[Mapbender-commits] r10281 - trunk/mapbender/http/php
svn_mapbender at osgeo.org svn_mapbender at osgeo.org
Wed Oct 2 04:44:04 PDT 2019
Author: armin11
Date: 2019-10-02 04:44:04 -0700 (Wed, 02 Oct 2019)
New Revision: 10281
   trunk/mapbender/http/php/mod_featuretypeISOMetadata.php
   trunk/mapbender/http/php/mod_getDownloadOptions.php
Add openapi 3.0 json link to download options
Modified: trunk/mapbender/http/php/mod_featuretypeISOMetadata.php
--- trunk/mapbender/http/php/mod_featuretypeISOMetadata.php	2019-10-02 07:08:15 UTC (rev 10280)
+++ trunk/mapbender/http/php/mod_featuretypeISOMetadata.php	2019-10-02 11:44:04 UTC (rev 10281)
@@ -31,17 +31,36 @@
 require_once(dirname(__FILE__) . "/../classes/class_XmlBuilder.php");
 require_once(dirname(__FILE__)."/../classes/class_owsConstraints.php");
 require_once(dirname(__FILE__)."/../classes/class_qualityReport.php");
+if (file_exists(dirname(__FILE__)."/../../conf/linkedDataProxy.json")) {
+     $configObject = json_decode(file_get_contents("../../conf/linkedDataProxy.json"));
+if (isset($configObject) && isset($configObject->behind_rewrite) && $configObject->behind_rewrite == true) {
+    $behindRewrite = true;
+} else {
+    $behindRewrite = false;
+if (isset($configObject) && isset($configObject->rewrite_path) && $configObject->rewrite_path != "") {
+    $rewritePath = $configObject->rewrite_path;
+} else {
+    $rewritePath = "linkedDataProxy";
 $con = db_connect(DBSERVER,OWNER,PW);
 db_select_db(DB,$con);
 global $serviceType;
 global $serviceTypeTitle;
+global $ogcApiFeaturesUrl;
+if (!empty($_SERVER['HTTPS'])) {
+    $schema = "https";
+} else {
+    $schema = "http";
 if (DEFINED("MAPBENDER_PATH") && MAPBENDER_PATH !== "") {
 	$mapbenderServiceUrl = MAPBENDER_PATH."/php/wfs.php?INSPIRE=1&FEATURETYPE_ID=";
 } else {
-	$mapbenderServiceUrl = $_SERVER['HTTP_HOST']."/mapbender/php/wfs.php?INSPIRE=1&FEATURETYPE_ID=";
+	$mapbenderServiceUrl = $schema."://".$_SERVER['HTTP_HOST']."/mapbender/php/wfs.php?INSPIRE=1&FEATURETYPE_ID=";
 $admin = new administration();
@@ -118,6 +137,14 @@
 	echo 'Parameter <b>validate</b> is not valid (true).<br/>';
 	die();
+if ($serviceType == "ogcapifeatures") {
+    if ($behindRewrite) {
+	$ogcApiFeaturesUrl = $schema."://".$_SERVER['HTTP_HOST']."/".$rewritePath;
+    } else {
+	$ogcApiFeaturesUrl = MAPBENDER_PATH."/php/mod_linkedDataProxy.php?";
 //some needfull functions to pull metadata out of the database!
 function fillISO19139(XmlBuilder $xmlBuilder, $recordId) {
     	global $wmsView;
@@ -125,6 +152,7 @@
 	global $admin;
+        global $ogcApiFeaturesUrl;
 	//read out relevant information from mapbender database:
 	if ($wmsView != '') {
 		$sql = "SELECT * ";
@@ -399,10 +427,23 @@
             './gmd:identificationInfo/srv:SV_ServiceIdentification/srv:couplingType/srv:SV_CouplingType',
             "tight");
+   switch ($serviceType) {
+        case "wfs":
+	    $url = $mapbenderServiceUrl.$mbMeta['featuretype_id']."&REQUEST=GetCapabilities&SERVICE=WFS&VERSION=".$mbMeta['wfs_version'];
+	    $protocol = "OGC:WFS-".$mbMeta['wfs_version']."-http-get-feature";
+	    $operation = "GetCapabilities";
+            break;
+	case "ogcapifeatures":
+            $url = $ogcApiFeaturesUrl."/".$mbMeta['wfs_id']."/api";
+	    $protocol = "OGC:API:Features";
+	    $operation = "getApiDescription";
+            break;
     $xmlBuilder->addValue($MD_Metadata,
             './gmd:identificationInfo/srv:SV_ServiceIdentification/srv:containsOperations/srv:SV_OperationMetadata/srv:operationName/gco:CharacterString',
-            "GetCapabilities");
+            $operation);
             './gmd:identificationInfo/srv:SV_ServiceIdentification/srv:containsOperations/srv:SV_OperationMetadata/srv:DCP/srv:DCPList/@codeListValue',
             "WebServices");
@@ -410,10 +451,10 @@
             './gmd:identificationInfo/srv:SV_ServiceIdentification/srv:containsOperations/srv:SV_OperationMetadata/srv:DCP/srv:DCPList/@codeList',
             "./resources/codelist/gmxCodelists.xml#DCPList");
-	//connectPoint **********************************
+    //connectPoint **********************************
             './gmd:identificationInfo/srv:SV_ServiceIdentification/srv:containsOperations/srv:SV_OperationMetadata/srv:connectPoint/gmd:CI_OnlineResource/gmd:linkage/gmd:URL',
-            "http://".$_SERVER['HTTP_HOST']."/mapbender/php/wfs.php?inspire=1&featuretype_id=".$mbMeta['featuretype_id']."&REQUEST=GetCapabilities&SERVICE=WFS");
+            $url);
 	//fill in operatesOn fields with datasetid if given
 	/*INSPIRE example: <srv:operatesOn xlink:href="http://image2000.jrc.it#image2000_1_nl2_multi"/>*/
@@ -464,7 +505,6 @@
     //Check if anonymous user has rights to access this featuretype - if not ? which resource should be advertised? TODO
     //initialize url to give back as point of access
     $url = '';
-    //$e = new mb_exception($serviceType);
         case "wfs":
@@ -471,7 +511,7 @@
             break;
-            $url = "http://localhost/spatial-objects/".$mbMeta['wfs_id']."/collections/".$mbMeta['featuretype_name'];
+            $url = $ogcApiFeaturesUrl."/".$mbMeta['wfs_id']."/collections/".$mbMeta['featuretype_name'];
             break;
Modified: trunk/mapbender/http/php/mod_getDownloadOptions.php
--- trunk/mapbender/http/php/mod_getDownloadOptions.php	2019-10-02 07:08:15 UTC (rev 10280)
+++ trunk/mapbender/http/php/mod_getDownloadOptions.php	2019-10-02 11:44:04 UTC (rev 10281)
@@ -261,11 +261,14 @@
 						if (isset($configObject) && isset($configObject->datasource_url) && $configObject->datasource_url != "") {
 							$downloadOptions->{$idList[$i]}->option[$j]->accessClient = $configObject->datasource_url.$configObject->rewrite_path."/".$row['service_id']."/collections/".$row['resource_name'];//."/items?&f=html";
+							$downloadOptions->{$idList[$i]}->option[$j]->accessUrl = $configObject->datasource_url.$configObject->rewrite_path."/".$row['service_id']."/api";//."/items?&f=html";
 						} else {
 							$downloadOptions->{$idList[$i]}->option[$j]->accessClient = "http://".$_SERVER['HTTP_HOST']."/".$configObject->rewrite_path."/".$row['service_id']."/collections/".$row['resource_name'];//."/items?&f=html";
+							$downloadOptions->{$idList[$i]}->option[$j]->accessUrl = "http://".$_SERVER['HTTP_HOST']."/".$configObject->rewrite_path."/".$row['service_id']."/api";//."/items?&f=html";
                                         } else {
 						$downloadOptions->{$idList[$i]}->option[$j]->accessClient = $webPath."php/mod_linkedDataProxy.php?wfsid=".$row['service_id']."&collection=".$row['resource_name'];
+						$downloadOptions->{$idList[$i]}->option[$j]->accessUrl = $webPath."php/mod_linkedDataProxy.php?wfsid=".$row['service_id']."&collections=api";
 					//$downloadOptions->{$idList[$i]}->option[$j]->accessClient = "https://www....";
 					$downloadOptions->{$idList[$i]}->title = $row['title'];
More information about the Mapbender_commits mailing list
