[Mapbender-commits] r10152 - trunk/mapbender/http/php
svn_mapbender at osgeo.org
Mon Jun 17 03:06:46 PDT 2019
Author: armin11
Date: 2019-06-17 03:06:46 -0700 (Mon, 17 Jun 2019)
New Revision: 10152
trunk/mapbender/http/php/mod_sessionWrapper.php
Possibility to write dummy multipolygon into session - for testing purposes only
Modified: trunk/mapbender/http/php/mod_sessionWrapper.php
--- trunk/mapbender/http/php/mod_sessionWrapper.php 2019-06-17 10:02:14 UTC (rev 10151)
+++ trunk/mapbender/http/php/mod_sessionWrapper.php 2019-06-17 10:06:46 UTC (rev 10152)
@@ -99,29 +99,30 @@
$value = urldecode($testMatch);
$testMatch = NULL;
} else {
-//generate dummy gml and put it into session:
-/*$bbox = "6,48,8,51";
-$newBbox = explode(",", $bbox);
-$GML = '<FeatureCollection xmlns:gml="http://www.opengis.net/gml"><boundedBy><Box srsName="EPSG:4326">';
-$GML .= "<coordinates>".$newBbox[0].",".$newBbox[1]." ".$newBbox[2];
-$GML .= ",".$newBbox[3]."</coordinates></Box>";
-$GML .= '</boundedBy><featureMember><gemeinde><title>BBOX</title><the_geom><MultiPolygon srsName="EPSG:';
-$GML .= "4326".'"><polygonMember><Polygon><outerBoundaryIs><LinearRing><coordinates>';
-$GML .= $newBbox[0].",".$newBbox[1]." ".$newBbox[2].",";
-$GML .= $newBbox[1]." ".$newBbox[2].",".$newBbox[3]." ";
-$GML .= $newBbox[0].",".$newBbox[3]." ".$newBbox[0].",".$newBbox[1];
-$GML .= "</coordinates></LinearRing></outerBoundaryIs></Polygon></polygonMember></MultiPolygon></the_geom></gemeinde></featureMember></FeatureCollection>";
-Mapbender::session()->set('GML',$GML);
-$resultObj['success'] = true;
-$resultObj['message'] = 'Dummy GML written into session!';
-$resultObj['result'] = null;
-echo json_encode($resultObj);
-die();*/
$resultObj['message'] = 'Parameter value for key '.$key.' not given!';
die();
+ if ($value == 'dummyPolygon') {
+ $bbox = "6,48,8,51";
+ $newBbox = explode(",", $bbox);
+ $GML = '<FeatureCollection xmlns:gml="http://www.opengis.net/gml"><boundedBy><Box srsName="EPSG:4326">';
+ $GML .= "<coordinates>".$newBbox[0].",".$newBbox[1]." ".$newBbox[2];
+ $GML .= ",".$newBbox[3]."</coordinates></Box>";
+ $GML .= '</boundedBy><featureMember><gemeinde><title>BBOX</title><the_geom><MultiPolygon srsName="EPSG:';
+ $GML .= "4326".'"><polygonMember><Polygon><outerBoundaryIs><LinearRing><coordinates>';
+ $GML .= $newBbox[0].",".$newBbox[1]." ".$newBbox[2].",";
+ $GML .= $newBbox[1]." ".$newBbox[2].",".$newBbox[3]." ";
+ $GML .= $newBbox[0].",".$newBbox[3]." ".$newBbox[0].",".$newBbox[1];
+ $GML .= "</coordinates></LinearRing></outerBoundaryIs></Polygon></polygonMember></MultiPolygon></the_geom></gemeinde></featureMember></FeatureCollection>";
+ Mapbender::session()->set('GML', $GML);
+ $resultObj['success'] = true;
+ $resultObj['message'] = 'Dummy GML MultiPolygon written into session!';
+ $resultObj['result'] = null;
+ echo json_encode($resultObj);
+ die();
Mapbender::session()->set('GML',$value);
$resultObj['message'] = 'GML written into session!';
More information about the Mapbender_commits
