AJAX revisited
Christoph Baudson christoph.baudson at ccgis.de
Wed Nov 29 06:14:59 EST 2006
Hi there,
in a recent experiment with jQuery I added some AJAX-functionality to
Mapbender (see http://wms1.ccgis.de/mapbender_dev/, GUI
gui_digitize_modular).
When a geometry is sent to Geoserver I send the request via AJAX and not
via a frame:
parent.mb_ajax_get('../extensions/geom2wfst2.php',
{filter:str,url:myconf['wfs_transaction']},
function(xml,status){wfsSubWrite(m,type,status);});
'geom2wfst2.php' sends the geometry to Geoserver; the request is a
combination of the parameters 'url' and 'filter'.
The new thing is the function wfsSubWrite: it's a callback function,
invoked when the WFS request is finished. It refreshes the mapframe
after a geometry has been saved/deleted/updated. There are no more
synchronization problems.
Another advantage is, that geom2wfst2.php no longer has to handle the
xml result from Geoserver. It's simply returned to the callback function by
header('Content-type: text/xml');
echo $data;
The callback function can now check if any errors occured (still on my
to do list). This is the modular approach that we are after.
Cheers,
Christoph
More information about the Mapbender_dev mailing list
