[Mapbender-commits] r10248 - trunk/mapbender/http/javascripts
svn_mapbender at osgeo.org
Fri Sep 13 04:20:48 PDT 2019
Author: armin11
Date: 2019-09-13 04:20:48 -0700 (Fri, 13 Sep 2019)
New Revision: 10248
Added:
trunk/mapbender/http/javascripts/mod_wfsGazetteerEditor_client_flst.php
New options to build nicer guis ;-) - thanx to karl owesny
Added: trunk/mapbender/http/javascripts/mod_wfsGazetteerEditor_client_flst.php
--- trunk/mapbender/http/javascripts/mod_wfsGazetteerEditor_client_flst.php (rev 0)
+++ trunk/mapbender/http/javascripts/mod_wfsGazetteerEditor_client_flst.php 2019-09-13 11:20:48 UTC (rev 10248)
@@ -0,0 +1,1482 @@
+<?php
+# $Id: mod_wfsGazetteerEditor_client.php 1414 2008-01-17 08:55:06Z diewald $
+# maintained by http://www.mapbender.org/index.php/User:Verena Diewald
+# http://www.mapbender.org/index.php/WFS_gazetteer
+# Copyright (C) 2002 CCGIS
+# This program is free software; you can redistribute it and/or modify
+# it under the terms of the GNU General Public License as published by
+# the Free Software Foundation; either version 2, or (at your option)
+# any later version.
+# This program is distributed in the hope that it will be useful,
+# but WITHOUT ANY WARRANTY; without even the implied warranty of
+# MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the
+# GNU General Public License for more details.
+# You should have received a copy of the GNU General Public License
+# along with this program; if not, write to the Free Software
+# Foundation, Inc., 59 Temple Place - Suite 330, Boston, MA 02111-1307, USA.
+require_once(dirname(__FILE__)."/../../core/globalSettings.php");
+include(dirname(__FILE__) . "/../../core/epsg.php");
+$gui_id = Mapbender::session()->get("mb_user_gui");
+$target = $_REQUEST["e_target"];
+$e_id_css = $_REQUEST["e_id_css"];
+$isLoaded = $_REQUEST["isLoaded"];
+$con = db_connect($DBSERVER,$OWNER,$PW);
+db_select_db($DB,$con);
+<!DOCTYPE HTML PUBLIC "-//W3C//DTD HTML 4.01 Transitional//EN">
+<html>
+<head>
+<meta http-equiv="Content-Type" content="text/html; charset='<?php echo CHARSET;?>'">
+<title>mod_wfsGazetteerEditor</title>
+<STYLE TYPE="text/css">
+div.mainDiv {
+ width: 330px;
+input.op {
+ width: 32px;
+div.helptext {
+ visibility: hidden;
+ display: none;
+ position: absolute;
+ top: 5%;
+ left: 5%;
+ width: 90%;
+ padding: 5px;
+ color: #000;
+ background-color: #CCC;
+ border: 1px solid #000;
+ z-index:1000;
+div.helptext p {
+ margin: 0 ;
+div.helptext a.close {
+ display: block;
+ margin: 5px auto;
+ text-align: center;
+a img {
+ vertical-align: middle;
+ border: 0;
+ margin-bottom: 10px;
+</STYLE>
+<?php
+include '../include/dyn_css.php';
+<script type="text/javascript">
+<?php
+ include '../include/dyn_js.php';
+ include '../include/dyn_php.php';
+ include("../../conf/" . $wfs_spatial_request_conf_filename);
+ echo "var targetString = '" . $target . "';";
+ echo "var e_id_css = '" . $e_id_css . "';";
+ echo "var latLonSrsJson = '" . $latLonSrsJson . "';";
+ require(dirname(__FILE__)."/../javascripts/wfsFilter.js");
+// Element var maxHighlightedPoints
+try{
+ if (maxHighlightedPoints){
+ maxHighlightedPoints = Number(maxHighlightedPoints);
+ if (isNaN(maxHighlightedPoints)) {
+ var e = new parent.Mb_warning("mod_wfsGazetteerEditor_client.php: Element var maxHighlightedPoints must be a number.");
+catch(e){
+ maxHighlightedPoints = 0;
+ var e = new parent.Mb_warning("mod_wfsGazetteerEditor_client.php: Element var maxHighlightedPoints is not set, see 'edit element vars'.");
+//Element var to force request a crs which differ from crs values given in wfs capabilities!
+try {if(forceCrsFromMap){}}catch(e) {forceCrsFromMap = 0;}
+var global_forceCrsFromMap = forceCrsFromMap;
+var otherFrame = parent.window.frames[e_id_css];
+<?php
+//var global_selectedWfsConfId = otherFrame.global_selectedWfsConfId;
+$wfsConfId = $_REQUEST['wfsConfId'];
+echo "var global_selectedWfsConfId = '$wfsConfId';\n";
+//var global_wfsConfObj = otherFrame.global_wfsConfObj;
+var targetArray = targetString.split(",");
+var global_resultHighlight;
+var requestGeometryHighlight;
+var point_px = 10;
+var resultGeom = null;
+var cw_fillcolor = "#cc33cc";
+var frameName = e_id_css + "_";
+var inputNotEnough = [];
+var button_point = "point";
+var button_polygon = "polygon";
+var button_rectangle = "rectangle";
+var button_extent = "extent";
+var mb_wfs_tolerance = 8;
+var activeButton = null;
+var mod_wfs_spatialRequest_geometry = null;
+var mod_wfs_spatialRequest_frameName = "";
+var mod_wfs_spatialRequest_epsg;
+var mod_wfs_spatialRequest_width;
+var mod_wfs_spatialRequest_height;
+var buttonWfs_id = [];
+var buttonWfs_on = [];
+var buttonWfs_src = [];
+var buttonWfs_title_off = [];
+var buttonWfs_title_on = [];
+var buttonWfs_x = [];
+var buttonWfs_y = [];
+ * This Geometry contains the geometry of the optinal spatial constraint
+var spatialRequestGeom = null;
+ * Something like box, polygon, point, extent
+var spatialRequestType = null;
+ * This Geometry contains the result from the WFS request
+var geomArray = null;
+var frameIsReady = function () {
+ var req = parent.Mapbender.Ajax.Request({
+ url: "../php/mod_wfs_conf_server.php",
+ method: "getWfsConfsFromId",
+ parameters: {
+ wfsConfIdString: global_selectedWfsConfId
+ callback: function(result,success,message){
+ console.debug("b");
+ console.debug(result);
+ // the rest of the script doesn't expect an array, but an object, so the result must be converted
+ global_wfsConfObj = {};
+ for(var i in result){
+ if(!result.hasOwnProperty(i)){ continue;}
+ global_wfsConfObj[result[i].id] = result[i];
+ init_wfsSpatialRequest();
+ appendWfsForm();
+ appendStyles();
+ setWfsInfo();
+ // creates a Highlight object for the request geometry
+ var styleProperties = {"position":"absolute", "top":"0px", "left":"0px", "z-index":100};
+ requestGeometryHighlight = new parent.Highlight(targetArray, "requestGeometryHighlight", styleProperties, 2);
+ parent.mb_registerSubFunctions("window.frames['" + frameName +"'].requestGeometryHighlight.paint()");
+// req.send();
+ parent.mb_ajax_json("../php/mod_wfs_gazetteer_server.php", {command:"getWfsConf",wfsConfIdString: global_selectedWfsConfId }, function(json,status){
+ global_wfsConfObj = json;
+ appendWfsForm();
+ appendStyles();
+ setWfsInfo();
+function showHelptext(helptextId) {
+ hideHelptext();
+ document.getElementById('helptext' + helptextId).style.visibility = 'visible';
+ document.getElementById('helptext' + helptextId).style.display = 'block';
+function hideHelptext(helptextId) {
+ if(helptextId) {
+ document.getElementById('helptext' + helptextId).style.visibility = 'hidden';
+ document.getElementById('helptext' + helptextId).style.display = 'none';
+ var helptext = document.getElementsByTagName('div');
+ for(var i = 0; i < helptext.length; i++) {
+ if(helptext[i].className === 'helptext') {
+ helptext[i].style.visibility = 'hidden';
+ helptext[i].style.display = 'none';
+function trim(string) {
+ return string.replace(/^\s+/, '').replace(/\s+$/, '');
+function removeChildNodes(node) {
+ if (node) {
+ while (node.childNodes.length > 0) {
+ var childNode = node.firstChild;
+ node.removeChild(childNode);
+ * removes whitespaces and endlines before and after a string
+function trimString (str) {
+ return str.replace(/^\s+|\s+|\n+$/g, '');
+function openwindow(Adresse) {
+ Fenster1 = window.open(Adresse, "<?php echo _mb("Informations"); ?>", "width=500,height=500,left=100,top=100,scrollbars=yes,resizable=no");
+ Fenster1.focus();
+function setWfsInfo() {
+ // append bulb image
+ //var bulbNode = document.getElementById("wfsInfo");
+ //var imgNode = document.createElement("img");
+ //imgNode.id = "wfsInfoImg";
+ //imgNode.src = "../img/button_blue/getArea_off.png";
+ //imgNode.border = 0;
+ //bulbNode.appendChild(imgNode);
+ //bulbNode.href = "javascript:openwindow('../php/mod_showMetadata.php?resource=wfs-conf&id=" + global_selectedWfsConfId.toString() + "');";
+ //bulbNode.style.display = "inline";
+ // set image (pre configured or editor)
+ //var wfsPreConfiguredOrEditor = document.getElementById("wfsPreConfiguredOrEditor");
+ //var preConfigured = false;
+ //for (var i=0; i < global_wfsConfObj[global_selectedWfsConfId].element.length; i++) {
+ // if (parseInt(global_wfsConfObj[global_selectedWfsConfId].element[i].f_search)) {
+ // preConfigured = true;
+ // break;
+ //if (preConfigured) {
+ // wfsPreConfiguredOrEditor.src = "../img/gnome/icn_suchmodul.png";
+ // wfsPreConfiguredOrEditor.title = "<?php echo _mb("Moduletype: Search"); ?>";
+ //else {
+ // wfsPreConfiguredOrEditor.src = "../img/gnome/document-save.png";
+ //wfsPreConfiguredOrEditor.style.display = 'inline';
+ // set wfsGeomType image
+ var wfsGeomTypeNode = document.getElementById("wfsGeomType");
+ var wfsGeomType = "";
+ for (var i=0; i < global_wfsConfObj[global_selectedWfsConfId].element.length; i++) {
+ if (parseInt(global_wfsConfObj[global_selectedWfsConfId].element[i].f_geom)) {
+ wfsGeomType = global_wfsConfObj[global_selectedWfsConfId].element[i].element_type;
+ if (wfsGeomType.match(/Point/)) {
+ wfsGeomTypeNode.src = "../img/button_digitize_blue_red/point.png";
+ wfsGeomTypeNode.style.display = 'inline';
+ wfsGeomTypeNode.title = '<?php echo _mb("Geometrytype: point"); ?>';
+ else if (wfsGeomType.match(/Line/)) {
+ wfsGeomTypeNode.src = "../img/button_digitize_blue_red/line.png";
+ wfsGeomTypeNode.title = '<?php echo _mb("Geometrytype: line"); ?>';
+ else if (wfsGeomType.match(/Polygon/)) {
+ wfsGeomTypeNode.src = "../img/button_digitize_blue_red/polygon.png";
+ wfsGeomTypeNode.title = '<?php echo _mb("Geometrytype: area"); ?>';
+ else {
+ var e = new parent.Mb_exception("WFS gazetteer: geometry type unknown.");
+ * BUTTON HANDLING
+function addButtonWfs(id, isOn, src, title, x, y) {
+ buttonWfs_id.push(id);
+ buttonWfs_on.push(isOn);
+ buttonWfs_src.push(src);
+ buttonWfs_title_off.push(title);
+ buttonWfs_title_on.push(title);
+ buttonWfs_x.push(x);
+ buttonWfs_y.push(y);
+function init_wfsSpatialRequest() {
+ buttonWfs_id = [];
+ buttonWfs_on = [];
+ buttonWfs_src = [];
+ buttonWfs_title_off = [];
+ buttonWfs_title_on = [];
+ buttonWfs_x = [];
+ buttonWfs_y = [];
+ addButtonWfs("rectangle", buttonRectangle.status, buttonRectangle.img, buttonRectangle.title, buttonRectangle.x, buttonRectangle.y);
+ addButtonWfs("polygon", buttonPolygon.status, buttonPolygon.img, buttonPolygon.title, buttonPolygon.x, buttonPolygon.y);
+ addButtonWfs("point", buttonPoint.status, buttonPoint.img, buttonPoint.title, buttonPoint.x, buttonPoint.y);
+ addButtonWfs("extent", buttonExtent.status, buttonExtent.img, buttonExtent.title, buttonExtent.x, buttonExtent.y);
+ displayButtons();
+function wfsInitFunction (j) {
+ parent.mb_regButton_frame('initWfsButton',frameName,j);
+function initWfsButton(ind, pos) {
+ parent.mb_button[ind] = document.getElementById(buttonWfs_id[pos]);
+ parent.mb_button[ind].img_over = buttonWfs_imgdir + buttonWfs_src[pos].replace(/_off/,"_over");
+ parent.mb_button[ind].img_on = buttonWfs_imgdir + buttonWfs_src[pos].replace(/_off/,"_on");
+ parent.mb_button[ind].img_off = buttonWfs_imgdir + buttonWfs_src[pos];
+ parent.mb_button[ind].status = 0;
+ parent.mb_button[ind].elName = buttonWfs_id[pos];
+ parent.mb_button[ind].frameName = frameName;
+ parent.mb_button[ind].go = new Function ("requestGeometryHighlight.clean();wfsEnable(parent.mb_button["+ind+"], " + pos + ")");
+ parent.mb_button[ind].stop = new Function ("wfsDisable(parent.mb_button["+ind+"], " + pos + ")");
+ var ind = parent.getMapObjIndexByName("mapframe1");
+ mod_wfs_spatialRequest_width = parent.mb_mapObj[ind].width;
+ mod_wfs_spatialRequest_height = parent.mb_mapObj[ind].height;
+ mod_wfs_spatialRequest_epsg = parent.mb_mapObj[ind].epsg;
+ parent.mb_registerPanSubElement("measuring");
+function displayButtons() {
+ for (var i = 0 ; i < buttonWfs_id.length ; i ++) {
+ if (parseInt(buttonWfs_on[i])==1) {
+ var currentImg = document.createElement("img");
+ currentImg.id = buttonWfs_id[i];
+ currentImg.name = buttonWfs_id[i];
+ currentImg.title = buttonWfs_title_off[i];
+ currentImg.src = buttonWfs_imgdir+buttonWfs_src[i];
+ currentImg.style.position = "absolute";
+ currentImg.style.top = buttonWfs_y[i];
+ currentImg.style.left = buttonWfs_x[i];
+ currentImg.onmouseover = new Function("wfsInitFunction("+i+")");
+ document.getElementById("displaySpatialButtons").appendChild(currentImg);
+function disableButtons() {
+ removeChildNodes(document.getElementById("displaySpatialButtons"));
+function wfsEnable(obj) {
+ var el = parent.window.document;
+ el.onmouseover = null;
+ el.onmousedown = null;
+ el.onmouseup = null;
+ el.onmousemove = null;
+ if (obj.id == button_point) {
+ if (activeButton == null) {
+ activeButton = obj;
+ if (obj.id == button_polygon) {
+ else if (obj.id == button_rectangle){
+ else if (obj.id == button_extent){
+ callRequestGeometryConstructor(obj, "mapframe1");
+function wfsDisable(obj) {
+ el.ondblclick = null;
+ parent.writeTag("","measure_display","");
+ parent.writeTag("","measure_sub","");
+ activeButton = null;
+ * Request geometry
+function callRequestGeometryConstructor(pressedButton,target){
+ var selectedType = pressedButton.id;
+ spatialRequestType = selectedType;
+ var geometryConstructor = new parent.RequestGeometryConstructor(target);
+ geometryConstructor.getGeometry(selectedType,function(target,queryGeom){
+ // callback function; called when query geometry has been
+ // constructed by user.
+ if (queryGeom !='') {
+ spatialRequestGeom = queryGeom;
+ // disable the selected button
+ parent.mb_disableThisButton(pressedButton.elName);
+ // spatialRequestGeom is a Geometry, but for the highlight
+ // a MultiGeometry is needed.
+ var multiGeom;
+ // a line represents a bbox...but highlight must be a polyon
+ // (extent or box selection)
+ if (spatialRequestGeom.geomType == parent.geomType.line) {
+ multiGeom = new parent.MultiGeometry(parent.geomType.polygon);
+ newGeom = new parent.Geometry(parent.geomType.polygon);
+ var p1 = spatialRequestGeom.get(0);
+ var p2 = spatialRequestGeom.get(1);
+ newGeom.addPoint(p1);
+ newGeom.addPointByCoordinates(p1.x, p2.y);
+ newGeom.addPoint(p2);
+ newGeom.addPointByCoordinates(p2.x, p1.y);
+ newGeom.close();
+ multiGeom.add(newGeom);
+ // standard case
+ // (polygon and point selection)
+ else {
+ multiGeom = new parent.MultiGeometry(spatialRequestGeom.geomType);
+ multiGeom.add(spatialRequestGeom);
+ // add highlight of geometry
+ requestGeometryHighlight.add(multiGeom);
+ requestGeometryHighlight.paint();
+ // add button for geometry deletion
+ var deleteGeomButton = document.getElementById("deleteRequestGeometry");
+ deleteGeomButton.style.display = "block";
+ deleteGeomButton.onclick = function () {
+ spatialRequestGeom = null;
+ this.style.display = "none";
+ requestGeometryHighlight.clean();
+ * Appends styles to the pre-configured WFS form
+function appendStyles() {
+ var styleObj;
+ var rule = global_wfsConfObj[global_selectedWfsConfId].g_style + global_wfsConfObj[global_selectedWfsConfId].g_res_style;
+ if (parent.ie) {
+ var styleSheetObj=document.createStyleSheet();
+ styleObj=styleSheetObj.owningElement || styleSheetObj.ownerNode;
+ styleObj.setAttribute("type","text/css");
+ ruleArray = rule.split("}");
+ for (var i=0; i < ruleArray.length - 1; i++) {
+ var currentRule = trimString(ruleArray[i]);
+ var nameValueArray = currentRule.split("{");
+ var name = nameValueArray[0];
+ var value = nameValueArray[1];
+ styleSheetObj.addRule(name,value);
+ else {
+ styleObj=document.createElement("style");
+ document.getElementsByTagName("head")[0].appendChild(styleObj);
+ styleObj.appendChild(document.createTextNode(rule+"\n"));
+function isSearchPreconfigured () {
+ //check for configured search elements in wfs conf
+ var wfsConfElementArray = global_wfsConfObj[global_selectedWfsConfId].element;
+ for (var i = 0; i < wfsConfElementArray.length; i++){
+ if (parseInt(wfsConfElementArray[i].f_search)) {
+ return true;
+ //check for stored query elements in wfs conf
+ var storedQueryElementArray = global_wfsConfObj[global_selectedWfsConfId].storedQueryElement;
+ if(storedQueryElementArray) {
+ return true;
+ return false;
+function appendWfsForm() {
+ var form = document.getElementById("wfsForm");
+ removeChildNodes(form);
+ if(!isSearchPreconfigured()){
+ * Appends the WFS editor
+ document.getElementById("mainDiv").style.display = "block";
+ fillLeftList();
+ else{
+ * Appends the pre-configured WFS form
+ var divContainer = document.createElement("div");
+ divContainer.className = global_wfsConfObj[global_selectedWfsConfId].g_label_id;
+ divContainer.innerHTML = global_wfsConfObj[global_selectedWfsConfId].g_label;
+ form.appendChild(divContainer);
+ var spanNode = document.createElement("span");
+ spanNode.setAttribute("id", "ttttt");
+ spanNode.className = wfsConfElementArray[i].f_label_id;
+ spanNode.innerHTML = wfsConfElementArray[i].f_label;
+ if (wfsConfElementArray[i].f_form_element_html && wfsConfElementArray[i].f_form_element_html.length > 0) {
+ var inputNode = document.createElement("span");
+ inputNode.innerHTML = wfsConfElementArray[i].f_form_element_html;
+ } else {
+ var inputNode = document.createElement("input");
+ inputNode.type = "text";
+ inputNode.className = wfsConfElementArray[i].f_style_id;
+ inputNode.id = wfsConfElementArray[i].element_name;
+ if(wfsConfElementArray[i].f_helptext && wfsConfElementArray[i].f_helptext.length > 0) {
+ var helptextNode = document.createElement('span');
+ var helptextDisplay = document.createElement('div');
+ helptextDisplay.id = 'helptext' + i;
+ helptextDisplay.className = 'helptext';
+ var helptext = document.createElement('p');
+ helptext.innerHTML = wfsConfElementArray[i].f_helptext.replace(/(http:\/\/\S*)/g,'<a href="$1" target="blank">$1<\/a>');
+ helptext.innerHTML += '<a href="#" class="close" onclick="hideHelptext(' + i + ')">close</a>';
+ helptextDisplay.appendChild(helptext);
+ helptextNode.innerHTML = ' <a href="#" onclick="showHelptext(' + i + ')"><img src="../img/help.png" width="16" height="16" alt="?" /></a> ';
+ form.appendChild(spanNode);
+ form.appendChild(inputNode);
+ if(wfsConfElementArray[i].f_helptext.length > 0) { form.appendChild(helptextNode); }
+ if(wfsConfElementArray[i].f_helptext.length > 0) { form.appendChild(helptextDisplay); }
+ form.appendChild(document.createElement("br"));
+ //add stored query elements
+ for (var i = 0; i < storedQueryElementArray.length; i++){
+ spanNode.setAttribute("id", storedQueryElementArray[i].name+"Span");
+ spanNode.innerHTML = storedQueryElementArray[i].name;
+ inputNode.id = storedQueryElementArray[i].name;
+ var submitButton = document.createElement("input");
+ submitButton.type = "submit";
+ submitButton.id = "wfsForm_Submit";
+ submitButton.className = global_wfsConfObj[global_selectedWfsConfId].g_button_id;
+ submitButton.value = global_wfsConfObj[global_selectedWfsConfId].g_button;
+ form.appendChild(submitButton);
+ checkSrs();
+function checkSrs(){
+ //check SRS
+ var submit = document.getElementById("wfsForm_Submit");
+ var submit_attr = document.getElementById("attrPanel_Submit");
+ var epsgCode = parent.mb_mapObj[ind].getSRS().toUpperCase();
+ var epsgString = parent.mb_mapObj[ind].getSRS();
+ //check for "http://www.opengis.net/gml/srs/epsg.xml#4326"
+ if (epsgString.search("http://www.opengis.net/gml/srs/epsg.xml") !== -1) {
+ var epsgCodeSplit = epsgCode.split("#");
+ } else {
+ var epsgCodeSplit = epsgCode.split(":");
+ var epsgString = epsgCodeSplit[1];
+ var ftSrs = global_wfsConfObj[global_selectedWfsConfId].featuretype_srs;
+ if (ftSrs.search("http://www.opengis.net/gml/srs/epsg.xml") !== -1) {
+ var ftSrsSplit = ftSrs.split("#");
+ } else {
+ var ftSrsSplit = ftSrs.split(":");
+ if(ftSrsSplit.length > 2) {
+ if(ftSrsSplit.length == 6) {
+ var checkVal = ftSrsSplit[5];
+ else {
+ var checkVal = ftSrsSplit[6];
+ else {
+ var checkVal = ftSrsSplit[1];
+ //return true if usage of crs should be forced!
+ if (global_forceCrsFromMap == 1) {
+ if(submit)submit.disabled = false;
+ return true;
+ //if default featuretype_srs does not match current mapObj srs, check for other srs
+ if(checkVal != epsgString) {
+ //check if other featuretype_srs matches current mapObj srs
+ var otherSrs = global_wfsConfObj[global_selectedWfsConfId].featuretype_other_srs;
+ if(otherSrs.length == 0) {
+ viewerEpsgId = parent.mb_mapObj[ind].getSRS().split(":");
+ viewerEpsgId = viewerEpsgId.slice(-1)[0];
+ viewerEpsgIdLink = "<a style=\"color:#808040; text-decoration:underline;\" target=\"_blank\" href=\"http://spatialreference.org/ref/epsg/"+viewerEpsgId+"/\">"+parent.mb_mapObj[ind].getSRS()+"</a>";
+ var msg = "<?php echo _mb("The coordinate reference system (crs) of the objects differ from the crs of the viewer"); ?>"+" ("+viewerEpsgIdLink+"). "+"<?php echo _mb("A query will not be possible."); ?>\n";
+ epsgId = global_wfsConfObj[global_selectedWfsConfId].featuretype_srs.split(":");
+ epsgId = epsgId.slice(-1)[0];
+ epsgIdLink = "<a style=\"color:#808040; text-decoration:underline;\" target=\"_blank\" href=\"http://spatialreference.org/ref/epsg/"+epsgId+"/\">"+global_wfsConfObj[global_selectedWfsConfId].featuretype_srs+"</a>";
+ msg += "<?php echo _mb("Please switch viewer crs to"); ?> " + " " + epsgIdLink;
+ srsErrorPopup = parent.$("<div><p>"+ msg +"</p></div>").dialog({
+ title: "<?php echo _mb("CRS Error"); ?>",
+ width:500,
+ height: 150,
+ modal: true
+ srsErrorPopup.dialog('open');
+ //disable Submit Button
+ if(submit)submit.disabled = true;
+ if(submit_attr)submit_attr.disabled = true;
+ return false;
+ else {
+ var epsgMatched = false;
+ var msgEpsgString = "";
+ for (var i = 0; i < otherSrs.length; i++) {
+ var ftOtherSrs = otherSrs[i].epsg;
+ var ftOtherSrsSplit = ftOtherSrs.split(":");
+ if(ftOtherSrsSplit.length > 2) {
+ if(ftOtherSrsSplit.length == 6) {
+ var checkVal = ftOtherSrsSplit[5];
+ else {
+ var checkVal = ftOtherSrsSplit[6];
+ else {
+ var checkVal = ftOtherSrsSplit[1];
+ if(checkVal == epsgString) {
+ epsgMatched = true;
+ break;
+ if(i > 0) {
+ msgEpsgString += ", ";
+ msgEpsgString += ftOtherSrs;
+ if(epsgMatched) {
+ if(submit_attr)submit_attr.disabled = false;
+ var msg = '<?php echo _mb("Please note: Wfs featuretype is not requested in default srs, other srs is used (variation of transformation possible)! ");?>';
+ alert(msg);
+ return true;
+ else {
+ var msg = '<?php echo _mb("Please note: Different EPSG of map and wfs featuretype, no spatial request in gazetterWFS possible! ");?>';
+ msg += parent.mb_mapObj[ind].getSRS() + " - " + msgEpsgString + ". ";
+ msg += '<?php echo _mb("No EPSG for wfs featuretype matches the map EPSG!");?>';
+ alert(msg);
+ return false;
+ //if default featuretype_srs matches current mapObj srs, allow search
+ else {
+ return true;
+//------------------------------------------------- start Editor functions
+function fillLeftList() {
+ deleteSelectOptions(document.attrPanel.leftList);
+ deleteSelectOptions(document.attrPanel.rightList);
+ deleteFilterText();
+ var wfsConf = global_wfsConfObj[global_selectedWfsConfId];
+ for (var i = 0 ; i < wfsConf.element.length ; i++) {
+ // do not include geometry column
+ if (wfsConf.element[i].f_geom != 1) {
+ var lLOption = document.createElement("option");
+ lLOption.id = "lLOPtion"+i+"_"+wfsConf.element[i].element_type;
+ lLOption.value = i;
+ lLOption.innerHTML = wfsConf.element[i].element_name;
+ document.getElementById("leftList").appendChild(lLOption);
+ function fillRightList() {
+ var chosenLayer = global_wfsConfObj[global_selectedWfsConfId].featuretype_name;
+ var layerAttr=document.getElementById("leftList");
+ var chosenAttr =layerAttr.options[layerAttr.selectedIndex].text;
+ var wfs_getfeature = global_wfsConfObj[global_selectedWfsConfId].wfs_getfeature;
+ document.getElementById("progressWheel").innerHTML = "<table><tr><td><img src='../img/indicator_wheel.gif'></td><td>Get features...</td></tr></table>";
+ var properties = {"command":"getFeature", "wfsFeatureTypeName":chosenLayer, "wfsGetFeatureAttr":chosenAttr, "wfsGetFeature":wfs_getfeature,"wfs_conf_id":global_selectedWfsConfId,"destSrs":global_wfsConfObj[global_selectedWfsConfId].featuretype_srs};
+ parent.$.post("../javascripts/mod_wfsGazetteerEditor_server.php", properties, function (result, status) {
+ if (status == "success") {
+ var arrFeatureColumnValues = eval('(' + result + ')');
+ var i = 0;
+ for( var i=0; i<arrFeatureColumnValues.length; i++){
+ removeChildNodes(document.getElementById("progressWheel"));
+ if(arrFeatureColumnValues[i]!=''){
+ var rLOption = document.createElement("option");
+ rLOption.id = "rLOption"+i;
+ rLOption.value = i;
+ rLOption.innerHTML = arrFeatureColumnValues[i];
+ document.getElementById("rightList").appendChild(rLOption);
+ * writeLeftValueInString()
+ * @param {}
+ * Doppelklick auf Listeneintrag (Links) => Listenwert wir in Textarea geschrieben
+function writeLeftValueInString(){
+ var chosenAttr = layerAttr.options[layerAttr.selectedIndex].text;
+ if(layerAttr.options[layerAttr.selectedIndex].id.match("int") || layerAttr.options[layerAttr.selectedIndex].id.match("float")){
+ controlOperators("int");
+ else if(layerAttr.options[layerAttr.selectedIndex].id.match("string")){
+ controlOperators("string");
+ else if(layerAttr.options[layerAttr.selectedIndex].id.match("date")){
+ controlOperators("date");
+ else{
+ controlOperators("all");
+ var attrTxt = "[" + chosenAttr + "]";
+ insertAtCursor(document.attrPanel.attrRequestText, attrTxt);
+function hideOperators(){
+ document.getElementById('greaterThan').style.visibility = "hidden";
+ document.getElementById('lessThan').style.visibility = "hidden";
+ document.getElementById('lessThanOrEqualTo').style.visibility = "hidden";
+ document.getElementById('greaterThanOrEqualTo').style.visibility = "hidden";
+ document.getElementById('and').style.visibility = "hidden";
+ document.getElementById('like').style.visibility = "hidden";
+ document.getElementById('equal').style.visibility = "hidden";
+ document.getElementById('notEqual').style.visibility = "hidden";
+function controlOperators(opType){
+ document.getElementById('greaterThan').style.visibility = "visible";
+ document.getElementById('lessThan').style.visibility = "visible";
+ document.getElementById('lessThanOrEqualTo').style.visibility = "visible";
+ document.getElementById('greaterThanOrEqualTo').style.visibility = "visible";
+ document.getElementById('and').style.visibility = "visible";
+ document.getElementById('like').style.visibility = "visible";
+ document.getElementById('equal').style.visibility = "visible";
+ document.getElementById('notEqual').style.visibility = "visible";
+ if(opType=='int'){
+ else if(opType=='string'){
+ else if(opType=='date'){
+ // do something
+ else{
+ // do something
+ * writeRightValueInString()
+ * @param {}
+ * Doppelklick auf Listeneintrag (Rechts) => Listenwert wir in Textarea geschrieben
+function writeRightValueInString(){
+ var chosenVal =document.getElementById("rightList").options[document.getElementById("rightList").selectedIndex].text;
+ insertAtCursor(document.attrPanel.attrRequestText,chosenVal);
+* insertOperator
+* @param {type} param
+ function insertOperator(value) {
+ var wert = value;
+ insertAtCursor(document.attrPanel.attrRequestText, wert);
+ * insertAtCursor
+ * @param {Textfeld, String} param
+ * Fuegt an die Cursorstelle einen Text(String) ein
+function insertAtCursor(myField, myValue) {
+//IE support
+ if (document.selection) {
+ myField.focus();
+ sel = document.selection.createRange();
+ sel.text = myValue;
+//MOZILLA/NETSCAPE support
+ else if (myField.selectionStart || myField.selectionStart == '0') {
+ var startPos = myField.selectionStart;
+ var endPos = myField.selectionEnd;
+ myField.value = myField.value.substring(0, startPos)
+ + myValue
+ + myField.value.substring(endPos, myField.value.length);
+ } else {
+ myField.value += myValue;
+ * deleteSelectOptions()
+ * @param {}
+function deleteSelectOptions(field){
+ var numOfOpt = field.length;
+ for (i=0; i <numOfOpt; i++){
+ field.options[field.length-1] = null;
+ * deleteFilterText()
+ * @param {type}
+ * Button loescht Eintrag im Textfeld (attrRequestText)
+ function deleteFilterText() {
+ document.attrPanel.attrRequestText.value="";
+function createWfsFilter (srs, latLonSrsJson) {
+ var wfsFilter = new WfsFilter();
+ * Add filter from WFS editor
+ if (!isSearchPreconfigured()) {
+ var filter = document.attrPanel.attrRequestText.value;
+ if (!wfsFilter.parse(filter)) {
+ alert("Keine gültige Filterbedingung gesetzt.");
+ return false;
+ * Add filter from pre configured searches
+ var filterParameterCount = getNumberOfFilterParameters();
+ var el = global_wfsConfObj[global_selectedWfsConfId].element;
+ if (filterParameterCount != 0) {
+ for (var i = 0; i < el.length; i++) {
+ if (el[i]['f_search'] == 1) {
+ var a = document.getElementById(el[i]['element_name']).value.split(",");
+ wfsFilter.addPreConfigured(el[i]['element_name'], a, el[i]['f_toupper'], el[i]['f_operator']);
+ * Add filter from request geometry
+ if (spatialRequestGeom != null) {
+ // get geometry column name
+ var geometryColumnName = "";
+ for (var j = 0; j < el.length; j++) {
+ if (el[j].f_geom == 1) {
+ geometryColumnName = el[j].element_name;
+ // get filter option
+ var filterOption = "";
+ var selectedButton;
+ if (spatialRequestGeom.geomType == parent.geomType.polygon) {
+ selectedButton = buttonPolygon;
+ else
+ selectedButton = buttonRectangle;
+ if (selectedButton.filteroption == 'within') {
+ filterOption = "Within";
+ else
+ if (selectedButton.filteroption == 'intersects') {
+ filterOption = "Intersects";
+ // add spatial filter
+ wfsFilter.addSpatial(spatialRequestGeom, geometryColumnName, filterOption, srs, "", latLonSrsJson);
+ return wfsFilter.toString();
+ * The filter is calculated from the WFS editor or the pre-comfigured
+ * search form, with optional request geometry
+ function makeRequest() {
+ // hide the result and detail popup
+ if (typeof(resultGeometryPopup) != "undefined") {
+ resultGeometryPopup.dialog('close');
+ if (typeof(wfsPopup) != "undefined") {
+ wfsPopup.dialog('close');
+ // empty the result geometry
+// geomArray not used any more
+// if(geomArray != null && geomArray.count()>0){
+// geomArray.empty();
+ // set the Highlight object for the result geometry
+ global_resultHighlight = new parent.Highlight(targetArray, "wfsGazetteerEditorHighlight", styleProperties, 2);
+ * Send WFS request
+ document.getElementById("progressWheel").innerHTML = "<table><tr><td><img src='../img/indicator_wheel.gif'></td></tr></table>";
+ var exportToShape = document.getElementById("exportToShape").checked;
+ //for storedQueryId take the first array element's storedQueryId
+ var storedQueryId = storedQueryElementArray[0].storedQueryId;
+ var storedQueryParams = "";
+ var queryParamName = storedQueryElementArray[i].name;
+ var queryParamValue = document.getElementById(storedQueryElementArray[i].name).value;
+ storedQueryParams += "<wfs:Parameter name=\"" + queryParamName + "\">" + queryParamValue + "</wfs:Parameter>";
+ var srs = parent.mb_mapObj[ind].getSRS();
+ else {
+ else {
+ srs = ftSrs;
+ else {
+ if(otherSrs.length > 0) {
+ else {
+ else {
+ srs = ftOtherSrs;
+ break;
+ var parameters = {
+ "command" : "getSearchResults",
+ "wfs_conf_id" : global_selectedWfsConfId,
+ "typename" : global_wfsConfObj[global_selectedWfsConfId].featuretype_name,
+ "frame" : this.name,
+ "filter" : createWfsFilter(srs, latLonSrsJson),
+ "backlink" : "",
+ "exportToShape":exportToShape,
+ "destSrs" : srs,
+ "storedQueryParams" : storedQueryParams,
+ "storedQueryId" : storedQueryId
+ parent.mb_ajax_get("../javascripts/mod_wfsGazetteerEditor_server.php", parameters, function (jsCode, status) {
+ if(status=='success'){
+ for (var i=0; i < parent.wms.length; i++) {
+ for (var j=0; j < parent.wms[i].objLayer.length; j++) {
+ var currentLayer = parent.wms[i].objLayer[j];
+ var wms_id = parent.wms[i].wms_id;
+ if (currentLayer.gui_layer_wfs_featuretype == global_selectedWfsConfId) {
+ var layer_name = currentLayer.layer_name;
+ parent.handleSelectedLayer_array(targetArray[0],[wms_id],[layer_name],'querylayer',1);
+ parent.handleSelectedLayer_array(targetArray[0],[wms_id],[layer_name],'visible',1);
+ var geoObj = jsCode; //eval('(' + jsCode + ')');
+ if (!exportToShape) {
+ if (jsCode) {
+ if (typeof(geoObj) == 'object') {
+ displayPopup(geoObj);
+ else {
+ displayPopup();
+ else {
+ alert("<?php echo _mb("No result"); ?>");
+ else {
+ if (geoObj) {
+ var downloadZipFunction = function () {
+ parent.window.frames['loadData'].location.href = geoObj.filename;
+ //if($.browser.msie && $.browser.version === '6.0') {
+ // setTimeout(downloadZipFunction, 3000);
+ //else {
+ downloadZipFunction();
+ else {
+ alert("<?php echo _mb("An error occured when start download."); ?>");
+ document.getElementById("progressWheel").innerHTML = "";
+ else{
+ if(inputNotEnough.length==0){
+ if (jsCode) {
+ else {
+ displayPopup();
+ else {
+ alert("Kein Ergebnis.");
+ else {
+ if (geoObj) {
+ //else {
+ else{
+ return false;
+ return false;
+function getListTitle(geom){
+ var resultObj = {};
+ var currentElement = wfsConf.element[i];
+ if (currentElement.f_show == 1 && geom.e.getElementValueByName(currentElement.element_name) != false) {
+ var pos = currentElement.f_respos;
+ if (pos > 0) {
+ resultObj[pos] = geom.e.getElementValueByName(currentElement.element_name);
+ return resultObj;
+function createListOfGeometries(){
+ var listOfGeom = "<table style='background-color:#EEEEEE;'>\n";
+ if (geomArray != null && geomArray.count() > 0) {
+ for (var i = 0 ; i < geomArray.count(); i ++) {
+ if (geomArray.get(i).get(-1).isComplete()) {
+ listOfGeom += "\t<tr>\n\t\t ";
+ var resultElObj = getListTitle(geomArray.get(i));
+ for (var wfsConfEl in resultElObj) {
+ if(resultElObj[wfsConfEl]!=''){
+ listOfGeom += "<td style='cursor:pointer;\n";
+ if ((i % 2) === 0) {
+ listOfGeom += "color:black'";
+ else {
+ listOfGeom += "\t\t\t onmouseover=\"window.frames['"+frameName+"'].setResult('over',"+i+")\" ";
+ listOfGeom += " onmouseout=\"window.frames['"+frameName+"'].setResult('out',"+i+")\" ";
+ listOfGeom += " onclick=\"window.frames['"+frameName+"'].setResult('click',"+i+"); window.frames['"+frameName+"'].showWfs("+i+");\" ";
+ listOfGeom += ">"+ resultElObj[wfsConfEl] +"</td>";
+ listOfGeom += "\t\t</tr>\n";
+ listOfGeom += "</table>\n";
+ return listOfGeom;
+function displayPopup(geom){
+ geomArray = geom;
+ if(!parent.$("#resultList")){
+ return;
+ var resultList = parent.$('#resultList').mapbender();
+ resultList.clear();
+ resultList.setTitle(global_wfsConfObj[global_selectedWfsConfId].wfs_conf_abstract);
+ resultList.setWFSconf(global_wfsConfObj[global_selectedWfsConfId]);
+ resultList.addFeatureCollection(geom);
+ resultList.show();
+ return;
+ var contentHtml = "<?php echo _mb("No result"); ?>";
+ if (geomArray != null && geomArray.count() > 0){
+ contentHtml = createListOfGeometries();
+ if (typeof(resultGeometryPopup) == "undefined") {
+ resultGeometryPopup = parent.$("<div>"+ contentHtml +"</div>").dialog({
+ title: searchPopupTitle,
+ width:searchPopupWidth,
+ height: searchPopupHeight,
+ position: [ searchPopupX,searchPopupY],
+ onclose: function(){
+ resultList.hide();
+ else {
+ resultGeometryPopup.html(contentHtml);
+ resultGeometryPopup.dialog('open');
+function showWfs(geometryIndex) {
+ var wfsElement = geomArray.get(geometryIndex).e;
+ var resultHtml = "";
+ resultHtml += "<table style='background-color:#EEEEEE;'>\n";
+ var details = 0;
+ for (var i = 0 ; i <wfsConf.element.length; i ++) {
+ if(wfsConf.element[i].f_show_detail == 1){
+ resultHtml +="<tr><td>\n";
+ resultHtml += wfsConf.element[i].element_name;
+ resultHtml +="</td>\n";
+ resultHtml += "<td>\n";
+ var elementVal = wfsElement.getElementValueByName(wfsConf.element[i].element_name);
+ resultHtml += elementVal;
+ resultHtml += "</td></tr>\n";
+ details = 1;
+// if(details != 1){
+// resultHtml +="<tr><td><?php echo _mb("No information available."); ?></td></tr>\n";
+ resultHtml += "</table>\n";
+ if(details == 1){
+ if (typeof(wfsPopup) == "undefined") {
+ wfsPopup = parent.$("<div>"+resultHtml+"</div>").dialog({
+ title: detailPopupTitle,
+ width: detailPopupWidth,
+ height: detailPopupWidth,
+ position: [detailPopupX,detailPopupY]
+ else {
+ wfsPopup.html(resultHtml);
+ wfsPopup.dialog('open');
+//------------------------------------------------- end Editor functions
+function getNumberOfFilterParameters(){
+ var cnt = 0;
+ inputNotEnough = [];
+ for (var i = 0; i < el.length; i++){
+ if( el[i]['f_search'] == 1){
+ if (document.getElementById(el[i]['element_name']).value != '') {
+ cnt++;
+ if(document.getElementById(el[i]['element_name']).value.length < el[i]['f_min_input']){
+ inputNotEnough.push(el[i]['element_name']+"("+el[i]['f_min_input']+")");
+ //check if there are stored query elements for search
+ var elementValue = document.getElementById(storedQueryElementArray[i].name).value;
+ if (elementValue != '') {
+ cnt++;
+ if(inputNotEnough.length>0){
+ alert("Pflichtfelder: "+inputNotEnough.join(', '));
+ return false;
+ return cnt;
+* event -> {over || out || click}
+* geom -> commaseparated coordinates x1,y1,x2,y2 ...
+function setResult(event, index){
+ var currentGeom = geomArray.get(index);
+ if (maxHighlightedPoints > 0 && currentGeom.getTotalPointCount() > maxHighlightedPoints) {
+ currentGeom = currentGeom.getBBox4();
+ if (event == "over") {
+ global_resultHighlight.add(currentGeom, cw_fillcolor);
+ global_resultHighlight.paint();
+ else if (event == "out"){
+ global_resultHighlight.del(currentGeom, cw_fillcolor);
+ else if (event == "click"){
+ var bbox = currentGeom.getBBox();
+ var bufferFloat = parseFloat(global_wfsConfObj[global_selectedWfsConfId].g_buffer);
+ var buffer = new parent.Point(bufferFloat,bufferFloat);
+ bbox[0] = bbox[0].minus(buffer);
+ bbox[1] = bbox[1].plus(buffer);
+ parent.mb_calculateExtent(targetArray[0], bbox[0].x, bbox[0].y, bbox[1].x, bbox[1].y);
+ parent.zoom(targetArray[0], 'true', 1.0);
+ return true;
+</script>
+</head>
+<body leftmargin='0' topmargin='10' bgcolor='#ffffff' onload='frameIsReady()'> <!-- onload='initModWfsGazetteer();init_wfsSpatialRequest();' -->
+ <!-- WFS conf info -->
+ <!--<img src = "" name='wfsPreConfiguredOrEditor' id='wfsPreConfiguredOrEditor' style='display:none'>
+ <img src = "" name='wfsGeomType' id='wfsGeomType' style='display:none'>-->
+ <a name='wfsInfo' title='<?php echo _mb("Show information"); ?>' id='wfsInfo' style='display:none'></a><form name='attrPanel' id='attrPanel' onsubmit='return makeRequest();'>
+ <div class='mainDiv' id='mainDiv' style="display:none">
+ <b><?php echo _mb("Set spatial filter"); ?></b><br>
+ <div name='displaySpatialButtons' id='displaySpatialButtons' style='width:180px'></div>
+ <input type="button" id="deleteRequestGeometry" name="deleteRequestGeometry" value="löschen" style="position:absolute;top:70px;left:120px;display:none">
+ <br><br>
+ <b><?php echo _mb("Set attribute filter"); ?></b>
+ <table>
+ <tr valign='top'>
+ <td width='30%'> </td><td width='35%'> </td><td width='35%' style='font-size:12px;'><?php echo _mb("Examples (first 20 entries):"); ?></td>
+ </tr>
+ <tr valign='top'>
+ <td width='30%'>
+ <select name='leftList' id='leftList' onChange='fillRightList();' onDblClick='writeLeftValueInString();' size='8' style='width:120px;'></select>
+ </td>
+ <td width='35%'>
+ <input id='greaterThan' class='op' onClick='insertOperator(value);' type='button' value='>>' name='op1'>
+ <input id='greaterThanOrEqualTo' class='op' onClick='insertOperator(value);' type='button' value='>=' name='op2'><br>
+ <input id='lessThan' class='op' onClick='insertOperator(value);' type='button' value='<<' name='op3'>
+ <input id='lessThanOrEqualTo' class='op' onClick='insertOperator(value);' type='button' value='<=' name='op4'><br>
+ <input id='equal' class='op' onClick='insertOperator(value);' type='button' value='==' name='op5'>
+ <input id='notEqual' class='op' onClick='insertOperator(value);' type='button' value='<>' name='op6'><br>
+ <input id='like' class='op' onClick='insertOperator(value);' type='button' value=' LIKE ' name='op7'>
+ <input id='and' class='op' onClick='insertOperator(value);' type='button' value=' AND ' name='op8'><br>
+ </td>
+ <td width='35%'>
+ <select name='rightList' id='rightList' onDblClick='writeRightValueInString();' size='8' style='width:120px;'>
+ </select>
+ </td>
+ </tr>
+ </table>
+ <br>
+ <table>
+ <tr>
+ <td style='width:80%;height:40' colspan=4>
+ <textarea cols='48' rows='5' name='attrRequestText' id='attrRequestText' ></textarea>
+ </td>
+ </tr>
+ <tr >
+ <td>
+ <input type='submit' id='attrPanel_Submit' value='<?php echo _mb("Start query"); ?>'>
+ </td>
+ <td>
+ <input onClick='deleteFilterText();' type='button' value='<?php echo _mb("Reset filter"); ?>'>
+ </td>
+ <td>
+ <div name='displayCheckbox' id='displayCheckbox' style='width:180px'>
+ <input type='checkbox' name='exportToShape' id='exportToShape'><?php echo _mb("Export data"); ?>
+ </div>
+ </td>
+ </tr>
+ </table>
+ </div>
+</form>
+<form name='wfsForm' id='wfsForm' onsubmit='return makeRequest()'></form>
+<div name='progressWheel' id='progressWheel'></div>
+</body>
+</html>
More information about the Mapbender_commits
