[Mapbender-commits] r10123 - trunk/mapbender/http/php
svn_mapbender at osgeo.org svn_mapbender at osgeo.org
Tue May 14 03:28:13 PDT 2019
Author: armin11
Date: 2019-05-14 03:28:13 -0700 (Tue, 14 May 2019)
New Revision: 10123
   trunk/mapbender/http/php/mod_showOrganizationList.php
   trunk/mapbender/http/php/tagCloud.php
Option for sorting organization list -  rank (number of resources), id, title. More info in INSPIRE thematic information.
Modified: trunk/mapbender/http/php/mod_showOrganizationList.php
--- trunk/mapbender/http/php/mod_showOrganizationList.php	2019-05-14 09:51:37 UTC (rev 10122)
+++ trunk/mapbender/http/php/mod_showOrganizationList.php	2019-05-14 10:28:13 UTC (rev 10123)
@@ -1,9 +1,19 @@
 <?php
 //server component to pull statistics FROM geoportal catalogue
 require_once(dirname(__FILE__)."/../../core/globalSettings.php");
+$orderBy = 'rank';
+if (isset($_REQUEST["orderBy"]) & $_REQUEST["orderBy"] != "") {
+	$testMatch = $_REQUEST["orderBy"];
+ 	if (!($testMatch == 'rank' or $testMatch == 'title' or $testMatch == 'id' or $testMatch == 'date')){
+		//echo 'orderBy: <b>'.$testMatch.'</b> is not valid.<br/>';
+		echo 'Parameter <b>orderBy</b> is not valid (rank,title,id,date).<br/>';
+		die();
+	$orderBy = $testMatch;
+	$testMatch = NULL;
 $sql = <<<SQL
-SELECT published_resources.*, mb_group_name, mb_group_description, mb_group_logo_path, mb_group_title, uuid FROM (
+SELECT published_resources.*, datasets+featuretypes+layers+wmcs as all_resources, mb_group_name, mb_group_description, mb_group_logo_path, mb_group_title, mb_group_homepage, uuid FROM (
 SELECT SUM(dataset_count) AS datasets, SUM(featuretype_count) AS featuretypes, SUM(layer_count) AS layers, SUM(wmc_count) AS wmcs, mb_group_id FROM (
 SELECT 0 AS dataset_count, 0 AS featuretype_count, resource_count AS layer_count, 0 AS wmc_count, mb_group_id FROM (
@@ -47,10 +57,23 @@
 ) AS owner_wmc INNER JOIN mb_user_mb_group on owner_wmc.fkey_user_id = mb_user_mb_group.fkey_mb_user_id WHERE mb_user_mb_group_type = 2 ) AS published_wmc GROUP BY fkey_mb_group_id
 ) AS resources GROUP BY mb_group_id ) AS published_resources INNER JOIN mb_group on published_resources.mb_group_id = mb_group.mb_group_id
-ORDER BY mb_group_name DESC
 SQL;
-//order by - group_id, group_name, group_title
+switch ($orderBy) {
+	case "rank":
+		$sql .= " ORDER BY all_resources DESC";
+		break;
+	case "id":
+		$sql .= " ORDER BY mb_group_id ASC";
+		break;
+	case "title":
+		$sql .= " ORDER BY mb_group_name ASC";
+		break;
+	default:
+		break;
 $v = array();
 $t = array();
@@ -66,10 +89,12 @@
 	$jsonOutput->organizations[$numberOfOrgas]->{'title_long'} = $row['mb_group_title'];
 	$jsonOutput->organizations[$numberOfOrgas]->{'image_display_url'} = $row['mb_group_logo_path'];
 	$jsonOutput->organizations[$numberOfOrgas]->{'detail_url'} = '../mod_showOrganizationInfo.php?id='.$row['mb_group_id'].'&outputFormat=ckan';
+	$jsonOutput->organizations[$numberOfOrgas]->{'homepage'} = $row['mb_group_homepage'];
 	$jsonOutput->organizations[$numberOfOrgas]->{'datasets'} = $row['datasets'];
 	$jsonOutput->organizations[$numberOfOrgas]->{'layers'} = $row['layers'];
 	$jsonOutput->organizations[$numberOfOrgas]->{'featuretypes'} = $row['featuretypes'];
 	$jsonOutput->organizations[$numberOfOrgas]->{'wmcs'} = $row['wmcs'];
+	$jsonOutput->organizations[$numberOfOrgas]->{'all_resources'} = $row['all_resources'];
 	$numberOfOrgas++;
 $json = json_encode($jsonOutput);
Modified: trunk/mapbender/http/php/tagCloud.php
--- trunk/mapbender/http/php/tagCloud.php	2019-05-14 09:51:37 UTC (rev 10122)
+++ trunk/mapbender/http/php/tagCloud.php	2019-05-14 10:28:13 UTC (rev 10123)
@@ -176,7 +176,7 @@
 		$tags[$i] = array('weight'  =>$row['sum'], 'tagname' =>$row[$showName], 'url'=>'http://'.$hostName.$pathToSearchScript.urlencode('searchText=*&resultTarget=file&outputFormat=json&isoCategories='.$row['md_topic_category_id'].'&languageCode='.$languageCode));
 	if ($type == 'inspireCategories') {
-		$tags[$i] = array('weight'  =>$row['sum'], 'tagname' =>$row[$showName], 'url'=>'http://'.$hostName.$pathToSearchScript.urlencode('searchText=*&resultTarget=file&outputFormat=json&inspireCategories='.$row[$categoryFilter.'_id'].'&languageCode='.$languageCode), 'description'=>$row[$categoryFilter.'_description_'.$languageCode], 'info'=>$row[$categoryFilter.'_uri']);
+		$tags[$i] = array('weight'  =>$row['sum'], 'tagname' =>$row[$showName], 'url'=>'http://'.$hostName.$pathToSearchScript.urlencode('searchText=*&resultTarget=file&outputFormat=json&inspireCategories='.$row[$categoryFilter.'_id'].'&languageCode='.$languageCode), 'description'=>$row[$categoryFilter.'_description_'.$languageCode], 'info'=>$row[$categoryFilter.'_uri'], 'mbId'=>$row[$categoryFilter.'_id']);
 	if ($type == 'keywords') {
@@ -242,11 +242,14 @@
     		$tagCloudJSON->tagCloud->tags[$i]->title = $tags[$i]['tagname'];
 		$tagCloudJSON->tagCloud->tags[$i]->url = $tags[$i]['url'];
 		$tagCloudJSON->tagCloud->tags[$i]->weight = $tags[$i]['weight'];
+		$tagCloudJSON->tagCloud->tags[$i]->id = $tags[$i]['mbId'];
-			$tagCloudJSON->tagCloud->tags[$i]->info = $tags[$i]['info'];
+			$tagCloudJSON->tagCloud->tags[$i]->info = $tags[$i]['info'];
+			$tagCloudJSON->tagCloud->tags[$i]->inspireThemeId = end(explode('/', $tagCloudJSON->tagCloud->tags[$i]->info));
 			$tagCloudJSON->tagCloud->tags[$i]->description = $tags[$i]['description'];
 			//symbol
-			$tagCloudJSON->tagCloud->tags[$i]->symbolUrl = MAPBENDER_PATH."/img/INSPIRE-themes-icons-master/svg/".end(explode('/', $tagCloudJSON->tagCloud->tags[$i]->info)).".svg";
+			$tagCloudJSON->tagCloud->tags[$i]->symbolUrl = MAPBENDER_PATH."/img/INSPIRE-themes-icons-master/svg/".$tagCloudJSON->tagCloud->tags[$i]->inspireThemeId.".svg";
 #echo "json";
More information about the Mapbender_commits mailing list
