[Mapbender-commits] r10392 - in trunk/mapbender: http/classes http/javascripts lib
svn_mapbender at osgeo.org
Mon Jan 27 08:47:42 PST 2020
Author: armin11
Date: 2020-01-27 08:47:42 -0800 (Mon, 27 Jan 2020)
New Revision: 10392
trunk/mapbender/http/classes/class_map.php
trunk/mapbender/http/javascripts/initWmcObj.php
trunk/mapbender/lib/class_GetApi.php
First draft for extending get-parameter for ZOOM=x,y,scale - only possible for projected crs at the moment
Modified: trunk/mapbender/http/classes/class_map.php
--- trunk/mapbender/http/classes/class_map.php 2020-01-27 08:30:31 UTC (rev 10391)
+++ trunk/mapbender/http/classes/class_map.php 2020-01-27 16:47:42 UTC (rev 10392)
@@ -165,7 +165,56 @@
return round($scale);
+ * @return new box for given poi (array) and scale (int)
+ public function getBboxFromPoiScale($point, $scale, $pointEpsg = false, $mapResolutionDpi = MB_RESOLUTION){
+ $geographicEpsgArray = array("EPSG:4326","EPSG:3857","EPSG:900913");
+ /*$scale;
+ $xtenty;
+ $bbox = $this->getExtentInfo();*/
+ $mapSetEpsg = $this->getEpsg();
+ if ($pointEpsg == false) { // point is interpreted as given in epsg of gui/wmc
+ if (in_array($mapSetEpsg, $geographicEpsgArray)) {
+ //wms 1.3.0 spec
+ //$scale = $distanceInDeegree * ((6378137 * M_PI) / 180) / $this->getHeight() / 0.00028;
+ //calculate it from height of image cause lat direction always has right great circle distances
+ $distanceInDeegree = $this->getHeight() * 0.00028 * (double)$scale * 360.0 / (2.0 * M_PI * 6378137.0);
+ //$e = new mb_exception("distance in deegree: ".$distanceInDeegree. " - scale: ".$scale. " - height: ".$this->getHeight());
+ $bbox[0] = $point[0] - ($distanceInDeegree / 2);
+ $bbox[1] = $point[1] - ($distanceInDeegree / 2);
+ $bbox[2] = $point[0] + ($distanceInDeegree / 2);
+ $bbox[3] = $point[1] + ($distanceInDeegree / 2);
+ } else {
+ $xtenty = $scale / ($mapResolutionDpi * 100) * $this->getWidth(); //x width in m
+ $ytenty = $scale / ($mapResolutionDpi * 100) * $this->getHeight();
+ $bbox[0] = $point[0] - ($xtenty / 2);
+ $bbox[1] = $point[1] - ($ytenty / 2);
+ $bbox[2] = $point[0] + ($xtenty / 2);
+ $bbox[3] = $point[1] + ($ytenty / 2);
+ return $bbox;
+ /*if ($this->getEpsg() == "EPSG:4326") {
+ $pxLenx = ($bbox[2] - $bbox[0]) / $this->getWidth();
+ $pxLeny = ($bbox[3] - $bbox[1]) / $this->getHeight();
+ $lat_from = ((($bbox[3] - $bbox[1]) / 2) * M_PI) / 180;
+ $lat_to = ((($bbox[3] - $bbox[1]) / 2 + $pxLeny) * M_PI) / 180;
+ $lon_from = ((($bbox[2] - $bbox[0]) / 2) * M_PI) / 180;
+ $lon_to = ((($bbox[2] - $bbox[0]) / 2 + $pxLeny) * M_PI) / 180;
+ $dist = 6371229 * acos(sin($lat_from) * sin($lat_to) + cos($lat_from) * cos($lat_to) * cos($lon_from - $lon_to));
+ $scale = ($dist / sqrt(2)) * ($mapResolutionDpi * 100);
+ else {
+ $xtenty = $bbox[3] - $bbox[1];
+ $scale = ($xtenty / $this->getHeight()) * ($mapResolutionDpi * 100);
+ return round($scale);*/
* @return String EPSG code of the map.
Modified: trunk/mapbender/http/javascripts/initWmcObj.php
--- trunk/mapbender/http/javascripts/initWmcObj.php 2020-01-27 08:30:31 UTC (rev 10391)
+++ trunk/mapbender/http/javascripts/initWmcObj.php 2020-01-27 16:47:42 UTC (rev 10392)
@@ -838,6 +838,27 @@
if(is_array($zoom)) {
$e = new mb_notice("javascripts/initWmcObj.php: check ZOOM API: ".implode(',', $zoom));
+if (count($zoom) == 3) {
+ //add zoom[2] to x and y and set bbox
+ //calculate new extent from scale -
+ $point = array($zoom[0], $zoom[1]);
+ $scale = $zoom[2];
+ $newExtent = $wmcGetApi->mainMap->getBboxFromPoiScale($point, $scale);
+ //Problem: TODO setExtent does not work properly for geographic EPSGs!!! test line 519 - if a point geometry is given by geojson
+ //$e = new mb_exception(json_encode($newExtent));
+ //$e = new mb_exception(json_encode($wmcGetApi->mainMap->getEpsg()));
+ $bbox = new Mapbender_bbox(
+ $newExtent[0],
+ $newExtent[1],
+ $newExtent[2],
+ $newExtent[3],
+ $epsg = $wmcGetApi->mainMap->getEpsg());
+ $wmcGetApi->mainMap->setExtent($bbox);
+ //render point at middle position
if (count($zoom) == 4 || count($zoom) == 5) {
$e = new mb_notice("javascripts/initWmcObject.php: found EXTENT");
if (count($zoom) == 5){
@@ -848,15 +869,21 @@
$zoom[3],
$epsg = $zoom[4]);
} else {
- // get current epsg from wmc bounding box
- // ViewContext->General->BoundingBox->SRS
- $e = new mb_notice("javascripts/initWmcObject.php: SRS found in current WMC: ".$wmcGetApi->mainMap->getEpsg());
- $bbox = new Mapbender_bbox(
- $zoom[0],
- $zoom[1],
- $zoom[2],
- $zoom[3],
- $epsg = $wmcGetApi->mainMap->getEpsg());
+ //check if zoom with scale and epsg is requested
+ if (strpos(strtolower($zoom[3], "epsg:") === 0 ) && is_numeric($zoom[0]) && is_numeric($zoom[1]) && is_numeric($zoom[2])) {
+ $e = new mb_notice("javascripts/initWmcObject.php: SRS found in zoom parameter: ".$zoom[4]);
+ //calculate bbox from central point with scale (or offset in m) - depends on epsg
+ } else {
+ // get current epsg from wmc bounding box
+ // ViewContext->General->BoundingBox->SRS
+ $e = new mb_notice("javascripts/initWmcObject.php: SRS found in current WMC: ".$wmcGetApi->mainMap->getEpsg());
+ $zoom[0],
+ $zoom[1],
+ $zoom[2],
+ $zoom[3],
Modified: trunk/mapbender/lib/class_GetApi.php
--- trunk/mapbender/lib/class_GetApi.php 2020-01-27 08:30:31 UTC (rev 10391)
+++ trunk/mapbender/lib/class_GetApi.php 2020-01-27 16:47:42 UTC (rev 10392)
@@ -285,20 +285,34 @@
$inputArray = explode(",", $input);
$input = array();
switch (count($inputArray)) {
+ case 3:
+ if (is_numeric($inputArray[0]) && is_numeric($inputArray[1]) && is_numeric($inputArray[2])) {
+ return $inputArray;
+ } else {
+ $e = new mb_exception("lib/class_GetApi.php: found non numeric value in zoom parameter!");
+ break;
case 4:
- //read out coordinates - have to be numeric values
- $i = 0;
- foreach ($inputArray as $id) {
- if (is_numeric($id)) {
- //do nothing
- } else {
- $e = new mb_exception("lib/class_GetApi.php: found non numeric value in zoom parameter: at pos ".$i." : ".$id);
- return false;
+ //check if last element begins with epsg: - then it will be the case, that zoom to coordinate with scale and special epsg is requested
+ if (strpos(strtolower($inputArray[3], "epsg:") === 0 ) && is_numeric($inputArray[0]) && is_numeric($inputArray[1]) && is_numeric($inputArray[2])) {
+ //extract epsg code ...
+ //create point object with scale ...
+ } else {
+ //read out coordinates - have to be numeric values
+ $i = 0;
+ foreach ($inputArray as $id) {
+ if (is_numeric($id)) {
+ //do nothing
+ } else {
+ $e = new mb_exception("lib/class_GetApi.php: found non numeric value in zoom parameter: at pos ".$i." : ".$id);
+ return false;
+ $i++;
- $i++;
- return $inputArray;
- break;
+ break;
case 5:
//read out coordinates and epsg
for ($i=0; $i < 4; $i++) {
@@ -317,11 +331,11 @@
return false;
return $inputArray;
- break;
+ break;
default:
//count doesn't match
return false;
- break;
+ break;
/*$i = 0;
More information about the Mapbender_commits
