[Mapbender-commits] r10265 - trunk/mapbender/http/php
svn_mapbender at osgeo.org
Fri Sep 20 05:37:31 PDT 2019
Author: armin11
Date: 2019-09-20 05:37:31 -0700 (Fri, 20 Sep 2019)
New Revision: 10265
trunk/mapbender/http/php/mod_syncCkan_server.php
Fix for ckan 2.8+ - set id to update user
Modified: trunk/mapbender/http/php/mod_syncCkan_server.php
--- trunk/mapbender/http/php/mod_syncCkan_server.php 2019-09-18 14:35:16 UTC (rev 10264)
+++ trunk/mapbender/http/php/mod_syncCkan_server.php 2019-09-20 12:37:31 UTC (rev 10265)
@@ -268,8 +268,6 @@
if (isset($orgaId)){
$sql4 .= " AND mb_group_id = ".$orgaId."";
switch ($showOnlyDatasetMetadata) {
case "true":
if ($showOnlyUnlinkedOrganizations == "true") {
@@ -321,12 +319,13 @@
//try to read orga
$ckanResult = $syncCkanClass->getRemoteCkanOrga($requestPostJson);
$ckanResultObject = json_decode($ckanResult);
+ $e = new mb_notice("php/mod_syncCkan_server.php: check for existing orga in external ckan instance: ".$requestPostJson);
if ($ckanResultObject->success == true) {
//give back ckan id of organization
-$e = new mb_exception("orga found!");
+ $e = new mb_notice("php/mod_syncCkan_server.php: identical orga found in ckan");
//get revision_list of organization to get last change date!
$ckanResultOrgaRevList = $syncCkanClass->getRemoteCkanOrgaRevList($requestPostJson);
-$e = new mb_exception("orga rev list: ".$ckanResultOrgaRevList);
+//$e = new mb_exception("orga rev list: ".$ckanResultOrgaRevList);
//extract last timestamp:
$ckanResultOrgaRevListObject = json_decode($ckanResultOrgaRevList);
//check for update if needed!
@@ -337,30 +336,33 @@
//$dateTimeCkanOrga = new DateTime($ckanResultObject->result->created);
$dateTimeMapbenderOrga = new DateTime($orga->updated);
-$e = new mb_exception("datetime ckan: ".$dateTimeCkanOrga->format('Y-m-d H:i:s')." - datetime mapbender: ".$dateTimeMapbenderOrga->format('Y-m-d H:i:s'));
+ $e = new mb_notice("php/mod_syncCkan_server.php: compare timestamp of organizations: datetime ckan: ".$dateTimeCkanOrga->format('Y-m-d H:i:s')." - datetime mapbender: ".$dateTimeMapbenderOrga->format('Y-m-d H:i:s'));
if (($dateTimeCkanOrga < $dateTimeMapbenderOrga) || $ckanResultObject->result->state == "deleted") {
$ckanOrgaRepresentation = $syncCkanClass->getInternalOrgaAsCkan($orga->serialId);
$ckanResult = $syncCkanClass->updateRemoteCkanOrga($ckanOrgaRepresentation);
-$e = new mb_exception("update organization ! ".$ckanResult); //id needed!!!!
+ $e = new mb_notice("php/mod_syncCkan_server.php: update organization! ".$ckanResult); //id needed!!!!
} else {
-$e = new mb_exception("no update required!");
+ $e = new mb_notice("php/mod_syncCkan_server.php: no update of organization required!");
} else {
-$e = new mb_exception("organization not found - try to create it!");
+ $e = new mb_notice("php/mod_syncCkan_server.php: organization not found in ckan - try to create it!");
//try to create it
+ //forgotten to initialize a new group, when the uuid is alread available, but
+ $ckanOrgaRepresentation = $syncCkanClass->getInternalOrgaAsCkan($orga->serialId);
+//$e = new mb_exception("php/mod_syncCkan_server.php: try to create group id: ".$orga->serialId." ".$ckanOrgaRepresentation);
$ckanResult = $syncCkanClass->createRemoteCkanOrga($ckanOrgaRepresentation);
-$e = new mb_exception("result of creation: ". $ckanResult);
+//$e = new mb_exception("php/mod_syncCkan_server.php: result of creation: ". $ckanResult);
-$e = new mb_exception("organization successfully created!: ");
+ $e = new mb_notice("php/mod_syncCkan_server.php: organization successfully created!");
} else {
- $e = new mb_exception("an error occured when trying to create organization via ckan api! ");
+ $e = new mb_notice("php/mod_syncCkan_server.php: an error occured when trying to create organization via ckan api!");
} else {
- //read ckan representation of internal group from registry
+ //read ckan representation of internal group from registry - sync all ckan orgas with mapbender!!!!
+ //$e = new mb_exception("php/mod_syncCkan_server.php: returned ckan orga from mapbender: ".$ckanOrgaRepresentation);
$ckanOrgaRepresentationObject = json_decode($ckanOrgaRepresentation);
$ckanOrgaPreferredName = $ckanOrgaRepresentationObject->name;
$requestPost = new stdClass();
@@ -368,16 +370,16 @@
$requestPostJson = json_encode($requestPost);
//check if already exists and/or state is "deleted"- than update and set to active
-$e = new mb_exception("remote ckan organization: ".$ckanResult);
+//$e = new mb_exception("php/mod_syncCkan_server.php: remote ckan organization: ".$ckanResult);
if ($ckanResultObject->success == false) {
+ $e = new mb_notice("php/mod_syncCkan_server.php: organization not found - try to create it!");
//try to create it
+//$e = new mb_exception("php/mod_syncCkan_server.php: organization successfully created!: ");
//store uuid of external created ckan organization into mapbender database as foreign key
$sql = "UPDATE mb_group SET mb_group_ckan_uuid = $1 WHERE mb_group_id = $2";
$v = array($ckanResultObject->result->id, $orga->serialId);
@@ -408,7 +410,7 @@
$ckanOrgaRepresentationObject->id = $ckanResultObject->result->id;
$ckanOrgaRepresentation = json_encode($ckanOrgaRepresentationObject);
@@ -423,7 +425,7 @@
+ //$e = new mb_exception("update organization ! ".$ckanResult); //id needed!!!!
@@ -435,13 +437,13 @@
$requestPost->{'id'} = $editingUserName;
$ckanResultUser = $syncCkanClass->getRemoteCkanUser($requestPostJson);
-$e = new mb_exception("get user: ".$ckanResultUser); //id needed!!!!
- $ckanResultUserObject = json_decode($ckanResultUser);
+ $ckanResultUserObject = json_decode($ckanResultUser);
if ($ckanResultUserObject->success == true) {
//check if user has already editor role in organization
//update user
+ //get id from user if already exists - is needed for update since ckan 2.8+!
+ $requestPost->{'id'} = $ckanResultUserObject->result->id;
$requestPost->{'name'} = $editingUserName;
$requestPost->{'email'} = "kontakt at geoportal.rlp.de";
$requestPost->{'password'} = "1234".$editingUserName."5678";
@@ -450,7 +452,6 @@
//$requestPost->groups[1]->name = "opendata";
$ckanResultUser = $syncCkanClass->updateRemoteCkanUser($requestPostJson);
-$e = new mb_exception("update user: ".$ckanResultUser);
} else {
//create user
@@ -460,7 +461,7 @@
$ckanResultUser = $syncCkanClass->createRemoteCkanUser($requestPostJson);
+//$e = new mb_exception("get user: ".$ckanResultUser);
@@ -486,9 +487,9 @@
$requestPost->{'capacity'} = "editor";
$ckanResultMember = $syncCkanClass->getRemoteCkanMember($requestPostJson);
-$e = new mb_exception("get member: ".$ckanResultMember);
+//$e = new mb_exception("get member: ".$ckanResultMember);
$ckanResultMemberObject = json_decode($ckanResultMember);
-$e = new mb_exception("number of editors: ".count($ckanResultMemberObject->result));
+//$e = new mb_exception("number of editors: ".count($ckanResultMemberObject->result));
if (count($ckanResultMemberObject->result == 0)) {
//add membership for editor
@@ -498,27 +499,22 @@
$ckanResultMember = $syncCkanClass->createRemoteCkanMember($requestPostJson);
-$e = new mb_exception("get member after creating: ".$ckanResultMember);
+//$e = new mb_exception("get member after creating: ".$ckanResultMember);
//add user with role editor to groups "transparenzgesetz" and "opendata"
+ if (defined("CKAN_EDITOR_DEFAULT_GROUPS") && is_array(CKAN_EDITOR_DEFAULT_GROUPS)) {
+ foreach(CKAN_EDITOR_DEFAULT_GROUPS as $ckanGroup) {
- $requestPost->{'id'} = "transparenzgesetz";
+ $requestPost->{'id'} = $ckanGroup;
$requestPost->{'object'} = $userId;
$requestPost->{'object_type'} = "user";
- $requestPost = new stdClass();
- $requestPost->{'id'} = "opendata";
- $requestPost->{'object'} = $userId;
- $requestPost->{'object_type'} = "user";
- $requestPost->{'capacity'} = "editor";
- $requestPostJson = json_encode($requestPost);
- $ckanResultMember = $syncCkanClass->createRemoteCkanMember($requestPostJson);
header('Content-Type: application/json; charset='.CHARSET);
echo json_encode($returnObject, JSON_NUMERIC_CHECK);
More information about the Mapbender_commits
