[Mapbender-dev] branches, tags and svn ...
Thomas Baschetti Thomas.Baschetti at gmx.de
Fri Nov 3 06:10:40 EST 2006
> You asked about the svn. At the moment we commit the new or changed code
> only to the mapbender trunk and don't offer a testbed.
> I think it's a good idea to setup a testarea where new code can be
> presented to the community. But I don't know, how this can be organized
> in the svn.
Don't know either, but it definitly would be nice.
> Another question we discussed about at the FOSSGIS 2006 was: Where can
> we leave code which is not generic or assume a special database or
> architecture or is not following the standars, but maybe is nice to have
> (some examples poi-search [needs configuration and geodata in a
> postgresql database], str/hsnr-search implemented on postgresql ...). It
> would be nice to have a branch where this code could be left.
What about a special directory?
For my modules i first used $MAPBENDEROOT/http/extensions,
at the moment i put all in a new directory in
$MAPBENDEROOT/http/itebo to
keep it separated from the original distribution.
I wanted to use a direcory-order like
 http/extensions/extension1
 http/extensions/extension2
 http/extensions/extension3
but this won't work because of code like
> require_once("../php/mb_validateSession.php");
which require to be only one level down.
Ciao
Thomas Baschetti
ITEBO GmbH
Der GMX SmartSurfer hilft bis zu 70% Ihrer Onlinekosten zu sparen!
Ideal für Modem und ISDN: http://www.gmx.net/de/go/smartsurfer
More information about the Mapbender_dev mailing list
