[Mapbender-commits] r10267 - trunk/mapbender/http/php
svn_mapbender at osgeo.org svn_mapbender at osgeo.org
Mon Sep 23 23:32:21 PDT 2019
Author: hollsandre
Date: 2019-09-23 23:32:21 -0700 (Mon, 23 Sep 2019)
New Revision: 10267
   trunk/mapbender/http/php/mod_sessionWrapper.php
added possibility to change preferred gui in session
Modified: trunk/mapbender/http/php/mod_sessionWrapper.php
--- trunk/mapbender/http/php/mod_sessionWrapper.php	2019-09-23 06:45:26 UTC (rev 10266)
+++ trunk/mapbender/http/php/mod_sessionWrapper.php	2019-09-24 06:32:21 UTC (rev 10267)
@@ -6,7 +6,7 @@
 $key = "mb_user_id";
 $value = null;
 $allowedOperations = array("get", "set");
-$allowedKeys = array("mb_user_id", "GML", "dsgvo");
+$allowedKeys = array("mb_user_id", "GML", "dsgvo", "preferred_gui");
 $resultObj['result'] = '';
 $resultObj['success'] = false;
@@ -14,16 +14,16 @@
 //if (!($hostName == '127.0.0.1')) {
 if (!($hostName == 'localhost' or $hostName == '127.0.0.1')) {
-	$resultObj['message'] ='hostName not allowed - only local connections possible (localhost,127.0.0.1)';
+	$resultObj['message'] ='hostName not allowed - only local connections possible (localhost,127.0.0.1)';
 	$resultObj['result'] = null;
 	echo json_encode($resultObj);
-	die();
+	die();
 if (isset($_REQUEST["sessionId"]) & $_REQUEST["sessionId"] != "") {
 	//echo "<br>Requested sessionId: ".$_REQUEST["sessionId"]."<br>";
 } else {
-	$resultObj['message'] ='No sessionId given - please give parameter!';
+	$resultObj['message'] ='No sessionId given - please give parameter!';
 	die();
@@ -35,7 +35,7 @@
     session_id($_REQUEST["sessionId"]);
 } else {
     $e = new mb_exception("storage does not exist!");
-    $resultObj['message'] ='Requested session does not exists on server - please use existing identifier!';
+    $resultObj['message'] ='Requested session does not exists on server - please use existing identifier!';
     die();
@@ -42,17 +42,17 @@
 //parse operation
 if (isset($_REQUEST["operation"]) & $_REQUEST["operation"] != "") {
-	$testMatch = $_REQUEST["operation"];
+	$testMatch = $_REQUEST["operation"];
  	if (!in_array($testMatch, $allowedOperations)){
-    		$resultObj['message'] ='Parameter operation is not valid '.implode(',', $allowedOperations);
+    		$resultObj['message'] ='Parameter operation is not valid '.implode(',', $allowedOperations);
-    		die();
+    		die();
 	$operation = $testMatch;
 	$testMatch = NULL;
 } else {
-    	$resultObj['message'] ="Parameter operation not set - please set either ".implode(' or ', $allowedOperations);
+    	$resultObj['message'] ="Parameter operation not set - please set either ".implode(' or ', $allowedOperations);
 	die();
@@ -59,17 +59,17 @@
 //parse operation
 if (isset($_REQUEST["key"]) & $_REQUEST["key"] != "") {
-	$testMatch = $_REQUEST["key"];
- 	if (!in_array($testMatch, $allowedKeys)){
-    		$resultObj['message'] = 'Parameter key is not valid '.implode(',', $allowedKeys);
+	$testMatch = $_REQUEST["key"];
+ 	if (!in_array($testMatch, $allowedKeys)){
+    		$resultObj['message'] = 'Parameter key is not valid '.implode(',', $allowedKeys);
-    		echo json_encode($resultObj);
+    		echo json_encode($resultObj);
 		die();
 	$key = $testMatch;
 	$testMatch = NULL;
 } else {
-    	$resultObj['message'] = 'Parameter key not set - please set either '.implode(' or ', $allowedKeys);
+    	$resultObj['message'] = 'Parameter key not set - please set either '.implode(' or ', $allowedKeys);
 	die();
@@ -77,7 +77,7 @@
 switch ($operation) {
     case "get":
 	$resultObj['success'] = true;
-	$resultObj['message'] = 'Extracted session variable successfully!';
+	$resultObj['message'] = 'Extracted session variable successfully!';
     	$resultObj['result']->key = $key;
 	$resultObj['result']->value = Mapbender::session()->get($key);
@@ -90,16 +90,16 @@
 		//parse operation
 		if (isset($_REQUEST["value"]) & $_REQUEST["value"] != "") {
 			$testMatch = $_REQUEST["value"];
- 			/*if (!in_array($testMatch, $allowedKeys)){
+ 			/*if (!in_array($testMatch, $allowedKeys)){
 				die();
 			$value = urldecode($testMatch);
 			$testMatch = NULL;
 		} else {
-    			$resultObj['message'] = 'Parameter value for key '.$key.' not given!';
+    			$resultObj['message'] = 'Parameter value for key '.$key.' not given!';
 			die();
@@ -118,7 +118,7 @@
 			$GML .= "</coordinates></LinearRing></outerBoundaryIs></Polygon></polygonMember></MultiPolygon></the_geom></gemeinde></featureMember></FeatureCollection>";
 			Mapbender::session()->set('GML', $GML);
-			$resultObj['message'] = 'Dummy GML MultiPolygon written into session!';
+			$resultObj['message'] = 'Dummy GML MultiPolygon written into session!';
 			die();
@@ -125,7 +125,7 @@
 		Mapbender::session()->set('GML',$value);
-		$resultObj['message'] = 'GML written into session!';
+		$resultObj['message'] = 'GML written into session!';
 		die();
@@ -138,7 +138,7 @@
 				case "true":
 					Mapbender::session()->set($key, "yes");
-					$resultObj['message'] = 'Set dsgvo to yes!';
+					$resultObj['message'] = 'Set dsgvo to yes!';
 					die();
@@ -146,7 +146,7 @@
 				case "false":
 					Mapbender::session()->set($key, "no");
-					$resultObj['message'] = 'Set dsgvo to no!';
+					$resultObj['message'] = 'Set dsgvo to no!';
 					die();
@@ -154,7 +154,7 @@
 				default:
 					die();
@@ -163,8 +163,20 @@
 			$testMatch = NULL;
 	        break;
-            default:
-		$resultObj['message'] = 'Not allowed to set key: '.$key.' via http!';
+			case "preferred_gui":
+				if (isset($_REQUEST["value"]) & $_REQUEST["value"] != "") {
+					$testMatch = $_REQUEST["value"];
+					$value = urldecode($testMatch);
+					Mapbender::session()->set($key, $value);
+							$resultObj['success'] = true;
+							$resultObj['message'] = 'Set preferred_gui to'.$value.'!';
+							$resultObj['result'] = null;
+							die();
+			#		break;
+          default:
+		$resultObj['message'] = 'Not allowed to set key: '.$key.' via http!';
 		break;
More information about the Mapbender_commits mailing list
