[Mapbender-commits] r10159 - trunk/mapbender/http/php
svn_mapbender at osgeo.org svn_mapbender at osgeo.org
Wed Jun 26 06:25:30 PDT 2019
Author: armin11
Date: 2019-06-26 06:25:30 -0700 (Wed, 26 Jun 2019)
New Revision: 10159
   trunk/mapbender/http/php/mod_callCswMetadata.php
Fix for spatial search (bbox filter) via csw
Modified: trunk/mapbender/http/php/mod_callCswMetadata.php
--- trunk/mapbender/http/php/mod_callCswMetadata.php	2019-06-26 12:20:04 UTC (rev 10158)
+++ trunk/mapbender/http/php/mod_callCswMetadata.php	2019-06-26 13:25:30 UTC (rev 10159)
@@ -264,7 +264,7 @@
 		echo 'Parameter <b>searchTypeBbox</b> is not valid (inside,outside,intersects).<br/>';
 		die();
-	$searchTypeBbox = $testMatch; //TODO activate this
+	$searchTypeBbox = $testMatch;
 	$testMatch = NULL;
 /*if (isset($_REQUEST["accessRestrictions"]) & $_REQUEST["accessRestrictions"] != "") {
@@ -484,26 +484,26 @@
 //	$queryText = '';
 //} else {
-/*if (count($searchTextArray) > 1) {
+if (count($searchTextArray) > 1) {
 	$fullTextFilter = "<ogc:And>";
 } else {
 	$fullTextFilter = "";
-$fullTextFilter = "";
-//foreach($searchTextArray as $queryString) {
+//$fullTextFilter = "";
+foreach($searchTextArray as $queryString) {
 	$fullTextFilter .= '<ogc:PropertyIsLike wildCard="*" singleChar="_" escapeChar="">';
 	$fullTextFilter .= '<ogc:PropertyName>AnyText</ogc:PropertyName>';
 	/*if($queryString != '*'){
 		$queryString = '*' . explode($queryString) . '*';
-	$queryString = '*' . implode("*", $searchTextArray) . '*';
-	$fullTextFilter .= '<ogc:Literal>'.$queryString.'</ogc:Literal>';
+	//$queryString = '*' . implode("*", $searchTextArray) . '*';
+	$fullTextFilter .= '<ogc:Literal>'.$queryString.'*</ogc:Literal>';
 	$fullTextFilter .= '</ogc:PropertyIsLike>';
 	$fullTextFilter .= "</ogc:And>";
 	$fullTextFilter .= '<ogc:PropertyIsLike wildCard="%" singleChar="_" escapeChar="">';
@@ -513,10 +513,11 @@
 $existsSpatialFilter = false;
 $searchBboxArray = explode(",", $searchBbox);
+//TODO: test the right filter!
 if ($searchBbox !== NULL) {
     $existsSpatialFilter = true;
     switch ($searchTypeBbox) {
-	case "intersect":
+	case "intersects":
 		$spatialFilter .= "<ogc:BBOX>";
 	break;
 	case "inside":
@@ -529,10 +530,10 @@
     $spatialFilter .= "<ogc:PropertyName>BoundingBox</ogc:PropertyName>";
-    $spatialFilter .= "<gml:Envelope>";
-    $spatialFilter .= "<gml:lowerCorner>".$searchBboxArray[0]." ".$searchBboxArray[1]."</gml:lowerCorner>";
-    $spatialFilter .= "<gml:upperCorner>".$searchBboxArray[2]." ".$searchBboxArray[3]."</gml:upperCorner>";
-    $spatialFilter .= "</gml:Envelope>";
+    $spatialFilter .= '<gml:Box xmlns:gml="http://www.opengis.net/gml" srsName="EPSG:4326">';
+    $spatialFilter .= '<gml:coordinates decimal="." cs="," ts=" ">';
+    $spatialFilter .= $searchBboxArray[0].','.$searchBboxArray[1].' '.$searchBboxArray[2].','.$searchBboxArray[3];
+    $spatialFilter .= '</gml:coordinates></gml:Box>';
 	case "intersect":
 		$spatialFilter .= "</ogc:BBOX>";
@@ -544,12 +545,12 @@
 		$spatialFilter .= "</ogc:Disjoint>";
 	break;
 	default:
-		$spatialFilter .= "/<ogc:BBOX>";
+		$spatialFilter .= "</ogc:BBOX>";
 //combine filter
 //$e = new mb_exception("fullTextFilter: ".$fullTextFilter);
 if ($existsSpatialFilter == true && $searchText !== '' && $searchText !== '*'){
     $additionalFilter = "<ogc:And>".$fullTextFilter.$spatialFilter."</ogc:And>";
 } else {
@@ -559,8 +560,8 @@
 	$additionalFilter = $fullTextFilter;
+//$e = new mb_exception("additionalFilter: ".$additionalFilter);
 //csw Id = catalogueId
 $csw = new csw();
 $csw->createCatObjFromDB($catalogueId);
More information about the Mapbender_commits mailing list
