[Mapbender-dev] Mapbender_Tutorial_>>_printversion_fyi
Christoph Baudson (WhereGroup) christoph.baudson at wheregroup.com
Thu Apr 5 08:12:22 EDT 2007
I think your approach is fine; although I think that actual Mapbender
users might have more insights to share. Maybe post to
mapbender_users at lists.osgeo.org
as well.
Thanks for your contribution,
Christoph
Heike Wirtz schrieb:
> Hello list,
> A printable version of the Mapbender-Tutorial is missing yet.
> I have started to generate a full version of "Mapbender_Tutorial_de".
> Please look at "Mapbender_tutorial_komplett" and the documentation at the
> head.
> First I want to inform you about the project and the chosen approach
> creating templates.
> Is it an acceptable solution?
> I would appreciate it if you give me a hint to improve the procedure.
> Perhaps it may be of more interest to change the approach (i.e. XML)?
> Greetings,
> Heike
> Hallo Liste,
> bislang existiert keine Printverion des Mapbender-Turorials.
> Mit Hilfe von Templates generiere ich nun eine Volltext-Version des
> Tutorials; der Projektfortschritt ist im "Mapbender_tutorial_komplett"
> dokumentiert.
> Sind Projekt und Vorgehensweise aus Eurer Sicht sinnvoll?
> Gibt es vielleicht eine strategisch sinnvollere Herangehensweise (xml)?
> Beste Grüße
> Heike
> Mapbender_dev mailing list
> Mapbender_dev at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/mapbender_dev
Baudson Christoph
http://www.wheregroup.com
More information about the Mapbender_dev mailing list
