[Mapbender-dev] Packer (code conventions)
Paul Spencer pspencer at dmsolutions.ca
Mon Feb 5 07:58:45 EST 2007
Christoph,
jsmin is an alternative to packer.
Cheers
Paul
On 5-Feb-07, at 6:44 AM, Christoph Baudson (WhereGroup) wrote:
> Hello,
> today I have tested the packer by Dean Edwards (http://
> dean.edwards.name/packer/usage/) by compressing the class point.js
> * I had to add a semicolon after every function statement to make
> it work.
> * The file size was reduced from 3.3Kb to 1.8Kb. For larger files
> the compression rate will be higher, for example jQuery is 55Kb
> uncompressed and 19Kb compressed.
> At a first glance I don't any other packer like Dean Edwards'. And
> to it seems like it's in wide use (searching for "dean edwards" AND
> "packer" results in 18000 google matches)
> The semicolon after functions is necessary if we want to use this
> packer. So do we want to use this packer? As a developer who works
> on a more theoretical level I'm not as much in touch with customer
> demands as others. But I sense that saving half the bandwidth
> weighs more than the addition of an (obscure) semicolon.
> I would love to hear some more opinions on this.
> Christoph
> Mapbender_dev mailing list
> Mapbender_dev at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/mapbender_dev
|Paul Spencer                          pspencer at dmsolutions.ca    |
|Chief Technology Officer                                         |
|DM Solutions Group Inc                http://www.dmsolutions.ca/ |
More information about the Mapbender_dev mailing list
