[Mapbender-commits] r10260 - in trunk/mapbender: conf http/classes http/php lib resources/db/pgsql/UTF-8/update
svn_mapbender at osgeo.org
Tue Sep 17 07:39:24 PDT 2019
Author: armin11
Date: 2019-09-17 07:39:24 -0700 (Tue, 17 Sep 2019)
New Revision: 10260
trunk/mapbender/conf/mapbender.conf-dist
trunk/mapbender/http/classes/class_user.php
trunk/mapbender/http/php/mod_editFilteredUser.php
trunk/mapbender/http/php/mod_editUser.php
trunk/mapbender/lib/editUser.php
trunk/mapbender/resources/db/pgsql/UTF-8/update/update_2.8_pgsql_UTF-8.sql
Some enhancement to define a preferred_gui for a user - they may choose from a list of available and accessable guis
Modified: trunk/mapbender/conf/mapbender.conf-dist
--- trunk/mapbender/conf/mapbender.conf-dist 2019-09-17 14:02:32 UTC (rev 10259)
+++ trunk/mapbender/conf/mapbender.conf-dist 2019-09-17 14:39:24 UTC (rev 10260)
@@ -284,6 +284,11 @@
#define("PUBLIC_USER_DEFAULT_GUI", "Geoportal-RLP");
+# define category for applications (guis) that are choosable by users as preferred gui
+#define("PREFERRED_GUI_CATEGORY", 2);
# set the default srs for the PUBLIC_USER in the SESSION
#define("PUBLIC_USER_DEFAULT_SRS", "EPSG:25832");
Modified: trunk/mapbender/http/classes/class_user.php
--- trunk/mapbender/http/classes/class_user.php 2019-09-17 14:02:32 UTC (rev 10259)
+++ trunk/mapbender/http/classes/class_user.php 2019-09-17 14:39:24 UTC (rev 10260)
@@ -51,6 +51,7 @@
var $isActive = 'f';
var $createDigest = 'f';
+var $preferredGui = '';
static $displayName = "User";
static $internalName = "user";
@@ -152,7 +153,8 @@
"academicTitle" => $this->academicTitle,
"activationKey" => $this->activationKey,
"isActive" => $this->isActive,
- "createDigest" => $this->createDigest
+ "createDigest" => $this->createDigest,
+ "preferredGui" => $this->preferredGui
return $result;
@@ -254,6 +256,7 @@
$this->activationKey = isset($changes->activationKey) ? $changes->activationKey : $this->activationKey;
$this->isActive = isset($changes->isActive) ? $changes->isActive : $this->isActive;
$this->createDigest = isset($changes->createDigest) ? $changes->createDigest : $this->createDigest;
+ $this->preferredGui = isset($changes->preferredGui) ? $changes->preferredGui : $this->preferredGui;
return true;
@@ -290,8 +293,9 @@
"mb_user_login_count = $28, " .
"activation_key = $29, " .
"is_active = $30, " .
- "create_digest = $31 " .
- "WHERE mb_user_id = $32;";
+ "create_digest = $31, " .
+ "fkey_preferred_gui_id = $32 " .
+ "WHERE mb_user_id = $33;";
if ($this->isActive !== 't') {$this->isActive = 'f';}
if ($this->createDigest !== 't') {$this->createDigest = 'f';}
@@ -328,6 +332,7 @@
$this->activationKey !== "" ? $this->activationKey : null,
$this->isActive,
+ $this->preferredGui,
is_numeric($this->id) ? intval($this->id) : null,
@@ -337,7 +342,7 @@
"s", "s", "s", "i", "s",
"s", "s", "s", "s", "s",
- "s", "s", "i", "s", "b", "b", "i"
+ "s", "s", "i", "s", "b", "b", "s", "i"
$update_result = db_prep_query($sql_update,$v,$t);
@@ -418,6 +423,7 @@
$this->firstName = $row["mb_user_firstname"];
$this->lastName = $row["mb_user_lastname"];
$this->academicTitle = $row["mb_user_academictitle"];
+ $this->preferredGui = $row["fkey_preferred_gui_id"];
else {
throw new Exception("no such User");
@@ -869,10 +875,11 @@
* Returns an array of application IDs that the user is allowed to access.
* @return Array an array of application IDs
- * @param $ignorepublic boolean whether or not to ignore
- * public applications (?)
+ * @param $ignorePublic boolean whether or not to ignore
+ * public applications (?)
+ * @param $categoryFilter false or id of category to filter guis - only return those guis, that are in that category
- public function getApplicationsByPermission ($ignorepublic = false) {
+ public function getApplicationsByPermission ($ignorePublic = false, $categoryFilter = false) {
$mb_user_id = $this->id;
$arrayGuis = array();
$mb_user_groups = array();
@@ -900,21 +907,34 @@
$sql_g .= "$".strval($i+1);
array_push($v,$mb_user_groups[$i]);
array_push($t,"i");
+ $numberOfGroups = $i;
$sql_g .= ") GROUP BY gui.gui_id";
+ if ($categoryFilter != false) {
+ $sql_g = "SELECT fkey_gui_id as gui_id from gui_gui_category as gui_id WHERE fkey_gui_id IN "."(".$sql_g.") AND fkey_gui_category_id = $".strval($numberOfGroups+2);
+ array_push($v, $categoryFilter);
+ array_push($t, "i");
$res_g = db_prep_query($sql_g,$v,$t);
while($row = db_fetch_array($res_g)){
array_push($arrayGuis,$row["gui_id"]);
$sql_guis = "SELECT gui.gui_id FROM gui JOIN gui_mb_user ON gui.gui_id = gui_mb_user.fkey_gui_id";
$sql_guis .= " WHERE (gui_mb_user.fkey_mb_user_id = $1) ";
- if (!isset($ignore_public) OR $ignore_public== false){
+ if (!isset($ignorePublic) OR $ignorePublic== false){
$sql_guis .= " AND gui.gui_public = 1 ";
$sql_guis .= " GROUP BY gui.gui_id";
- $v = array($mb_user_id);
+ $v = array($mb_user_id);
$t = array("i");
+ $sql_guis = "SELECT fkey_gui_id as gui_id from gui_gui_category as gui_id WHERE fkey_gui_id IN "."(".$sql_guis.") AND fkey_gui_category_id = $2";
$res_guis = db_prep_query($sql_guis,$v,$t);
$guis = array();
while($row = db_fetch_array($res_guis)){
Modified: trunk/mapbender/http/php/mod_editFilteredUser.php
--- trunk/mapbender/http/php/mod_editFilteredUser.php 2019-09-17 14:02:32 UTC (rev 10259)
+++ trunk/mapbender/http/php/mod_editFilteredUser.php 2019-09-17 14:39:24 UTC (rev 10260)
@@ -52,6 +52,7 @@
$action = $_POST["action"];
$is_active = $_POST["is_active"];
$create_digest = $_POST["create_digest"];
+$fkey_preferred_gui_id = $_POST["fkey_preferred_gui_id"];
require_once(dirname(__FILE__)."/../classes/class_user.php");
$myUser = true;
include "../../lib/editUser.php";
Modified: trunk/mapbender/http/php/mod_editUser.php
--- trunk/mapbender/http/php/mod_editUser.php 2019-09-17 14:02:32 UTC (rev 10259)
+++ trunk/mapbender/http/php/mod_editUser.php 2019-09-17 14:39:24 UTC (rev 10260)
@@ -25,7 +25,7 @@
//security_patch_log(__FILE__,__LINE__);
//import_request_variables("PG");
-$postvars = explode(",", "selected_user,name,firstname,lastname,academic_title,password,password_plain,v_password,description,email,phone,facsimile,street,housenumber,delivery_point,postal_code,city,organization,department,position,country,owner_name,owner_id,login_count,resolution,action,is_active, create_digest");
+$postvars = explode(",", "selected_user,name,firstname,lastname,academic_title,password,password_plain,v_password,description,email,phone,facsimile,street,housenumber,delivery_point,postal_code,city,organization,department,position,country,owner_name,owner_id,login_count,resolution,action,is_active, create_digest,fkey_preferred_gui_id");
foreach ($postvars as $value) {
${$value} = $_POST[$value];
Modified: trunk/mapbender/lib/editUser.php
--- trunk/mapbender/lib/editUser.php 2019-09-17 14:02:32 UTC (rev 10259)
+++ trunk/mapbender/lib/editUser.php 2019-09-17 14:39:24 UTC (rev 10260)
@@ -141,6 +141,12 @@
</head>
<body>
<?php
+if (defined("PREFERRED_GUI_CATEGORY") && is_int(PREFERRED_GUI_CATEGORY)) {
+ $preferredGuiCategory = PREFERRED_GUI_CATEGORY;
+} else {
+ $preferredGuiCategory = false;
//TODO: important - to extent form mod_editUser.php and mod_editFilteredUser.php have to include the allowed HTTP POST variables!!!!!!!!!!!
#delete
if ($action == 'delete' && (!isset($editSelf) || !$editSelf)) {
@@ -197,6 +203,7 @@
$user->isActive = 'f';
break;
+ $user->preferredGui = $fkey_preferred_gui_id;
$user->create();
$user->setNewUserPasswordTicket();
//TODO: check function !
@@ -258,10 +265,11 @@
break;
$user->commit();
if($withPasswordInsertion == 'true' && $password !== '' && $user->validUserPasswordTicket($user->passwordTicket)) {
$user->setPassword($password, $user->passwordTicket);
echo "<script language='JavaScript'>alert('Password has been updated successfully!');</script>";
@@ -300,6 +308,7 @@
$country = "";
$is_active = 'f';
$create_digest = 'f';
+ $fkey_preferred_gui_id = "";
@@ -336,7 +345,8 @@
$user = new User(intval($selected_user));
$data = $user->getFields();
+ //$available Guis :
+ //$e = new mb_exception("guis:".json_encode($user->getApplicationsByPermission (false, 2)));
if ($selected_user && intval($selected_user) === $user->id) {
echo '<option value="'.htmlentities($user->id, ENT_QUOTES, 'UTF-8').'" title="'.htmlentities($user->email, ENT_QUOTES, 'UTF-8').'" selected="selected">'.htmlentities($user->name, ENT_QUOTES, "UTF-8").'</option>';
@@ -374,7 +384,8 @@
$city = $data["city"];
$country = $data["country"];
$is_active = $data["isActive"];
- $create_digest = $data["createDigest"];
+ $create_digest = $data["createDigest"];
+ $fkey_preferred_gui_id = $data["preferredGui"];
@@ -584,6 +595,15 @@
echo "</td>";
echo "</tr>";
+#preferredGui
+if ($preferredGuiCategory != false && count($user->getApplicationsByPermission(false, $preferredGuiCategory)) > 0) {
+echo "<tr>";
+ echo "<td>"._mb("Preferred GUI")." (".implode(",", $user->getApplicationsByPermission(false, $preferredGuiCategory))."): </td>";
+ echo "<td>";
+ echo "<input type='text' size='30' name='fkey_preferred_gui_id' value='".htmlentities($fkey_preferred_gui_id, ENT_QUOTES, "UTF-8")."'>";
+ echo "</td>";
+echo "</tr>";
# blank row
echo "<tr>";
echo "<td colspan='2'> </td>";
Modified: trunk/mapbender/resources/db/pgsql/UTF-8/update/update_2.8_pgsql_UTF-8.sql
--- trunk/mapbender/resources/db/pgsql/UTF-8/update/update_2.8_pgsql_UTF-8.sql 2019-09-17 14:02:32 UTC (rev 10259)
+++ trunk/mapbender/resources/db/pgsql/UTF-8/update/update_2.8_pgsql_UTF-8.sql 2019-09-17 14:39:24 UTC (rev 10260)
@@ -135,3 +135,19 @@
-- 2019-09-13 - update css to have a nicer default gui!
update gui_element set e_width=null, e_height=null where e_id = 'body' AND fkey_gui_id IN ( 'Administration_DE', 'PortalAdmin_DE', 'admin1');
+-- 2019-0-17 - add option to have a preferred gui defined for a user account
+-- Column: fkey_preferred_gui_id
+-- ALTER TABLE mb_user DROP COLUMN fkey_preferred_gui_id;
+ALTER TABLE mb_user ADD COLUMN fkey_preferred_gui_id character varying(50);
+-- Foreign Key: fkey_preferred_gui_id_fkey
+-- ALTER TABLE mb_user DROP CONSTRAINT fkey_preferred_gui_id_fkey;
+ ADD CONSTRAINT fkey_preferred_gui_id_fkey FOREIGN KEY (fkey_preferred_gui_id)
+ REFERENCES gui (gui_id) MATCH SIMPLE
+ ON UPDATE CASCADE;
More information about the Mapbender_commits
