[Mapbender-commits] r10236 - in trunk/mapbender/http: classes	frames javascripts php
    svn_mapbender at osgeo.org
    Fri Sep  6 01:34:32 PDT 2019
Author: armin11
Date: 2019-09-06 01:34:32 -0700 (Fri, 06 Sep 2019)
New Revision: 10236
   trunk/mapbender/http/classes/class_connector.php
   trunk/mapbender/http/classes/class_csw.php
   trunk/mapbender/http/classes/class_cswClient.php
   trunk/mapbender/http/classes/class_gml_3_factory.php
   trunk/mapbender/http/classes/class_wfs.php
   trunk/mapbender/http/frames/index.php
   trunk/mapbender/http/javascripts/mod_copyright.php
   trunk/mapbender/http/php/mod_callMetadata.php
   trunk/mapbender/http/php/mod_exportIso19139.php
   trunk/mapbender/http/php/mod_getCoupledResourcesForDataset.php
   trunk/mapbender/http/php/mod_loadWFSCapabilities.php
   trunk/mapbender/http/php/mod_syncCkan_server.php
Improve csw interface
Modified: trunk/mapbender/http/classes/class_connector.php
--- trunk/mapbender/http/classes/class_connector.php	2019-09-03 11:02:23 UTC (rev 10235)
+++ trunk/mapbender/http/classes/class_connector.php	2019-09-06 08:34:32 UTC (rev 10236)
@@ -68,6 +68,7 @@
 		//an internet connection. It can be that some requests are done thru this class to the urls of
 		//HTTP_AUTH_PROXY or OWSPROXY. If some of those are part of the url they must be exchanged with 127.0.0.1 - 			//which hopefully should work.
 		$testMatch = $url;
+$e = new mb_exception("url: ".$url);
 		$localTmpFolder = 'file://'.str_replace('classes',ltrim(TMPDIR,'../'),dirname(__FILE__)).'/';
 		$pattern = '/^http:|https:|'.str_replace('/','\/',$localTmpFolder).'/';
 		//$e = new mb_exception('file://'.str_replace('classes',ltrim(TMPDIR,'../'),dirname(__FILE__)).'/');
@@ -314,7 +315,7 @@
 				curl_setopt($ch, CURLOPT_POST, 1);
 			curl_setopt($ch, CURLOPT_POSTFIELDS, $this->httpPostData);
-			//$e = new mb_exception($this->httpPostData);
+//$e = new mb_exception($this->httpPostData);
 		$useragent=CONNECTION_USERAGENT;
 		//Build own headers for GET Requests - maybe needful?
@@ -333,7 +334,7 @@
 		curl_setopt($ch, CURLOPT_HTTPHEADER, $headers);
 		#curl_setopt($ch, CURLOPT_HEADER, true);
-		$e = new mb_notice("class_connector.php: CURL connect to:".$url);
+//$e = new mb_exception("class_connector.php: CURL connect to:".$url);
 		//curl_setopt ($ch,CURLOPT_USERAGENT,$useragent);
 		curl_setopt($ch,CURLOPT_DNS_USE_GLOBAL_CACHE, false);
 		curl_setopt($ch,CURLINFO_HEADER_OUT, true);
@@ -374,7 +375,7 @@
 		if ($tmpHttpProxy != '') {
 			putenv("http_proxy=$tmpHttpProxy");
-		//$e = new mb_notice("class_connector.php: CURL give back: ".$file);
+//$e = new mb_exception("class_connector.php: CURL give back: ".$file);
 		return $file;
Modified: trunk/mapbender/http/classes/class_csw.php
--- trunk/mapbender/http/classes/class_csw.php	2019-09-03 11:02:23 UTC (rev 10235)
+++ trunk/mapbender/http/classes/class_csw.php	2019-09-06 08:34:32 UTC (rev 10236)
@@ -146,9 +146,10 @@
 			$xml = str_replace('xlink:href', 'xlinkhref', $this->cat_getcapabilities_doc);
 			#http://forums.devshed.com/php-development-5/simplexml-namespace-attributes-problem-452278.html
 			#http://www.leftontheweb.com/message/A_small_SimpleXML_gotcha_with_namespaces
+//test without replace:
+			$xml = $this->cat_getcapabilities_doc;
 			$csw202Cap = new SimpleXMLElement($xml);
+			$namespaces = $csw202Cap->getNamespaces(true);
 			if ($csw202Cap === false) {
 				foreach(libxml_get_errors() as $error) {
         				$e = new mb_exception($error->message);
@@ -159,7 +160,7 @@
 		catch (Exception $e) {
     			$e = new mb_exception($e->getMessage());
+//xmlns:ns2="http://www.w3.org/1999/xlink"
 		if ($csw202Cap !== false) {
 			//read all relevant information an put them into the mapbender csw object
 			//xmlns="http://www.opengis.net/csw"
@@ -213,15 +214,15 @@
 			//for op_types
 			$op_types = array("GetCapabilities","DescribeRecord","GetRecords","GetRecordById");
 			foreach ($op_types as $op_type)  {
-				$this->cat_op_values[mb_strtolower($op_type)]['get']['dflt'] = $csw202Cap->xpath('/csw:Capabilities/ows:OperationsMetadata/ows:Operation[@name="'.$op_type.'"]/ows:DCP/ows:HTTP/ows:Get/@xlinkhref');
+				$this->cat_op_values[mb_strtolower($op_type)]['get']['dflt'] = $csw202Cap->xpath('/csw:Capabilities/ows:OperationsMetadata/ows:Operation[@name="'.$op_type.'"]/ows:DCP/ows:HTTP/ows:Get/@xlink:href');
 				$this->cat_op_values[mb_strtolower($op_type)]['get']['dflt'] = html_entity_decode($this->cat_op_values[mb_strtolower($op_type)]['get']['dflt'][0]);
 				//$e = new mb_exception("class_csw: operationurl: ".$this->cat_op_values[mb_strtolower($op_type)]['get']['dflt']);
-				$this->cat_op_values[mb_strtolower($op_type)]['post']['dflt'] = $csw202Cap->xpath('/csw:Capabilities/ows:OperationsMetadata/ows:Operation[@name="'.$op_type.'"]/ows:DCP/ows:HTTP/ows:Post/@xlinkhref');
+				$this->cat_op_values[mb_strtolower($op_type)]['post']['dflt'] = $csw202Cap->xpath('/csw:Capabilities/ows:OperationsMetadata/ows:Operation[@name="'.$op_type.'"]/ows:DCP/ows:HTTP/ows:Post/@xlink:href');
 				$this->cat_op_values[mb_strtolower($op_type)]['post']['dflt'] = html_entity_decode($this->cat_op_values[mb_strtolower($op_type)]['post']['dflt'][0]);
 				//extract constraints for this operation
 				$constraints = $csw202Cap->xpath('/csw:Capabilities/ows:OperationsMetadata/ows:Operation[@name="'.$op_type.'"]/ows:Constraint[@name="PostEncoding"]/ows:Value');
 				foreach ($constraints as $constraint) {
-					$this->cat_op_values[mb_strtolower($op_type)]['post'][mb_strtolower($constraint)]=$this->cat_op_values[mb_strtolower($op_type)]['post']['dflt'];
+					$this->cat_op_values[mb_strtolower($op_type)]['post'][mb_strtolower($constraint)]=$this->cat_op_values[mb_strtolower($op_type)]['post'][$constraint];
 					//$e = new mb_exception("class_csw: constraint: ".mb_strtolower($constraint));
Modified: trunk/mapbender/http/classes/class_cswClient.php
--- trunk/mapbender/http/classes/class_cswClient.php	2019-09-03 11:02:23 UTC (rev 10235)
+++ trunk/mapbender/http/classes/class_cswClient.php	2019-09-06 08:34:32 UTC (rev 10236)
@@ -344,7 +344,9 @@
 			//$e = new mb_exception("test: ".$csw->cat_op_values[$operationNameCsw]['post']);
 			if ($cswId != false) {
 				$this->operationResult = $this->getResult($csw->cat_op_values[$operationNameCsw]['post'], $postRequest);
+				//csw not from database but from capabilities!
 			} else {
+$e = new mb_exception(json_encode($csw->cat_op_values[$operationNameCsw]));
 				$this->operationResult = $this->getResult($csw->cat_op_values[$operationNameCsw]['post']['dflt'], $postRequest);
 			//Also give back url of operation
@@ -353,6 +355,7 @@
 			} else {
 				$this->operationUrl = $csw->cat_op_values[$operationNameCsw]['post']['dflt'];
+$e = new mb_exception($this->operationUrl);
 		} else {
 			$this->operationResult = $this->getResult($csw->cat_op_values["transaction"]['post'], $postRequest);
 			//$this->operationUrl = $csw->cat_op_values[$operationNameCsw]['post'];
Modified: trunk/mapbender/http/classes/class_gml_3_factory.php
--- trunk/mapbender/http/classes/class_gml_3_factory.php	2019-09-03 11:02:23 UTC (rev 10235)
+++ trunk/mapbender/http/classes/class_gml_3_factory.php	2019-09-06 08:34:32 UTC (rev 10236)
@@ -386,7 +386,7 @@
 						$srs = $geomNode->getAttribute("srsName");
+//$e = new mb_exception("classes/class_gml_3_factory: found srs: ".$srs);
 				//if srsName of featureMember is empty, use the srsName of node //gml:boundedBy/gml:Envelope
 				if($srs == "") {
 					$srs = $gmlBoundedBySrs;
Modified: trunk/mapbender/http/classes/class_wfs.php
--- trunk/mapbender/http/classes/class_wfs.php	2019-09-03 11:02:23 UTC (rev 10235)
+++ trunk/mapbender/http/classes/class_wfs.php	2019-09-06 08:34:32 UTC (rev 10236)
@@ -508,6 +508,7 @@
 				$getRequest .= "&FILTER=".urlencode($filter);
 //$e = new mb_exception("classes/class_wfs.php: getfeature-GET-url: ".$getRequest);
+//$e = new mb_exception("classes/class_wfs.php: getfeature-GET-result: ".$this->get($getRequest));
                             return $this->get($getRequest);
 			    break;
Modified: trunk/mapbender/http/frames/index.php
--- trunk/mapbender/http/frames/index.php	2019-09-03 11:02:23 UTC (rev 10235)
+++ trunk/mapbender/http/frames/index.php	2019-09-06 08:34:32 UTC (rev 10236)
@@ -296,6 +296,8 @@
 $mapPhpParameters = htmlentities($urlParameters, ENT_QUOTES, CHARSET);
 $mapPhpParameters .= "&".htmlentities($_SERVER["QUERY_STRING"]);
+$e = new mb_exception("index.php: mapPhpParameters: ".$mapPhpParameters);
 if ($representationType == "htmlComplete") {
 	$html .= "<script type='text/javascript' src='../javascripts/map.php?".$mapPhpParameters."'></script>".$linebreak;
 } else {
Modified: trunk/mapbender/http/javascripts/mod_copyright.php
--- trunk/mapbender/http/javascripts/mod_copyright.php	2019-09-03 11:02:23 UTC (rev 10235)
+++ trunk/mapbender/http/javascripts/mod_copyright.php	2019-09-06 08:34:32 UTC (rev 10236)
@@ -36,7 +36,7 @@
 function mod_copyright(){
 	var myMapObj = Mapbender.modules[mod_copyright_target];
-	var str_c = "<div style='z-index:70;font-family:" + mod_copyright_font + ";font-size:" + mod_copyright_fontsize + ";color:" + mod_copyright_color2 + ";position:absolute;bottom:5px;right:5px'>"+mod_copyright_text+"</div>";
+	var str_c = "<div style='z-index:110;font-family:" + mod_copyright_font + ";font-size:" + mod_copyright_fontsize + ";color:" + mod_copyright_color2 + ";position:absolute;bottom:5px;right:5px'>"+mod_copyright_text+"</div>";
 	var map_el = myMapObj.getDomElement();
 	if(!map_el.ownerDocument.getElementById(myMapObj.elementName+"_copyright")){
@@ -47,4 +47,4 @@
 		map_el.appendChild(el_top);
 	writeTag(myMapObj.frameName, myMapObj.elementName+"_copyright", str_c);
\ No newline at end of file
Modified: trunk/mapbender/http/php/mod_callMetadata.php
--- trunk/mapbender/http/php/mod_callMetadata.php	2019-09-03 11:02:23 UTC (rev 10235)
+++ trunk/mapbender/http/php/mod_callMetadata.php	2019-09-06 08:34:32 UTC (rev 10236)
@@ -686,7 +686,7 @@
 		$classificationElements[10]['name2show'] = 'Datenaktualität von:';
 		$classificationElements[11]['name2show'] = 'Datenaktualität bis:';
-		$resourceCategories['wms'] = 'Darstellungsdienste';
+		$resourceCategories['wms'] = 'Kartenebenen';
 		$resourceCategories['wfs'] = 'Such- und Download- und Erfassungsmodule';
 		$resourceCategories['wmc'] = 'Kartenzusammenstellungen';
 		$resourceCategories['dataset'] = 'Datensätze';
@@ -716,7 +716,7 @@
 		$classificationElements[10]['name2show'] = 'Actuality of dataset from:';
 		$classificationElements[11]['name2show'] = 'Actuality of dataset to:';
-		$resourceCategories['wms'] = 'Viewingservices';
+		$resourceCategories['wms'] = 'Maplayers';
 		$resourceCategories['wfs'] = 'Search- and Downloadservices';
 		$resourceCategories['wmc'] = 'Combined Maps';
 		$resourceCategories['dataset'] = 'Datasets';
@@ -774,7 +774,7 @@
 		$resourceCategories['wfs'] = 'Such- und Downloaddienste';
Modified: trunk/mapbender/http/php/mod_exportIso19139.php
--- trunk/mapbender/http/php/mod_exportIso19139.php	2019-09-03 11:02:23 UTC (rev 10235)
+++ trunk/mapbender/http/php/mod_exportIso19139.php	2019-09-06 08:34:32 UTC (rev 10236)
@@ -78,8 +78,8 @@
 //TODO: test if this ok - maybe not everything is parsed by class? instead we could use $mbMetadata->readFromUrl($url);
 $mbMetadata->createFromUrl($url);
-$e = new mb_exception("php/mod_exportIso19139.php: url for getrecordbyid: ".$url);
-$e = new mb_exception("php/mod_exportIso19139.php: datasetid from getrecordbyid: ".$mbMetadata->datasetIdCodeSpace.$mbMetadata->datasetId);
+//$e = new mb_exception("php/mod_exportIso19139.php: url for getrecordbyid: ".$url);
+//$e = new mb_exception("php/mod_exportIso19139.php: datasetid from getrecordbyid: ".$mbMetadata->datasetIdCodeSpace.$mbMetadata->datasetId);
 //$e = new mb_exception("datasetId: ".$mbMetadata->datasetId);
 //$e = new mb_exception("datasetIdCodeSpace: ".$mbMetadata->datasetIdCodeSpace);
@@ -97,8 +97,11 @@
 		//$e = new mb_exception("parse csw capabilities!");
 		//parse url
 		$urlArray = parse_url($url);
-		$urlWithoutRequest = $urlArray['scheme']."://".$urlArray['host'].":".$urlArray['port']."/".$urlArray['path'];
+//$e = new mb_exception(json_encode($urlArray));
+		//$urlWithoutRequest = $urlArray['scheme']."://".$urlArray['host'].":".$urlArray['port']."/".$urlArray['path'];
+		$urlWithoutRequest = $urlArray['scheme']."://".$urlArray['host'].$urlArray['path'];
 		$csw->createCatObjFromXML($urlWithoutRequest."?SERVICE=CSW&VERSION=2.0.2&REQUEST=GetCapabilities");
+		//$e = new mb_exception($urlWithoutRequest."?SERVICE=CSW&VERSION=2.0.2&REQUEST=GetCapabilities");
 		$cswClient = new cswClient();
 		$operation = "getrecordsresolvecoupling";
 		$getrecordId = $mbMetadata->fileIdentifier;
Modified: trunk/mapbender/http/php/mod_getCoupledResourcesForDataset.php
--- trunk/mapbender/http/php/mod_getCoupledResourcesForDataset.php	2019-09-03 11:02:23 UTC (rev 10235)
+++ trunk/mapbender/http/php/mod_getCoupledResourcesForDataset.php	2019-09-06 08:34:32 UTC (rev 10236)
@@ -215,7 +215,8 @@
 		//$e = new mb_exception("php/mod_getCoupledResourcesForDataset.php: datasetid from getrecordbyid: ".$mbMetadata->datasetId);
-		$datasetId = str_replace('&','&',$mbMetadata->datasetIdCodeSpace.$mbMetadata->datasetId);
+		$datasetId = str_replace('&','&',$mbMetadata->datasetIdCodeSpace.'/'.$mbMetadata->datasetId);
 		$recordType = 'service';
 		$cswResponseObject = $cswClient->doRequest(false, $operation, $getrecordId, false, $recordType, false, false, false, $datasetId, $csw);
 		$serviceMetadataUrls = array();
Modified: trunk/mapbender/http/php/mod_loadWFSCapabilities.php
--- trunk/mapbender/http/php/mod_loadWFSCapabilities.php	2019-09-03 11:02:23 UTC (rev 10235)
+++ trunk/mapbender/http/php/mod_loadWFSCapabilities.php	2019-09-06 08:34:32 UTC (rev 10236)
@@ -158,6 +158,7 @@
 echo "REQUEST=GetCapabilities&VERSION=1.0.0&SERVICE=WFS<br>";
 echo "REQUEST=GetCapabilities&VERSION=1.1.0&SERVICE=WFS<br>";
 echo "REQUEST=GetCapabilities&VERSION=2.0.0&SERVICE=WFS<br>";
+//echo "REQUEST=GetCapabilities&VERSION=2.0.2&SERVICE=WFS<br>";
 echo "<br><br>";
 echo "Link to WFS Capabilities URL:<br>";
Modified: trunk/mapbender/http/php/mod_syncCkan_server.php
--- trunk/mapbender/http/php/mod_syncCkan_server.php	2019-09-03 11:02:23 UTC (rev 10235)
+++ trunk/mapbender/http/php/mod_syncCkan_server.php	2019-09-06 08:34:32 UTC (rev 10236)
@@ -198,6 +198,8 @@
 		echo "You are not root user and therefor not allowed to sync organizations with ckan!";
 		die();
 	$sql = <<<SQL
 select opendata.*, mb_group.uuid, mb_group_id, mb_group_title, mb_group_description, mb_group_homepage, mb_group_logo_path, mb_group_address, mb_group_postcode, mb_group_city, mb_group_email, timestamp, mb_group.mb_group_ckan_uuid from mb_group, (select (sum(count_wms_layer)+sum(count_metadata)) as number_of_opendata_ressources, group_id,mb_group_name from (
@@ -213,6 +215,9 @@
 SQL;
+if (isset($orgaId)){
+	$sql .= " AND mb_group_id = ".$orgaId."";
 	$sql2 = <<<SQL
@@ -225,6 +230,10 @@
 SQL;
+	$sql2 .= " AND mb_group_id = ".$orgaId."";
 	$sql3 = <<<SQL
@@ -240,7 +249,11 @@
 SQL;
+	$sql3 .= " AND mb_group_id = ".$orgaId."";
 	$sql4 = <<<SQL
 select opendata.*, mb_group.uuid, mb_group_id, mb_group_title, mb_group_description, mb_group_homepage, mb_group_logo_path, mb_group_address, mb_group_postcode, mb_group_city, mb_group_email, timestamp, mb_group.mb_group_ckan_uuid from mb_group, (select (sum(count_wms_layer)+sum(count_metadata)) as number_of_opendata_ressources, group_id, mb_group_name from (
@@ -252,6 +265,11 @@
 SQL;
+	$sql4 .= " AND mb_group_id = ".$orgaId."";
 	switch ($showOnlyDatasetMetadata) {
 		case "true":
 			if ($showOnlyUnlinkedOrganizations == "true") {
More information about the Mapbender_commits
