px}.media-list{padding-left:0;list-style:none}.list-group{margin-bottom:20px;padding-left:0}.list-group-item{posi
tion:relative;display:block;padding:10px 15px;margin-bottom:-1px;background-color:#fff;border:1px solid #ddd}.list-group-item:first-child{border-top-right-radius:4px;border-top-left-radius:4px}.list-group-item:last-child{margin-bottom:0;border-bottom-right-radius:4px;border-bottom-left-radius:4px}a.list-group-item,button.list-group-item{color:#555}a.list-group-item .list-group-item-heading,button.list-group-item .list-group-item-heading{color:#333}a.list-group-item:hover,button.list-group-item:hover,a.list-group-item:focus,button.list-group-item:focus{text-decoration:none;color:#555;background-color:#f5f5f5}button.list-group-item{width:100%;text-align:left}.list-group-item.disabled,.list-group-item.disabled:hover,.list-group-item.disabled:focus{background-color:#eee;color:#777;cursor:not-allowed}.list-group-item.disabled .list-group-item-heading,.list-group-item.disabled:hover .list-group-item-heading,.list-group-item.disabled:focus .list-group-item-heading{color:inherit}.list-group
-item.disabled .list-group-item-text,.list-group-item.disabled:hover .list-group-item-text,.list-group-item.disabled:focus .list-group-item-text{color:#777}.list-group-item.active,.list-group-item.active:hover,.list-group-item.active:focus{z-index:2;color:#fff;background-color:#871e32;border-color:#871e32}.list-group-item.active .list-group-item-heading,.list-group-item.active:hover .list-group-item-heading,.list-group-item.active:focus .list-group-item-heading,.list-group-item.active .list-group-item-heading>small,.list-group-item.active:hover .list-group-item-heading>small,.list-group-item.active:focus .list-group-item-heading>small,.list-group-item.active .list-group-item-heading>.small,.list-group-item.active:hover .list-group-item-heading>.small,.list-group-item.active:focus .list-group-item-heading>.small{color:inherit}.list-group-item.active .list-group-item-text,.list-group-item.active:hover .list-group-item-text,.list-group-item.active:focus .list-group-item-text{color:#e58
c9d}.list-group-item-success{color:#3c763d;background-color:#dff0d8}a.list-group-item-success,button.list-group-item-success{color:#3c763d}a.list-group-item-success .list-group-item-heading,button.list-group-item-success .list-group-item-heading{color:inherit}a.list-group-item-success:hover,button.list-group-item-success:hover,a.list-group-item-success:focus,button.list-group-item-success:focus{color:#3c763d;background-color:#d0e9c6}a.list-group-item-success.active,button.list-group-item-success.active,a.list-group-item-success.active:hover,button.list-group-item-success.active:hover,a.list-group-item-success.active:focus,button.list-group-item-success.active:focus{color:#fff;background-color:#3c763d;border-color:#3c763d}.list-group-item-info{color:#31708f;background-color:#d9edf7}a.list-group-item-info,button.list-group-item-info{color:#31708f}a.list-group-item-info .list-group-item-heading,button.list-group-item-info .list-group-item-heading{color:inherit}a.list-group-item-info:ho
ver,button.list-group-item-info:hover,a.list-group-item-info:focus,button.list-group-item-info:focus{color:#31708f;background-color:#c4e3f3}a.list-group-item-info.active,button.list-group-item-info.active,a.list-group-item-info.active:hover,button.list-group-item-info.active:hover,a.list-group-item-info.active:focus,button.list-group-item-info.active:focus{color:#fff;background-color:#31708f;border-color:#31708f}.list-group-item-warning{color:#8a6d3b;background-color:#fcf8e3}a.list-group-item-warning,button.list-group-item-warning{color:#8a6d3b}a.list-group-item-warning .list-group-item-heading,button.list-group-item-warning .list-group-item-heading{color:inherit}a.list-group-item-warning:hover,button.list-group-item-warning:hover,a.list-group-item-warning:focus,button.list-group-item-warning:focus{color:#8a6d3b;background-color:#faf2cc}a.list-group-item-warning.active,button.list-group-item-warning.active,a.list-group-item-warning.active:hover,button.list-group-item-warning.active:
hover,a.list-group-item-warning.active:focus,button.list-group-item-warning.active:focus{color:#fff;background-color:#8a6d3b;border-color:#8a6d3b}.list-group-item-danger{color:#a94442;background-color:#f2dede}a.list-group-item-danger,button.list-group-item-danger{color:#a94442}a.list-group-item-danger .list-group-item-heading,button.list-group-item-danger .list-group-item-heading{color:inherit}a.list-group-item-danger:hover,button.list-group-item-danger:hover,a.list-group-item-danger:focus,button.list-group-item-danger:focus{color:#a94442;background-color:#ebcccc}a.list-group-item-danger.active,button.list-group-item-danger.active,a.list-group-item-danger.active:hover,button.list-group-item-danger.active:hover,a.list-group-item-danger.active:focus,button.list-group-item-danger.active:focus{color:#fff;background-color:#a94442;border-color:#a94442}.list-group-item-heading{margin-top:0;margin-bottom:5px}.list-group-item-text{margin-bottom:0;line-height:1.3}.panel{margin-bottom:20px;bac
kground-color:#fff;border:1px solid transparent;border-radius:4px;-webkit-box-shadow:0 1px 1px rgba(0,0,0,0.05);box-shadow:0 1px 1px rgba(0,0,0,0.05)}.panel-body{padding:15px}.panel-heading{padding:10px 15px;border-bottom:1px solid transparent;border-top-right-radius:3px;border-top-left-radius:3px}.panel-heading>.dropdown .dropdown-toggle{color:inherit}.panel-title{margin-top:0;margin-bottom:0;font-size:16px;color:inherit}.panel-title>a,.panel-title>small,.panel-title>.small,.panel-title>small>a,.panel-title>.small>a{color:inherit}.panel-footer{padding:10px 15px;background-color:#f5f5f5;border-top:1px solid #ddd;border-bottom-right-radius:3px;border-bottom-left-radius:3px}.panel>.list-group,.panel>.panel-collapse>.list-group{margin-bottom:0}.panel>.list-group .list-group-item,.panel>.panel-collapse>.list-group .list-group-item{border-width:1px 0;border-radius:0}.panel>.list-group:first-child .list-group-item:first-child,.panel>.panel-collapse>.list-group:first-child .list-group-item
:first-child{border-top:0;border-top-right-radius:3px;border-top-left-radius:3px}.panel>.list-group:last-child .list-group-item:last-child,.panel>.panel-collapse>.list-group:last-child .list-group-item:last-child{border-bottom:0;border-bottom-right-radius:3px;border-bottom-left-radius:3px}.panel>.panel-heading+.panel-collapse>.list-group .list-group-item:first-child{border-top-right-radius:0;border-top-left-radius:0}.panel-heading+.list-group .list-group-item:first-child{border-top-width:0}.list-group+.panel-footer{border-top-width:0}.panel>.table,.panel>.table-responsive>.table,.panel>.panel-collapse>.table{margin-bottom:0}.panel>.table caption,.panel>.table-responsive>.table caption,.panel>.panel-collapse>.table caption{padding-left:15px;padding-right:15px}.panel>.table:first-child,.panel>.table-responsive:first-child>.table:first-child{border-top-right-radius:3px;border-top-left-radius:3px}.panel>.table:first-child>thead:first-child>tr:first-child,.panel>.table-responsive:first-c
hild>.table:first-child>thead:first-child>tr:first-child,.panel>.table:first-child>tbody:first-child>tr:first-child,.panel>.table-responsive:first-child>.table:first-child>tbody:first-child>tr:first-child{border-top-left-radius:3px;border-top-right-radius:3px}.panel>.table:first-child>thead:first-child>tr:first-child td:first-child,.panel>.table-responsive:first-child>.table:first-child>thead:first-child>tr:first-child td:first-child,.panel>.table:first-child>tbody:first-child>tr:first-child td:first-child,.panel>.table-responsive:first-child>.table:first-child>tbody:first-child>tr:first-child td:first-child,.panel>.table:first-child>thead:first-child>tr:first-child th:first-child,.panel>.table-responsive:first-child>.table:first-child>thead:first-child>tr:first-child th:first-child,.panel>.table:first-child>tbody:first-child>tr:first-child th:first-child,.panel>.table-responsive:first-child>.table:first-child>tbody:first-child>tr:first-child th:first-child{border-top-left-radius:3p
x}.panel>.table:first-child>thead:first-child>tr:first-child td:last-child,.panel>.table-responsive:first-child>.table:first-child>thead:first-child>tr:first-child td:last-child,.panel>.table:first-child>tbody:first-child>tr:first-child td:last-child,.panel>.table-responsive:first-child>.table:first-child>tbody:first-child>tr:first-child td:last-child,.panel>.table:first-child>thead:first-child>tr:first-child th:last-child,.panel>.table-responsive:first-child>.table:first-child>thead:first-child>tr:first-child th:last-child,.panel>.table:first-child>tbody:first-child>tr:first-child th:last-child,.panel>.table-responsive:first-child>.table:first-child>tbody:first-child>tr:first-child th:last-child{border-top-right-radius:3px}.panel>.table:last-child,.panel>.table-responsive:last-child>.table:last-child{border-bottom-right-radius:3px;border-bottom-left-radius:3px}.panel>.table:last-child>tbody:last-child>tr:last-child,.panel>.table-responsive:last-child>.table:last-child>tbody:last-ch
ild>tr:last-child,.panel>.table:last-child>tfoot:last-child>tr:last-child,.panel>.table-responsive:last-child>.table:last-child>tfoot:last-child>tr:last-child{border-bottom-left-radius:3px;border-bottom-right-radius:3px}.panel>.table:last-child>tbody:last-child>tr:last-child td:first-child,.panel>.table-responsive:last-child>.table:last-child>tbody:last-child>tr:last-child td:first-child,.panel>.table:last-child>tfoot:last-child>tr:last-child td:first-child,.panel>.table-responsive:last-child>.table:last-child>tfoot:last-child>tr:last-child td:first-child,.panel>.table:last-child>tbody:last-child>tr:last-child th:first-child,.panel>.table-responsive:last-child>.table:last-child>tbody:last-child>tr:last-child th:first-child,.panel>.table:last-child>tfoot:last-child>tr:last-child th:first-child,.panel>.table-responsive:last-child>.table:last-child>tfoot:last-child>tr:last-child th:first-child{border-bottom-left-radius:3px}.panel>.table:last-child>tbody:last-child>tr:last-child td:last
-child,.panel>.table-responsive:last-child>.table:last-child>tbody:last-child>tr:last-child td:last-child,.panel>.table:last-child>tfoot:last-child>tr:last-child td:last-child,.panel>.table-responsive:last-child>.table:last-child>tfoot:last-child>tr:last-child td:last-child,.panel>.table:last-child>tbody:last-child>tr:last-child th:last-child,.panel>.table-responsive:last-child>.table:last-child>tbody:last-child>tr:last-child th:last-child,.panel>.table:last-child>tfoot:last-child>tr:last-child th:last-child,.panel>.table-responsive:last-child>.table:last-child>tfoot:last-child>tr:last-child th:last-child{border-bottom-right-radius:3px}.panel>.panel-body+.table,.panel>.panel-body+.table-responsive,.panel>.table+.panel-body,.panel>.table-responsive+.panel-body{border-top:1px solid #ddd}.panel>.table>tbody:first-child>tr:first-child th,.panel>.table>tbody:first-child>tr:first-child td{border-top:0}.panel>.table-bordered,.panel>.table-responsive>.table-bordered{border:0}.panel>.table-b
ordered>thead>tr>th:first-child,.panel>.table-responsive>.table-bordered>thead>tr>th:first-child,.panel>.table-bordered>tbody>tr>th:first-child,.panel>.table-responsive>.table-bordered>tbody>tr>th:first-child,.panel>.table-bordered>tfoot>tr>th:first-child,.panel>.table-responsive>.table-bordered>tfoot>tr>th:first-child,.panel>.table-bordered>thead>tr>td:first-child,.panel>.table-responsive>.table-bordered>thead>tr>td:first-child,.panel>.table-bordered>tbody>tr>td:first-child,.panel>.table-responsive>.table-bordered>tbody>tr>td:first-child,.panel>.table-bordered>tfoot>tr>td:first-child,.panel>.table-responsive>.table-bordered>tfoot>tr>td:first-child{border-left:0}.panel>.table-bordered>thead>tr>th:last-child,.panel>.table-responsive>.table-bordered>thead>tr>th:last-child,.panel>.table-bordered>tbody>tr>th:last-child,.panel>.table-responsive>.table-bordered>tbody>tr>th:last-child,.panel>.table-bordered>tfoot>tr>th:last-child,.panel>.table-responsive>.table-bordered>tfoot>tr>th:last-ch
ild,.panel>.table-bordered>thead>tr>td:last-child,.panel>.table-responsive>.table-bordered>thead>tr>td:last-child,.panel>.table-bordered>tbody>tr>td:last-child,.panel>.table-responsive>.table-bordered>tbody>tr>td:last-child,.panel>.table-bordered>tfoot>tr>td:last-child,.panel>.table-responsive>.table-bordered>tfoot>tr>td:last-child{border-right:0}.panel>.table-bordered>thead>tr:first-child>td,.panel>.table-responsive>.table-bordered>thead>tr:first-child>td,.panel>.table-bordered>tbody>tr:first-child>td,.panel>.table-responsive>.table-bordered>tbody>tr:first-child>td,.panel>.table-bordered>thead>tr:first-child>th,.panel>.table-responsive>.table-bordered>thead>tr:first-child>th,.panel>.table-bordered>tbody>tr:first-child>th,.panel>.table-responsive>.table-bordered>tbody>tr:first-child>th{border-bottom:0}.panel>.table-bordered>tbody>tr:last-child>td,.panel>.table-responsive>.table-bordered>tbody>tr:last-child>td,.panel>.table-bordered>tfoot>tr:last-child>td,.panel>.table-responsive>.ta
ble-bordered>tfoot>tr:last-child>td,.panel>.table-bordered>tbody>tr:last-child>th,.panel>.table-responsive>.table-bordered>tbody>tr:last-child>th,.panel>.table-bordered>tfoot>tr:last-child>th,.panel>.table-responsive>.table-bordered>tfoot>tr:last-child>th{border-bottom:0}.panel>.table-responsive{border:0;margin-bottom:0}.panel-group{margin-bottom:20px}.panel-group .panel{margin-bottom:0;border-radius:4px}.panel-group .panel+.panel{margin-top:5px}.panel-group .panel-heading{border-bottom:0}.panel-group .panel-heading+.panel-collapse>.panel-body,.panel-group .panel-heading+.panel-collapse>.list-group{border-top:1px solid #ddd}.panel-group .panel-footer{border-top:0}.panel-group .panel-footer+.panel-collapse .panel-body{border-bottom:1px solid #ddd}.panel-default{border-color:#ddd}.panel-default>.panel-heading{color:#333;background-color:#f5f5f5;border-color:#ddd}.panel-default>.panel-heading+.panel-collapse>.panel-body{border-top-color:#ddd}.panel-default>.panel-heading .badge{color:#
f5f5f5;background-color:#333}.panel-default>.panel-footer+.panel-collapse>.panel-body{border-bottom-color:#ddd}.panel-primary{border-color:#871e32}.panel-primary>.panel-heading{color:#fff;background-color:#871e32;border-color:#871e32}.panel-primary>.panel-heading+.panel-collapse>.panel-body{border-top-color:#871e32}.panel-primary>.panel-heading .badge{color:#871e32;background-color:#fff}.panel-primary>.panel-footer+.panel-collapse>.panel-body{border-bottom-color:#871e32}.panel-success{border-color:#d6e9c6}.panel-success>.panel-heading{color:#3c763d;background-color:#dff0d8;border-color:#d6e9c6}.panel-success>.panel-heading+.panel-collapse>.panel-body{border-top-color:#d6e9c6}.panel-success>.panel-heading .badge{color:#dff0d8;background-color:#3c763d}.panel-success>.panel-footer+.panel-collapse>.panel-body{border-bottom-color:#d6e9c6}.panel-info{border-color:#bce8f1}.panel-info>.panel-heading{color:#31708f;background-color:#d9edf7;border-color:#bce8f1}.panel-info>.panel-heading+.pane
l-collapse>.panel-body{border-top-color:#bce8f1}.panel-info>.panel-heading .badge{color:#d9edf7;background-color:#31708f}.panel-info>.panel-footer+.panel-collapse>.panel-body{border-bottom-color:#bce8f1}.panel-warning{border-color:#faebcc}.panel-warning>.panel-heading{color:#8a6d3b;background-color:#fcf8e3;border-color:#faebcc}.panel-warning>.panel-heading+.panel-collapse>.panel-body{border-top-color:#faebcc}.panel-warning>.panel-heading .badge{color:#fcf8e3;background-color:#8a6d3b}.panel-warning>.panel-footer+.panel-collapse>.panel-body{border-bottom-color:#faebcc}.panel-danger{border-color:#ebccd1}.panel-danger>.panel-heading{color:#a94442;background-color:#f2dede;border-color:#ebccd1}.panel-danger>.panel-heading+.panel-collapse>.panel-body{border-top-color:#ebccd1}.panel-danger>.panel-heading .badge{color:#f2dede;background-color:#a94442}.panel-danger>.panel-footer+.panel-collapse>.panel-body{border-bottom-color:#ebccd1}.embed-responsive{position:relative;display:block;height:0;
padding:0;overflow:hidden}.embed-responsive .embed-responsive-item,.embed-responsive iframe,.embed-responsive embed,.embed-responsive object,.embed-responsive video{position:absolute;top:0;left:0;bottom:0;height:100%;width:100%;border:0}.embed-responsive-16by9{padding-bottom:56.25%}.embed-responsive-4by3{padding-bottom:75%}.well{min-height:20px;padding:19px;margin-bottom:20px;background-color:#f5f5f5;border:1px solid #e3e3e3;border-radius:4px;-webkit-box-shadow:inset 0 1px 1px rgba(0,0,0,0.05);box-shadow:inset 0 1px 1px rgba(0,0,0,0.05)}.well blockquote{border-color:#ddd;border-color:rgba(0,0,0,0.15)}.well-lg{padding:24px;border-radius:6px}.well-sm{padding:9px;border-radius:3px}.close{float:right;font-size:21px;font-weight:bold;line-height:1;color:#000;text-shadow:0 1px 0 #fff;opacity:.2;filter:alpha(opacity=20)}.close:hover,.close:focus{color:#000;text-decoration:none;cursor:pointer;opacity:.5;filter:alpha(opacity=50)}button.close{padding:0;cursor:pointer;background:transparent;bor
der:0;-webkit-appearance:none}.modal-open{overflow:hidden}.modal{display:none;overflow:hidden;position:fixed;top:0;right:0;bottom:0;left:0;z-index:1050;-webkit-overflow-scrolling:touch;outline:0}.modal.fade .modal-dialog{-webkit-transform:translate(0,-25%);-ms-transform:translate(0,-25%);-o-transform:translate(0,-25%);transform:translate(0,-25%);-webkit-transition:-webkit-transform .3s ease-out;-moz-transition:-moz-transform .3s ease-out;-o-transition:-o-transform .3s ease-out;transition:transform .3s ease-out}.modal.in .modal-dialog{-webkit-transform:translate(0,0);-ms-transform:translate(0,0);-o-transform:translate(0,0);transform:translate(0,0)}.modal-open .modal{overflow-x:hidden;overflow-y:auto}.modal-dialog{position:relative;width:auto;margin:10px}.modal-content{position:relative;background-color:#fff;border:1px solid #999;border:1px solid rgba(0,0,0,0.2);border-radius:6px;-webkit-box-shadow:0 3px 9px rgba(0,0,0,0.5);box-shadow:0 3px 9px rgba(0,0,0,0.5);background-clip:padding-
box;outline:0}.modal-backdrop{position:fixed;top:0;right:0;bottom:0;left:0;z-index:1040;background-color:#000}.modal-backdrop.fade{opacity:0;filter:alpha(opacity=0)}.modal-backdrop.in{opacity:.5;filter:alpha(opacity=50)}.modal-header{padding:15px;border-bottom:1px solid #e5e5e5}.modal-header .close{margin-top:-2px}.modal-title{margin:0;line-height:1.42857143}.modal-body{position:relative;padding:15px}.modal-footer{padding:15px;text-align:right;border-top:1px solid #e5e5e5}.modal-footer .btn+.btn{margin-left:5px;margin-bottom:0}.modal-footer .btn-group .btn+.btn{margin-left:-1px}.modal-footer .btn-block+.btn-block{margin-left:0}.modal-scrollbar-measure{position:absolute;top:-9999px;width:50px;height:50px;overflow:scroll}@media(min-width:768px){.modal-dialog{width:600px;margin:30px auto}.modal-content{-webkit-box-shadow:0 5px 15px rgba(0,0,0,0.5);box-shadow:0 5px 15px rgba(0,0,0,0.5)}.modal-sm{width:300px}}@media(min-width:992px){.modal-lg{width:900px}}.tooltip{position:absolute;z-ind
ex:1070;display:block;font-family:"Helvetica Neue",Helvetica,Arial,sans-serif;font-style:normal;font-weight:normal;letter-spacing:normal;line-break:auto;line-height:1.42857143;text-align:left;text-align:start;text-decoration:none;text-shadow:none;text-transform:none;white-space:normal;word-break:normal;word-spacing:normal;word-wrap:normal;font-size:12px;opacity:0;filter:alpha(opacity=0)}.tooltip.in{opacity:.9;filter:alpha(opacity=90)}.tooltip.top{margin-top:-3px;padding:5px 0}.tooltip.right{margin-left:3px;padding:0 5px}.tooltip.bottom{margin-top:3px;padding:5px 0}.tooltip.left{margin-left:-3px;padding:0 5px}.tooltip-inner{max-width:200px;padding:3px 8px;color:#fff;text-align:center;background-color:#000;border-radius:4px}.tooltip-arrow{position:absolute;width:0;height:0;border-color:transparent;border-style:solid}.tooltip.top .tooltip-arrow{bottom:0;left:50%;margin-left:-5px;border-width:5px 5px 0;border-top-color:#000}.tooltip.top-left .tooltip-arrow{bottom:0;right:5px;margin-bott
om:-5px;border-width:5px 5px 0;border-top-color:#000}.tooltip.top-right .tooltip-arrow{bottom:0;left:5px;margin-bottom:-5px;border-width:5px 5px 0;border-top-color:#000}.tooltip.right .tooltip-arrow{top:50%;left:0;margin-top:-5px;border-width:5px 5px 5px 0;border-right-color:#000}.tooltip.left .tooltip-arrow{top:50%;right:0;margin-top:-5px;border-width:5px 0 5px 5px;border-left-color:#000}.tooltip.bottom .tooltip-arrow{top:0;left:50%;margin-left:-5px;border-width:0 5px 5px;border-bottom-color:#000}.tooltip.bottom-left .tooltip-arrow{top:0;right:5px;margin-top:-5px;border-width:0 5px 5px;border-bottom-color:#000}.tooltip.bottom-right .tooltip-arrow{top:0;left:5px;margin-top:-5px;border-width:0 5px 5px;border-bottom-color:#000}.popover{position:absolute;top:0;left:0;z-index:1060;display:none;max-width:276px;padding:1px;font-family:"Helvetica Neue",Helvetica,Arial,sans-serif;font-style:normal;font-weight:normal;letter-spacing:normal;line-break:auto;line-height:1.42857143;text-align:lef
t;text-align:start;text-decoration:none;text-shadow:none;text-transform:none;white-space:normal;word-break:normal;word-spacing:normal;word-wrap:normal;font-size:14px;background-color:#fff;background-clip:padding-box;border:1px solid #ccc;border:1px solid rgba(0,0,0,0.2);border-radius:6px;-webkit-box-shadow:0 5px 10px rgba(0,0,0,0.2);box-shadow:0 5px 10px rgba(0,0,0,0.2)}.popover.top{margin-top:-10px}.popover.right{margin-left:10px}.popover.bottom{margin-top:10px}.popover.left{margin-left:-10px}.popover-title{margin:0;padding:8px 14px;font-size:14px;background-color:#f7f7f7;border-bottom:1px solid #ebebeb;border-radius:5px 5px 0 0}.popover-content{padding:9px 14px}.popover>.arrow,.popover>.arrow:after{position:absolute;display:block;width:0;height:0;border-color:transparent;border-style:solid}.popover>.arrow{border-width:11px}.popover>.arrow:after{border-width:10px;content:""}.popover.top>.arrow{left:50%;margin-left:-11px;border-bottom-width:0;border-top-color:#999;border-top-color:r
gba(0,0,0,0.25);bottom:-11px}.popover.top>.arrow:after{content:" ";bottom:1px;margin-left:-10px;border-bottom-width:0;border-top-color:#fff}.popover.right>.arrow{top:50%;left:-11px;margin-top:-11px;border-left-width:0;border-right-color:#999;border-right-color:rgba(0,0,0,0.25)}.popover.right>.arrow:after{content:" ";left:1px;bottom:-10px;border-left-width:0;border-right-color:#fff}.popover.bottom>.arrow{left:50%;margin-left:-11px;border-top-width:0;border-bottom-color:#999;border-bottom-color:rgba(0,0,0,0.25);top:-11px}.popover.bottom>.arrow:after{content:" ";top:1px;margin-left:-10px;border-top-width:0;border-bottom-color:#fff}.popover.left>.arrow{top:50%;right:-11px;margin-top:-11px;border-right-width:0;border-left-color:#999;border-left-color:rgba(0,0,0,0.25)}.popover.left>.arrow:after{content:" ";right:1px;border-right-width:0;border-left-color:#fff;bottom:-10px}.carousel{position:relative}.carousel-inner{position:relative;overflow:hidden;width:100%}.carousel-inner>.item{display
:none;position:relative;-webkit-transition:.6s ease-in-out left;-o-transition:.6s ease-in-out left;transition:.6s ease-in-out left}.carousel-inner>.item>img,.carousel-inner>.item>a>img{line-height:1}@media all and (transform-3d),(-webkit-transform-3d){.carousel-inner>.item{-webkit-transition:-webkit-transform .6s ease-in-out;-moz-transition:-moz-transform .6s ease-in-out;-o-transition:-o-transform .6s ease-in-out;transition:transform .6s ease-in-out;-webkit-backface-visibility:hidden;-moz-backface-visibility:hidden;backface-visibility:hidden;-webkit-perspective:1000px;-moz-perspective:1000px;perspective:1000px}.carousel-inner>.item.next,.carousel-inner>.item.active.right{-webkit-transform:translate3d(100%,0,0);transform:translate3d(100%,0,0);left:0}.carousel-inner>.item.prev,.carousel-inner>.item.active.left{-webkit-transform:translate3d(-100%,0,0);transform:translate3d(-100%,0,0);left:0}.carousel-inner>.item.next.left,.carousel-inner>.item.prev.right,.carousel-inner>.item.active{-w
ebkit-transform:translate3d(0,0,0);transform:translate3d(0,0,0);left:0}}.carousel-inner>.active,.carousel-inner>.next,.carousel-inner>.prev{display:block}.carousel-inner>.active{left:0}.carousel-inner>.next,.carousel-inner>.prev{position:absolute;top:0;width:100%}.carousel-inner>.next{left:100%}.carousel-inner>.prev{left:-100%}.carousel-inner>.next.left,.carousel-inner>.prev.right{left:0}.carousel-inner>.active.left{left:-100%}.carousel-inner>.active.right{left:100%}.carousel-control{position:absolute;top:0;left:0;bottom:0;width:15%;opacity:.5;filter:alpha(opacity=50);font-size:20px;color:#fff;text-align:center;text-shadow:0 1px 2px rgba(0,0,0,0.6);background-color:rgba(0,0,0,0)}.carousel-control.left{background-image:-webkit-linear-gradient(left,rgba(0,0,0,0.5) 0,rgba(0,0,0,0.0001) 100%);background-image:-o-linear-gradient(left,rgba(0,0,0,0.5) 0,rgba(0,0,0,0.0001) 100%);background-image:linear-gradient(to right,rgba(0,0,0,0.5) 0,rgba(0,0,0,0.0001) 100%);background-repeat:repeat-x;f
ilter:progid:DXImageTransform.Microsoft.gradient(startColorstr='#80000000',endColorstr='#00000000',GradientType=1)}.carousel-control.right{left:auto;right:0;background-image:-webkit-linear-gradient(left,rgba(0,0,0,0.0001) 0,rgba(0,0,0,0.5) 100%);background-image:-o-linear-gradient(left,rgba(0,0,0,0.0001) 0,rgba(0,0,0,0.5) 100%);background-image:linear-gradient(to right,rgba(0,0,0,0.0001) 0,rgba(0,0,0,0.5) 100%);background-repeat:repeat-x;filter:progid:DXImageTransform.Microsoft.gradient(startColorstr='#00000000',endColorstr='#80000000',GradientType=1)}.carousel-control:hover,.carousel-control:focus{outline:0;color:#fff;text-decoration:none;opacity:.9;filter:alpha(opacity=90)}.carousel-control .icon-prev,.carousel-control .icon-next,.carousel-control .glyphicon-chevron-left,.carousel-control .glyphicon-chevron-right{position:absolute;top:50%;margin-top:-10px;z-index:5;display:inline-block}.carousel-control .icon-prev,.carousel-control .glyphicon-chevron-left{left:50%;margin-left:-10p
x}.carousel-control .icon-next,.carousel-control .glyphicon-chevron-right{right:50%;margin-right:-10px}.carousel-control .icon-prev,.carousel-control .icon-next{width:20px;height:20px;line-height:1;font-family:serif}.carousel-control .icon-prev:before{content:'\2039'}.carousel-control .icon-next:before{content:'\203a'}.carousel-indicators{position:absolute;bottom:10px;left:50%;z-index:15;width:60%;margin-left:-30%;padding-left:0;list-style:none;text-align:center}.carousel-indicators li{display:inline-block;width:10px;height:10px;margin:1px;text-indent:-999px;border:1px solid #fff;border-radius:10px;cursor:pointer;background-color:#000 \9;background-color:rgba(0,0,0,0)}.carousel-indicators .active{margin:0;width:12px;height:12px;background-color:#fff}.carousel-caption{position:absolute;left:15%;right:15%;bottom:20px;z-index:10;padding-top:20px;padding-bottom:20px;color:#fff;text-align:center;text-shadow:0 1px 2px rgba(0,0,0,0.6)}.carousel-caption .btn{text-shadow:none}@media screen a
nd (min-width:768px){.carousel-control .glyphicon-chevron-left,.carousel-control .glyphicon-chevron-right,.carousel-control .icon-prev,.carousel-control .icon-next{width:30px;height:30px;margin-top:-10px;font-size:30px}.carousel-control .glyphicon-chevron-left,.carousel-control .icon-prev{margin-left:-10px}.carousel-control .glyphicon-chevron-right,.carousel-control .icon-next{margin-right:-10px}.carousel-caption{left:20%;right:20%;padding-bottom:30px}.carousel-indicators{bottom:20px}}.clearfix:before,.clearfix:after,.dl-horizontal dd:before,.dl-horizontal dd:after,.container:before,.container:after,.container-fluid:before,.container-fluid:after,.row:before,.row:after,.form-horizontal .form-group:before,.form-horizontal .form-group:after,.btn-toolbar:before,.btn-toolbar:after,.btn-group-vertical>.btn-group:before,.btn-group-vertical>.btn-group:after,.nav:before,.nav:after,.navbar:before,.navbar:after,.navbar-header:before,.navbar-header:after,.navbar-collapse:before,.navbar-collapse
:after,.pager:before,.pager:after,.panel-body:before,.panel-body:after,.modal-header:before,.modal-header:after,.modal-footer:before,.modal-footer:after{content:" ";display:table}.clearfix:after,.dl-horizontal dd:after,.container:after,.container-fluid:after,.row:after,.form-horizontal .form-group:after,.btn-toolbar:after,.btn-group-vertical>.btn-group:after,.nav:after,.navbar:after,.navbar-header:after,.navbar-collapse:after,.pager:after,.panel-body:after,.modal-header:after,.modal-footer:after{clear:both}.center-block{display:block;margin-left:auto;margin-right:auto}.pull-right{float:right!important}.pull-left{float:left!important}.hide{display:none!important}.show{display:block!important}.invisible{visibility:hidden}.text-hide{font:0/0 a;color:transparent;text-shadow:none;background-color:transparent;border:0}.hidden{display:none!important}.affix{position:fixed}@-ms-viewport{width:device-width}.visible-xs,.visible-sm,.visible-md,.visible-lg{display:none!important}.visible-xs-bloc
k,.visible-xs-inline,.visible-xs-inline-block,.visible-sm-block,.visible-sm-inline,.visible-sm-inline-block,.visible-md-block,.visible-md-inline,.visible-md-inline-block,.visible-lg-block,.visible-lg-inline,.visible-lg-inline-block{display:none!important}@media(max-width:767px){.visible-xs{display:block!important}table.visible-xs{display:table!important}tr.visible-xs{display:table-row!important}th.visible-xs,td.visible-xs{display:table-cell!important}}@media(max-width:767px){.visible-xs-block{display:block!important}}@media(max-width:767px){.visible-xs-inline{display:inline!important}}@media(max-width:767px){.visible-xs-inline-block{display:inline-block!important}}@media(min-width:768px) and (max-width:991px){.visible-sm{display:block!important}table.visible-sm{display:table!important}tr.visible-sm{display:table-row!important}th.visible-sm,td.visible-sm{display:table-cell!important}}@media(min-width:768px) and (max-width:991px){.visible-sm-block{display:block!important}}@media(min-w
idth:768px) and (max-width:991px){.visible-sm-inline{display:inline!important}}@media(min-width:768px) and (max-width:991px){.visible-sm-inline-block{display:inline-block!important}}@media(min-width:992px) and (max-width:1199px){.visible-md{display:block!important}table.visible-md{display:table!important}tr.visible-md{display:table-row!important}th.visible-md,td.visible-md{display:table-cell!important}}@media(min-width:992px) and (max-width:1199px){.visible-md-block{display:block!important}}@media(min-width:992px) and (max-width:1199px){.visible-md-inline{display:inline!important}}@media(min-width:992px) and (max-width:1199px){.visible-md-inline-block{display:inline-block!important}}@media(min-width:1200px){.visible-lg{display:block!important}table.visible-lg{display:table!important}tr.visible-lg{display:table-row!important}th.visible-lg,td.visible-lg{display:table-cell!important}}@media(min-width:1200px){.visible-lg-block{display:block!important}}@media(min-width:1200px){.visible-l
g-inline{display:inline!important}}@media(min-width:1200px){.visible-lg-inline-block{display:inline-block!important}}@media(max-width:767px){.hidden-xs{display:none!important}}@media(min-width:768px) and (max-width:991px){.hidden-sm{display:none!important}}@media(min-width:992px) and (max-width:1199px){.hidden-md{display:none!important}}@media(min-width:1200px){.hidden-lg{display:none!important}}.visible-print{display:none!important}@media print{.visible-print{display:block!important}table.visible-print{display:table!important}tr.visible-print{display:table-row!important}th.visible-print,td.visible-print{display:table-cell!important}}.visible-print-block{display:none!important}@media print{.visible-print-block{display:block!important}}.visible-print-inline{display:none!important}@media print{.visible-print-inline{display:inline!important}}.visible-print-inline-block{display:none!important}@media print{.visible-print-inline-block{display:inline-block!important}}@media print{.hidden-p
rint{display:none!important}}.btn-default,.btn-primary,.btn-success,.btn-info,.btn-warning,.btn-danger{text-shadow:0 -1px 0 rgba(0,0,0,0.2);-webkit-box-shadow:inset 0 1px 0 rgba(255,255,255,0.15),0 1px 1px rgba(0,0,0,0.075);box-shadow:inset 0 1px 0 rgba(255,255,255,0.15),0 1px 1px rgba(0,0,0,0.075)}.btn-default:active,.btn-primary:active,.btn-success:active,.btn-info:active,.btn-warning:active,.btn-danger:active,.btn-default.active,.btn-primary.active,.btn-success.active,.btn-info.active,.btn-warning.active,.btn-danger.active{-webkit-box-shadow:inset 0 3px 5px rgba(0,0,0,0.125);box-shadow:inset 0 3px 5px rgba(0,0,0,0.125)}.btn-default.disabled,.btn-primary.disabled,.btn-success.disabled,.btn-info.disabled,.btn-warning.disabled,.btn-danger.disabled,.btn-default[disabled],.btn-primary[disabled],.btn-success[disabled],.btn-info[disabled],.btn-warning[disabled],.btn-danger[disabled],fieldset[disabled] .btn-default,fieldset[disabled] .btn-primary,fieldset[disabled] .btn-success,fieldset[
disabled] .btn-info,fieldset[disabled] .btn-warning,fieldset[disabled] .btn-danger{-webkit-box-shadow:none;box-shadow:none}.btn-default .badge,.btn-primary .badge,.btn-success .badge,.btn-info .badge,.btn-warning .badge,.btn-danger .badge{text-shadow:none}.btn:active,.btn.active{background-image:none}.btn-default{background-image:-webkit-linear-gradient(top,#fff 0,#e0e0e0 100%);background-image:-o-linear-gradient(top,#fff 0,#e0e0e0 100%);background-image:linear-gradient(to bottom,#fff 0,#e0e0e0 100%);filter:progid:DXImageTransform.Microsoft.gradient(startColorstr='#ffffffff',endColorstr='#ffe0e0e0',GradientType=0);filter:progid:DXImageTransform.Microsoft.gradient(enabled = false);background-repeat:repeat-x;border-color:#dbdbdb;text-shadow:0 1px 0 #fff;border-color:#ccc}.btn-default:hover,.btn-default:focus{background-color:#e0e0e0;background-position:0 -15px}.btn-default:active,.btn-default.active{background-color:#e0e0e0;border-color:#dbdbdb}.btn-default.disabled,.btn-default[disab
led],fieldset[disabled] .btn-default,.btn-default.disabled:hover,.btn-default[disabled]:hover,fieldset[disabled] .btn-default:hover,.btn-default.disabled:focus,.btn-default[disabled]:focus,fieldset[disabled] .btn-default:focus,.btn-default.disabled.focus,.btn-default[disabled].focus,fieldset[disabled] .btn-default.focus,.btn-default.disabled:active,.btn-default[disabled]:active,fieldset[disabled] .btn-default:active,.btn-default.disabled.active,.btn-default[disabled].active,fieldset[disabled] .btn-default.active{background-color:#e0e0e0;background-image:none}.btn-primary{background-image:-webkit-linear-gradient(top,#871e32 0,#55131f 100%);background-image:-o-linear-gradient(top,#871e32 0,#55131f 100%);background-image:linear-gradient(to bottom,#871e32 0,#55131f 100%);filter:progid:DXImageTransform.Microsoft.gradient(startColorstr='#ff871e32',endColorstr='#ff55131f',GradientType=0);filter:progid:DXImageTransform.Microsoft.gradient(enabled = false);background-repeat:repeat-x;border-co
lor:#4d111c}.btn-primary:hover,.btn-primary:focus{background-color:#55131f;background-position:0 -15px}.btn-primary:active,.btn-primary.active{background-color:#55131f;border-color:#4d111c}.btn-primary.disabled,.btn-primary[disabled],fieldset[disabled] .btn-primary,.btn-primary.disabled:hover,.btn-primary[disabled]:hover,fieldset[disabled] .btn-primary:hover,.btn-primary.disabled:focus,.btn-primary[disabled]:focus,fieldset[disabled] .btn-primary:focus,.btn-primary.disabled.focus,.btn-primary[disabled].focus,fieldset[disabled] .btn-primary.focus,.btn-primary.disabled:active,.btn-primary[disabled]:active,fieldset[disabled] .btn-primary:active,.btn-primary.disabled.active,.btn-primary[disabled].active,fieldset[disabled] .btn-primary.active{background-color:#55131f;background-image:none}.btn-success{background-image:-webkit-linear-gradient(top,#5cb85c 0,#419641 100%);background-image:-o-linear-gradient(top,#5cb85c 0,#419641 100%);background-image:linear-gradient(to bottom,#5cb85c 0,#419
641 100%);filter:progid:DXImageTransform.Microsoft.gradient(startColorstr='#ff5cb85c',endColorstr='#ff419641',GradientType=0);filter:progid:DXImageTransform.Microsoft.gradient(enabled = false);background-repeat:repeat-x;border-color:#3e8f3e}.btn-success:hover,.btn-success:focus{background-color:#419641;background-position:0 -15px}.btn-success:active,.btn-success.active{background-color:#419641;border-color:#3e8f3e}.btn-success.disabled,.btn-success[disabled],fieldset[disabled] .btn-success,.btn-success.disabled:hover,.btn-success[disabled]:hover,fieldset[disabled] .btn-success:hover,.btn-success.disabled:focus,.btn-success[disabled]:focus,fieldset[disabled] .btn-success:focus,.btn-success.disabled.focus,.btn-success[disabled].focus,fieldset[disabled] .btn-success.focus,.btn-success.disabled:active,.btn-success[disabled]:active,fieldset[disabled] .btn-success:active,.btn-success.disabled.active,.btn-success[disabled].active,fieldset[disabled] .btn-success.active{background-color:#419
641;background-image:none}.btn-info{background-image:-webkit-linear-gradient(top,#5bc0de 0,#2aabd2 100%);background-image:-o-linear-gradient(top,#5bc0de 0,#2aabd2 100%);background-image:linear-gradient(to bottom,#5bc0de 0,#2aabd2 100%);filter:progid:DXImageTransform.Microsoft.gradient(startColorstr='#ff5bc0de',endColorstr='#ff2aabd2',GradientType=0);filter:progid:DXImageTransform.Microsoft.gradient(enabled = false);background-repeat:repeat-x;border-color:#28a4c9}.btn-info:hover,.btn-info:focus{background-color:#2aabd2;background-position:0 -15px}.btn-info:active,.btn-info.active{background-color:#2aabd2;border-color:#28a4c9}.btn-info.disabled,.btn-info[disabled],fieldset[disabled] .btn-info,.btn-info.disabled:hover,.btn-info[disabled]:hover,fieldset[disabled] .btn-info:hover,.btn-info.disabled:focus,.btn-info[disabled]:focus,fieldset[disabled] .btn-info:focus,.btn-info.disabled.focus,.btn-info[disabled].focus,fieldset[disabled] .btn-info.focus,.btn-info.disabled:active,.btn-info[dis
abled]:active,fieldset[disabled] .btn-info:active,.btn-info.disabled.active,.btn-info[disabled].active,fieldset[disabled] .btn-info.active{background-color:#2aabd2;background-image:none}.btn-warning{background-image:-webkit-linear-gradient(top,#f0ad4e 0,#eb9316 100%);background-image:-o-linear-gradient(top,#f0ad4e 0,#eb9316 100%);background-image:linear-gradient(to bottom,#f0ad4e 0,#eb9316 100%);filter:progid:DXImageTransform.Microsoft.gradient(startColorstr='#fff0ad4e',endColorstr='#ffeb9316',GradientType=0);filter:progid:DXImageTransform.Microsoft.gradient(enabled = false);background-repeat:repeat-x;border-color:#e38d13}.btn-warning:hover,.btn-warning:focus{background-color:#eb9316;background-position:0 -15px}.btn-warning:active,.btn-warning.active{background-color:#eb9316;border-color:#e38d13}.btn-warning.disabled,.btn-warning[disabled],fieldset[disabled] .btn-warning,.btn-warning.disabled:hover,.btn-warning[disabled]:hover,fieldset[disabled] .btn-warning:hover,.btn-warning.disab
led:focus,.btn-warning[disabled]:focus,fieldset[disabled] .btn-warning:focus,.btn-warning.disabled.focus,.btn-warning[disabled].focus,fieldset[disabled] .btn-warning.focus,.btn-warning.disabled:active,.btn-warning[disabled]:active,fieldset[disabled] .btn-warning:active,.btn-warning.disabled.active,.btn-warning[disabled].active,fieldset[disabled] .btn-warning.active{background-color:#eb9316;background-image:none}.btn-danger{background-image:-webkit-linear-gradient(top,#d9534f 0,#c12e2a 100%);background-image:-o-linear-gradient(top,#d9534f 0,#c12e2a 100%);background-image:linear-gradient(to bottom,#d9534f 0,#c12e2a 100%);filter:progid:DXImageTransform.Microsoft.gradient(startColorstr='#ffd9534f',endColorstr='#ffc12e2a',GradientType=0);filter:progid:DXImageTransform.Microsoft.gradient(enabled = false);background-repeat:repeat-x;border-color:#b92c28}.btn-danger:hover,.btn-danger:focus{background-color:#c12e2a;background-position:0 -15px}.btn-danger:active,.btn-danger.active{background-c
olor:#c12e2a;border-color:#b92c28}.btn-danger.disabled,.btn-danger[disabled],fieldset[disabled] .btn-danger,.btn-danger.disabled:hover,.btn-danger[disabled]:hover,fieldset[disabled] .btn-danger:hover,.btn-danger.disabled:focus,.btn-danger[disabled]:focus,fieldset[disabled] .btn-danger:focus,.btn-danger.disabled.focus,.btn-danger[disabled].focus,fieldset[disabled] .btn-danger.focus,.btn-danger.disabled:active,.btn-danger[disabled]:active,fieldset[disabled] .btn-danger:active,.btn-danger.disabled.active,.btn-danger[disabled].active,fieldset[disabled] .btn-danger.active{background-color:#c12e2a;background-image:none}.thumbnail,.img-thumbnail{-webkit-box-shadow:0 1px 2px rgba(0,0,0,0.075);box-shadow:0 1px 2px rgba(0,0,0,0.075)}.dropdown-menu>li>a:hover,.dropdown-menu>li>a:focus{background-image:-webkit-linear-gradient(top,#871d33 0,#72182b 100%);background-image:-o-linear-gradient(top,#871d33 0,#72182b 100%);background-image:linear-gradient(to bottom,#871d33 0,#72182b 100%);background-r
epeat:repeat-x;filter:progid:DXImageTransform.Microsoft.gradient(startColorstr='#ff871d33',endColorstr='#ff72182b',GradientType=0);background-color:#72182b}.dropdown-menu>.active>a,.dropdown-menu>.active>a:hover,.dropdown-menu>.active>a:focus{background-image:-webkit-linear-gradient(top,#871e32 0,#72192a 100%);background-image:-o-linear-gradient(top,#871e32 0,#72192a 100%);background-image:linear-gradient(to bottom,#871e32 0,#72192a 100%);background-repeat:repeat-x;filter:progid:DXImageTransform.Microsoft.gradient(startColorstr='#ff871e32',endColorstr='#ff72192a',GradientType=0);background-color:#72192a}.navbar-default{background-image:-webkit-linear-gradient(top,#fff 0,#f8f8f8 100%);background-image:-o-linear-gradient(top,#fff 0,#f8f8f8 100%);background-image:linear-gradient(to bottom,#fff 0,#f8f8f8 100%);background-repeat:repeat-x;filter:progid:DXImageTransform.Microsoft.gradient(startColorstr='#ffffffff',endColorstr='#fff8f8f8',GradientType=0);filter:progid:DXImageTransform.Micro
soft.gradient(enabled = false);border-radius:4px;-webkit-box-shadow:inset 0 1px 0 rgba(255,255,255,0.15),0 1px 5px rgba(0,0,0,0.075);box-shadow:inset 0 1px 0 rgba(255,255,255,0.15),0 1px 5px rgba(0,0,0,0.075)}.navbar-default .navbar-nav>.open>a,.navbar-default .navbar-nav>.active>a{background-image:-webkit-linear-gradient(top,#dbdbdb 0,#e2e2e2 100%);background-image:-o-linear-gradient(top,#dbdbdb 0,#e2e2e2 100%);background-image:linear-gradient(to bottom,#dbdbdb 0,#e2e2e2 100%);background-repeat:repeat-x;filter:progid:DXImageTransform.Microsoft.gradient(startColorstr='#ffdbdbdb',endColorstr='#ffe2e2e2',GradientType=0);-webkit-box-shadow:inset 0 3px 9px rgba(0,0,0,0.075);box-shadow:inset 0 3px 9px rgba(0,0,0,0.075)}.navbar-brand,.navbar-nav>li>a{text-shadow:0 1px 0 rgba(255,255,255,0.25)}.navbar-inverse{background-image:-webkit-linear-gradient(top,#71182b 0,#470f1b 100%);background-image:-o-linear-gradient(top,#71182b 0,#470f1b 100%);background-image:linear-gradient(to bottom,#71182b
0,#470f1b 100%);background-repeat:repeat-x;filter:progid:DXImageTransform.Microsoft.gradient(startColorstr='#ff71182b',endColorstr='#ff470f1b',GradientType=0);filter:progid:DXImageTransform.Microsoft.gradient(enabled = false);border-radius:4px}.navbar-inverse .navbar-nav>.open>a,.navbar-inverse .navbar-nav>.active>a{background-image:-webkit-linear-gradient(top,#1d060b 0,#27080f 100%);background-image:-o-linear-gradient(top,#1d060b 0,#27080f 100%);background-image:linear-gradient(to bottom,#1d060b 0,#27080f 100%);background-repeat:repeat-x;filter:progid:DXImageTransform.Microsoft.gradient(startColorstr='#ff1d060b',endColorstr='#ff27080f',GradientType=0);-webkit-box-shadow:inset 0 3px 9px rgba(0,0,0,0.25);box-shadow:inset 0 3px 9px rgba(0,0,0,0.25)}.navbar-inverse .navbar-brand,.navbar-inverse .navbar-nav>li>a{text-shadow:0 -1px 0 rgba(0,0,0,0.25)}.navbar-static-top,.navbar-fixed-top,.navbar-fixed-bottom{border-radius:0}@media(max-width:767px){.navbar .navbar-nav .open .dropdown-menu
>.active>a,.navbar .navbar-nav .open .dropdown-menu>.active>a:hover,.navbar .navbar-nav .open .dropdown-menu>.active>a:focus{color:#fff;background-image:-webkit-linear-gradient(top,#871e32 0,#72192a 100%);background-image:-o-linear-gradient(top,#871e32 0,#72192a 100%);background-image:linear-gradient(to bottom,#871e32 0,#72192a 100%);background-repeat:repeat-x;filter:progid:DXImageTransform.Microsoft.gradient(startColorstr='#ff871e32',endColorstr='#ff72192a',GradientType=0)}}.alert{text-shadow:0 1px 0 rgba(255,255,255,0.2);-webkit-box-shadow:inset 0 1px 0 rgba(255,255,255,0.25),0 1px 2px rgba(0,0,0,0.05);box-shadow:inset 0 1px 0 rgba(255,255,255,0.25),0 1px 2px rgba(0,0,0,0.05)}.alert-success{background-image:-webkit-linear-gradient(top,#dff0d8 0,#c8e5bc 100%);background-image:-o-linear-gradient(top,#dff0d8 0,#c8e5bc 100%);background-image:linear-gradient(to bottom,#dff0d8 0,#c8e5bc 100%);background-repeat:repeat-x;filter:progid:DXImageTransform.Microsoft.gradient(startColorstr='#ff
dff0d8',endColorstr='#ffc8e5bc',GradientType=0);border-color:#b2dba1}.alert-info{background-image:-webkit-linear-gradient(top,#d9edf7 0,#b9def0 100%);background-image:-o-linear-gradient(top,#d9edf7 0,#b9def0 100%);background-image:linear-gradient(to bottom,#d9edf7 0,#b9def0 100%);background-repeat:repeat-x;filter:progid:DXImageTransform.Microsoft.gradient(startColorstr='#ffd9edf7',endColorstr='#ffb9def0',GradientType=0);border-color:#9acfea}.alert-warning{background-image:-webkit-linear-gradient(top,#fcf8e3 0,#f8efc0 100%);background-image:-o-linear-gradient(top,#fcf8e3 0,#f8efc0 100%);background-image:linear-gradient(to bottom,#fcf8e3 0,#f8efc0 100%);background-repeat:repeat-x;filter:progid:DXImageTransform.Microsoft.gradient(startColorstr='#fffcf8e3',endColorstr='#fff8efc0',GradientType=0);border-color:#f5e79e}.alert-danger{background-image:-webkit-linear-gradient(top,#f2dede 0,#e7c3c3 100%);background-image:-o-linear-gradient(top,#f2dede 0,#e7c3c3 100%);background-image:linear-gr
adient(to bottom,#f2dede 0,#e7c3c3 100%);background-repeat:repeat-x;filter:progid:DXImageTransform.Microsoft.gradient(startColorstr='#fff2dede',endColorstr='#ffe7c3c3',GradientType=0);border-color:#dca7a7}.progress{background-image:-webkit-linear-gradient(top,#ebebeb 0,#f5f5f5 100%);background-image:-o-linear-gradient(top,#ebebeb 0,#f5f5f5 100%);background-image:linear-gradient(to bottom,#ebebeb 0,#f5f5f5 100%);background-repeat:repeat-x;filter:progid:DXImageTransform.Microsoft.gradient(startColorstr='#ffebebeb',endColorstr='#fff5f5f5',GradientType=0)}.progress-bar{background-image:-webkit-linear-gradient(top,#871e32 0,#5d1523 100%);background-image:-o-linear-gradient(top,#871e32 0,#5d1523 100%);background-image:linear-gradient(to bottom,#871e32 0,#5d1523 100%);background-repeat:repeat-x;filter:progid:DXImageTransform.Microsoft.gradient(startColorstr='#ff871e32',endColorstr='#ff5d1523',GradientType=0)}.progress-bar-success{background-image:-webkit-linear-gradient(top,#5cb85c 0,#449d
44 100%);background-image:-o-linear-gradient(top,#5cb85c 0,#449d44 100%);background-image:linear-gradient(to bottom,#5cb85c 0,#449d44 100%);background-repeat:repeat-x;filter:progid:DXImageTransform.Microsoft.gradient(startColorstr='#ff5cb85c',endColorstr='#ff449d44',GradientType=0)}.progress-bar-info{background-image:-webkit-linear-gradient(top,#5bc0de 0,#31b0d5 100%);background-image:-o-linear-gradient(top,#5bc0de 0,#31b0d5 100%);background-image:linear-gradient(to bottom,#5bc0de 0,#31b0d5 100%);background-repeat:repeat-x;filter:progid:DXImageTransform.Microsoft.gradient(startColorstr='#ff5bc0de',endColorstr='#ff31b0d5',GradientType=0)}.progress-bar-warning{background-image:-webkit-linear-gradient(top,#f0ad4e 0,#ec971f 100%);background-image:-o-linear-gradient(top,#f0ad4e 0,#ec971f 100%);background-image:linear-gradient(to bottom,#f0ad4e 0,#ec971f 100%);background-repeat:repeat-x;filter:progid:DXImageTransform.Microsoft.gradient(startColorstr='#fff0ad4e',endColorstr='#ffec971f',Gra
dientType=0)}.progress-bar-danger{background-image:-webkit-linear-gradient(top,#d9534f 0,#c9302c 100%);background-image:-o-linear-gradient(top,#d9534f 0,#c9302c 100%);background-image:linear-gradient(to bottom,#d9534f 0,#c9302c 100%);background-repeat:repeat-x;filter:progid:DXImageTransform.Microsoft.gradient(startColorstr='#ffd9534f',endColorstr='#ffc9302c',GradientType=0)}.progress-bar-striped{background-image:-webkit-linear-gradient(45deg,rgba(255,255,255,0.15) 25%,transparent 25%,transparent 50%,rgba(255,255,255,0.15) 50%,rgba(255,255,255,0.15) 75%,transparent 75%,transparent);background-image:-o-linear-gradient(45deg,rgba(255,255,255,0.15) 25%,transparent 25%,transparent 50%,rgba(255,255,255,0.15) 50%,rgba(255,255,255,0.15) 75%,transparent 75%,transparent);background-image:linear-gradient(45deg,rgba(255,255,255,0.15) 25%,transparent 25%,transparent 50%,rgba(255,255,255,0.15) 50%,rgba(255,255,255,0.15) 75%,transparent 75%,transparent)}.list-group{border-radius:4px;-webkit-box-sh
adow:0 1px 2px rgba(0,0,0,0.075);box-shadow:0 1px 2px rgba(0,0,0,0.075)}.list-group-item.active,.list-group-item.active:hover,.list-group-item.active:focus{text-shadow:0 -1px 0 #5d1523;background-image:-webkit-linear-gradient(top,#871e32 0,#681726 100%);background-image:-o-linear-gradient(top,#871e32 0,#681726 100%);background-image:linear-gradient(to bottom,#871e32 0,#681726 100%);background-repeat:repeat-x;filter:progid:DXImageTransform.Microsoft.gradient(startColorstr='#ff871e32',endColorstr='#ff681726',GradientType=0);border-color:#681726}.list-group-item.active .badge,.list-group-item.active:hover .badge,.list-group-item.active:focus .badge{text-shadow:none}.panel{-webkit-box-shadow:0 1px 2px rgba(0,0,0,0.05);box-shadow:0 1px 2px rgba(0,0,0,0.05)}.panel-default>.panel-heading{background-image:-webkit-linear-gradient(top,#f5f5f5 0,#e8e8e8 100%);background-image:-o-linear-gradient(top,#f5f5f5 0,#e8e8e8 100%);background-image:linear-gradient(to bottom,#f5f5f5 0,#e8e8e8 100%);backg
round-repeat:repeat-x;filter:progid:DXImageTransform.Microsoft.gradient(startColorstr='#fff5f5f5',endColorstr='#ffe8e8e8',GradientType=0)}.panel-primary>.panel-heading{background-image:-webkit-linear-gradient(top,#871e32 0,#72192a 100%);background-image:-o-linear-gradient(top,#871e32 0,#72192a 100%);background-image:linear-gradient(to bottom,#871e32 0,#72192a 100%);background-repeat:repeat-x;filter:progid:DXImageTransform.Microsoft.gradient(startColorstr='#ff871e32',endColorstr='#ff72192a',GradientType=0)}.panel-success>.panel-heading{background-image:-webkit-linear-gradient(top,#dff0d8 0,#d0e9c6 100%);background-image:-o-linear-gradient(top,#dff0d8 0,#d0e9c6 100%);background-image:linear-gradient(to bottom,#dff0d8 0,#d0e9c6 100%);background-repeat:repeat-x;filter:progid:DXImageTransform.Microsoft.gradient(startColorstr='#ffdff0d8',endColorstr='#ffd0e9c6',GradientType=0)}.panel-info>.panel-heading{background-image:-webkit-linear-gradient(top,#d9edf7 0,#c4e3f3 100%);background-image:
-o-linear-gradient(top,#d9edf7 0,#c4e3f3 100%);background-image:linear-gradient(to bottom,#d9edf7 0,#c4e3f3 100%);background-repeat:repeat-x;filter:progid:DXImageTransform.Microsoft.gradient(startColorstr='#ffd9edf7',endColorstr='#ffc4e3f3',GradientType=0)}.panel-warning>.panel-heading{background-image:-webkit-linear-gradient(top,#fcf8e3 0,#faf2cc 100%);background-image:-o-linear-gradient(top,#fcf8e3 0,#faf2cc 100%);background-image:linear-gradient(to bottom,#fcf8e3 0,#faf2cc 100%);background-repeat:repeat-x;filter:progid:DXImageTransform.Microsoft.gradient(startColorstr='#fffcf8e3',endColorstr='#fffaf2cc',GradientType=0)}.panel-danger>.panel-heading{background-image:-webkit-linear-gradient(top,#f2dede 0,#ebcccc 100%);background-image:-o-linear-gradient(top,#f2dede 0,#ebcccc 100%);background-image:linear-gradient(to bottom,#f2dede 0,#ebcccc 100%);background-repeat:repeat-x;filter:progid:DXImageTransform.Microsoft.gradient(startColorstr='#fff2dede',endColorstr='#ffebcccc',GradientTyp
e=0)}.well{background-image:-webkit-linear-gradient(top,#e8e8e8 0,#f5f5f5 100%);background-image:-o-linear-gradient(top,#e8e8e8 0,#f5f5f5 100%);background-image:linear-gradient(to bottom,#e8e8e8 0,#f5f5f5 100%);background-repeat:repeat-x;filter:progid:DXImageTransform.Microsoft.gradient(startColorstr='#ffe8e8e8',endColorstr='#fff5f5f5',GradientType=0);border-color:#dcdcdc;-webkit-box-shadow:inset 0 1px 3px rgba(0,0,0,0.05),0 1px 0 rgba(255,255,255,0.1);box-shadow:inset 0 1px 3px rgba(0,0,0,0.05),0 1px 0 rgba(255,255,255,0.1)}
\ No newline at end of file
Added: trunk/mapbender/http/extensions/mobilemap2/scripts/netgis/client.html
--- trunk/mapbender/http/extensions/mobilemap2/scripts/netgis/client.html (rev 0)
+++ trunk/mapbender/http/extensions/mobilemap2/scripts/netgis/client.html 2019-06-14 07:30:34 UTC (rev 10148)
@@ -0,0 +1,469 @@
+ <div id="netgis-client" style="position: relative; overflow: hidden; width: 100%; height: 100%;">
+ NetGIS WebGIS Client
+ (c) Sebastian Pauli, NetGIS, 2017-2019
+ <!-- Custom Styles -->
+ <link rel="stylesheet" type="text/css" href="./styles/common.css" />
+ <link rel="stylesheet" type="text/css" href="./styles/layout.css" />
+ <link rel="stylesheet" type="text/css" href="./styles/map.css" />
+ <link rel="stylesheet" type="text/css" href="./styles/popup.css" />
+ <link rel="stylesheet" type="text/css" href="./styles/menu.css" />
+ <link rel="stylesheet" type="text/css" href="./styles/manager.css" />
+ <link rel="stylesheet" type="text/css" href="./styles/sidemenu.css" />
+ <!-- App Loader -->
+ <div id="client-loader" style="position: absolute; left: 0px; right: 0px; top: 0px; bottom: 0px; background: white; z-index: 2000;">
+ <div style="position: absolute; left: 0px; right: 0px; top: 40%; font-size: 50px; text-align: center;">
+ <span class="text-primary glyphicon glyphicon-cog spinner"></span>
+ </div>
+ </div>
+ <!-- Navbar -->
+ <nav id="navbar-container" class="navbar navbar-inverse navbar-fixed-top shadow-lg" style="position: relative;"><!-- navbar-fixed-top navbar-embedded -->
+ <div class="container-fluid">
+ <div class="navbar-header">
+ <button type="button" class="navbar-toggle" data-toggle="collapse" data-target="#navbar">
+ <span class="icon-bar"></span>
+ <!--<span class="glyphicon glyphicon-menu-hamburger"></span>-->
+ </button>
+ <a id="menu-title" class="navbar-brand" href=".">GeoPortal.RLP</a>
+ </div>
+ <div class="collapse navbar-collapse" id="navbar">
+ <ul class="nav navbar-nav">
+ <!-- Layers -->
+ <li id="layer-menu-container" class="dropdown">
+ <a href="#" class="dropdown-toggle" data-toggle="dropdown"><span class="icon-left glyphicon glyphicon-th-list"></span>Ebenen <span class="caret"></span></a>
+ <ul class="dropdown-menu layer-list" id="layer-menu">
+ <li><a href="#" data-toggle="modal" data-target="#layer-dialog"><span class="icon-left glyphicon glyphicon-cog"></span>Verwalten / Suchen</a></li>
+ <li class="divider hidden-xs"></li>
+ </ul>
+ </li>
+ <!-- Tools -->
+ <li id="tool-menu-container" class="dropdown">
+ <a href="#" class="dropdown-toggle" data-toggle="dropdown"><span class="icon-left glyphicon glyphicon-th-large"></span>Tools <span class="caret"></span></a>
+ <ul class="dropdown-menu">
+ <li><a href="#" class="tool-pan"><span class="icon-left glyphicon glyphicon-move"></span>Ansicht bewegen</a></li>
+ <li><a href="#" class="tool-zoom-box-in"><span class="icon-left glyphicon glyphicon-zoom-in"></span>Hineinzoomen (Rechteck)</a></li>
+ <li><a href="#" class="tool-zoom-box-out"><span class="icon-left glyphicon glyphicon-zoom-out"></span>Herauszoomen (Rechteck)</a></li>
+ <li><a href="#" class="tool-view-undo"><span class="icon-left glyphicon glyphicon-step-backward"></span>Vorherige Ansicht</a></li>
+ <li><a href="#" class="tool-view-redo"><span class="icon-left glyphicon glyphicon-step-forward"></span>Nächste Ansicht</a></li>
+ <li><a href="#" class="tool-feature-info"><span class="icon-left glyphicon glyphicon-info-sign"></span>Objekt-Abfrage</a></li>
+ <li><a href="#" class="tool-measure-length"><span class="icon-left glyphicon glyphicon-resize-full"></span>Strecke messen</a></li>
+ <li><a href="#" class="tool-measure-area"><span class="icon-left glyphicon glyphicon-edit"></span>Fläche messen</a></li>
+ </ul>
+ </li>
+ <!-- Geolocation -->
+ <li id="geolocation-menu-container" class="dropdown">
+ <a href="#" class="dropdown-toggle" data-toggle="dropdown"><span class="icon-left glyphicon glyphicon-record"></span>Position <span class="caret"></span></a>
+ <li><a href="#" class="btn-position-active"><span class="icon-left glyphicon glyphicon-unchecked"></span>Aktiviert</a></li>
+ <li><a href="#" class="btn-position-center"><span class="icon-left glyphicon glyphicon-unchecked"></span>Auto.-Zentrieren</a></li>
+ <li><a href="#" class="btn-position-zoom"><span class="icon-left glyphicon glyphicon-record"></span>Position zentrieren</a></li>
+ </ul>
+ </li>
+ <!-- Scale -->
+ <li id="scale-menu-container" class="dropdown">
+ <a href="#" class="dropdown-toggle" data-toggle="dropdown"><span class="icon-left glyphicon glyphicon-cog"></span>Maßstab <span class="caret"></span></a>
+ <ul class="dropdown-menu" id="scale-menu">
+ <li id="scale-custom" data-scale=""><a href="#"><span class="icon-left glyphicon glyphicon-check"></span>1 : <span class="scale-value">XXXX</span></a></li>
+ <li id="scale-divider" class="divider hidden-xs"></li>
+ </ul>
+ </li>
+ <!-- Info -->
+ <li id="info-menu-container" class="dropdown">
+ <a href="#" class="dropdown-toggle" data-toggle="dropdown"><span class="icon-left glyphicon glyphicon-info-sign"></span>Info <span class="caret"></span></a>
+ <ul class="dropdown-menu" id="info-menu">
+ <li><a id="usage-terms-link" href="#" target="_blank"><span class="icon-left glyphicon glyphicon-share"></span>Nutzungsbedingungen</a></li>
+ </ul>
+ </li>
+ </ul>
+ <div id="search-bar-container" class="nav navbar-form navbar-right">
+ <!-- Search Bar -->
+ <div class="input-group">
+ <span id="search-button" class="input-group-addon clickable" data-toggle="collapse" data-target="#search-panel">
+ <i class="glyphicon glyphicon-search"></i>
+ <i class="glyphicon glyphicon-refresh spinner hidden"></i>
+ </span>
+ <input id="search-input" type="text" class="form-control" placeholder="Ortssuche..." autocomplete="off" value="" />
+ </div>
+ </div>
+ </div>
+ </div>
+ </nav>
+ <!-- Content -->
+ <div class="container-fluid container-full">
+ <div class="row row-full">
+ <!-- Viewport -->
+ <div class="col-md-12 col-lg-12 col-full no-padding">
+ <!-- Map Container -->
+ <div id="map-container"></div>
+ <div id="position-overlay" class="clickable" title="Ihre Position"><span class="glyphicon glyphicon-record"></span></div>
+ <div id="zoom-bar-container" class="btn-group-vertical map-control-right index-top shadow-md">
+ <button type="button" class="btn btn-primary tool-view-full" title="Volle Ausdehnung zoomen"><img src="./images/icon_rlp.png" height="20"></button>
+ <button type="button" class="btn btn-primary tool-zoom-in" title="Hineinzoomen"><span class="glyphicon glyphicon-plus"></span></button>
+ <button type="button" class="btn btn-primary tool-zoom-out" title="Herauszoomen"><span class="glyphicon glyphicon-minus"></span></button>
+ </div>
+ <div class="btn-group-vertical map-control-left index-top shadow-md">
+ <button id="feature-info-button" type="button" class="btn btn-primary tool-feature-info" title="Abfragen"><span class="glyphicon glyphicon-info-sign"></span></button>
+ <button id="legend-button" type="button" class="btn btn-primary tool-legend" title="Legende" data-toggle="modal" data-target="#legend-dialog"><span class="glyphicon glyphicon-option-vertical"></span></button>
+ </div>
+ <div id="measure-container" class="measure-overlay">
+ <span id="measure-content"></span>
+ <span id="measure-close" class="glyphicon glyphicon-remove clickable" style="margin-left: 0.25em"></span>
+ </div>
+ <div id="result-overlay">
+ <span class="glyphicon glyphicon-record"></span>
+ </div>
+ <div id="watermark-container" class="index-top small">
+ <a href="http://www.geoportal.rlp.de/portal/servicebereich/impressum.html" target="_blank">© GDI-RP</a>
+ </div>
+ <div id="popup-container" class="ol-popup">
+ <div id="popup-closer" class="ol-popup-closer text-primary"></div>
+ <div id="popup-content">
+ <br/>
+ <button class="btn btn-primary btn-block" onclick="netgis.menu.toggleSideMenu( true );">
+ <span class="glyphicon glyphicon-info-sign"></span>
+ </button>
+ </div>
+ </div>
+ </div>
+ <!-- Search Output -->
+ <div class="col-xs-12 collapse no-padding shadow-lg" id="search-panel">
+ <div class="list-group" id="search-list">
+ <a class="list-group-item" data-toggle="collapse" href="#search-panel">
+ <span class="glyphicon glyphicon-search icon-left"></span>
+ <strong>Suchergebnisse:</strong>
+ <span class="glyphicon glyphicon-remove pull-right"></span>
+ <div id="search-message">
+ <div class="alert alert-info">
+ <strong>Ihre Ortsuche ergab keine Treffer. Tipp: Trennen Sie mehrere Suchbegriffe mit einem Komma!</strong><br/>
+ Beispiel: <i>„Von-Kuhl-Straße 49, Koblenz“</i>
+ </div>
+ </div>
+ </a>
+ </div>
+ </div>
+ </div>
+ </div>
+ <!-- Side Menu -->
+ <div class="" id="side-menu">
+ <button type="button" class="btn btn-default btn-block" style="width: 100%; height: 50px" onclick="netgis.menu.toggleSideMenu( false );">
+ <span class="glyphicon glyphicon-chevron-left"></span>
+ </button>
+ <div class="container-fluid" id="side-menu-content">
+ </div>
+ </div>
+ <!-- Layer Manager -->
+ <div class="modal fade" id="layer-dialog" style="/*overflow-y: scroll*/">
+ <div class="modal-dialog">
+ <div class="panel panel-primary">
+ <div class="panel-heading clickable" data-toggle="modal" data-target="#layer-dialog">
+ <h4 class="panel-title">Ebenen verwalten<span class="pull-right glyphicon glyphicon-remove"></span></h4>
+ </div>
+ <div class="panel-body">
+ <!-- Layer Search -->
+ <div class="form-group">
+ <span id="layer-search-button" class="input-group-addon clickable">
+ </span>
+ <input id="layer-search-input" type="text" class="form-control" placeholder="Datensuche..." />
+ </div>
+ </div>
+ <!-- Search Results -->
+ <div class="panel-heading clickable" data-toggle="collapse" data-target="#layer-results">
+ <h4 class="panel-title">Suchergebnisse (<span id="layer-results-count">0</span>)<span class="icon-right glyphicon glyphicon-chevron-down pull-right"></span></h4>
+ </div>
+ <div id="layer-results" class="panel-collapse collapse">
+ <div class="alert alert-info alert-dismissable hidden" id="layer-results-alert">
+ <a href="#" class="close" data-dismiss="alert" aria-label="close">×</a>
+ Zu Ihrer Suchanfrage wurden <strong><span id="layer-results-total">0</span> Ebenen</strong> gefunden, es können aber nur max. 40 Ergebnisse angezeigt werden.<br/>
+ </div>
+ <div class="list-group" style="margin-bottom: 0px" id="layer-results-list">
+ </div>
+ </div>
+ </div>
+ </div>
+ <!-- Layer List -->
+ <div class="panel panel-primary" style="margin-bottom: 0px">
+ <div class="panel-heading clickable" data-toggle="collapse" data-target="#layer-container">
+ <h4 class="panel-title">Ebenen (<span id="layer-count">0</span>)<span class="icon-right glyphicon glyphicon-chevron-down pull-right"></span></h4>
+ </div>
+ <div id="layer-container" class="panel-collapse collapse">
+ <ul class="nav nav-tabs nav-justified">
+ <li id="tab-layers-all" class="active">
+ <a href="#layer-list-all" data-toggle="tab"><span class="icon-left glyphicon glyphicon-folder-open"></span> Themen</a>
+ </li>
+ <li id="tab-layers-map">
+ <a href="#layer-list-map" data-toggle="tab"><span class="icon-left glyphicon glyphicon-eye-open"></span> Karte</a>
+ </li>
+ </ul>
+ <div class="tab-content">
+ <div class="tab-pane active list-group layer-list" id="layer-list-all">
+ </div>
+ <div class="tab-pane list-group layer-list" id="layer-list-map">
+ </div>
+ </div>
+ </div>
+ </div>
+ </div>
+ </div>
+ <div class="panel-footer">
+ </div>
+ </div>
+ </div>
+ </div>
+ <!-- Legend Dialog -->
+ <div class="modal fade" id="legend-dialog">
+ <div class="modal-dialog" style="vertical-align: middle;">
+ <div class="panel-heading clickable" data-toggle="modal" data-target="#legend-dialog">
+ <h4 class="panel-title">Legende<span class="pull-right glyphicon glyphicon-remove"></span></h4>
+ </div>
+ <div class="panel-body" id="legend-panel">
+ </div>
+ </div>
+ </div>
+ </div>
+ </div>
+ <!-- Geolocation Dialog -->
+ <div class="modal fade" id="geolocation-dialog">
+ <div class="modal-dialog" style="vertical-align: middle">
+ <div class="panel-heading" data-toggle="modal" data-target="#geolocation-dialog">
+ <h4 class="panel-title clickable">Fehler<span class="pull-right glyphicon glyphicon-remove"></span></h4>
+ </div>
+ <strong>Die Positionierung ihres Gerätes konnte nicht aktiviert werden.</strong><br/>
+ Bitte stellen Sie sicher, dass Sie ihrem Web-Browser den Zugriff auf ihren Standort erlauben
+ und diese Seite über eine gesicherte Verbindung aufrufen (https).
+ </div>
+ </div>
+ </div>
+ </div>
+ </div>
+ </div>
+ <!-- Loader Dialog -->
+ <div class="modal fade" id="loader-dialog">
+ <div class="panel-heading">
+ <h4 class="panel-title" id="loader-title">Bitte warten...<span class="glyphicon glyphicon-refresh pull-right"></span></h4>
+ </div>
+ <span id="loader-message">Karte wird geladen.</span>
+ </div>
+ <div class="progress" style="margin-bottom: 0px;">
+ <div class="progress-bar progress-bar-striped progress-bar-info active" role="progressbar"></div>
+ </div>
+ </div>
+ </div>
+ </div>
+ </div>
+ <!-- Templates -->
+ <script type="text/html" id="menu-layer-template">
+ <li data-id="id" >
+ <a href="#" class="btn-layer" data-template-bind='{ "attribute": "data-id", "value": "id" }'>
+ <span class="icon-left glyphicon glyphicon-unchecked"></span>
+ <span data-content="title"></span>
+ </a>
+ </li>
+ </script>
+ <script type="text/html" id="menu-group-template">
+ <li data-id="id" class="dropdown-submenu">
+ <a href="#" class="btn-group" data-template-bind='{ "attribute": "data-id", "value": "id" }'>
+ <span class="icon-folder glyphicon glyphicon-folder-open"></span>
+ <span class="hidden-md hidden-lg caret"></span>
+ <span class="hidden-xs hidden-sm caret-right"></span>
+ </a>
+ <ul class="dropdown-menu child-container">
+ </ul>
+ </li>
+ </script>
+ <script type="text/html" id="layer-item-template">
+ <div data-id="id">
+ <a href="#" class="btn-layer list-group-item" data-template-bind='{ "attribute": "data-id", "value": "id" }'>
+ <span class="pull-right">
+ <span class="btn-remove glyphicon glyphicon-remove"></span>
+ </span>
+ </a>
+ </div>
+ </script>
+ <script type="text/html" id="layer-group-template">
+ <div data-id="id" class="hover-group">
+ <a href="" class="btn-group list-group-item collapser" data-template-bind='{ "attribute": "data-id", "value": "id" }' data-toggle="collapse">
+ <span class="btn-remove-group glyphicon glyphicon-remove" title="Dienst entfernen"></span>
+ <span class="icon-right glyphicon glyphicon-chevron-down"></span>
+ </span>
+ </a>
+ <div class="collapse child-container">
+ </div>
+ </div>
+ </script>
+ <script type="text/html" id="map-layer-template">
+ <span class="icon-left glyphicon glyphicon-check"></span>
+ <span class="btn-zoom glyphicon glyphicon-fullscreen" title="Zoom"></span>
+ <span class="btn-up glyphicon glyphicon-arrow-up" title="Rauf"></span>
+ <span class="btn-down glyphicon glyphicon-arrow-down" title="Runter"></span>
+ </span>
+ </a>
+ </div>
+ </script>
+ <script type="text/html" id="layer-result-template">
+ <div class="list-group-item" data-template-bind='{ "attribute": "data-index", "value": "index" }'>
+ <h4 class="list-group-item-heading clickable">
+ <span class="result-item-title" data-content="title"></span>
+ <!--<span class="badge" data-content="count"></span>-->
+ <span class="btn-add pull-right glyphicon glyphicon-plus"></span>
+ </h4>
+ <div class="list-group-item-text">
+ <div class="collapse">
+ <table class="table table-condensed">
+ <thead><tr><th>Beschreibung:</tb></tr></thead>
+ <tbody><tr><td data-content="details"></td></tr></tbody>
+ </table>
+ <thead><tr><th>Ebenen:</tb></tr></thead>
+ <tbody data-content="rows"></tbody>
+ </table>
+ </div>
+ <button class="btn btn-default btn-xs btn-block collapser"><span class="glyphicon glyphicon-triangle-bottom"></span></button>
+ </div>
+ </div>
+ </script>
+ <script type="text/html" id="search-result-template">
+ <a href="#" class="list-group-item search-result" data-template-bind='{ "attribute": "data-index", "value": "index" }'>
+ <span class="icon-left glyphicon glyphicon-map-marker"></span>
+ </a>
+ </script>
+ <!-- TODO: layer item collapse -->
+ <script type="text/html" id="legend-item-template">
+ <div class="panel-heading clickable">
+ <h4 class="panel-title"><span data-content="title"></span></h4>
+ </div>
+ <img data-template-bind='{ "attribute": "src", "value": "url" }'></img>
+ </div>
+ </div>
+ </script>
+ <!-- Custom Scripts -->
+ <script type="text/javascript" src="./scripts/netgis/config.js"></script>
+ <script type="text/javascript" src="./scripts/netgis/events.js"></script>
+ <script type="text/javascript" src="./scripts/netgis/entity.js"></script>
+ <script type="text/javascript" src="./scripts/netgis/component.js"></script>
+ <script type="text/javascript" src="./scripts/netgis/entities.js"></script>
+ <script type="text/javascript" src="./scripts/netgis/params.js"></script>
+ <script type="text/javascript" src="./scripts/netgis/loader.js"></script>
+ <script type="text/javascript" src="./scripts/netgis/map.js"></script>
+ <script type="text/javascript" src="./scripts/netgis/menu.js"></script>
+ <script type="text/javascript" src="./scripts/netgis/manager.js"></script>
+ <script type="text/javascript" src="./scripts/netgis/layers.js"></script>
+ <!-- Embedded Client Callback -->
+ <script type="text/javascript">$( document ).ready( netgis.client.onDocReady );</script>
+ </div>
Added: trunk/mapbender/http/extensions/mobilemap2/scripts/netgis/client.js
--- trunk/mapbender/http/extensions/mobilemap2/scripts/netgis/client.js (rev 0)
+++ trunk/mapbender/http/extensions/mobilemap2/scripts/netgis/client.js 2019-06-14 07:30:34 UTC (rev 10148)
@@ -0,0 +1,61 @@
+ * The main NetGIS namespace. Should contain all other modules.
+ * @namespace
+var netgis =
+netgis.client =
+ function ()
+ "use strict";
+ // Variables
+ var customCallback;
+ // Methods
+ var load = function( target, callback )
+ var container = $( "#" + target );
+ container.load
+ "./scripts/netgis/client.html",
+ null,
+ function( data, status )
+ if ( status === "success" )
+ customCallback = callback;
+ //container.find( ".navbar" ).toggleClass( "navbar-embedded", true );
+ var onDocReady = function()
+ $( "#client-loader" ).fadeOut();
+ if ( customCallback ) customCallback();
+ // Public Interface
+ var iface =
+ load: load,
+ onDocReady: onDocReady
+ return iface;
+// Entry Point
+//console.info( "Loading Client..." );
+//$( "#geoportal-container" ).load( "./scripts/netgis/client.html" );
Modified: trunk/mapbender/http/extensions/mobilemap2/scripts/netgis/component.js
--- trunk/mapbender/http/extensions/mobilemap2/scripts/netgis/component.js 2019-06-13 15:04:42 UTC (rev 10147)
+++ trunk/mapbender/http/extensions/mobilemap2/scripts/netgis/component.js 2019-06-14 07:30:34 UTC (rev 10148)
@@ -145,3 +145,13 @@
netgis.component.Extent.prototype.name = "extent";
+/** Opacity */
+netgis.component.Opacity = function( value )
+ this.value = value;
+ return this;
+netgis.component.Opacity.prototype.name = "opacity";
Modified: trunk/mapbender/http/extensions/mobilemap2/scripts/netgis/config.js
--- trunk/mapbender/http/extensions/mobilemap2/scripts/netgis/config.js 2019-06-13 15:04:42 UTC (rev 10147)
+++ trunk/mapbender/http/extensions/mobilemap2/scripts/netgis/config.js 2019-06-14 07:30:34 UTC (rev 10148)
@@ -72,6 +72,6 @@
URL_HEIGHT_PROXY: "",
//URL_HEIGHT_REQUEST: "http://www.geoportal.rlp.de/mapbender/extensions/mobilemap/query/rasterqueryWms.php?&lang=de" //"http://www.gdi-rp-dienste2.rlp.de/cgi-bin/mapserv.fcgi?map=/data/umn/geoportal/dhm_query/dhm.map&" + "SERVICE=WMS&VERSION=1.1.1&REQUEST=GetFeatureInfo&SERVICE=WMS&LAYERS=mydhm&QUERY_LAYERS=mydhm"
URL_HEIGHT_REQUEST: "../../extensions/mobilemap/query/rasterqueryWms.php?&lang=de"
+ URL_USAGE_TERMS: "http://www.geoportal.rlp.de/portal/servicebereich/rechtshinweis.html"
Modified: trunk/mapbender/http/extensions/mobilemap2/scripts/netgis/layers.js
--- trunk/mapbender/http/extensions/mobilemap2/scripts/netgis/layers.js 2019-06-13 15:04:42 UTC (rev 10147)
+++ trunk/mapbender/http/extensions/mobilemap2/scripts/netgis/layers.js 2019-06-14 07:30:34 UTC (rev 10148)
@@ -1,7 +1,7 @@
* NetGIS WebGIS Client
- * (c) Sebastian Pauli, NetGIS, 2017
+ * (c) Sebastian Pauli, NetGIS, 2017-2019
@@ -25,31 +25,21 @@
netgis.events.on( netgis.events.LAYER_TOGGLE, onLayerToggle );
netgis.events.on( netgis.events.LAYER_REMOVE, onLayerRemove );
netgis.events.on( netgis.events.LAYERS_LOADING, onLayersLoading );
- // Get Parameters
- var url = window.location.search.substr( 1 );
- url = url.split( "&" );
- var params = {};
- for ( var i = 0; i < url.length; i++ )
+ // Request WMC
+ if ( netgis.params.get( "wmc_id" ) )
- var p = url[ i ].split( "=" );
- params[ p[ 0 ] ] = p[ 1 ];
+ requestWmc( netgis.params.get( "wmc_id" ) );
- // Request WMC
- if ( params.wmc_id )
- requestWmc( params.wmc_id );
else
netgis.events.call( netgis.events.LAYERS_LOADING, { loading: true } );
// Request Layer
- if ( params.layerid )
+ if ( netgis.params.get( "layerid" ) )
- singleLayerRequest = parseInt( params.layerid );
- requestLayers( [ params.layerid ] );
+ singleLayerRequest = parseInt( netgis.params.get( "layerid" ) );
+ requestLayers( [ netgis.params.get( "layerid" ) ] );
else
netgis.events.call( netgis.events.LAYERS_LOADING, { loading: false } );
@@ -62,7 +52,10 @@
- var url = netgis.config.URL_WMC_REQUEST + "?confFileName=" + netgis.config.CONF_FILE_NAME + "&wmc_id=" + id + "&epsg=" + netgis.config.MAP_PROJECTION.split( ":" )[ 1 ] + "&withHierarchy=1";
+ var url = netgis.config.URL_WMC_REQUEST;
+ var lastChar = url.charAt( url.length - 1 );
+ if ( lastChar !== "?" && lastChar !== "&" ) url += "?";
+ url += "confFileName=" + netgis.config.CONF_FILE_NAME + "&wmc_id=" + id + "&epsg=" + netgis.config.MAP_PROJECTION.split( ":" )[ 1 ] + "&withHierarchy=1";
if ( netgis.config.URL_WMC_PROXY && netgis.config.URL_WMC_PROXY.length > 0 )
@@ -140,9 +133,14 @@
entity.set( new netgis.component.Parent( parentEntity ) );
//entity.set( new netgis.component.Position( layerData.layerPos ) );
+ //entity.print();
if ( layerData.getLegendGraphicUrl && layerData.getLegendGraphicUrlFormat )
entity.set( new netgis.component.Legend( layerData.getLegendGraphicUrl, layerData.getLegendGraphicUrlFormat ) );
+ if ( layerData.legendUrl )
+ entity.set( new netgis.component.Legend( decodeURIComponent( layerData.legendUrl ), layerData.getLegendGraphicUrlFormat ) );
if ( layerData.layerQueryable === 1 || layerData.queryable === 1 ) //NOTE: these two props should have the same name!
entity.set( new netgis.component.Queryable() );
@@ -226,6 +224,11 @@
// Set active from WMC
if ( layer.active === true )
entity.set( new netgis.component.Active() );
+ if ( layer.opacity )
+ entity.set( new netgis.component.Opacity( parseFloat( layer.opacity ) * 0.01 ) );
+ //console.info( "WMC Layer:", layer );
requestLayers( ids );
Modified: trunk/mapbender/http/extensions/mobilemap2/scripts/netgis/manager.js
--- trunk/mapbender/http/extensions/mobilemap2/scripts/netgis/manager.js 2019-06-13 15:04:42 UTC (rev 10147)
+++ trunk/mapbender/http/extensions/mobilemap2/scripts/netgis/manager.js 2019-06-14 07:30:34 UTC (rev 10148)
@@ -235,7 +235,7 @@
var parentElement = layerList.find( "#" + parent.id );
childElement.detach();
- parentElement.find( ".child-container" ).append( childElement );
+ parentElement.children( ".child-container" ).append( childElement );
Modified: trunk/mapbender/http/extensions/mobilemap2/scripts/netgis/map.js
--- trunk/mapbender/http/extensions/mobilemap2/scripts/netgis/map.js 2019-06-13 15:04:42 UTC (rev 10147)
+++ trunk/mapbender/http/extensions/mobilemap2/scripts/netgis/map.js 2019-06-14 07:30:34 UTC (rev 10148)
@@ -1,7 +1,7 @@
@@ -50,6 +50,8 @@
var backLayerHybrid;
var backLayerAerial;
+ var scaleBar;
var interactions =
pan: null,
@@ -312,12 +314,8 @@
$( "#popup-closer" ).click( onPopupClose );
// Scale Bar
- var scaleBar = new ol.control.ScaleLine();
+ setScaleBarVisible( true );
- map.addControl( scaleBar );
- $( container ).find( ".ol-scale-line" ).addClass( "shadow-md" );
// Events
@@ -343,8 +341,34 @@
positionCenter = false;
map.updateSize();
+ // Parameters
+ var center = getCenter();
+ var zoom = getZoom();
+ if ( netgis.params.get( "x" ) ) center[ 0 ] = netgis.params.getFloat( "x" );
+ if ( netgis.params.get( "y" ) ) center[ 1 ] = netgis.params.getFloat( "y" );
+ if ( netgis.params.get( "z" ) ) zoom = netgis.params.getFloat( "z" );
+ setView( center, zoom );
+ if ( netgis.params.getInt( "scale_bar" ) === 0 ) setScaleBarVisible( false );
+ var setScaleBarVisible = function( on )
+ if ( on )
+ scaleBar = new ol.control.ScaleLine();
+ map.addControl( scaleBar );
+ $( container ).find( ".ol-scale-line" ).addClass( "shadow-md" );
+ else
+ if ( scaleBar ) map.removeControl( scaleBar );
var setInteraction = function( i )
// Clear Old Interaction
@@ -551,6 +575,16 @@
return getScaleFromResolution( view.getResolution() );
+ var getZoom = function()
+ return view.getZoom();
+ var getCenter = function()
+ return view.getCenter();
var addHistory = function( center, zoom )
// No duplicates at the end
@@ -610,7 +644,7 @@
return scale;
- var createLayerWms = function( url, layerName, index )
+ var createLayerWms = function( url, layerName, index, opacity )
//var type = ol.source.TileWMS;
@@ -678,7 +712,7 @@
source: source,
zIndex: index,
- opacity: netgis.config.MAP_DEFAULT_OPACITY
+ opacity: opacity ? opacity : netgis.config.MAP_DEFAULT_OPACITY //NOTE: should be obsolete, default passed in anyway
@@ -689,9 +723,9 @@
//TODO: remove old background layer if exists
- console.info( "BG:", url, layerName );
+ //console.info( "BG:", url, layerName );
- map.addLayer( createLayerWms( url, layerName, 0 ) );
+ map.addLayer( createLayerWms( url, layerName, 0, netgis.config.MAP_DEFAULT_OPACITY ) );
var requestFeatureInfo = function( url, layer )
@@ -794,8 +828,10 @@
var name = layer.components.name.value;
var index = layer.components.order.value; //layers.length - l; //TODO: real layer order?
+ var opacity = layer.components.opacity ? layer.components.opacity.value : netgis.config.MAP_DEFAULT_OPACITY;
- var mapLayer = createLayerWms( url, name, index );
+ var mapLayer = createLayerWms( url, name, index, opacity );
layer.set( new netgis.component.MapLayer( mapLayer ) );
@@ -893,8 +929,11 @@
var onMapClick = function( event )
- popupContent.empty();
+ //popupContent.empty();
+ netgis.menu.clearSideContent();
+ netgis.menu.toggleSideMenu( true );
// KML Feature Info
var features = [];
var pixel = map.getEventPixel( event.originalEvent );
@@ -937,7 +976,8 @@
var element = $( content );
element.find( ".panel-heading" ).click( function() { element.find( "#" + panelId ).collapse( "toggle" ); } );
- popupContent.append( element );
+ //popupContent.append( element );
+ netgis.menu.addSideContent( element );
// WMS Feature Info
@@ -982,11 +1022,12 @@
var frame_url = url;
if ( netgis.config.URL_FEATURE_INFO_PROXY && netgis.config.URL_FEATURE_INFO_PROXY.length > 0 )
- frame_url = netgis.config.URL_FEATURE_INFO_PROXY + "?q=" + encodeURIComponent( url );
+ frame_url = netgis.config.URL_FEATURE_INFO_PROXY + "?q=" + encodeURIComponent( url );
content += "<div id='" + panelId + "' class='panel-collapse collapse'>";
content += "<div class='panel-body'>";
- content += "<iframe seamless width='280' height='100' src='" + frame_url + "'></iframe>";
+ //content += "<iframe seamless width='280' height='100' src='" + frame_url + "'></iframe>";
+ content += "<iframe seamless width='280' src='" + frame_url + "'></iframe>";
content += "</div>";
@@ -1007,8 +1048,8 @@
@@ -1050,7 +1091,8 @@
@@ -1067,6 +1109,13 @@
var onPopupClose = function( event )
popupContainer.fadeOut( 200 );
+ // Close Menu
+ netgis.menu.toggleSideMenu( false );
+ // Default Interaction
+ pan();
var onFeatureInfoResponse = function( data, layer )
@@ -1109,7 +1158,7 @@
zIndex: 999,
- opacity: netgis.config.MAP_DEFAULT_OPACITY,
+ opacity: kml.components.opacity ? kml.components.opacity.value : netgis.config.MAP_DEFAULT_OPACITY,
style: onKmlStyle
@@ -1153,9 +1202,11 @@
var index = layers.length - l; //TODO: real layer order?
//TODO: layer list deprecated because of map layer component?
- var mapLayer = layerList[ layer.id ] = createLayerWms( url, name, index );
+ var mapLayer = layerList[ layer.id ] = createLayerWms( url, name, index, opacity );
//TODO: create only layers without children (non-groups)
@@ -1438,6 +1489,8 @@
setView: setView,
setViewScale: setViewScale,
updateSize: updateSize,
+ getZoom: getZoom,
+ getCenter: getCenter,
isPositionActive: isPositionActive,
isPositionCenter: isPositionCenter,
setBackgroundLayer: setBackgroundLayer,
@@ -1445,6 +1498,7 @@
getScale: getScale,
showPopup: showPopup,
hidePopup: hidePopup,
+ setScaleBarVisible: setScaleBarVisible,
setInteraction: setInteraction,
interactions: interactions,
Modified: trunk/mapbender/http/extensions/mobilemap2/scripts/netgis/menu.js
--- trunk/mapbender/http/extensions/mobilemap2/scripts/netgis/menu.js 2019-06-13 15:04:42 UTC (rev 10147)
+++ trunk/mapbender/http/extensions/mobilemap2/scripts/netgis/menu.js 2019-06-14 07:30:34 UTC (rev 10148)
@@ -1,7 +1,7 @@
@@ -15,6 +15,7 @@
"use strict";
// Private Variables
+ var navbarContainer;
var layerMenu;
var searchInput;
var searchPanel;
@@ -25,7 +26,13 @@
var searchButton;
var searchMessage;
var scaleItems;
+ var scaleCustom;
+ var scaleDivider;
+ var scaleValue;
+ var sideMenu;
+ var sideMenuContent;
var legendPanel;
var geolocationDialog;
@@ -32,6 +39,7 @@
// Private Methods
var init = function()
+ navbarContainer = $( "#navbar-container" );
layerMenu = $( "#layer-menu" );
searchInput = $( "#search-input" );
searchPanel = $( "#search-panel" );
@@ -39,17 +47,18 @@
//searchSpinner = $( "#search-spinner" );
searchButton = $( "#search-button" );
searchMessage = $( "#search-message" );
legendPanel = $( "#legend-panel" );
geolocationDialog = $( "#geolocation-dialog" );
- $( "#legend-dialog" ).on( "show.bs.modal", onLegendShow );
+ // Side Menu
+ sideMenu = $( "#side-menu" );
+ sideMenuContent = sideMenu.find( "#side-menu-content" );
+ // Scales
var scaleMenu = $( "#scale-menu" );
var scales = netgis.config.MAP_SCALES;
//TODO: use html template
for ( var s = 0; s < scales.length; s++ )
var item = "<li data-scale='" + scales[ s ] + "'>";
@@ -65,8 +74,22 @@
scaleItems = scaleMenu.find( ".btn-scale" );
scaleItems.click( onScaleClick );
+ scaleCustom = scaleMenu.find( "#scale-custom" );
+ scaleDivider = scaleMenu.find( "#scale-divider" );
+ scaleValue = scaleCustom.find( ".scale-value" );
+ onMapMove( null );
+ // Search
searchInput.val( "" );
+ // Info Links
+ if ( netgis.config.URL_USAGE_TERMS )
+ var usageTerms = $( "#usage-terms-link" );
+ usageTerms.attr( "href", netgis.config.URL_USAGE_TERMS );
// Events
$( ".navbar-brand" ).click( onBrandClick );
@@ -88,6 +111,8 @@
$( ".btn-position-center" ).click( onPositionCenterClick );
$( ".btn-position-zoom" ).click( onPositionZoomClick );
+ $( "#legend-dialog" ).on( "show.bs.modal", onLegendShow );
layerMenu.parent().on( "hidden.bs.dropdown", onLayerMenuHidden );
searchInput.change( onSearchChange );
@@ -103,9 +128,148 @@
netgis.events.on( netgis.events.POSITION_ERROR, onPositionError );
netgis.events.on( netgis.events.MAP_MOVE, onMapMove );
+ // Parameters
+ if ( netgis.params.getInt( "menu_title" ) === 0 ) setTitleVisible( false );
+ if ( netgis.params.getInt( "layer_menu" ) === 0 ) setLayerMenuVisible( false );
+ if ( netgis.params.getInt( "tool_menu" ) === 0 ) setToolMenuVisible( false );
+ if ( netgis.params.getInt( "position_menu" ) === 0 ) setPositionMenuVisible( false );
+ if ( netgis.params.getInt( "scale_menu" ) === 0 ) setScaleMenuVisible( false );
+ if ( netgis.params.getInt( "info_menu" ) === 0 ) setInfoMenuVisible( false );
+ if ( netgis.params.getInt( "search_bar" ) === 0 ) setSearchBarVisible( false );
+ if ( netgis.params.getInt( "zoom_bar" ) === 0 ) setZoomBarVisible( false );
+ if ( netgis.params.getInt( "feature_info" ) === 0 ) setFeatureInfoButtonVisible( false );
+ if ( netgis.params.getInt( "legend_button" ) === 0 ) setLegendButtonVisible( false );
- //TODO: testing
+ var setTitleVisible = function( on )
+ if ( on )
+ $( "#menu-title" ).show();
+ else
+ $( "#menu-title" ).hide();
+ var setLayerMenuVisible = function( on )
+ if ( on )
+ $( "#layer-menu-container" ).show();
+ else
+ $( "#layer-menu-container" ).hide();
+ var setToolMenuVisible = function( on )
+ if ( on )
+ $( "#tool-menu-container" ).show();
+ else
+ $( "#tool-menu-container" ).hide();
+ var setPositionMenuVisible = function( on )
+ if ( on )
+ $( "#geolocation-menu-container" ).show();
+ else
+ $( "#geolocation-menu-container" ).hide();
+ var setScaleMenuVisible = function( on )
+ if ( on )
+ $( "#scale-menu-container" ).show();
+ else
+ $( "#scale-menu-container" ).hide();
+ var setInfoMenuVisible = function( on )
+ if ( on )
+ $( "#info-menu-container" ).show();
+ else
+ $( "#info-menu-container" ).hide();
+ var setSearchBarVisible = function( on )
+ if ( on )
+ $( "#search-bar-container" ).show();
+ else
+ $( "#search-bar-container" ).hide();
+ var setZoomBarVisible = function( on )
+ if ( on )
+ $( "#zoom-bar-container" ).show();
+ else
+ $( "#zoom-bar-container" ).hide();
+ var setFeatureInfoButtonVisible = function( on )
+ if ( on )
+ var e = $( "#feature-info-button" );
+ e.show();
+ e.parent().toggleClass( "btn-group-vertical", true );
+ else
+ e.hide();
+ e.parent().toggleClass( "btn-group-vertical", false );
+ var setLegendButtonVisible = function( on )
+ if ( on )
+ var e = $( "#legend-button" );
+ e.show();
+ else
+ e.hide();
var update = function()
// Clear
@@ -182,6 +346,8 @@
//layerResultsList.empty();
//layerResultsCount.text( "0" );
+ toggleSideMenu( false );
query = encodeURIComponent( $.trim( query ) );
if ( query.length < 2 ) return;
@@ -234,6 +400,21 @@
searchQuery = query;
+ var toggleSideMenu = function( on )
+ sideMenu.toggleClass( "visible", on );
+ var clearSideContent = function( content )
+ sideMenuContent.empty();
+ var addSideContent = function( item )
+ sideMenuContent.append( item );
// Event Handlers
$( document ).ready( init );
@@ -307,7 +488,7 @@
var parentElement = layerMenu.find( "#" + parent.id );
@@ -672,11 +853,15 @@
var url = layer.components.legend.url;
- url += "service=wms";
- url += "&version=1.1.1";
- url += "&request=GetLegendGraphic";
- url += "&format=" + layer.components.legend.format;
- url += "&layer=" + layer.components.name.value;
+ // Append parameters if not already given in url string
+ if ( url.search( /GetLegendGraphic/i ) === -1 )
+ url += "service=wms";
+ url += "&version=1.1.1";
+ url += "&request=GetLegendGraphic";
+ url += "&format=" + layer.components.legend.format;
+ url += "&layer=" + layer.components.name.value;
var item =
@@ -692,6 +877,8 @@
var scale = netgis.map.getScale();
+ var found = false;
scaleItems.each
function( key, value )
@@ -699,17 +886,52 @@
var item = $( value ).parent();
var icon = item.find( ".glyphicon" );
- var checked = ( scale === item.data( "scale" ) );
+ var checked = false;
+ if ( scale === item.data( "scale" ) )
+ var checked = true;
+ found = true;
icon.toggleClass( "glyphicon-check", checked );
icon.toggleClass( "glyphicon-unchecked", ! checked );
+ if ( found === true )
+ scaleCustom.hide();
+ scaleDivider.hide();
+ else
+ scaleValue.text( scale );
+ scaleCustom.data( "scale", scale );
+ scaleCustom.show();
+ scaleDivider.show();
// Public Interface
var iface =
- update: update
+ update: update,
+ toggleSideMenu: toggleSideMenu,
+ clearSideContent: clearSideContent,
+ addSideContent: addSideContent,
+ setTitleVisible: setTitleVisible,
+ setLayerMenuVisible: setLayerMenuVisible,
+ setToolMenuVisible: setToolMenuVisible,
+ setPositionMenuVisible: setPositionMenuVisible,
+ setScaleMenuVisible: setScaleMenuVisible,
+ setInfoMenuVisible: setInfoMenuVisible,
+ setSearchBarVisible: setSearchBarVisible,
+ setZoomBarVisible: setZoomBarVisible,
+ setFeatureInfoButtonVisible: setFeatureInfoButtonVisible,
+ setLegendButtonVisible: setLegendButtonVisible
return iface;
Added: trunk/mapbender/http/extensions/mobilemap2/scripts/netgis/params.js
--- trunk/mapbender/http/extensions/mobilemap2/scripts/netgis/params.js (rev 0)
+++ trunk/mapbender/http/extensions/mobilemap2/scripts/netgis/params.js 2019-06-14 07:30:34 UTC (rev 10148)
@@ -0,0 +1,71 @@
+ * NetGIS WebGIS Client
+ * (c) Sebastian Pauli, NetGIS, 2019
+ * The NetGIS Parameters module (for runtime settings, not launch config!).
+ * @namespace
+netgis.params =
+ function ()
+ "use strict";
+ // Variables
+ var getParams;
+ // Methods
+ var init = function()
+ // Get Parameters
+ var url = window.location.search.substr( 1 );
+ url = url.split( "&" );
+ getParams = {};
+ for ( var i = 0; i < url.length; i++ )
+ var p = url[ i ].split( "=" );
+ getParams[ p[ 0 ].toLowerCase() ] = p[ 1 ];
+ var get = function( key )
+ return getParams[ key.toLowerCase() ];
+ var getString = function( key )
+ //TODO: check string output, otherwise same as raw get
+ var getInt = function( key )
+ return parseInt( getParams[ key.toLowerCase() ] );
+ var getFloat = function( key )
+ return parseFloat( getParams[ key.toLowerCase() ] );
+ // Entry Point
+ init();
+ var iface =
+ get: get,
+ getString: getString,
+ getInt: getInt,
+ getFloat: getFloat
+ return iface;
Modified: trunk/mapbender/http/extensions/mobilemap2/styles/common.css
--- trunk/mapbender/http/extensions/mobilemap2/styles/common.css 2019-06-13 15:04:42 UTC (rev 10147)
+++ trunk/mapbender/http/extensions/mobilemap2/styles/common.css 2019-06-14 07:30:34 UTC (rev 10148)
@@ -29,11 +29,6 @@
z-index: 900;
-/*.gj-tree-drag-el
- z-index: 1020;
.clickable
cursor: pointer;
@@ -75,48 +70,4 @@
0% { transform: rotate( 0deg ); }
100% { transform: rotate( 360deg ); }
-.dropdown-submenu {
- position:relative;
-.dropdown-submenu>.dropdown-menu {
- top:0;
- left:100%;
- margin-top:-6px;
- margin-left:-1px;
- -webkit-border-radius:0 6px 6px 6px;
- -moz-border-radius:0 6px 6px 6px;
- border-radius:0 6px 6px 6px;
-.dropdown-submenu:hover>.dropdown-menu {
- display:block;
-.dropdown-submenu>a:after {
- display:block;
- content:" ";
- float:right;
- width:0;
- height:0;
- border-color:transparent;
- border-style:solid;
- border-width:5px 0 5px 5px;
- border-left-color:#cccccc;
- margin-top:5px;
- margin-right:-10px;
-.dropdown-submenu:hover>a:after {
- border-left-color:#ffffff;
-.dropdown-submenu.pull-left {
- float:none;
-.dropdown-submenu.pull-left>.dropdown-menu {
- left:-100%;
- margin-left:10px;
- -webkit-border-radius:6px 0 6px 6px;
- -moz-border-radius:6px 0 6px 6px;
- border-radius:6px 0 6px 6px;
Modified: trunk/mapbender/http/extensions/mobilemap2/styles/layout.css
--- trunk/mapbender/http/extensions/mobilemap2/styles/layout.css 2019-06-13 15:04:42 UTC (rev 10147)
+++ trunk/mapbender/http/extensions/mobilemap2/styles/layout.css 2019-06-14 07:30:34 UTC (rev 10148)
@@ -1,11 +1,4 @@
-/* https://stackoverflow.com/questions/19089384/twitter-bootstrap-3-two-columns-full-height */
-html, body
- height: 100%;
.container-full
position: absolute;
Modified: trunk/mapbender/http/extensions/mobilemap2/styles/menu.css
--- trunk/mapbender/http/extensions/mobilemap2/styles/menu.css 2019-06-13 15:04:42 UTC (rev 10147)
+++ trunk/mapbender/http/extensions/mobilemap2/styles/menu.css 2019-06-14 07:30:34 UTC (rev 10148)
@@ -1,4 +1,8 @@
+#navbar-container
.dropdown-submenu {
position: relative;
@@ -49,4 +53,41 @@
border-top-left-radius: 0px;
border-bottom-right-radius: 0px;
border-bottom-left-radius: 0px;
+.navbar-embedded .navbar-header
+ float: none;
+.navbar-embedded .navbar-toggle
+ display: block;
+.navbar-embedded .navbar-collapse.collapse
+ display: none !important;
+.navbar-embedded .navbar-nav
+ float: none !important;
+.navbar-embedded .navbar-nav>li
+ float: none;
+.navbar-embedded .navbar-collapse.collapse.in
+ display: block !important;
+.navbar-embedded
+ max-height: 100%;
+ overflow: auto;
+ z-index: 1010;
Modified: trunk/mapbender/http/extensions/mobilemap2/styles/popup.css
--- trunk/mapbender/http/extensions/mobilemap2/styles/popup.css 2019-06-13 15:04:42 UTC (rev 10147)
+++ trunk/mapbender/http/extensions/mobilemap2/styles/popup.css 2019-06-14 07:30:34 UTC (rev 10148)
@@ -10,7 +10,7 @@
border: 1px solid #cccccc;
bottom: 12px;
left: -50px;
- min-width: 343px; /*365px; /*280px;*/
+ min-width: 100px; /*343px;*/ /*365px; /*280px;*/
cursor: auto;
Added: trunk/mapbender/http/extensions/mobilemap2/styles/sidemenu.css
--- trunk/mapbender/http/extensions/mobilemap2/styles/sidemenu.css (rev 0)
+++ trunk/mapbender/http/extensions/mobilemap2/styles/sidemenu.css 2019-06-14 07:30:34 UTC (rev 10148)
@@ -0,0 +1,18 @@
+#side-menu
+ background-color: white;
+ width: 343px;
+ position: absolute;
+ left: -400px;
+ top: 0px;
+ bottom: 0px;
+ z-index: 1050;
+ box-shadow: rgba( 0, 0, 0, 0.176 ) 0px 6px 12px;
+ transition: left 0.2s;
+#side-menu.visible
+ left: 0px;
Added: trunk/mapbender/http/extensions/mobilemap2/test_embed.html
--- trunk/mapbender/http/extensions/mobilemap2/test_embed.html (rev 0)
+++ trunk/mapbender/http/extensions/mobilemap2/test_embed.html 2019-06-14 07:30:34 UTC (rev 10148)
@@ -0,0 +1,59 @@
+<!DOCTYPE html>
+(c) Sebastian Pauli, NetGIS, 2017-2019
+<html lang="de">
+ <head>
+ <meta http-equiv="content-type" content="text/html; charset=utf-8" />
+ <meta name="viewport" content="width=device-width, initial-scale=1" />
+ <title>GeoPortal RLP</title>
+ <link rel="stylesheet" type="text/css" href="./libs/bootstrap/css/bootstrap-custom.min.css" />
+ <link rel="stylesheet" type="text/css" href="./libs/openlayers/ol.css" />
+ <style>
+ html, body
+ width: 100%;
+ height: 100%;
+ </style>
+ </head>
+ <body>
+ <p>Embedded Geoportal Client:</p>
+ <div id="geoportal-container" style="border: 1px solid red; width: 600px; height: 400px; margin-left: 100px;"></div>
+ <script type="text/javascript" src="./libs/jquery/jquery.min.js"></script>
+ <script type="text/javascript" src="./libs/jquery-template/jquery.loadTemplate.min.js"></script>
+ <script type="text/javascript" src="./libs/bootstrap/js/bootstrap.min.js"></script>
+ <script type="text/javascript" src="./libs/proj4js/proj4.js"></script>
+ <script type="text/javascript" src="./libs/openlayers/ol-debug.js"></script>
+ <script type="text/javascript" src="./scripts/netgis/client.js"></script>
+ <script>
+ netgis.client.load
+ "geoportal-container",
+ function()
+ // Make sure the menu is not too large, otherwise we get a line wrap
+ netgis.menu.setTitleVisible( false );
+ netgis.menu.setToolMenuVisible( false );
+ netgis.menu.setScaleMenuVisible( false );
+ netgis.menu.setInfoMenuVisible( false );
+ </script>
+ </body>
+</html>
More information about the Mapbender_commits
