[Mapbender-commits] r10346 - trunk/mapbender/http/html
svn_mapbender at osgeo.org
Wed Nov 20 23:17:33 PST 2019
Author: armin11
Date: 2019-11-20 23:17:32 -0800 (Wed, 20 Nov 2019)
New Revision: 10346
trunk/mapbender/http/html/mod_treefolderPlain2019.php
Fix - rewind to older version
Modified: trunk/mapbender/http/html/mod_treefolderPlain2019.php
--- trunk/mapbender/http/html/mod_treefolderPlain2019.php 2019-11-20 17:11:24 UTC (rev 10345)
+++ trunk/mapbender/http/html/mod_treefolderPlain2019.php 2019-11-21 07:17:32 UTC (rev 10346)
@@ -0,0 +1,1159 @@
+<?php
+# $Id: mod_treefolder2.php 2975 2008-09-18 12:58:42Z nimix $
+# http://www.mapbender.org/index.php/Mod_treefolder2.php
+# Copyright (C) 2007 Melchior Moos
+# This program is free software; you can redistribute it and/or modify
+# it under the terms of the GNU General Public License as published by
+# the Free Software Foundation; either version 2, or (at your option)
+# any later version.
+# This program is distributed in the hope that it will be useful,
+# but WITHOUT ANY WARRANTY; without even the implied warranty of
+# MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the
+# GNU General Public License for more details.
+# You should have received a copy of the GNU General Public License
+# along with this program; if not, write to the Free Software
+# Foundation, Inc., 59 Temple Place - Suite 330, Boston, MA 02111-1307, USA.
+require_once(dirname(__FILE__)."/../php/mb_validateSession.php");
+include '../include/dyn_js.php';
+function openwindow (Adresse, width, height) {
+ Fenster1 = window.open(Adresse, '<?php echo _mb("Information");?>', "width="+width+",height="+height+",left=100,top=100,scrollbars=yes,resizable=yes");
+ Fenster1.focus();
+<?php
+ echo "mod_treeGDE_map = '".$e_target[0]."';";
+// <script language="JavaScript">
+var msgObj = {};
+msgObj.tooltipHandleWms = '<?php echo _mb("(De)activate this service");?>';
+msgObj.tooltipLayerVisible = '<?php echo _mb("Toggles the visibility of this service");?>';
+msgObj.tooltipLayerQuerylayer = '<?php echo _mb("Toggles the queryability of this service");?>';
+msgObj.tooltipLayerContextMenu = '<?php echo _mb("Opens the layer context menu");?>';
+msgObj.tooltipWmsContextMenu = '<?php echo _mb("Opens the WMS context menu");?>';
+msgObj.tooltipRemoveWms = '<?php echo _mb("Removes the selected WMS");?>';
+msgObj.tooltipMoveSelectionUp = '<?php echo _mb("Moves the selection up");?>';
+msgObj.tooltipMoveSelectionDown = '<?php echo _mb("Moves the selection down");?>';
+msgObj.tooltipMetadata = '<?php echo _mb("Show metadata");?>';
+msgObj.tooltipFeaturetypeCoupling = '<?php echo _mb("Coupled featuretypes");?>';
+if (typeof(localizetree) === 'undefined')localizetree = 'false';
+function localizeTree () {
+ var treefolderTitleArray = [];
+ var map = Mapbender.modules[mod_treeGDE_map];
+ if (map === null) {
+ return;
+ for(var i = 0; i < map.wms.length; i++) {
+ var currentWms = map.wms[i];
+ treefolderTitleArray.push({
+ title : currentWms.objLayer.length > 0 ?
+ currentWms.objLayer[0].gui_layer_title :
+ currentWms.wms_title,
+ layer : []
+ for (var j = 0; j < currentWms.objLayer.length; j++) {
+ var currentLayer = currentWms.objLayer[j];
+ treefolderTitleArray[treefolderTitleArray.length-1].layer.push({
+ title : currentLayer.gui_layer_title
+ var req = new Mapbender.Ajax.Request({
+ url: "../php/mod_treefolder2_l10n.php",
+ method: "translateServiceData",
+ parameters: {
+ data: treefolderTitleArray
+ callback: function (obj, success, message) {
+ var translatedTitleArray = obj;
+ for (var i = 0; i < translatedTitleArray.length; i++) {
+ currentWms.wms_currentTitle = translatedTitleArray[i].title;
+ for(var j = 0; j < currentWms.objLayer.length; j++) {
+ if (translatedTitleArray[i].layer.length > j) {
+ currentLayer.layer_currentTitle = translatedTitleArray[i].layer[j].title;
+ reloadTree();
+ req.send();
+eventInit.register(function () {
+ localizeTree();
+if (localizetree == 'true') {
+ eventLocalize.register(function () {
+ localizeTree();
+var jst_container = "document.getElementById('treeContainer')";
+var jst_image_folder = imagedir;
+var jst_display_root = false;
+var defaultTarget = 'examplemain';
+var lock=false;
+var lock_update=false;
+var lock_check=false;
+var lock_maprequest = false; //global var to prohibit multiple saving states as wmc to session when loading wmc
+var selectedMap=-1;
+var selectedWMS=-1;
+var selectedLayer=-1;
+var initialized=false;
+var errors = 0;
+var state=Array();
+var treeState = "";
+<?php
+//load structure
+$sql = "SELECT * FROM gui_treegde WHERE fkey_gui_id = $1 AND NOT lft = 1 ORDER BY lft;";
+$v = array(Mapbender::session()->get("mb_user_gui"));
+$t = array("s");
+$res = db_prep_query($sql, $v, $t);
+//init tree converting arrays
+$nr = array(); //array for nested sets numbers
+$str = array(); //array for js array elements
+$categories = array(); //array for wms folders
+$path = array(); //stack for actual path elements
+$rights = array(); //stack for rights of open elements
+//build javascript data array for jsTree
+while($row = db_fetch_array($res)){
+ //push javascript array elements to a single array with lefts and rights
+ $left = "['folder_".$row['id']."', ['".$row['my_layer_title']."', 'javascript:_foo()'],[";
+ $right = "]],";
+ array_push($nr, $row['lft']);
+ array_push($str, $left);
+ array_push($nr, $row['rgt']);
+ array_push($str, $right);
+ //finish all nodes that have no further childs
+ while(count($rights) > 0 && $rights[count($rights)-1]<$row['lft']){
+ array_pop($rights);
+ array_pop($path);
+ //set path for each wms that is referenced in this folder
+ array_push($rights, $row['rgt']);
+ array_push($path, "folder_".$row['id']);
+ if($row['wms_id']!=""){
+ foreach(explode(",",$row['wms_id']) as $wms){
+ array_push($categories, "'wms_".$wms."':\"root_id|".implode("|", $path)."\"");
+//if we have a configured structure output it
+if(count($str)>0){
+ //order js array elements
+ array_multisort($nr, $str);
+ //output javascript vars
+ $arrNodesStr = "[['root_id', ['Layer','javascript:_foo()'],[".implode("",$str)."]]];";
+ $arrNodesStr = str_replace(array("[]", ",]"),array("","]"),$arrNodesStr);
+ echo "var arrNodesStr = \"".$arrNodesStr."\";\n";
+ echo "var categories = {".implode(",", $categories)."};\n";
+else{
+//if there is no structure take default
+var arrNodesStr = "[['root_id', ['Layer','javascript:_foo()']]];";
+var categories = {};
+<?php
+var arrNodes = eval(arrNodesStr);
+function _foo(){selectedMap=-1;selectedWMS=-1;selectedLayer=-1}
+// some defaults
+if (typeof(reverse) === 'undefined')reverse = 'false';
+if (typeof(switchwms) === 'undefined')switchwms = 'true';
+if (typeof(ficheckbox) === 'undefined')ficheckbox = 'false';
+if (typeof(metadatalink) === 'undefined')metadatalink = 'false';
+if (typeof(wmsbuttons) === 'undefined')wmsbuttons = 'false';
+if (typeof(showstatus) === 'undefined')showstatus = 'false';
+if (typeof(alerterror) === 'undefined')alerterror = 'false';
+if (typeof(openfolder) === 'undefined')openfolder = 'false';
+if (typeof(handlesublayer) === 'undefined')handlesublayer = 'false';
+if (typeof(enlargetreewidth) === 'undefined') enlargetreewidth = 'false';
+if (typeof(enlargetreewidthopacity) === 'undefined') enlargetreewidthopacity = 'false';
+if (typeof(menu) === 'undefined')menu = '';
+if (typeof(redirectToMetadataUrl) !== 'undefined' && redirectToMetadataUrl == "false") {
+ redirectToMetadataUrl = false;
+else {
+ redirectToMetadataUrl = true;
+if (typeof(datalink) === 'undefined')datalink = 'false';
+if (typeof(featuretypeCoupling) === 'undefined')featuretypeCoupling = 'false';
+if (typeof(metadataWidth) === 'undefined')metadataWidth = '500';
+if (typeof(metadataHeight) === 'undefined')metadataHeight = '500';
+if (typeof(activatedimension) === 'undefined')activatedimension = 'false';
+var defaultMetadataUrl = '../php/mod_showMetadata.php?resource=layer&layout=tabs&';
+if (redirectToMetadataUrl) {
+ defaultMetadataUrl += 'redirectToMetadataUrl=1';
+else {
+ defaultMetadataUrl += 'redirectToMetadataUrl=0';
+//menu elements
+var menu_move_up = ['menu_move_up', ['<?php echo _mb("Move up");?> ','javascript:var sd = "{@strData}";var ids=eval(sd.substr(0, sd.length-6))[1][7];move_up(ids[0],ids[1],ids[2]);',,'up.svg']];
+var menu_move_down = ['menu_move_down', ['<?php echo _mb("Move down");?> ', 'javascript:var sd = "{@strData}";var ids=eval(sd.substr(0, sd.length-6))[1][7];move_down(ids[0],ids[1],ids[2]);',,'down.svg']];
+var menu_delete = ['menu_delete', ['<?php echo _mb("Remove");?> ', 'javascript:var sd = "{@strData}";var ids=eval(sd.substr(0, sd.length-6))[1][7];remove_wms(ids[0],ids[1],ids[2]);',,'trash.svg']];
+var menu_opacity_down = ['menu_opacity_down', ['<?php echo _mb("Opacity down");?> ','javascript:var sd = "{@strData}";var ids=eval(sd.substr(0, sd.length-6))[1][7];opacity_down(ids[0],ids[1],ids[2]);',,'up.svg']];
+var menu_opacity_up = ['menu_opacity_up', ['<?php echo _mb("Opacity up");?> ','javascript:var sd = "{@strData}";var ids=eval(sd.substr(0, sd.length-6))[1][7];opacity_up(ids[0],ids[1],ids[2]);',,'down.svg']];
+var menu_metalink = ['menu_metalink', ['<?php echo _mb("Information");?> ', 'javascript:var sd = "{@strData}";var ids=eval(sd.substr(0, sd.length-6))[1][7];openwindow(defaultMetadataUrl + "&id="+parent.mb_mapObj[ids[0]].wms[ids[1]].objLayer[ids[2]].layer_uid'+','+metadataWidth+','+metadataHeight+');',,'info.svg']];
+var menu_zoom = ['menu_zoom', ['<?php echo _mb("Zoom");?> ', 'javascript:var sd = "{@strData}";var ids=eval(sd.substr(0, sd.length-6))[1][7];zoomToLayer(ids[0],ids[1],ids[2]);',,'zoom.png']];
+var menu_hide = ['menu_hide', ['<?php echo _mb("Hide menu");?> ', 'javascript:hideMenu()',,'clear_white.svg']];
+var menu_style = ['menu_style', ['<?php echo _mb("Change style");?> ', 'javascript:var sd = "{@strData}";var ids=eval(sd.substr(0, sd.length-6))[1][7];openStyleDialog(ids[0],ids[1],ids[2])',,'styling.svg']];
+var menu_legend = ['menu_legend', ['<?php echo _mb("Legende öffnen");?> ', 'javascript:var sd = "{@strData}";var ids=eval(sd.substr(0, sd.length-6))[1][7];openLegendHtml(ids[0],ids[1],ids[2])',,'legend_tree.png']];
+//var menu_wms_switch = ['menu_zoom', ['<?php echo _mb("Zoom");?> ', 'javascript:var sd = "{@strData}";eval(eval(sd.substr(0, sd.length-6))[1][1]);openwindow(defaultMetadataUrl + "&id="+parent.mb_mapObj[selectedMap].wms[selectedWMS].objLayer[selectedLayer].layer_uid'+','+metadataWidth+','+metadataHeight+');',,'info.png']];
+//var menu_layer_switch = ['menu_zoom', ['Zjjj ', 'javascript:var sd = "{@strData}";eval(eval(sd.substr(0, sd.length-6))[1][1]);openwindow(defaultMetadataUrl + "&id="+parent.mb_mapObj[selectedMap].wms[selectedWMS].objLayer[selectedLayer].layer_uid'+','+metadataWidth+','+metadataHeight+');',,'info.png']];
+//var menu_info_switch = ['menu_zoom', ['Zmn ', 'javascript:var sd = "{@strData}";eval(eval(sd.substr(0, sd.length-6))[1][1]);openwindow(defaultMetadataUrl + "&id="+parent.mb_mapObj[selectedMap].wms[selectedWMS].objLayer[selectedLayer].layer_uid'+','+metadataWidth+','+metadataHeight+');',,'info.png']];
+//parent.eventMapRequestFailed.register(function(t){imgerror(t)});
+eventAfterLoadWMS.register(reloadTree);
+eventInit.register(registerInitMapCheck);
+Mapbender.events.init.register(function () {
+ $("#" + mod_treeGDE_map).mapbender().events.afterMoveWms.register(reloadTree);
+eventInit.register(loadTree);
+if(showstatus=='true'||alerterror=='true'){
+ //eventAfterMapRequest.register(init_mapcheck);
+ //init_mapcheck();
+eventAfterMapRequest.register(updateScale);
+eventAfterMapRequest.register(updateCheckState);
+function registerInitMapCheck() {
+ if(showstatus=='true'||alerterror=='true'){
+ //console.log("Registrierung init_mapcheck an eventAfterMapRequest");
+ eventAfterMapRequest.register(init_mapcheck);
+if (enlargetreewidth) {
+ eventAfterInit.register(function(){
+ var initialWidth = parseInt($('#treeGDE').css("width"));
+ $('#treeGDE').bind("mouseenter", function(){
+ $(this).css({
+ 'width': initialWidth + enlargetreewidth,
+ if (enlargetreewidthopacity) {
+ $(this).css({
+ '-moz-opacity': '1',
+ 'opacity': '1',
+ 'filter': 'alpha(opacity=100)'
+ $(this).mousewheel();
+ $('#treeGDE').bind("mouseleave", function(){
+ $(this).css({
+ 'width': initialWidth,
+ $(this).css({
+ 'opacity': '1',
+if(wmsbuttons != "true")
+ jst_highlight = false;
+function select(i,ii,iii){
+ //ignore if selected
+ if(selectedMap==i && selectedWMS==ii && selectedLayer==iii)return;
+ if(selectedMap==-1 && selectedWMS==-1 && selectedLayer==-1){
+ selectedMap=i;
+ selectedWMS=ii;
+ selectedLayer=iii;
+ return;
+ //scalehints
+ var scale = parseInt(mb_getScale(mod_treeGDE_map));
+ if(scale < parseInt(mb_mapObj[selectedMap].wms[selectedWMS].objLayer[selectedLayer].gui_layer_minscale) && parseInt(mb_mapObj[selectedMap].wms[selectedWMS].objLayer[selectedLayer].gui_layer_minscale) != 0){
+ if(selectedLayer==0)
+ setNodeColor(arrNodes[0][0]+"|wms_"+ mb_mapObj[selectedMap].wms[selectedWMS].wms_id, '#999999');
+ else
+ setNodeColor(arrNodes[0][0]+"|wms_"+ mb_mapObj[selectedMap].wms[selectedWMS].wms_id+"|"+ mb_mapObj[selectedMap].wms[selectedWMS].objLayer[selectedLayer].layer_id, '#999999');
+ else if(scale > parseInt( mb_mapObj[selectedMap].wms[selectedWMS].objLayer[selectedLayer].gui_layer_maxscale) && parseInt( mb_mapObj[selectedMap].wms[selectedWMS].objLayer[selectedLayer].gui_layer_maxscale) != 0){
+ else
+ else{
+ setNodeColor(arrNodes[0][0]+"|wms_"+ mb_mapObj[selectedMap].wms[selectedWMS].wms_id, '');
+ else
+ setNodeColor(arrNodes[0][0]+"|wms_"+ mb_mapObj[selectedMap].wms[selectedWMS].wms_id+"|"+ mb_mapObj[selectedMap].wms[selectedWMS].objLayer[selectedLayer].layer_id, '');
+ selectedMap=i;
+ selectedWMS=ii;
+function updateScale(){
+ if(!initialized)return;
+ myMapObj = getMapObjByName(mod_treeGDE_map);
+ if(myMapObj){
+ var scale = parseInt( myMapObj.getScale());
+ for(var ii=0; ii< myMapObj.wms.length; ii++){
+ for(var iii=1; iii< myMapObj.wms[ii].objLayer.length; iii++){
+ if(scale < parseInt( myMapObj.wms[ii].objLayer[iii].gui_layer_minscale) && parseInt( myMapObj.wms[ii].objLayer[iii].gui_layer_minscale) != 0){
+ if(iii==0)
+ setNodeColor(arrNodes[0][0]+"|wms_"+ myMapObj.wms[ii].wms_id, '#999999');
+ else
+ setNodeColor(arrNodes[0][0]+"|wms_"+ myMapObj.wms[ii].wms_id+"|"+ myMapObj.wms[ii].objLayer[iii].layer_id, '#999999');
+ else if(scale > parseInt( myMapObj.wms[ii].objLayer[iii].gui_layer_maxscale) && parseInt( myMapObj.wms[ii].objLayer[iii].gui_layer_maxscale) != 0){
+ if(iii==0)
+ else
+ else{
+ if(iii==0)
+ setNodeColor(arrNodes[0][0]+"|wms_"+ myMapObj.wms[ii].wms_id, '');
+ else
+ setNodeColor(arrNodes[0][0]+"|wms_"+ myMapObj.wms[ii].wms_id+"|"+ myMapObj.wms[ii].objLayer[iii].layer_id, '');
+function updateCheckState(){
+ if(!initialized||lock_check)return;
+ lock_check=true;
+ var map = getMapObjByName(mod_treeGDE_map);
+ for(var i=0; i< mb_mapObj.length; i++){
+ var scale = parseInt( map.getScale());
+ if( mb_mapObj[i].elementName == mod_treeGDE_map){
+ for(var ii=0; ii< mb_mapObj[i].wms.length; ii++){
+ for(var iii=1; iii< mb_mapObj[i].wms[ii].objLayer.length; iii++){
+ if(! mb_mapObj[i].wms[ii].objLayer[iii].has_childs){
+ path = arrNodes[0][0]+"|wms_"+ mb_mapObj[i].wms[ii].wms_id+"|"+ mb_mapObj[i].wms[ii].objLayer[iii].layer_id;
+ checkNode(path, 0, mb_mapObj[i].wms[ii].objLayer[iii].gui_layer_visible==='1'||mb_mapObj[i].wms[ii].objLayer[iii].gui_layer_visible===1, false);
+ if(ficheckbox == 'true')
+ checkNode(path, 1, mb_mapObj[i].wms[ii].objLayer[iii].gui_layer_querylayer=='1', false);
+ lock_check=false;
+function operaLoad(){
+ initArray();
+ renderTree();
+ setTimeout('initWmsCheckboxen();updateScale();',100);
+function loadTree(){
+ if(wmsbuttons=='true'){
+ var div = document.createElement("div");
+ div.innerHTML = '<a href="javascript:move_up()"><img title="'+msgObj.tooltipMoveSelectionUp+'" src="'+imagedir+'/up.svg" alt="move up" style="position:relative;top:0px;left:0px;"/></a><a href="javascript:move_down()"><img title="'+msgObj.tooltipMoveSelectionDown+'" src="'+imagedir+'/down.svg" alt="move down" style="position:relative;top:0px;left:-3px"/></a><a href="javascript:remove_wms()"><img title="'+msgObj.tooltipRemoveWms+'" src="'+imagedir+'/delete_wms.png" alt="remove wms" style="position:relative;top:0px;left:-6px"/></a>';
+ document.getElementById("treeGDE").appendChild(div);
+ div.id = "treeContainer"
+ if(window.opera){
+ setTimeout('operaLoad()',200);
+ return;
+ initArray();
+ renderTree();
+ initWmsCheckboxen();
+ updateScale();
+function reloadTree(){
+ if(!initialized) return;
+ selectedMap=-1;
+ selectedWMS=-1;
+ selectedLayer=-1;
+ initialized=false;
+ arrNodes = eval(arrNodesStr)
+ initArray();
+ renderTree();
+ if(window.opera)
+ else{
+ updateScale();
+ Mapbender.events.treeReloaded.trigger();
+function imgerror(wms, path, imgObj){
+ var map= getMapObjIndexByName(mod_treeGDE_map);
+ //t.onerror=null;
+ //t.onabort=null;
+ if(state[wms]!=-1 && alerterror=='true'){
+ state[wms]=-1;
+ var errorMsg = '<?php echo _mb("Failed to load WMS");?> ' + mb_mapObj[map].wms[wms].objLayer[0].layer_currentTitle;
+ $('<div id="imgErrorDialog">' + errorMsg + ':<iframe style="width:90%;height:90%;" src="' + imgObj.attr("src") + '"></iframe></div>').dialog();
+ checkNode(path, 0, false);
+ /*if(confirm('<?php echo _mb("Failed to load WMS");?> ' +
+ mb_mapObj[map].wms[wms].objLayer[0].layer_currentTitle +
+ '\n<?php echo _mb("Do you want to try to load it in a new window?");?>')) {
+ window.open(imgObj.attr("src"),"");
+ state[wms]=-1;
+ errors++;
+ if(showstatus=='true')
+ setNodeImage(arrNodes[0][0]+"|wms_"+ mb_mapObj[map].wms[wms].wms_id, "error_folder.png");
+function checkComplete(wms, map, img, first){
+ var ind= getMapObjIndexByName(mod_treeGDE_map);
+ if (mb_mapObj[ind].wms[wms].mapURL == false ||
+ !mb_mapObj[ind].getDomElement().ownerDocument.getElementById(map) ||
+ mb_mapObj[ind].getDomElement().ownerDocument.getElementById(map).complete) {
+ if(state[wms]!=-1){
+ for(var i=1;i< mb_mapObj[ind].wms[wms].objLayer.length;i++){
+ if(mb_mapObj[ind].wms[wms].objLayer[i].gui_layer_visible===1||mb_mapObj[ind].wms[wms].objLayer[i].gui_layer_visible==="1"){
+ state[wms]=1;
+ setNodeImage(img);
+ //Removes the previous Maprequest image from dom
+ var prevlastRequestDiv = $("#"+mod_treeGDE_map+"_maps > div:last").prev().attr("id");
+ var prevWmsgid=prevlastRequestDiv+"_map_"+wms;
+ var $prevWmsgid=$("#"+prevWmsgid);
+ $prevWmsgid.remove();
+ break;
+ else{
+ if(first){
+ state[wms]=0;
+ $("#" + map).error(function () {
+ imgerror(wms, img, $(this));
+ //$(map).onabort=imgerror;
+ setNodeImage(img, "clock.svg");
+ setTimeout('checkComplete('+wms+', "'+map+'", "'+img+'");',100);
+// mb_registerWmsLoadErrorFunctions("window.frames['treeGDE'].imgerror();");
+function init_mapcheck(){
+ errors = 0;
+ var ind = getMapObjIndexByName(mod_treeGDE_map);
+ if(! mb_mapObj[ind]||!initialized){
+ setTimeout("init_mapcheck();",100);
+ return;
+ for(var wms=0;wms< mb_mapObj[ind].wms.length;wms++){
+ var lastRequestDiv = $("#"+mod_treeGDE_map+"_maps > div:last" ).attr("id");
+ var wmsimgid=lastRequestDiv+"_map_"+wms;
+ if( mb_mapObj[ind].getDomElement().ownerDocument.getElementById(wmsimgid)){
+ checkComplete(wms, wmsimgid, arrNodes[0][0]+'|wms_'+ mb_mapObj[ind].wms[wms].wms_id, true);
+function local_handleSelectedLayer(mapObj,wms_id,layername,type,status){
+ if(lock_update||lock_check)return;
+ var ind = getMapObjIndexByName(mapObj);
+ for(var i=0; i< mb_mapObj[ind].wms.length; i++){
+ if( mb_mapObj[ind].wms[i].wms_id == wms_id){
+ mb_mapObj[ind].wms[i].handleLayer(layername, type, status);
+ break;
+function zoomToLayer(j,k,l){
+ if(!j&&!k&&!l){
+ j=selectedMap;
+ k=selectedWMS;
+ l=selectedLayer;
+ var my= mb_mapObj[j].wms[k].objLayer[l].layer_epsg;
+ for (var i=0; i < my.length;i++) {
+ if(my[i]["epsg"]== mb_mapObj[j].epsg){
+ mb_calculateExtent(mod_treeGDE_map,my[i]["minx"],my[i]["miny"],my[i]["maxx"],my[i]["maxy"]);
+ var arrayExt = mb_mapObj[j].extent.toString().split(",");
+ mb_repaint(mod_treeGDE_map,arrayExt[0],arrayExt[1],arrayExt[2],arrayExt[3]);
+ //mb_repaint(mod_treeGDE_map,my[i]["minx"],my[i]["miny"],my[i]["maxx"],my[i]["maxy"]);
+ break;
+function openLegendHtml(j,k,l){
+ if(!j && !k&& !l){
+ j=selectedMap;
+ k=selectedWMS;
+ l=selectedLayer;
+ var my= mb_mapObj[j].wms[k].objLayer[l];
+ var legendWindow = window.open("../metadata/"+my.layer_name+".html", '<?php echo _mb("Legend");?>', "width=800,height=800,left=100,top=100,scrollbars=yes,resizable=no");
+ legendWindow.focus();
+function openStyleDialog(j,k,l){
+ j=selectedMap;
+ k=selectedWMS;
+ l=selectedLayer;
+ var dialogHtml = "<select id='styleSelect'>";
+ for (var i=0;i < my.layer_style.length;i++) {
+ dialogHtml += "<option value='" + my.layer_style[i].name + "'";
+ if(my.layer_style[i].name == my.gui_layer_style) {
+ dialogHtml += " selected";
+ dialogHtml += ">" + my.layer_style[i].title + "</option>";
+ dialogHtml += "</select>";
+ if(my.layer_style.length > 1) {
+ $("<div id='changeStyleDialog' title='<?php echo _mb('Change layer style');?>'><?php echo _mb('Please select a style');?>: </div>").dialog(
+ bgiframe: true,
+ autoOpen: true,
+ modal: false,
+ buttons: {
+ "<?php echo _mb('Close');?>": function(){
+ $(this).dialog('close').remove();
+ $(dialogHtml).appendTo("#changeStyleDialog");
+ $("#styleSelect").change(function() {
+ my.gui_layer_style = this.options[this.selectedIndex].value;
+ Mapbender.modules[mod_treeGDE_map].setMapRequest();
+ else {
+ alert("<?php echo _mb('There is no different style available for this layer.');?>");
+//---begin------------- opacity --------------------
+var opacityIncrement = 20;
+function opacity_up(j, k, l) {
+ handleOpacity(j, k, opacityIncrement);
+function opacity_down(j, k, l) {
+ handleOpacity(j, k, -opacityIncrement);
+function handleOpacity(mapObj_id, wms_id, increment) {
+ var opacity = mb_mapObj[mapObj_id].wms[wms_id].gui_wms_mapopacity*100 + increment;
+ mb_mapObj[mapObj_id].wms[wms_id].setOpacity(opacity);
+ reloadTree();
+//---end------------- opacity --------------------
+function move_up(j,k,l){
+ if(isNaN(j)&&isNaN(k)&&isNaN(l)){
+ j=selectedMap;
+ k=selectedWMS;
+ l=selectedLayer;
+ if(j==-1||k==-1||l==-1){
+ alert("<?php echo _mb('You have to select the WMS you want to move up!');?> ")
+ return;
+ var lid= mb_mapObj[j].wms[k].objLayer[l].layer_id;
+ if(! mb_mapObj[j].move( mb_mapObj[j].wms[k].wms_id,lid,(reverse=="true")?false:true)){
+ alert("<?php echo _mb('Illegal move operation');?>");
+ return;
+ treeState = getState();
+ mb_mapObj[j].zoom(true, 1.0);
+ mb_execloadWmsSubFunctions();
+ //find layer and select
+ for(k=0;k< mb_mapObj[j].wms.length;k++){
+ for(l=0;l< mb_mapObj[j].wms[k].objLayer.length;l++){
+ if( mb_mapObj[j].wms[k].objLayer[l].layer_id==lid){
+ select(j,k,l);
+ if(l!=0)
+ selectNode(String(lid));
+ else
+ selectNode("wms_"+String( mb_mapObj[j].wms[k].wms_id));
+function move_down(j,k,l){
+ j=selectedMap;
+ k=selectedWMS;
+ l=selectedLayer;
+ alert("<?php echo _mb('You have to select the WMS you want to move down!');?>")
+ return;
+ if(! mb_mapObj[j].move( mb_mapObj[j].wms[k].wms_id,lid,(reverse=="true")?true:false)){
+ return;
+ select(j,k,l);
+ if(l!=0)
+ else
+function remove_wms(j,k,l){
+ j=selectedMap;
+ k=selectedWMS;
+ l=selectedLayer;
+ alert("<?php echo _mb('You have to select the WMS you want to delete!');?>")
+ return;
+ if(l!=0){
+ alert("<?php echo _mb('It is not possible to delete a single layer, please select a WMS!');?>")
+ return;
+ var visibleWMS=0;
+ for(var i=0;i< mb_mapObj[j].wms.length;i++)
+ if( mb_mapObj[j].wms[i].gui_wms_visible==='1'|| mb_mapObj[j].wms[i].gui_wms_visible===1)
+ visibleWMS++;
+ if(visibleWMS<=1){
+ alert ("<?php echo _mb('Last WMS can not be removed.');?>");
+ return;
+ if(confirm('<?php echo _mb("Are you sure you want to remove");?>' + ' "'+ mb_mapObj[j].wms[k].objLayer[l].layer_currentTitle+'"?')){
+ mb_mapObjremoveWMS(j,k);
+ lock_maprequest = true; //done to prohibit save wmc for each wms
+ lock_maprequest = false;
+function updateParent(path){
+ if(lock_check)return;
+ var reset_lock=!lock_update;
+ lock_update=true;
+ var state=getChildrenCheckState(path, 0);
+ //enableCheckbox(path, (state!=-1)); //3rd state
+ checkNode(path, 0, (state==1));
+ if(state==0 && showstatus=='true' && path.split(jst_delimiter[0]).length == 2){
+ setTimeout('setNodeImage("'+path+'", "eye_off.svg");', 100);
+ else{
+ setTimeout('setNodeImage("'+path+'", "verticaldots.svg");', 100);
+ if(reset_lock){
+ lock_update=false;
+ handleSelectedWMS(path, true);
+function handleSelectedWMS(path){
+ if(lock_update)return;
+ var t = path.split("|");
+ var wms_id = t[t.length-1].substr(4);
+ var reset_lock=!lock_check;
+ var wms = getWMSIndexById(mod_treeGDE_map,wms_id);
+ var layername = mb_mapObj[ind].wms[wms].objLayer[0].layer_name;
+ var bChk = IsChecked(path, 0);
+ // in this case, only the root layer visibility/querylayer
+ // needs to be adjusted, without cascading the changes to
+ // its children
+ if (arguments.length === 2 && arguments[1]) {
+ var l = mb_mapObj[ind].wms[wms].getLayerByLayerName(layername);
+ l.gui_layer_visible = bChk ? 1 : 0;
+ l.gui_layer_querylayer = bChk ? 1 : 0;
+ mb_restateLayers(mod_treeGDE_map,wms_id);
+ if (!lock_maprequest) {
+ setSingleMapRequest(mod_treeGDE_map,wms_id);
+ return;
+ mb_mapObj[ind].wms[wms].handleLayer(layername,"visible",bChk?"1":"0");
+ mb_mapObj[ind].wms[wms].handleLayer(layername,"querylayer",bChk?"1":"0");
+ lock_check=true;
+ checkChildren(path, 0, bChk);
+ if(ficheckbox)checkChildren(path, 1, bChk);
+ if(bChk==false && showstatus=='true'){
+ else{
+ if(reset_lock)
+ lock_check=false;
+function handleSelection(path, box){
+ lock_check=true;
+ var bChk = IsChecked(path, box);
+// enableCheckbox(path, 0, true);
+ checkChildren(path, box, bChk);
+ if(reset_lock){
+ //find wms id from path
+ for(var i=1;t[i].indexOf("wms_")!=0;i++){}
+ var wms_id = t[i].substr(4);
+ //set maprequest
+ if(box==0)
+ lock_check=false;
+function setDimensionUserValue(j,k,l,dimensionIndex,userValue) {
+ j=selectedMap;
+ k=selectedWMS;
+ l=selectedLayer;
+ var my = mb_mapObj[j].wms[k].objLayer[l];
+ var myWms = mb_mapObj[j].wms[k];
+ //delete all userValues from other layers of this wms
+ for (var k=0;k< myWms.objLayer.length;k++) {
+ for (var i=0;i< myWms.objLayer[k].layer_dimension.length;i++) {
+ myWms.objLayer[k].layer_dimension[i].userValue = "";
+ my.layer_dimension[dimensionIndex].userValue = userValue;
+ //openfolder = true;
+ reloadTree();
+//function for buggy servers which do not support real iso8601 patterns for UTC :-(
+function makeDateTimeBetter(dateTimeIso) {
+ return dateTimeIso.replace('+00:00','Z');
+function snapToDiscreteValue(userValue,extent) {
+ //call it via sync ajax call :-(
+ transformUrl = '../php/mod_transformTimeDimension.php?operation=snapToGrid&userValue='+encodeURIComponent(userValue);
+ var response = $.ajax({
+ url: transformUrl,
+ type: "POST",
+ async: false,
+ data: {
+ 'extent':extent,
+ success: function (data) {
+ return data;
+ error: function() {
+ alert("An error occured!");
+ }).responseText;
+ var jsonValue = JSON.parse(response);
+ return jsonValue.data[0].value;
+function openDimensionSelectHtml(j,k,l,dimensionIndex) {
+ j=selectedMap;
+ k=selectedWMS;
+ l=selectedLayer;
+ $("#selectDimensionDialog").remove();
+ //extract/calculate discrete values for time!
+ var userValue = mb_mapObj[j].wms[k].objLayer[l].layer_dimension[dimensionIndex].userValue; //not already defined in mapobj!!
+ var extent = mb_mapObj[j].wms[k].objLayer[l].layer_dimension[dimensionIndex].extent;
+ var dimdefault = mb_mapObj[j].wms[k].objLayer[l].layer_dimension[dimensionIndex].default;
+ var dialogHtml = "<div id='timeline'></div>";
+ $("<div id='selectDimensionDialog' title='<?php echo _mb('Select layer dimension');?>'><?php echo _mb('Please select a value for TIME. One single element can be dragged on timeline after selection. Scale may be altered by scrolling.');?>: </div>").dialog(
+ bgiframe: true,
+ autoOpen: true,
+ modal: false,
+ width: 400,
+ closeOnEscape: false,
+ open: function(event, ui) { $( "div[aria-labelledby='ui-dialog-title-selectDimensionDialog']" ).children().children(".ui-dialog-titlebar-close").hide()}, //hide closing x - but only for element with special id!!!
+ buttons: {
+ $('selectDimensionDialog').remove();
+ //delete container, items, timeline
+ $(dialogHtml).appendTo("#selectDimensionDialog");
+ //fill timeline into div
+ if (userValue !== undefined && userValue !== false && userValue !== "" && userValue !== "undefined") {
+ userValue = makeDateTimeBetter(userValue);
+ transformUrl = '../php/mod_transformTimeDimension.php?userValue='+encodeURIComponent(userValue)+'&default='+encodeURIComponent(dimdefault);
+ } else {
+ transformUrl = '../php/mod_transformTimeDimension.php?default='+encodeURIComponent(dimdefault);
+ $.ajax({
+ type: "POST",
+ data: {
+ 'extent': extent,
+ // hide the "loading..." message
+ //document.getElementById('loading').style.display = 'none';
+ // DOM element where the Timeline will be attached
+ var container = document.getElementById('timeline');
+ // Create a DataSet (allows two way data-binding)
+ var items = new vis.DataSet(data.data);
+ // Configuration for the Timeline
+ var options = data.options;
+ //check if onclick or onmove should be enabled
+ if (data.options.editable.updateTime !== 'undefined' && data.options.editable.updateTime == true) {
+ options.onMove = function (item,callback) {
+ //calculate new value for item start based on snapping to period from extent
+ item.start = new Date(snapToDiscreteValue(item.start.toISOString(),extent));
+ item.content = item.start.toISOString();
+ myWms.gui_wms_dimension_time = makeDateTimeBetter(item.start.toISOString());
+ setDimensionUserValue(j,k,l,dimensionIndex,myWms.gui_wms_dimension_time);
+ Mapbender.modules[mod_treeGDE_map].setSingleMapRequest(mod_treeGDE_map,mb_mapObj[j].wms[k].wms_id);
+ callback(item);
+ } else {
+ options.editable = false;
+ // Create a Timeline
+ var timeline = new vis.Timeline(container, items, options);
+ //if (data.options.editable.updateTime == 'undefined' || data.options.editable.updateTime == false) {
+ timeline.on('select', function (properties) {
+ if (properties.event.type == "tap") {
+ myWms.gui_wms_dimension_time = makeDateTimeBetter(timeline.itemsData._data[timeline.getSelection()].content);
+ error: function (err) {
+ //console.log('Error', err);
+ if (err.status === 0) {
+ alert('Failed to load json for configuration of timeline from server.\nPlease contact your portal administrator!');
+ else {
+ alert('Failed to load json from server.');
+function initArray(){
+ var parentObj = "";
+ var controls="";
+ if( mb_mapObj.length > 0){
+ if( mb_mapObj[i].wms[ii].gui_wms_visible === '1' || mb_mapObj[i].wms[ii].gui_wms_visible === 1){
+ for(var iii=0; iii< mb_mapObj[i].wms[ii].objLayer.length; iii++){
+ var temp = mb_mapObj[i].wms[ii].objLayer[iii];
+ if( mb_mapObj[i].wms[ii].objLayer[iii].layer_parent == ""){
+ if(!temp.gui_layer_selectable == '1' && !temp.gui_layer_queryable == '1')
+ continue;
+ parentNode = arrNodes[0][0];
+ if(eval("categories.wms_"+ mb_mapObj[i].wms[ii].wms_id) !== undefined)
+ parentNode = eval("categories.wms_"+ mb_mapObj[i].wms[ii].wms_id);
+ else
+ eval("categories['wms_"+ mb_mapObj[i].wms[ii].wms_id+"'] = parentNode");
+ var c_menu="[";
+ if(reverse=="true"){
+ if(menu.indexOf("wms_down")!=-1 && ii!= mb_mapObj[i].wms.length-1)c_menu+="menu_move_up,";
+ if(menu.indexOf("wms_up")!=-1 && parentObj!="")c_menu+="menu_move_down,";
+ else{
+ if(menu.indexOf("wms_up")!=-1 && parentObj!="")c_menu+="menu_move_up,";
+ if(menu.indexOf("wms_down")!=-1 && ii!= mb_mapObj[i].wms.length-1)c_menu+="menu_move_down,";
+ if(menu.indexOf("remove")!=-1)c_menu+="menu_delete,";
+// if(menu.indexOf("wms_switch")!=-1)c_menu+="menu_wms_switch,";
+ if(menu.indexOf("opacity_up")!=-1 && parseFloat( mb_mapObj[i].wms[ii].gui_wms_mapopacity) < 1)c_menu+="menu_opacity_up,";
+ if(menu.indexOf("opacity_down")!=-1 && parseFloat( mb_mapObj[i].wms[ii].gui_wms_mapopacity) > 0)c_menu+="menu_opacity_down,";
+ if(menu.indexOf("hide")!=-1)c_menu+="menu_hide";
+ c_menu+="]";
+ controls='';
+ if(switchwms=='true')controls='<INPUT type="checkbox" title="' + msgObj.tooltipHandleWms + '" onclick="handleSelectedWMS(\''+parentNode+'|wms_'+ mb_mapObj[i].wms[ii].wms_id+'\');" />';
+ if(metadatalink == 'true'){
+ controls+='<a class="metadata_link" href="'+defaultMetadataUrl + '&id='+temp.layer_uid+'"'+' target=\'_blank\' onclick="metadata_window = window.open(this.href,\'Metadata\',\'Width=700, Height=550,scrollbars=yes,menubar=yes,toolbar=yes\'); metadata_window.focus(); return false;"><img alt="'+msgObj.tooltipMetadata+'" title="'+msgObj.tooltipMetadata+'" src="'+imagedir+'/info.svg" /></a>';
+ addNode(parentNode,["wms_"+ mb_mapObj[i].wms[ii].wms_id,[temp.layer_currentTitle,((metadatalink=='true'&&wmsbuttons != 'true')?('javascript:openwindow(\"'+ defaultMetadataUrl + '&id='+temp.layer_uid+'\",'+metadataWidth+','+metadataHeight+');'):"javascript:select("+i+","+ii+","+iii+");"),,,temp.layer_currentTitle,eval(c_menu),controls,[i,ii,iii]]],false,false,reverse=="true");
+ parentObj = parentNode+"|wms_"+ mb_mapObj[i].wms[ii].wms_id;
+ if( mb_mapObj[i].wms[ii].objLayer[iii].layer_parent && (handlesublayer=="true"|| mb_mapObj[i].wms[ii].objLayer[iii].layer_parent=="0")){
+ var parentLayer = "";
+ var j = iii;
+ while( mb_mapObj[i].wms[ii].objLayer[j].layer_parent!="0"){
+ //find parent
+ for(var jj=0; jj < mb_mapObj[i].wms[ii].objLayer.length; jj++){
+ if( mb_mapObj[i].wms[ii].objLayer[jj].layer_pos==parseInt( mb_mapObj[i].wms[ii].objLayer[j].layer_parent)){
+ j=jj;
+ break;
+ parentLayer = "|" + mb_mapObj[i].wms[ii].objLayer[j].layer_id + parentLayer;
+ if(temp.gui_layer_selectable == '1' || temp.gui_layer_queryable == '1'){
+ var c_menu="[";
+ if(menu.indexOf("layer_down")!=-1 && iii!= mb_mapObj[i].wms[ii].objLayer.length-1)c_menu+="menu_move_up,";
+ if(menu.indexOf("layer_up")!=-1 && iii!=1)c_menu+="menu_move_down,";
+ else{
+ if(menu.indexOf("layer_up")!=-1 && iii!=1)c_menu+="menu_move_up,";
+ if(menu.indexOf("layer_down")!=-1 && iii!= mb_mapObj[i].wms[ii].objLayer.length-1)c_menu+="menu_move_down,";
+ if(menu.indexOf("metainfo")!=-1)c_menu+="menu_metalink,";
+ if(menu.indexOf("zoom")!=-1 && temp.layer_epsg.length>0)c_menu+="menu_zoom,";
+// if(menu.indexOf("layer_switch")!=-1)c_menu+="menu_layer_switch,";
+// if(menu.indexOf("info_switch")!=-1)c_menu+="menu_info_switch,";
+ if(menu.indexOf("hide")!=-1)c_menu+="menu_hide,";
+ if(menu.indexOf("change_style")!=-1)c_menu+="menu_style,";
+ if(menu.indexOf("legend")!=-1)c_menu+="menu_legend";
+ c_menu+="]";
+ controls = [];
+ controls.push('<input type="checkbox" title="' + msgObj.tooltipLayerVisible + '" ');
+ if(temp.layer_name=="")
+ controls.push('style="display:none;" ');
+ if(temp.gui_layer_visible==='1' ||temp.gui_layer_visible===1){
+ controls.push('checked ');
+ if(temp.gui_layer_selectable!='1')
+ controls.push('disabled ');
+ controls.push("onclick=\"local_handleSelectedLayer('"+mod_treeGDE_map+"','"+ mb_mapObj[i].wms[ii].wms_id+"','"+temp.layer_name+"','visible',this.checked?1:0);");
+ if(ficheckbox == 'false')
+ controls.push("local_handleSelectedLayer('"+mod_treeGDE_map+"','"+ mb_mapObj[i].wms[ii].wms_id+"','"+temp.layer_name+"','querylayer',this.checked?1:0);");
+ controls.push("handleSelection('"+parentObj+parentLayer+"|"+temp.layer_id+"', 0);");
+ controls.push("updateParent('"+parentObj+parentLayer+"');\" />");
+ if(ficheckbox == 'true'){
+ controls.push('<input type="checkbox" title="' + msgObj.tooltipLayerQuerylayer + '" ');
+ if(temp.gui_layer_querylayer=='1')
+ if(temp.gui_layer_queryable!='1')
+ controls.push("onclick=\"local_handleSelectedLayer('"+mod_treeGDE_map+"','"+ mb_mapObj[i].wms[ii].wms_id+"','"+temp.layer_name+"','querylayer',this.checked?1:0);");
+ controls.push("handleSelection('"+parentObj+parentLayer+"|"+temp.layer_id+"', 1);\" />");
+ if(wmsbuttons == 'true'&&metadatalink == 'true'){
+ controls.push('<a href="'+defaultMetadataUrl + '&id='+temp.layer_uid+'"'+' target=\'_blank\' onclick="metadata_window = window.open(this.href,\'Metadata\',\'Width=700, Height=550,scrollbars=yes,menubar=yes,toolbar=yes\');metadata_window.focus(); return false;"><img alt="'+msgObj.tooltipMetadata+'" title="'+msgObj.tooltipMetadata+'" src="'+imagedir+'/info.svg" /></a>');
+ if(datalink == 'true' && mb_mapObj[i].wms[ii].objLayer[iii].layer_dataurl != ''){
+ controls.push('<a href="'+mb_mapObj[i].wms[ii].objLayer[iii].layer_dataurl+'"'+' target=\'_blank\' onclick="download_window = window.open(this.href,\'Download Data\',\'Width=450, Height=350,scrollbars=yes,menubar=yes,toolbar=yes\'); download_window.focus(); return false;"><img class="treegde2019" width="18" height="18" alt="'+msgObj.tooltipDownload+'" title="'+msgObj.tooltipDownload+'" src="'+imagedir+'/download.svg" /></a>');
+//if (typeof mb_mapObj[i].wms[ii].objLayer[iii].layer_featuretype_coupling == 'undefined') {
+//alert(mb_mapObj[i].wms[ii].objLayer[iii].layer_title+': '+JSON.stringify(mb_mapObj[i].wms[ii].objLayer[iii].layer_featuretype_coupling));
+ if(featuretypeCoupling == 'true' && mb_mapObj[i].wms[ii].objLayer[iii].layer_featuretype_coupling != ''){
+//alert(mb_mapObj[i].wms[ii].objLayer[iii].layer_featuretype_coupling);
+ //controls.push('<a href="'+mb_mapObj[i].wms[ii].objLayer[iii].layer_featuretype_coupling+'"'+' target=\'_blank\' onclick="featuretype_window = window.open(this.href,\'Featuretype Data\',\'Width=450, Height=350,scrollbars=yes,menubar=yes,toolbar=yes\'); featuretype_window.focus(); return false;"><img width="18" height="18" alt="'+msgObj.tooltipFeaturetypeCoupling+'" title="'+msgObj.tooltipFeaturetypeCoupling+'" src="'+imagedir+'/../gnome/accessories-dictionary.png" /></a>');
+ controls.push('<img width="18" height="18" coupling="'+btoa(mb_mapObj[i].wms[ii].objLayer[iii].layer_featuretype_coupling)+'" onclick="alert(atob(this.getAttribute(\'coupling\')))" alt="'+msgObj.tooltipFeaturetypeCoupling+'" title="'+msgObj.tooltipFeaturetypeCoupling+'" src="'+imagedir+'/../osgeo_graphics/geosilk/application_view_columns.png" />');
+ //controls.push('<img width="18" height="18" onclick="alert('+mb_mapObj[i].wms[ii].objLayer[iii].layer_featuretype_coupling+');" alt="'+msgObj.tooltipFeaturetypeCoupling+'" title="'+msgObj.tooltipFeaturetypeCoupling+'" src="'+imagedir+'/../osgeo_graphics/geosilk/application_view_columns.png" />');
+ //dimension buttons
+ if (activatedimension == 'true') {
+ timeDimensionAvailable = false;
+ timeDimensionIndex = false;
+ elevationDimensionAvailable = false;
+ elevationDimensionIndex = false;
+ //check for existence of time and/or elevation name attribute in dimension
+ for (dimensionIndex = 0; dimensionIndex < mb_mapObj[i].wms[ii].objLayer[iii].layer_dimension.length; ++dimensionIndex) {
+ switch (mb_mapObj[i].wms[ii].objLayer[iii].layer_dimension[dimensionIndex].name) {
+ case "time":
+ timeDimensionAvailable = true;
+ timeDimensionIndex = dimensionIndex;
+ timeUserValue = mb_mapObj[i].wms[ii].objLayer[iii].layer_dimension[dimensionIndex].userValue;
+ break;
+ case "elevation":
+ elevationDimensionAvailable = true;
+ elevationDimensionIndex = dimensionIndex;
+ elevationUserValue = mb_mapObj[i].wms[ii].objLayer[iii].layer_dimension[dimensionIndex].userValue;
+ break;
+ if (timeDimensionAvailable === true) {
+ text = JSON.stringify(mb_mapObj[i].wms[ii].objLayer[iii].layer_dimension[timeDimensionIndex]);
+ controls.push('<img onclick="openDimensionSelectHtml('+i+','+ii+','+iii+','+timeDimensionIndex+');" width="16" height="16" alt="'+msgObj.tooltipTimeDimension+'" title="Zeitpunkt wählen" style="cursor:pointer;margin:8px 5px -5px 0px" src="'+imagedir+'/clock.svg" />');
+ if (timeUserValue !== undefined && timeUserValue !== false && timeUserValue !== "" && timeUserValue !== "undefined") {
+ controls.push('<b>'+timeUserValue+'</b>');
+ //set gui_wms_dimension_time to value of layer - only one layer of a wms should have the userValue defined - if more have this, the last one will overwrite all earlier!
+ mb_mapObj[i].wms[ii].gui_wms_dimension_time = timeUserValue;
+ var groupedImageStyle ='';
+ if (temp.has_childs == true){
+ groupedImageStyle ='verticaldots.svg';
+ else{
+ addNode(parentObj + parentLayer, [temp.layer_id,[temp.layer_currentTitle,((metadatalink=='true'&&wmsbuttons != 'true')?('javascript:openwindow(\"'+ defaultMetadataUrl + '&id='+temp.layer_uid+'\",'+metadataWidth+','+metadataHeight+');'):"javascript:select("+i+","+ii+","+iii+");"),,((c_menu!='[]'&&temp.layer_name!="")?groupedImageStyle:null),temp.layer_currentTitle,eval(c_menu),controls.join(""),[i,ii,iii]]],false,false,reverse=="true");
+ initialized=true;
+//https://stackoverflow.com/questions/4253367/how-to-escape-a-json-string-containing-newline-characters-using-javascript
+// implement JSON stringify serialization
+JSON.stringify = JSON.stringify || function (obj) {
+ var t = typeof (obj);
+ if (t != "object" || obj === null) {
+ // simple data type
+ if (t == "string") obj = '"'+obj+'"';
+ return String(obj);
+ else {
+ // recurse array or object
+ var n, v, json = [], arr = (obj && obj.constructor == Array);
+ for (n in obj) {
+ v = obj[n]; t = typeof(v);
+ if (t == "string") v = '"'+v+'"';
+ else if (t == "object" && v !== null) v = JSON.stringify(v);
+ json.push((arr ? "" : '"' + n + '":') + String(v));
+ var rawString = (arr ? "[" : "{") + String(json) + (arr ? "]" : "}");
+ return rawString;
+function escape (key, val) {
+ if (typeof(val)!="string") return val;
+ var replaced = encodeURIComponent(val);
+ return replaced;
+JSON.stringifyEscaped = function(obj){
+ return JSON.stringify(obj,escape);
+function initWmsCheckboxen(){
+ var hidden=0;
+ updateParent(arrNodes[0][0]+"|wms_"+ mb_mapObj[i].wms[ii].wms_id);
+ else if(ii<= parseInt(openfolder, 10)+hidden)
+ hidden++;
+ closeAll();
+ var openFolderIndex = parseInt(openfolder, 10) + hidden;
+ if(treeState!='') {
+ setState(treeState);
+ else if(openfolder!=='false' && openFolderIndex < mb_mapObj[i].wms.length && openFolderIndex >= 0) {
+ setState(arrNodes[0][0]+"|wms_"+ mb_mapObj[i].wms[ openFolderIndex].wms_id);
More information about the Mapbender_commits
