[Mapbender-commits] r10295 - in trunk/mapbender: http/plugins resources/locale/de_DE/LC_MESSAGES
svn_mapbender at osgeo.org svn_mapbender at osgeo.org
Mon Oct 21 06:24:44 PDT 2019
Author: armin11
Date: 2019-10-21 06:24:44 -0700 (Mon, 21 Oct 2019)
New Revision: 10295
   trunk/mapbender/http/plugins/mb_iframepopup.js
   trunk/mapbender/http/plugins/mb_metadata_manager_select.js
   trunk/mapbender/http/plugins/mb_metadata_server.php
   trunk/mapbender/http/plugins/mb_metadata_showMetadata.js
   trunk/mapbender/resources/locale/de_DE/LC_MESSAGES/Mapbender.po
Some little fixes for the application metadata editor.
Modified: trunk/mapbender/http/plugins/mb_iframepopup.js
--- trunk/mapbender/http/plugins/mb_iframepopup.js	2019-10-21 11:26:55 UTC (rev 10294)
+++ trunk/mapbender/http/plugins/mb_iframepopup.js	2019-10-21 13:24:44 UTC (rev 10295)
@@ -41,8 +41,8 @@
 	        $('<iframe src="' + this.href + '" />').dialog({
 	            title: ($this.attr('title')) ? $this.attr('title') : 'External Site',
 	            autoOpen: true,
-	            width: 800,
-	            height: 500,
+	            width: 850,
+	            height: 550,
 	            modal: true,
 	            resizable: true,
 				autoResize: true,
@@ -50,7 +50,7 @@
 	                opacity: 0.5,
 	                background: "black"
-	        }).width(800 - horizontalPadding).height(500 - verticalPadding);
+	        }).width(850 - horizontalPadding).height(550 - verticalPadding);
Modified: trunk/mapbender/http/plugins/mb_metadata_manager_select.js
--- trunk/mapbender/http/plugins/mb_metadata_manager_select.js	2019-10-21 11:26:55 UTC (rev 10294)
+++ trunk/mapbender/http/plugins/mb_metadata_manager_select.js	2019-10-21 13:24:44 UTC (rev 10295)
@@ -151,9 +151,9 @@
 	this.initTable = function() {
 		//initialize table object with jquery from ajax call to serverside script with translated headers!
 		mainDivContainer = $("#mb_metadata_manager_select");
+		//initialize size of table
 		//get attribute from object?
 		mainDivContainer.empty();
 		tableContainer = $(document.createElement('table'));
@@ -162,9 +162,9 @@
 		tableContainer.attr({'id':'metadataTable'});
 		//add button to add new entry to metadata table
 		if (hierarchyLevel == 'application') {
-		    $("<img class='metadataEntry clickable' title='new' src='../img/add.png' onclick='initMetadata(null, null, \"application\", true);return false;'/>").appendTo($("#mb_metadata_manager_select"));
+		    $("<img class='metadataEntry clickable' title='new' src='../img/gnome/newGui.png' onclick='initMetadata(null, null, \"application\", true);return false;'/>").appendTo($("#mb_metadata_manager_select"));
 		} else {
-		    $("<img class='metadataEntry clickable' title='new' src='../img/add.png' onclick='initMetadataAddon(null, null, \"metadata\", true);return false;'/>").appendTo($("#mb_metadata_manager_select"));
+		    $("<img class='metadataEntry clickable' title='new' src='../img/gnome/newGui.png' onclick='initMetadataAddon(null, null, \"metadata\", true);return false;'/>").appendTo($("#mb_metadata_manager_select"));
 		mainDivContainer.append(tableContainer);
 		//alert("created");
Modified: trunk/mapbender/http/plugins/mb_metadata_server.php
--- trunk/mapbender/http/plugins/mb_metadata_server.php	2019-10-21 11:26:55 UTC (rev 10294)
+++ trunk/mapbender/http/plugins/mb_metadata_server.php	2019-10-21 13:24:44 UTC (rev 10295)
@@ -1472,6 +1472,7 @@
 		//set export2csw and searchable always initially to true
 		$resultObj["export2csw2"] = true;
+		$resultObj["export2csw"] = true;
 		$resultObj["searchable"] = true;
 		$ajaxResponse->setResult($resultObj);
 		$ajaxResponse->setSuccess(true);
@@ -2155,7 +2156,7 @@
 //TODO - this function is defined for application metadata first - have to be extended to be used for other types dataset/series ...2019-10-07
 		$resourceType = $ajaxResponse->getParameter("resourceType");
 		$data = $ajaxResponse->getParameter("data");
-		if ($data->export2csw2 == "on") {
+		if ($data->export2csw == "on") {
 			$data->export2csw = 't';
 		} else {
 			$data->export2csw = 'f';
Modified: trunk/mapbender/http/plugins/mb_metadata_showMetadata.js
--- trunk/mapbender/http/plugins/mb_metadata_showMetadata.js	2019-10-21 11:26:55 UTC (rev 10294)
+++ trunk/mapbender/http/plugins/mb_metadata_showMetadata.js	2019-10-21 13:24:44 UTC (rev 10295)
@@ -295,8 +295,9 @@
 					modal: true
 				if (resourceType !== 'metadata') {
-					//update resource form to show edited data
-					that.fillResourceForm(resourceId, resourceType);
+					//first this means it will be an application!
+					//that.fillResourceForm(resourceId, resourceType);
+					Mapbender.modules.mb_metadata_manager_select.initTable();
 				} else {
@@ -325,7 +326,8 @@
 				} else {
@@ -456,6 +458,7 @@
 							return;
+//alert("showForm - save form: resourceType: "+resourceType);
 					var formData = $metadataForm.easyform("serialize");
 					if (!isNew) {
 						that.updateAddedMetadata(metadataId, resourceId, resourceType, formData);
Modified: trunk/mapbender/resources/locale/de_DE/LC_MESSAGES/Mapbender.po
--- trunk/mapbender/resources/locale/de_DE/LC_MESSAGES/Mapbender.po	2019-10-21 11:26:55 UTC (rev 10294)
+++ trunk/mapbender/resources/locale/de_DE/LC_MESSAGES/Mapbender.po	2019-10-21 13:24:44 UTC (rev 10295)
@@ -4356,4 +4356,18 @@
 msgid "Provider"
 msgstr "Anbieter"
+msgid "Application type"
+msgstr "Anwendungstyp"
+msgid "External application"
+msgstr "Externe Anwendung"
+msgid "Reference / Address"
+msgstr "Referenz / Adresse"
+msgid "Terms of Use / Constraints"
+msgstr "Nutzungsbedingungen / Zugangsbeschränkungen"
More information about the Mapbender_commits mailing list
