[Mapbender-dev] Exception handling
Christoph Baudson (WhereGroup) christoph.baudson at wheregroup.com
Fri Apr 13 09:13:11 EDT 2007
Hello everyone,
today I added a more sophisticated exception handling to Mapbender. It
is just a draft and may be enhanced at anytime. Please let me know if
you think this is a sensible approach or if you have additional suggestions.
Description:
check mapbender.conf. There are new constants:
define("LOG_LEVEL", "warning");
this is the log level. Choose from the following list.
define("LOG_LEVEL_LIST", "off,error,warning,all");
The list is hierarchical:
off: ignores all
error: logs errors only
warning: logs errors and warnings
all: logs errors and warnings (and maybe others in the future)
Throw an exception (as before) via
$e = new mb_exception($message);
A warning may be thrown like this
$e = new mb_warning($message);
Both classes are inherited from mb_log, which basically is the "old"
mb_exception. For possible new types, a new class may be added easily.
For JavaScript exceptions, there are the following options
"on": via AJAX to PHP, then written in the error log file
"alert": the exception is being alerted
"console": the exception is being displayed by Firebug
"off": ignores JS exceptions
set via
define("LOG_JS", "on");
Throw it via
var e = new Mb_exception(message);
var e = new Mb_warning(message);
As each JS exception triggers an AJAX request, it might be sensible to
consider turning them off (or use console/alert).
Baudson Christoph
http://www.wheregroup.com
More information about the Mapbender_dev mailing list
