[Mapbender-commits] r10303 - in trunk/mapbender/http: classes php
svn_mapbender at osgeo.org
Mon Oct 28 05:57:51 PDT 2019
Author: armin11
Date: 2019-10-28 05:57:50 -0700 (Mon, 28 Oct 2019)
New Revision: 10303
trunk/mapbender/http/classes/class_user.php
trunk/mapbender/http/php/mod_createUser.php
Add send mail function for activation key
Modified: trunk/mapbender/http/classes/class_user.php
--- trunk/mapbender/http/classes/class_user.php 2019-10-28 10:18:36 UTC (rev 10302)
+++ trunk/mapbender/http/classes/class_user.php 2019-10-28 12:57:50 UTC (rev 10303)
@@ -522,16 +522,15 @@
public function sendUserLoginMail () {
$admin = new administration();
- $userMessage = "Your Mapbender login data:\n";
+ $userMessage = "Activation mail for Mapbender Geoportal\n";
$userMessage .= "Your login name is: ".$this->name."\n";
- $userMessage .= "Please set your password using the following link: \n";
- $mbUrl = substr(LOGIN, 0, -9);
- //$userMessage .= $mbUrl."../javascripts/mod_confirmLogin.php?user_id=".$this->id."&user_name=".$this->name."&user_ticket=".$this->passwordTicket."\n";
- $userMessage .= $mbUrl."../php/mod_activateUserAccount?activationKey=".$this->activation_key."\n";
+ $userMessage .= "Please activate your account by click on following link: \n";
+ $mbUrl = MAPBENDER_PATH."/";
+ $userMessage .= $mbUrl."php/mod_activateUserAccount.php?activationKey=".$this->activation_key."\n";
$userMessage .= "Follow this link to login to Mapbender: \n";
$userMessage .= LOGIN."\n";
$userMail = $admin->getEmailByUserId($this->id);
- if(!$admin->sendEmail("", "", $userMail, $this->name, utf8_decode("Your Mapbender account"), utf8_decode($userMessage), $error_msg)) {
+ if(!$admin->sendEmail("", "", $userMail, $this->name, utf8_decode("Your Mapbender Geoportal account"), utf8_decode($userMessage), $error_msg)) {
return "Registry data could not be send. Please check mail address.";
return "Registry data has been sent successfully.";
Modified: trunk/mapbender/http/php/mod_createUser.php
--- trunk/mapbender/http/php/mod_createUser.php 2019-10-28 10:18:36 UTC (rev 10302)
+++ trunk/mapbender/http/php/mod_createUser.php 2019-10-28 12:57:50 UTC (rev 10303)
@@ -159,6 +159,9 @@
$v = array($new_guiId1[0],$new_guiId2[0],$new_guiId3[0],$new_guiId4[0]);
$t = array('s','s','s','s');
$res_del_from_group = db_prep_query($sql_del_from_group,$v,$t);
+ //send mail with activation key to user!
+ $user->sendUserLoginMail();
+ echo "<script language='JavaScript'>alert('Email with activation key has been sent!');</script>";
More information about the Mapbender_commits
