[Mapbender-commits] r10333 - trunk/mapbender/http/plugins
svn_mapbender at osgeo.org
Sat Nov 16 03:34:56 PST 2019
Author: armin11
Date: 2019-11-16 03:34:56 -0800 (Sat, 16 Nov 2019)
New Revision: 10333
Added:
trunk/mapbender/http/plugins/mod_metadataCarousel.php
New cool module for a carousel slider to dynamically load pulished wmc from the searchInterface (mapbender catalogue) into the mapviewer ;-) .
Added: trunk/mapbender/http/plugins/mod_metadataCarousel.php
--- trunk/mapbender/http/plugins/mod_metadataCarousel.php (rev 0)
+++ trunk/mapbender/http/plugins/mod_metadataCarousel.php 2019-11-16 11:34:56 UTC (rev 10333)
@@ -0,0 +1,258 @@
+<?php
+ * Package: mod_metadataCarousel
+ * Description:
+ * This modul generates a div with a dynamic slider to allow the selection
+ * of single loadable metadata resources - wmc, ...
+ * The module shoudl be invoked thru a button click. The button may be a mb_button.js module
+ * see also mod_WMSpreferencesDiv or overview toogle
+ * Files:
+ * - http/plugins/mod_metadataCarousel.php
+ * SQL:
+ * License:
+ * Copyright (c) 2009, Open Source Geospatial Foundation
+ * This program is dual licensed under the GNU General Public License
+ * and Simplified BSD license.
+ * http://svn.osgeo.org/mapbender/trunk/mapbender/license/license.txt
+require_once(dirname(__FILE__)."/../php/mb_validateSession.php");
+$e_id = 'metadataCarousel';
+//include all element vars from the given element
+include '../include/dyn_js.php';
+include '../include/dyn_php.php';
+//if we need some other elements fom the database - do the stuff
+//echo "var mod_gui_wms_visible = '".$vis."';";
+//load options from element vars - if not already be done before
+//element_vars we need
+// 1. script name of the searchInterface to use
+// 2. number of tiles to show together
+// 3. number of objects to get from the searchInterface with one call (should be a factor of 2. )
+// 4. resource type - wmc/layer
+// 5. list of resource ids to filter {[1,2,3]}
+// 6. size of images, ...
+// 7. allowResize - like in loadwmc cause a function is borrowed from there
+//options.resourceFilter = "[3,11,12]";
+options.allowResize = true;
+options.resourceFilter = "[]";
+var metadataCarousel = function() {
+ var that = this;
+ this.id = options.id; //id of the upper div tag from mapbender element
+ this.resourceFilter = JSON.parse(options.resourceFilter);
+ if (this.resourceFilter.length > 0){
+ this.resourceFilterString = "&resourceIds="+this.resourceFilter.join(',');
+ } else {
+ this.resourceFilterString = "";
+ this.initForm = function() {
+ this.moduleContainer = $(document.createElement('div')).attr({'id': 'container'}).appendTo('#' + options.id);
+ this.moduleContainer.addClass('cf');
+ this.mainContainer = $(document.createElement('div')).appendTo(this.moduleContainer);
+ this.mainContainer.attr('id', 'main');
+ this.mainContainer.attr('role', 'main');
+ //hide during initialization
+ $('#' + options.id).hide();
+ this.sliderContainer = $(document.createElement('section')).appendTo(this.mainContainer);
+ this.sliderContainer.addClass('slider');
+ this.carouselContainer = $(document.createElement('div')).appendTo(this.sliderContainer);
+ this.carouselContainer.addClass('flexslider');
+ this.carouselContainer.addClass('carousel');
+ this.slidesContainer = $(document.createElement('ul')).appendTo(this.carouselContainer);
+ this.slidesContainer.addClass('slides');
+ this.slidesContainer.attr('id', 'slides');
+ //first dummy entries ;-)
+ this.slidesContainer.append("<li><img src='../img/mapbender_logo.png' /></li><li><img class='' src='../img/mapbender_logo.png' /></li><li><img src='../img/mapbender_logo.png' /></li><li><img src='../img/mapbender_logo.png' /></li>");
+ var targetName = options.target;
+ var showMoreButtonText = "Show more";
+ var maxResults = 12;
+ var currentPage = 0;
+ var maxPages = 1;
+ var numberOfResults = 0;
+ var searchUrl = "../php/mod_callMetadata.php?";
+ //var searchUrl = "../php/mod_callMetadataRemote.php?";
+ //first init form - hopefully that is done fast
+ this.initForm();
+ this.loadMore = function(){
+ //alert("actual_loaded_page: "+currentPage+" - max pages: "+maxPages); 1-10 (100)
+ //hide further loading button while loading more data
+ $('.show_more_button').hide();
+ //load next page
+ $.ajax({url: searchUrl+"searchText=*&searchResources=wmc&searchPages="+(parseInt(currentPage) + parseInt(1))+"&maxResults="+maxResults+that.resourceFilterString, async: false, success: function(result){
+ result.wmc.srv.forEach(that.addElementToSlider);
+ //increase global var currentPage
+ currentPage = parseInt(currentPage) + parseInt(1);
+ //unbind all old click events
+ $('.slides li img').unbind('click');
+ //reinitialize click event
+ $('.slides li img').click(function(){
+ var $this = $(this);
+ resourceId = $this.attr("resourceId");
+ alert(resourceId);
+ that.alterCss();
+ //show loading button again
+ $('.show_more_button').show();
+ $('.show_more_button').attr("value", "1-"+parseInt(currentPage)*parseInt(maxResults)+" ("+numberOfResults+") - "+showMoreButtonText);
+ if (parseInt(currentPage)*parseInt(maxResults) >= parseInt(numberOfResults)) {
+ $('.show_more_button').attr("value", "1-"+numberOfResults+" ("+numberOfResults+")");
+ $('.show_more_button').unbind('click');
+ var mainFlexSlider = $('#'+this.id);
+ mainFlexSlider.flexslider({
+ animation: "slide",
+ animationLoop: false,
+ itemWidth: 150,
+ itemMargin: 5,
+ maxItems: 3,
+ pausePlay: false,
+ start: function(slider){
+ $('.slides li img', slider).click(function(){
+ resourceId = $this.attr("resourceId"); that.loadWmcById(resourceId)
+ end: function(slider){
+ that.loadMore();
+ this.fillInitialMetadata = function() {
+ //initialize slider from first request to search interface
+ var initialResult = $.ajax({url: searchUrl+"searchText=*&searchResources=wmc&maxResults="+maxResults+that.resourceFilterString, async: false, success: function(result){
+ if (result.valid)
+ return true;
+ else
+ return false;
+ var initialSearchJson = JSON.parse(initialResult.responseText);
+ //extract number of currrent page, rpp and max results
+ currentPage = initialSearchJson.wmc.md.p;
+ numberOfResults = initialSearchJson.wmc.md.nresults;
+ maxPages = Math.ceil(numberOfResults / maxResults);
+ //remove temporary main slider content
+ $("ul.slides").html("");
+ //alert("number of all wmc: "+JSON.parse(initialResult.responseText).wmc.md.nresults);
+ JSON.parse(initialResult.responseText).wmc.srv.forEach(that.addElementToSlider);
+ this.alterCss = function(){
+ $('.flexslider').css({"overflow":"hidden","position":"relative","height":"130px"});
+ $('.flexslider_images').css({"width":"150px","height":"100px"});
+ this.addElementToSlider = function(item) {
+ mainFlexSlider.data('flexslider').addSlide("<li class='flexslider slides'><a href='#'><img class='flexslider flexslider_images' src='"+item.previewURL+"' resourceId='"+item.id+"' title='"+item.title+"'/><span class='flex-caption'>"+item.title+"</span><span class='flex-load-count'>"+item.loadCount+"</span></a></li>");
+ that.alterCss();
+ this.removeOldContainer = function(){
+ $('#container').remove();
+ this.loadWmcById = function(wmcId){
+ alert(wmcId);
+ //Mapbender.modules.loadwmc.executeJavaScript({method:"loadWmc", parameters:{id:wmcId}});
+ that.executeJavaScript({method:"loadWmc", parameters:{id:wmcId}});
+ that.fillInitialMetadata();
+ that.removeOldContainer();
+ $('#' + options.id).show();
+ that.alterCss();
+//copied from javascripts/mod_loadwmc.js because it will not available, if loadwmc window has been closed somewhen!!!!
+ this.executeJavaScript = function (args) {
+ var req = new Mapbender.Ajax.Request({
+ url: "../php/mod_loadwmc_server.php",
+ method: args.method,
+ parameters: args.parameters,
+ callback: function (obj, result, message) {
+ if (!result) {
+ new Mapbender.Warning(message);
+ return;
+ try {
+ if (args.method === "deleteWmc" || args.method === "setWMCPublic"){
+ return;
+ //things that have been done to load wmc
+ if (obj.javascript && typeof(obj.javascript) == "object") {
+ for (var j = 0; j < obj.javascript.length; j++) {
+ //TODO: prohibit multiple maprequests when load wmc, cause on maprequests the wmc maybe stored to session :-(
+ //alert("Statement: " + obj.javascript[j]);
+ //eventAfterLoadWMS.trigger(); -- load the each wms again and saves the wmc to session for each wms - prohibit this behaviour!!!! - Done by global lock_maprequest in class_wmc.php line 1220+!!
+ //console.log("Statement: " + obj.javascript[j]);
+ eval(obj.javascript[j]);
+ if (options.allowResize == true) {
+ if (Mapbender.modules.resizeMapsize) {
+ //alert("Module resizeMapsize is available!");
+ try {$('#resizeMapsize').trigger("click");} catch (e) {alert(e)};
+ } else {
+ //alert("allowResize not defined");
+ if (args.method === "loadWmc" || args.method === 'loadWmcFromFile') {
+ var kml = $('#mapframe1').data('kml');
+ if(kml) {
+ try {
+ $.each(kml.kmlOrder, function(_, v) {
+ $('li[title="' + v + '"]').unbind().find('*').unbind();
+ $('li[title="' + v + '"]').remove();
+ kml._kmls = JSON.parse(restoredWmcExtensionData.KMLS);
+ kml.cache = {};
+ kml.kmlOrder = JSON.parse(restoredWmcExtensionData.KMLORDER);
+ kml.render();
+ for(var k in kml._kmls) {
+ kml.element.trigger('kml:loaded', kml._kmls[k]);
+ } catch(e) {
+ // just ignore the exception for now
+ that.events.loaded.trigger({
+ extensionData: restoredWmcExtensionData
+ that.hide();
+ new Mapbender.Notice(args.message);
+ catch (e) {
+ new Mapbender.Exception(e.message);
+ req.send();
+//register object in mapbender!
+Mapbender.events.init.register(function() {
+ Mapbender.modules[options.id] = $.extend(new metadataCarousel(),Mapbender.modules[options.id]);
More information about the Mapbender_commits
