[Mapbender-dev] Mapbender on sourceforge and svn access
Astrid Emde (WhereGroup) astrid.emde at wheregroup.com
Tue Feb 13 10:15:22 EST 2007
Frank Warmerdam schrieb:
> Astrid Emde (WhereGroup) wrote:
>> hi list,
>> arnulf@
>> Marc Jansen should get svn access - could you give it to him?
> Astrid,
> Marc can create an OSGeo account at:
>   https://www.osgeo.org/cgi-bin/ldap_create_user.py
> Then someone (properly the Mapbender PSC chair, but sufficient would be
> someone known and trusted from the project) should file a ticket in
> the OSGeo Trac requesting he be added to the Mapbender SVN group:
>   http://trac.osgeo.org/trac/osgeo
> Please set the component to "SAC" (System Administration Committee).
> You may
> set the assigned to field to "warmerdam" to send the ticket directly
> to me,
> or let it default which will direct it to the SAC chair for assignment.
> A few details in the procedure may change in the coming weeks after which
> we will more fully document it for the sake of projects.
> Best regards,
Hi frank,
 thanx for the quick answer. i just tried it and followed the steps.
marc@ do you already have an osgeo-account?
greetings from bonn
astrid
More information about the Mapbender_dev mailing list
