[Mapbender-dev] Re: PHP 5 needed for next Mapbender
Leonhard Dietze dietze at geoinform.fh-mainz.de
Thu Jun 8 00:50:29 EDT 2006
>> I have no information regarding the use of PHP 4 and 5 on the same box
>> / webserver. (((.. but only thinking about it makes my head ache)))
> Yes, seems a little bit tricky to me, too.
> The hint from Björn would require to rename all files of one application
> (no good idea, especially because of all the references between files
> and the database...)
> Perhaps with virtual servers or different installations (i want to
> upgrade that box to apache2 anyway).
We have PHP4 and PHP5 running on the same server,
but one as cgi and the other one as Apache-Module.
But - as you said - I use differenz file extensions
for them to be able to use both versions: php- and
phtml-files
Regards,
Leo
More information about the Mapbender_dev mailing list
