[Mapbender-users] Mapbender version 2.2.3, 2.2.4, 2.3, 2.4
Till Adams adams at terrestris.de
Wed May 24 05:00:35 EDT 2006
Hallo Arnulf,
da Versionsnummern ja realistisch betrachtet hauptsächlich der
eindeutigen Unterscheidung dienen,
bin ich auch für eine eindeutige Regelung, das spräche für Mapbender
Version 2.4.
Das dann nicht vorhandene Release 2.3 würde dann sozusagen als
"Development Version" verschwinden,
vgl. UMN Mapserver Versionen 3.7,4.3, 4.5, 4.7.
Vielleicht sollte man generell bei neuen Releases, die auch mehr
Funktionalität bringen auf diese
Verisonierung springen, so daß die X.X.X-Versionen nur Bugfixes, aber
keine neuen Module mehr enthalten.
Das wäre an dieser Stelle dann konsequent.
And now in english:
Versioning is up to my mind in general useful when seperating different
versions. So I think a clear arrangement will help all,
this speaks in favor of version 2.4.
The then not released release (;-)) 2.3 would disappear as a development
version, comparable with the UMN Mapserver
versions 3.7,4.3,4.5,4.7
I think in genereal we should go this way: If a release has new
functions and modules, we give a new number like 2.5,2.6, etc.
If the reelase only has bugfixes, but no new modules, we can add a
X.X.number. This would be a clear way.
Till ;-)
Arnulf Christl schrieb:
>Hello,
>there has been some confusion lately regarding the next version. Regularly
>this would be v 2.2.4. In the Wiki it now says 2.3 and users (se below)
>already ask for 2.4.
>With respect to the migration and graduation process into OSGeo, the
>corresponding code cleaning, completely reworked OWS security proxy and
>digitizing modules I suggest that we directly move to 2.4. This will also
>help prevent people from confusing versions, I can already see us
>explaining that 2.3 is a newer version than 2.2.4... Try to keep it
>simple.
>The next version is scheduled for June - from a promo point of view it
>would be nice to have it out before Where 2.0 (June 10th) but I cannot
>judge whether this will be possible. So please comment on this and keep in
>mind that it might still be necessary to squeeze in some time regarding
>OSGeo graduation.
>This is the call for a vote for the 2.4 release by the 10th of June.
>If you +1 this be prepared to put in some extra hours. Especially the
>German language gui layout and the service metadata dump (caps) needs
>extra attention because of the extended character encoding support.
>In future we will have to manage versions and planning in the stable part
>of the Mapbender site (https://mapbender.osgeo.org), the Wiki seems to be
>no good for this.
>Arnulf.
>On Tue, May 16, 2006 11:37, ruth schÿfffff6nbuchner wrote:
>>Dear community,
>>  was there already fixed a day in may, when mapbender version 2.4 will be
>>downloadable?
>>  thanks for regard, ruth
>>Telefonieren Sie ohne weitere Kosten mit Ihren Freunden von PC zu PC!
>>Jetzt Yahoo! Messenger installieren!
*  released: AmeiN! ArcMap-Export-2-UMN  *
*        LiveLinux 'WebGIS on CD'        *
*        http://www.terrestris.de        *
Dipl. Geogr. Till Adams
terrestris, H. Paulsen& T. Adams GbR
Siemensstr. 8 * 53121 Bonn
Tel.: 0228 962 899 52 * Fax.: 0228 962 899 57
info at terrestris.de * http://www.terrestris.de
More information about the Mapbender_dev mailing list
