[Mapbender-commits] r10384 - in trunk/mapbender/http: javascripts plugins
svn_mapbender at osgeo.org
Mon Jan 13 05:38:46 PST 2020
Author: hollsandre
Date: 2020-01-13 05:38:44 -0800 (Mon, 13 Jan 2020)
New Revision: 10384
trunk/mapbender/http/javascripts/mod_savewmc.js
trunk/mapbender/http/plugins/kmlTree.php
allowed some more character in regex
Modified: trunk/mapbender/http/javascripts/mod_savewmc.js
--- trunk/mapbender/http/javascripts/mod_savewmc.js 2020-01-02 08:02:38 UTC (rev 10383)
+++ trunk/mapbender/http/javascripts/mod_savewmc.js 2020-01-13 13:38:44 UTC (rev 10384)
@@ -112,7 +112,7 @@
String.prototype.hashCode = function() {
if (Array.prototype.reduce) {
- return this.split("").reduce(function(a,b){a=((a<<5)-a)+b.charCodeAt(0);return a&a},0);
+ return this.split("").reduce(function(a,b){a=((a<<5)-a)+b.charCodeAt(0);return a&a},0);
} else {
var hash = 0, i, chr, len;
@@ -194,13 +194,13 @@
mb_mapObj[0].kmlOrder = null;
var mapObjWithoutHistory = mb_mapObj;
- //set history and hash itself to null to identify same object and store the hash in a special field
+ //set history and hash itself to null to identify same object and store the hash in a special field
mapObjWithoutHistory[0].mb_MapHistoryObj = null;
that.mapObjHashWithoutHistory = $.toJSON(mapObjWithoutHistory).hashCode();
- //send mapObj without
+ //send mapObj without
var mapObjectToSend = $.toJSON(mb_mapObj);
//if compression is demanded see http://rosettacode.org/wiki/LZW_compression#JavaScript
if (beLzwCompressed == 'true') { //
@@ -362,8 +362,8 @@
attributes.isoTopicCat = isoTopicCat;
if(attributes.title != ""){
- if(!attributes.title.match(/^[a-zA-Z0-9\säöüÄÖÜß_\-]+$/)){
- alert("Allowed characters for title are: A-Z, a-z, 0-9, -, _");
+ if(!attributes.title.match(/^[a-zA-Z0-9äöüÄÖÜß_\- \"§&()?:,=/\s\\r\\n\\t]+$/)){
+ alert("Allowed characters for title are: A-Z, a-z, 0-9, -, _, äA, öO, üU, ß, \", , , =, /, &, §, (), : ");
return;
}else{
@@ -372,16 +372,16 @@
if(attributes.abstract != ""){
- if(!attributes.abstract.match(/^[a-zA-Z0-9\säöüÄÖÜß_\-]+$/)){
- alert("Allowed characters for abstract are: A-Z, a-z, 0-9, -, _");
+ if(!attributes.abstract.match(/^[a-zA-Z0-9äöüÄÖÜß_\- \"§&()?:,=/\s\\r\\n\\t]+$/)){
+ alert("Allowed characters for abstract are: A-Z, a-z, 0-9, -, _, äA, öO, üU, ß, \", , , =, /, &, §, (), : ");
return;
if(attributes.keywords != ""){
- if(!attributes.keywords.match(/^[a-zA-Z0-9\säöüÄÖÜß_\-]+$/)){
- alert("Allowed characters for keywords are: A-Z, a-z, 0-9, -, _");
+ if(!attributes.keywords.match(/^[a-zA-Z0-9äöüÄÖÜß_\- \"§&()?:,=/\s\\r\\n\\t]+$/)){
+ alert("Allowed characters for keywords are: A-Z, a-z, 0-9, -, _, äA, öO, üU, ß, \", , , =, /, &, §, (), : ");
return;
Modified: trunk/mapbender/http/plugins/kmlTree.php
--- trunk/mapbender/http/plugins/kmlTree.php 2020-01-02 08:02:38 UTC (rev 10383)
+++ trunk/mapbender/http/plugins/kmlTree.php 2020-01-13 13:38:44 UTC (rev 10384)
@@ -569,8 +569,8 @@
var version = 'v1'
if (title == '') {
return;
- } else if (!title.match(/^[a-zA-Z0-9-_]+$/)){
- alert("Allowed characters are: A-Z, a-z, 0-9, -, _");
+ } else if (!title.match(/^[a-zA-Z0-9äöüÄÖÜß_\- \"§&()?:,=/\s\\r\\n\\t]+$/)){
return;
kml.addLayer(title, {
@@ -875,7 +875,7 @@
var featureInfoFilter = ['title', 'marker-size', 'marker-symbol', 'marker-color',
'marker-offset-x', 'marker-offset-y', 'stroke', 'stroke-opacity',
'stroke-width', 'fill', 'fill-opacity'];
function escapeHTML(text) {
return text
.toString()
@@ -886,7 +886,7 @@
.replace(/'/g, ''')
.replace(/\//g, '/');
function createFeatureInfoContent(props) {
var $table = $("<table>")
.attr("border", 1);
@@ -900,7 +900,7 @@
return $table.attr('outerHTML');
this.getFeatureInfos = function (click) {
var map = Mapbender.modules.mapframe1;
var kml = $('#mapframe1').data('kml');
@@ -912,7 +912,7 @@
content: createFeatureInfoContent(kmlLayer.data.features[locator.id].properties)
Mapbender.events.init.register(function() {
More information about the Mapbender_commits
