[Mapbender-commits] r10250 - trunk/mapbender/http/plugins
    svn_mapbender at osgeo.org
    Fri Sep 13 04:58:04 PDT 2019
Author: armin11
Date: 2019-09-13 04:58:04 -0700 (Fri, 13 Sep 2019)
New Revision: 10250
   trunk/mapbender/http/plugins/kmlTree.php
New options to build nicer guis ;-) - thanx to karl owesny
Modified: trunk/mapbender/http/plugins/kmlTree.php
--- trunk/mapbender/http/plugins/kmlTree.php	2019-09-13 11:50:41 UTC (rev 10249)
+++ trunk/mapbender/http/plugins/kmlTree.php	2019-09-13 11:58:04 UTC (rev 10250)
@@ -329,7 +329,7 @@
                                                 isPublic = data;
                                                 if (isPublic == 1){
-                        							alert('To publicate a WMC is not allowed for the Guest-User!'+
+                        							alert('The Guest-User is not allowed to publish a WMC!'+
                         							      'If you want to use this function, please create an account.');
                         							return false;
@@ -871,6 +871,48 @@
         return data;
+    //  'area', 'boundary-length', 'track-length'
+    var featureInfoFilter = ['title', 'marker-size', 'marker-symbol', 'marker-color',
+        'marker-offset-x', 'marker-offset-y', 'stroke', 'stroke-opacity',
+        'stroke-width', 'fill', 'fill-opacity'];
+    function escapeHTML(text) {
+        return text
+                .toString()
+		.replace(/&/g, '&')
+                .replace(/</g, '<')
+                .replace(/>/g, '>')
+                .replace(/"/g, '"')
+                .replace(/'/g, ''')
+                .replace(/\//g, '/');
+    function createFeatureInfoContent(props) {
+        var $table = $("<table>")
+                .attr("border", 1);
+        for (var key in props) {
+            if (props.hasOwnProperty(key) && featureInfoFilter.indexOf(key) < 0) {
+                $table
+                    .append($("<tr>")
+                        .append($("<td>").html(escapeHTML(key)))
+                        .append($("<td>").html(escapeHTML(props[key]))))
+        return $table.attr('outerHTML');
+    this.getFeatureInfos = function (click) {
+        var map = Mapbender.modules.mapframe1;
+        var kml = $('#mapframe1').data('kml');
+        return kml.findFeaturesAtClick(click)
+            .map(function (locator) {
+                var kmlLayer = map.kmls[locator.url];
+                return {
+                    title: kmlLayer.data.title,
+                    content: createFeatureInfoContent(kmlLayer.data.features[locator.id].properties)
 Mapbender.events.init.register(function() {
More information about the Mapbender_commits
