[Mapbender-commits] r10165 - in trunk/mapbender/http: classes php
svn_mapbender at osgeo.org svn_mapbender at osgeo.org
Thu Jun 27 05:42:57 PDT 2019
Author: armin11
Date: 2019-06-27 05:42:57 -0700 (Thu, 27 Jun 2019)
New Revision: 10165
Added:
   trunk/mapbender/http/php/mod_getOnlineAccessOptions.php
   trunk/mapbender/http/classes/class_cswClient.php
   trunk/mapbender/http/classes/class_iso19139.php
   trunk/mapbender/http/php/mod_exportIso19139.php
   trunk/mapbender/http/php/mod_getCoupledResourcesForDataset.php
Some enhancements for resolving dataset - service coupling of iso metadata
Modified: trunk/mapbender/http/classes/class_cswClient.php
--- trunk/mapbender/http/classes/class_cswClient.php	2019-06-27 09:32:34 UTC (rev 10164)
+++ trunk/mapbender/http/classes/class_cswClient.php	2019-06-27 12:42:57 UTC (rev 10165)
@@ -146,14 +146,27 @@
 						$postRequest .= '<ogc:And>';
 					$postRequest .= '<ogc:Or>';
                     			$postRequest .= '<ogc:PropertyIsEqualTo>';
                        			$postRequest .= '<ogc:PropertyName>OperatesOn</ogc:PropertyName>';
                         		$postRequest .= '<ogc:Literal>'.$datasetId.'</ogc:Literal>';
                     			$postRequest .= '</ogc:PropertyIsEqualTo>';
                         		$postRequest .= '<ogc:Literal>'.$recordId.'</ogc:Literal>';
+                    			/*$postRequest .= '<ogc:PropertyIsEqualTo>';
+                       			$postRequest .= '<ogc:PropertyName>OperatesOnIdentifier</ogc:PropertyName>';
+                        		$postRequest .= '<ogc:Literal>'.$datasetId.'</ogc:Literal>';
+                    			$postRequest .= '</ogc:PropertyIsEqualTo>';*/
+                        		$postRequest .= '<ogc:Literal>'.$recordId.'</ogc:Literal>';
 					$postRequest .= '</ogc:Or>';
 					if ($additionalFilter !== false) {
 						$postRequest .= $additionalFilter;
@@ -485,6 +498,7 @@
 			$cswInterfaceObject = new connector();
 			$cswInterfaceObject->set('httpType','POST');
 			$postData = stripslashes($postData);
+			//$e = new mb_exception("classes/class_cswClient.php: post xml: ".$postData);
 			$dataXMLObject = new SimpleXMLElement($postData);
 			$postData = $dataXMLObject->asXML();
 			//$e = new mb_exception($postData);
@@ -493,7 +507,7 @@
 			$cswInterfaceObject->set('httpContentType','text/xml');
 			$cswInterfaceObject->load($url);
 			//$file = $cswInterfaceObject->file;
-//$e = new mb_exception($cswInterfaceObject->file);
+			//$e = new mb_exception($cswInterfaceObject->file);
 			return $cswInterfaceObject->file;
 	//insert or update - depends if record with same fileidentifier already exists in catalog and if timestamp is not newer than the timestamp of the new record
Modified: trunk/mapbender/http/classes/class_iso19139.php
--- trunk/mapbender/http/classes/class_iso19139.php	2019-06-27 09:32:34 UTC (rev 10164)
+++ trunk/mapbender/http/classes/class_iso19139.php	2019-06-27 12:42:57 UTC (rev 10165)
@@ -339,7 +339,7 @@
 					$this->datasetIdCodeSpace = $codeSpace[0];
 				} else {
 					//neither MD_Identifier nor RS_Identifier are defined in a right way
-					$e = new mb_notice("class_iso19139.php: No datasetId found in metadata record!");
+					$e = new mb_exception("class_iso19139.php: No datasetId found in metadata record!");
 			//abstract
Modified: trunk/mapbender/http/php/mod_exportIso19139.php
--- trunk/mapbender/http/php/mod_exportIso19139.php	2019-06-27 09:32:34 UTC (rev 10164)
+++ trunk/mapbender/http/php/mod_exportIso19139.php	2019-06-27 12:42:57 UTC (rev 10165)
@@ -69,12 +69,18 @@
 //instantiate
 $mbMetadata = new Iso19139();
 //test if getrecordbyid request was used - then the service data may also be in the same catalogue
-if (strpos(strtoupper($url), "GETRECORDBYID",strtoupper($url)) !== false && strpos(strtoupper($url), "SERVICE=CSW") !== false && strpos(strtoupper($url), "VERSION=2.0.2") !== false) {
+if (strpos(strtoupper($url), "GETRECORDBYID") !== false && strpos(strtoupper($url), "SERVICE=CSW") !== false && strpos(strtoupper($url), "VERSION=2.0.2") !== false) {
 	$cswBasedResource = true;
 //build search request for services
 //TODO: test if this ok - maybe not everything is parsed by class? instead we could use $mbMetadata->readFromUrl($url);
 $mbMetadata->createFromUrl($url);
+$e = new mb_exception("php/mod_exportIso19139.php: url for getrecordbyid: ".$url);
+$e = new mb_exception("php/mod_exportIso19139.php: datasetid from getrecordbyid: ".$mbMetadata->datasetIdCodeSpace.$mbMetadata->datasetId);
 //$e = new mb_exception("datasetId: ".$mbMetadata->datasetId);
 //$e = new mb_exception("datasetIdCodeSpace: ".$mbMetadata->datasetIdCodeSpace);
 //$e = new mb_exception("hierarchyLevel: ".$mbMetadata->hierarchyLevel);
@@ -96,7 +102,7 @@
 		$cswClient = new cswClient();
 		$operation = "getrecordsresolvecoupling";
 		$getrecordId = $mbMetadata->fileIdentifier;
-		$datasetId = $mbMetadata->datasetId;
+		$datasetId = str_replace('&','&',$mbMetadata->datasetIdCodeSpace.$mbMetadata->datasetId);
 		$recordType = 'service';
 		$cswResponseObject = $cswClient->doRequest(false, $operation, $getrecordId, false, $recordType, false, false, false, $datasetId, $csw);
 		//$e = new mb_exception("test1");
Modified: trunk/mapbender/http/php/mod_getCoupledResourcesForDataset.php
--- trunk/mapbender/http/php/mod_getCoupledResourcesForDataset.php	2019-06-27 09:32:34 UTC (rev 10164)
+++ trunk/mapbender/http/php/mod_getCoupledResourcesForDataset.php	2019-06-27 12:42:57 UTC (rev 10165)
@@ -14,6 +14,57 @@
 //https://gdk.gdi-de.org/gdi-de/srv/eng/csw?request=GetRecordById&service=CSW&version=2.0.2&Id=71b31668-746b-40a2-975a-172a87318e45&ElementSetName=full&OUTPUTSCHEMA=http://www.isotc211.org/2005/gmd
 //localhost/mapbender/php/mod_getCoupledResourcesForDataset.php?getRecordByIdUrl=https%3A%2F%2Fgdk.gdi-de.org%2Fgdi-de%2Fsrv%2Feng%2Fcsw%3Frequest%3DGetRecordById%26service%3DCSW%26version%3D2.0.2%26Id%3D71b31668-746b-40a2-975a-172a87318e45%26ElementSetName%3Dfull%26OUTPUTSCHEMA%3Dhttp%3A%2F%2Fwww.isotc211.org%2F2005%2Fgmd
+function microtime_float()
+    list($usec, $sec) = explode(" ", microtime());
+    return ((float)$usec + (float)$sec);
+function correctWmsUrl($wms_url) {
+	//check if last sign is ? or & or none of them
+	$lastChar = substr($wms_url,-1);
+	//check if getcapabilities is set as a parameter
+	$findme = "getcapabilities";
+	$posGetCap = strpos(strtolower($wms_url), $findme);
+	if ($posGetCap === false) {
+		$posGetAmp = strpos(strtolower($wms_url), "?");
+		if ($posGetAmp === false) {
+			$wms_url .= "?REQUEST=GetCapabilities&VERSION=1.1.1&SERVICE=WMS";
+		} else {
+			switch ($lastChar) {
+				case "?":
+					$wms_url .= "REQUEST=GetCapabilities&VERSION=1.1.1&SERVICE=WMS";
+				break;
+				case "&":
+				break;
+				default:
+					$wms_url .= "&REQUEST=GetCapabilities&VERSION=1.1.1&SERVICE=WMS";
+				break;
+	} else {
+		//check if version is defined
+		$findme1 = "version=";
+		$posVersion = strpos(strtolower($wms_url), $findme1);
+		if ($posVersion === false) {
+			$wms_url .= "&VERSION=1.1.1";
+		} else {
+			//mapbender only handle 1.1.1
+			$wms_url = str_replace('version=1.3.0', 'VERSION=1.1.1', $wms_url);
+			$wms_url = str_replace('VERSION=1.3.0', 'VERSION=1.1.1', $wms_url);
+	//exchange &? with & and &
+	$wms_url = str_replace('&?', '&', $wms_url);
+	$wms_url = str_replace('&', '&', $wms_url);
+	return $wms_url;
 $languageCode = "de";
 $url = urldecode($_REQUEST['getRecordByIdUrl']);
 $outputFormat = 'json';
@@ -21,6 +72,38 @@
 $resultObj['result'] = '';
 $resultObj['success'] = false;
 $resultObj['message'] = 'no message';
+$starttime = microtime_float();
+$hostName = $_SERVER['HTTP_HOST'];
+$headers = apache_request_headers();
+$originFromHeader = false;
+foreach ($headers as $header => $value) {
+    	if ($header === "Origin") {
+		//$e = new mb_exception("Origin: ".$value);
+		$originFromHeader = $value;
+if (isset($_REQUEST["hostName"]) & $_REQUEST["hostName"] != "") {
+	//validate to some hosts
+	$testMatch = $_REQUEST["hostName"];
+	//look for whitelist in mapbender.conf
+	$HOSTNAME_WHITELIST_array = explode(",",HOSTNAME_WHITELIST);
+	if (!in_array($testMatch,$HOSTNAME_WHITELIST_array)) {
+		//echo "Requested hostname <b>".$testMatch."</b> not whitelist! Please control your mapbender.conf.";
+		echo "Requested <b>hostName</b> not in whitelist! Please control your mapbender.conf.";
+		$e = new mb_notice("Whitelist: ".HOSTNAME_WHITELIST);
+		$e = new mb_notice("hostName not found in whitelist!");
+		die();
+	$hostName = $testMatch;
+	$testMatch = NULL;
+if (isset($_SERVER['HTTPS']) && $_SERVER['HTTPS'] == 'on') {
+	$scheme = "https";
+} else {
+	$scheme = "http";
 //get language parameter out of mapbender session if it is set else set default language to de_DE
 $sessionLang = Mapbender::session()->get("mb_lang");
 if (isset($sessionLang) && ($sessionLang!='')) {
@@ -90,8 +173,9 @@
 //initialize if resource is based on a request to csw interface
 $cswBasedResource = false;
 } else {
 	$resultObj['message'] ='Url dont validate against a getrecordbyid url!';
@@ -101,7 +185,9 @@
+//$e = new mb_exception("php/mod_getCoupledResourcesForDataset.php: url for getrecordbyid: ".$url);
+//$e = new mb_exception("php/mod_getCoupledResourcesForDataset.php: datasetid from getrecordbyid: ".$mbMetadata->datasetIdCodeSpace.$mbMetadata->datasetId);
 $serviceMetadata = new stdClass();
 $serviceMetadataIndex = 0;
 if ($mbMetadata->hierarchyLevel == 'dataset' || $mbMetadata->hierarchyLevel == 'series') {
@@ -118,9 +204,10 @@
 		$urlWithoutRequest = $urlArray['scheme']."://".$urlArray['host'].":".$urlArray['port']."/".$urlArray['path'];
 		$csw->createCatObjFromXML($urlWithoutRequest."?SERVICE=CSW&VERSION=2.0.2&REQUEST=GetCapabilities");
+		//$e = new mb_exception("php/mod_getCoupledResourcesForDataset.php: datasetid from getrecordbyid: ".$mbMetadata->datasetId);
 		$serviceMetadataUrls = array();
@@ -137,6 +224,8 @@
 				die();
 			for ($k = 1; $k <= count($metadataRecord) ; $k++) {
+				//TODO: check if class metadata can be used instead - read xml write xml - parse metadata from xml? Look for namespaces!
 				$fileIdentifier = $cswClient->operationResult->xpath('/csw:GetRecordsResponse/csw:SearchResults/gmd:MD_Metadata['.$k.']/gmd:fileIdentifier/gco:CharacterString');
 				$fileIdentifier = (string)$fileIdentifier[0];
 				//service date
@@ -149,9 +238,15 @@
 				$mdServiceType = $cswClient->operationResult->xpath('/csw:GetRecordsResponse/csw:SearchResults/gmd:MD_Metadata['.$k.']/gmd:identificationInfo/srv:SV_ServiceIdentification/srv:serviceType/gco:LocalName');
 				$mdServiceType = (string)$mdServiceType[0];
 				//accessUrl
-				$mdAccessUrl = $cswClient->operationResult->xpath('/csw:GetRecordsResponse/csw:SearchResults/gmd:MD_Metadata['.$k.']/gmd:distributionInfo/gmd:MD_Distribution/gmd:transferOptions/gmd:MD_DigitalTransferOptions/gmd:onLine/gmd:CI_OnlineResource/gmd:linkage/gmd:URL');
-				$mdAccessUrl = (string)$mdAccessUrl[0];
+				/*$mdAccessUrl = $cswClient->operationResult->xpath('/csw:GetRecordsResponse/csw:SearchResults/gmd:MD_Metadata['.$k.']/gmd:distributionInfo/gmd:MD_Distribution/gmd:transferOptions/gmd:MD_DigitalTransferOptions/gmd:onLine/gmd:CI_OnlineResource/gmd:linkage/gmd:URL');
+				$mdAccessUrl = (string)$mdAccessUrl[0];*/
+				//first read the inspire kind of implementation of the access to capabilities documents
+				$accessUrl = $cswClient->operationResult->xpath('/csw:GetRecordsResponse/csw:SearchResults/gmd:MD_Metadata['.$k.']/gmd:distributionInfo/gmd:MD_Distribution/gmd:transferOptions/gmd:MD_DigitalTransferOptions/gmd:onLine/gmd:CI_OnlineResource/gmd:linkage/gmd:URL');
+				if ($accessUrl[0] == '') {
+					//search for another accessUrl - as defined in csw ap iso
+					$accessUrl = $cswClient->operationResult->xpath('/csw:GetRecordsResponse/csw:SearchResults/gmd:MD_Metadata['.$k.']/gmd:identificationInfo/srv:SV_ServiceIdentification/srv:containsOperations/srv:SV_OperationMetadata/srv:connectPoint/gmd:CI_OnlineResource/gmd:linkage/gmd:URL');
+				$mdAccessUrl = $accessUrl[0];
 				//get service type - view / download
 				//get service title
@@ -170,14 +265,42 @@
 				$serviceMetadata->service[$k]->serviceType = $mdServiceType;
 				$serviceMetadata->service[$k]->serviceTitle = $mdTitle;
 				$serviceMetadata->service[$k]->serviceDate = $mdDateStamp;
-				$serviceMetadata->service[$k]->metadataUrl = $urlWithoutRequest."?SERVICE=CSW&VERSION=2.0.2&REQUEST=GetRecordById&outputSchema=".urlencode('http://www.isotc211.org/2005/gmd')."&id=".$fileIdentifier;
-				$serviceMetadata->service[$k]->accessUrl = $mdAccessUrl;
+				$serviceMetadata->service[$k]->mdLink = $urlWithoutRequest."?SERVICE=CSW&VERSION=2.0.2&REQUEST=GetRecordById&outputSchema=".urlencode('http://www.isotc211.org/2005/gmd')."&id=".$fileIdentifier;
+				$serviceMetadata->service[$k]->htmlLink = $scheme.'://'.$hostName.str_replace(basename($_SERVER['SCRIPT_NAME']), "mod_exportIso19139.php", $_SERVER['PHP_SELF'])."?url=".urlencode($urlWithoutRequest."?SERVICE=CSW&VERSION=2.0.2&REQUEST=GetRecordById&outputSchema=".urlencode('http://www.isotc211.org/2005/gmd')."&id=".$fileIdentifier);
+				if (is_array($mdAccessUrl)) {
+					$mdAccessUrl = $mdAccessUrl[0];
+				//$serviceMetadata->service[$k]->accessUrl = $mdAccessUrl;
+				if (in_array(strtoupper($mdServiceType), array('VIEW','OGC:WMS','WMS','PREDEFINED ATOM','DOWNLOAD','WFS','ATOM'))) {
+					if (in_array(strtoupper($mdServiceType), array('PREDEFINED ATOM','DOWNLOAD','WFS','ATOM'))) {
+						if (in_array(strtoupper($mdServiceType), array('PREDEFINED ATOM','ATOM'))) {
+							$serviceMetadata->service[$k]->accessClient = $scheme.'://'.$hostName.str_replace("php/".basename($_SERVER['SCRIPT_NAME']), "plugins/mb_downloadFeedClient.php", $_SERVER['PHP_SELF'])."?url=".urlencode($mdAccessUrl);
+							$serviceMetadata->service[$k]->serviceSubType = 'ATOM';
+							$serviceMetadata->service[$k]->serviceType = "download";
+							$serviceMetadata->service[$k]->accessUrl = $mdAccessUrl;
+						$serviceMetadata->service[$k]->serviceSubType = 'WFS';
+						$serviceMetadata->service[$k]->accessUrl = (string)$mdAccessUrl;
+					} else {
+						$serviceMetadata->service[$k]->serviceType = 'view';
+						$serviceMetadata->service[$k]->accessUrl = correctWmsUrl($mdAccessUrl);
+				} else {
+					$serviceMetadata->service[$k]->serviceType = 'other';
+					if ($mdAccessUrl == "" || isempty($mdAccessUrl)) {
+						$serviceMetadata->service[$k]->accessUrl = null;
+		$serviceMetadata->service = array_values($serviceMetadata->service);
 		$resultObj['message'] = "Coupling resolved successfully!";
 		$resultObj['success'] = true;
+		$serviceMetadata->genTime = microtime_float() - $starttime;
 		$resultObj['result'] = $serviceMetadata;
-		echo json_encode($resultObj);
+		echo json_encode($resultObj, TRUE);
 		die();
 	} else {
 		$resultObj['message'] ='No csw based resource!!';
Added: trunk/mapbender/http/php/mod_getOnlineAccessOptions.php
--- trunk/mapbender/http/php/mod_getOnlineAccessOptions.php	                        (rev 0)
+++ trunk/mapbender/http/php/mod_getOnlineAccessOptions.php	2019-06-27 12:42:57 UTC (rev 10165)
@@ -0,0 +1,332 @@
+<?php
+//2012-11-20-http://localhost/mapbender_trunk/php/mod_getDownloadOptions.php?id=70e0c3e5-707c-f8e1-8037-7b38702176d9&output=xml
+//http://localhost/mapbender_trunk/php/mod_getDownloadOptions.php?id=0a8b7dc8-b198-aac5-9713-79b623a6e651,0395ee4a-f27f-7e71-fc17-65498ffa991c
+// http://www.mapbender.org/index.php/
+// Copyright (C) 2002 CCGIS
+// This program is free software; you can redistribute it and/or modify
+// it under the terms of the GNU General Public License as published by
+// the Free Software Foundation; either version 2, or (at your option)
+// any later version.
+// This program is distributed in the hope that it will be useful,
+// but WITHOUT ANY WARRANTY; without even the implied warranty of
+// MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE.  See the
+// GNU General Public License for more details.
+// You should have received a copy of the GNU General Public License
+// along with this program; if not, write to the Free Software
+// Foundation, Inc., 59 Temple Place - Suite 330, Boston, MA 02111-1307, USA.
+//Script for pulling all download options for one or more metadataset which are identified by their fileidentifier
+require_once(dirname(__FILE__) . "/../../core/globalSettings.php");
+require_once(dirname(__FILE__) . "/../classes/class_Uuid.php");
+//get language parameter out of mapbender session if it is set else set default language to de_DE
+$sessionLang = Mapbender::session()->get("mb_lang");
+if (isset($sessionLang) && ($sessionLang!='')) {
+	$e = new mb_notice("mod_showMetadata.php: language found in session: ".$sessionLang);
+	$language = $sessionLang;
+	$langCode = explode("_", $language);
+	$langCode = $langCode[0]; # Hopefully de or s.th. else
+	$languageCode = $langCode; #overwrite the GET Parameter with the SESSION information
+$e = new mb_notice("mod_showMetadata.php: language in SESSION: ".$sessionLang);
+$e = new mb_notice("mod_showMetadata.php: new language: ".$languageCode);
+$outputFormat = "json";
+if (isset($_REQUEST["languageCode"]) & $_REQUEST["languageCode"] != "") {
+	//validate to csv integer list
+	$testMatch = $_REQUEST["languageCode"];
+	if (!($testMatch == 'de' or $testMatch == 'fr' or $testMatch == 'en')){
+		//echo 'languageCode: <b>'.$testMatch.'</b> is not valid.<br/>';
+		echo 'Parameter <b>languageCode</b> is not valid (de,fr,en).<br/>';
+		die();
+	$languageCode = $testMatch;
+	$e = new mb_notice("mod_showMetadata.php: languageCode from GET parameter: ".$languageCode);
+$localeObj->setCurrentLocale($languageCode);
+if (isset($_REQUEST["outputFormat"]) & $_REQUEST["outputFormat"] != "") {
+	$testMatch = $_REQUEST["outputFormat"];
+ 	if (!($testMatch == 'json' or $testMatch == 'html')){
+		//echo 'outputFormat: <b>'.$testMatch.'</b> is not valid.<br/>';
+		echo 'Parameter <b>outputFormat</b> is not valid (json,html).<br/>';
+		die();
+	$outputFormat = $testMatch;
+function checkUrlInDatalink($url, $datalinkIds) {
+	$sql = "SELECT datalink_id FROM datalink WHERE datalink_id in (".explode(",",$datalinkIds).") AND datalink_url = ".urldecode($url);
+	$res = db_query($sql);
+	//$row = db_fetch_assoc($res)
+	$e = new mb_exception("num rows: ".db_numrows($res));
+	if (db_numrows($res) > 0) {
+		return true;
+	} else {
+		return false;
+//make all parameters available as upper case
+foreach($_REQUEST as $key => $val) {
+	$_REQUEST[strtoupper($key)] = $val;
+//validate request params
+if (isset($_REQUEST['ID']) & $_REQUEST['ID'] != "") {
+	//validate cs list of uuids or other identifiers - which?
+	$testMatch = $_REQUEST["ID"];
+	//$uuid = new Uuid($testMatch);
+	//$isUuid = $uuid->isValid();
+	$idList = explode(',',$_REQUEST['ID']);
+	for ($i = 0; $i < count($idList); $i++) {
+		$testMatch = $idList[$i];
+		$uuid = new Uuid($testMatch);
+		$isUuid = $uuid->isValid();
+		if (!$isUuid) {
+			//echo 'Id: <b>'.$testMatch.'</b> is not a valid uuid (12-4-4-4-8)!<br/>';
+			echo 'Parameter <b>Id</b> is not a valid uuid (12-4-4-4-8) or a list of uuids!<br/>';
+			die();
+function getDownloadOptions($idList) {
+	//define query to pull all download options - actually only the inspire download services based on atom feeds
+	$sql = "select service_id, service_uuid, resource_id, resource_type, datalink, NULL as datalink_text, title, format, inspire_download from (
+select service_id, resource_id, service_uuid, resource_type, fkey_datalink_id as datalink, title, format, inspire_download from (select fkey_wms_id as service_id, layer_id as resource_id, 'layer' as resource_type, layer.uuid as service_uuid, metadata_relation.title, format, layer.inspire_download from layer inner join (select metadata_id, title, format, uuid, fkey_layer_id from mb_metadata inner join ows_relation_metadata on ows_relation_metadata.fkey_metadata_id = mb_metadata.metadata_id) ";
+	$sql .= "as metadata_relation on metadata_relation.fkey_layer_id = layer.layer_id where layer_searchable = 1 AND metadata_relation.uuid = $1) as layer_metadata LEFT OUTER JOIN ows_relation_data ON layer_metadata.resource_id = ows_relation_data.fkey_layer_id
+) as inspire_layer inner join wms on inspire_layer.service_id = wms.wms_id ";
+	$sql .= "union select fkey_wfs_id as service_id, service_uuid, featuretype_id as resource_id, 'wfs' as resource_type, NULL ";
+	$sql .= "as datalink, NULL as datalink_text, title, 'GML' as format, inspire_download from (select wfs_featuretype.featuretype_id ,wfs_featuretype.fkey_wfs_id, wfs.uuid as service_uuid, wfs_featuretype.inspire_download from wfs_featuretype inner join wfs on wfs_featuretype.fkey_wfs_id = wfs.wfs_id WHERE inspire_download = 1 ORDER BY featuretype_id) as featuretype_inspire inner join (select metadata_id, title, format, uuid, fkey_featuretype_id from mb_metadata inner join ows_relation_metadata on ";
+	$sql .= "ows_relation_metadata.fkey_metadata_id = mb_metadata.metadata_id) as metadata_relation on metadata_relation.fkey_featuretype_id = featuretype_inspire.featuretype_id and metadata_relation.uuid = $1 ";
+	$sql .= "union select NULL as service_id, NULL as service_uuid, NULL as resource_id, 'metadata' as resource_type, NULL ";
+	$sql .= "as datalink, datalinks as datalink_text, title, format, inspire_download FROM mb_metadata WHERE mb_metadata.uuid = $1 and inspire_download = 1;";
+	$sql = "select service_id, resource_id, resource_type, fkey_datalink_id as datalink from (select fkey_wms_id as service_id, layer_id as resource_id, 'layer' as resource_type from layer inner join (select metadata_id, uuid, fkey_layer_id from mb_metadata inner join ows_relation_metadata on ows_relation_metadata.fkey_metadata_id = mb_metadata.metadata_id) ";
+	$sql .= "as metadata_relation on metadata_relation.fkey_layer_id = layer.layer_id where layer.inspire_download = 1 and metadata_relation.uuid = $1) as layer_metadata LEFT OUTER JOIN ows_relation_data ON layer_metadata.resource_id = ows_relation_data.fkey_layer_id union select fkey_wfs_id as service_id, featuretype_id as resource_id, 'wfs' as resource_type, NULL ";
+	$sql .= "as datalink from (select wfs_featuretype.featuretype_id ,wfs_featuretype.fkey_wfs_id,  wfs_featuretype.inspire_download from wfs_featuretype WHERE inspire_download = 1 ORDER BY featuretype_id) as featuretype_inspire inner join (select metadata_id, uuid, fkey_featuretype_id from mb_metadata inner join ows_relation_metadata on ";
+	$sql .= "ows_relation_metadata.fkey_metadata_id = mb_metadata.metadata_id) as metadata_relation on metadata_relation.fkey_featuretype_id = featuretype_inspire.featuretype_id and metadata_relation.uuid = $1;";*/
+	//initialize array for result
+	//$e = new mb_exception($idList);
+		$v = array($idList[$i]);
+		$t = array('s');
+		$res = db_prep_query($sql,$v,$t);
+		//problem, $res don't give back false if it was not successful!
+		//push rows into associative array
+		$j = 0;
+		while ($row = db_fetch_assoc($res)) {
+			//echo "j: ".$j."<br>";
+			switch ($row['resource_type']) {
+				case "wfs":
+					if ($row['inspire_download'] == 1) {
+						$serviceIdIndex = false;
+						for ($k = 0; $k < count($downloadOptions->{$idList[$i]}->option); $k++) {
+							//echo "k: ".$k."<br>";
+							//echo "service_id: ".$row['service_id']." - searched Id: ".$downloadOptions->{$idList[$i]}->option[$k]->serviceId."<br>";
+							if ($row['service_id'] == $downloadOptions->{$idList[$i]}->option[$k]->serviceId) {
+								//service_id found at index $k
+								$serviceIdIndex = $k;
+								//echo "Service already found on index: ".$serviceIdIndex."<br>";
+						if ($serviceIdIndex !== false) {
+							//echo "Add featuretype to given service: ".$serviceIdIndex."<br>";
+							//old wfs has been found
+							//get count of current fts
+							$m = count($downloadOptions->{$idList[$i]}->option[$serviceIdIndex]->featureType);
+							//echo "m: ".$m."<br>";
+							$downloadOptions->{$idList[$i]}->option[$serviceIdIndex]->featureType[$m] = $row['resource_id'];
+						} else {
+							$downloadOptions->{$idList[$i]}->option[$j]->type = "wfsrequest";
+							$downloadOptions->{$idList[$i]}->option[$j]->serviceId = $row['service_id'];
+							$downloadOptions->{$idList[$i]}->option[$j]->serviceUuid = $row['service_uuid'];
+							$downloadOptions->{$idList[$i]}->option[$j]->featureType[0] = $row['resource_id'];
+							$downloadOptions->{$idList[$i]}->option[$j]->format = $row['format'];
+						$downloadOptions->{$idList[$i]}->title = $row['title'];
+						$downloadOptions->{$idList[$i]}->uuid = $idList[$i];
+						//add wfs option
+						$downloadOptions->{$idList[$i]}->option[$j+1]->type = "wfs";
+						$downloadOptions->{$idList[$i]}->option[$j+1]->wfsId = $row['service_id'];
+						$downloadOptions->{$idList[$i]}->option[$j+1]->featuretypeId = $row['resource_id'];
+						$j++;
+					} else {
+						//add wfs option
+						$downloadOptions->{$idList[$i]}->option[$j]->type = "wfs";
+						$downloadOptions->{$idList[$i]}->option[$j]->wfsId = $row['service_id'];
+						$downloadOptions->{$idList[$i]}->option[$j]->featuretypeId = $row['resource_id'];
+				break;
+				case "layer":
+						if (!isset($row['datalink'] ) || $row['datalink'] == '') {
+							$downloadOptions->{$idList[$i]}->option[$j]->type = "wmslayergetmap";
+							$row['format'] = 'GeoTIFF';
+						} else {
+							$downloadOptions->{$idList[$i]}->option[$j]->type = "wmslayerdataurl";
+							//add to array with datalink (ids)
+							//$arrayDataLinks[] = $row['datalink'];
+						$downloadOptions->{$idList[$i]}->option[$j]->serviceUuid = $row['service_uuid'];//This is a layer uuid - not a service uuid!!!!
+						$downloadOptions->{$idList[$i]}->option[$j]->resourceId = $row['resource_id'];
+						$downloadOptions->{$idList[$i]}->option[$j]->dataLink = $row['datalink'];
+						//add wms option
+						$downloadOptions->{$idList[$i]}->option[$j+1]->type = "wms";
+						$downloadOptions->{$idList[$i]}->option[$j+1]->wmsId = $row['service_id'];
+						$downloadOptions->{$idList[$i]}->option[$j+1]->layerId = $row['resource_id'];
+						$j++;
+					} else {
+						//add wms option
+						$downloadOptions->{$idList[$i]}->option[$j]->type = "wms";
+						$downloadOptions->{$idList[$i]}->option[$j]->wmsId = $row['service_id'];
+						$downloadOptions->{$idList[$i]}->option[$j]->layerId = $row['resource_id'];
+				break;
+				case "metadata":
+					if (isset($row['datalink_text'] ) || $row['datalink_text'] != '') {
+						$downloadLinks = json_decode($row['datalink_text']);
+						$downloadOptions->{$idList[$i]}->option[$j]->type = "downloadlink";
+						//parse json and add some more info?
+						//$downloadLinks = json_decode($row['datalink_text']);
+						foreach ($downloadLinks->downloadLinks as $downloadLink) {
+							$downloadOptions->{$idList[$i]}->option[$j]->link = $downloadLink->{"0"};
+							//check if
+				break;
+		$j++;
+		//delete double entries - maybe url is given from dataurl - use this
+		//get all dataurlids
+		//foreach($downloadOptions->{$idList[$i]}->option as $option) {
+			//$option->dataLink;
+	//$e = new mb_exception(json_encode($downloadOptions));
+	//add further option from metadata itself - if
+	$result = json_encode($downloadOptions);
+	return $result;
+$downloadOptions = getDownloadOptions($idList);
+if ($downloadOptions != "null" && $outputFormat == "json") {
+	header('Content-Type: application/json; charset='.CHARSET);
+	echo $downloadOptions;
+if ($downloadOptions != "null" && $outputFormat == "html") {
+	$options = json_decode($downloadOptions);
+	$header = '<!DOCTYPE html><html xmlns="http://www.w3.org/1999/xhtml" xml:lang="'.$languageCode.'">';
+	$header .= '<body>';
+	$header .= '<head>' .
+		'<title>'._mb('Download options for dataset(s)').'</title>' .
+		'<meta name="viewport" content="width=device-width, user-scalable=no, initial-scale=1.0, maximum-scale=1.0;">'.
+		'<meta name="description" content="'._mb('Download options for datasets').'" xml:lang="'.$languageCode.'" />'.
+		'<meta name="keywords" content="'._mb('spatial dataset').'" xml:lang="'.$languageCode.'" />'	.
+		'<meta http-equiv="cache-control" content="no-cache">'.
+		'<meta http-equiv="pragma" content="no-cache">'.
+		'<meta http-equiv="expires" content="0">'.
+		'<meta http-equiv="content-language" content="'.$languageCode.'" />'.
+		'<meta http-equiv="content-style-type" content="text/css" />'.
+		'<meta http-equiv="Content-Type" content="text/html; charset='.CHARSET.'">' .
+		'</head>';
+	$header .= '<link type="text/css" href="../css/metadata.css" rel="Stylesheet" />';
+	$header .= '<link type="text/css" href="../extensions/jquery-ui-1.8.1.custom/css/custom-theme/jquery-ui-1.8.5.custom.css" rel="Stylesheet" />';
+	$header .= '<script type="text/javascript" src="../extensions/jquery-ui-1.8.1.custom/js/jquery-1.4.2.min.js"></script>';
+	$header .= '<script type="text/javascript" src="../extensions/jquery-ui-1.8.1.custom/js/jquery-ui-1.8.1.custom.min.js"></script>';
+	$header .= '<style type="text/css">a{white-space:normal;}</style>';
+//some js for dialog
+	echo $header;
+	if (defined("MAPBENDER_PATH") && MAPBENDER_PATH != '') {
+		$mapbenderUrl = MAPBENDER_PATH;
+	} else {
+		$mapbenderUrl = "http://www.geoportal.rlp.de/mapbender";
+	$script .= '<script type="text/javascript">';
+	$script .= '$(function() {';
+	$script .= '	$("#tabs").tabs();';
+	$script .= '});';
+	$script .= '</script>';
+	echo $script;
+	$metadataList = _mb("Used dataset(s)").":<br>";
+	//generate one tab for each dataset
+	//independently define the headers of the parts
+	$metadataList .= '<div class="demo">';
+	$metadataList .= '<div id="tabs">';
+	$metadataList .= '<ul>';
+	$iTabs = 1;
+	foreach ($idList as $currentUuid){
+		$metadataList .= 	'<li><a href="#tabs-'.$iTabs.'">'.$options->{$currentUuid}->title.'<br>'.$currentUuid.'</a></li>';
+		$iTabs++;
+	$iTabs = 1;
+	$metadataList.= '</ul>';
+		//$metadataList .= "<a href='../php/mod_iso19139ToHtml.php?url=".urlencode($mapbenderUrl."/php/mod_dataISOMetadata.php?outputFormat=iso19139&id=".$currentUuid)."'>".$options->{$currentUuid}->title."</a> <a href='../php/mod_dataISOMetadata.php?outputFormat=iso19139&id=".$currentUuid."&validate=true'>".'validate'."</a>";
+		$metadataList .= '<div id="tabs-'.$iTabs.'">';
+		$metadataList .= "<a href='../php/mod_iso19139ToHtml.php?url=".urlencode($mapbenderUrl."/php/mod_dataISOMetadata.php?outputFormat=iso19139&id=".$currentUuid)."'>"._mb('Metadata')."</a>";
+		//echo $options->{$currentUuid}->title;
+		$metadataList .= "<br>";
+		if ($downloadOptions != null) {
+			$iOptions = 1;
+			foreach ($options->{$currentUuid}->option as $option) {
+				switch ($option->type) {
+					case "wmslayergetmap":
+						$metadataList .= $iOptions.". "._mb('Download raster data from INSPIRE Download Service').":   <a href='../plugins/mb_downloadFeedClient.php?url=".urlencode($mapbenderUrl."/php/mod_inspireDownloadFeed.php?id=".$currentUuid."&type=SERVICE&generateFrom=wmslayer&layerid=".$option->resourceId)."'><img src='../img/osgeo_graphics/geosilk/raster_download.png' title='"._mb('Download raster data from INSPIRE Download Service')."'/></a>";
+						break;
+					case "wmslayerdataurl":
+						$metadataList .=  $iOptions.". "._mb('Download linked data from INSPIRE Download Service').":   <a href='../plugins/mb_downloadFeedClient.php?url=".urlencode($mapbenderUrl."/php/mod_inspireDownloadFeed.php?id=".$currentUuid."&type=SERVICE&generateFrom=dataurl&layerid=".$option->resourceId)."'><img src='../img/osgeo_graphics/geosilk/link_download.png' title='"._mb('Download linked data from INSPIRE Download Service')."'/></a>";
+						break;
+					case "wfsrequest":
+						$metadataList .=  $iOptions.". "._mb('Download GML data from INSPIRE Download Service').":   <a href='../plugins/mb_downloadFeedClient.php?url=".urlencode($mapbenderUrl."/php/mod_inspireDownloadFeed.php?id=".$currentUuid."&type=SERVICE&generateFrom=wfs&wfsid=".$option->serviceId)."'><img src='../img/osgeo_graphics/geosilk/vector_download.png' title='"._mb('Download GML data from INSPIRE Download Service')."'/></a>";
+						break;
+					case "downloadlink":
+						$metadataList .=  $iOptions.". "._mb('Download linked data from INSPIRE Download Service').":   <a href='../plugins/mb_downloadFeedClient.php?url=".urlencode($mapbenderUrl."/php/mod_inspireDownloadFeed.php?id=".$currentUuid."&type=SERVICE&generateFrom=metadata")."'><img src='../img/osgeo_graphics/geosilk/link_download.png' title='"._mb('Download linked data from INSPIRE Download Service')."'/></a>";
+						break;
+				$iOptions++;
+		$iTabs++;
+		$metadataList .= '</div>';
+	$metadataList.= '</div>';
+	echo $metadataList;
+	echo "</Body></HTML>";
More information about the Mapbender_commits mailing list
