[Mapbender-dev] proposal: new column in db
Christoph Baudson (WhereGroup) christoph.baudson at wheregroup.com
Thu Aug 9 05:36:53 EDT 2007
Thanks, I have checked in the relevant code.
Sven Böhme (WhereGroup) schrieb:
> +1
> Sven
> Sebastian Schmitz schrieb:
>> +1
>> Sebastian
>> Samson, Marko schrieb:
>>> +1 to the new column
>>> @testbaudson have a nice vacation
>>> Marko
>>>> -----Original Message-----
>>>> From: mapbender_dev-bounces at lists.osgeo.org
>>>> [mailto:mapbender_dev-bounces at lists.osgeo.org] On Behalf Of Uli
>>>> Rothstein (WhereGroup)
>>>> Sent: Wednesday, August 08, 2007 8:41 AM
>>>> To: Mapbender Developer List
>>>> Subject: Re: [Mapbender-dev] proposal: new column in db
>>>> Hi,
>>>> +1 for the new column e_title.
>>>> best regards
>>>> Uli
>>>> Christoph Baudson (WhereGroup) schrieb:
>>>>> When experimenting with internationalization I realized
>>>> that there is
>>>>> a general need to separate content from structure in Mapbender.
>>>>> An example is the tooltip for each module, which originates from a
>>>>> database entry "e_attributes" in table "gui_element". A
>>>> typical entry
>>>>> would look like this:
>>>>> onclick='mod_addWMS()'  onmouseover='this.src =
>>>>> this.src.replace(/_off/,"_over");'  onmouseout='this.src =
>>>>> this.src.replace(/_over/, "_off");' title="Adding WMS"
>>>>> It's not easy extracting the translation of the title from
>>>> this field.
>>>>> So I propose to add a new column "e_title" to gui_element,
>>>> where the
>>>>> tooltip may come from. By this way, it will be easy to
>>>> translate the
>>>>> title as it is isolated.
>>>>> The title may also be used for the headers in the module "mod_tab".
>>>>> Please vote on my proposal ASAP, so I can check in the
>>>> relevant code
>>>>> before my vacation starting Saturday.
>>>>> Thanks
>>>>> Baudson Christoph
>>>>> http://www.wheregroup.com
>>>>> _______________________________________________
>>>>> Mapbender_dev mailing list
>>>>> Mapbender_dev at lists.osgeo.org
>>>>> http://lists.osgeo.org/mailman/listinfo/mapbender_dev
>>>> Ulrich Rothstein
>>>> WhereGroup GmbH & Co. KG
>>>> Siemensstraße 8
>>>> 53121 Bonn
>>>> Germany
>>>> Fon: +49 (0)228 / 90 90 38 - 17
>>>> Fax: +49 (0)228 / 90 90 38 - 11
>>>> mailto:uli.rothstein at wheregroup.com
>>>> Amtsgericht Bonn, HRA 6788
>>>> Komplementärin:
>>>> WhereGroup Verwaltungs GmbH
>>>> vertreten durch:
>>>> Arnulf Christl, Olaf Knopp, Peter Stamm
Baudson Christoph
More information about the Mapbender_dev mailing list
