[Mapbender-commits] r10326 - trunk/mapbender/tools
svn_mapbender at osgeo.org
Mon Nov 11 08:47:53 PST 2019
Author: armin11
Date: 2019-11-11 08:47:52 -0800 (Mon, 11 Nov 2019)
New Revision: 10326
trunk/mapbender/tools/mod_exportISOMetadata.php
Export application metadata and metadata for OGC API Features REST interfaces.
Modified: trunk/mapbender/tools/mod_exportISOMetadata.php
--- trunk/mapbender/tools/mod_exportISOMetadata.php 2019-11-11 16:21:39 UTC (rev 10325)
+++ trunk/mapbender/tools/mod_exportISOMetadata.php 2019-11-11 16:47:52 UTC (rev 10326)
@@ -35,8 +35,8 @@
db_select_db(DB,$con);
//define the view or table where to read out the layer ids for which metadatafiles should be generated
-$wmsView = "search_wms_view";
-//$wmsView = "wms_search_table";
+//$wmsView = "search_wms_view";
+$wmsView = "wms_search_table";
if (isset($configObject->metadataGenerationUri) && $configObject->metadataGenerationUri != "") {
$baseUri = $configObject->metadataGenerationUri;
@@ -72,6 +72,9 @@
$countLayer = 0;
$countMetadataURL = 0;
$countDls = 0;
+$countApplications = 0;
+$countRestInterfaces = 0;
logMessages(date('Y-m-d - H:i:s', time()));
//remove files from $metadataDir!
if ($handle = opendir($metadataDir)) {
@@ -194,12 +197,12 @@
SELECT wfs_version, fkey_wfs_id, featuretype_id FROM (SELECT fkey_wfs_id, featuretype_id FROM wfs_featuretype WHERE featuretype_id
IN (select fkey_featuretype_id from mb_metadata LEFT JOIN ows_relation_metadata ON metadata_id = fkey_metadata_id where
- fkey_featuretype_id IS NOT NULL)) ft LEFT JOIN wfs ON
- ft.fkey_wfs_id = wfs_id WHERE wfs_version = '2.0.0' OR wfs_version = '2.0.2' ;
+ fkey_featuretype_id IS NOT NULL AND metadata_id = $1)) ft LEFT JOIN wfs ON
+ ft.fkey_wfs_id = wfs_id WHERE (wfs_version = '2.0.0' OR wfs_version = '2.0.2');
SQL;
- $v = array();
- $t = array();
+ $v = array($row_metadata["metadata_id"]);
+ $t = array('i');
$res_wfs2 = db_prep_query($sqlWfs2,$v,$t);
while ($row_wfs2 = db_fetch_array($res_wfs2)) {
$generatorDlsUrlWfs2 = $generatorBaseUrlDlsWfs2."SERVICE=WFS&outputFormat=iso19139&Id=".$row_wfs2['featuretype_id'];
@@ -221,9 +224,60 @@
$countLayer++;
+//export application metadata
+$sql_app = "select uuid, export2csw from mb_metadata where type = 'application' and searchable = true;";
+$v = array();
+$t = array();
+$res_app = db_prep_query($sql_app, $v, $t);
+while ($row_app = db_fetch_array($res_app)) {
+ $generatorUrlMetadata = $generatorBaseUrlMetadata."outputFormat=iso19139&id=".$row_app['uuid'];
+ logMessages("URL for app requested: ".$generatorUrlMetadata);
+ $generatorInterfaceObject = new connector($generatorUrlMetadata);
+ $ISOFile = $generatorInterfaceObject->file;
+ logMessages("Metadata uuid: ".$row_app['uuid']);
+ //generate temporary files under tmp
+ if($h = fopen($metadataDir."/mapbenderApplicationMetadata_".$row_app['uuid']."_iso19139.xml","w")){
+ if(!fwrite($h,$ISOFile)){
+ logMessages("mod_exportISOMetadata.php: cannot write to file: ".$metadataDir."/metadata/mapbenderMetadata_".$row_app['uuid']."_iso19139.xml");
+ logMessages("Application metadata file with metadata uuid ".$row_app['uuid']." written to ".$metadataDir);
+ fclose($h);
+ $countApplications++;
+//export rest interfaces for wfs2.0.0+ based wfs featuretypes which are searchable and opendata classified
+$sql_rest = "select wfs_featuretype.featuretype_id from wfs_featuretype where fkey_wfs_id in (select wfs_id from wfs where wfs_id in (select fkey_wfs_id from wfs_termsofuse inner join termsofuse on fkey_termsofuse_id = termsofuse_id where termsofuse.isopen = 1) and wfs_version = '2.0.0') and featuretype_searchable = 1";
+$v = array();
+$t = array();
+$res_rest = db_prep_query($sql_rest, $v, $t);
+while ($row_rest = db_fetch_array($res_rest)) {
+ //$generatorUrlMetadata = $generatorBaseUrlMetadata."outputFormat=iso19139&id=".$row_app['uuid'];
+ $generatorDlsUrlRest = $generatorBaseUrlDlsWfs2."SERVICETYPE=ogcapifeatures&outputFormat=iso19139&Id=".$row_rest['featuretype_id'];
+ //logMessages("URL for app requested: ".$generatorUrlMetadata);
+ $generatorInterfaceObject = new connector($generatorDlsUrlRest);
+ logMessages("Featuretype id: ".$row_rest['featuretype_id']);
+ if($h = fopen($metadataDir."/mapbenderRestMetadata_".$row_rest['featuretype_id']."_iso19139.xml","w")){
+ logMessages("mod_exportISOMetadata.php: cannot write to file: ".$metadataDir."/metadata/mapbenderRestMetadata_".$row_rest['featuretype_id']."_iso19139.xml");
+ logMessages("REST metadata file with featuretype_id ".$row_rest['featuretype_id']." written to ".$metadataDir);
+ fclose($h);
+ $countRestInterfaces++;
logMessages("Number of generated View Service Metadata Records (one for each layer): ".$countLayer);
logMessages("Number of generated Data Metadata Records (multiple for each layer): ".$countMetadataURL);
logMessages("Number of generated Download Service Metadata Records (multiple for each metadataset): ".$countDls);
+logMessages("Number of generated Application Metadata Records: ".$countApplications);
+logMessages("Number of generated REST Service Metadata Records: ".$countRestInterfaces);
More information about the Mapbender_commits
